2011-05-23Merge branches 'doc', 'multitouch', 'upstream' and 'upstream-fixes' into ↵Jiri Kosina
for-linus
2011-05-23HID: hid-multitouch: cosmetic changes, sort classes and devicesBenjamin Tissoires
This patch sorts the defs for the MT_CLS. I choose to split generic classes and device specific ones to be able to add more generic classes in the future. It also put eGalax devices at their right place (alphabetically) in mt_devices. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-20HID: hid-multitouch: class MT_CLS_STANTUM is redundant with MT_CLS_CONFIDENCEBenjamin Tissoires
Stantum devices used to work with MT_CLS_STANTUM but MT_CLS_CONFIDENCE is exactly the same. This patch switches them to this generic class, and remove the unused MT_CLS_STANTUM. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-20HID: hid-multitouch: add support for Unitec panelsBenjamin Tissoires
This patch introduce support for Unitec panels. This device has not been optimized in term of kernel processing operations (default class), but it will work. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-20HID: hid-multitouch: add support for Touch International panelsBenjamin Tissoires
This patch introduce support for Touch International panels. This device has not been optimized in term of kernel processing operations (default class), but it will work. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-20HID: hid-multitouch: add support for GoodTouch panelsBenjamin Tissoires
This patch introduce support for GoodTouch panels. This device has not been optimized in term of kernel processing operations (default class), but it will work. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-20HID: hid-multitouch: add support for CVTouch panelsBenjamin Tissoires
This patch introduce support for CVTouch panels. This device has not been optimized in term of kernel processing operations (default class), but it will work. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-20HID: hid-multitouch: add support for ActionStar panelsBenjamin Tissoires
This patch introduce support for ActionStar panels. This device has not been optimized in term of kernel processing operations (default class), but it will work. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-20HID: hiddev: fix race between hiddev_disconnect and hiddev_releaseJiri Kosina
When hiddev_disconnect() runs with chardev open, it will proceed with usbhid_close(). When userspace in parallel runs the hiddev_release(), it sees !hiddev->exists (as it has been already set so by hiddev_disconnect()) and kfrees hiddev while hiddev_disconnect() hasn't finished yet. Serialize the access to hiddev->exists and hiddev->open by existancelock. Reported-by: mike-@cinci.rr.com Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-20HID: magicmouse: ignore 'ivalid report id' while switching modesJiri Kosina
The device reponds with 'invalid report id' when feature report switching it into multitouch mode is sent to it. This has been silently ignored before 0825411ade ("HID: bt: Wait for ACK on Sent Reports"), but since this commit, it propagates -EIO from the _raw callback . So let the driver ignore -EIO as response to 0xd7,0x01 report, as that's how the device reacts in normal mode. Sad, but following reality. This fixes https://bugzilla.kernel.org/show_bug.cgi?id=35022 Tested-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-20HID: fix a crash in hid_report_raw_event() function.Armando Visconti
I'm using a Data Modul EasyTouch USB multitouch controller, which is issuing a hid report with a size equals to 0. The rsize value gets set to 536870912 and Linux is crashing in the memset because the value is too big. Signed-off-by: Armando Visconti <armando.visconti@st.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-19HID: hid-multitouch: add support for Elo TouchSystems 2515 IntelliTouch PlusBenjamin Tissoires
This patch adds support for Elo TouchSystems 2515 IntelliTouch Plus that can be found in Lenovo A700 all-in-one. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Tested-by: Bastien Nocera <hadess@hadess.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-18HID: assorted usage updates from hut 1.12Jarod Wilson
I've got a Tivo Slide bluetooth remote/dongle, which uses a fair number of hid usages that aren't currently mapped in hid-input.c. I'd initially written additions to hid-input.c with just this device in mind, including some bits that were specific to the device. This go around, I'm looking at adding/correcting as many generic HID usages from the HID Usage Tables, version 1.12, as I can -- which also serves to enable all but four of the buttons on the Tivo Slide remote[*]. Outside of fixing the obviously incorrect mapping of 0xc 0x45 from KEY_RADIO to KEY_RIGHT, and making use of the new KEY_IMAGES (just added in 2.6.39-rc4) for AL Image Browser instead of KEY_MEDIA, these are purely additions, and thus should have no negative impact on any already functional HID devices. Most of the added mappings seemed to be perfectly logical to me, but there were a few that were mapped on more of an "I think this makes the most sense" basis. [*] I'll handle the last four tivo buttons via an hid-tivo.c follow-up. CC: Dmitry Torokhov <dmitry.torokhov@gmail.com> CC: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-18Merge branch 'master' into upstream.Jiri Kosina
This is sync with Linus' tree to receive KEY_IMAGES definition that went in through input tree.
2011-05-18HID: roccat: fix actual/startup profile sysfs attribute in koneplusStefan Achatz
startup_profile and actual_profile didn't work as expected. Also as the actual profile is persistent, the distinction between the two was ambiguous, so both use the same code now and startup_profile has been deprecated. Also the event is now propagated through chardev. The userland tool has been updated to support this change. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-18HID: hid-multitouch: Add support for Lumio panelsBenjamin Tissoires
This patch enables support for Lumio optical devices. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-18HID: 'name' and 'phys' in 'struct hid_device' can never be NULLDaniel Mack
As they are static members of fix size, there is no need to NULL-check them. Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Change netdev_fix_features messages loglevel vmxnet3: Fix inconsistent LRO state after initialization sfc: Fix oops in register dump after mapping change IPVS: fix netns if reading ip_vs_* procfs entries bridge: fix forwarding of IPv6
2011-05-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: Revert "mmc: fix a race between card-detect rescan and clock-gate work instances"
2011-05-16mm: fix kernel-doc warning in page_alloc.cRandy Dunlap
Fix new kernel-doc warning in mm/page_alloc.c: Warning(mm/page_alloc.c:2370): No description found for parameter 'nid' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-16PCI: Clear bridge resource flags if requested size is 0Yinghai Lu
During pci remove/rescan testing found: pci 0000:c0:03.0: PCI bridge to [bus c4-c9] pci 0000:c0:03.0: bridge window [io 0x1000-0x0fff] pci 0000:c0:03.0: bridge window [mem 0xf0000000-0xf00fffff] pci 0000:c0:03.0: bridge window [mem 0xfc180000000-0xfc197ffffff 64bit pref] pci 0000:c0:03.0: device not available (can't reserve [io 0x1000-0x0fff]) pci 0000:c0:03.0: Error enabling bridge (-22), continuing pci 0000:c0:03.0: enabling bus mastering pci 0000:c0:03.0: setting latency timer to 64 pcieport 0000:c0:03.0: device not available (can't reserve [io 0x1000-0x0fff]) pcieport: probe of 0000:c0:03.0 failed with error -22 This bug was caused by commit c8adf9a3e873 ("PCI: pre-allocate additional resources to devices only after successful allocation of essential resources.") After that commit, pci_hotplug_io_size is changed to additional_io_size from minium size. So it will not go through resource_size(res) != 0 path, and will not be reset. The root cause is: pci_bridge_check_ranges will set RESOURCE_IO flag for pci bridge, and later if children do not need IO resource. those bridge resources will not need to be allocated. but flags is still there. that will confuse the the pci_enable_bridges later. related code: static void assign_requested_resources_sorted(struct resource_list *head, struct resource_list_x *fail_head) { struct resource *res; struct resource_list *list; int idx; for (list = head->next; list; list = list->next) { res = list->res; idx = res - &list->dev->resource[0]; if (resource_size(res) && pci_assign_resource(list->dev, idx)) { ... reset_resource(res); } } } At last, We have to clear the flags in pbus_size_mem/io when requested size == 0 and !add_head. becasue this case it will not go through adjust_resources_sorted(). Just make size1 = size0 when !add_head. it will make flags get cleared. At the same time when requested size == 0, add_size != 0, will still have in head and add_list. because we do not clear the flags for it. After this, we will get right result: pci 0000:c0:03.0: PCI bridge to [bus c4-c9] pci 0000:c0:03.0: bridge window [io disabled] pci 0000:c0:03.0: bridge window [mem 0xf0000000-0xf00fffff] pci 0000:c0:03.0: bridge window [mem 0xfc180000000-0xfc197ffffff 64bit pref] pci 0000:c0:03.0: enabling bus mastering pci 0000:c0:03.0: setting latency timer to 64 pcieport 0000:c0:03.0: setting latency timer to 64 pcieport 0000:c0:03.0: irq 160 for MSI/MSI-X pcieport 0000:c0:03.0: Signaling PME through PCIe PME interrupt pci 0000:c4:00.0: Signaling PME through PCIe PME interrupt pcie_pme 0000:c0:03.0:pcie01: service driver pcie_pme loaded aer 0000:c0:03.0:pcie02: service driver aer loaded pciehp 0000:c0:03.0:pcie04: Hotplug Controller: v3: more simple fix. also fix one typo in pbus_size_mem Signed-off-by: Yinghai Lu <yinghai@kernel.org> Reviewed-by: Ram Pai <linuxram@us.ibm.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-16net: Change netdev_fix_features messages loglevelMichał Mirosław
Those reduced to DEBUG can possibly be triggered by unprivileged processes and are nothing exceptional. Illegal checksum combinations can only be caused by driver bug, so promote those messages to WARN. Since GSO without SG will now only cause DEBUG message from netdev_fix_features(), remove the workaround from register_netdevice(). Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16vmxnet3: Fix inconsistent LRO state after initializationThomas Jarosch
During initialization of vmxnet3, the state of LRO gets out of sync with netdev->features. This leads to very poor TCP performance in a IP forwarding setup and is hitting many VMware users. Simplified call sequence: 1. vmxnet3_declare_features() initializes "adapter->lro" to true. 2. The kernel automatically disables LRO if IP forwarding is enabled, so vmxnet3_set_flags() gets called. This also updates netdev->features. 3. Now vmxnet3_setup_driver_shared() is called. "adapter->lro" is still set to true and LRO gets enabled again, even though netdev->features shows it's disabled. Fix it by updating "adapter->lro", too. The private vmxnet3 adapter flags are scheduled for removal in net-next, see commit a0d2730c9571aeba793cb5d3009094ee1d8fda35 "net: vmxnet3: convert to hw_features". Patch applies to 2.6.37 / 2.6.38 and 2.6.39-rc6. Please CC: comments. Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sfc: Fix oops in register dump after mapping changeBen Hutchings
Commit 747df2258b1b9a2e25929ef496262c339c380009 ('sfc: Always map MCDI shared memory as uncacheable') introduced a separate mapping for the MCDI shared memory (MC_TREG_SMEM). This means we can no longer easily include it in the register dump. Since it is not particularly useful in debugging, substitute a recognisable dummy value. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: OMAP3: set the core dpll clk rate in its set_rate function omap: iommu: Return IRQ_HANDLED in fault handler when no fault occured
2011-05-16Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: Take lock around probes for drm_fb_helper_hotplug_event drm/i915: Revert i915.semaphore=1 default from 47ae63e0 vga_switcheroo: don't toggle-switch devices drm/radeon/kms: add some evergreen/ni safe regs drm/radeon/kms: fix extended lvds info parsing drm/radeon/kms: fix tiling reg on fusion
2011-05-16Revert "mmc: fix a race between card-detect rescan and clock-gate work ↵Chris Ball
instances" This reverts commit 26fc8775b51484d8c0a671198639c6d5ae60533e, which has been reported to cause boot/resume-time crashes for some users: https://bbs.archlinux.org/viewtopic.php?id=118751. Signed-off-by: Chris Ball <cjb@laptop.org> Cc: <stable@kernel.org>
2011-05-16drm: Take lock around probes for drm_fb_helper_hotplug_eventChris Wilson
We need to hold the dev->mode_config.mutex whilst detecting the output status. But we also need to drop it for the call into drm_fb_helper_single_fb_probe(), which indirectly acquires the lock when attaching the fbcon. Failure to do so exposes a race with normal output probing. Detected by adding some warnings that the mutex is held to the backend detect routines: [ 17.772456] WARNING: at drivers/gpu/drm/i915/intel_crt.c:471 intel_crt_detect+0x3e/0x373 [i915]() [ 17.772458] Hardware name: Latitude E6400 [ 17.772460] Modules linked in: .... [ 17.772582] Pid: 11, comm: kworker/0:1 Tainted: G W 2.6.38.4-custom.2 #8 [ 17.772584] Call Trace: [ 17.772591] [<ffffffff81046af5>] ? warn_slowpath_common+0x78/0x8c [ 17.772603] [<ffffffffa03f3e5c>] ? intel_crt_detect+0x3e/0x373 [i915] [ 17.772612] [<ffffffffa0355d49>] ? drm_helper_probe_single_connector_modes+0xbf/0x2af [drm_kms_helper] [ 17.772619] [<ffffffffa03534d5>] ? drm_fb_helper_probe_connector_modes+0x39/0x4d [drm_kms_helper] [ 17.772625] [<ffffffffa0354760>] ? drm_fb_helper_hotplug_event+0xa5/0xc3 [drm_kms_helper] [ 17.772633] [<ffffffffa035577f>] ? output_poll_execute+0x146/0x17c [drm_kms_helper] [ 17.772638] [<ffffffff81193c01>] ? cfq_init_queue+0x247/0x345 [ 17.772644] [<ffffffffa0355639>] ? output_poll_execute+0x0/0x17c [drm_kms_helper] [ 17.772648] [<ffffffff8105b540>] ? process_one_work+0x193/0x28e [ 17.772652] [<ffffffff8105c6bc>] ? worker_thread+0xef/0x172 [ 17.772655] [<ffffffff8105c5cd>] ? worker_thread+0x0/0x172 [ 17.772658] [<ffffffff8105c5cd>] ? worker_thread+0x0/0x172 [ 17.772663] [<ffffffff8105f767>] ? kthread+0x7a/0x82 [ 17.772668] [<ffffffff8100a724>] ? kernel_thread_helper+0x4/0x10 [ 17.772671] [<ffffffff8105f6ed>] ? kthread+0x0/0x82 [ 17.772674] [<ffffffff8100a720>] ? kernel_thread_helper+0x0/0x10 Reported-by: Frederik Himpe <fhimpe@telenet.be> References: https://bugs.freedesktop.org/show_bug.cgi?id=36394 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-16drm/i915: Revert i915.semaphore=1 default from 47ae63e0Andy Lutomirski
My Q67 / i7-2600 box has rev09 Sandy Bridge graphics. It hangs instantly when GNOME loads and it hangs so hard the reset button doesn't work. Setting i915.semaphore=0 fixes it. Semaphores were disabled in a1656b9090f7008d2941c314f5a64724bea2ae37 in 2.6.38 and were re-enabled by commit 47ae63e0c2e5fdb582d471dc906eb29be94c732f Merge: c59a333 467cffb Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Mon Mar 7 12:32:44 2011 +0000 Merge branch 'drm-intel-fixes' into drm-intel-next Apply the trivial conflicting regression fixes, but keep GPU semaphores enabled. Conflicts: drivers/gpu/drm/i915/i915_drv.h drivers/gpu/drm/i915/i915_gem_execbuffer.c (It's worth noting that the offending change is i915_drv.c, which is not a conflict.) Signed-off-by: Andy Lutomirski <luto@mit.edu> Acked-by: Keith Packard <keithp@keithp.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-16vga_switcheroo: don't toggle-switch devicesFlorian Mickler
If the requested device is already active, ignore the request. This restores the original behaviour of the interface. The change was probably an unintended side effect of commit 66b37c6777c4 vga_switcheroo: split switching into two stages which did not take into account to duplicate the !active check in the split-off stage2. Fix this by factoring that check out of stage1 into the debugfs_write routine. References: https://bugzilla.kernel.org/show_bug.cgi?id=34252 Reported-by: Igor Murzov <e-mail@date.by> Tested-by: Igor Murzov <e-mail@date.by> Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-15Merge branch 'pablo/nf-2.6-updates' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-05-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix FS_IOC_SETFLAGS ioctl Btrfs: fix FS_IOC_GETFLAGS ioctl fs: remove FS_COW_FL Btrfs: fix easily get into ENOSPC in mixed case Prevent oopsing in posix_acl_valid()
2011-05-15IPVS: fix netns if reading ip_vs_* procfs entriesHans Schillstrom
Without this patch every access to ip_vs in procfs will increase the netns count i.e. an unbalanced get_net()/put_net(). (ipvsadm commands also use procfs.) The result is you can't exit a netns if reading ip_vs_* procfs entries. Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-15bridge: fix forwarding of IPv6Stephen Hemminger
The commit 6b1e960fdbd75dcd9bcc3ba5ff8898ff1ad30b6e bridge: Reset IPCB when entering IP stack on NF_FORWARD broke forwarding of IPV6 packets in bridge because it would call bp_parse_ip_options with an IPV6 packet. Reported-by: Noah Meyerhans <noahm@debian.org> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: fix split bio handling rbd: fix leak of ops struct
2011-05-14Btrfs: fix FS_IOC_SETFLAGS ioctlLi Zefan
Steps to reproduce the bug: - Call FS_IOC_SETLFAGS ioctl with flags=FS_COMPR_FL - Call FS_IOC_SETFLAGS ioctl with flags=0 - Call FS_IOC_GETFLAGS ioctl, and you'll see FS_COMPR_FL is still set! Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14Btrfs: fix FS_IOC_GETFLAGS ioctlLi Zefan
As we've added per file compression/cow support. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14fs: remove FS_COW_FLLi Zefan
FS_COW_FL and FS_NOCOW_FL were newly introduced to control per file COW in btrfs, but FS_NOCOW_FL is sufficient. The fact is we don't have corresponding BTRFS_INODE_COW flag. COW is default, and FS_NOCOW_FL can be used to switch off COW for a single file. If we mount btrfs with nodatacow, a newly created file will be set with the FS_NOCOW_FL flag. So to turn on COW for it, we can just clear the FS_NOCOW_FL flag. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14Btrfs: fix easily get into ENOSPC in mixed caseliubo
When a btrfs disk is created by mixed data & metadata option, it will have no pure data or pure metadata space info. In btrfs's for-linus branch, commit 78b1ea13838039cd88afdd62519b40b344d6c920 (Btrfs: fix OOPS of empty filesystem after balance) initializes space infos at the very beginning. The problem is this initialization does not take the mixed case into account, which will cause btrfs will easily get into ENOSPC in mixed case. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14Prevent oopsing in posix_acl_valid()Daniel J Blueman
If posix_acl_from_xattr() returns an error code, a negative address is dereferenced causing an oops; fix by checking for error code first. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Reviewed-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata: fix oops when LPM is used with PMP
2011-05-14tmpfs: fix race between swapoff and writepageHugh Dickins
Shame on me! Commit b1dea800ac39 "tmpfs: fix race between umount and writepage" fixed the advertized race, but introduced another: as even its comment makes clear, we cannot safely rely on a peek at list_empty() while holding no lock - until info->swapped is set, shmem_unuse_inode() may delete any formerly-swapped inode from the shmem_swaplist, which in this case would leave a swap area impossible to swapoff. Although I don't relish taking the mutex every time, I don't care much for the alternatives either; and at least the peek at list_empty() in shmem_evict_inode() (a hotter path since most inodes would never have been swapped) remains safe, because we already truncated the whole file. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-14libata: fix oops when LPM is used with PMPTejun Heo
ae01b2493c (libata: Implement ATA_FLAG_NO_DIPM and apply it to mcp65) added ATA_FLAG_NO_DIPM and made ata_eh_set_lpm() check the flag. However, @ap is NULL if @link points to a PMP link and thus the unconditional @ap->flags dereference leads to the following oops. BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: [<ffffffff813f98e1>] ata_eh_recover+0x9a1/0x1510 ... Pid: 295, comm: scsi_eh_4 Tainted: P 2.6.38.5-core2 #1 System76, Inc. Serval Professional/Serval Professional RIP: 0010:[<ffffffff813f98e1>] [<ffffffff813f98e1>] ata_eh_recover+0x9a1/0x1510 RSP: 0018:ffff880132defbf0 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff880132f40000 RCX: 0000000000000000 RDX: ffff88013377c000 RSI: ffff880132f40000 RDI: 0000000000000000 RBP: ffff880132defce0 R08: ffff88013377dc58 R09: ffff880132defd98 R10: 0000000000000000 R11: 00000000ffffffff R12: 0000000000000000 R13: 0000000000000000 R14: ffff88013377c000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff8800bf700000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000018 CR3: 0000000001a03000 CR4: 00000000000406e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process scsi_eh_4 (pid: 295, threadinfo ffff880132dee000, task ffff880133b416c0) Stack: 0000000000000000 ffff880132defcc0 0000000000000000 ffff880132f42738 ffffffff813ee8f0 ffffffff813eefe0 ffff880132defd98 ffff88013377f190 ffffffffa00b3e30 ffffffff813ef030 0000000032defc60 ffff880100000000 Call Trace: [<ffffffff81400867>] sata_pmp_error_handler+0x607/0xc30 [<ffffffffa00b273f>] ahci_error_handler+0x1f/0x70 [libahci] [<ffffffff813faade>] ata_scsi_error+0x5be/0x900 [<ffffffff813cf724>] scsi_error_handler+0x124/0x650 [<ffffffff810834b6>] kthread+0x96/0xa0 [<ffffffff8100cd64>] kernel_thread_helper+0x4/0x10 Code: 8b 95 70 ff ff ff b8 00 00 00 00 48 3b 9a 10 2e 00 00 48 0f 44 c2 48 89 85 70 ff ff ff 48 8b 8d 70 ff ff ff f6 83 69 02 00 00 01 <48> 8b 41 18 0f 85 48 01 00 00 48 85 c9 74 12 48 8b 51 08 48 83 RIP [<ffffffff813f98e1>] ata_eh_recover+0x9a1/0x1510 RSP <ffff880132defbf0> CR2: 0000000000000018 Fix it by testing @link->ap->flags instead. stable: ATA_FLAG_NO_DIPM was added during 2.6.39 cycle but was backported to 2.6.37 and 38. This is a fix for that and thus also applicable to 2.6.37 and 38. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: "Nathan A. Mourey II" <nmoureyii@ne.rr.com> LKML-Reference: <1304555277.2059.2.camel@localhost.localdomain> Cc: Connor H <cmdkhh@gmail.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-05-14Merge branch 'fbmem'Linus Torvalds
* fbmem: Further fbcon sanity checking fbmem: fix remove_conflicting_framebuffers races
2011-05-14Revert "libata: ahci_start_engine compliant to AHCI spec"Tejun Heo
This reverts commit 270dac35c26433d06a89150c51e75ca0181ca7e4. The commits causes command timeouts on AC plug/unplug. It isn't yet clear why. As the commit was for a single rather obscure controller, revert the change for now. The problem was reported and bisected by Gu Rui in bug#34692. https://bugzilla.kernel.org/show_bug.cgi?id=34692 Also, reported by Rafael and Michael in the following thread. http://thread.gmane.org/gmane.linux.kernel/1138771 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Gu Rui <chaos.proton@gmail.com> Reported-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Michael Leun <lkml20100708@newton.leun.net> Cc: Jian Peng <jipeng2005@gmail.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-14Further fbcon sanity checkingBruno Prémont
This moves the if (num_registered_fb == FB_MAX) return -ENXIO; check _AFTER_ the call to do_remove_conflicting_framebuffers() as this would (now in a safe way) allow a native driver to replace the conflicting one even if all slots in registered_fb[] are taken. This also prevents unregistering a framebuffer that is no longer registered (vga16f will unregister at module unload time even if the frame buffer had been unregistered earlier due to being found conflicting). Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-14fbmem: fix remove_conflicting_framebuffers racesLinus Torvalds
When a register_framebuffer() call results in us removing old conflicting framebuffers, the new registration_lock doesn't protect that situation. And we can't just add the same locking to the function, because these functions call each other: register_framebuffer() calls remove_conflicting_framebuffers, which in turn calls unregister_framebuffer for any conflicting entry. In order to fix it, this just creates wrapper functions around all three functions and makes the versions that actually do the work be called "do_xxx()", leaving just the wrapper that gets the lock and calls the worker function. So the rule becomes simply that "do_xxxx()" has to be called with the lock held, and now do_register_framebuffer() can just call do_remove_conflicting_framebuffers(), and that in turn can call _do_unregister_framebuffer(), and there is no deadlock, and we can hold the registration lock over the whole sequence, fixing the races. It also makes error cases simpler, and fixes one situation where we would return from unregister_framebuffer() without releasing the lock, pointed out by Bruno Prémont. Tested-by: Bruno Prémont <bonbons@linux-vserver.org> Tested-by: Anca Emanuel <anca.emanuel@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6: alpha: Wire up syscalls new to 2.6.39 alpha: convert to clocksource_register_hz
2011-05-13alpha: Wire up syscalls new to 2.6.39Michael Cree
Wire up the syscalls: name_to_handle_at open_by_handle_at clock_adjtime syncfs and adjust some whitespace in the neighbourhood to align commments. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-05-13alpha: convert to clocksource_register_hzJohn Stultz
Converts alpha to use clocksource_register_hz. Signed-off-by: John Stultz <johnstul@us.ibm.com> CC: Richard Henderson <rth@twiddle.net> CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru> CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Matt Turner <mattst88@gmail.com>
