The adis16080 reports sample values in twos complement. So we need to perform a
sign extension on the result, otherwise negative values will be reported
incorrectly as large positive values.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Fix the following warning when building with W=1 option:
drivers/staging/iio/adc/mxs-lradc.c: In function 'mxs_lradc_trigger_handler':
drivers/staging/iio/adc/mxs-lradc.c:244:2: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
Instantiating the driver with no available regulator results in:
[39711.686393] i2c i2c-7: new_device: Instantiated device max1139 at 0x35
[39711.688687] BUG: unable to handle kernel paging request at fffffffffffffe13
[39711.688734] IP: [<ffffffff813e835b>] regulator_disable+0x1b/0x80
[39711.688788] PGD 1c0e067 PUD 1c0f067 PMD 0
[39711.688835] Oops: 0000 [#1] SMP
Caused by bad probe error path. Fix it.
Driver should also not attempt to free the interrupt in its error path if
none was allocated. Fix that problem as well.
Finally, testing if the regulator was allocated is not necessary in the
remove function, since the probe function bails out if this is the case.
Remove that check.
regulator_get_voltage() may return negative error code.
Add error checking to avoid setting error code to voltage_uv.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Don't set error code to to pos_voltage_uv and neg_voltage_uv.
Add error checking to avoid setting error code to st->vref_uv.
Not much to say, without that change, hid-sensor-trigger will be
always compiled if HID_SENSOR_IIO_COMMON is selected which fails if
CONFIG_IIO_TRIGGER is not set because CONFIG_IIO_CONSUMERS_PER_TRIGGER
will not be defined.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
/opt/work/linux-2.6/drivers/iio/adc/at91_adc.c: In function 'at91_adc_trigger_handler':
/opt/work/linux-2.6/drivers/iio/adc/at91_adc.c:83:22: error: 'indio_dev' undeclared (first use in this function)
/opt/work/linux-2.6/drivers/iio/adc/at91_adc.c:83:22: note: each undeclared identifier is reported only once for each function it appears in
Cc: linux-iio@vger.kernel.org
Commit 9d5e9fdf ("staging:iio:adis16260: Use adis library") switched over the
adis16260 driver to use the common adis library but neglected to update the
Kconfig entry to reflect the change.
This leads to the following compile error if no other driver selects the adis
library:
drivers/built-in.o: In function `adis16260_write_frequency':
adis16260_core.c:(.text+0x5a83bf): undefined reference to `adis_write_reg_8'
drivers/built-in.o: In function `adis16260_read_frequency':
adis16260_core.c:(.text+0x5a8433): undefined reference to `adis_read_reg_16'
drivers/built-in.o: In function `adis16260_write_raw':
adis16260_core.c:(.text+0x5a8538): undefined reference to `adis_write_reg_16'
adis16260_core.c:(.text+0x5a856b): undefined reference to `adis_write_reg_16'
drivers/built-in.o: In function `adis16260_read_raw':
adis16260_core.c:(.text+0x5a85d3): undefined reference to `adis_single_conversion'
adis16260_core.c:(.text+0x5a873e): undefined reference to `adis_read_reg_16'
adis16260_core.c:(.text+0x5a87fb): undefined reference to `adis_read_reg_16'
drivers/built-in.o: In function `adis16260_probe':
adis16260_core.c:(.devinit.text+0x5c6b8): undefined reference to `adis_init'
adis16260_core.c:(.devinit.text+0x5c799): undefined reference to `adis_initial_startup'
drivers/built-in.o: In function `adis16260_remove':
adis16260_core.c:(.devexit.text+0x9943): undefined reference to `adis_write_reg_16'
This patch updates the adis16260 Kconfig entry to select the adis library.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
There is a typo in the adf4350 driver turning a shift into a compare. This patch
fixes it.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Pull watchdog updates from Wim Van Sebroeck:
"This includes some fixes and code improvements (like
clk_prepare_enable and clk_disable_unprepare), conversion from the
omap_wdt and twl4030_wdt drivers to the watchdog framework, addition
of the SB8x0 chipset support and the DA9055 Watchdog driver and some
OF support for the davinci_wdt driver."
* git://www.linux-watchdog.org/linux-watchdog: (22 commits)
watchdog: mei: avoid oops in watchdog unregister code path
watchdog: Orion: Fix possible null-deference in orion_wdt_probe
watchdog: sp5100_tco: Add SB8x0 chipset support
watchdog: davinci_wdt: add OF support
watchdog: da9052: Fix invalid free of devm_ allocated data
watchdog: twl4030_wdt: Change TWL4030_MODULE_PM_RECEIVER to TWL_MODULE_PM_RECEIVER
watchdog: remove depends on CONFIG_EXPERIMENTAL
watchdog: Convert dev_printk(KERN_<LEVEL> to dev_<level>(
watchdog: DA9055 Watchdog driver
watchdog: omap_wdt: eliminate goto
watchdog: omap_wdt: delete redundant platform_set_drvdata() calls
watchdog: omap_wdt: convert to devm_ functions
watchdog: omap_wdt: convert to new watchdog core
watchdog: WatchDog Timer Driver Core: fix comment
watchdog: s3c2410_wdt: use clk_prepare_enable and clk_disable_unprepare
watchdog: imx2_wdt: Select the driver via ARCH_MXC
watchdog: cpu5wdt.c: add missing del_timer call
watchdog: hpwdt.c: Increase version string
watchdog: Convert twl4030_wdt to watchdog core
davinci_wdt: preparation for switch to common clock framework
Pull CIFS fixes from Steve French:
"Misc small cifs fixes"
* 'for-next' of git://git.samba.org/sfrench/cifs-2.6:
cifs: eliminate cifsERROR variable
cifs: don't compare uniqueids in cifs_prime_dcache unless server inode numbers are in use
cifs: fix double-free of "string" in cifs_parse_mount_options
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm
Pull dm update from Alasdair G Kergon:
"Miscellaneous device-mapper fixes, cleanups and performance
improvements.
Of particular note:
- Disable broken WRITE SAME support in all targets except linear and
striped. Use it when kcopyd is zeroing blocks.
- Remove several mempools from targets by moving the data into the
bio's new front_pad area(which dm calls 'per_bio_data').
- Fix a race in thin provisioning if discards are misused.
- Prevent userspace from interfering with the ioctl parameters and
use kmalloc for the data buffer if it's small instead of vmalloc.
- Throttle some annoying error messages when I/O fails."
* tag 'dm-3.8-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (36 commits)
dm stripe: add WRITE SAME support
dm: remove map_info
dm snapshot: do not use map_context
dm thin: dont use map_context
dm raid1: dont use map_context
dm flakey: dont use map_context
dm raid1: rename read_record to bio_record
dm: move target request nr to dm_target_io
dm snapshot: use per_bio_data
dm verity: use per_bio_data
dm raid1: use per_bio_data
dm: introduce per_bio_data
dm kcopyd: add WRITE SAME support to dm_kcopyd_zero
dm linear: add WRITE SAME support
dm: add WRITE SAME support
dm: prepare to support WRITE SAME
dm ioctl: use kmalloc if possible
dm ioctl: remove PF_MEMALLOC
dm persistent data: improve improve space map block alloc failure message
dm thin: use DMERR_LIMIT for errors
This reverts commit 79f77bf9a4e3dd5ead006b8f17e7c4ff07d8374e.
This is obviously wrong, and I have no idea how I missed seeing the
warning in testing: I must just not have looked at the right logs. The
caller bumps rq_resused/rq_next_page, so it will always be hit on a
large enough read.
Reported-by: Dave Jones <davej@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull more infiniband changes from Roland Dreier:
"Second batch of InfiniBand/RDMA changes for 3.8:
- cxgb4 changes to fix lookup engine hash collisions
- mlx4 changes to make flow steering usable
- fix to IPoIB to avoid pinning dst reference for too long"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
RDMA/cxgb4: Fix bug for active and passive LE hash collision path
RDMA/cxgb4: Fix LE hash collision bug for passive open connection
RDMA/cxgb4: Fix LE hash collision bug for active open connection
mlx4_core: Allow choosing flow steering mode
mlx4_core: Adjustments to Flow Steering activation logic for SR-IOV
mlx4_core: Fix error flow in the flow steering wrapper
mlx4_core: Add QPN enforcement for flow steering rules set by VFs
cxgb4: Add LE hash collision bug fix path in LLD driver
cxgb4: Add T4 filter support
IPoIB: Call skb_dst_drop() once skb is enqueued for sending
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic cleanup from Arnd Bergmann:
"These are a few cleanups for asm-generic:
- a set of patches from Lars-Peter Clausen to generalize asm/mmu.h
and use it in the architectures that don't need any special
handling.
- A patch from Will Deacon to remove the {read,write}s{b,w,l} as
discussed during the arm64 review
- A patch from James Hogan that helps with the meta architecture
series."
* tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
xtensa: Use generic asm/mmu.h for nommu
h8300: Use generic asm/mmu.h
c6x: Use generic asm/mmu.h
asm-generic/mmu.h: Add support for FDPIC
asm-generic/mmu.h: Remove unused vmlist field from mm_context_t
asm-generic: io: remove {read,write} string functions
asm-generic/io.h: remove asm/cacheflush.h include
Commit db5b0ae00712 ("Merge tag 'dt' of git://git.kernel.org/.../arm-soc")
causes a duplicated build target. This patch fixes it and sorts out the
build target alphabetically so that we can recognize something wrong
easily.
Cc: Olof Johansson <olof@lixom.net>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Rename stripe_map_discard to stripe_map_range and reuse it for WRITE
SAME bio processing.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
This patch removes map_info from bio-based device mapper targets.
map_info is still used for request-based targets.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Eliminate struct map_info from dm-snap.
map_info->ptr was used in dm-snap to indicate if the bio was tracked.
If map_info->ptr was non-NULL, the bio was linked in tracked_chunk_hash.
This patch removes the use of map_info->ptr. We determine if the bio was
tracked based on hlist_unhashed(&c->node). If hlist_unhashed is true,
the bio is not tracked, if it is false, the bio is tracked.
This patch removes endio_hook_pool from dm-thin and uses per-bio data instead.
This patch removes any use of map_info in preparation for the next patch
that removes map_info from bio-based device mapper.
Don't use map_info any more in dm-raid1.
map_info was used for writes to hold the region number. For this purpose
we add a new field dm_bio_details to dm_raid1_bio_record.
map_info was used for reads to hold a pointer to dm_raid1_bio_record (if
the pointer was non-NULL, bio details were saved; if the pointer was
NULL, bio details were not saved). We use
dm_raid1_bio_record.details->bi_bdev for this purpose. If bi_bdev is
NULL, details were not saved, if bi_bdev is non-NULL, details were
saved.
Replace map_info with a per-bio structure "struct per_bio_data" in dm-flakey.
Rename struct read_record to bio_record in dm-raid1.
In the following patch, the structure will be used for both read and
write bios, so rename it.
This patch moves target_request_nr from map_info to dm_target_io and
makes it accessible with dm_bio_get_target_request_nr.
This patch is a preparation for the next patch that removes map_info.
Replace tracked_chunk_pool with per_bio_data in dm-snap.
Replace io_mempool with per_bio_data in dm-verity.
Replace read_record_pool with per_bio_data in dm-raid1.
Introduce a field per_bio_data_size in struct dm_target.
Targets can set this field in the constructor. If a target sets this
field to a non-zero value, "per_bio_data_size" bytes of auxiliary data
are allocated for each bio submitted to the target. These data can be
used for any purpose by the target and help us improve performance by
removing some per-target mempools.
Per-bio data is accessed with dm_per_bio_data. The
argument data_size must be the same as the value per_bio_data_size in
dm_target.
If the target has a pointer to per_bio_data, it can get a pointer to
the bio with dm_bio_from_per_bio_data() function (data_size must be the
same as the value passed to dm_per_bio_data).
Add WRITE SAME support to dm-io and make it accessible to
dm_kcopyd_zero(). dm_kcopyd_zero() provides an asynchronous interface
whereas the blkdev_issue_write_same() interface is synchronous.
WRITE SAME is a SCSI command that can be leveraged for more efficient
zeroing of a specified logical extent of a device which supports it.
Only a single zeroed logical block is transfered to the target for each
WRITE SAME and the target then writes that same block across the
specified extent.
The dm thin target uses this.
The linear target can already support WRITE SAME requests so signal
this by setting num_write_same_requests to 1.
WRITE SAME bios have a payload that contain a single page. When
cloning WRITE SAME bios DM has no need to modify the bi_io_vec
attributes (and doing so would be detrimental). DM need only alter the
start and end of the WRITE SAME bio accordingly.
Rather than duplicate __clone_and_map_discard, factor out a common
function that is also used by __clone_and_map_write_same.
Allow targets to opt in to WRITE SAME support by setting
'num_write_same_requests' in the dm_target structure.
A dm device will only advertise WRITE SAME support if all its
targets and all its underlying devices support it.
If the parameter buffer is small enough, try to allocate it with kmalloc()
rather than vmalloc().
vmalloc is noticeably slower than kmalloc because it has to manipulate
page tables.
In my tests, on PA-RISC this patch speeds up activation 13 times.
On Opteron this patch speeds up activation by 5%.
This patch introduces a new function free_params() to free the
parameters and this uses new flags that record whether or not vmalloc()
was used and whether or not the input buffer must be wiped after use.
When allocating memory for the userspace ioctl data, set some
appropriate GPF flags directly instead of using PF_MEMALLOC.
Improve space map error message when unable to allocate a new
metadata block.
Signed-off-by: Joe Thornber <ejt@redhat.com>
Throttle all errors logged from the IO path by dm thin.
Nearly all of persistent-data is in the IO path so throttle error
messages with DMERR_LIMIT to limit the amount logged when
something has gone wrong.
Reinstate a useful error message when the block manager buffer validator fails.
This was mistakenly eliminated when the block manager was converted to use
dm-bufio.
If the user does not supply a bitmap region_size to the dm raid target,
a reasonable size is computed automatically. If this is not a power of 2,
the md code will report an error later.
This patch catches the problem early and rounds the region_size to the
next power of two.
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Remove unused @data_block parameter from cell_defer.
Change thin_bio_map to use many returns rather than setting a variable.
Rename cell_defer_except() to cell_defer_no_holder() which describes
its function more clearly.
track_chunk is always called with interrupts enabled. Consequently, we
do not need to save and restore interrupt state in "flags" variable.
This patch changes spin_lock_irqsave to spin_lock_irq and
spin_unlock_irqrestore to spin_unlock_irq.
Use a defined macro DM_ENDIO_INCOMPLETE instead of a numeric constant.
mempool_alloc can't fail if __GFP_WAIT is specified, so the condition
that tests if read_record is non-NULL is always true.
