We moved HDMI DDC configuration to the device-tree.
If DDC config is missing from the device-tree
we default to v1.2 config.
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Update model and compatibility nodes to be more in-line with mainline.
Cosmetic clean-up to bring it more in-line with mainline driver in order
to be able to easily assess whether it is all kosher.
This automatically selects options for zone DMA and 64 bit DMA addresses
when LPAE is enabled on ARM Tegra platforms. These options are required
for proper operation with LPAE enabled.
The ZONE_DMA option is required to ensure that drivers that allocate DMA
memory get buffers from the first 4 GiB. This is necessary because a lot
of the controllers only support addressing 32 bits.
As for ARCH_DMA_ADDR_T_64BIT, there are situations where devices that do
support addresses of more than 32 bits (such as the display controller
or the GPU) can run without translating addresses through an IOMMU on a
device with more than 4 GiB of system memory.
Note that both of these options are stop-gap solutions required only
until the IOMMU can be properly integrated with the DMA mapping API and
drivers use that properly and consistently.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
[treding@nvidia.com: specify rationale for options]
Signed-off-by: Thierry Reding <treding@nvidia.com>
(backported from commit 6aa26c5d66595494e810c791602d87a572c78808)
With gcc 7 the following compile time error occurs:
| drivers/video/tegra/dc/dp.c:1178:12: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses]
| cr_done ? : ({ret = -EINVAL; goto fail; });
| drivers/video/tegra/dc/dp.c:1186:12: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses]
| lt_done ? : ({ret = -EINVAL; goto fail; });
| arch/arm/mach-tegra/tegra11_soctherm.c:2978:40: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses]
| s->sensor_enable = s->sensor_enable ?: therm->zone_enable;
| drivers/video/tegra/dc/dsi.c:766:34: error: '*' in boolean context, suggest '&&' instead [-Werror=int-in-bool-context]
| drivers/video/tegra/dc/dsi.c:757:1:
| (platform_t_phy_ps) ? ( \
| kernel-source/drivers/video/tegra/dc/dsi.c:766:34:
| dsi->info.phy_timing.t_tlpx_ns * 1000,
| drivers/video/tegra/dc/dsi.c:757:2: note: in definition of macro 'SELECT_T_PHY'
| arch/arm/mach-tegra/powergate-t12x.c:814:10: error: statement will never be executed [-Werror=switch-unreachable]
| return true;
| .../drivers/usb/gadget/tegra_udc.c:2565:17: error: 'out' directive writing 3 bytes into a region of size between 2 and 11 [-Werror=format-overflow=]
| sprintf(name, "ep%dout", i);
| .../drivers/usb/gadget/tegra_udc.c:2565:3: note: 'sprintf' output between 7 and 16 bytes into a destination of size 14
The last end point will never be greater than 32 but the compiler can
not find this out from the code. Work around this by passing a format
specifier to interpreat i as a signed char.
Activate PWM pin muxing for Apalis PWM3. Note that the same PWM3 is
already active on pu6 being Apalis BKL1_PWM as well. Therefore exporting
that one for raw sysfs access will fail and one has to revert to using
the pwm backlight.
Enable support for the Large Physical Address Extension aka LPAE.
Tegra spi driver was using devm_kzalloc before dev
was bound.
It turns out that the current PCIe reset implementation is not quite
working reliably due to some Intel i210 errata. Fix this by making sure
the i210's +V3.3_ETH rail is properly disabled during its reset
sequence.
Also further improve on the bringing up the PCIe switch as found on the
Apalis Evaluation board.
Toradex Carrier boards use the ST M41T0 RTC (not M41T00). The RTC
is almost the same, but the M41T0 needs some special handling in
case the oscillator fails. Now that support for this difference is
available, using the new compatible string to make use of it.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
The m41t0 variant is very similar to the already supported m41t00
variant, with the notable exception of the oscillator fail bit.
The data sheet notes:
If the oscillator fail (OF) bit is internally set to a '1,' this
indicates that the oscillator has either stopped, or was stopped
for some period of time and can be used to judge the validity of
the clock and date data.
The bit will get cleared with a regular write of the system time,
so no changes are needed to clear it.
(backported from commit 8566f70c8a90f3914b06e934852596ba94aaa381)
Prepare for snapd integration.
Change SPI2 clock parent to clk_m being 12 MHz which is anyway the
maximum frequency the K20 micro controller's SPI peripheral can be run.
This further allows for the EzPort to be run at exactly 2 MHz which is
the maximum allowed as well.
(cherry picked from commit 15e73283a975a1b899d7f6807aa882ef885573dd)
This patch includes CAN driver and improvements in SPI communications
for Apalis TK1 k20 based MFD.
Requires firmware version 0.9.
Drive current for LANE4 was not set if configured as 24bpp LVDS out.
Fix it by programming proper drive current register if using 24bpp out.
https://devtalk.nvidia.com/default/topic/1003030
Due to problems with LP0 sleep, make LP1 the default option.
Use modedb to set mode on Apalis TK1 frame buffer/display
controller.
Allow to specify framebuffer videomode using kernel command line
parameters. NVIDIAs binary X driver later on picks up those settings
and start X with current mode settings, if no EDID data are available.
Reused some of the implementation from Stefan's work for modedb
support[1] on Tegra20/30
[1] http://git.toradex.com/cgit/linux-toradex.git/commit/?h=tegra-next&id=1d3625dd9903bcc59e2df56836565ebb682948c1
Instead of providing revision, SKU and PID information
via soc_id pass SoC's unique ID.
It is require to dispose all virtual irq of hwirq on chip
created on given irq domain before removing this irq domain.
Hence dispose all mapped irqs before deleting the irq domains
in regmap_del_irq_chip();
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
irqdomain now supports removal of domains on exit so we can properly clean
up on deletion of a regmap irqchip.
Signed-off-by: Mark Brown <broonie@linaro.org>
Since commit 1c6c69525b40eb76de8adf039409722015927dc3 ("genirq: Reject
bogus threaded irq requests") threaded IRQs without a primary handler
need to be requested with IRQF_ONESHOT, otherwise the request will fail.
The %irq_flags flag is used to request the threaded IRQ and is also a
parameter of the caller. Hence, we cannot be sure that IRQF_ONESHOT is
set. This change avoids the potentially missing flag by setting
IRQF_ONESHOT when requesting the threaded IRQ.
Generated by: scripts/coccinelle/misc/irqf_oneshot.cocci
Signed-off-by: Valentin Rothberg <Valentin.Rothberg@lip6.fr>
Signed-off-by: Wojciech Bieganski <wbieganski@antmicro.com>
This reverts commit b2f6b2abc791802631ff1c85488cdf3c1f0a97e2.
Signed-off-by: Mariusz Glebocki <mglebocki@antmicro.com>
Configure GPIO connected to i210 wake-up pin
as a wake-up source in the device tree.
Fix suspend and resume for LP1 sleep.
Integrate latest igb driver version 5.3.5.4
(igb-5.3.5.4.tar.gz from e1000.sf.net).
While this fixes a build time warning using later gcc compilers it
should not have any further impact.
On Apalis TK1 boards K20 MCU is used
for CAN, GPIO, ADC and touch screen.
This patch includes support for core MFD device, GPIO, ADC
and touch screen.
Integrate support for the carrier board level I2C RTC.
Now with the working card detect pin in place on the latest V1.1 HW
polling is no longer required. Therefore make it an optional define for
V1.0 samples.
Add sd card detect SD1_CD# applicable for V1.1 modules using GPIO_PV2.
Configure Apalis MMC1 D6 GPIO on SDMMC3_CLK_LB_IN as reserved function
without any pull-up/down.
Configure GPIO_PV2 as SD1_CD# according to latest V1.1 HW.
Leave SDMMC3_CLK_LB_OUT muxed as SDMMC3 with output driver enabled aka
not tristated and input driver enabled as well as it features some
magic properties even though the external loopback is disabled and the
internal loopback used as per SDMMC_VENDOR_MISC_CNTRL_0 register's
SDMMC_SPARE1 bits being set to 0xfffd according to the TRM! This pin is
now a not-connect on V1.1 HW in order to avoid any interference.
