Hack for Realtek HDA driver not to crash due to PCI structure not being
initialised as expected.
By default configure for LG LP156WF1 15.6 inch full HD dual channel
LVDS panel.
Integrate support for the Realtek ALC898 as found on the Apalis
Evaluation Board V1.0a.
Please note that the following HDA rewiring needs to be done:
remove jumpers X6-5 and 7 to 9
rewire as follows:
X5 X7
5 9
7 8
8 5
9 7
Please further note that currently only noise is heard during playback.
SODIMM-59, SODIMM-67 is no longer a GPIO and thus the PWM are usable again.
PWM<D>
Fix null pointer during USB OTG host to peripheral transition caused by
freeing the platform data twice. See the following Tegra OTG driver
commit for reference:
8acf989d5896b152cc88f8b29afd11d522f903e3
Integrate CAN support for the Colibri Evaluation Board V3.1a with built-in
MCP2515 SPI CAN controller resp. the Colibri Evaluation Board V2.1c with its
built-in SJA1000 CAN controller connected to the GMI bus.
The following kernel configuration needs to be enabled as well:
CONFIG_CAN
CONFIG_CAN_RAW
CONFIG_CAN_BCM
CONFIG_CAN_DEV
Plus depending on the Evaluation Board revision:
CONFIG_CAN_MCP251X
or
CONFIG_CAN_SJA1000
CONFIG_CAN_SJA1000_PLATFORM
Optional support for 32-bit GMI as well as xPOD CAN on MECS Tellurium for
Colibri T20 is provided via commented defines in
arch/arm/mach-tegra/board-colibri_t20.h.
Add initial Android kernel configuration adopted from
tegra3_android_defconfig.
Unless HDA driver is enabled device enters safe mode upon start-up.
NVIDIA's Android for their Cardhu developer tablet is looking for the
machine name in order to initialise certain things. For now just hack
it to be able to use their regular initrd.
Android uses 32 bits per pixel and fails otherwise.
While at it increase the default DVI-D aka HDMI resolution to full HD.
Integrate MAX9526 video decoder support as found on our analogous
camera module (ACM) connected to a Colibri Evaluation carrier board.
The following kernel configuration options are required to be enabled:
CONFIG_VIDEO_V4L2=y
CONFIG_SOC_CAMERA=y
CONFIG_SOC_CAMERA_MAX9526=y
CONFIG_VIDEO_TEGRA=y
The VI client within drivers/video/tegra is mutually exclusive with the
Tegra V4L2 framework, since they both want to own the camera hardware.
Signed-off-by: Andrew Chew <achew@nvidia.com>
set some platform_data.
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Move GPIO defines to header file.
While at it get rid of spurious AVDD_DSI_CSI_ENB_GPIO define.
Re-arrange defines in header file.
Get rid of spurious AC_PRESENT_GPIO/INT defines.
Explicitly configure MMC/SD card as 4-bit only by default.
Rename UARTs to be consistent with Colibri FF/BT/STDUART naming.
Rename PWM LEDs to be consistent with Colibri PWM<X> naming.
Migrate from static TEGRA_GPIO_TO_IRQ macro to run-time gpio_to_irq
function.
While at it clean-up some comments and fix some long lines in order to
adhere to Linux kernel coding style.
Clean-up clocks. HDA clocks are of course required on Apalis T30.
Fix naming of fixed regulator initialisation function.
Fix naming of CAN initialisation function.
Move Apalis T30 specific entries for alphabetical consistency. Put
Colibri T30 items in alphabetical order.
Enable back key wake-up source.
Due to missing pull-ups on the gpio-key pins Android unintentionally
entered safe-mode.
Rotate touch for now due to missing resistive touch calibration
integration. This makes our 7 inch EDT ET070080DH6 panel usable.
Activate 24 bpp RGB output.
Please not that this is just the backend configuration. For true 24 bpp
output the framebuffer as well as driver have to be configured for 24
resp. 32 bpp as well.
The audio_port_id in the audio platform data really has to be the index
of the registered tegra_i2s_device rather than the I2S interface
instance.
Enable building b43 driver as a module to demo Broadcom AirForce
BCM4311 based mini-PCIe Wi-Fi 802.11a/b/g module.
Reset PLX PEX 8605 PCIe Switch on Apalis Evaluation Board to enable
X43, X44 and X45.
Add defines for the generic Apalis GPIOs 1 to 8 and the special use
thereof on the Apalis Evaluation Board:
FAN_EN on GPIO8: enable FAN supply on X35
PEX_PERST_N on GPIO7: reset PCIe switch for X43, X44 and X45
TOUCH_WIPER on GPIO6: optional touch wiper GPIO
Fix the following build error using our OpenEmbedded gcc-4.7:
arch/arm/mach-tegra/pcie.c:335:22: error: 'reg_pmc_base' defined but
not used [-Werror=unused-variable]
cc1: all warnings being treated as errors
Add new PCIe driver fixing multi-port operation. Pulled from
Linux_Kernel-src_CARMA_DevKit-ver3.1.10_l4t_Rev545.tgz.
This patch integrates multi-touch for the TouchRevolution Fusion 7 and
10 panels connected to Iris as follows:
Iris X16-5, SODIMM pin 194, I2C SDA
Iris X16-6, SODIMM pin 196, I2C SCL
Iris X16-15, SODIMM pin 103, pen down interrupt
Iris X16-16, SODIMM pin 101, reset
The following kernel configuration needs to be enabled:
Device Drivers -> Input device support -> Touchscreens
-> TouchRevolution Fusion F0710A Touchscreens
Please note that level shifters are required.
Please further note that our current OpenEmbedded BSP does not yet
integrate multi-touch support in the XInput as well as X server layers.
This patch adds the multi-touch input driver for the TouchRevolution
Fusion 7 and 10 panels (See Fusion 7 and 10 drivers for Linux.pdf and
Linux Drivers Fusion 10.zip).
This patch contains updated display timings for the TouchRevolution
Fusion 10 aka Chunghwa Picture Tubes CLAA101NC05 10.1 inch 1024x600@60
single channel LVDS panel.
While at it add a note that the backlight brightness polarity is
display model specific.
This patch adds display timings for the Chunghwa Picture Tubes
CLAA101NC05 10.1 inch 1024x600@60 single channel LVDS panel.
This patch adds display timings for the LG LP156WF1 15.6 inch full HD
dual channel LVDS panel.
The THine THC63LVD827 LVDS transmitter uses 8 GPIOs for configuration.
This patch configures and exports them for easy user-space access.
Configure LG LP156WF1 15.6 inch full HD dual channel LVDS panel:
root@apalis-t30:~# echo out > /sys/class/gpio/gpio216/direction
root@apalis-t30:~# echo 0 > /sys/class/gpio/gpio216/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio219/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio219/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio220/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio220/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio221/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio221/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio222/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio222/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio223/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio223/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio225/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio225/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio226/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio226/value
root@apalis-t30:~# cat /sys/kernel/debug/gpio | grep LVDS
gpio-216 (LVDS: Single/Dual Ch) out lo
gpio-219 (LVDS: 18/24 Bit Mode) out hi
gpio-220 (LVDS: Output Enable ) out hi
gpio-221 (LVDS: Power Down ) out hi
gpio-222 (LVDS: Clock Polarity) out hi
gpio-223 (LVDS: Colour Mapping) out hi
gpio-225 (LVDS: Swing Mode ) out hi
gpio-226 (LVDS: DDRclk Disable) out hi
Add battery regulator which is always-on. The rail which is
powered from battery can be added on this rail as consumer.
bug 1218527
Change-Id: I2394e1894649cd4fa736646981374681f603c832
Reviewed-on: http://git-master/r/#change,193052
(cherry picked from commit 4b9cabe87060bf5f252206aba5b62ea1ccb2ff83)
Reviewed-on: http://git-master/r/193777
Tested-by: Preetham Chandru <pchandru@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
enable /dev mount with ACL
Bug 1225372
Bug 1219372
Change-Id: I3b80012e97c3a5ec8358285f81c5111a30ed19f8
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/196206
set is_int_enable to true only if we register for a irq.
Bug 1211260
Change-Id: I603efe721796db70d504da7999e5d7939d45d13a
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/193047
(cherry picked from commit 8b89b2b64c67d80fcfc29cd4f6a92d4527e70df9)
Reviewed-on: http://git-master/r/195844
GVS: Gerrit_Virtual_Submit
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Add support for PM315
Bug 1217569
Change-Id: I230fcec04eb5a96441e2c19b304d608d86eaf996
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/191555
Looks like this DPD stuff whatever it is fails 8-bit MMC1 slot card
detection on our current Apalis T30 prototypes.
See f4cd0d4448d65a42b65c338f85a3ab8064923c61.
This patch allows for easy integration of a custom Linux boot logo to
replace the Tux' being shown by default.
Use gimp or the like to create a raw PPM in your desired resolution.
Reduce the number of colours in the image to 224:
user@host:~$ ppmquant 224 Toradex-640x480.ppm > \
Toradex-640x480-224.ppm
ppmquant: making histogram...
ppmquant: 370 colors found
ppmquant: choosing 224 colors...
ppmquant: mapping image to new colors...
Convert it from raw PPM to ASCII format:
user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \
Toradex-640x480-ascii-224.ppm
Copy it into the Linux sources:
cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\
logo_custom_clut224.ppm
Activate exclusively custom Linux logo in the kernel configuration:
Device Drivers -> Graphics support -> Bootup logo ->
Custom 224-color Linux logo
And re-compile the kernel.
The following commit actually missed adding the new files:
7925180aee227f3de7af4a8cbad1c4b203a9132e
Tested on early prototype Apalis T30 V1.0a module.
Known issues:
- ADC not integrated yet.
- HDA not integrated yet.
- CEC not integrated yet.
- IrDA not integrated yet.
- Keys not integrated yet therefore no way to wake from suspend.
- 8-bit MMC1 slot card detection interrupt not working despite
detection GPIO successfully being tested with GPIOConfig.
Note: even 8-bit cards work fine if already plugged-in during boot.
- PCIe limited to internal Gigabit Ethernet chip for now due to our
proprietary way of resetting other ports which requires further
integration into NVIDIA's driver.
