Dan Carpenter's static code checker reports:
The patch 473ed7be0da0: "gpio / ACPI: Add support for ACPI GPIO
operation regions" from Mar 14, 2014, leads to the following static
checker warning:
drivers/gpio/gpiolib-acpi.c:454 acpi_gpio_adr_space_handler()
warn: should 'gpiod_get_raw_value(desc) << i' be a 64 bit type?
This is due the fact that *value is of type u64 and gpiod_get_raw_value()
returns int. Since i can be larger than 31, it is possible that the value
returned gets wrapped.
Fix this by casting the return of gpiod_get_raw_value() to u64 first before
shift.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Commit aa92b6f689ac (gpio / ACPI: Allocate ACPI specific data directly in
acpi_gpiochip_add()) moved ACPI handle checking to acpi_gpiochip_add() but
forgot to check whether chip->dev is NULL before dereferencing it.
Since chip->dev pointer is optional we can end up with crash like following:
BUG: unable to handle kernel NULL pointer dereference at 00000138
IP: [<c126c2b3>] acpi_gpiochip_add+0x13/0x190
*pde = 00000000
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: ssb(+) ...
CPU: 0 PID: 512 Comm: modprobe Tainted: G W 3.14.0-rc7-next-20140324-t1 #24
Hardware name: Dell Inc. Latitude D830 /0UY141, BIOS A02 06/07/2007
task: f5799900 ti: f543e000 task.ti: f543e000
EIP: 0060:[<c126c2b3>] EFLAGS: 00010282 CPU: 0
EIP is at acpi_gpiochip_add+0x13/0x190
EAX: 00000000 EBX: f57824c4 ECX: 00000000 EDX: 00000000
ESI: f57824c4 EDI: 00000010 EBP: f543fc54 ESP: f543fc40
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
CR0: 8005003b CR2: 00000138 CR3: 355f8000 CR4: 000007d0
Stack:
f543fc5c fd1f7790 f57824c4 000000be 00000010 f543fc84 c1269f4e f543fc74
fd1f78bd 00008002 f57822b0 f5782090 fd1f8400 00000286 fd1f9994 00000000
f5782000 f543fc8c fd1f7e39 f543fcc8 fd1f0bd8 000000c0 00000000 00000000
Call Trace:
[<fd1f7790>] ? ssb_pcie_mdio_write+0xa0/0xd0 [ssb]
[<c1269f4e>] gpiochip_add+0xee/0x300
[<fd1f78bd>] ? ssb_pcicore_serdes_workaround+0xfd/0x140 [ssb]
[<fd1f7e39>] ssb_gpio_init+0x89/0xa0 [ssb]
[<fd1f0bd8>] ssb_attach_queued_buses+0xc8/0x2d0 [ssb]
[<fd1f0f65>] ssb_bus_register+0x185/0x1f0 [ssb]
[<fd1f3120>] ? ssb_pci_xtal+0x220/0x220 [ssb]
[<fd1f106c>] ssb_bus_pcibus_register+0x2c/0x80 [ssb]
[<fd1f40dc>] ssb_pcihost_probe+0x9c/0x110 [ssb]
[<c1276c8f>] pci_device_probe+0x6f/0xc0
[<c11bdb55>] ? sysfs_create_link+0x25/0x40
[<c131d8b9>] driver_probe_device+0x79/0x360
[<c1276512>] ? pci_match_device+0xb2/0xc0
[<c131dc51>] __driver_attach+0x71/0x80
[<c131dbe0>] ? __device_attach+0x40/0x40
[<c131bd87>] bus_for_each_dev+0x47/0x80
[<c131d3ae>] driver_attach+0x1e/0x20
[<c131d007>] bus_add_driver+0x157/0x230
[<c131e219>] driver_register+0x59/0xe0
Fix this by checking chip->dev pointer against NULL first. Also we can now
remove redundant check in acpi_gpiochip_request/free_interrupts().
Reported-by: Sabrina Dubroca <sd@queasysnail.net>
Tested-by: Sabrina Dubroca <sd@queasysnail.net>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Tested-by: Josh Boyer <jwboyer@fedoraproject.org>
During irq mapping, in irq_set_chip_and_handler() the process
of setting this up may incur calls to lock the irqchip, which
in turn may need to dereference and use the chip data. So set
the data first, then set the chip and handler.
Some versions of gcc even warn about it:
mm/shmem.c: In function ‘shmem_file_aio_read’:
mm/shmem.c:1414: warning: ‘error’ may be used uninitialized in this function
If the loop is aborted during the first iteration by one of the two
first break statements, error will be uninitialized.
Introduced by commit 6e58e79db8a1 ("introduce copy_page_to_iter, kill
loop over iovec in generic_file_aio_read()").
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
On 32 bit, size_t is "unsigned int", not "unsigned long", causing the
following warning when comparing with PAGE_SIZE, which is always "unsigned
long":
fs/cifs/file.c: In function ‘cifs_readdata_to_iov’:
fs/cifs/file.c:2757: warning: comparison of distinct pointer types lacks a cast
Introduced by commit 7f25bba819a3 ("cifs_iovec_read: keep iov_iter
between the calls of cifs_readdata_to_iov()"), which changed the
signedness of "remaining" and the code from min_t() to min().
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull slab changes from Pekka Enberg:
"The biggest change is byte-sized freelist indices which reduces slab
freelist memory usage:
https://lkml.org/lkml/2013/12/2/64"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
mm: slab/slub: use page->list consistently instead of page->lru
mm/slab.c: cleanup outdated comments and unify variables naming
slab: fix wrongly used macro
slub: fix high order page allocation problem with __GFP_NOFAIL
slab: Make allocations with GFP_ZERO slightly more efficient
slab: make more slab management structure off the slab
slab: introduce byte sized index for the freelist of a slab
slab: restrict the number of objects in a slab
slab: introduce helper functions to get/set free object
slab: factor out calculate nr objects in cache_estimate
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull misc kbuild changes from Michal Marek:
"Here is the non-critical part of kbuild:
- One bogus coccinelle check removed, one check fixed not to suggest
the obsolete PTR_RET macro
- scripts/tags.sh does not index the generated *.mod.c files
- new objdiff tool to list differences between two versions of an
object file
- A fix for scripts/bootgraph.pl"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scripts/coccinelle: Use PTR_ERR_OR_ZERO
scripts/bootgraph.pl: Add graphic header
scripts: objdiff: detect object code changes between two commits
Coccicheck: Remove memcpy to struct assignment test
scripts/tags.sh: Ignore *.mod.c
This patch fixes I/O errors with the sym53c8xx_2 driver when the disk
returns QUEUE FULL status.
When the controller encounters an error (including QUEUE FULL or BUSY
status), it aborts all not yet submitted requests in the function
sym_dequeue_from_squeue.
This function aborts them with DID_SOFT_ERROR.
If the disk has full tag queue, the request that caused the overflow is
aborted with QUEUE FULL status (and the scsi midlayer properly retries
it until it is accepted by the disk), but the sym53c8xx_2 driver aborts
the following requests with DID_SOFT_ERROR --- for them, the midlayer
does just a few retries and then signals the error up to sd.
The result is that disk returning QUEUE FULL causes request failures.
The error was reproduced on 53c895 with COMPAQ BD03685A24 disk
(rebranded ST336607LC) with command queue 48 or 64 tags. The disk has
64 tags, but under some access patterns it return QUEUE FULL when there
are less than 64 pending tags. The SCSI specification allows returning
QUEUE FULL anytime and it is up to the host to retry.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: James Bottomley <JBottomley@Parallels.com>
Commit 8f619b5429d9 ("powerpc/ppc64: Do not turn AIL (reloc-on
interrupts) too early") added code to set the AIL bit in the LPCR
without checking whether the kernel is running in hypervisor mode. The
result is that when the kernel is running as a guest (i.e., under
PowerKVM or PowerVM), the processor takes a privileged instruction
interrupt at that point, causing a panic. The visible result is that
the kernel hangs after printing "returning from prom_init".
This fixes it by checking for hypervisor mode being available before
setting LPCR. If we are not in hypervisor mode, we enable relocation-on
interrupts later in pSeries_setup_arch using the H_SET_MODE hcall.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Commits 11d4616bd07f ("futex: revert back to the explicit waiter
counting code") and 69cd9eba3886 ("futex: avoid race between requeue and
wake") changed some of the finer details of how we think about futexes.
One was a late fix and the other a consequence of overlooking the whole
requeuing logic.
The first change caused our documentation to be incorrect, and the
second made us aware that we need to explicitly add more details to it.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Pull yet more networking updates from David Miller:
1) Various fixes to the new Redpine Signals wireless driver, from
Fariya Fatima.
2) L2TP PPP connect code takes PMTU from the wrong socket, fix from
Dmitry Petukhov.
3) UFO and TSO packets differ in whether they include the protocol
header in gso_size, account for that in skb_gso_transport_seglen().
From Florian Westphal.
4) If VLAN untagging fails, we double free the SKB in the bridging
output path. From Toshiaki Makita.
5) Several call sites of sk->sk_data_ready() were referencing an SKB
just added to the socket receive queue in order to calculate the
second argument via skb->len. This is dangerous because the moment
the skb is added to the receive queue it can be consumed in another
context and freed up.
It turns out also that none of the sk->sk_data_ready()
implementations even care about this second argument.
So just kill it off and thus fix all these use-after-free bugs as a
side effect.
6) Fix inverted test in tcp_v6_send_response(), from Lorenzo Colitti.
7) pktgen needs to do locking properly for LLTX devices, from Daniel
Borkmann.
8) xen-netfront driver initializes TX array entries in RX loop :-) From
Vincenzo Maffione.
9) After refactoring, some tunnel drivers allow a tunnel to be
configured on top itself. Fix from Nicolas Dichtel.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (46 commits)
vti: don't allow to add the same tunnel twice
gre: don't allow to add the same tunnel twice
drivers: net: xen-netfront: fix array initialization bug
pktgen: be friendly to LLTX devices
r8152: check RTL8152_UNPLUG
net: sun4i-emac: add promiscuous support
net/apne: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
net: ipv6: Fix oif in TCP SYN+ACK route lookup.
drivers: net: cpsw: enable interrupts after napi enable and clearing previous interrupts
drivers: net: cpsw: discard all packets received when interface is down
net: Fix use after free by removing length arg from sk_data_ready callbacks.
Drivers: net: hyperv: Address UDP checksum issues
Drivers: net: hyperv: Negotiate suitable ndis version for offload support
Drivers: net: hyperv: Allocate memory for all possible per-pecket information
bridge: Fix double free and memory leak around br_allowed_ingress
bonding: Remove debug_fs files when module init fails
i40evf: program RSS LUT correctly
i40evf: remove open-coded skb_cow_head
ixgb: remove open-coded skb_cow_head
igbvf: remove open-coded skb_cow_head
git://git.kernel.org/pub/scm/linux/kernel/git/realmz6/blackfin-linux
Pull blackfin updates from Steven Miao:
"Code cleanup, some previously ignored patches, and bug fixes"
* tag 'blackfin-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/realmz6/blackfin-linux:
blackfin: cleanup board files
bf609: clock: drop unused clock bit set/clear functions
Blackfin: bf537: rename "CONFIG_ADT75"
Blackfin: bf537: rename "CONFIG_AD7314"
Blackfin: bf537: rename ad2s120x ->ad2s1200
blackfin: bf537: fix typo "CONFIG_SND_SOC_ADV80X_MODULE"
blackfin: dma: current count mmr is read only
bfin_crc: Move architecture independant crc header file out of the blackfin folder.
bf54x: drop unuesd HOST status,control,timeout registers bit define macros
blackfin: portmux: cleanup head file
Blackfin: remove "config IP_CHECKSUM_L1"
blackfin: Remove GENERIC_GPIO config option again
blackfin:Use generic /proc/interrupts implementation
blackfin: bf60x: fix typo "CONFIG_PM_BFIN_WAKE_PA15_POL"
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc
Pull remoteproc cleanups from Ohad Ben-Cohen:
"Several remoteproc cleanup patches coming from Jingoo Han, Julia
Lawall and Uwe Kleine-König"
* tag 'remoteproc-3.15-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc:
remoteproc/ste_modem: staticize local symbols
remoteproc/davinci: simplify use of devm_ioremap_resource
remoteproc/davinci: drop needless devm_clk_put
git://git.linuxfoundation.org/llvmlinux/kernel
Pull llvm patches from Behan Webster:
"These are some initial updates to support compiling the kernel with
clang.
These patches have been through the proper reviews to the best of my
ability, and have been soaking in linux-next for a few weeks. These
patches by themselves still do not completely allow clang to be used
with the kernel code, but lay the foundation for other patches which
are still under review.
Several other of the LLVMLinux patches have been already added via
maintainer trees"
* tag 'llvmlinux-for-v3.15' of git://git.linuxfoundation.org/llvmlinux/kernel:
x86: LLVMLinux: Fix "incomplete type const struct x86cpu_device_id"
x86 kbuild: LLVMLinux: More cc-options added for clang
x86, acpi: LLVMLinux: Remove nested functions from Thinkpad ACPI
LLVMLinux: Add support for clang to compiler.h and new compiler-clang.h
LLVMLinux: Remove warning about returning an uninitialized variable
kbuild: LLVMLinux: Fix LINUX_COMPILER definition script for compilation with clang
Documentation: LLVMLinux: Update Documentation/dontdiff
kbuild: LLVMLinux: Adapt warnings for compilation with clang
kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Here are the target pending updates for v3.15-rc1. Apologies in
advance for waiting until the second to last day of the merge window
to send these out.
The highlights this round include:
- iser-target support for T10 PI (DIF) offloads (Sagi + Or)
- Fix Task Aborted Status (TAS) handling in target-core (Alex Leung)
- Pass in transport supported PI at session initialization (Sagi + MKP + nab)
- Add WRITE_INSERT + READ_STRIP T10 PI support in target-core (nab + Sagi)
- Fix iscsi-target ERL=2 ASYNC_EVENT connection pointer bug (nab)
- Fix tcm_fc use-after-free of ft_tpg (Andy Grover)
- Use correct ib_sg_dma primitives in ib_isert (Mike Marciniszyn)
Also, note the virtio-scsi + vhost-scsi changes to expose T10 PI
metadata into KVM guest have been left-out for now, as there where a
few comments from MST + Paolo that where not able to be addressed in
time for v3.15. Please expect this feature for v3.16-rc1"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (43 commits)
ib_srpt: Use correct ib_sg_dma primitives
target/tcm_fc: Rename ft_tport_create to ft_tport_get
target/tcm_fc: Rename ft_{add,del}_lport to {add,del}_wwn
target/tcm_fc: Rename structs and list members for clarity
target/tcm_fc: Limit to 1 TPG per wwn
target/tcm_fc: Don't export ft_lport_list
target/tcm_fc: Fix use-after-free of ft_tpg
target: Add check to prevent Abort Task from aborting itself
target: Enable READ_STRIP emulation in target_complete_ok_work
target/sbc: Add sbc_dif_read_strip software emulation
target: Enable WRITE_INSERT emulation in target_execute_cmd
target/sbc: Add sbc_dif_generate software emulation
target/sbc: Only expose PI read_cap16 bits when supported by fabric
target/spc: Only expose PI mode page bits when supported by fabric
target/spc: Only expose PI inquiry bits when supported by fabric
target: Pass in transport supported PI at session initialization
target/iblock: Fix double bioset_integrity_free bug
Target/sbc: Initialize COMPARE_AND_WRITE write_sg scatterlist
target/rd: T10-Dif: RAM disk is allocating more space than required.
iscsi-target: Fix ERL=2 ASYNC_EVENT connection pointer bug
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"A series of bug fix patches for v3.15-rc1. Most are just driver
fixes. There are some changes at remote controller core level, fixing
some definitions on a new API added for Kernel v3.15.
It also adds the missing include at include/uapi/linux/v4l2-common.h,
to allow its compilation on userspace, as pointed by you"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (24 commits)
[media] gpsca: remove the risk of a division by zero
[media] stk1160: warrant a NUL terminated string
[media] v4l: ti-vpe: retain v4l2_buffer flags for captured buffers
[media] v4l: ti-vpe: Set correct field parameter for output and capture buffers
[media] v4l: ti-vpe: zero out reserved fields in try_fmt
[media] v4l: ti-vpe: Fix initial configuration queue data
[media] v4l: ti-vpe: Use correct bus_info name for the device in querycap
[media] v4l: ti-vpe: report correct capabilities in querycap
[media] v4l: ti-vpe: Allow usage of smaller images
[media] v4l: ti-vpe: Use video_device_release_empty
[media] v4l: ti-vpe: Make sure in job_ready that we have the needed number of dst_bufs
[media] lgdt3305: include sleep functionality in lgdt3304_ops
[media] drx-j: use customise option correctly
[media] m88rs2000: fix sparse static warnings
[media] r820t: fix size and init values
[media] rc-core: remove generic scancode filter
[media] rc-core: split dev->s_filter
[media] rc-core: do not change 32bit NEC scancode format for now
[media] rtl28xxu: remove duplicate ID 0458:707f Genius TVGo DVB-T03
[media] xc2028: add missing break to switch
Pull PCIe non-transparent bridge fixes and features from Jon Mason:
"NTB driver bug fixes to address issues in list traversal, skb leak in
ntb_netdev, a typo, and a leak of msix entries in the error path.
Clean ups of the event handling logic, as well as a overall style
cleanup. Finally, the driver was converted to use the new
pci_enable_msix_range logic (and the refactoring to go along with it)"
* tag 'ntb-3.15' of git://github.com/jonmason/ntb:
ntb: Use pci_enable_msix_range() instead of pci_enable_msix()
ntb: Split ntb_setup_msix() into separate BWD/SNB routines
ntb: Use pci_msix_vec_count() to obtain number of MSI-Xs
NTB: Code Style Clean-up
NTB: client event cleanup
ntb: Fix leakage of ntb_device::msix_entries[] array
NTB: Fix typo in setting one translation register
ntb_netdev: Fix skb free issue in open
ntb_netdev: Fix list_for_each_entry exit issue
The vfs merge caused a latent bug to show up:
In file included from fs/ceph/super.h:4:0,
from fs/ceph/ioctl.c:3:
include/linux/ceph/ceph_debug.h:4:0: warning: "pr_fmt" redefined [enabled by default]
#define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
In file included from include/linux/kernel.h:13:0,
from include/linux/uio.h:12,
from include/linux/socket.h:7,
from include/uapi/linux/in.h:22,
from include/linux/in.h:23,
from fs/ceph/ioctl.c:1:
include/linux/printk.h:214:0: note: this is the location of the previous definition
#define pr_fmt(fmt) fmt
where the reason is that <linux/ceph_debug.h> is included much too late
for the "pr_fmt()" define.
The include of <linux/ceph_debug.h> needs to be the first include in the
file, but fs/ceph/ioctl.c had for some reason missed that, and it wasn't
noticeable until some unrelated header file changes brought in an
indirect earlier include of <linux/kernel.h>.
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Nicolas Dichtel says:
tunnels: don't allow to add the same tunnel twice
This series fixes the check of an existing tunnel with the same
parameters when a new tunnel is added. I've checked all users of
ip_tunnel_newlink(): gre, gretap, ipip and vti. The bug exists only
for gre and vti.
Before the patch, it was possible to add two times the same tunnel:
ip l a vti1 type vti remote 10.16.0.121 local 10.16.0.249 key 41
ip l a vti2 type vti remote 10.16.0.121 local 10.16.0.249 key 41
It was possible, because ip_tunnel_newlink() calls ip_tunnel_find() with the
argument dev->type, which was set only later (when calling ndo_init handler
in register_netdevice()). Let's set this type in the setup handler, which is
called before newlink handler.
Introduced by commit b9959fd3b0fa ("vti: switch to new ip tunnel code").
CC: Cong Wang <amwang@redhat.com>
CC: Steffen Klassert <steffen.klassert@secunet.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
ip l a gre1 type gre remote 10.16.0.121 local 10.16.0.249
ip l a gre2 type gre remote 10.16.0.121 local 10.16.0.249
Introduced by commit c54419321455 ("GRE: Refactor GRE tunneling code.").
CC: Pravin B Shelar <pshelar@nicira.com>
This patch fixes the initialization of an array used in the TX
datapath that was mistakenly initialized together with the
RX datapath arrays. An out of range array access could happen
when RX and TX rings had different sizes.
Signed-off-by: Vincenzo Maffione <v.maffione@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net
Jeff Kirsher says:
Intel Wired LAN Driver Updates
This series contains updates to e1000, e1000e, igb, igbvf, ixgb, ixgbe,
ixgbevf and i40evf.
Mark fixes an issue with ixgbe and ixgbevf by adding a bit to indicate
when workqueues have been initialized. This permits the register read
error handling from attempting to use them prior to that, which also
generates warnings. Checking for a detected removal after initializing
the work queues allows the probe function to return an error without
getting the workqueue involved. Further, if the error_detected
callback is entered before the workqueues are initialized, exit without
recovery since the device initialization was so truncated.
Francois Romieu provides several patches to all the drivers to remove
the open coded skb_cow_head.
Jakub Kicinski provides a fix for igb where last_rx_timestamp should be
updated only when Rx time stamp is read.
Mitch provides a fix for i40evf where a recent change broke the RSS LUT
programming causing it to be programmed with all 0's.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull more tracing updates from Steven Rostedt:
"This includes the final patch to clean up and fix the issue with the
design of tracepoints and how a user could register a tracepoint and
have that tracepoint not be activated but no error was shown.
The design was for an out of tree module but broke in tree users. The
clean up was to remove the saving of the hash table of tracepoint
names such that they can be enabled before they exist (enabling a
module tracepoint before that module is loaded). This added more
complexity than needed. The clean up was to remove that code and just
enable tracepoints that exist or fail if they do not.
This removed a lot of code as well as the complexity that it brought.
As a side effect, instead of registering a tracepoint by its name, the
tracepoint needs to be registered with the tracepoint descriptor.
This removes having to duplicate the tracepoint names that are
enabled.
The second patch was added that simplified the way modules were
searched for.
This cleanup required changes that were in the 3.15 queue as well as
some changes that were added late in the 3.14-rc cycle. This final
change waited till the two were merged in upstream and then the change
was added and full tests were run. Unfortunately, the test found some
errors, but after it was already submitted to the for-next branch and
not to be rebased. Sparse errors were detected by Fengguang Wu's bot
tests, and my internal tests discovered that the anonymous union
initialization triggered a bug in older gcc compilers. Luckily, there
was a bugzilla for the gcc bug which gave a work around to the
problem. The third and fourth patch handled the sparse error and the
gcc bug respectively.
A final patch was tagged along to fix a missing documentation for the
README file"
* tag 'trace-3.15-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Add missing function triggers dump and cpudump to README
tracing: Fix anonymous unions in struct ftrace_event_call
tracepoint: Fix sparse warnings in tracepoint.c
tracepoint: Simplify tracepoint module search
tracepoint: Use struct pointer instead of name hash for reg/unreg tracepoints
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
that commit has fixed only the parts of that mess in fs/splice.c itself;
there had been more in several other ->splice_read() instances...
O_APPEND handling there hadn't been completely fixed by Pavel's
patch; it checks the right value, but it's racy - we can't really
do that until i_mutex has been taken.
Fix by switching to __generic_file_aio_write() (open-coding
generic_file_aio_write(), actually) and pulling mutex_lock() above
inode_size_read().
Cc: stable@vger.kernel.org
ceph_osdc_put_request(ERR_PTR(-error)) oopses. What we want there
is break, not goto out.
Similarly to commit 43279500deca ("packet: respect devices with
LLTX flag in direct xmit"), we can basically apply the very same
to pktgen. This will help testing against LLTX devices such as
dummy driver (or others), which only have a single netdevice txq
and would otherwise require locking their txq from pktgen side
while e.g. in dummy case, we would not need any locking. Fix this
by making use of HARD_TX_{UN,}LOCK API, so that NETIF_F_LLTX will
be respected.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Eric Dumazet <edumazet@google.com>
When the device is unplugged, the driver would try to disable the
device. Add checking the flag of RTL8152_UNPLUG to skip setting
the device when it is unplugged. This could shorten the time of
unloading the driver.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
The sun4i-emac driver is rather primitive, and doesn't support
promiscuous mode. This makes usage such as bridging impossible,
which is a shame on virtualization capable HW such as the
Allwinner A20.
The fix is fairly simple: move the RX setup code to the ndo_set_rx_mode
vector, and add the required HW configuration when IFF_PROMISC is passed
by the core code.
This has been tested on a generic A20 box running a few virtual
machines hanging off a bridge with the EMAC chip as the link to the
outside world.
Cc: Stefan Roese <sr@denx.de>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
This patch fixes coccinelle error regarding usage of IS_ERR and
PTR_ERR instead of PTR_ERR_OR_ZERO.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
using IS_ENABLED() macro instead of defined(CONFIG_XXX) || defined(CONFIG_XXX_MODULE)
Signed-off-by: Steven Miao <realmz6@gmail.com>
In v3.2 the Analog Devices ADT75 temperature sensor driver was removed
as an IIO driver and support for it was added to the LM75 HWMON driver.
But it was apparently overlooked to rename one reference to CONFIG_ADT75
to CONFIG_SENSORS_LM75. Do so now. Use the IS_ENABLED() macro, while
we're at it.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
In v3.2 the Analog Devices AD7314 temperature sensor driver was removed
as an IIO driver and added as a HWMON driver. But it was apparently
overlooked to rename two references to CONFIG_AD7314 to
CONFIG_SENSORS_AD7314. Do so now. Use the IS_ENABLED() macro, while
we're at it.
In v3.2 the Analog Devices ad2s1200/ad2s1205 driver was renamed from
ad2s120x to ad2s1200. But it apparently forgot to rename the references
to this driver in the BF537-STAMP code. Rename these now, and use the
IS_ENABLED() macro, while we're at it.
There's a (rather subtle) typo in "CONFIG_SND_SOC_ADV80X_MODULE". Fix it
once and for all by using IS_ENABLED(), which is designed to avoid
issues like this.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
folder.
drop unused head file
change pinmux request/free macro for backward compatiblity
add function declaration
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isci
Pull async SCSI resume support from Dan Williams:
"Allow disks and other devices to resume in parallel.
This provides a tangible speed up for a non-esoteric use case (laptop
resume):
https://01.org/suspendresume/blogs/tebrandt/2013/hard-disk-resume-optimization-simpler-approach"
* 'async-scsi-resume' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isci:
scsi: async sd resume
Pull md updates from Neil Brown:
"Just a few md patches for the 3.15 merge window.
Not much happening in md/raid at the moment. Just a few bug fixes
(one for -stable) and a couple of performance tweaks"
* tag 'md/3.15' of git://neil.brown.name/md:
raid5: get_active_stripe avoids device_lock
raid5: make_request does less prepare wait
md: avoid oops on unload if some process is in poll or select.
md/raid1: r1buf_pool_alloc: free allocate pages when subsequent allocation fails.
md/bitmap: don't abuse i_writecount for bitmap files.
Pull NVMe driver updates from Matthew Wilcox:
"Various updates to the NVMe driver. The most user-visible change is
that drive hotplugging now works and CPU hotplug while an NVMe drive
is installed should also work better"
* git://git.infradead.org/users/willy/linux-nvme:
NVMe: Retry failed commands with non-fatal errors
NVMe: Add getgeo to block ops
NVMe: Start-stop nvme_thread during device add-remove.
NVMe: Make I/O timeout a module parameter
NVMe: CPU hot plug notification
NVMe: per-cpu io queues
NVMe: Replace DEFINE_PCI_DEVICE_TABLE
NVMe: Fix divide-by-zero in nvme_trans_io_get_num_cmds
NVMe: IOCTL path RCU protect queue access
NVMe: RCU protected access to io queues
NVMe: Initialize device reference count earlier
NVMe: Add CONFIG_PM_SLEEP to suspend/resume functions
Pull aio ctx->ring_pages migration serialization fix from Ben LaHaise.
* git://git.kvack.org/~bcrl/aio-next:
aio: v4 ensure access to ctx->ring_pages is correctly serialised for migration
The code was incorrectly using sg_dma_address() and
sg_dma_len() instead of ib_sg_dma_address() and
ib_sg_dma_len().
This prevents srpt from functioning with the
Intel HCA and indeed will corrupt memory
badly.
Cc: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Tested-by: Vinod Kumar <vinod.kumar@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Cc: stable@vger.kernel.org # 3.3+
Because it doesn't always create, if there's an existing one it just
returns it.
Signed-off-by: Andy Grover <agrover@redhat.com>
