* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: Make struct pcmcia_device_id const, sound drivers edition
staging: pcmcia: Convert pcmcia_device_id declarations to const
pcmcia: Make declaration and uses of struct pcmcia_device_id const
pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits)
drivers/gpu/drm/radeon/atom.c: fix warning
drm/radeon/kms: bump kms version number
drm/radeon/kms: properly set num banks for fusion asics
drm/radeon/kms/atom: move dig phy init out of modesetting
drm/radeon/kms/cayman: fix typo in register mask
drm/radeon/kms: fix typo in spread spectrum code
drm/radeon/kms: fix tile_config value reported to userspace on cayman.
drm/radeon/kms: fix incorrect comparison in cayman setup code.
drm/radeon/kms: add wait idle ioctl for eg->cayman
drm/radeon/cayman: setup hdp to invalidate and flush when asked
drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked
agp/uninorth: Fix lockups with radeon KMS and >1x.
drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only
drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices
drm/radeon/kms: fixup eDP connector handling
drm/radeon/kms: bail early for eDP in hotplug callback
drm/radeon/kms: simplify hotplug handler logic
drm/radeon/kms: rewrite DP handling
drm/radeon/kms/atom: add support for setting DP panel mode
drm/radeon/kms: atombios.h updates for DP panel mode
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (29 commits)
[S390] cpu hotplug: fix external interrupt subclass mask handling
[S390] oprofile: dont access lowcore
[S390] oprofile: add missing irq stats counter
[S390] Ignore sendmmsg system call note wired up warning
[S390] s390,oprofile: fix compile error for !CONFIG_SMP
[S390] s390,oprofile: fix alert counter increment
[S390] Remove unused includes in process.c
[S390] get CPC image name
[S390] sclp: event buffer dissection
[S390] chsc: process channel-path-availability information
[S390] refactor page table functions for better pgste support
[S390] merge page_test_dirty and page_clear_dirty
[S390] qdio: prevent compile warning
[S390] sclp: remove unnecessary sendmask check
[S390] convert old cpumask API into new one
[S390] pfault: cleanup code
[S390] pfault: cpu hotplug vs missing completion interrupts
[S390] smp: add __noreturn attribute to cpu_die()
[S390] percpu: implement arch specific irqsafe_cpu_ops
[S390] vdso: disable gcov profiling
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits)
Input: ADP5589 - new driver for I2C Keypad Decoder and I/O Expander
Input: tsc2007 - add X, Y and Z fuzz factors to platform data
Input: tsc2007 - add poll_period parameter to platform data
Input: tsc2007 - add poll_delay parameter to platform data
Input: tsc2007 - add max_rt parameter to platform data
Input: tsc2007 - debounce pressure measurement
Input: ad714x - fix captouch wheel option algorithm
Input: ad714x - allow platform code to specify irqflags
Input: ad714x - fix threshold and completion interrupt masks
Input: ad714x - fix up input configuration
Input: elantech - remove support for proprietary X driver
Input: elantech - report multitouch with proper ABS_MT messages
Input: elantech - export pressure and width when supported
Input: elantech - describe further the protocol
Input: atmel_tsadcc - correct call to input_free_device
Input: add driver FSL MPR121 capacitive touch sensor
Input: remove useless synchronize_rcu() calls
Input: ads7846 - fix gpio_pendown configuration
Input: ads7846 - add possibility to use external vref on ads7846
Input: rotary-encoder - add support for half-period encoders
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Unify input section names
percpu: Avoid extra NOP in percpu_cmpxchg16b_double
percpu: Cast away printk format warning
percpu: Always align percpu output section to PAGE_SIZE
Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
* 'linux-next' of git://git.infradead.org/ubi-2.6:
UBI: switch to dynamic printks
UBI: turn some macros into static inline
UBI: improve checking in debugging prints
UBI: fix typo in a message
UBI: fix minor stylistic issues
UBI: use __packed instead of __attribute__((packed))
UBI: cleanup comments around volume properties
UBI: re-name set volume properties ioctl
UBI: make the control character device non-seekable
* 'linux-next' of git://git.infradead.org/ubifs-2.6: (52 commits)
UBIFS: switch to dynamic printks
UBIFS: fix kernel-doc comments
UBIFS: fix extremely rare mount failure
UBIFS: simplify LEB recovery function further
UBIFS: always cleanup the recovered LEB
UBIFS: clean up LEB recovery function
UBIFS: fix-up free space on mount if flag is set
UBIFS: add the fixup function
UBIFS: add a superblock flag for free space fix-up
UBIFS: share the next_log_lnum helper
UBIFS: expect corruption only in last journal head LEBs
UBIFS: synchronize write-buffer before switching to the next bud
UBIFS: remove BUG statement
UBIFS: change bud replay function conventions
UBIFS: substitute the replay tree with a replay list
UBIFS: simplify replay
UBIFS: store free and dirty space in the bud replay entry
UBIFS: remove unnecessary stack variable
UBIFS: double check that buds are replied in order
UBIFS: make 2 functions static
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (22 commits)
m68knommu: Use generic show_interrupts()
coldfire_qspi compile fix
m68k: merge the mmu and non-mmu versions of sys_m68k.c
m68knommu: use asm-generic/bitops/ext2-atomic.h
m68knommu: Remove obsolete #include <linux/sys.h>
m68k: merge mmu and non-mmu versions of asm-offsets.c
m68k: merge non-mmu and mmu versions of m68k_ksyms.c
m68knommu: remove un-needed exporting of COLDFIRE symbols
m68knommu: move EXPORT of kernel_thread to function definition
m68knommu: move EXPORT of local checksumming functions to definitions
m68knommu: move EXPORT of dump_fpu to function definition
m68knommu: clean up mm/init_no.c
m68k: merge the mmu and non-mmu mm/Makefile
m68k: mv kmap_mm.c to kmap.c
m68knommu: remove stubs for __ioremap() and iounmap()
m68knommu: remove unused kernel_set_cachemode()
m68k: let Makefile sort out compiling mmu and non-mmu lib/checksum.c
m68k: remove duplicate memcpy() implementation
m68k: remove duplicate memset() implementation
m68k: remove duplicate memmove() implementation
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, ioapic: Restore ioapic entries during resume properly
x86: Get rid of asmregparm
um: Use RWSEM_GENERIC_SPINLOCK on x86
In mask/restore_ioapic_entries() we should be restoring ioapic
entries when ioapics[apic].saved_registers is not NULL.
Fix the typo and address the resume hang regression reported by
Linus.
This was not found sooner because the systems where these
changes were tested on kept the IO-APIC entries intact over
resume.
Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Daniel J Blueman <daniel.blueman@gmail.com>
Link: http://lkml.kernel.org/r/1306259131.7171.7.camel@sbsiddha-MOBL3.sc.intel.com
As UML does no longer need asmregparm we can remove it.
Signed-off-by: Richard Weinberger <richard@nod.at>
Cc: namhyung@gmail.com
Cc: davem@davemloft.net
Cc: fweisbec@gmail.com
Cc: dhowells@redhat.com
Link: http://lkml.kernel.org/r/%3C1306189085-29896-1-git-send-email-richard%40nod.at%3E
Commit d12337 (rwsem: Remove redundant asmregparm annotation)
broke rwsem on UML.
As we cannot compile UML with -mregparm=3 and keeping asmregparm only
for UML is inadequate the easiest solution is using RWSEM_GENERIC_SPINLOCK.
Thanks to Thomas Gleixner for the idea.
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Tested-by: Toralf Förster <toralf.foerster@gmx.de>
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: <stable@kernel.org> # .39.x
Link: http://lkml.kernel.org/r/%3C1306183893-26655-1-git-send-email-richard%40nod.at%3E
Apart from whitespace differences, /proc/interrupts doesn't change by
enabling GENERIC_IRQ_SHOW.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
The m68k/m68knommu merge broke the qspi build.
Signed-off-by: Steven King <sfking@fdwdc.com>
There is a lot of common code in the sys_m68k.c files. The mmu and non-mmu
versions can easily be merged into a single file.
There is really only 2 functions that differ in the 2 cases. A single
ifdef on CONFIG_MMU can take care of this. Alternatively we could break
those 2 functions out and maintain sys_m68k_no.c and sys_m68k_mm.c with
just this code in it (Makefile could then just build the right one).
Does anyone have strong feelings on which way they want this done?
m68knommu can use generic implementation of ext2 atomic bitops.
It is strait forward to merge the mmu and non-mmu versions of
asm-offstes.c. Some name changes are required for the preempt and
thread_info.flags in the non-mmu entry.S assembler to make them
consistent for both setups.
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (23 commits)
sh: Ignore R_SH_NONE module relocations.
SH: SE7751: Fix pcibios_map_platform_irq prototype.
sh: remove warning and warning_symbol from struct stacktrace_ops
sh: wire up sys_sendmmsg.
clocksource: sh_tmu: Runtime PM support
clocksource: sh_tmu: __clocksource_updatefreq_hz() update
clocksource: sh_cmt: Runtime PM support
clocksource: sh_cmt: __clocksource_updatefreq_hz() update
dmaengine: shdma: synchronize RCU before freeing, simplify spinlock
dmaengine: shdma: add runtime- and system-level power management
dmaengine: shdma: fix locking
sh: sh-sci: sh7377 and sh73a0 build fixes
sh: cosmetic improvement: use an existing pointer
serial: sh-sci: suspend/resume wakeup support V2
serial: sh-sci: Runtime PM support
sh: select IRQ_FORCED_THREADING.
sh: intc: Set virtual IRQs as nothread.
sh: fixup fpu.o compile order
i2c: add a module alias to the sh-mobile driver
ALSA: add a module alias to the FSI driver
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools: Fix sample type size calculation in 32 bits archs
profile: Use vzalloc() rather than vmalloc() & memset()
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (247 commits)
[media] gspca - sunplus: Fix some warnings and simplify code
[media] gspca: Fix some warnings tied to 'no debug'
[media] gspca: Unset debug by default
[media] gspca - cpia1: Remove a bad conditional compilation instruction
[media] gspca - main: Remove USB traces
[media] gspca - main: Version change to 2.13
[media] gspca - stk014 / t613: Accept the index 0 in querymenu
[media] gspca - kinect: Remove __devinitdata
[media] gspca - cpia1: Fix some warnings
[media] video/Kconfig: Fix mis-classified devices
[media] support for medion dvb stick 1660:1921
[media] tm6000: fix uninitialized field, change prink to dprintk
[media] cx231xx: Add support for Iconbit U100
[media] saa7134 add new TV cards
[media] Use a more consistent value for RC repeat period
[media] cx18: Move spinlock and vb_type initialisation into stream_init
[media] tm6000: remove tm6010 sif audio start and stop
[media] tm6000: remove unused exports
[media] tm6000: add pts logging
[media] tm6000: change from ioctl to unlocked_ioctl
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6:
fat: Fix statfs->f_namelen
fat: Replace all printk with fat_msg()
fat: Add fat_msg() function for preformated FAT messages
fat: Convert fat_fs_error to use %pV
fat: Fix possible null deref in fat_cache_add()
fat: use new setup() for ->dir_ops too
The coretemp driver provides a single set of device attributes for each
physical core of a HT CPU to avoid duplicate sensors. This
functionality was introduced with commit d883b9f09772 ("hwmon:
(coretemp) Skip duplicate CPU entries").
Commit e40cc4bdfd4b ("x86/hwmon: register alternate sibling upon CPU
removal") extends this functionality to register the HT sibling of a CPU
which is taken offline, to ensure that sensor attributes are provided if
at least one HT sibling of a core is online.
Add comments into the code describing the functionality in some more
detail.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Durgadoss R <durgadoss.r@intel.com>
We try to enforce it by using -Wstrict-prototypes, but apparently they
sometimes get through. Introduced by 4eec42f39204 ("watchdog: Change
the default timeout and configure nmi watchdog period based").
The shift used here to count the number of bits set in
the mask doesn't work above the low part for archs that
are not 64 bits.
Fix the constant used for the shift.
This fixes a 32-bit perf top failure reported by Eric Dumazet:
Can't parse sample, err = -14
Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com
Link: http://lkml.kernel.org/r/1306200686-17317-1-git-send-email-fweisbec@gmail.com
After cleaning up m68k_ksyms_no.c it is now strait forward to merge
the non-mmu and mmu versions of m68k_ksyms.c. The need for the extra
gcc functions is not strictly based on having an MMU or not. It is
based on the family the processor belongs too, so use an appropriate
conditional check.
There is no reason most of the symbols enclosed in a conditional
on CONFIG_COLDFIRE need to be exported. And they sure don't need to
be doing it in m68k_ksyms_no.c. Move the dma symbols export (which
are currently needed) to the definitions of those, and remove the
rest of the exporting here.
The EXPORT_SYMBOL(kernel_thread) belongs at the definition of that function,
not in some other random code file. So move it there.
The EXPORT_SYMBOL() of the local lib checksum functions belongs with
the definitions, not in some other random code file. So move then there.
The EXPORT_SYMBOL(dump_fpu) belongs at the definition of the function,
The memory initialization code for m68knommu has grown a bit crufty,
clean it up.
. remove unused declaration for die_if_kernel()
. remove un-needed declaration of free_initmem()
. removed unused definitions of empty_bad_page and empty_bad_page_table
. removed unused DEBUG code
. make free_initmem() proper prototype
Its is trivial to megre the mmu and non-mmu arch/m68k/mm/Makefile's back
into a single file. So do it.
The non-mmu kmap_no.c has been removed. So we can move kmap_mm.c
back to being the only kmap.c.
The implementation of iounmap() and __ioremap() for non-mmu m68k is
trivial. We can inline them in m68knommu headers and remove the trivial
implementations.
None of the m68knommu platforms will ever use kernel_set_cachemode().
And it is specific to a couple of m68k devices. So remove it.
We don't need an arch/m68k/lib/checksum.c wrapper to include the correct
mmu or non-mmu version of the checksum code. Let the Makefile just build
the appropriate one.
Merging the mmu and non-mmu directories we ended up with duplicate
implementations of memcpy(). One is a little more optimized for the
>= 68020 case, but that can easily be inserted into a single
implementation of memcpy(). Clean up the exporting of this symbol
too, otherwise we end up exporting it twice on a no-mmu build.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
implementations of memset(). One is a little more optimized for the
implementation of memset(). Clean up the exporting of this symbol
(and identical) implementations of memmove(). Remove one of them.
We can easily support the slight differences in libs needed by the
mmu and non-mmu builds in a single Makefile, so merge them back into
a single file again.
The implementation of gcc's muldi3 support function differs only in
the use of the machine's 64 bit sized mul or not. (It isn't based
on using an MMU or not). Merge the current mmu and non-mmu versions
of arc/m68k/lib/muldi3 and use the appropriate pre-processor
conditionals to get the right version for all m68k processor types.
* 'drm-radeon-next' of /ssd/git/drm-radeon-next: (32 commits)
udelay() doesn't like 8-bit arguments:
drivers/gpu/drm/radeon/atom.c: In function 'atom_op_delay':
drivers/gpu/drm/radeon/atom.c:653: warning: comparison is always false due to limited range of data type
while we're there, use msleep() rather than open-coding it.
Cc: David Airlie <airlied@linux.ie>
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
Cc: Matt Turner <mattst88@gmail.com>
- proper bank size for fusion for 2D tiling.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
Needed by userspace for 2D tiled buffer alignment
It only needs to be called once at startup, not for every
modeset.
Noticed by Droste on IRC.
