2015-05-17Linux 3.10.79v3.10.79Greg Kroah-Hartman
2015-05-17ACPICA: Utilities: Cleanup to enforce ↵Lv Zheng
ACPI_PHYSADDR_TO_PTR()/ACPI_PTR_TO_PHYSADDR(). commit 6d3fd3cc33d50e4c0d0c0bd172de02caaec3127c upstream. ACPICA commit 154f6d074dd38d6ebc0467ad454454e6c5c9ecdf There are code pieces converting pointers using "(acpi_physical_address) x" or "ACPI_CAST_PTR (t, x)" formats, this patch cleans up them. Known issues: 1. Cleanup of "(ACPI_PHYSICAL_ADDRRESS) x" for a table field For the conversions around the table fields, it is better to fix it with alignment also fixed. So this patch doesn't modify such code. There should be no functional problem by leaving them unchanged. Link: https://github.com/acpica/acpica/commit/154f6d07 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Dirk Behme <dirk.behme@gmail.com> Signed-off-by: George G. Davis <george_davis@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ACPICA: Tables: Change acpi_find_root_pointer() to use acpi_physical_address.Lv Zheng
commit f254e3c57b9d952e987502aefa0804c177dd2503 upstream. ACPICA commit 7d9fd64397d7c38899d3dc497525f6e6b044e0e3 OSPMs like Linux expect an acpi_physical_address returning value from acpi_find_root_pointer(). This triggers warnings if sizeof (acpi_size) doesn't equal to sizeof (acpi_physical_address): drivers/acpi/osl.c:275:3: warning: passing argument 1 of 'acpi_find_root_pointer' from incompatible pointer type [enabled by default] In file included from include/acpi/acpi.h:64:0, from include/linux/acpi.h:36, from drivers/acpi/osl.c:41: include/acpi/acpixf.h:433:1: note: expected 'acpi_size *' but argument is of type 'acpi_physical_address *' This patch corrects acpi_find_root_pointer(). Link: https://github.com/acpica/acpica/commit/7d9fd643 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Dirk Behme <dirk.behme@gmail.com> Signed-off-by: George G. Davis <george_davis@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17revert "softirq: Add support for triggering softirq work on softirqs"Christoph Hellwig
commit fc21c0cff2f425891b28ff6fb6b03b325c977428 upstream. This commit was incomplete in that code to remove items from the per-cpu lists was missing and never acquired a user in the 5 years it has been in the tree. We're going to implement what it seems to try to archive in a simpler way, and this code is in the way of doing so. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pan Xinhui <xinhuix.pan@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17sound/oss: fix deadlock in sequencer_ioctl(SNDCTL_SEQ_OUTOFBAND)Alexey Khoroshilov
commit bc26d4d06e337ade069f33d3f4377593b24e6e36 upstream. A deadlock can be initiated by userspace via ioctl(SNDCTL_SEQ_OUTOFBAND) on /dev/sequencer with TMR_ECHO midi event. In this case the control flow is: sound_ioctl() -> case SND_DEV_SEQ: case SND_DEV_SEQ2: sequencer_ioctl() -> case SNDCTL_SEQ_OUTOFBAND: spin_lock_irqsave(&lock,flags); play_event(); -> case EV_TIMING: seq_timing_event() -> case TMR_ECHO: seq_copy_to_input() -> spin_lock_irqsave(&lock,flags); It seems that spin_lock_irqsave() around play_event() is not necessary, because the only other call location in seq_startplay() makes the call without acquiring spinlock. So, the patch just removes spinlocks around play_event(). By the way, it removes unreachable code in seq_timing_event(), since (seq_mode == SEQ_2) case is handled in the beginning. Compile tested only. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17mmc: card: Don't access RPMB partitions for normal read/writeChuanxiao Dong
commit 4e93b9a6abc0d028daf3c8a00cb77b679d8a4df4 upstream. During kernel boot, it will try to read some logical sectors of each block device node for the possible partition table. But since RPMB partition is special and can not be accessed by normal eMMC read / write CMDs, it will cause below error messages during kernel boot: ... mmc0: Got data interrupt 0x00000002 even though no data operation was in progress. mmcblk0rpmb: error -110 transferring data, sector 0, nr 32, cmd response 0x900, card status 0xb00 mmcblk0rpmb: retrying using single block read mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900 mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900 mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900 mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900 mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900 mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900 end_request: I/O error, dev mmcblk0rpmb, sector 0 Buffer I/O error on device mmcblk0rpmb, logical block 0 end_request: I/O error, dev mmcblk0rpmb, sector 8 Buffer I/O error on device mmcblk0rpmb, logical block 1 end_request: I/O error, dev mmcblk0rpmb, sector 16 Buffer I/O error on device mmcblk0rpmb, logical block 2 end_request: I/O error, dev mmcblk0rpmb, sector 24 Buffer I/O error on device mmcblk0rpmb, logical block 3 ... This patch will discard the access request in eMMC queue if it is RPMB partition access request. By this way, it avoids trigger above error messages. Fixes: 090d25fe224c ("mmc: core: Expose access to RPMB partition") Signed-off-by: Yunpeng Gao <yunpeng.gao@intel.com> Signed-off-by: Chuanxiao Dong <chuanxiao.dong@intel.com> Tested-by: Michael Shigorin <mike@altlinux.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17pinctrl: Don't just pretend to protect pinctrl_maps, do it for realDoug Anderson
commit c5272a28566b00cce79127ad382406e0a8650690 upstream. Way back, when the world was a simpler place and there was no war, no evil, and no kernel bugs, there was just a single pinctrl lock. That was how the world was when (57291ce pinctrl: core device tree mapping table parsing support) was written. In that case, there were instances where the pinctrl mutex was already held when pinctrl_register_map() was called, hence a "locked" parameter was passed to the function to indicate that the mutex was already locked (so we shouldn't lock it again). A few years ago in (42fed7b pinctrl: move subsystem mutex to pinctrl_dev struct), we switched to a separate pinctrl_maps_mutex. ...but (oops) we forgot to re-think about the whole "locked" parameter for pinctrl_register_map(). Basically the "locked" parameter appears to still refer to whether the bigger pinctrl_dev mutex is locked, but we're using it to skip locks of our (now separate) pinctrl_maps_mutex. That's kind of a bad thing(TM). Probably nobody noticed because most of the calls to pinctrl_register_map happen at boot time and we've got synchronous device probing. ...and even cases where we're asynchronous don't end up actually hitting the race too often. ...but after banging my head against the wall for a bug that reproduced 1 out of 1000 reboots and lots of looking through kgdb, I finally noticed this. Anyway, we can now safely remove the "locked" parameter and go back to a war-free, evil-free, and kernel-bug-free world. Fixes: 42fed7ba44e4 ("pinctrl: move subsystem mutex to pinctrl_dev struct") Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17drm/i915: Add missing MacBook Pro models with dual channel LVDSLukas Wunner
commit 3916e3fd81021fb795bfbdb17f375b6b3685bced upstream. Single channel LVDS maxes out at 112 MHz. The 15" pre-retina models shipped with 1440x900 (106 MHz) by default or 1680x1050 (119 MHz) as a BTO option, both versions used dual channel LVDS even though the smaller one would have fit into a single channel. Notes: Bug report showing that the MacBookPro8,2 with 1440x900 uses dual channel LVDS (this lead to it being hardcoded in intel_lvds.c by Daniel Vetter with commit 618563e3945b9d0864154bab3c607865b557cecc): https://bugzilla.kernel.org/show_bug.cgi?id=42842 If i915.lvds_channel_mode=2 is missing even though the machine needs it, every other vertical line is white and consequently, only the left half of the screen is visible (verified by myself on a MacBookPro9,1). Forum posting concerning a MacBookPro6,2 with 1440x900, author is using i915.lvds_channel_mode=2 on the kernel command line, proving that the machine uses dual channels: https://bbs.archlinux.org/viewtopic.php?id=185770 Chi Mei N154C6-L04 with 1440x900 is a replacement panel for all MacBook Pro "A1286" models, and that model number encompasses the MacBookPro6,2 / 8,2 / 9,1. Page 17 of the panel's datasheet shows it's driven with dual channel LVDS: http://www.ebay.com/itm/-/400690878560 http://www.everymac.com/ultimate-mac-lookup/?search_keywords=A1286 http://www.taopanel.com/chimei/datasheet/N154C6-L04.pdf Those three 15" models, MacBookPro6,2 / 8,2 / 9,1, are the only ones with i915 graphics and dual channel LVDS, so that list should be complete. And the 8,2 is already in intel_lvds.c. Possible motivation to use dual channel LVDS even on the 1440x900 models: Reduce the number of different parts, i.e. use identical logic boards and display cabling on both versions and the only differing component is the panel. Signed-off-by: Lukas Wunner <lukas@wunner.de> Acked-by: Jani Nikula <jani.nikula@intel.com> [Jani: included notes in the commit message for posterity] Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: mvebu: armada-xp-openblocks-ax3-4: Disable internal RTCGregory CLEMENT
commit 750e30d4076ae5e02ad13a376e96c95a2627742c upstream. There is no crystal connected to the internal RTC on the Open Block AX3. So let's disable it in order to prevent the kernel probing the driver uselessly. Eventually this patches removes the following warning message from the boot log: "rtc-mv d0010300.rtc: internal RTC not ticking" Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: dts: imx23-olinuxino: Fix dr_mode of usb0Stefan Wahren
commit 0fdebe1a2f4d3a8fc03754022fabf8ba95e131a3 upstream. The dr_mode of usb0 on imx233-olinuxino is left to default "otg". Since the green LED (GPIO2_1) on imx233-olinuxino is connected to the same pin as USB_OTG_ID it's possible to disable USB host by LED toggling: echo 0 > /sys/class/leds/green/brightness [ 1068.890000] ci_hdrc ci_hdrc.0: remove, state 1 [ 1068.890000] usb usb1: USB disconnect, device number 1 [ 1068.920000] usb 1-1: USB disconnect, device number 2 [ 1068.920000] usb 1-1.1: USB disconnect, device number 3 [ 1069.070000] usb 1-1.2: USB disconnect, device number 4 [ 1069.450000] ci_hdrc ci_hdrc.0: USB bus 1 deregistered [ 1074.460000] ci_hdrc ci_hdrc.0: timeout waiting for 00000800 in 11 This patch fixes the issue by setting dr_mode to "host" in the dts file. Reported-by: Harald Geyer <harald@ccbib.org> Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Peter Chen <peter.chen@freescale.com> Fixes: b49312948285 ("ARM: dts: imx23-olinuxino: Add USB host support") Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: dts: imx28: Fix AUART4 TX-DMA interrupt nameMarek Vasut
commit 4ada77e37a773168fea484899201e272ab44ba8b upstream. Fix a typo in the TX DMA interrupt name for AUART4. This patch makes AUART4 operational again. Signed-off-by: Marek Vasut <marex@denx.de> Fixes: f30fb03d4d3a ("ARM: dts: add generic DMA device tree binding for mxs-dma") Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: dts: imx25: Add #pwm-cells to pwm4Markus Pargmann
commit f90d3f0d0a11fa77918fd5497cb616dd2faa8431 upstream. The property '#pwm-cells' is currently missing. It is not possible to use pwm4 without this property. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Fixes: 5658a68fb578 ("ARM i.MX25: Add devicetree") Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17gpio: sysfs: fix memory leaks and device hotplugJohan Hovold
commit 483d821108791092798f5d230686868112927044 upstream. Unregister GPIOs requested through sysfs at chip remove to avoid leaking the associated memory and sysfs entries. The stale sysfs entries prevented the gpio numbers from being exported when the gpio range was later reused (e.g. at device reconnect). This also fixes the related module-reference leak. Note that kernfs makes sure that any on-going sysfs operations finish before the class devices are unregistered and that further accesses fail. The chip exported flag is used to prevent gpiod exports during removal. This also makes it harder to trigger, but does not fix, the related race between gpiochip_remove and export_store, which is really a race with gpiod_request that needs to be addressed separately. Also note that this would prevent the crashes (e.g. NULL-dereferences) at reconnect that affects pre-3.18 kernels, as well as use-after-free on operations on open attribute files on pre-3.14 kernels (prior to kernfs). Fixes: d8f388d8dc8d ("gpio: sysfs interface") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17gpio: unregister gpiochip device before removing itJohan Hovold
commit 01cca93a9491ed95992523ff7e79dd9bfcdea8e0 upstream. Unregister gpiochip device (used to export information through sysfs) before removing it internally. This way removal will reverse addition. Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17xen/console: Update console event channel on resumeBoris Ostrovsky
commit b9d934f27c91b878c4b2e64299d6e419a4022f8d upstream. After a resume the hypervisor/tools may change console event channel number. We should re-query it. Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17mm/memory-failure: call shake_page() when error hits thp tail pageNaoya Horiguchi
commit 09789e5de18e4e442870b2d700831f5cb802eb05 upstream. Currently memory_failure() calls shake_page() to sweep pages out from pcplists only when the victim page is 4kB LRU page or thp head page. But we should do this for a thp tail page too. Consider that a memory error hits a thp tail page whose head page is on a pcplist when memory_failure() runs. Then, the current kernel skips shake_pages() part, so hwpoison_user_mappings() returns without calling split_huge_page() nor try_to_unmap() because PageLRU of the thp head is still cleared due to the skip of shake_page(). As a result, me_huge_page() runs for the thp, which is broken behavior. One effect is a leak of the thp. And another is to fail to isolate the memory error, so later access to the error address causes another MCE, which kills the processes which used the thp. This patch fixes this problem by calling shake_page() for thp tail case. Fixes: 385de35722c9 ("thp: allow a hwpoisoned head page to be put back to LRU") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Dean Nelson <dnelson@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17nilfs2: fix sanity check of btree level in nilfs_btree_root_broken()Ryusuke Konishi
commit d8fd150fe3935e1692bf57c66691e17409ebb9c1 upstream. The range check for b-tree level parameter in nilfs_btree_root_broken() is wrong; it accepts the case of "level == NILFS_BTREE_LEVEL_MAX" even though the level is limited to values in the range of 0 to (NILFS_BTREE_LEVEL_MAX - 1). Since the level parameter is read from storage device and used to index nilfs_btree_path array whose element count is NILFS_BTREE_LEVEL_MAX, it can cause memory overrun during btree operations if the boundary value is set to the level parameter on device. This fixes the broken sanity check and adds a comment to clarify that the upper bound NILFS_BTREE_LEVEL_MAX is exclusive. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ocfs2: dlm: fix race between purge and get lock resourceJunxiao Bi
commit b1432a2a35565f538586774a03bf277c27fc267d upstream. There is a race window in dlm_get_lock_resource(), which may return a lock resource which has been purged. This will cause the process to hang forever in dlmlock() as the ast msg can't be handled due to its lock resource not existing. dlm_get_lock_resource { ... spin_lock(&dlm->spinlock); tmpres = __dlm_lookup_lockres_full(dlm, lockid, namelen, hash); if (tmpres) { spin_unlock(&dlm->spinlock); >>>>>>>> race window, dlm_run_purge_list() may run and purge the lock resource spin_lock(&tmpres->spinlock); ... spin_unlock(&tmpres->spinlock); } } Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Joseph Qi <joseph.qi@huawei.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13Linux 3.10.78v3.10.78Greg Kroah-Hartman
2015-05-13ARC: signal handling robustifyVineet Gupta
commit e4140819dadc3624accac8294881bca8a3cba4ed upstream. A malicious signal handler / restorer can DOS the system by fudging the user regs saved on stack, causing weird things such as sigreturn returning to user mode PC but cpu state still being kernel mode.... Ensure that in sigreturn path status32 always has U bit; any other bogosity (gargbage PC etc) will be taken care of by normal user mode exceptions mechanisms. Reproducer signal handler: void handle_sig(int signo, siginfo_t *info, void *context) { ucontext_t *uc = context; struct user_regs_struct *regs = &(uc->uc_mcontext.regs); regs->scratch.status32 = 0; } Before the fix, kernel would go off to weeds like below: --------->8----------- [ARCLinux]$ ./signal-test Path: /signal-test CPU: 0 PID: 61 Comm: signal-test Not tainted 4.0.0-rc5+ #65 task: 8f177880 ti: 5ffe6000 task.ti: 8f15c000 [ECR ]: 0x00220200 => Invalid Write @ 0x00000010 by insn @ 0x00010698 [EFA ]: 0x00000010 [BLINK ]: 0x2007c1ee [ERET ]: 0x10698 [STAT32]: 0x00000000 : <-------- BTA: 0x00010680 SP: 0x5ffe7e48 FP: 0x00000000 LPS: 0x20003c6c LPE: 0x20003c70 LPC: 0x00000000 ... --------->8----------- Reported-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13UBI: fix soft lockup in ubi_check_volume()hujianyang
commit 9aa272b492e7551a9ee0e2c83c720ea013698485 upstream. Running mtd-utils/tests/ubi-tests/io_basic.c could cause soft lockup or watchdog reset. It is because *updatevol* will perform ubi_check_volume() after updating finish and this function will full scan the updated lebs if the volume is initialized as STATIC_VOLUME. This patch adds *cond_resched()* in the loop of lebs scan to avoid soft lockup. Helped by Richard Weinberger <richard@nod.at> [ 2158.067096] INFO: rcu_sched self-detected stall on CPU { 1} (t=2101 jiffies g=1606 c=1605 q=56) [ 2158.172867] CPU: 1 PID: 2073 Comm: io_basic Tainted: G O 3.10.53 #21 [ 2158.172898] [<c000f624>] (unwind_backtrace+0x0/0x120) from [<c000c294>] (show_stack+0x10/0x14) [ 2158.172918] [<c000c294>] (show_stack+0x10/0x14) from [<c008ac3c>] (rcu_check_callbacks+0x1c0/0x660) [ 2158.172936] [<c008ac3c>] (rcu_check_callbacks+0x1c0/0x660) from [<c002b480>] (update_process_times+0x38/0x64) [ 2158.172953] [<c002b480>] (update_process_times+0x38/0x64) from [<c005ff38>] (tick_sched_handle+0x54/0x60) [ 2158.172966] [<c005ff38>] (tick_sched_handle+0x54/0x60) from [<c00601ac>] (tick_sched_timer+0x44/0x74) [ 2158.172978] [<c00601ac>] (tick_sched_timer+0x44/0x74) from [<c003f348>] (__run_hrtimer+0xc8/0x1b8) [ 2158.172992] [<c003f348>] (__run_hrtimer+0xc8/0x1b8) from [<c003fd9c>] (hrtimer_interrupt+0x128/0x2a4) [ 2158.173007] [<c003fd9c>] (hrtimer_interrupt+0x128/0x2a4) from [<c0246f1c>] (arch_timer_handler_virt+0x28/0x30) [ 2158.173022] [<c0246f1c>] (arch_timer_handler_virt+0x28/0x30) from [<c0086214>] (handle_percpu_devid_irq+0x9c/0x124) [ 2158.173036] [<c0086214>] (handle_percpu_devid_irq+0x9c/0x124) from [<c0082bd8>] (generic_handle_irq+0x20/0x30) [ 2158.173049] [<c0082bd8>] (generic_handle_irq+0x20/0x30) from [<c000969c>] (handle_IRQ+0x64/0x8c) [ 2158.173060] [<c000969c>] (handle_IRQ+0x64/0x8c) from [<c0008544>] (gic_handle_irq+0x3c/0x60) [ 2158.173074] [<c0008544>] (gic_handle_irq+0x3c/0x60) from [<c02f0f80>] (__irq_svc+0x40/0x50) [ 2158.173083] Exception stack(0xc4043c98 to 0xc4043ce0) [ 2158.173092] 3c80: c4043ce4 00000019 [ 2158.173102] 3ca0: 1f8a865f c050ad10 1f8a864c 00000031 c04b5970 0003ebce 00000000 f3550000 [ 2158.173113] 3cc0: bf00bc68 00000800 0003ebce c4043ce0 c0186d14 c0186cb8 80000013 ffffffff [ 2158.173130] [<c02f0f80>] (__irq_svc+0x40/0x50) from [<c0186cb8>] (read_current_timer+0x4/0x38) [ 2158.173145] [<c0186cb8>] (read_current_timer+0x4/0x38) from [<1f8a865f>] (0x1f8a865f) [ 2183.927097] BUG: soft lockup - CPU#1 stuck for 22s! [io_basic:2073] [ 2184.002229] Modules linked in: nandflash(O) [last unloaded: nandflash] Signed-off-by: Wang Kai <morgan.wang@huawei.com> Signed-off-by: hujianyang <hujianyang@huawei.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13Drivers: hv: vmbus: Don't wait after requesting offersK. Y. Srinivasan
commit 73cffdb65e679b98893f484063462c045adcf212 upstream. Don't wait after sending request for offers to the host. This wait is unnecessary and simply adds 5 seconds to the boot time. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ARM: dts: dove: Fix uart[23] reg propertySebastian Hesselbarth
commit a74cd13b807029397f7232449df929bac11fb228 upstream. Fix Dove's register addresses of uart2 and uart3 nodes that seem to be broken since ages due to a copy-and-paste error. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13staging: panel: fix lcd typeSudip Mukherjee
commit 2c20d92dad5db6440cfa88d811b69fd605240ce4 upstream. the lcd type as defined in the Kconfig is not matching in the code. as a result the rs, rw and en pins were getting interchanged. Kconfig defines the value of PANEL_LCD to be 1 if we select custom configuration but in the code LCD_TYPE_CUSTOM is defined as 5. my hardware is LCD_TYPE_CUSTOM, but the pins were assigned to it as pins of LCD_TYPE_OLD, and it was not working. Now values are corrected with referenece to the values defined in Kconfig and it is working. checked on JHD204A lcd with LCD_TYPE_CUSTOM configuration. Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Acked-by: Willy Tarreau <w@1wt.eu> [wt: backport to 3.10 and 3.14] Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13usb: gadget: printer: enqueue printer's response for setup requestAndrzej Pietrasiewicz
commit eb132ccbdec5df46e29c9814adf76075ce83576b upstream. Function-specific setup requests should be handled in such a way, that apart from filling in the data buffer, the requests are also actually enqueued: if function-specific setup is called from composte_setup(), the "usb_ep_queue()" block of code in composite_setup() is skipped. The printer function lacks this part and it results in e.g. get device id requests failing: the host expects some response, the device prepares it but does not equeue it for sending to the host, so the host finally asserts timeout. This patch adds enqueueing the prepared responses. Fixes: 2e87edf49227: "usb: gadget: make g_printer use composite" Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com> [ported to stable 3.10 and 3.14] Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13usb: host: oxu210hp: use new USB_RESUME_TIMEOUTFelipe Balbi
commit 84c0d178eb9f3a3ae4d63dc97a440266cf17f7f5 upstream. Make sure we're using the new macro, so our resume signaling will always pass certification. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-133w-sas: fix command completion raceChristoph Hellwig
commit 579d69bc1fd56d5af5761969aa529d1d1c188300 upstream. The 3w-sas driver needs to tear down the dma mappings before returning the command to the midlayer, as there is no guarantee the sglist and count are valid after that point. Also remove the dma mapping helpers which have another inherent race due to the request_id index. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Torsten Luettgert <ml-lkml@enda.eu> Tested-by: Bernd Kardatzki <Bernd.Kardatzki@med.uni-tuebingen.de> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-133w-9xxx: fix command completion raceChristoph Hellwig
commit 118c855b5623f3e2e6204f02623d88c09e0c34de upstream. The 3w-9xxx driver needs to tear down the dma mappings before returning the command to the midlayer, as there is no guarantee the sglist and count are valid after that point. Also remove the dma mapping helpers which have another inherent race due to the request_id index. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-133w-xxxx: fix command completion raceChristoph Hellwig
commit 9cd9554615cba14f0877cc9972a6537ad2bdde61 upstream. The 3w-xxxx driver needs to tear down the dma mappings before returning the command to the midlayer, as there is no guarantee the sglist and count are valid after that point. Also remove the dma mapping helpers which have another inherent race due to the request_id index. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ext4: fix data corruption caused by unwritten and delayed extentsLukas Czerner
commit d2dc317d564a46dfc683978a2e5a4f91434e9711 upstream. Currently it is possible to lose whole file system block worth of data when we hit the specific interaction with unwritten and delayed extents in status extent tree. The problem is that when we insert delayed extent into extent status tree the only way to get rid of it is when we write out delayed buffer. However there is a limitation in the extent status tree implementation so that when inserting unwritten extent should there be even a single delayed block the whole unwritten extent would be marked as delayed. At this point, there is no way to get rid of the delayed extents, because there are no delayed buffers to write out. So when a we write into said unwritten extent we will convert it to written, but it still remains delayed. When we try to write into that block later ext4_da_map_blocks() will set the buffer new and delayed and map it to invalid block which causes the rest of the block to be zeroed loosing already written data. For now we can fix this by simply not allowing to set delayed status on written extent in the extent status tree. Also add WARN_ON() to make sure that we notice if this happens in the future. This problem can be easily reproduced by running the following xfs_io. xfs_io -f -c "pwrite -S 0xaa 4096 2048" \ -c "falloc 0 131072" \ -c "pwrite -S 0xbb 65536 2048" \ -c "fsync" /mnt/test/fff echo 3 > /proc/sys/vm/drop_caches xfs_io -c "pwrite -S 0xdd 67584 2048" /mnt/test/fff This can be theoretically also reproduced by at random by running fsx, but it's not very reliable, though on machines with bigger page size (like ppc) this can be seen more often (especially xfstest generic/127) Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13rbd: end I/O the entire obj_request on errorIlya Dryomov
commit 082a75dad84d79d1c15ea9e50f31cb4bb4fa7fd6 upstream. When we end I/O struct request with error, we need to pass obj_request->length as @nr_bytes so that the entire obj_request worth of bytes is completed. Otherwise block layer ends up confused and we trip on rbd_assert(more ^ (which == img_request->obj_request_count)); in rbd_img_obj_callback() due to more being true no matter what. We already do it in most cases but we are missing some, in particular those where we don't even get a chance to submit any obj_requests, due to an early -ENOMEM for example. A number of obj_request->xferred assignments seem to be redundant but I haven't touched any of obj_request->xferred stuff to keep this small and isolated. Cc: Alex Elder <elder@linaro.org> Reported-by: Shawn Edwards <lesser.evil@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13serial: of-serial: Remove device_type = "serial" registrationMichal Simek
commit 6befa9d883385c580369a2cc9e53fbf329771f6d upstream. Do not probe all serial drivers by of_serial.c which are using device_type = "serial"; property. Only drivers which have valid compatible strings listed in the driver should be probed. When PORT_UNKNOWN is setup probe will fail anyway. Arnd quotation about driver historical background: "when I wrote that driver initially, the idea was that it would get used as a stub to hook up all other serial drivers but after that, the common code learned to create platform devices from DT" This patch fix the problem with on the system with xilinx_uartps and 16550a where of_serial failed to register for xilinx_uartps and because of irq_dispose_mapping() removed irq_desc. Then when xilinx_uartps was asking for irq with request_irq() EINVAL is returned. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: hda - Fix mute-LED fixed modeTakashi Iwai
commit ee52e56e7b12834476cd0031c5986254ba1b6317 upstream. The mute-LED mode control has the fixed on/off states that are supposed to remain on/off regardless of the master switch. However, this doesn't work actually because the vmaster hook is called in the vmaster code itself. This patch fixes it by calling the hook indirectly after checking the mute LED mode. Reported-and-tested-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: emu10k1: Emu10k2 32 bit DMA modePeter Zubaj
commit 7241ea558c6715501e777396b5fc312c372e11d9 upstream. Looks like audigy emu10k2 (probably emu10k1 - sb live too) support two modes for DMA. Second mode is useful for 64 bit os with more then 2 GB of ram (fixes problems with big soundfont loading) 1) 32MB from 2 GB address space using 8192 pages (used now as default) 2) 16MB from 4 GB address space using 4096 pages Mode is set using HCFG_EXPANDED_MEM flag in HCFG register. Also format of emu10k2 page table is then different. Signed-off-by: Peter Zubaj <pzubaj@marticonet.sk> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: emu10k1: Fix card shortname string buffer overflowTakashi Iwai
commit d02260824e2cad626fb2a9d62e27006d34b6dedc upstream. Some models provide too long string for the shortname that has 32bytes including the terminator, and it results in a non-terminated string exposed to the user-space. This isn't too critical, though, as the string is stopped at the succeeding longname string. This patch fixes such entries by dropping "SB" prefix (it's enough to fit within 32 bytes, so far). Meanwhile, it also changes strcpy() with strlcpy() to make sure that this kind of problem won't happen in future, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: emux: Fix mutex deadlock in OSS emulationTakashi Iwai
commit 1c94e65c668f44d2c69ae7e7fc268ab3268fba3e upstream. The OSS emulation in synth-emux helper has a potential AB/BA deadlock at the simultaneous closing and opening: close -> snd_seq_release() -> sne_seq_free_client() -> snd_seq_delete_all_ports(): takes client->ports_mutex -> port_delete() -> snd_emux_unuse(): takes emux->register_mutex open -> snd_seq_oss_open() -> snd_emux_open_seq_oss(): takes emux->register_mutex -> snd_seq_event_port_attach() -> snd_seq_create_port(): takes client->ports_mutex This patch addresses the deadlock by reducing the rance taking emux->register_mutex in snd_emux_open_seq_oss(). The lock is needed for the refcount handling, so move it locally. The calls in emux_seq.c are already with the mutex, thus they are replaced with the version without mutex lock/unlock. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ALSA: emux: Fix mutex deadlock at unloadingTakashi Iwai
commit 07b0e5d49d227e3950cb13a3e8caf248ef2a310e upstream. The emux-synth driver has a possible AB/BA mutex deadlock at unloading the emu10k1 driver: snd_emux_free() -> snd_emux_detach_seq(): mutex_lock(&emu->register_mutex) -> snd_seq_delete_kernel_client() -> snd_seq_free_client(): mutex_lock(&register_mutex) snd_seq_release() -> snd_seq_free_client(): mutex_lock(&register_mutex) -> snd_seq_delete_all_ports() -> snd_emux_unuse(): mutex_lock(&emu->register_mutex) Basically snd_emux_detach_seq() doesn't need a protection of emu->register_mutex as it's already being unregistered. So, we can get rid of this for avoiding the deadlock. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ipv4: Missing sk_nulls_node_init() in ping_unhash().David S. Miller
[ Upstream commit a134f083e79fb4c3d0a925691e732c56911b4326 ] If we don't do that, then the poison value is left in the ->pprev backlink. This can cause crashes if we do a disconnect, followed by a connect(). Tested-by: Linus Torvalds <torvalds@linux-foundation.org> Reported-by: Wen Xu <hotdog3645@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06Linux 3.10.77v3.10.77Greg Kroah-Hartman
2015-05-06s390: Fix build errorGuenter Roeck
s390 images fail to build in 3.10 with arch/s390/kernel/suspend.c: In function 'pfn_is_nosave': arch/s390/kernel/suspend.c:147:10: error: 'ipl_info' undeclared arch/s390/kernel/suspend.c:147:27: error: 'IPL_TYPE_NSS' undeclared due to a missing include file. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06nosave: consolidate __nosave_{begin,end} in <asm/sections.h>Geert Uytterhoeven
commit 7f8998c7aef3ac9c5f3f2943e083dfa6302e90d0 upstream. The different architectures used their own (and different) declarations: extern __visible const void __nosave_begin, __nosave_end; extern const void __nosave_begin, __nosave_end; extern long __nosave_begin, __nosave_end; Consolidate them using the first variant in <asm/sections.h>. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06memstick: mspro_block: add missing curly bracesDan Carpenter
commit 13f6b191aaa11c7fd718d35a0c565f3c16bc1d99 upstream. Using the indenting we can see the curly braces were obviously intended. This is a static checker fix, but my guess is that we don't read enough bytes, because we don't calculate "t_len" correctly. Fixes: f1d82698029b ('memstick: use fully asynchronous request processing') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06C6x: time: Ensure consistency in __initNishanth Menon
commit f4831605f2dacd12730fe73961c77253cc2ea425 upstream. time_init invokes timer64_init (which is __init annotation) since all of these are invoked at init time, lets maintain consistency by ensuring time_init is marked appropriately as well. This fixes the following warning with CONFIG_DEBUG_SECTION_MISMATCH=y WARNING: vmlinux.o(.text+0x3bfc): Section mismatch in reference from the function time_init() to the function .init.text:timer64_init() The function time_init() references the function __init timer64_init(). This is often because time_init lacks a __init annotation or the annotation of timer64_init is wrong. Fixes: 546a39546c64 ("C6X: time management") Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06wl18xx: show rx_frames_per_rates as an array as it really isNicolas Iooss
commit a3fa71c40f1853d0c27e8f5bc01a722a705d9682 upstream. In struct wl18xx_acx_rx_rate_stat, rx_frames_per_rates field is an array, not a number. This means WL18XX_DEBUGFS_FWSTATS_FILE can't be used to display this field in debugfs (it would display a pointer, not the actual data). Use WL18XX_DEBUGFS_FWSTATS_FILE_ARRAY instead. This bug has been found by adding a __printf attribute to wl1271_format_buffer. gcc complained about "format '%u' expects argument of type 'unsigned int', but argument 5 has type 'u32 *'". Fixes: c5d94169e818 ("wl18xx: use new fw stats structures") Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06lib: memzero_explicit: use barrier instead of OPTIMIZER_HIDE_VARmancha security
commit 0b053c9518292705736329a8fe20ef4686ffc8e9 upstream. OPTIMIZER_HIDE_VAR(), as defined when using gcc, is insufficient to ensure protection from dead store optimization. For the random driver and crypto drivers, calls are emitted ... $ gdb vmlinux (gdb) disassemble memzero_explicit Dump of assembler code for function memzero_explicit: 0xffffffff813a18b0 <+0>: push %rbp 0xffffffff813a18b1 <+1>: mov %rsi,%rdx 0xffffffff813a18b4 <+4>: xor %esi,%esi 0xffffffff813a18b6 <+6>: mov %rsp,%rbp 0xffffffff813a18b9 <+9>: callq 0xffffffff813a7120 <memset> 0xffffffff813a18be <+14>: pop %rbp 0xffffffff813a18bf <+15>: retq End of assembler dump. (gdb) disassemble extract_entropy [...] 0xffffffff814a5009 <+313>: mov %r12,%rdi 0xffffffff814a500c <+316>: mov $0xa,%esi 0xffffffff814a5011 <+321>: callq 0xffffffff813a18b0 <memzero_explicit> 0xffffffff814a5016 <+326>: mov -0x48(%rbp),%rax [...] ... but in case in future we might use facilities such as LTO, then OPTIMIZER_HIDE_VAR() is not sufficient to protect gcc from a possible eviction of the memset(). We have to use a compiler barrier instead. Minimal test example when we assume memzero_explicit() would *not* be a call, but would have been *inlined* instead: static inline void memzero_explicit(void *s, size_t count) { memset(s, 0, count); <foo> } int main(void) { char buff[20]; snprintf(buff, sizeof(buff) - 1, "test"); printf("%s", buff); memzero_explicit(buff, sizeof(buff)); return 0; } With <foo> := OPTIMIZER_HIDE_VAR(): (gdb) disassemble main Dump of assembler code for function main: [...] 0x0000000000400464 <+36>: callq 0x400410 <printf@plt> 0x0000000000400469 <+41>: xor %eax,%eax 0x000000000040046b <+43>: add $0x28,%rsp 0x000000000040046f <+47>: retq End of assembler dump. With <foo> := barrier(): (gdb) disassemble main Dump of assembler code for function main: [...] 0x0000000000400464 <+36>: callq 0x400410 <printf@plt> 0x0000000000400469 <+41>: movq $0x0,(%rsp) 0x0000000000400471 <+49>: movq $0x0,0x8(%rsp) 0x000000000040047a <+58>: movl $0x0,0x10(%rsp) 0x0000000000400482 <+66>: xor %eax,%eax 0x0000000000400484 <+68>: add $0x28,%rsp 0x0000000000400488 <+72>: retq End of assembler dump. As can be seen, movq, movq, movl are being emitted inlined via memset(). Reference: http://thread.gmane.org/gmane.linux.kernel.cryptoapi/13764/ Fixes: d4c5efdb9777 ("random: add and use memzero_explicit() for clearing data") Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: mancha security <mancha1@zoho.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06e1000: add dummy allocator to fix race condition between mtu change and netpollSabrina Dubroca
commit 08e8331654d1d7b2c58045e549005bc356aa7810 upstream. There is a race condition between e1000_change_mtu's cleanups and netpoll, when we change the MTU across jumbo size: Changing MTU frees all the rx buffers: e1000_change_mtu -> e1000_down -> e1000_clean_all_rx_rings -> e1000_clean_rx_ring Then, close to the end of e1000_change_mtu: pr_info -> ... -> netpoll_poll_dev -> e1000_clean -> e1000_clean_rx_irq -> e1000_alloc_rx_buffers -> e1000_alloc_frag And when we come back to do the rest of the MTU change: e1000_up -> e1000_configure -> e1000_configure_rx -> e1000_alloc_jumbo_rx_buffers alloc_jumbo finds the buffers already != NULL, since data (shared with page in e1000_rx_buffer->rxbuf) has been re-alloc'd, but it's garbage, or at least not what is expected when in jumbo state. This results in an unusable adapter (packets don't get through), and a NULL pointer dereference on the next call to e1000_clean_rx_ring (other mtu change, link down, shutdown): BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81194d6e>] put_compound_page+0x7e/0x330 [...] Call Trace: [<ffffffff81195445>] put_page+0x55/0x60 [<ffffffff815d9f44>] e1000_clean_rx_ring+0x134/0x200 [<ffffffff815da055>] e1000_clean_all_rx_rings+0x45/0x60 [<ffffffff815df5e0>] e1000_down+0x1c0/0x1d0 [<ffffffff811e2260>] ? deactivate_slab+0x7f0/0x840 [<ffffffff815e21bc>] e1000_change_mtu+0xdc/0x170 [<ffffffff81647050>] dev_set_mtu+0xa0/0x140 [<ffffffff81664218>] do_setlink+0x218/0xac0 [<ffffffff814459e9>] ? nla_parse+0xb9/0x120 [<ffffffff816652d0>] rtnl_newlink+0x6d0/0x890 [<ffffffff8104f000>] ? kvm_clock_read+0x20/0x40 [<ffffffff810a2068>] ? sched_clock_cpu+0xa8/0x100 [<ffffffff81663802>] rtnetlink_rcv_msg+0x92/0x260 By setting the allocator to a dummy version, netpoll can't mess up our rx buffers. The allocator is set back to a sane value in e1000_configure_rx. Fixes: edbbb3ca1077 ("e1000: implement jumbo receive with partial descriptors") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06ksoftirqd: Enable IRQs and call cond_resched() before poking RCUCalvin Owens
commit 28423ad283d5348793b0c45cc9b1af058e776fd6 upstream. While debugging an issue with excessive softirq usage, I encountered the following note in commit 3e339b5dae24a706 ("softirq: Use hotplug thread infrastructure"): [ paulmck: Call rcu_note_context_switch() with interrupts enabled. ] ...but despite this note, the patch still calls RCU with IRQs disabled. This seemingly innocuous change caused a significant regression in softirq CPU usage on the sending side of a large TCP transfer (~1 GB/s): when introducing 0.01% packet loss, the softirq usage would jump to around 25%, spiking as high as 50%. Before the change, the usage would never exceed 5%. Moving the call to rcu_note_context_switch() after the cond_sched() call, as it was originally before the hotplug patch, completely eliminated this problem. Signed-off-by: Calvin Owens <calvinowens@fb.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Mike Galbraith <mgalbraith@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06RCU pathwalk breakage when running into a symlink overmounting somethingAl Viro
commit 3cab989afd8d8d1bc3d99fef0e7ed87c31e7b647 upstream. Calling unlazy_walk() in walk_component() and do_last() when we find a symlink that needs to be followed doesn't acquire a reference to vfsmount. That's fine when the symlink is on the same vfsmount as the parent directory (which is almost always the case), but it's not always true - one _can_ manage to bind a symlink on top of something. And in such cases we end up with excessive mntput(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06drm/i915: cope with large i2c transfersDmitry Torokhov
commit 9535c4757b881e06fae72a857485ad57c422b8d2 upstream. The hardware, according to the specs, is limited to 256 byte transfers, and current driver has no protections in case users attempt to do larger transfers. The code will just stomp over status register and mayhem ensues. Let's split larger transfers into digestable chunks. Doing this allows Atmel MXT driver on Pixel 1 function properly (it hasn't since commit 9d8dc3e529a19e427fd379118acd132520935c5d "Input: atmel_mxt_ts - implement T44 message handling" which tries to consume multiple touchscreen/touchpad reports in a single transaction). Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06drm/radeon: fix doublescan modes (v2)Alex Deucher
commit fd99a0943ffaa0320ea4f69d09ed188f950c0432 upstream. Use the correct flags for atom. v2: handle DRM_MODE_FLAG_DBLCLK Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
