[ Upstream commit b9eda06f80b0db61a73bd87c6b0eb67d8aca55ad ]
Acked-by: David Miller <davem@davemloft.net>
[ Upstream commit 9f28a2fc0bd77511f649c0a788c7bf9a5fd04edb ]
Commit 2c8cec5c10b (ipv4: Cache learned PMTU information in inetpeer)
removed IP route cache garbage collector a bit too soon, as this gc was
responsible for expired routes cleanup, releasing their neighbour
reference.
As pointed out by Robert Gladewitz, recent kernels can fill and exhaust
their neighbour cache.
Reintroduce the garbage collection, since we'll have to wait our
neighbour lookups become refcount-less to not depend on this stuff.
Reported-by: Robert Gladewitz <gladewitz@gmx.de>
[ Upstream commit e688a604807647c9450f9c12a7cb6d027150a895 ]
Chris Boot reported crashes occurring in ipv6_select_ident().
[ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>]
ipv6_select_ident+0x31/0xa7
[ 461.578229] Call Trace:
[ 461.580742] <IRQ>
[ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2
[ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155
[ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b
[ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e
[nf_conntrack_ipv6]
[ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543
[ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a
[bridge]
[ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459
[ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76
[bridge]
[ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f
[bridge]
[ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.677299] [<ffffffffa0379215>] ?
nf_bridge_update_protocol+0x20/0x20 [bridge]
[ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack]
[ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56
[bridge]
[ 461.704616] [<ffffffffa0379031>] ?
nf_bridge_push_encap_header+0x1c/0x26 [bridge]
[ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95
[bridge]
[ 461.719490] [<ffffffffa037900a>] ?
nf_bridge_pull_encap_header+0x1c/0x27 [bridge]
[ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge]
[ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56
[bridge]
This is caused by bridge netfilter special dst_entry (fake_rtable), a
special shared entry, where attaching an inetpeer makes no sense.
Problem is present since commit 87c48fa3b46 (ipv6: make fragment
identifications less predictable)
Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and
__ip_select_ident() fallback to the 'no peer attached' handling.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
rt6_alloc_cow().
[ Upstream commit bb3c36863e8001fc21a88bebfdead4da4c23e848 ]
After commit 8e2ec639173f325977818c45011ee176ef2b11f6 ("ipv6: don't
use inetpeer to store metrics for routes.") the test in rt6_alloc_cow()
for setting the ANYCAST flag is now wrong.
'rt' will always now have a plen of 128, because it is set explicitly
to 128 by ip6_rt_copy.
So to restore the semantics of the test, check the destination prefix
length of 'ort'.
[ Upstream commit d01ff0a049f749e0bf10a35bb23edd012718c8c2 ]
After reset ipv4_devconf->data[IPV4_DEVCONF_ACCEPT_LOCAL] to 0,
we should flush route cache, or it will continue receive packets with local
source address, which should be dropped.
Signed-off-by: Weiping Pan <panweiping3@gmail.com>
[ Upstream commit c0ed1c14a72ca9ebacd51fb94a8aca488b0d361e ]
flow_cach_flush() might sleep but can be called from
atomic context via the xfrm garbage collector. So add
a flow_cache_flush_deferred() function and use this if
the xfrm garbage colector is invoked from within the
packet path.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Timo Teräs <timo.teras@iki.fi>
[ Upstream commit a76c0adf60f6ca5ff3481992e4ea0383776b24d2 ]
When checking whether a DATA chunk fits into the estimated rwnd a
full sizeof(struct sk_buff) is added to the needed chunk size. This
quickly exhausts the available rwnd space and leads to packets being
sent which are much below the PMTU limit. This can lead to much worse
performance.
The reason for this behaviour was to avoid putting too much memory
pressure on the receiver. The concept is not completely irational
because a Linux receiver does in fact clone an skb for each DATA chunk
delivered. However, Linux also reserves half the available socket
buffer space for data structures therefore usage of it is already
accounted for.
When proposing to change this the last time it was noted that this
behaviour was introduced to solve a performance issue caused by rwnd
overusage in combination with small DATA chunks.
Trying to reproduce this I found that with the sk_buff overhead removed,
the performance would improve significantly unless socket buffer limits
are increased.
The following numbers have been gathered using a patched iperf
supporting SCTP over a live 1 Gbit ethernet network. The -l option
was used to limit DATA chunk sizes. The numbers listed are based on
the average of 3 test runs each. Default values have been used for
sk_(r|w)mem.
Chunk
Size Unpatched No Overhead
4 15.2 Kbit [!] 12.2 Mbit [!]
8 35.8 Kbit [!] 26.0 Mbit [!]
16 95.5 Kbit [!] 54.4 Mbit [!]
32 106.7 Mbit 102.3 Mbit
64 189.2 Mbit 188.3 Mbit
128 331.2 Mbit 334.8 Mbit
256 537.7 Mbit 536.0 Mbit
512 766.9 Mbit 766.6 Mbit
1024 810.1 Mbit 808.6 Mbit
Signed-off-by: Thomas Graf <tgraf@redhat.com>
[ Upstream commit 2692ba61a82203404abd7dd2a027bda962861f74 ]
Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for
limiting the autoclose value. If userspace passes in -1 on 32-bit
platform, the overflow check didn't work and autoclose would be set
to 0xffffffff.
This patch defines a max_autoclose (in seconds) for limiting the value
and exposes it through sysctl, with the following intentions.
1) Avoid overflowing autoclose * HZ.
2) Keep the default autoclose bound consistent across 32- and 64-bit
platforms (INT_MAX / HZ in this patch).
3) Keep the autoclose value consistent between setsockopt() and
getsockopt() calls.
Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Xi Wang <xi.wang@gmail.com>
[ Upstream commit 3f1e6d3fd37bd4f25e5b19f1c7ca21850426c33f ]
gred_change_vq() is called under sch_tree_lock(sch).
This means a spinlock is held, and we are not allowed to sleep in this
context.
We might pre-allocate memory using GFP_KERNEL before taking spinlock,
but this is not suitable for stable material.
[ Upstream commit cd7816d14953c8af910af5bb92f488b0b277e29d ]
previous commit 3fb72f1e6e6165c5f495e8dc11c5bbd14c73385c
makes IP-Config wait for carrier on at least one network device.
Before waiting (predefined value 120s), check that at least one device
was successfully brought up. Otherwise (e.g. buggy bootloader
which does not set the MAC address) there is no point in waiting
for carrier.
Cc: Micha Nelissen <micha@neli.hopto.org>
Cc: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
[ Upstream commit 7838f2ce36b6ab5c13ef20b1857e3bbd567f1759 ]
Userspace may not provide TCA_OPTIONS, in fact tc currently does
so not do so if no arguments are specified on the command line.
Return EINVAL instead of panicing.
[ Upstream commit 9cef310fcdee12b49b8b4c96fd8f611c8873d284 ]
Received non stream protocol packets were calling llc_cmsg_rcv that used a
skb after that skb was released by sk_eat_skb. This caused received STP
packets to generate kernel panics.
Signed-off-by: Alexandru Juncu <ajuncu@ixiacom.com>
Signed-off-by: Kunjan Naik <knaik@ixiacom.com>
[ Upstream commit a454daceb78844a09c08b6e2d8badcb76a5d73b9 ]
Signed-off-by: Djalal Harouni <tixxdz@opendz.org>
[ Upstream commit a03ffcf873fe0f2565386ca8ef832144c42e67fa ]
x86 jump instruction size is 2 or 5 bytes (near/long jump), not 2 or 6
bytes.
In case a conditional jump is followed by a long jump, conditional jump
target is one byte past the start of target instruction.
Signed-off-by: Markus Kötter <nepenthesdev@gmail.com>
[ A combination of upstream commits 1d299bc7732c34d85bd43ac1a8745f5a2fed2078 and
e88d2468718b0789b4c33da2f7e1cef2a1eee279 ]
Although we provide a proper way for a debugger to control whether
syscall restart occurs, we run into problems because orig_i0 is not
saved and restored properly.
Luckily we can solve this problem without having to make debuggers
aware of the issue. Across system calls, several registers are
considered volatile and can be safely clobbered.
Therefore we use the pt_regs save area of one of those registers, %g6,
as a place to save and restore orig_i0.
Debuggers transparently will do the right thing because they save and
restore this register already.
[ Upstream commit 2e8ecdc008a16b9a6c4b9628bb64d0d1c05f9f92 ]
[ Upstream commit a52312b88c8103e965979a79a07f6b34af82ca4b ]
Properly return the original destination buffer pointer.
Tested-by: Kjetil Oftedal <oftedal@gmail.com>
[ Upstream commit 21f74d361dfd6a7d0e47574e315f780d8172084a ]
This is setting things up so that we can correct the return
value, so that it properly returns the original destination
buffer pointer.
[ Upstream commit 045b7de9ca0cf09f1adc3efa467f668b89238390 ]
[ Upstream commit 3e37fd3153ac95088a74f5e7c569f7567e9f993a ]
To handle the large physical addresses, just make a simple wrapper
around remap_pfn_range() like MIPS does.
[ Upstream commit 0b64120cceb86e93cb1bda0dc055f13016646907 ]
Some of the sun4v code patching occurs in inline functions visible
to, and usable by, modules.
Therefore we have to patch them up during module load.
[ Upstream commit b1f44e13a525d2ffb7d5afe2273b7169d6f2222e ]
The "(insn & 0x01800000) != 0x01800000" test matches 'restore'
but that is a legitimate place to see the %lo() part of a 32-bit
symbol relocation, particularly in tail calls.
Tested-by: Sergei Trofimovich <slyfox@gentoo.org>
[ Upstream commit 7cc8583372a21d98a23b703ad96cab03180b5030 ]
This silently was working for many years and stopped working on
Niagara-T3 machines.
We need to set the MSIQ to VALID before we can set it's state to IDLE.
On Niagara-T3, setting the state to IDLE first was causing HV_EINVAL
errors. The hypervisor documentation says, rather ambiguously, that
the MSIQ must be "initialized" before one can set the state.
I previously understood this to mean merely that a successful setconf()
operation has been performed on the MSIQ, which we have done at this
point. But it seems to also mean that it has been set VALID too.
Upstrem commit: 911ae9434f83e7355d343f6c2be3ef5b00ea7aed
There's a bug in the MSIX backup and restore routines that cause a crash on
non-x86 (direct access to PCI space not via read/write). These routines are
unnecessary and were removed by the above commit, so also remove them from
stable to fix the crash.
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit e26a51148f3ebd859bca8bf2e0f212839b447f62 upstream.
commit 8aacc9f550 ("mm/mempolicy.c: fix pgoff in mbind vma merge") is the
slightly incorrect fix.
Why? Think following case.
1. map 4 pages of a file at offset 0
[0123]
2. map 2 pages just after the first mapping of the same file but with
page offset 2
[0123][23]
3. mbind() 2 pages from the first mapping at offset 2.
mbind_range() should treat new vma is,
[0123][23]
|23|
mbind vma
but it does
[0123][23]
|01|
mbind vma
Oops. then, it makes wrong vma merge and splitting ([01][0123] or similar).
This patch fixes it.
[testcase]
test result - before the patch
case4: 126: test failed. expect '2,4', actual '2,2,2'
case5: passed
case6: passed
case7: passed
case8: passed
case_n: 246: test failed. expect '4,2', actual '1,4'
kernel BUG at mm/filemap.c:135!
invalid opcode: 0000 [#4] SMP DEBUG_PAGEALLOC
(snip long bug on messages)
test result - after the patch
case4: passed
case5: passed
case6: passed
case7: passed
case8: passed
case_n: passed
source: mbind_vma_test.c
#include <numaif.h>
#include <numa.h>
#include <sys/mman.h>
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <string.h>
static unsigned long pagesize;
void* mmap_addr;
struct bitmask *nmask;
char buf[1024];
FILE *file;
char retbuf[10240] = "";
int mapped_fd;
char *rubysrc = "ruby -e '\
pid = %d; \
vstart = 0x%llx; \
vend = 0x%llx; \
s = `pmap -q #{pid}`; \
rary = []; \
s.each_line {|line|; \
ary=line.split(\" \"); \
addr = ary[0].to_i(16); \
if(vstart <= addr && addr < vend) then \
rary.push(ary[1].to_i()/4); \
end; \
print rary.join(\",\"); \
void init(void)
void* addr;
char buf[128];
nmask = numa_allocate_nodemask();
numa_bitmask_setbit(nmask, 0);
pagesize = getpagesize();
sprintf(buf, "%s", "mbind_vma_XXXXXX");
mapped_fd = mkstemp(buf);
if (mapped_fd == -1)
perror("mkstemp "), exit(1);
unlink(buf);
if (lseek(mapped_fd, pagesize*8, SEEK_SET) < 0)
perror("lseek "), exit(1);
if (write(mapped_fd, "\0", 1) < 0)
perror("write "), exit(1);
addr = mmap(NULL, pagesize*8, PROT_NONE,
MAP_SHARED, mapped_fd, 0);
if (addr == MAP_FAILED)
perror("mmap "), exit(1);
if (mprotect(addr+pagesize, pagesize*6, PROT_READ|PROT_WRITE) < 0)
perror("mprotect "), exit(1);
mmap_addr = addr + pagesize;
/* make page populate */
memset(mmap_addr, 0, pagesize*6);
void fin(void)
void* addr = mmap_addr - pagesize;
munmap(addr, pagesize*8);
memset(buf, 0, sizeof(buf));
memset(retbuf, 0, sizeof(retbuf));
void mem_bind(int index, int len)
int err;
err = mbind(mmap_addr+pagesize*index, pagesize*len,
MPOL_BIND, nmask->maskp, nmask->size, 0);
if (err)
perror("mbind "), exit(err);
void mem_interleave(int index, int len)
int err;
MPOL_INTERLEAVE, nmask->maskp, nmask->size, 0);
if (err)
void mem_unbind(int index, int len)
int err;
MPOL_DEFAULT, NULL, 0, 0);
if (err)
void Assert(char *expected, char *value, char *name, int line)
if (strcmp(expected, value) == 0) {
fprintf(stderr, "%s: passed\n", name);
return;
else {
fprintf(stderr, "%s: %d: test failed. expect '%s', actual '%s'\n",
name, line,
expected, value);
// exit(1);
AAAA
PPPPPPNNNNNN
might become
PPNNNNNNNNNN
case 4 below
void case4(void)
init();
sprintf(buf, rubysrc, getpid(), mmap_addr, mmap_addr+pagesize*6);
mem_bind(0, 4);
mem_unbind(2, 2);
file = popen(buf, "r");
fread(retbuf, sizeof(retbuf), 1, file);
Assert("2,4", retbuf, "case4", __LINE__);
fin();
AAAA
PPPPPPNNNNNN
might become
PPPPPPPPPPNN
case 5 below
void case5(void)
init();
mem_bind(0, 2);
mem_bind(2, 2);
Assert("4,2", retbuf, "case5", __LINE__);
fin();
AAAA
PPPPNNNNXXXX
might become
PPPPPPPPPPPP 6
void case6(void)
init();
mem_bind(0, 2);
mem_bind(4, 2);
mem_bind(2, 2);
Assert("6", retbuf, "case6", __LINE__);
fin();
AAAA
PPPPNNNNXXXX
might become
PPPPPPPPXXXX 7
void case7(void)
init();
mem_bind(0, 2);
mem_interleave(4, 2);
mem_bind(2, 2);
Assert("4,2", retbuf, "case7", __LINE__);
fin();
AAAA
PPPPNNNNXXXX
might become
PPPPNNNNNNNN 8
void case8(void)
init();
mem_bind(0, 2);
mem_interleave(2, 2);
Assert("2,4", retbuf, "case8", __LINE__);
fin();
void case_n(void)
init();
/* make redundunt mappings [0][1234][34][7] */
mmap(mmap_addr + pagesize*4, pagesize*2, PROT_READ|PROT_WRITE,
MAP_FIXED|MAP_SHARED, mapped_fd, pagesize*3);
/* Expect to do nothing. */
mem_unbind(2, 2);
Assert("4,2", retbuf, "case_n", __LINE__);
fin();
int main(int argc, char** argv)
case4();
case5();
case6();
case7();
case8();
case_n();
return 0;
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Caspar Zhang <caspar@casparzhang.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
commit b0365c8d0cb6e79eb5f21418ae61ab511f31b575 upstream.
If a huge page is enqueued under the protection of hugetlb_lock, then the
operation is atomic and safe.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 77e00f2ea94abee1ad13bdfde19cf7aa25992b0e upstream.
We already do this for cayman, need to also do it for
BTC parts. The default memory and voltage setup is not
adequate for advanced operation. Continuing will
result in an unusable display.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: Jean Delvare <khali@linux-fr.org>
commit e67d668e147c3b4fec638c9e0ace04319f5ceccd upstream.
This patch makes use of the set_memory_x() kernel API in order
to make necessary BIOS calls to source NMIs.
This is needed for SLES11 SP2 and the latest upstream kernel as it appears
the NX Execute Disable has grown in its control.
Signed-off by: Thomas Mingarelli <thomas.mingarelli@hp.com>
Signed-off by: Wim Van Sebroeck <wim@iguana.be>
commit e6780f7243eddb133cc20ec37fa69317c218b709 upstream.
It was found (by Sasha) that if you use a futex located in the gate
area we get stuck in an uninterruptible infinite loop, much like the
ZERO_PAGE issue.
While looking at this problem, PeterZ realized you'll get into similar
trouble when hitting any install_special_pages() mapping. And are there
still drivers setting up their own special mmaps without page->mapping,
and without special VM or pte flags to make get_user_pages fail?
In most cases, if page->mapping is NULL, we do not need to retry at all:
Linus points out that even /proc/sys/vm/drop_caches poses no problem,
because it ends up using remove_mapping(), which takes care not to
interfere when the page reference count is raised.
But there is still one case which does need a retry: if memory pressure
called shmem_writepage in between get_user_pages_fast dropping page
table lock and our acquiring page lock, then the page gets switched from
filecache to swapcache (and ->mapping set to NULL) whatever the refcount.
Fault it back in to get the page->mapping needed for key->shared.inode.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
commit 55205c916e179e09773d98d290334d319f45ac6b upstream.
This change fixes a linking problem, which happens if oprofile
is selected to be compiled as built-in:
`oprofile_arch_exit' referenced in section `.init.text' of
arch/arm/oprofile/built-in.o: defined in discarded section
`.exit.text' of arch/arm/oprofile/built-in.o
The problem is appeared after commit 87121ca504, which
introduced oprofile_arch_exit() calls from __init function. Note
that the aforementioned commit has been backported to stable
branches, and the problem is known to be reproduced at least
with 3.0.13 and 3.1.5 kernels.
Signed-off-by: Vladimir Zapolskiy <vladimir.zapolskiy@nokia.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: oprofile-list <oprofile-list@lists.sourceforge.net>
Link: http://lkml.kernel.org/r/20111222151540.GB16765@erda.amd.com
commit 3b6e3c73851a9a4b0e6ed9d378206341dd65e8a5 upstream.
When getting a cmd irq during an ongoing data transfer
with dma, the dma job were never terminated. This is now
corrected.
Tested-by: Linus Walleij <linus.walleij@linaro.org>
Signed-off-by: Per Forlin <per.forlin@stericsson.com>
Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com>
commit b63038d6f4ca5d1849ce01d9fc5bb9cb426dec73 upstream.
The interrupt was previously enabled and then correctly cleared.
Now we also handle it correctly.
commit 5776ac2eb33164c77cdb4d2b48feee15616eaba3 upstream.
According to imx pwm RM, the real period value should be
PERIOD value in PWMPR plus 2.
PWMO (Hz) = PCLK(Hz) / (period +2)
Signed-off-by: Jason Chen <jason.chen@linaro.org>
commit e30e2fdfe56288576ee9e04dbb06b4bd5f282203 upstream.
Currently, the *_global_[un]lock_online() routines are not at all synchronized
with CPU hotplug. Soft-lockups detected as a consequence of this race was
reported earlier at https://lkml.org/lkml/2011/8/24/185. (Thanks to Cong Meng
for finding out that the root-cause of this issue is the race condition
between br_write_[un]lock() and CPU hotplug, which results in the lock states
getting messed up).
Fixing this race by just adding {get,put}_online_cpus() at appropriate places
in *_global_[un]lock_online() is not a good option, because, then suddenly
br_write_[un]lock() would become blocking, whereas they have been kept as
non-blocking all this time, and we would want to keep them that way.
So, overall, we want to ensure 3 things:
1. br_write_lock() and br_write_unlock() must remain as non-blocking.
2. The corresponding lock and unlock of the per-cpu spinlocks must not happen
for different sets of CPUs.
3. Either prevent any new CPU online operation in between this lock-unlock, or
ensure that the newly onlined CPU does not proceed with its corresponding
per-cpu spinlock unlocked.
To achieve all this:
(a) We introduce a new spinlock that is taken by the *_global_lock_online()
routine and released by the *_global_unlock_online() routine.
(b) We register a callback for CPU hotplug notifications, and this callback
takes the same spinlock as above.
(c) We maintain a bitmap which is close to the cpu_online_mask, and once it is
initialized in the lock_init() code, all future updates to it are done in
the callback, under the above spinlock.
(d) The above bitmap is used (instead of cpu_online_mask) while locking and
unlocking the per-cpu locks.
The callback takes the spinlock upon the CPU_UP_PREPARE event. So, if the
br_write_lock-unlock sequence is in progress, the callback keeps spinning,
thus preventing the CPU online operation till the lock-unlock sequence is
complete. This takes care of requirement (3).
The bitmap that we maintain remains unmodified throughout the lock-unlock
sequence, since all updates to it are managed by the callback, which takes
the same spinlock as the one taken by the lock code and released only by the
unlock routine. Combining this with (d) above, satisfies requirement (2).
Overall, since we use a spinlock (mentioned in (a)) to prevent CPU hotplug
operations from racing with br_write_lock-unlock, requirement (1) is also
taken care of.
By the way, it is to be noted that a CPU offline operation can actually run
in parallel with our lock-unlock sequence, because our callback doesn't react
to notifications earlier than CPU_DEAD (in order to maintain our bitmap
properly). And this means, since we use our own bitmap (which is stale, on
purpose) during the lock-unlock sequence, we could end up unlocking the
per-cpu lock of an offline CPU (because we had locked it earlier, when the
CPU was online), in order to satisfy requirement (2). But this is harmless,
though it looks a bit awkward.
Debugged-by: Cong Meng <mc@linux.vnet.ibm.com>
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit a41c58a6665cc995e237303b05db42100b71b65e upstream.
If the request is to create non-root group and we fail to meet it, we
should leave the root unchanged.
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Balbir Singh <bsingharora@gmail.com>
commit 78feb35b8161acd95c33a703ed6ab6f554d29387 upstream.
My previous patch
34a5b4b6af104cf18eb50748509528b9bdbc4036 iwlwifi: do not re-configure
HT40 after associated
Fix the case of HT40 after association on specified AP, but it break the
association for some APs and cause not able to establish connection.
We need to address HT40 before and after addociation.
Reported-by: Andrej Gelenberg <andrej.gelenberg@udo.edu>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Tested-by: Andrej Gelenberg <andrej.gelenberg@udo.edu>
commit 123877b80ed62c3b897c53357b622574c023b642 upstream.
Check the IEEE80211_TX_CTL_ASSIGN_SEQ flag from mac80211, then decide how to
set the TX_CMD_FLG_SEQ_CTL_MSK bit. Setting the wrong bit in BAR frame whill
make the firmware to increment the sequence number which is incorrect and
cause unknown behavior.
commit 10636bc2d60942254bda149827b922c41f4cb4af upstream.
The stations always chooses 1Mbps for all trasmitting frames,
whenever the AP is configured to lock the supported rates.
As the max phy rate is always set with the 4th from highest phy rate,
this assumption might be wrong if we have less than that. Fix that.
Cc: Paul Stewart <pstew@google.com>
Reported-by: Ajay Gummalla <agummalla@google.com>
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
commit f83f71fda27650ae43558633be93652577dbc38c upstream.
With 16-bit RGB565 colour format pixels are stored by the device in memory
in the following order:
| b3 | b2 | b1 | b0 |
| R5 G6 B5 | R5 G6 B5 |
This corresponds to V4L2_PIX_FMT_RGB565 fourcc, not V4L2_PIX_FMT_RGB565X.
This change is required to avoid trouble when setting up video pipeline
with the s5p-tv devices, so the colour formats at both devices can be
properly matched.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
commit e6f67b8c05f5e129e126f4409ddac6f25f58ffcb upstream.
lockdep reports a deadlock in jfs because a special inode's rw semaphore
is taken recursively. The mapping's gfp mask is GFP_NOFS, but is not
used when __read_cache_page() calls add_to_page_cache_lru().
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
commit 8653be1afd60d6e8c36139b487e375b70357d9ef upstream.
Check inuse variable before trying to access twl_map to prevent
dereferencing of uninitialized variable.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
commit e0197aae59e55c06db172bfbe1a1cdb8c0e1cab3 upstream.
There is a BUG when migrating a PF_EXITING proc. Since css_set_prefetch()
is not called for the PF_EXITING case, find_existing_css_set() will return
NULL inside cgroup_task_migrate() causing a BUG.
This bug is easy to reproduce. Create a zombie and echo its pid to
cgroup.procs.
$ cat zombie.c
\#include <unistd.h>
int main()
if (fork())
pause();
return 0;
We are hitting this bug pretty regularly on ChromeOS.
This bug is already fixed by Tejun Heo's cgroup patchset which is
targetted for the next merge window:
https://lkml.org/lkml/2011/11/1/356
I've create a smaller patch here which just fixes this bug so that a
fix can be merged into the current release and stable.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Downstream-Bug-Report: http://crosbug.com/23953
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: containers@lists.linux-foundation.org
Cc: cgroups@vger.kernel.org
Cc: Paul Menage <paul@paulmenage.org>
Cc: Olof Johansson <olofj@chromium.org>
commit 61074287c2965edf0fc75b54ae8f4ce99f182669 upstream.
You didn't mean this to be a bool.
Acked-by: Tony Olech <tony.olech@elandigitalsystems.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
commit 695c60f21c69e525a89279a5f35bae4ff237afbc upstream.
commit 828b1c50ae ("nilfs2: add compat ioctl") incidentally broke all
other NILFS compat ioctls. Make them work again.
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit d1ee8878a142f81ea1b40d602c6360b752829437 upstream.
This patch is against the mainline v3.1 release (c3b92c8) and
fixes a compile error when building for OMAP3+DSS+VOUT
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Gary Thomas <gary@mlbassoc.com>
commit 50345f1ea9cda4618d9c26e590a97ecd4bc7ac75 upstream.
Fix the following bug in sel_netport_insert() where rcu_dereference() should
be rcu_dereference_protected() as sel_netport_lock is held.
[ INFO: suspicious rcu_dereference_check() usage. ]
security/selinux/netport.c:127 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 0
1 lock held by ossec-rootcheck/3323:
#0: (sel_netport_lock){+.....}, at: [<ffffffff8117d775>] sel_netport_sid+0xbb/0x226
stack backtrace:
Pid: 3323, comm: ossec-rootcheck Not tainted 3.1.0-rc8-fsdevel+ #1095
Call Trace:
[<ffffffff8105cfb7>] lockdep_rcu_dereference+0xa7/0xb0
[<ffffffff8117d871>] sel_netport_sid+0x1b7/0x226
[<ffffffff8117d6ba>] ? sel_netport_avc_callback+0xbc/0xbc
[<ffffffff8117556c>] selinux_socket_bind+0x115/0x230
[<ffffffff810a5388>] ? might_fault+0x4e/0x9e
[<ffffffff810a53d1>] ? might_fault+0x97/0x9e
[<ffffffff81171cf4>] security_socket_bind+0x11/0x13
[<ffffffff812ba967>] sys_bind+0x56/0x95
[<ffffffff81380dac>] ? sysret_check+0x27/0x62
[<ffffffff8105b767>] ? trace_hardirqs_on_caller+0x11e/0x155
[<ffffffff81076fcd>] ? audit_syscall_entry+0x17b/0x1ae
[<ffffffff811b5eae>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff81380d7b>] system_call_fastpath+0x16/0x1b
Acked-by: Paul Moore <paul@paul-moore.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit 111d489f0fb431f4ae85d96851fbf8d3248c09d8 upstream.
Currently, the code assumes that the SEQUENCE status bits are mutually
exclusive. They are not...
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 6c52961743f38747401b47127b82159ab6d8a7a4 upstream.
After commit 06222e491e663dac939f04b125c9dc52126a75c4 (fs: handle
SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek)
the behaviour of llseek() was changed so that it always revalidates
the file size. The bug appears to be due to a logic error in the
afore-mentioned commit, which always evaluates to 'true'.
Reported-by: Roel Kluin <roel.kluin@gmail.com>
commit c25573b5134294c0be82bfaecc6d08136835b271 upstream.
Whenever we free a slot, we know that the resulting xprt->num_reqs will
be less than xprt->max_reqs, so we know that we can release at least one
backlogged rpc_task.
commit 913050b91eb94f194392dd797b1ff3779f606ac0 upstream.
If oprofilefs_ulong_from_user() is called with count equals
zero, *val remains unchanged. Depending on the implementation it
might be uninitialized.
Change oprofilefs_ulong_from_user()'s interface to return count
on success. Thus, we are able to return early if count equals
zero which avoids using *val uninitialized. Fixing all users of
oprofilefs_ulong_ from_user().
This follows write syscall implementation when count is zero:
"If count is zero ... [and if] no errors are detected, 0 will be
returned without causing any other effect." (man 2 write)
Reported-By: Mike Waychison <mikew@google.com>
Link: http://lkml.kernel.org/r/20111219153830.GH16765@erda.amd.com
