2007-05-11further UTF-8 fixes and name correctionDavid Woodhouse
> -** Copyright 1994 by Bj<94>rn Brauel > +** Copyright 1994 by Bj”rn Brauel I think these were cp437, and it should read 'Björn'. (asm-m68k/atari*.h) Also note that Arnaldo just put more legacy noise into CREDITS... Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-11Fix wrong identifier name in Documentation/kref.txtSatyam Sharma
There's a typo / wrong identifier name in Documentation/kref.txt. Fix it. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Acked-by: Corey Minyard <minyard@acm.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-10locks: fix F_GETLK regression (failure to find conflicts)J. Bruce Fields
In 9d6a8c5c213e34c475e72b245a8eb709258e968c we changed posix_test_lock to modify its single file_lock argument instead of taking separate input and output arguments. This makes it no longer safe to set the output lock's fl_type to F_UNLCK before looking for a conflict, since that means searching for a conflict against a lock with type F_UNLCK. This fixes a regression which causes F_GETLK to incorrectly report no conflict on most filesystems (including any filesystem that doesn't do its own locking). Also fix posix_lock_to_flock() to copy the lock type. This isn't strictly necessary, since the caller already does this; but it seems less likely to cause confusion in the future. Thanks to Doug Chapman for the bug report. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Acked-by: Doug Chapman <doug.chapman@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10Merge master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] MTX-1 Watchdog driver [WATCHDOG] s3c2410_wdt - initialize watchdog irq resource [WATCHDOG] Kconfig menuconfig patch [WATCHDOG] pcwd.c: Port to the new device driver model [WATCHDOG] use mutex instead of semaphore in Berkshire USB-PC Watchdog driver [WATCHDOG] the scheduled removal of the i8xx_tco watchdog driver [WATCHDOG] Semi-typical watchdog bug re early misc_register() [WATCHDOG] add support for the w83627thf chipset.
2007-05-10Allow compat_ioctl.c to compile without CONFIG_NETSimon Horman
A small regression appears to have been introduced in the recent patch "cleanup compat ioctl handling", which was included in Linus' tree after 2.6.20. siocdevprivate_ioctl() is no longer defined if CONFIG_NET is undefined, whereas previously it was a dummy function in this case. This causes compilation with CONFIG_COMPAT but without CONFIG_NET to fail. fs/compat_ioctl.c: In function `compat_sys_ioctl': fs/compat_ioctl.c:3571: warning: implicit declaration of function `siocdevprivate_ioctl' Cc: Christoph Hellwig <hch@lst.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10Fix ixp4xx compile errorFrederik Deweerdt
drivers/input/misc/ixp4xx-beeper.c: In function 'ixp4xx_spkr_event': drivers/input/misc/ixp4xx-beeper.c:54: error: 'input_dev' undeclared (first use in this function) drivers/input/misc/ixp4xx-beeper.c:54: error: (Each undeclared identifier is reported only once drivers/input/misc/ixp4xx-beeper.c:54: error: for each function it appears in.) Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (24 commits) [POWERPC] Fix compile error with kexec and CONFIG_SMP=n [POWERPC] Split initrd logic out of early_init_dt_scan_chosen() to fix warning [POWERPC] Fix warning in hpte_decode(), and generalize it [POWERPC] Minor pSeries IOMMU debug cleanup [POWERPC] PS3: Fix sys manager build error [POWERPC] Assorted janitorial EEH cleanups [POWERPC] We don't define CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID [POWERPC] pmu_sys_suspended is only defined for PPC32 [POWERPC] Fix incorrect calculation of I/O window addresses [POWERPC] celleb: Update celleb_defconfig [POWERPC] celleb: Fix parsing of machine type hack command line option [POWERPC] celleb: Fix PCI config space accesses to subordinate buses [POWERPC] celleb: Fix support for multiple PCI domains [POWERPC] Wire up sys_utimensat [POWERPC] CPM_UART: Removed __init from cpm_uart_init_portdesc to fix warning [POWERPC] User rheap from arch/powerpc/lib [POWERPC] 83xx: Fix the PCI ranges in the MPC834x_MDS device tree. [POWERPC] 83xx: Fix the PCI ranges in the MPC832x_MDS device tree. [POWERPC] CPM_UART: cpm_uart_set_termios should take ktermios, not termios [POWERPC] Change rheap functions to use ulongs instead of pointers ...
2007-05-10Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Use alloc_pci_dev() in PCI bus probes. [SPARC64]: Bump PROMINTR_MAX to 32. [SPARC64]: Fix recursion in PROM tree building. [SERIAL] sunzilog: Interrupt enable before ISR handler installed [SPARC64] PCI: Consolidate PCI access code into pci_common.c
2007-05-10Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: acpi,msi-laptop: Fall back to EC polling mode for MSI laptop specific EC commands sony-laptop: rename SONY_LAPTOP_OLD to a more meaningful SONYPI_COMPAT asus-laptop: version bump and lindent asus-laptop: fix light sens init asus-laptop: add GPS support asus-laptop: notify ALL events ACPICA: Lindent ACPI: created a dedicated workqueue for notify() execution Revert "ACPICA: fix AML mutex re-entrancy" Revert "Execute AML Notify() requests on stack." Revert "ACPICA: revert "acpi_serialize" changes" ACPI: delete un-reliable concept of cooling mode ACPI: thermal trip points are read-only
2007-05-10Merge branch 'juju' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'juju' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (138 commits) firewire: Convert OHCI driver to use standard goto unwinding for error handling. firewire: Always use parens with sizeof. firewire: Drop single buffer request support. firewire: Add a comment to describe why we split the sg list. firewire: Return SCSI_MLQUEUE_HOST_BUSY for out of memory cases in queuecommand. firewire: Handle the last few DMA mapping error cases. firewire: Allocate scsi_host up front and allocate the sbp2_device as hostdata. firewire: Provide module aliase for backwards compatibility. firewire: Add to fw-core-y instead of assigning fw-core-objs in Makefile. firewire: Break out shared IEEE1394 constant to separate header file. firewire: Use linux/*.h instead of asm/*.h header files. firewire: Uppercase most macro names. firewire: Coding style cleanup: no spaces after function names. firewire: Convert card_rwsem to a regular mutex. firewire: Clean up comment style. firewire: Use lib/ implementation of CRC ITU-T. CRC ITU-T V.41 firewire: Rename fw-device-cdev.c to fw-cdev.c and move header to include/linux. firewire: Future proof the iso ioctls by adding a handle for the iso context. firewire: Add read/write and size annotations to IOC numbers. ... Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] update default configuration. [S390] Kconfig: no wireless on s390. [S390] Kconfig: use common Kconfig files for s390. [S390] Kconfig: common config options for s390. [S390] Kconfig: unwanted menus for s390. [S390] Kconfig: menus with depends on HAS_IOMEM. [S390] Kconfig: refine depends statements. [S390] Avoid compile warning. [S390] qdio: re-add lost perf_stats.tl_runs change in qdio_handle_pci [S390] Avoid sparse warnings. [S390] dasd: Fix modular build. [S390] monreader inlining cleanup. [S390] cio: Make some structures and a function static. [S390] cio: Get rid of _ccw_device_get_device_number(). [S390] fix subsystem removal fallout
2007-05-10timer: revert parenthesis fix in tbase_get_deferrable() etcakpm@linux-foundation.org
On 09-05-2007 21:10, Pallipadi, Venkatesh wrote: ... > On a 64 bit system, converting pointer to int causes unnecessary > compiler warning, and intermediate long conversion was to avoid that. > I will have to rephrase my comment to remove 32 bit value and use int, > as that is what the function returns. So, this patch reverts all changes done by my previous patch. I apologize for my wrong comment about "logical error" here. Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Satyam Sharma <satyam.sharma@gmail.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10i2c-at91: compile fix (IS_ERR)Alexey Dobriyan
CC drivers/i2c/busses/i2c-at91.o drivers/i2c/busses/i2c-at91.c: In function 'at91_i2c_probe': drivers/i2c/busses/i2c-at91.c:213: warning: implicit declaration of function 'IS_ERR' Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Brownell <david-b@pacbell.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10i2c-at91 supports new-style i2c driversDavid Brownell
Make i2c-at91 register as i2c adapter zero (none of these chips seem to have more than one TWI controllers) to let it kick in any board-specific device declarations; also make it hotplug/coldplug. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10md: avoid a possibility that a read error can wrongly propagate through ↵NeilBrown
md/raid1 to a filesystem. When a raid1 has only one working drive, we want read error to propagate up to the filesystem as there is no point failing the last drive in an array. Currently the code perform this check is racy. If a write and a read a both submitted to a device on a 2-drive raid1, and the write fails followed by the read failing, the read will see that there is only one working drive and will pass the failure up, even though the one working drive is actually the *other* one. So, tighten up the locking. Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10drivers/hwmon: switch to using input_dev->dev.parentDmitry Torokhov
In preparation for struct class_device -> struct device input core conversion, switch to using input_dev->dev.parent when specifying device position in sysfs tree. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10SLUB: remove nr_cpu_ids hackChristoph Lameter
This was in SLUB in order to head off trouble while the nr_cpu_ids functionality was not merged. Its merged now so no need to still have this. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10SLUB: SLUB_DEBUG must depend on SLUBChristoph Lameter
Otherwise people get asked about SLUB_DEBUG even if they have another slab allocator enabled. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10Revert "[PATCH] paravirt: Add startup infrastructure for paravirtualization"Eric W. Biederman
This reverts commit c9ccf30d77f04064fe5436027ab9d2230c7cdd94. Entering the kernel at startup_32 without passing our real mode data in %esi, and without guaranteeing that physical and virtual addresses are identity mapped makes head.S impossible to maintain. The only user of this infrastructure is lguest which is not merged so nothing we currently support will break by removing this over designed nightmare, and only the pending lguest patches will be affected. The pending Xen patches have a different entry point that they use. We are currently discussing what Xen and lguest need to do to boot the kernel in a more normal fashion so using startup_32 in this weird manner is clearly not their long term direction. So let's remove this code in head.S before it causes brain damage to people trying to maintain head.S Cc: Chris Wright <chrisw@sous-sol.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Zachary Amsden <zach@vmware.com> CC: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10arm: fix i2c-pxa buildRussell King
From commit 7d054817b780e664bed6701b2aa637718e1905b7: > According to the PXA27x developer's manual, we shall do so. We shall also at least compile test our changes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10ocfs2: kobject/kset foobarRandy Dunlap
Fix gcc warning and Oops that it causes: fs/ocfs2/cluster/masklog.c:161: warning: assignment from incompatible pointer type [ 2776.204120] OCFS2 Node Manager 1.3.3 [ 2776.211729] BUG: spinlock bad magic on CPU#0, modprobe/4424 [ 2776.214269] lock: ffff810021c8fe18, .magic: ffffffff, .owner: /6394416, .owner_cpu: 0 [ 2776.217864] [ 2776.217865] Call Trace: [ 2776.219662] [<ffffffff803426c8>] spin_bug+0x9e/0xe9 [ 2776.221921] [<ffffffff803427bf>] _raw_spin_lock+0x23/0xf9 [ 2776.224417] [<ffffffff8051acf4>] _spin_lock+0x9/0xb [ 2776.226676] [<ffffffff8033c3b1>] kobject_shadow_add+0x98/0x1ac [ 2776.229367] [<ffffffff8033c4d0>] kobject_add+0xb/0xd [ 2776.231665] [<ffffffff8033c4df>] kset_add+0xd/0xf [ 2776.233845] [<ffffffff8033c5a6>] kset_register+0x23/0x28 [ 2776.236309] [<ffffffff8808ccb7>] :ocfs2_nodemanager:mlog_sys_init+0x68/0x6d [ 2776.239518] [<ffffffff8808ccee>] :ocfs2_nodemanager:o2cb_sys_init+0x32/0x4a [ 2776.242726] [<ffffffff880b80a6>] :ocfs2_nodemanager:init_o2nm+0xa6/0xd5 [ 2776.245772] [<ffffffff8025266c>] sys_init_module+0x1471/0x15d2 [ 2776.248465] [<ffffffff8033f250>] simple_strtoull+0x0/0xdc [ 2776.250959] [<ffffffff8020948e>] system_call+0x7e/0x83 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10early_pfn_to_nid needs to be __meminitStephen Rothwell
Since it is referenced by memmap_init_zone (which is __meminit) via the early_pfn_in_nid macro when CONFIG_NODES_SPAN_OTHER_NODES is set (which basically means PowerPC 64). This removes a section mismatch warning in those circumstances. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10AF_RXRPC: reduce debugging noiseDavid Howells
Reduce debugging noise generated by AF_RXRPC. Signed-off-by: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10AFS: further write support fixesDavid Howells
Further fixes for AFS write support: (1) The afs_send_pages() outer loop must do an extra iteration if it ends with 'first == last' because 'last' is inclusive in the page set otherwise it fails to send the last page and complete the RxRPC op under some circumstances. (2) Similarly, the outer loop in afs_pages_written_back() must also do an extra iteration if it ends with 'first == last', otherwise it fails to clear PG_writeback on the last page under some circumstances. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10AFS: write support fixesDavid Howells
AFS write support fixes: (1) Support large files using the 64-bit file access operations if available on the server. (2) Use kmap_atomic() rather than kmap() in afs_prepare_page(). (3) Don't do stuff in afs_writepage() that's done by the caller. [akpm@linux-foundation.org: fix right shift count >= width of type] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10add upper-32-bits macroAndrew Morton
We keep on getting "right shift count >= width of type" warnings when doing things like sector_t s; x = s >> 56; because with CONFIG_LBD=n, s is only 32-bit. Similar problems can occur with dma_addr_t's. So add a simple wrapper function which code can use to avoid this warning. The above example would become x = upper_32_bits(s) >> 24; The first user is in fact AFS. Cc: James Bottomley <James.Bottomley@SteelEye.com> Cc: "Cameron, Steve" <Steve.Cameron@hp.com> Cc: "Miller, Mike (OS Dev)" <Mike.Miller@hp.com> Cc: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10slub: support concurrent local and remote frees and allocs on a slabChristoph Lameter
Avoid atomic overhead in slab_alloc and slab_free SLUB needs to use the slab_lock for the per cpu slabs to synchronize with potential kfree operations. This patch avoids that need by moving all free objects onto a lockless_freelist. The regular freelist continues to exist and will be used to free objects. So while we consume the lockless_freelist the regular freelist may build up objects. If we are out of objects on the lockless_freelist then we may check the regular freelist. If it has objects then we move those over to the lockless_freelist and do this again. There is a significant savings in terms of atomic operations that have to be performed. We can even free directly to the lockless_freelist if we know that we are running on the same processor. So this speeds up short lived objects. They may be allocated and freed without taking the slab_lock. This is particular good for netperf. In order to maximize the effect of the new faster hotpath we extract the hottest performance pieces into inlined functions. These are then inlined into kmem_cache_alloc and kmem_cache_free. So hotpath allocation and freeing no longer requires a subroutine call within SLUB. [I am not sure that it is worth doing this because it changes the easy to read structure of slub just to reduce atomic ops. However, there is someone out there with a benchmark on 4 way and 8 way processor systems that seems to show a 5% regression vs. Slab. Seems that the regression is due to increased atomic operations use vs. SLAB in SLUB). I wonder if this is applicable or discernable at all in a real workload?] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10x86_64: fix default_do_nmi() missing return after an if ()Mathieu Desnoyers
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10firewire: Convert OHCI driver to use standard goto unwinding for error handling.Kristian Høgsberg
Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-10firewire: Always use parens with sizeof.Kristian Høgsberg
2007-05-10firewire: Drop single buffer request support.Kristian Høgsberg
The SCSI layer only passes sg requests down, so drop the use_sg == 0, request_bufflen != 0 case. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-10firewire: Add a comment to describe why we split the sg list.Kristian Høgsberg, Stefan Richter
2007-05-10firewire: Return SCSI_MLQUEUE_HOST_BUSY for out of memory cases in queuecommand.Kristian Høgsberg
2007-05-10firewire: Handle the last few DMA mapping error cases.Kristian Høgsberg
This should be the last missing checks. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-10firewire: Allocate scsi_host up front and allocate the sbp2_device as hostdata.Kristian Høgsberg
Avoids an extra allocation and simplifies lifetime rules for the scsi_host. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-10firewire: Provide module aliase for backwards compatibility.Olaf Hering
This patch loads fw-sbp2 if sbp2 is still in the config file. So one can go back and forth between releases without worry about the root filesystem drivers. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Existing mkinitrd scripts still have to be adapted, unless they grok module aliases. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-10firewire: Add to fw-core-y instead of assigning fw-core-objs in Makefile.Kristian Høgsberg
2007-05-10firewire: Break out shared IEEE1394 constant to separate header file.Kristian Høgsberg
2007-05-10firewire: Use linux/*.h instead of asm/*.h header files.Kristian Høgsberg
2007-05-10firewire: Uppercase most macro names.Kristian Høgsberg
2007-05-10firewire: Coding style cleanup: no spaces after function names.Kristian Høgsberg
2007-05-10firewire: Convert card_rwsem to a regular mutex.Kristian Høgsberg
2007-05-10firewire: Clean up comment style.Kristian Høgsberg
Drop filenames from file preamble, drop editor annotations and use standard indent style for block comments. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (fixed typo)
2007-05-10firewire: Use lib/ implementation of CRC ITU-T.Kristian Høgsberg
With the CRC ITU-T implementation available in lib/ we can use that instead. This also fixes a bug in the topology map crc computation. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (fixed Kconfig)
2007-05-10CRC ITU-T V.41Ivo van Doorn
This will add the CRC calculation according to the CRC ITU-T V.41 to the kernel lib/ folder. This code has been derived from the rt2x00 driver, currently found only in the wireless-dev tree, but this library is generic and could be used by more drivers who currently use their own implementation. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Also useful for the new firewire stack. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-10[S390] update default configuration.Martin Schwidefsky
2007-05-10[S390] Kconfig: no wireless on s390.Martin Schwidefsky
Hide the config menues for wireless on s390. Cc: John W. Linville <linville@tuxdriver.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-10[S390] Kconfig: use common Kconfig files for s390.Martin Schwidefsky
Disband drivers/s390/Kconfig, use the common Kconfig files. The s390 specific config options from drivers/s390/Kconfig are moved to the respective common Kconfig files. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-10[S390] Kconfig: common config options for s390.Martin Schwidefsky
Disable some configuration options in the common Kconfig files that are of no interest to a s390 machine. Enable hangcheck timer. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-10[S390] Kconfig: unwanted menus for s390.Martin Schwidefsky
Disable some more menus in the configuration files that are of no interest to a s390 machine. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
