commit b602345da6cbb135ba68cf042df8ec9a73da7981 upstream.
If the result of an NFSv3 readdir{,plus} request results in the
"offset" on one entry having to be split across 2 pages, and is sized
so that the next directory entry doesn't fit in the requested size,
then memory corruption can happen.
When encode_entry() is called after encoding the last entry that fits,
it notices that ->offset and ->offset1 are set, and so stores the
offset value in the two pages as required. It clears ->offset1 but
*does not* clear ->offset.
Normally this omission doesn't matter as encode_entry_baggage() will
be called, and will set ->offset to a suitable value (not on a page
boundary).
But in the case where cd->buflen < elen and nfserr_toosmall is
returned, ->offset is not reset.
This means that nfsd3proc_readdirplus will see ->offset with a value 4
bytes before the end of a page, and ->offset1 set to NULL.
It will try to write 8bytes to ->offset.
If we are lucky, the next page will be read-only, and the system will
BUG: unable to handle kernel paging request at...
If we are unlucky, some innocent page will have the first 4 bytes
corrupted.
nfsd3proc_readdir() doesn't even check for ->offset1, it just blindly
writes 8 bytes to the offset wherever it is.
Fix this by clearing ->offset after it is used, and copying the
->offset handling code from nfsd3_proc_readdirplus into
nfsd3_proc_readdir.
(Note that the commit hash in the Fixes tag is from the 'history'
tree - this bug predates git).
Fixes: 0b1d57cf7654 ("[PATCH] kNFSd: Fix nfs3 dentry encoding")
Fixes-URL: https://git.kernel.org/pub/scm/linux/kernel/git/history/history.git/commit/?id=0b1d57cf7654
Cc: stable@vger.kernel.org (v2.6.12+)
Signed-off-by: NeilBrown <neilb@suse.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 8127d82705998568b52ac724e28e00941538083d upstream.
If the I/O completion failed with a fatal error, then we should just
exit nfs_pageio_complete_mirror() rather than try to recoalesce.
Fixes: a7d42ddb3099 ("nfs: add mirroring support to pgio layer")
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
Cc: stable@vger.kernel.org # v4.0+
commit 4d91969ed4dbcefd0e78f77494f0cb8fada9048a upstream.
Whether we need to exit early, or just reprocess the list, we
must not lost track of the request which failed to get recoalesced.
Fixes: 03d5eb65b538 ("NFS: Fix a memory leak in nfs_do_recoalesce")
commit f57dcf4c72113c745d83f1c65f7291299f65c14f upstream.
When we fail to add the request to the I/O queue, we currently leave it
to the caller to free the failed request. However since some of the
requests that fail are actually created by nfs_pageio_add_request()
itself, and are not passed back the caller, this leads to a leakage
issue, which can again cause page locks to leak.
This commit addresses the leakage by freeing the created requests on
error, using desc->pg_completion_ops->error_cleanup()
Fixes: a7d42ddb30997 ("nfs: add mirroring support to pgio layer")
Cc: stable@vger.kernel.org # v4.0: c18b96a1b862: nfs: clean up rest of reqs
Cc: stable@vger.kernel.org # v4.0: d600ad1f2bdb: NFS41: pop some layoutget
commit 0bdb50c531f7377a9da80d3ce2d61f389c84cb30 upstream.
A dm-raid array with devices larger than 4GB won't assemble on
a 32 bit host since _check_data_dev_sectors() was added in 4.16.
This is because to_sector() treats its argument as an "unsigned long"
which is 32bits (4GB) on a 32bit host. Using "unsigned long long"
is more correct.
Kernels as early as 4.2 can have other problems due to to_sector()
being used on the size of a device.
Fixes: 0cf4503174c1 ("dm raid: add support for the MD RAID0 personality")
cc: stable@vger.kernel.org (v4.2+)
Reported-and-tested-by: Guillaume Perréal <gperreal@free.fr>
Signed-off-by: NeilBrown <neil@brown.name>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit e2477233145f2156434afb799583bccd878f3e9f upstream.
Fix boolean expressions by using logical AND operator '&&' instead of
bitwise operator '&'.
This issue was detected with the help of Coccinelle.
Fixes: 4fa084af28ca ("ARM: OSIRIS: DVS (Dynamic Voltage Scaling) supoort.")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
[krzk: Fix -Wparentheses warning]
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit ca6d5149d2ad0a8d2f9c28cbe379802260a0a5e0 upstream.
GCC 8 warns about the logic in vr_get/set(), which with -Werror breaks
the build:
In function ‘user_regset_copyin’,
inlined from ‘vr_set’ at arch/powerpc/kernel/ptrace.c:628:9:
include/linux/regset.h:295:4: error: ‘memcpy’ offset [-527, -529] is
out of the bounds [0, 16] of object ‘vrsave’ with type ‘union
<anonymous>’ [-Werror=array-bounds]
arch/powerpc/kernel/ptrace.c: In function ‘vr_set’:
arch/powerpc/kernel/ptrace.c:623:5: note: ‘vrsave’ declared here
} vrsave;
This has been identified as a regression in GCC, see GCC bug 88273.
However we can avoid the warning and also simplify the logic and make
it more robust.
Currently we pass -1 as end_pos to user_regset_copyout(). This says
"copy up to the end of the regset".
The definition of the regset is:
[REGSET_VMX] = {
.core_note_type = NT_PPC_VMX, .n = 34,
.size = sizeof(vector128), .align = sizeof(vector128),
.active = vr_active, .get = vr_get, .set = vr_set
The end is calculated as (n * size), ie. 34 * sizeof(vector128).
In vr_get/set() we pass start_pos as 33 * sizeof(vector128), meaning
we can copy up to sizeof(vector128) into/out-of vrsave.
The on-stack vrsave is defined as:
union {
elf_vrreg_t reg;
u32 word;
} vrsave;
And elf_vrreg_t is:
typedef __vector128 elf_vrreg_t;
So there is no bug, but we rely on all those sizes lining up,
otherwise we would have a kernel stack exposure/overwrite on our
hands.
Rather than relying on that we can pass an explict end_pos based on
the sizeof(vrsave). The result should be exactly the same but it's
more obviously not over-reading/writing the stack and it avoids the
compiler warning.
Reported-by: Meelis Roos <mroos@linux.ee>
Reported-by: Mathieu Malaterre <malat@debian.org>
Tested-by: Mathieu Malaterre <malat@debian.org>
Tested-by: Meelis Roos <mroos@linux.ee>
commit fe1ef6bcdb4fca33434256a802a3ed6aacf0bd2f upstream.
Commit 8792468da5e1 "powerpc: Add the ability to save FPU without
giving it up" unexpectedly removed the MSR_FE0 and MSR_FE1 bits from
the bitmask used to update the MSR of the previous thread in
__giveup_fpu() causing a KVM-PR MacOS guest to lockup and panic the
host kernel.
Leaving FE0/1 enabled means unrelated processes might receive FPEs
when they're not expecting them and crash. In particular if this
happens to init the host will then panic.
eg (transcribed):
qemu-system-ppc[837]: unhandled signal 8 at 12cc9ce4 nip 12cc9ce4 lr 12cc9ca4 code 0
systemd[1]: unhandled signal 8 at 202f02e0 nip 202f02e0 lr 001003d4 code 0
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
Reinstate these bits to the MSR bitmask to enable MacOS guests to run
under 32-bit KVM-PR once again without issue.
Fixes: 8792468da5e1 ("powerpc: Add the ability to save FPU without giving it up")
Cc: stable@vger.kernel.org # v4.6+
Signed-off-by: Mark Cave-Ayland <mark.cave-ayland@ilande.co.uk>
commit 36da5ff0bea2dc67298150ead8d8471575c54c7d upstream.
The 83xx has 8 SPRG registers and uses at least SPRG4
for DTLB handling LRU.
Fixes: 2319f1239592 ("powerpc/mm: e300c2/c3/c4 TLB errata workaround")
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
commit 7b62f9bd2246b7d3d086e571397c14ba52645ef1 upstream.
Currently the opal log is globally readable. It is kernel policy to
limit the visibility of physical addresses / kernel pointers to root.
Given this and the fact the opal log may contain this information it
would be better to limit the readability to root.
Fixes: bfc36894a48b ("powerpc/powernv: Add OPAL message log interface")
Cc: stable@vger.kernel.org # v3.15+
Signed-off-by: Jordan Niethe <jniethe5@gmail.com>
Reviewed-by: Stewart Smith <stewart@linux.ibm.com>
Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
commit 6d183ca8baec983dc4208ca45ece3c36763df912 upstream.
'nobats' kernel parameter or some options like CONFIG_DEBUG_PAGEALLOC
deny the use of BATS for mapping memory.
This patch makes sure that the specific wii RAM mapping function
takes it into account as well.
Fixes: de32400dd26e ("wii: use both mem1 and mem2 as ram")
Reviewed-by: Jonathan Neuschafer <j.neuschaefer@gmx.net>
commit 9580b71b5a7863c24a9bd18bcd2ad759b86b1eff upstream.
Clear the on-stack STACK_FRAME_REGS_MARKER on exception exit in order
to avoid confusing stacktrace like the one below.
Call Trace:
[c0e9dca0] [c01c42a0] print_address_description+0x64/0x2bc (unreliable)
[c0e9dcd0] [c01c4684] kasan_report+0xfc/0x180
[c0e9dd10] [c0895130] memchr+0x24/0x74
[c0e9dd30] [c00a9e38] msg_print_text+0x124/0x574
[c0e9dde0] [c00ab710] console_unlock+0x114/0x4f8
[c0e9de40] [c00adc60] vprintk_emit+0x188/0x1c4
--- interrupt: c0e9df00 at 0x400f330
LR = init_stack+0x1f00/0x2000
[c0e9de80] [c00ae3c4] printk+0xa8/0xcc (unreliable)
[c0e9df20] [c0c27e44] early_irq_init+0x38/0x108
[c0e9df50] [c0c15434] start_kernel+0x310/0x488
[c0e9dff0] [00003484] 0x3484
With this patch the trace becomes:
Call Trace:
[c0e9dca0] [c01c42c0] print_address_description+0x64/0x2bc (unreliable)
[c0e9dcd0] [c01c46a4] kasan_report+0xfc/0x180
[c0e9dd10] [c0895150] memchr+0x24/0x74
[c0e9dd30] [c00a9e58] msg_print_text+0x124/0x574
[c0e9dde0] [c00ab730] console_unlock+0x114/0x4f8
[c0e9de40] [c00adc80] vprintk_emit+0x188/0x1c4
[c0e9de80] [c00ae3e4] printk+0xa8/0xcc
commit 01215d3edb0f384ddeaa5e4a22c1ae5ff634149f upstream.
The jh pointer may be used uninitialized in the two cases below and the
compiler complain about it when enabling JBUFFER_TRACE macro, fix them.
In file included from fs/jbd2/transaction.c:19:0:
fs/jbd2/transaction.c: In function ‘jbd2_journal_get_undo_access’:
./include/linux/jbd2.h:1637:38: warning: ‘jh’ is used uninitialized in this function [-Wuninitialized]
#define JBUFFER_TRACE(jh, info) do { printk("%s: %d\n", __func__, jh->b_jcount);} while (0)
fs/jbd2/transaction.c:1219:23: note: ‘jh’ was declared here
struct journal_head *jh;
fs/jbd2/transaction.c: In function ‘jbd2_journal_dirty_metadata’:
./include/linux/jbd2.h:1637:38: warning: ‘jh’ may be used uninitialized in this function [-Wmaybe-uninitialized]
fs/jbd2/transaction.c:1332:23: note: ‘jh’ was declared here
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 904cdbd41d749a476863a0ca41f6f396774f26e4 upstream.
Now, we capture a data corruption problem on ext4 while we're truncating
an extent index block. Imaging that if we are revoking a buffer which
has been journaled by the committing transaction, the buffer's jbddirty
flag will not be cleared in jbd2_journal_forget(), so the commit code
will set the buffer dirty flag again after refile the buffer.
fsx kjournald2
jbd2_journal_commit_transaction
jbd2_journal_revoke commit phase 1~5...
jbd2_journal_forget
belongs to older transaction commit phase 6
jbddirty not clear __jbd2_journal_refile_buffer
__jbd2_journal_unfile_buffer
test_clear_buffer_jbddirty
mark_buffer_dirty
Finally, if the freed extent index block was allocated again as data
block by some other files, it may corrupt the file data after writing
cached pages later, such as during unmount time. (In general,
clean_bdev_aliases() related helpers should be invoked after
re-allocation to prevent the above corruption, but unfortunately we
missed it when zeroout the head of extra extent blocks in
ext4_ext_handle_unwritten_extents()).
This patch mark buffer as freed and set j_next_transaction to the new
transaction when it already belongs to the committing transaction in
jbd2_journal_forget(), so that commit code knows it should clear dirty
bits when it is done with the buffer.
This problem can be reproduced by xfstests generic/455 easily with
seeds (3246 3247 3248 3249).
chip use the pci_pericom_setup()
commit 78d3820b9bd39028727c6aab7297b63c093db343 upstream.
The four port Pericom chips have the fourth port at the wrong address.
Make use of quirk to fix it.
Fixes: c8d192428f52 ("serial: 8250: added acces i/o products quad and octal serial cards")
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Jay Dolan <jay.dolan@accesio.com>
commit b896b03bc7fce43a07012cc6bf5e2ab2fddf3364 upstream.
Have the correct number of ports created for ACCES serial cards. Two port
cards show up as four ports, and four port cards show up as eight.
commit 5c31ef91c06db7800ad573174bd92be4df34ecb2 upstream.
below patch to fix Fourth port offset of Percom PI7C9X7954 boards.
I had a problem using Fourth port on a pci express serial board based on Pericom
PI7C9X7954. Reading datasheet I notice a "special" offset assign to this port
when used in I/O mode.
Offset 0x0 -> UART 0
Offset 0x8 -> UART 1
Offset 0x10 -> UART 2
Offset 0x38 -> UART 3 <<---- This don't follow a logical sequence
This patch add a different init to last port, to have right offset.
I check also Pericom 7952 and 7958 but that devices follow logical sequence,
so they are ok.
Regards,
Angelo
Signed-off-by: Angelo Butti <buttiangelo@gmail.com>
commit f4817843e39ce78aace0195a57d4e8500a65a898 upstream.
There are two other drivers that bind to mrvl,mmp-uart and both of them
assume register shift of 2 bits. There are device trees that lack the
property and rely on that assumption.
If this driver wins the race to bind to those devices, it should behave
the same as the older deprecated driver.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
commit 7abab1605139bc41442864c18f9573440f7ca105 upstream.
If RX is disabled while there are still unprocessed bytes in RX FIFO,
cdns_uart_handle_rx() called from interrupt handler will get stuck in
the receive loop as read bytes will not get removed from the RX FIFO
and CDNS_UART_SR_RXEMPTY bit will never get set.
Avoid the stuck handler by checking first if RX is disabled. port->lock
protects against race with RX-disabling functions.
This HW behavior was mentioned by Nathan Rossi in 43e98facc4a3 ("tty:
xuartps: Fix RX hang, and TX corruption in termios call") which fixed a
similar issue in cdns_uart_set_termios().
The behavior can also be easily verified by e.g. setting
CDNS_UART_CR_RX_DIS at the beginning of cdns_uart_handle_rx() - the
following loop will then get stuck.
Resetting the FIFO using RXRST would not set RXEMPTY either so simply
issuing a reset after RX-disable would not work.
I observe this frequently on a ZynqMP board during heavy RX load at 1M
baudrate when the reader process exits and thus RX gets disabled.
Fixes: 61ec9016988f ("tty/serial: add support for Xilinx PS UART")
Signed-off-by: Anssi Hannula <anssi.hannula@bitwise.fi>
[ Upstream commit ca22f32a6296cbfa29de56328c8505560a18cfa8 ]
Legacy behaviour was to allow non-page-aligned mmap requests, as does the
linux mmap(2) implementation by virtue of automatically rounding up for
the caller.
To avoid breaking legacy userspace relax the newly introduced fix.
Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Fixes: 5c4604e757ba ("drm/i915: Prevent a race during I915_GEM_MMAP ioctl with WC set")
Reported-by: Guenter Roeck <linux@roeck-us.net>
Cc: Adam Zabrocki <adamza@microsoft.com>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: <stable@vger.kernel.org> # v4.0+
Cc: Akash Goel <akash.goel@intel.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: intel-gfx@lists.freedesktop.org
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Link: https://patchwork.freedesktop.org/patch/msgid/20190305110409.28633-1-tvrtko.ursulin@linux.intel.com
(cherry picked from commit a90e1948efb648f567444f87f3c19b2a0787affd)
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
commit f4e3f4ae1d9c9330de355f432b69952e8cef650c upstream.
Tegra186 and prior supports maximum 4K bytes per packet transfer
including 12 bytes of packet header.
This patch fixes max write length limit to account packet header
size for transfers.
Cc: stable@vger.kernel.org # 4.4+
Reviewed-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Sowjanya Komatineni <skomatineni@nvidia.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 21698fd57984cd28207d841dbdaa026d6061bceb upstream.
In the original code before 181bf1e815a2 the loop was continuing until
it finds the first matching superios[i].io and p->base.
But after 181bf1e815a2 the logic changed and the loop now returns the
pointer to the first mismatched array element which is then used in
get_superio_dma() and get_superio_irq() and thus returning the wrong
value.
Fix the condition so that it now returns the correct pointer.
Fixes: 181bf1e815a2 ("parport_pc: clean up the modified while loops using for")
Cc: Alan Cox <alan@linux.intel.com>
Signed-off-by: QiaoChong <qiaochong@loongson.cn>
[rewrite the commit message]
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 9ed3f22223c33347ed963e7c7019cf2956dd4e37 upstream.
When an output port driver is removed, also remove references to it from
any masters. Failing to do this causes a NULL ptr dereference when
configuring another output port:
> BUG: unable to handle kernel NULL pointer dereference at 000000000000000d
> RIP: 0010:master_attr_store+0x9d/0x160 [intel_th_gth]
> Call Trace:
> dev_attr_store+0x1b/0x30
> sysfs_kf_write+0x3c/0x50
> kernfs_fop_write+0x125/0x1a0
> __vfs_write+0x3a/0x190
> ? __vfs_write+0x5/0x190
> ? _cond_resched+0x1a/0x50
> ? rcu_all_qs+0x5/0xb0
> vfs_write+0xb8/0x1b0
> ksys_write+0x55/0xc0
> __x64_sys_write+0x1a/0x20
> do_syscall_64+0x5a/0x140
> entry_SYSCALL_64_after_hwframe+0x44/0xa9
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Fixes: b27a6a3f97b9 ("intel_th: Add Global Trace Hub driver")
CC: stable@vger.kernel.org # v4.4+
Reported-by: Ammy Yi <ammy.yi@intel.com>
commit 2b6e492467c78183bb629bb0a100ea3509b615a5 upstream.
With string type property entries we need to use
sizeof(const char *) instead of the number of characters as
the length of the entry.
If the string was shorter then sizeof(const char *),
attempts to read it would have failed with -EOVERFLOW. The
problem has been hidden because all build-in string
properties have had a string longer then 8 characters until
now.
Fixes: a85f42047533 ("device property: helper macros for property entry creation")
Cc: 4.5+ <stable@vger.kernel.org> # 4.5+
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
commit 8cf7630b29701d364f8df4a50e4f1f5e752b2778 upstream.
This bug has apparently existed since the introduction of this function
in the pre-git era (4500e91754d3 in Thomas Gleixner's history.git,
"[NET]: Add proc_dointvec_userhz_jiffies, use it for proper handling of
neighbour sysctls.").
As a minimal fix we can simply duplicate the corresponding check in
do_proc_dointvec_conv().
Link: http://lkml.kernel.org/r/20190207123426.9202-3-zev@bewilderbeest.net
Signed-off-by: Zev Weiss <zev@bewilderbeest.net>
Cc: Brendan Higgins <brendanhiggins@google.com>
Cc: Iurii Zaikin <yzaikin@google.com>
Cc: Luis Chamberlain <mcgrof@kernel.org>
Cc: <stable@vger.kernel.org> [2.6.2+]
commit 401592d2e095947344e10ec0623adbcd58934dd4 upstream.
When VM_NO_GUARD is not set area->size includes adjacent guard page,
thus for correct size checking get_vm_area_size() should be used, but
not area->size.
This fixes possible kernel oops when userspace tries to mmap an area on
1 page bigger than was allocated by vmalloc_user() call: the size check
inside remap_vmalloc_range_partial() accounts non-existing guard page
also, so check successfully passes but vmalloc_to_page() returns NULL
(guard page does not physically exist).
The following code pattern example should trigger an oops:
static int oops_mmap(struct file *file, struct vm_area_struct *vma)
void *mem;
mem = vmalloc_user(4096);
BUG_ON(!mem);
/* Do not care about mem leak */
return remap_vmalloc_range(vma, mem, 0);
And userspace simply mmaps size + PAGE_SIZE:
mmap(NULL, 8192, PROT_WRITE|PROT_READ, MAP_PRIVATE, fd, 0);
Possible candidates for oops which do not have any explicit size
checks:
*** drivers/media/usb/stkwebcam/stk-webcam.c:
v4l_stk_mmap[789] ret = remap_vmalloc_range(vma, sbuf->buffer, 0);
Or the following one:
*** drivers/video/fbdev/core/fbmem.c
static int
fb_mmap(struct file *file, struct vm_area_struct * vma)
res = fb->fb_mmap(info, vma);
Where fb_mmap callback calls remap_vmalloc_range() directly without any
explicit checks:
*** drivers/video/fbdev/vfb.c
static int vfb_mmap(struct fb_info *info,
return remap_vmalloc_range(vma, (void *)info->fix.smem_start, vma->vm_pgoff);
Link: http://lkml.kernel.org/r/20190103145954.16942-2-rpenyaev@suse.de
Signed-off-by: Roman Penyaev <rpenyaev@suse.de>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Joe Perches <joe@perches.com>
Cc: "Luis R. Rodriguez" <mcgrof@kernel.org>
commit 46612b751c4941c5c0472ddf04027e877ae5990f upstream.
When soft_offline_in_use_page() runs on a thp tail page after pmd is
split, we trigger the following VM_BUG_ON_PAGE():
Memory failure: 0x3755ff: non anonymous thp
__get_any_page: 0x3755ff: unknown zero refcount page type 2fffff80000000
Soft offlining pfn 0x34d805 at process virtual address 0x20fff000
page:ffffea000d360140 count:0 mapcount:0 mapping:0000000000000000 index:0x1
flags: 0x2fffff80000000()
raw: 002fffff80000000 ffffea000d360108 ffffea000d360188 0000000000000000
raw: 0000000000000001 0000000000000000 00000000ffffffff 0000000000000000
page dumped because: VM_BUG_ON_PAGE(page_ref_count(page) == 0)
kernel BUG at ./include/linux/mm.h:519!
soft_offline_in_use_page() passed refcount and page lock from tail page
to head page, which is not needed because we can pass any subpage to
split_huge_page().
Naoya had fixed a similar issue in c3901e722b29 ("mm: hwpoison: fix thp
split handling in memory_failure()"). But he missed fixing soft
offline.
Link: http://lkml.kernel.org/r/1551452476-24000-1-git-send-email-zhongjiang@huawei.com
Fixes: 61f5d698cc97 ("mm: re-enable THP")
Signed-off-by: zhongjiang <zhongjiang@huawei.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: <stable@vger.kernel.org> [4.5+]
commit 43f89877f26671c6309cd87d7364b1a3e66e71cf upstream.
In the case of ND_CMD_CALL, we should also check out_obj->type.
The patch uses out_obj->type, which is a short alias to
out_obj->package.type.
Fixes: 31eca76ba2fc ("nfit, libnvdimm: limited/whitelisted dimm command marshaling mechanism")
Signed-off-by: Dexuan Cui <decui@microsoft.com>
commit 7ca4c922aad2e3c46767a12f80d01c6b25337b59 upstream.
The 'div' field does not represent a number of bits used to divide
(understand: right-shift) the divider, but a number itself used to
divide the divider.
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
Signed-off-by: Maarten ter Huurne <maarten@treewalker.org>
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
commit bc5d922c93491878c44c9216e9d227c7eeb81d7f upstream.
Take a parent rate of 180 MHz, and a requested rate of 4.285715 MHz.
This results in a theorical divider of 41.999993 which is then rounded
up to 42. The .round_rate function would then return (180 MHz / 42) as
the clock, rounded down, so 4.285714 MHz.
Calling clk_set_rate on 4.285714 MHz would round the rate again, and
give a theorical divider of 42,0000028, now rounded up to 43, and the
rate returned would be (180 MHz / 43) which is 4.186046 MHz, aka. not
what we requested.
Fix this by rounding up the divisions.
Tested-by: Maarten ter Huurne <maarten@treewalker.org>
commit 5ae51d67aec95f6f9386aa8dd5db424964895575 upstream.
I noticed that modprobe clk-twl6040 can fail after a cold boot with:
abe_cm:clk:0010:0: failed to enable
Unhandled fault: imprecise external abort (0x1406) at 0xbe896b20
WARNING: CPU: 1 PID: 29 at drivers/clk/clk.c:828 clk_core_disable_lock+0x18/0x24
(clk_core_disable_lock) from [<c0123534>] (_disable_clocks+0x18/0x90)
(_disable_clocks) from [<c0124040>] (_idle+0x17c/0x244)
(_idle) from [<c0125ad4>] (omap_hwmod_idle+0x24/0x44)
(omap_hwmod_idle) from [<c053a038>] (sysc_runtime_suspend+0x48/0x108)
(sysc_runtime_suspend) from [<c06084c4>] (__rpm_callback+0x144/0x1d8)
(__rpm_callback) from [<c0608578>] (rpm_callback+0x20/0x80)
(rpm_callback) from [<c0607034>] (rpm_suspend+0x120/0x694)
(rpm_suspend) from [<c0607a78>] (__pm_runtime_idle+0x60/0x84)
(__pm_runtime_idle) from [<c053aaf0>] (sysc_probe+0x874/0xf2c)
(sysc_probe) from [<c05fecd4>] (platform_drv_probe+0x48/0x98)
After searching around for a similar issue, I came across an earlier fix
that never got merged upstream in the Android tree for glass-omap-xrr02.
There is patch "MFD: twl6040-codec: Implement PDMCLK cold temp errata"
by Misael Lopez Cruz <misael.lopez@ti.com>.
Based on my observations, this fix is also needed when cold booting
devices, and not just for deeper idle modes. Since we now have a clock
driver for pdmclk, let's fix the issue in twl6040_pdmclk_prepare().
Cc: Misael Lopez Cruz <misael.lopez@ti.com>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
commit 1c2d14212b15a60300a2d4f6364753e87394c521 upstream.
When ext2 filesystem is created with 64k block size, ext2_max_size()
will return value less than 0. Also, we cannot write any file in this fs
since the sb->maxbytes is less than 0. The core of the problem is that
the size of block index tree for such large block size is more than
i_blocks can carry. So fix the computation to count with this
possibility.
File size limits computed with the new function for the full range of
possible block sizes look like:
bits file_size
10 17247252480
11 275415851008
12 2196873666560
13 2197948973056
14 2198486220800
15 2198754754560
16 2198888906752
Reported-by: yangerkun <yangerkun@huawei.com>
commit f96c3ac8dfc24b4e38fc4c2eba5fea2107b929d1 upstream.
When computing maximum size of filesystem possible with given number of
group descriptor blocks, we forget to include s_first_data_block into
the number of blocks. Thus for filesystems with non-zero
s_first_data_block it can happen that computed maximum filesystem size
is actually lower than current filesystem size which confuses the code
and eventually leads to a BUG_ON in ext4_alloc_group_tables() hitting on
flex_gd->count == 0. The problem can be reproduced like:
truncate -s 100g /tmp/image
mkfs.ext4 -b 1024 -E resize=262144 /tmp/image 32768
mount -t ext4 -o loop /tmp/image /mnt
resize2fs /dev/loop0 262145
resize2fs /dev/loop0 300000
Fix the problem by properly including s_first_data_block into the
computed number of filesystem blocks.
Fixes: 1c6bd7173d66 "ext4: convert file system to meta_bg if needed..."
commit 9505b98ccddc454008ca7efff90044e3e857c827 upstream.
pxa_cpufreq_init_voltages() is marked __init but usually inlined into
the non-__init pxa_cpufreq_init() function. When building with clang,
it can stay as a standalone function in a discarded section, and produce
this warning:
WARNING: vmlinux.o(.text+0x616a00): Section mismatch in reference from the function pxa_cpufreq_init() to the function .init.text:pxa_cpufreq_init_voltages()
The function pxa_cpufreq_init() references
the function __init pxa_cpufreq_init_voltages().
This is often because pxa_cpufreq_init lacks a __init
annotation or the annotation of pxa_cpufreq_init_voltages is wrong.
Fixes: 50e77fcd790e ("ARM: pxa: remove __init from cpufreq_driver->init()")
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: All applicable <stable@vger.kernel.org>
commit 446fae2bb5395f3028d8e3aae1508737e5a72ea1 upstream.
of_cpu_device_node_get() will increase the refcount of device_node,
it is necessary to call of_node_put() at the end to release the
refcount.
Fixes: 9eb15dbbfa1a2 ("cpufreq: Add cpufreq driver for Tegra124")
Cc: <stable@vger.kernel.org> # 4.4+
Signed-off-by: Yangtao Li <tiny.windzz@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 607076a904c435f2677fadaadd4af546279db68b upstream.
It doesn't make sense and the USB core warns on each submit of such
URB, easily flooding the message buffer with tracebacks.
Analogous issue was fixed in regular libertas driver in commit 6528d8804780
("libertas: don't set URB_ZERO_PACKET on IN USB transfer").
Reviewed-by: Steve deRosier <derosier@cal-sierra.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 251b7aea34ba3c4d4fdfa9447695642eb8b8b098 upstream.
The memcpy()s in the PCBC implementation use walk->iv as both the source
and destination, which has undefined behavior. These memcpy()'s are
actually unneeded, because walk->iv is already used to hold the previous
plaintext block XOR'd with the previous ciphertext block. Thus,
walk->iv is already updated to its final value.
So remove the broken and unnecessary memcpy()s.
Fixes: 91652be5d1b9 ("[CRYPTO] pcbc: Add Propagated CBC template")
Cc: <stable@vger.kernel.org> # v2.6.21+
Signed-off-by: Maxim Zhukov <mussitantesmortem@gmail.com>
commit 8e928218780e2f1cf2f5891c7575e8f0b284fcce upstream.
In the past we had data corruption when reading compressed extents that
are shared within the same file and they are consecutive, this got fixed
by commit 005efedf2c7d0 ("Btrfs: fix read corruption of compressed and
shared extents") and by commit 808f80b46790f ("Btrfs: update fix for read
corruption of compressed and shared extents"). However there was a case
that was missing in those fixes, which is when the shared and compressed
extents are referenced with a non-zero offset. The following shell script
creates a reproducer for this issue:
#!/bin/bash
mkfs.btrfs -f /dev/sdc &> /dev/null
mount -o compress /dev/sdc /mnt/sdc
# Create a file with 3 consecutive compressed extents, each has an
# uncompressed size of 128Kb and a compressed size of 4Kb.
for ((i = 1; i <= 3; i++)); do
head -c 4096 /dev/zero
for ((j = 1; j <= 31; j++)); do
head -c 4096 /dev/zero | tr '\0' "\377"
done
done > /mnt/sdc/foobar
sync
echo "Digest after file creation: $(md5sum /mnt/sdc/foobar)"
# Clone the first extent into offsets 128K and 256K.
xfs_io -c "reflink /mnt/sdc/foobar 0 128K 128K" /mnt/sdc/foobar
xfs_io -c "reflink /mnt/sdc/foobar 0 256K 128K" /mnt/sdc/foobar
sync
echo "Digest after cloning: $(md5sum /mnt/sdc/foobar)"
# Punch holes into the regions that are already full of zeroes.
xfs_io -c "fpunch 0 4K" /mnt/sdc/foobar
xfs_io -c "fpunch 128K 4K" /mnt/sdc/foobar
xfs_io -c "fpunch 256K 4K" /mnt/sdc/foobar
sync
echo "Digest after hole punching: $(md5sum /mnt/sdc/foobar)"
echo "Dropping page cache..."
sysctl -q vm.drop_caches=1
umount /dev/sdc
When running the script we get the following output:
Digest after file creation: 5a0888d80d7ab1fd31c229f83a3bbcc8 /mnt/sdc/foobar
linked 131072/131072 bytes at offset 131072
128 KiB, 1 ops; 0.0033 sec (36.960 MiB/sec and 295.6830 ops/sec)
linked 131072/131072 bytes at offset 262144
128 KiB, 1 ops; 0.0015 sec (78.567 MiB/sec and 628.5355 ops/sec)
Digest after cloning: 5a0888d80d7ab1fd31c229f83a3bbcc8 /mnt/sdc/foobar
Digest after hole punching: 5a0888d80d7ab1fd31c229f83a3bbcc8 /mnt/sdc/foobar
Digest after hole punching: fba694ae8664ed0c2e9ff8937e7f1484 /mnt/sdc/foobar
This happens because after reading all the pages of the extent in the
range from 128K to 256K for example, we read the hole at offset 256K
and then when reading the page at offset 260K we don't submit the
existing bio, which is responsible for filling all the page in the
range 128K to 256K only, therefore adding the pages from range 260K
to 384K to the existing bio and submitting it after iterating over the
entire range. Once the bio completes, the uncompressed data fills only
the pages in the range 128K to 256K because there's no more data read
from disk, leaving the pages in the range 260K to 384K unfilled. It is
just a slightly different variant of what was solved by commit
005efedf2c7d0 ("Btrfs: fix read corruption of compressed and shared
extents").
Fix this by forcing a bio submit, during readpages(), whenever we find a
compressed extent map for a page that is different from the extent map
for the previous page or has a different starting offset (in case it's
the same compressed extent), instead of the extent map's original start
offset.
A test case for fstests follows soon.
Reported-by: Zygo Blaxell <ce3g8jdj@umail.furryterror.org>
Fixes: 808f80b46790f ("Btrfs: update fix for read corruption of compressed and shared extents")
Fixes: 005efedf2c7d0 ("Btrfs: fix read corruption of compressed and shared extents")
Cc: stable@vger.kernel.org # 4.3+
Tested-by: Zygo Blaxell <ce3g8jdj@umail.furryterror.org>
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit 349ae63f40638a28c6fce52e8447c2d14b84cc0c upstream.
We recently had a customer issue with a corrupted filesystem. When
trying to mount this image btrfs panicked with a division by zero in
calc_stripe_length().
The corrupt chunk had a 'num_stripes' value of 1. calc_stripe_length()
takes this value and divides it by the number of copies the RAID profile
is expected to have to calculate the amount of data stripes. As a DUP
profile is expected to have 2 copies this division resulted in 1/2 = 0.
Later then the 'data_stripes' variable is used as a divisor in the
stripe length calculation which results in a division by 0 and thus a
kernel panic.
When encountering a filesystem with a DUP block group and a
'num_stripes' value unequal to 2, refuse mounting as the image is
corrupted and will lead to unexpected behaviour.
Code inspection showed a RAID1 block group has the same issues.
Fixes: e06cd3dd7cea ("Btrfs: add validadtion checks for chunk loading")
CC: stable@vger.kernel.org # 4.4+
Reviewed-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: Nikolay Borisov <nborisov@suse.com>
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: David Sterba <dsterba@suse.com>
commit 28713169d879b67be2ef2f84dcf54905de238294 upstream.
This patch fixes a build failure when using GCC 8.1:
/usr/bin/ld: block/partitions/ldm.o: in function `ldm_parse_tocblock':
block/partitions/ldm.c:153: undefined reference to `strcmp'
This is caused by a new optimization which effectively replaces a
strncmp() call with a strcmp() call. This affects a number of strncmp()
call sites in the kernel.
The entire class of optimizations is avoided with -fno-builtin, which
gets enabled by -ffreestanding. This may avoid possible future build
failures in case new optimizations appear in future compilers.
I haven't done any performance measurements with this patch but I did
count the function calls in a defconfig build. For example, there are now
23 more sprintf() calls and 39 fewer strcpy() calls. The effect on the
other libc functions is smaller.
If this harms performance we can tackle that regression by optimizing
the call sites, ideally using semantic patches. That way, clang and ICC
builds might benfit too.
Reference: https://marc.info/?l=linux-m68k&m=154514816222244&w=2
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
commit a0ce2f0aa6ad97c3d4927bf2ca54bcebdf062d55 upstream.
Before this patch, it was possible for two pipes to affect each other after
data had been transferred between them with tee():
$ cat tee_test.c
int main(void) {
int pipe_a[2];
if (pipe(pipe_a)) err(1, "pipe");
int pipe_b[2];
if (pipe(pipe_b)) err(1, "pipe");
if (write(pipe_a[1], "abcd", 4) != 4) err(1, "write");
if (tee(pipe_a[0], pipe_b[1], 2, 0) != 2) err(1, "tee");
if (write(pipe_b[1], "xx", 2) != 2) err(1, "write");
char buf[5];
if (read(pipe_a[0], buf, 4) != 4) err(1, "read");
buf[4] = 0;
printf("got back: '%s'\n", buf);
$ gcc -o tee_test tee_test.c
$ ./tee_test
got back: 'abxx'
As suggested by Al Viro, fix it by creating a separate type for
non-mergeable pipe buffers, then changing the types of buffers in
splice_pipe_to_pipe() and link_pipe().
Fixes: 7c77f0b3f920 ("splice: implement pipe to pipe splicing")
Fixes: 70524490ee2e ("[PATCH] splice: add support for sys_tee()")
Suggested-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Jann Horn <jannh@google.com>
commit 73052b0daee0b750b39af18460dfec683e4f5887 upstream.
d_delete only unhashes an entry if it is reached with
dentry->d_lockref.count != 1. Prior to commit 8ead9dd54716 ("devpts:
more pty driver interface cleanups"), d_delete was called on a dentry
from devpts_pty_kill with two references held, which would trigger the
unhashing, and the subsequent dputs would release it.
Commit 8ead9dd54716 reworked devpts_pty_kill to stop acquiring the second
reference from d_find_alias, and the d_delete call left the dentries
still on the hashed list without actually ever being dropped from dcache
before explicit cleanup. This causes the number of negative dentries for
devpts to pile up, and an `ls /dev/pts` invocation can take seconds to
return.
Provide always_delete_dentry() from simple_dentry_operations
as .d_delete for devpts, to make the dentry be dropped from dcache.
Without this cleanup, the number of dentries in /dev/pts/ can be grown
arbitrarily as:
`python -c 'import pty; pty.spawn(["ls", "/dev/pts"])'`
A systemtap probe on dcache_readdir to count d_subdirs shows this count
to increase with each pty spawn invocation above:
probe kernel.function("dcache_readdir") {
subdirs = &@cast($file->f_path->dentry, "dentry")->d_subdirs;
p = subdirs;
p = @cast(p, "list_head")->next;
i = 0
while (p != subdirs) {
i = i+1;
printf("number of dentries: %d\n", i);
Fixes: 8ead9dd54716 ("devpts: more pty driver interface cleanups")
Signed-off-by: Varad Gautam <vrd@amazon.de>
Reported-by: Zheng Wang <wanz@amazon.de>
Reported-by: Brandon Schwartz <bsschwar@amazon.de>
Root-caused-by: Maximilian Heyne <mheyne@amazon.de>
Root-caused-by: Nicolas Pernas Maradei <npernas@amazon.de>
CC: David Woodhouse <dwmw@amazon.co.uk>
CC: Maximilian Heyne <mheyne@amazon.de>
CC: Stefan Nuernberger <snu@amazon.de>
CC: Amit Shah <aams@amazon.de>
CC: Linus Torvalds <torvalds@linux-foundation.org>
CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
CC: Al Viro <viro@ZenIV.linux.org.uk>
CC: Christian Brauner <christian.brauner@ubuntu.com>
CC: Eric W. Biederman <ebiederm@xmission.com>
CC: Matthew Wilcox <willy@infradead.org>
CC: Eric Biggers <ebiggers@google.com>
CC: <stable@vger.kernel.org> # 4.9+
commit 32e36bfbcf31452a854263e7c7f32fbefc4b44d8 upstream.
When using SCSI passthrough in combination with the iSCSI target driver
then cmd->t_state_lock may be obtained from interrupt context. Hence, all
code that obtains cmd->t_state_lock from thread context must disable
interrupts first. This patch avoids that lockdep reports the following:
WARNING: inconsistent lock state
4.18.0-dbg+ #1 Not tainted
inconsistent {HARDIRQ-ON-W} -> {IN-HARDIRQ-W} usage.
iscsi_ttx/1800 [HC1[1]:SC0[2]:HE0:SE0] takes:
000000006e7b0ceb (&(&cmd->t_state_lock)->rlock){?...}, at: target_complete_cmd+0x47/0x2c0 [target_core_mod]
{HARDIRQ-ON-W} state was registered at:
lock_acquire+0xd2/0x260
_raw_spin_lock+0x32/0x50
iscsit_close_connection+0x97e/0x1020 [iscsi_target_mod]
iscsit_take_action_for_connection_exit+0x108/0x200 [iscsi_target_mod]
iscsi_target_rx_thread+0x180/0x190 [iscsi_target_mod]
kthread+0x1cf/0x1f0
ret_from_fork+0x24/0x30
irq event stamp: 1281
hardirqs last enabled at (1279): [<ffffffff970ade79>] __local_bh_enable_ip+0xa9/0x160
hardirqs last disabled at (1281): [<ffffffff97a008a5>] interrupt_entry+0xb5/0xd0
softirqs last enabled at (1278): [<ffffffff977cd9a1>] lock_sock_nested+0x51/0xc0
softirqs last disabled at (1280): [<ffffffffc07a6e04>] ip6_finish_output2+0x124/0xe40 [ipv6]
Possible unsafe locking scenario:
CPU0
lock(&(&cmd->t_state_lock)->rlock);
<Interrupt>
commit a83da8a4509d3ebfe03bb7fffce022e4d5d4764f upstream.
It was reported that some devices report an OPTIMAL TRANSFER LENGTH of
0xFFFF blocks. That looks bogus, especially for a device with a
4096-byte physical block size.
Ignore OPTIMAL TRANSFER LENGTH if it is not a multiple of the device's
reported physical block size.
To make the sanity checking conditionals more readable--and to
facilitate printing warnings--relocate the checking to a helper
function. No functional change aside from the printks.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=199759
Reported-by: Christoph Anton Mitterer <calestyo@scientia.net>
commit 3722e6a52174d7c3a00e6f5efd006ca093f346c1 upstream.
The virtio scsi spec defines struct virtio_scsi_ctrl_tmf as a set of
device-readable records and a single device-writable response entry:
// Device-readable part
le32 type;
le32 subtype;
u8 lun[8];
le64 id;
// Device-writable part
u8 response;
The above should be organised as two descriptor entries (or potentially
more if using VIRTIO_F_ANY_LAYOUT), but without any extra data after "le64
id" or after "u8 response".
The Linux driver doesn't respect that, with virtscsi_abort() and
virtscsi_device_reset() setting cmd->sc before calling virtscsi_tmf(). It
results in the original scsi command payload (or writable buffers) added to
the tmf.
This fixes the problem by leaving cmd->sc zeroed out, which makes
virtscsi_kick_cmd() add the tmf to the control vq without any payload.
Signed-off-by: Felipe Franciosi <felipe@nutanix.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
commit 3438b2c039b4bf26881786a1f3450f016d66ad11 upstream.
A queue with a capacity of zero is clearly not a valid virtio queue.
Some emulators report zero queue size if queried with an invalid queue
index. Instead of crashing in this case let us just return -ENOENT. To
make that work properly, let us fix the notifier cleanup logic as well.
Signed-off-by: Halil Pasic <pasic@linux.ibm.com>
Signed-off-by: Cornelia Huck <cohuck@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit d2f276c8d3c224d5b493c42b6cf006ae4e64fb1c upstream.
When shutting down the timer, ensure that after we have stopped the
timer any pending interrupts are cleared. This fixes a problem when
suspending, as interrupts are disabled before the timer is stopped,
so the timer interrupt may still be asserted, preventing the system
entering a low power state when the wfi is executed.
Signed-off-by: Stuart Menefy <stuart.menefy@mathembedded.com>
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: <stable@vger.kernel.org> # v4.3+
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit a5719a40aef956ba704f2aa1c7b977224d60fa96 upstream.
When a timer tick occurs and the clock is in one-shot mode, the timer
needs to be stopped to prevent it triggering subsequent interrupts.
Currently this code is in exynos4_mct_tick_clear(), but as it is
only needed when an ISR occurs move it into exynos4_mct_tick_isr(),
leaving exynos4_mct_tick_clear() just doing what its name suggests it
should.
Cc: stable@vger.kernel.org # v4.3+
commit 28c4f730d2a44f2591cb104091da29a38dac49fe upstream.
The step values for some of the LDOs appears to be incorrect, resulting
in incorrect voltages (or at least, ones which are different from the
Samsung 3.4 vendor kernel).
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 56b5d4ea778c1b0989c5cdb5406d4a488144c416 upstream.
LDO35 uses 25 mV step, not 50 mV. Bucks 7 and 8 use 12.5 mV step
instead of 6.25 mV. Wrong step caused over-voltage (LDO35) or
under-voltage (buck7 and 8) if regulators were used (e.g. on Exynos5420
Arndale Octa board).
Fixes: cb74685ecb39 ("regulator: s2mps11: Add samsung s2mps11 regulator driver")
