Make sure dst_release() is not called with error pointer. This is
similar to commit 4910ac6c526d2868adcb5893e0c428473de862b5 ("ipv4:
Don't ip_rt_put() an error pointer in RAW sockets.").
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, UV: Fix kdump reboot
x86, amd-nb: Rename CPU PCI id define for F4
sound: Add delay.h to sound/soc/codecs/sn95031.c
x86, mtrr, pat: Fix one cpu getting out of sync during resume
x86, microcode: Unregister syscore_ops after microcode unloaded
x86: Stop including <linux/delay.h> in two asm header files
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix rebalance interval calculation
sched, doc: Beef up load balancing description
sched: Leave sched_setscheduler() earlier if possible, do not disturb SCHED_FIFO tasks
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Fix task_struct reference leak
perf: Fix task context scheduling
perf: mmap 512 kiB by default
perf: Rebase max unprivileged mlock threshold on top of page size
perf tools: Fix NO_NEWT=1 python build error
perf symbols: Properly align symbol_conf.priv_size
perf tools: Emit clearer message for sys_perf_event_open ENOENT return
perf tools: Fixup exit path when not able to open events
perf symbols: Fix vsyscall symbol lookup
oprofile, x86: Allow setting EDGE/INV/CMASK for counter events
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: create new rcu_access_index() and use in mce
WARN_ON_SMP(): Add comment to explain ({0;})
Fix build warnings caused by removal of *filp arg in struct
usb_serial_driver.
These changes were missed somehow in commits 00a0d0d65b61 ("tty: remove
filp from the USB tty ioctls") and 60b33c133ca0b ("tiocmget: kill off
the passing of the struct file")
drivers/usb/serial/mct_u232.c:159: warning: initialization from incompatible pointer type
drivers/usb/serial/opticon.c:627: warning: initialization from incompatible pointer type
Cc: Alan Cox <alan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
[media] radio: wl128x: Update registration process with ST
[media] staging: altera-jtag needs delay.h
git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32
* 'unicore32' of git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32:
unicore32 framebuffer fix: get videomemory by __get_free_pages() and make it floatable
unicore32 core architecture: remove duplicated #include
unicore32 rtc driver fix: cleanup irq_set_freq and irq_set_state
unicore32 fix: remove arch-specific futex support
unicore32 ldscript fix: add cacheline parameter to PERCPU() macro
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging:
hwmon: twl4030-madc-hwmon: add "platform:" prefix for platform modalias
The ADJ_SETOFFSET bit added in commit 094aa188 ("ntp: Add ADJ_SETOFFSET
mode bit") also introduced a way for any user to change the system time.
Sneaky or buggy calls to adjtimex() could set
ADJ_OFFSET_SS_READ | ADJ_SETOFFSET
which would result in a successful call to timekeeping_inject_offset().
This patch fixes the issue by adding the capability check.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Fix the following section mismatch warning.
WARNING: drivers/rtc/built-in.o(.data+0xa0): Section mismatch in reference from the variable vrtc_mrst_platform_driver to the function .init.text:vrtc_mrst_platform_probe()
The variable vrtc_mrst_platform_driver references the function __init vrtc_mrst_platform_probe()
If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable:
*_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console,
Signed-off-by: Major Lee <major_lee@wistron.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Only the e500v1/v2 cores have HID1[RXFE] so we should attempt to set or
clear this register bit on them. Otherwise we get crashes like:
NIP: c0579f84 LR: c006d550 CTR: c0579f84
REGS: ef857ec0 TRAP: 0700 Not tainted (2.6.38.2-00072-gf15ba3c)
MSR: 00021002 <ME,CE> CR: 22044022 XER: 00000000
TASK = ef8559c0[1] 'swapper' THREAD: ef856000 CPU: 0
GPR00: c006d538 ef857f70 ef8559c0 00000000 00000004 00000000 00000000 00000000
GPR08: c0590000 c30170a8 00000000 c30170a8 00000001 0fffe000 00000000 00000000
GPR16: 00000000 7ffa0e60 00000000 00000000 7ffb0bd8 7ff3b844 c05be000 00000000
GPR24: 00000000 00000000 c05c28b0 c0579fac 00000000 00029002 00000000 c0579f84
NIP [c0579f84] mpc85xx_mc_clear_rfxe+0x0/0x28
LR [c006d550] on_each_cpu+0x34/0x50
Call Trace:
[ef857f70] [c006d538] on_each_cpu+0x1c/0x50 (unreliable)
[ef857f90] [c057a070] mpc85xx_mc_init+0xc4/0xdc
[ef857fa0] [c0001cd4] do_one_initcall+0x34/0x1a8
[ef857fd0] [c055d9d8] kernel_init+0x17c/0x218
[ef857ff0] [c000cda4] kernel_thread+0x4c/0x68
Instruction dump:
40be0018 3c60c052 3863c70c 4be9baad 3be0ffed 4bd7c99d 80010014 7fe3fb78
83e1000c 38210010 7c0803a6 4e800020 <7c11faa6> 54290024 81290008
3d60c06e
Oops: Exception in kernel mode, sig: 4 [#2]
---[ end trace 49ff3b8f93efde1a ]---
Also use the HID1_RFXE define rather than a magic number.
PCIe memory address space is 1:1 mapped with u-boot.
Update dts of Px020RDB i.e. P1020RDB and P2020RDB to match the address map
changes in u-boot.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
On error path kfree() should get pointer to memory allocated by
kmalloc() not the address of variable holding it (which is on stack).
Signed-off-by: Mariusz Kozlowski <mk@lab.zgora.pl>
Avoid touching the flip setup regs while
acceleration is running. Set them at modeset
rather than during pageflip. Touching these
regs while acceleration is active caused hangs
on pre-avivo chips. These chips do not seem
to be affected, but better safe than sorry,
plus it avoids repeatedly reprogramming the
regs every flip.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
In rpckbd_open prror path, free_irq() was using NULL rather than the
driver data as the data pointer so free_irq() wouldn't have matched.
floatable
1. get videomemory by __get_free_pages() in fb-puv3.c
2. remove resource reservation for old fixed UNIGFX_MMAP & UVC_MMAP space
3. remove unused macros: PKUNTIY_UNIGFX_MMAP_BASE, PKUNITY_UNIGFX_MMAP_SIZE,
PKUNITY_UVC_MMAP_BASE, PKUNITY_UVC_MMAP_SIZE and KUSER_UNIGFX_BASE
4. remove unused header linux/vmalloc.h in fb-puv3.h
Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
Remove duplicated #include('s) in
arch/unicore32/kernel/traps.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
The futex functions in unicore32 are not used and verified,
so just replaced by asm-generic version.
Also, adjust cacheline parameter of RW_DATA_SECTION and EXCEPTION_TABLE
All callers are prepared for alloc failures anyway, so this error
can safely be boomeranged to the callers domain without super
bad consequences. ...At worst the connection might go into a state
where each RTO tries to (unsuccessfully) re-fragment with such
a mis-sized value and eventually dies.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Sometime the ASCONF_ACK parameters can equal to the fourfold of
ASCONF parameters, this only happend in some special case:
ASCONF parameter is :
Unrecognized Parameter (4 bytes)
ASCONF_ACK parameter should be:
Error Cause Indication parameter (8 bytes header)
+ Error Cause (4 bytes header)
+ Unrecognized Parameter (4bytes)
Four 4bytes Unrecognized Parameters in ASCONF chunk will cause panic.
Pid: 0, comm: swapper Not tainted 2.6.38-next+ #22 Bochs Bochs
EIP: 0060:[<c0717eae>] EFLAGS: 00010246 CPU: 0
EIP is at skb_put+0x60/0x70
EAX: 00000077 EBX: c09060e2 ECX: dec1dc30 EDX: c09469c0
ESI: 00000000 EDI: de3c8d40 EBP: dec1dc58 ESP: dec1dc2c
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process swapper (pid: 0, ti=dec1c000 task=c09aef20 task.ti=c0980000)
Stack:
c09469c0 e1894fa4 00000044 00000004 de3c8d00 de3c8d00 de3c8d44 de3c8d40
c09060e2 de25dd80 de3c8d40 dec1dc7c e1894fa4 dec1dcb0 00000040 00000004
00000000 00000800 00000004 00000004 dec1dce0 e1895a2b dec1dcb4 de25d960
Call Trace:
[<e1894fa4>] ? sctp_addto_chunk+0x4e/0x89 [sctp]
[<e1894fa4>] sctp_addto_chunk+0x4e/0x89 [sctp]
[<e1895a2b>] sctp_process_asconf+0x32f/0x3d1 [sctp]
[<e188d554>] sctp_sf_do_asconf+0xf8/0x173 [sctp]
[<e1890b02>] sctp_do_sm+0xb8/0x159 [sctp]
[<e18a2248>] ? sctp_cname+0x0/0x52 [sctp]
[<e189392d>] sctp_assoc_bh_rcv+0xac/0xe3 [sctp]
[<e1897d76>] sctp_inq_push+0x2d/0x30 [sctp]
[<e18a21b2>] sctp_rcv+0x7a7/0x83d [sctp]
[<c077a95c>] ? ipv4_confirm+0x118/0x125
[<c073a970>] ? nf_iterate+0x34/0x62
[<c074789d>] ? ip_local_deliver_finish+0x0/0x194
[<c0747992>] ip_local_deliver_finish+0xf5/0x194
[<c0747a6e>] NF_HOOK.clone.1+0x3d/0x44
[<c0747ab3>] ip_local_deliver+0x3e/0x44
[<c074775c>] ip_rcv_finish+0x29f/0x2c7
[<c07474bd>] ? ip_rcv_finish+0x0/0x2c7
[<c0747cae>] ip_rcv+0x1f5/0x233
[<c071dce3>] __netif_receive_skb+0x310/0x336
[<c07221f3>] netif_receive_skb+0x4b/0x51
[<e0a4ed3d>] cp_rx_poll+0x1e7/0x29c [8139cp]
[<c072275e>] net_rx_action+0x65/0x13a
[<c0445a54>] __do_softirq+0xa1/0x149
[<c04459b3>] ? __do_softirq+0x0/0x149
<IRQ>
[<c0445891>] ? irq_exit+0x37/0x72
[<c040a7e9>] ? do_IRQ+0x81/0x95
[<c07b3670>] ? common_interrupt+0x30/0x38
[<c0428058>] ? native_safe_halt+0xa/0xc
[<c040f5d7>] ? default_idle+0x58/0x92
[<c0408fb0>] ? cpu_idle+0x96/0xb2
[<c0797989>] ? rest_init+0x5d/0x5f
[<c09fd90c>] ? start_kernel+0x34b/0x350
[<c09fd0cb>] ? i386_start_kernel+0xba/0xc1
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
auth_hmacs field of struct sctp_cookie is used for store
Requested HMAC Algorithm Parameter, and each HMAC Identifier
is 2 bytes, so the length should be:
SCTP_AUTH_NUM_HMACS * sizeof(__u16) + 2
dev_ethtool_get_rx_csum() won't report rx checksumming when it's not
changeable and driver is converted to hw_features and friends. Fix this.
(dev->hw_features & NETIF_F_RXCSUM) check is dropped - if the
ethtool_ops->get_rx_csum is set, then driver is not coverted, yet.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
The documentation for the USB ethernet devices suggests that
only some devices are supposed to use usb0 as the network interface
name instead of eth0. The logic used there, and documented in
Kconfig for CDC is that eth0 will be used when the mac address
is a globally assigned one, but usb0 is used for the locally
managed range that is typically used on point-to-point links.
Unfortunately, this has caused a lot of pain on the smsc95xx
device that is used on the popular pandaboard without an
EEPROM to store the MAC address, which causes the driver to
call random_ether_address().
Obviously, there should be a proper MAC addressed assigned to
the device, and discussions are ongoing about how to solve
this, but this patch at least makes sure that the default
interface naming gets a little saner and matches what the
user can expect based on the documentation, including for
new devices.
The approach taken here is to flag whether a device might be a
point-to-point link with the new FLAG_POINTTOPOINT setting in
the usbnet driver_info. A driver can set both FLAG_POINTTOPOINT
and FLAG_ETHER if it is not sure (e.g. cdc_ether), or just one
of the two. The usbnet framework only looks at the MAC address
for device naming if both flags are set, otherwise it trusts the
flag.
Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Tested-by: Andy Green <andy.green@linaro.org>
Now we have CONFIG_ARCH_DMA_ADDR_T_64BIT. We can fix the hacky
dma_addr_t size test cleanly.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] fix build warning: argument 1 of 'irqd_irq_disabled'
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/urgent
In commit f5e5bf088bd3d30990efb7429aaf9f1e5134ffd6
ia64: Use irqd_irq_disabled() instead of desc->status access
Thomas forgot to convert from irq to *irq_data.
Add a call to irq_get_irq_data() to fix that.
Signed-off-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: pcm: fix infinite loop in snd_pcm_update_hw_ptr0()
ALSA: HDA: Add dock mic quirk for Lenovo Thinkpad X220
ALSA: ens1371: fix Creative Ectiva support
ALSA: firewire-speakers: fix hang when unplugging a running device
ASoC: Fix CODEC device name for Corgi
ALSA: hda - Fix pin-config of Gigabyte mobo
ASoC: imx: fix burstsize for DMA
ASoC: imx: set watermarks for mx2-dma
ASoC: twl6040: Return -ENOMEM if create_singlethread_workqueue fails
ASoC: tlv320dac33: Restore L/R DAC power control register
ASoC: Explicitly say registerless widgets have no register
ASoC: tlv320dac33: Fix inconsistent spinlock usage
When period interrupts are disabled, snd_pcm_update_hw_ptr0() compares
the current time against the time estimated for the current hardware
pointer to detect xruns. The somewhat fuzzy threshold in the while loop
makes it possible that hdelta becomes negative; the comparison being
done with unsigned types then makes the loop go through the entire 263
negative range, and, depending on the value, never reach an unsigned
value that is small enough to stop the loop. Doing this with interrupts
disabled results in the machine locking up.
To prevent this, ensure that the loop condition uses signed types for
both operands so that the comparison is correctly done.
Many thanks to Kelly Anderson for debugging this.
Reported-by: Nix <nix@esperi.org.uk>
Reported-by: "Christopher K." <c.krooss@googlemail.com>
Reported-and-tested-by: Kelly Anderson <kelly@silka.with-linux.com>
Signed-off-by: Kelly Anderson <kelly@silka.with-linux.com>
[cl: remove unneeded casts; use a temp variable]
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Cc: 2.6.38 <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
kdump: Allow shrinking of kdump region to be overridden
powerpc/pmac/smp: Remove no-longer needed preempt workaround
powerpc/smp: Increase vdso_data->processorCount, not just decrease it
powerpc/smp: Create idle threads on demand and properly reset them
powerpc/smp: Don't expose per-cpu "cpu_state" array
powerpc/pmac/smp: Fix CPU hotplug crashes on some machines
powerpc/smp: Add a smp_ops->bringup_up() done callback
powerpc/pmac: Rename cpu_state in therm_pm72 to avoid collision
powerpc/pmac/smp: Properly NAP offlined CPU on G5
powerpc/pmac/smp: Remove HMT changes for PowerMac offline code
powerpc/pmac/smp: Consolidate 32-bit and 64-bit PowerMac cpu_die in one file
powerpc/pmac/smp: Fixup smp_core99_cpu_disable() and use it on 64-bit
powerpc/pmac/smp: Rename fixup_irqs() to migrate_irqs() and use it on ppc32
powerpc/pmac/smp: Fix 32-bit PowerMac cpu_die
powerpc/smp: Remove unused smp_ops->cpu_enable()
powerpc/smp: Remove unused generic_cpu_enable()
powerpc/smp: Fix generic_mach_cpu_die()
powerpc/smp: soft-replugged CPUs must go back to start_secondary
powerpc: Make decrementer interrupt robust against offlined CPUs
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc32: Pass task_struct to schedule_tail() in ret_from_fork
apbuart: Depend upon sparc.
sparc64: Fix section mis-match errors.
sparc32,leon: Fixed APBUART frequency detection
sparc32, leon: APBUART driver must use archdata to get IRQ number
sparc: Hook up syncfs system call.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
appletalk: Fix OOPS in atalk_release().
mlx4: Fixing bad size of event queue buffer
mlx4: Fixing use after free
bonding:typo in comment
sctp: Pass __GFP_NOWARN to hash table allocation attempts.
connector: convert to synchronous netlink message processing
fib: add rtnl locking in ip_fib_net_exit
atm/solos-pci: Don't flap VCs when carrier state changes
atm/solos-pci: Don't include frame pseudo-header on transmit hex-dump
atm/solos-pci: Use VPI.VCI notation uniformly.
Atheros, atl2: Fix mem leaks in error paths of atl2_set_eeprom
netdev: fix mtu check when TSO is enabled
net/usb: Ethernet quirks for the LG-VL600 4G modem
phylib: phy_attach_direct: phy_init_hw can fail, add cleanup
bridge: mcast snooping, fix length check of snooped MLDv1/2
via-ircc: Pass PCI device pointer to dma_{alloc, free}_coherent()
via-ircc: Use pci_{get, set}_drvdata() instead of static pointer variable
net: gre: provide multicast mappings for ipv4 and ipv6
bridge: Fix compilation warning in function br_stp_recalculate_bridge_id()
net: Fix warnings caused by MAX_SKB_FRAGS change.
The MCE subsystem needs to sample an RCU-protected index outside of
any protection for that index. If this was a pointer, we would use
rcu_access_pointer(), but there is no corresponding rcu_access_index().
This commit therefore creates an rcu_access_index() and applies it
to MCE.
Tested-by: Zdenek Kabelac <zkabelac@redhat.com>
- Do not trace idle loop which takes a lot time
- Fix cache handling in generic ftrace code
- Do not trace lib functions ashldi3, ashrdi3, lshrdi3
Functions are called from generic ftrace code which
can't be traced
Hook up name_to_handle_at, open_by_handle_at, clock_adjtime, syncfs
Patches:
"microblaze: Convert to new irq function names"
sha (4adc192ec7d977c74c750320f289af9d61c1caca)
and
"microblaze: Use generic show_interrupts()"
sha(9d61c18b25726306c9231428c17db42e3ff29ba7)
should also setup edge/level in irq_set_chip_and_handler_name
name parameter.
Error log:
~ # cat /proc/interrupts
CPU0
2: 2 Xilinx INTC-Xilinx INTC eth0
3: 2 Xilinx INTC-Xilinx INTC eth0
4: 241 Xilinx INTC-Xilinx INTC timer
6: 108 Xilinx INTC-Xilinx INTC serial
Fixed:
CPU0
2: 2 Xilinx INTC-level eth0
3: 2 Xilinx INTC-level eth0
4: 238 Xilinx INTC-edge timer
6: 108 Xilinx INTC-level serial
v2: Fix exchanged edge and level
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
Acked-by: Ping Cheng <pingc@wacom.com>
On ppc64 the crashkernel region almost always overlaps an area of firmware.
This works fine except when using the sysfs interface to reduce the kdump
region. If we free the firmware area we are guaranteed to crash.
Rename free_reserved_phys_range to crash_free_reserved_phys_range and make
it a weak function so we can override it.
The generic code properly re-initializes the preempt count in the
idle thread now
Instead of creating idle threads at boot for all possible CPUs, we
create them on demand, like x86 or ARM, and we properly call init_idle
to re-initialize an idle thread when a CPU was unplugged and is now
re-plugged.
Instead, keep it static, expose an accessor and use that from
the PowerMac code. Avoids easy namespace collisions and will
make it easier to consolidate with other implementations.
On some machines that use i2c to synchronize the timebases (such
as PowerMac7,2/7,3 G5 machines), hotplug CPU would crash when
putting back a new CPU online due to the underlying i2c bus being
closed.
This uses the newly added bringup_done() callback to move the close
along with other housekeeping calls, and adds a CPU notifier to
re-open the i2c bus around subsequent hotplug operations
This allows us to stop abusing smp_ops->setup_cpu() for cleanup
tasks that have to take place after the initial boot time CPU
bringup.
