path: root/backport/backport-include
2017-09-21header: add UUID_STRING_LENHauke Mehrtens
This was added in commit 2b1b0d6670 ("lib/uuid.c: introduce a few more generic helpers") and is used by ath10k. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-21header: add uuid backportsHauke Mehrtens
This backports the following upstream commits: f9727a17db9: ("uuid: rename uuid types") df33767d9fe: ("uuid: hoist helpers uuid_equal() and uuid_copy() from xfs") ath10k now makes use of them. Some parts should go into the uapi/linux/uuid.h file, but then #include_next hack is not working correctly any more, so place it all into the normal file. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-15backports: remove pm_system_wakeup(), add MWIFIEX dependencyJohannes Berg
Since only MWIFIEX needs pm_system_wakeup(), and that can't be backported properly, remove it again and add a dependency for MWIFIEX on kernel 3.18. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-11backports: add devm_add_action()Johannes Berg
2017-09-11header: add pm_system_wakeup()Hauke Mehrtens
This function was added in kernel 3.18 in commit 068765ba7987e ("PM / sleep: Mechanism for aborting system suspends unconditionally") In our implementation we only call pm_system_wakeup(() and do not handle the abortion of the current suspend process. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-11header: add __get_dynamic_array_lenHauke Mehrtens
This was added in kernel 3.16 in commit beba4bb096201 ("tracing: Add __get_dynamic_array_len() macro for trace events") Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-11header: add IOMEM_ERR_PTR()Hauke Mehrtens
This was added in kernel 3.17 in commit efd342fb0031a1 ("of: Provide a function to request and map memory") Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-11patches: brcmfmac: Fix netdev_set_priv_destructorHauke Mehrtens
On kernel > 4.11.9 the new member priv_destructor should be set in netdev_set_priv_destructor() and not the old destructor member any more, it was removed. This fixes the build on >= 4.11.9. Fixes: 7c827d5ac9c1 ("patches: brcmfmac: fix netdev destructor") Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-08headers: atomic: add atomic_try_cmpxchg()Johannes Berg
This is needed for the refcount code. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-08change protection of module_param_hw_arrayJohannes Berg
Some (distro) kernels backported this, so simply protect the backport definition with #ifndef. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-08header: acpi: fix version commentJohannes Berg
I intended to not even apply the patch, but did anyway... Fix the comment now. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06header: add dma_wmb()Hauke Mehrtens
This is used by the qtnfmac driver. This was added in commit 1077fa36f23e259 ("arch: Add lightweight memory barriers dma_rmb() and dma_wmb()") Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06header: add offsetofend()Hauke Mehrtens
offsetofend() was moved from vfio.h to stddef.h in commit 3876488444e7123 ("include/stddef.h: Move offsetofend() from vfio.h to a generic kernel header") for kernel 4.1. Add it again to stddef.h so it is available in more include paths. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06backport: add __print_array()Hauke Mehrtens
This is used in the tracing system and needed by wireless now, it was introduced in commit 6ea22486ba46bc ("tracing: Add array printing helper"). This code is copied from kernel 4.0. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06header: rename wait_queue_entry_t to wait_queue_tHauke Mehrtens
In kernel 4.13 wait_queue_t was renamed to wait_queue_entry_t, reverse this for older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06header: add get_random_u32()Hauke Mehrtens
This was renamed in upstream kernel and changed from unsigned int to u32. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06header: backport devm_acpi_dev_add_driver_gpios()Hauke Mehrtens
This is used by some NFC drivers to get information from the ACPI. This was added in kernel 4.13, but backporting it to older kernel versions than 3.19 is hard because such old kernel versions do not even have struct acpi_gpio_mapping. This only adds the empty version of this function as this normally needed some extra support in the generic ACPI code and I do not care about this functionality. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06header: add module_param_hw_array()Hauke Mehrtens
This macro is used for some module parameters. This hwtype was newly introduced for module parameters in kernel 4.12, just ignore it on older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06header: backport mii_ethtool_{get,set}_link_ksettings()Hauke Mehrtens
This function was added in kernel 4.10 and is needed by the usbnet drivers. These functions were added in upstream commit: bc8ee596afe8f3 ("net: mii: add generic function to support ksetting support") Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06header: skbuff: fix signature of skb_put(), skb_push() and __skb_push()Hauke Mehrtens
In older kernel versions these functions returned a unsigned char*, now they return a void *. This change was done in upstream commit d58ff35122847a8 ("networking: make skb_push & __skb_push return void pointers") Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06header: skbuff: add skb_put_zero(), skb_put_data() and skb_put_u8()Hauke Mehrtens
These functions were added in kernel 4.13 and are used by many driver now. This was added in the following upsteram comits: e45a79da863c19 ("skbuff/mac80211: introduce and use skb_put_zero()") 59ae1d127ac0ae ("networking: introduce and use skb_put_data()") 634fef61076d64 ("networking: add and use skb_put_u8()") Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-09-06backport: fix netdev destructor backport for v4.11.9Luca Coelho
The patch that changed the netdev destructor code was backported to v4.11.9, so handle that in the backport. Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-07-28backport: fix netdev destructor backportLuca Coelho
The commit that changed the netdev destructor was also applied in v4.12-rc6, so we need to update the backport. Another issue was that when the default free_netdev() destructor was supposed to be used, we would get compilation errors, such as this one in hwsim: In file included from ./include/net/dst.h:12:0, from /home/luca/iwlwifi/stack-dev/drivers/net/wireless/mac80211_hwsim.c:22: /home/luca/iwlwifi/stack-dev/drivers/net/wireless/mac80211_hwsim.c: In function hwsim_mon_setup': /home/luca/iwlwifi/stack-dev/backport-include/linux/netdevice.h:325:23: error: '__free_netdev' undeclared (first use in this function) (_dev)->destructor = __ ## _destructor ^ /home/luca/iwlwifi/stack-dev/drivers/net/wireless/mac80211_hwsim.c:2977:2: note: in expansion of macro 'netdev_set_priv_destructor' netdev_set_priv_destructor(dev, free_netdev); ^~~~~~~~~~~~~~~~~~~~~~~~~~ /home/luca/iwlwifi/stack-dev/backport-include/linux/netdevice.h:325:23: note: each undeclared identifier is reported only once for each function it appears in (_dev)->destructor = __ ## _destructor ^ /home/luca/iwlwifi/stack-dev/drivers/net/wireless/mac80211_hwsim.c:2977:2: note: in expansion of macro 'netdev_set_priv_destructor' netdev_set_priv_destructor(dev, free_netdev); ^~~~~~~~~~~~~~~~~~~~~~~~~~ scripts/Makefile.build:300: recipe for target '/home/luca/iwlwifi/stack-dev/drivers/net/wireless/mac80211_hwsim.o' failed To fix this, add a new macro, netdev_set_def_destructor(), that handles this special case. Change-Id: Ifcf1f19690487aee67e776b5700ff496c779e86c Fixes: 721ae78f9355 ("backport: handle change in netdevice destructor usage") Reviewed-by: Arend van Spriel <arend.vanspriel@broadcom.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
2017-06-30backport: handle change in netdevice destructor usageArend Van Spriel
This patch deals with changes made in struct net_device by commit cf124db566e6 ("net: Fix inconsistent teardown and release of private netdev state."). Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-06-16backports: add lockdep_rtnl_is_held() for < 3.13 without CONFIG_PROVE_LOCKINGLuca Coelho
In kernels earlier than 3.13, lockdep_rtnl_is_held() is only declared in rtnetlink.h when CONFIG_PROVE_LOCKING is not set. Backport this function if that's the case. Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-04-26backports: add the necessary backports for netlink extackJohannes Berg
2017-04-26backports: extend magic to 6 possible argumentsJohannes Berg
2017-03-31backports: provide backport for setup_deferrable_timer()Arend Van Spriel
Since commit f8f118ceaa56 ("mac80211: Use setup_timer instead of init_timer") mac80211 needs setup_deferrable_timer() which is not available in older kernels. Provide a backport in linux/timer.h. Really need two flavors of backport to support up to 3.0 kernel. Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-03-31backports: add dummy include/linux/sched/signal.hArend Van Spriel
Simply including linux/sched.h for older kernels not carrying this file. This new include file was introduced by commit 3f07c0144132 ("sched/headers: Prepare for new header dependencies before moving code to <linux/sched/signal.h>"). Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-03-31backports: copy average.h from original kernelJohannes Berg
Instead of maintaining our own version of average.h, just copy the upstream version while generating the backport. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-03-31backports: add backport for idr_removeArend Van Spriel
Since commit d3e709e63e97 ("idr: Return the deleted entry from idr_remove") the function signature changed so provide a backport which does a idr_find() and subsequent idr_remove(). Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-23backports: add definitions S32_MAX and S32_MINArend Van Spriel
Since commit 20e32810bcf4 ("cfg80211: Accept multiple RSSI thresholds for CQM") the backports need to have S32_MAX and S32_MIN which were introduced in kernel.h since v3.14. Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-14backports: add "MBIM Extended Functional Descriptor" structure definitionArend Van Spriel
commit 477c6d345604 ("backports: add USB_CDC_MBIM_EXTENDED_TYPE if needed") added define but the structure definition that goes with it is also needed. As they were introduced in the same kernel version we can add the structure with the same #ifndef USB_CDC_MBIM_EXTENDED_TYPE. Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-09backports: always use new version compare macrosJohannes Berg
2017-02-09backports: don't use __ro_after_init with genl families on <=4.9Johannes Berg
4.9 introduced __ro_after_init, but generic netlink family registration was only changed to allow it in 4.10, otherwise deregistration will crash due to writing to the RO memory. Unfortunately, spatch doesn't handle this, so manually patch the families to replace __ro_after_init with __genl_ro_after_init which is defined to nothing on kernel version <= 4.9. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-07backports: add USB_CDC_MBIM_EXTENDED_TYPE if neededJohannes Berg
2017-02-07backports: fix version checks for debugfs_real_fops()Johannes Berg
2017-02-07backports: remove some stray whitespaceJohannes Berg
2017-02-07backports: add dev_coredumpsg() where neededJohannes Berg
Add dev_coredumpsg() on kernels where dev_coredumpm() is present but _sg() isn't, and restrict building appropriately. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-07backports: add cdc_parse_cdc_header()Johannes Berg
2017-02-07backports: add linux/gpio/driver.hJohannes Berg
2017-02-07backports: add READ_ONCE and WRITE_ONCEJohannes Berg
2017-02-07backports: add devm_gpio_free()Johannes Berg
2017-02-07backports: add strscpy()Johannes Berg
2017-02-07backports: suppress led_set_brightness redefinition warningsJohannes Berg
2017-02-07backports: always add netdev_rss_key_fill()Johannes Berg
In case we can't do the _once thing, just always get new randomness... it's likely going to happen anyway, and if it's not exposed to userspace we don't have much value in sharing it to start with. While at it, clean it up a bit. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-07backports: add more OF functionsJohannes Berg
2017-02-07backports: disable thermal for kernels < 3.8Johannes Berg
2017-02-07backports: add sg_nents()Johannes Berg
2017-02-07backports: include mutex.h in leds-disabled.hJohannes Berg
