The exynos ADC won't work without a regulator called "vdd" and a clock
called "adc". Document this fact in the device tree bindings.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
We need to initialize hardware before registering the touchscreen. Else,
we end up setting registers in mxs_lradc_ts_open(), getting called just
after registering the touchscreen with input_register_device() and by
the end of mxs_lradc_probe(), we reset the LRADC block hence losing the
correct configuration.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Fixes some typos in the documentation of exynos-adc.txt.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
exynos_adc is a DT only driver and exynos_adc_match table is always
compiled in. Hence remove the macro.
Avoid allocating and freeing the sample buffer for each transfer. Instead
allocate it once when we start sampling. Also pre-compute the number of bytes we
need to transfer in the same way.
The driver has support for reporting a channels scale, but none of the channels
set the IIO_CHAN_INFO_SCALE mask. Add the IIO_CHAN_INFO_SCALE to all channels to
indicate that the drivers supports reporting the scale.
The ad779x channels all follow the same pattern. Add a helper macro to
initialize the channel spec, this allows us to drop quite a few lines.
Use i2c_smbus_{read,write}_word_data_swapped instead of open-coding it.
None of the devices supported by this driver have an internal voltage reference,
so remove support for it from the driver.
Remove fields from the ad799x_state struct which are not used.
Use dev_{set,get}_drvdata for managing private data attached to a trigger
instead of using a custom field in the iio_trigger struct.
Introduce iio_tigger_{set,get}_drvdata which allows to attach driver specific
data to a trigger. The functions wrap access to the triggers private_data field
and all current users are updated to use iio_tigger_{set,get}_drvdata instead of
directly accessing the private_data field. This is the first step towards
removing the private_data field from the iio_trigger struct.
The following coccinelle script has been used to update the drivers:
<smpl>
struct iio_trigger *trigger;
expression priv;
-trigger->private_data = priv
+iio_trigger_set_drv_data(trigger, priv)
+iio_trigger_get_drv_data(trigger)
</smpl>
This macro relies on a local variable having a specific name. Replace
it with a new helper function, s626_mc_disable().
Cc: Ian Abbott <abbotti@mev.co.uk>
it with a new helper function, s626_mc_enable().
Currently the unused s626_ai_rinsn() function is commented out with
/* ... */ on every line of the function. Remove those by using an
This block will be removed once it is determined that it really
is not needed.
Reformat the whitespace in the comedi_lrange table and use the
BIP_RANGE() macro instead of generic RANGE() macro.
Factor the code that handles the counter interrupt out of s626_irq_handler().
Factor the code that handles the end of scan interrupt out of
s626_irq_handler().
Remove the printk noise when cfc_write_to_buffer() fails. The user
can't do anything about it anyway.
The comedi_async pointer is used a number of times in this function.
For aesthetic reasons, use a local variable for the pointer.
Also, since was already have a pointer to the "cmd" use that in the
for loop instead of s->async->cmd (or even async->cmd).
The comedi_subdevice in this function is actually the dev->read_subdev
that was initialized during the attach of the board. Use that instead
of accessing the dev->subdevices array directly.
Also, get the comedi_cmd used in s626_irq_handler() when the function
is first entered.
Factor the code that checks and handles the dio interrupts out of
s626_irq_handler().
This allows reducing the number of indents in the code and makes it
easier to follow.
This driver has three dio subdevices, each with 16 channels. These
subdevices use hardware registers that are spaced 0x10 bytes apart
for each "group" of 16 channels.
Create new macros to get the correct addresses for each register
based on the dio "group". Use the s->private (void *) to hold the
"group" number to use in the subdevice functions.
This allows removing struct dio_private and all its uses. It also
removes the ugly casts used to get the register address.
The comedi core expects the (*insn_read) operations to read insn->n
values and return the number of values actually read.
Make this function work like the core expects.
This is a simple true/false test, return bool instead of int.
The (*do_cmdtest) already validated the cmd sources so the default
cases in the switch() statements can never happen.
Preclear to trigger bits and change the switch() statements to simple
if() tests to set the bits.
Remove the kernel noise in labpc_common_attach() as well as a couple
obvious comments.
DMA support only works if an interrupt is available.
If the dma channel is not available this driver will still work
with interrupts for the analog input subdevice command support.
In addition, only dma channels 1 and 3 are valid for the ISA
devices.
If the interrupt is not available this driver will still work
with command support disabled for the analog input subdevice.
Make sure labpc_counter_set_mode() was successfull and return any
errno back to the caller.
For the if/else conditions that either load the counter of just set
the mode, use a common error patch to check for the error.
For aesthetic reasons, move the labpc_counter_load() function so
it's by the labpc_counter_set_mode() function.
Update all the labpc_counter_load() calls so that the I8254_MODE*
enums are used instead of the open coded values.
Introduce labpc_counter_set_mode() which is a wrapper around the
i8254_set_mode() helpers to program the 8254 timers. Use the new
function instead of directly writing to the timer mode register
with a "magic" number.
Let the compiler figure out if this function should be inlined.
For aesthetic reasons, move a couple of the #defines in this file
so that the register map defines are first.
Rename the register map defines to better match the National
Instruments Register-Level Programming Manual for the labpc.
Clean up the multi-line comments at the beginning of the file
so that they follow the CodingStyle.
Fix a checkpatch.pl warning about a line over 80 characters.
Introduce a helper function to wait for the a/d conversion to
complete.
Introduce a helper function to read the a/d conversion result
from the fifo.
Introduce a helper function to set the COMMAND6_REG.
The labpc_cancel() function can be used by the labpc_ai_insn_read() and
labpc_ai_cmd() functions to disable the ai subdevice.
Introduce a helper function to set the channel and gain bits in the
COMMAND1_REG.
Determine the chan, range, and aref when the variables are declared.
Determine the scan_mode early and get the proper chanspec so that
the chan, range, and aref can be determined when the variables are
declared.
labpc_ai_chanlist_invalid() checks that all the range and aref values
in the chanlist are the same so, for consistency, use the same chanspec
used to get the chan.
The ai subdevice (*do_cmd) pointer is only initialized if the
driver has successfully requested the interrupt. The extra test
in labpc_ai_cmd() is not necessary.
In labpc_ai_cmd(), move the declaration of the local variable
'irq_flags' to remove the need for the extra #ifdef/#endif.
Remove the DRV_NAME define and just open code the string in the
comedi_driver and pci_driver declarations.
In labpc_common_attach(), initialize the dev->board_name early and
use that instead of DRV_NAME when allocating the resources.
In labpc_common_attach(), move the declaration of the local variable
'dma_flags' to remove the need for the extra #ifdef/#endif.
Add some whitespace to the subdevice init.
Remove the unnecessary comment about adding command support to
the analog input subdevice and change the 'maxdata' value to hex
as this is more common in comedi drivers.
