commit 6b76106d8ef31111d6fc469564b83b5f5542794f upstream.
Even after commit 5478755616ae2ef1ce144dded589b62b2a50d575
("block: check for proper length of iov entries earlier ...")
we still won't check for zero-length entries after an unaligned
entry. Remove the break-statement, so all entries are checked.
commit 7a401a972df8e184b3d1a3fc958c0a4ddee8d312 upstream.
bdi_prune_sb() in bdi_unregister() attempts to removes the bdi links
from all super_blocks and then del_timer_sync() the writeback timer.
However, this can race with __mark_inode_dirty(), leading to
bdi_wakeup_thread_delayed() rearming the writeback timer on the bdi
we're unregistering, after we've called del_timer_sync().
This can end up with the bdi being freed with an active timer inside it,
as in the case of the following dump after the removal of an SD card.
Fix this by redoing the del_timer_sync() in bdi_destory().
WARNING: at /home/rabin/kernel/arm/lib/debugobjects.c:262 debug_print_object+0x9c/0xc8()
ODEBUG: free active (active state 0) object type: timer_list hint: wakeup_timer_fn+0x0/0x180
Modules linked in:
Backtrace:
[<c00109dc>] (dump_backtrace+0x0/0x110) from [<c0236e4c>] (dump_stack+0x18/0x1c)
r6:c02bc638 r5:00000106 r4:c79f5d18 r3:00000000
[<c0236e34>] (dump_stack+0x0/0x1c) from [<c0025e6c>] (warn_slowpath_common+0x54/0x6c)
[<c0025e18>] (warn_slowpath_common+0x0/0x6c) from [<c0025f28>] (warn_slowpath_fmt+0x38/0x40)
r8:20000013 r7:c780c6f0 r6:c031613c r5:c780c6f0 r4:c02b1b29
r3:00000009
[<c0025ef0>] (warn_slowpath_fmt+0x0/0x40) from [<c015eb4c>] (debug_print_object+0x9c/0xc8)
r3:c02b1b29 r2:c02bc662
[<c015eab0>] (debug_print_object+0x0/0xc8) from [<c015f574>] (debug_check_no_obj_freed+0xac/0x1dc)
r6:c7964000 r5:00000001 r4:c7964000
[<c015f4c8>] (debug_check_no_obj_freed+0x0/0x1dc) from [<c00a9e38>] (kmem_cache_free+0x88/0x1f8)
[<c00a9db0>] (kmem_cache_free+0x0/0x1f8) from [<c014286c>] (blk_release_queue+0x70/0x78)
[<c01427fc>] (blk_release_queue+0x0/0x78) from [<c015290c>] (kobject_release+0x70/0x84)
r5:c79641f0 r4:c796420c
[<c015289c>] (kobject_release+0x0/0x84) from [<c0153ce4>] (kref_put+0x68/0x80)
r7:00000083 r6:c74083d0 r5:c015289c r4:c796420c
[<c0153c7c>] (kref_put+0x0/0x80) from [<c01527d0>] (kobject_put+0x48/0x5c)
r5:c79643b4 r4:c79641f0
[<c0152788>] (kobject_put+0x0/0x5c) from [<c013ddd8>] (blk_cleanup_queue+0x68/0x74)
r4:c7964000
[<c013dd70>] (blk_cleanup_queue+0x0/0x74) from [<c01a6370>] (mmc_blk_put+0x78/0xe8)
r5:00000000 r4:c794c400
[<c01a62f8>] (mmc_blk_put+0x0/0xe8) from [<c01a64b4>] (mmc_blk_release+0x24/0x38)
r5:c794c400 r4:c0322824
[<c01a6490>] (mmc_blk_release+0x0/0x38) from [<c00de11c>] (__blkdev_put+0xe8/0x170)
r5:c78d5e00 r4:c74083c0
[<c00de034>] (__blkdev_put+0x0/0x170) from [<c00de2c0>] (blkdev_put+0x11c/0x12c)
r8:c79f5f70 r7:00000001 r6:c74083d0 r5:00000083 r4:c74083c0
r3:00000000
[<c00de1a4>] (blkdev_put+0x0/0x12c) from [<c00b0724>] (kill_block_super+0x60/0x6c)
r7:c7942300 r6:c79f4000 r5:00000083 r4:c74083c0
[<c00b06c4>] (kill_block_super+0x0/0x6c) from [<c00b0a94>] (deactivate_locked_super+0x44/0x70)
r6:c79f4000 r5:c031af64 r4:c794dc00 r3:c00b06c4
[<c00b0a50>] (deactivate_locked_super+0x0/0x70) from [<c00b1358>] (deactivate_super+0x6c/0x70)
r5:c794dc00 r4:c794dc00
[<c00b12ec>] (deactivate_super+0x0/0x70) from [<c00c88b0>] (mntput_no_expire+0x188/0x194)
r5:c794dc00 r4:c7942300
[<c00c8728>] (mntput_no_expire+0x0/0x194) from [<c00c95e0>] (sys_umount+0x2e4/0x310)
r6:c7942300 r5:00000000 r4:00000000 r3:00000000
[<c00c92fc>] (sys_umount+0x0/0x310) from [<c000d940>] (ret_fast_syscall+0x0/0x30)
---[ end trace e5c83c92ada51c76 ]---
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
commit d715e433b7ad19c02fc4becf0d5e9a59f97925de upstream.
kdump fails because we try to execute an HV only instruction. Feature
fixups are being applied after we copy the exception vectors down to 0
so they miss out on any updates.
We have always had this issue but it only became critical in v3.0
when we added CFAR support (breaks POWER5) and v3.1 when we added
POWERNV (breaks everyone).
commit 72f3bea075287785ed32b777b6dd2636aa7002e8 upstream.
Fixes the PS3 bootup hang introduced in 3.0-rc1 by:
commit 317f394160e9beb97d19a84c39b7e5eb3d7815a
sched: Move the second half of ttwu() to the remote cpu
Move the PS3's LV1 EOI call lv1_end_of_interrupt_ext() from ps3_chip_eoi()
to ps3_get_irq() for IPI messages.
If lv1_send_event_locally() is called between a previous call to
lv1_send_event_locally() and the coresponding call to
lv1_end_of_interrupt_ext() the second event will not be delivered to the
target cpu.
The PS3's SMP IPIs are implemented using lv1_send_event_locally(), so if two
IPI messages of the same type are sent to the same target in a relatively
short period of time the second IPI event can become lost when
lv1_end_of_interrupt_ext() is called from ps3_chip_eoi().
Signed-off-by: Geoff Levand <geoff@infradead.org>
commit 99cb2ddcc617f43917e94a4147aa3ccdb2bcd77e upstream.
gref->gref_id is unsigned so the error handling didn't work.
gnttab_grant_foreign_access() returns an int type, so we can add a
cast here, and it doesn't cause any problems.
gnttab_grant_foreign_access() can return a variety of errors
including -ENOSPC, -ENOSYS and -ENOMEM.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 21643e69a4c06f7ef155fbc70e3fba13fba4a756 upstream.
On 32 bit systems a high value of op.count could lead to an integer
overflow in the kzalloc() and gref_ids would be smaller than
expected. If the you triggered another integer overflow in
"if (gref_size + op.count > limit)" then you'd probably get memory
corruption inside add_grefs().
commit 90d4f5534d14815bd94c10e8ceccc57287657ecc upstream.
PVHVM running with more than 32 vcpus and pv_irq/pv_time enabled
need VCPU placement to work, or else it will softlockup.
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com>
commit f09ee0451a44a4e913a7c3cec3805508f7de6c54 upstream.
The codec for Devkit8000 (TWL4030) was not detected except
when build with CONFIG_SND_SOC_ALL_CODECS.
twl-core.c still uses the CONFIG_TWL4030_CODEC for
twl_has_codec().
In commit 57fe7251f5bfc4332f24479376de48a1e8ca6211
the CONFIG_TWL4030_CODEC was renamed
into CONFIG_MFD_TWL4030_AUDIO, thatswhy the codec
was not detected.
This patch renames the CONFIG_ TWL4030_CODEC into
CONFIG_MFD_TWL4030_AUDIO in twl-core.c.
Signed-off-by: Thomas Weber <weber@corscience.de>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
commit 9a3f530f39f4490eaa18b02719fb74ce5f4d2d86 upstream.
When the number of failed devices exceeds the allowed number
we must abort any active parity operations (checks or updates) as they
are no longer meaningful, and can lead to a BUG_ON in
handle_parity_checks6.
This bug was introduce by commit 6c0069c0ae9659e3a91b68eaed06a5c6c37f45c8
in 2.6.29.
Reported-by: Manish Katiyar <mkatiyar@gmail.com>
Tested-by: Manish Katiyar <mkatiyar@gmail.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: NeilBrown <neilb@suse.de>
[This patch is supposed to be applied in 3.1 (and maybe older) branches only.]
New kernels support newer firmware that users may try to incorrectly use
with older kernels. Display error and explain the problem in such a case
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
commit 153b19a3b9fd8b9478495b9ee1f93f6a77c564f9 upstream.
SFI tables reside in RAM and should not be modified once they are
written. Current code went to set pentry->irq to zero which causes
subsequent reads to fail with invalid SFI table checksum. This will
break kexec as the second kernel fails to validate SFI tables.
To fix this we use temporary variable for irq number.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit a94cc4e6c0a26a7c8f79a432ab2c89534aa674d5 upstream.
According to the SFI specification irq number 0xFF means device has no
interrupt or interrupt attached via GPIO.
Currently, we don't handle this special case and set irq field in
*_board_info structs to 255. It leads to confusion in some drivers.
Accelerometer driver tries to register interrupt 255, fails and prints
"Cannot get IRQ" to dmesg.
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 1c70c0cebd1295a42fec75045b8a6b4419cedef3 upstream.
They use the same register interfaces, so we can simply enable the
existing code on IVB.
v2:
- resolve conflict with ring freq scaling, we can enable it too
v3:
- resolve conflict again, this time on drm-intel-next
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Keith Packard <keithp@keithp.com>
Signed-off-by: Robert Hooker <robert.hooker@canonical.com>
Acked-by: Leann Ogasawara <leann.ogasawara@canonical.com>
Acked-by: Herton Krzesinski <herton.krzesinski@canonical.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit b872a37437e93df9d112ce674752b3b3a0a17020 upstream.
Noticed by Egbert.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: Egbert Eich <eich@suse.de>
commit cb871513f656bdfc48b185b55f37857b5c750c40 upstream.
Revert commit 6123b0e274503a0d3588e84fbe07c9aa01bfaf5d.
The problem this patch intends to solve has alreadqy been fixed by
commit 7a5caabd090b ("drivers/leds/ledtrig-timer.c: fix broken sysfs
delay handling").
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Cc: Antonio Ospite <ospite@studenti.unina.it>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Richard Purdie <rpurdie@rpsys.net>
commit bc5b8a9003132ae44559edd63a1623b7b99dfb68 upstream.
On a corrupted file system the ->len field could be wrong leading to
a buffer overflow.
Reported-and-acked-by: Clement LECIGNE <clement.lecigne@netasq.com>
commit 9f35a33b8d06263a165efe3541d9aa0cdbd70b3b upstream.
Fix a NULL pointer deref in the user-defined key type whereby updating a
negative key into a fully instantiated key will cause an oops to occur
when the code attempts to free the non-existent old payload.
This results in an oops that looks something like the following:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
PGD 3391d067 PUD 3894a067 PMD 0
Oops: 0002 [#1] SMP
CPU 1
Pid: 4354, comm: keyctl Not tainted 3.1.0-fsdevel+ #1140 /DG965RY
RIP: 0010:[<ffffffff81085fa1>] [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
RSP: 0018:ffff88003d591df8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000006e
RDX: ffffffff8161d0c0 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88003d591e18 R08: 0000000000000000 R09: ffffffff8152fa6c
R10: 0000000000000000 R11: 0000000000000300 R12: ffff88003b8f9538
R13: ffffffff8161d0c0 R14: ffff88003b8f9d50 R15: ffff88003c69f908
FS: 00007f97eb18c720(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CR2: 0000000000000008 CR3: 000000003d47a000 CR4: 00000000000006e0
Process keyctl (pid: 4354, threadinfo ffff88003d590000, task ffff88003c78a040)
Stack:
ffff88003e0ffde0 ffff88003b8f9538 0000000000000001 ffff88003b8f9d50
ffff88003d591e28 ffffffff810860f0 ffff88003d591e68 ffffffff8117bfea
ffff88003d591e68 ffffffff00000000 ffff88003e0ffde1 ffff88003e0ffde0
Call Trace:
[<ffffffff810860f0>] call_rcu_sched+0x10/0x12
[<ffffffff8117bfea>] user_update+0x8d/0xa2
[<ffffffff8117723a>] key_create_or_update+0x236/0x270
[<ffffffff811789b1>] sys_add_key+0x123/0x17e
[<ffffffff813b84bb>] system_call_fastpath+0x16/0x1b
Acked-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Neil Horman <nhorman@redhat.com>
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: James Morris <jmorris@namei.org>
commit dcaaf9f2c16b56f8bb316881fcd3f15c18fc71e7 upstream.
In the recent usb-audio driver, the initialization of volume ranges
may be delayed when the device doesn't respond well at the probing time.
But the volume quirks for certain devices are applied only in
mixer_ctl_feature_info() thus only at the very first probe and will be
missing when the volume range is initialized later.
This patch moves the volume quirk code to be always called from the
volume-range extraction (get_min_max()), so that the quirks are properly
applied in the later init time.
Reported-and-tested-by: Alexey Fisher <bug-track@fisher-privat.net>
commit 9fcd0ab130579d9742538340edda3225f2b49a3e upstream.
When the initial check of dB-range failed due to the read error, try to
check again at the later read, too. When an invalid dB range is found,
remove TLV flags and notify the mixer info change.
commit 091264f0bc12419560ac64fcef4567809d611658 upstream.
Can happen when there is no DP panel attached, confusing
users. Make it debug only.
commit 5e60ee780e792efe6dce97eceb110b1d30bab850 upstream.
Fence lock needs to be initialized before any call to nouveau_channel_put
because it calls nouveau_channel_idle->nouveau_fence_update which uses
fence lock.
BUG: spinlock bad magic on CPU#0, test/24134
lock: ffff88019f90dba8, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
Pid: 24134, comm: test Not tainted 3.0.0-nv+ #800
Call Trace:
spin_bug+0x9c/0xa3
do_raw_spin_lock+0x29/0x13c
_raw_spin_lock+0x1e/0x22
nouveau_fence_update+0x2d/0xf1
nouveau_channel_idle+0x22/0xa0
nouveau_channel_put_unlocked+0x84/0x1bd
nouveau_channel_put+0x20/0x24
nouveau_channel_alloc+0x4ec/0x585
nouveau_ioctl_fifo_alloc+0x50/0x130
drm_ioctl+0x289/0x361
do_vfs_ioctl+0x4dd/0x52c
sys_ioctl+0x42/0x65
It's easily triggerable from userspace.
Additionally remove double initialization of chan->fence.pending.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit 14660ccd599dc7bd6ecef17408bd76dc853f9b77 upstream.
I've been seeing memory leaks on my system in the form of large
(300-400MB) GEM objects created by now-dead processes laying around
clogging up memory. I usually notice when it gets to about 1.2GB of
them. Hopefully this clears up the issue, but I just found this bug
by inspection.
Signed-off-by: Eric Anholt <eric@anholt.net>
commit dfd3b596fbbfa48b8e7966ef996d587157554b69 upstream.
In the case of 29bit mode, CAC/UNCAC_ADDR does not return a right address.
This revises this problem by using P1SEGADDR and P2SEGADDR in 29bit mode.
Reported-by: Yutaro Ebihara <ebiharaml@si-linux.co.jp>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Tested-by: Simon Horman <horms@verge.net.au>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit 8eeea521d9d0fa6afd62df8c6e6566ee946117fa upstream.
The field is no longer initialised so this will crash if running on
wm8958.
Reported-by: Thomas Abraham <thomas.abraham@linaro.org>
commit 72103bd1285211440621f2c46f4fce377584de54 upstream.
Commit 31a3ddda166cda86d2b5111e09ba4bda5239fae6 introduced
a use after free in virtio-pci. The main issue is
that the release method signals removal of the virtio device,
while remove signals removal of the pci device.
For example, on driver removal or hot-unplug,
virtio_pci_release_dev is called before virtio_pci_remove.
We then might get a crash as virtio_pci_remove tries to use the
device freed by virtio_pci_release_dev.
We allocate/free all resources together with the
pci device, so we can leave the release method empty.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Amit Shah <amit.shah@redhat.com>
commit aeb4b88ec0a948efce8e3a23a8f964d3560a7308 upstream.
When a virtual mater control is created, the driver looks for slave
elements from the assigned card instance. But this may include the
elements of other codecs when multiple codecs are on the same HD-audio
bus. This works at the first time, but it'll give Oops when it's once
freed and re-created via reconfig sysfs.
This patch changes the element-look-up strategy to limit only to the
mixer elements of the same codec.
Reported-by: David Henningsson <david.henningsson@canonical.com>
commit 21404b772a1c65f7b935b8c0fddc388a949f4e31 upstream.
This removes the use of the special "macbookair_fn_keys" keyboard
translation table for the MacBookAir4,x models (ie the 2011 refresh).
They use the standard apple_fn_keys[] translation. Apparently only the
old MacBook Air's need a different translation table.
This mirrors the change that commit da617c7cb915 ("HID: consolidate
MacbookAir 4,1 mappings") did for the WELLSPRING6A ones, but does it for
the WELLSPRING6 model used on the MacBookAir4,2.
Reported-and-tested-by: Dirk Hohndel <hohndel@infradead.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Joshua V Dillon <jvdillon@gmail.com>
Cc: Chase Douglas <chase.douglas@canonical.com>
commit da617c7cb915545dda4280df888dd6f8d5697420 upstream.
MacbookAir 4,1 doesn't require extra mapping table, as the mappings
are identical to apple_fn_keys[].
commit ad734bc1565364f9e4b70888d3ce5743b3c1030a upstream.
I've recently bought a Apple wireless aluminum keyboard (model 2011) which is
not yet supported by the kernel - it seems they just changed the device id.
After applying the attached patch, the device is fully functional.
Signed-off-by: Andreas Krist <andreas.krist@gmail.com>
commit 213f9da80533940560bef8fa43b10c590895459c upstream.
This patch adds keyboard support for Macbook Pro 8 models which has
WELLSPRING5A model name and 0x0252, 0x0253 and 0x0254 USB IDs. Trackpad
support for those models are added to bcm5974 in
c331eb580a0a7906c0cdb8dbae3cfe99e3c0e555 ("Input: bcm5974 - Add
support for newer MacBookPro8,2).
Signed-off-by: Gökçen Eraslan <gokcen@pardus.org.tr>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
commit d762cc290b9f17e346f4297fd5984b70ce71ef66 upstream.
Added USB device IDs and keyboard map for MacBookAir 4,1 keyboard.
commit f6f554f09c5b831efdaf67c449e18ca06ee648fe upstream.
Otherwise the generic driver wouldn't unbind from it and wouldn't
let hid-apple to automatically take over.
commit c50bb1a4005630f47b5da26336f74a485033a515 upstream.
This panel is also known as the Dell ST2220Tc.
Signed-off-by: jeffbrown@android.com
Reviewed-By: Benjamin Tissoires <Benjamin_Tissoires@logitech.com>
commit 5d922baa631058c7e37ae33e81c4d3e6437f8d1d upstream.
Added USB device IDs for MacBookAir4,2 keyboard. Device constants were
copied from the MacBookAir3,2 constants. The 4,2 device specification is
reportedly unchanged from the 3,2 predecessor and seems to work well.
Signed-off-by: Joshua V Dillon <jvdillon@gmail.com>
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
commit 6d1db0777981e1626ae71243984ac300b61789ff upstream.
Create each gamepad as a separate joystick
Signed-off-by: Clemens Werther <clemens.werther@gmail.com>
commit 4a4c879904aa0cc64629e14a49b64fb3d149bf1a upstream.
Add USB device ids for the new revision (MB110LL/B) of Apple's wired aluminum
keyboard. I have only confirmed that the ANSI version is correct - it is
assumed that the ISO and JIS versions follow the standard numbering convention.
Signed-off-by: Dan Bastone <dan@pwienterprises.com>
commit f722013ee9fd24623df31dec9a91a6d02c3e2f2f upstream.
In nand_do_write_ops() code it is possible for a caller to provide
ops.oobbuf populated and ops.mode == MTD_OOB_AUTO, which currently
means that the chip->oob_poi buffer isn't initialised to all 0xFF.
The nand_fill_oob() method then carries out the task of copying
the provided OOB data to oob_poi, but with MTD_OOB_AUTO it skips
areas marked as unavailable by the layout struct, including the
bad block marker bytes.
An example of this causing issues is when the last OOB data read
was from the start of a bad block where the markers are not 0xFF,
and the caller wishes to write new OOB data at the beginning of
another block. In this scenario the caller would provide OOB data,
but nand_fill_oob() would skip the bad block marker bytes in
oob_poi before copying the OOB data provided by the caller.
This means that when the OOB data is written back to NAND,
the block is inadvertently marked as bad without the caller knowing.
This has been witnessed when using YAFFS2 where tags are stored
in the OOB.
To avoid this oob_poi is always initialised to 0xFF to make sure
no left over data is inadvertently written back to the OOB area.
Credits to Brian Norris <computersforpeace@gmail.com> for fixing this
patch.
Signed-off-by: Adam Thomson <adam.thomson@alcatel-lucent.com>
Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
commit 52d6d4ef5e6d1517688e27c11c01ab303ec681dd upstream.
My recent commits (3782c69d, 324c74a) introduced regression
for register offset selection that based on the macversion.
Not using parentheses in proper manner for ternary operator
leads to select wrong offset for the registers.
This issue was observed with AR9462 chip that immediate disconnect
after the association with the following message
ieee80211 phy3: wlan0: Failed to send nullfunc to AP 00:23:69:12:ea:47
after 500ms, disconnecting.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
commit f5ff7cd1a84caa9545d952a37ac872ccb73825fb upstream.
The previous commit enforces a new rule for handling the cloned packets
for transmit time stamping. These packets must not be freed using any other
function than skb_complete_tx_timestamp. This commit fixes the one and only
driver using this API.
The driver first appeared in v3.0.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
commit b2bac6acf86d05d8af0499f37d91ecac15722803 upstream.
As cryptd is depeneded on by other algorithms such as aesni-intel,
it needs to be registered before them. When everything is built
as modules, this occurs naturally. However, for this to work when
they are built-in, we need to use subsys_initcall in cryptd.
Tested-by: Josh Boyer <jwboyer@redhat.com>
Cc: Kerin Millar <kerframil@gmail.com>
commit 528f7ce6e439edeac38f6b3f8561f1be129b5e91 upstream.
In enter_state() we use "state" as an offset for the pm_states[]
array. The pm_states[] array only has PM_SUSPEND_MAX elements so
this test is off by one.
commit aa1c366e4febc7f5c2b84958a2dd7cd70e28f9d0 upstream.
With the conversion of struct flowi to a union of AF-specific structs, some
operations on the flow cache need to account for the exact size of the key.
Signed-off-by: David Ward <david.ward@ll.mit.edu>
Cc: Kim Phillips <kim.phillips@freescale.com>
commit 728871bc05afc8ff310b17dba3e57a2472792b13 upstream.
AF-specific flowi structs are now passed to flow_key_compare, which must
also be aligned to a long.
commit 8c0bec2151a47906bf779c6715a10ce04453ab77 upstream.
The i_mutex lock and flush_completed_IO() added by commit 2581fdc810
in ext4_evict_inode() causes lockdep complaining about potential
deadlock in several places. In most/all of these LOCKDEP complaints
it looks like it's a false positive, since many of the potential
circular locking cases can't take place by the time the
ext4_evict_inode() is called; but since at the very least it may mask
real problems, we need to address this.
This change removes the flush_completed_IO() and i_mutex lock in
ext4_evict_inode(). Instead, we take a different approach to resolve
the software lockup that commit 2581fdc810 intends to fix. Rather
than having ext4-dio-unwritten thread wait for grabing the i_mutex
lock of an inode, we use mutex_trylock() instead, and simply requeue
the work item if we fail to grab the inode's i_mutex lock.
This should speed up work queue processing in general and also
prevents the following deadlock scenario: During page fault,
shrink_icache_memory is called that in turn evicts another inode B.
Inode B has some pending io_end work so it calls ext4_ioend_wait()
that waits for inode B's i_ioend_count to become zero. However, inode
B's ioend work was queued behind some of inode A's ioend work on the
same cpu's ext4-dio-unwritten workqueue. As the ext4-dio-unwritten
thread on that cpu is processing inode A's ioend work, it tries to
grab inode A's i_mutex lock. Since the i_mutex lock of inode A is
still hold before the page fault happened, we enter a deadlock.
Signed-off-by: Jiaying Zhang <jiayingz@google.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 543e32d5ff165d0d68deedb0e3557478c7c36a4a upstream.
This bug was introduced in f8155a40 ("mtd: pxa3xx_nand: rework irq
logic") and causes the PXA3xx NAND controller fail to operate with NAND
flash that has empty pages. According to the comment in this block, the
hardware controller will report a double-bit error for empty pages,
which can and must be ignored.
This patch restores the original behaviour of the driver.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Acked-by: Lei Wen <leiwen@marvell.com>
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: David Woodhouse <David.Woodhouse@intel.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit 0fab028b77d714ad302404b23306cf7adb885223 upstream.
When keep_config is set, the detection would goes different routine.
That the driver would read out the setting which is set previously
by bootloader. While most bootloader keep the irq mask as off, and
current driver need all irq default open, keep_config behavior would
lead to no irq at all.
Signed-off-by: Lei Wen <leiwen@marvell.com>
Tested-by: Daniel Mack <zonque@gmail.com>
commit d5de1907d0af22e1a02de2b16a624148517a39c2 upstream.
parse_mtd_partitions takes a list of partition types; if the driver
isn't loaded, it attempts to load it, and then it grabs the partition
parser. For redboot, the module name is "redboot.ko", while the parser
name is "RedBoot". Since modprobe is case-sensitive, attempting to
modprobe "RedBoot" will never work. I suspect the embedded systems that
make use of redboot just always manually loaded redboot prior to loading
their specific nand chip drivers (or statically compiled it in).
Signed-off-by: Andres Salomon <dilinger@queued.net>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit bf5140817b2d65faac9b32fc9057a097044ac35b upstream.
On writes in MODE_RAW the mtd_oob_ops struct is not sufficiently
initialized which may cause nandwrite to fail. With this patch
it is possible to write raw nand/oob data without additional ECC
(either for testing or when some sectors need different oob layout
e.g. bootloader) like
nandwrite -n -r -o /dev/mtd0 <myfile>
Signed-off-by: Peter Wippich <pewi@gw-instruments.de>
Tested-by: Ricard Wanderlof <ricardw@axis.com>
