Move EXPORT_SYMBOL() to adjacent to each exported function/variable.
Move EXPORT_SYMBOL()s to places adjacent to functions/variables.
Clean up ugly hacks for sync with alsa-lib in pcm_params.h.
Appended is my patch adding PM support to the cs5535audio driver.
I also added the ac97 quirk but it's not yet confirmed which
boards need to be in the quirk list. The patch also includes some
Kconfig and misc cleanup.
Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com>
Added the model entry for Sony Vaio VGN-A790 laptop with ALC260 codec.
Patch provides for the ice1712 card driver to overwrite the midi port name
string given by default in mpu401_uart, with one specified in
snd_ice1712_card_info.
Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk>
Change snd_seq_midisynth_register_port() in seq_midi.c so that if a new client
is created, the client name string is based on card->shortname not
(port-specific) info->name.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Fixed a typo of 'pci_subsystem' in the last changeset.
Added the support for Thinkpad X60/T60/Z60 laptops with AD1981HD codec.
This second one unregisters the platform device again when the probe is
unsuccesful for sound/drivers, sound/arm/sa11xx-uda1341.c and
sound/ppc/powermac.c. This gets them all.
Signed-off-by: Rene Herman <rene.herman@keyaccess.nl>
Fix a typo of return value from vxpocket_config().
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
Fixed bug#1331
* git://oss.sgi.com:8090/xfs-2.6: (43 commits)
[XFS] Remove files from the build that are now unused.
[XFS] Fix a Makefile issue related to exports.o handling.
[XFS] Remove version 1 directory code. Never functioned on Linux, just
[XFS] Map EFSCORRUPTED to an actual error code, not just a made up one
[XFS] Kill direct access to ->count in valusema(); all we ever use it for
[XFS] Remove unneeded conditional code on NFS export interface related
[XFS] Remove an incorrect use of unlikely() on a relatively likely code
[XFS] Push some common code out of write path into core XFS code for
[XFS] Remove unnecessary local from open_exec dmapi path.
[XFS] Minor XFS documentation updates.
[XFS] Fix broken const use inside local suffix_strtoul routine.
[XFS] Fix nused counter. It's currently getting set to -1 rather than
[XFS] Fix mismerge of the fs_writable cleanup patch causing a freeze/thaw
[XFS] Fix up debug code so that bulkstat wont generate thousands of
[XFS] Remove unused parameter from di2xflags routine.
[XFS] Cleanup a missed porting conversion, and freezing.
[XFS] Resolve a namespace collision on remaining vtypes for FreeBSD
[XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters.
[XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters.
[XFS] statvfs component of directory/project quota support, code
Now /sys/class/usb is dynamically created when we have something to put
in it, and removed when all devices go away.
Just trying to cut down on the clutter in sysfs...
This moves the usb class devices that control the usbfs nodes to show up
in the proper place in the larger device tree.
No userspace changes is needed, this is compatible due to the symlinks
generated by the driver core.
Cc: Kay Sievers <kay.sievers@vrfy.org>
This will allow for us to give endpoints a major/minor to create a
"usbfs2-like" way to access endpoints directly from userspace in an
easier manner than the current usbfs provides us.
Instead of a kobject, will make things easier in the future (don't know
what I was thinking when I did this originally...)
This makes it easier to modify in the future without touching anything else.
Move <linux/usb_input.h> to <linux/usb/input.h> and remove some
redundant includes.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This moves header files for controller-specific platform data
from <linux/usb_XXX.h> to <linux/usb/XXX.h> to start reducing
some clutter.
This moves <linux/usb_cdc.h> to <linux/usb/cdc.h> to reduce some of the
clutter of usb header files.
This removes extraneous whitespace from the Ethernet/RNDIS gadget driver.
It's all space-at-EOL, spaces-before-tabs, or tabs-then-spaces.
Here is a patch (as720) adding an unusual_devs entry for the Nokia N80
mobile phone.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Some usbserial functions returns -EINVAL if the port doesn't exist or if
it's not opened. However, the right error code for such situations is
-ENODEV.
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
This patch adds IXP465 into the list of known devices and
adds IXP425 and IXP465 to the list of devices that have cfr. This
is not described in the hardware documentation, but without
it driver won't work.
Workaround (#if 1) that seemed to get rid of lost
status irqs is disabled for IXP4XX as it caused freezes
during testing of control messages. No lost irqs are
visible on IXP4XX.
Driver survived tests running over night without any
visible problems.
Signed-off-by: Milan Svoboda <msvoboda@ra.rockwell.com>
This patch fixes compile errors when pxa2xx_udc is to be compiled
for ixp4xx platform.
This patch removes limitation which prevents use of drivers that support
speeds different that full speed.
As pointed out by David Brownell, we know that IRQs are never
blocked when calling gs_close function. So the save/restore
IRQ flags are pointless.
Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com>
When closing the device, the driver acquires/release twice the
port lock before/after waiting for the data to be completely
sent. Therefore it will dead lock.
This patch fixes it and also uses the generic scheduler services
for waiting for an event.
If either the driver's open() method or try_module_get() fails, we need to
set 'tty->driver_data' and 'port->tty' to NULL in serial_open(), otherwise
we'll get an OOPS in usb_device_disconnect() when the device is disconnected.
Signed-off-by: Frank Gevaerts <frank.gevaerts@fks.be>
Acked-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
Acked-by: David Brownell <david-b@pacbell.net>
This is a new driver for the Cypress CY7C63xxx mirco controller series.
It currently supports the pre-programmed CYC63001A-PC by AK Modul-Bus
GmbH. It's based on a kernel 2.4 driver (cyport) by Marcus Maul which I
ported to kernel 2.6 using sysfs. I intend to support more controllers
of this family (and more features) as soon as I get hold of the required
IDs etc. Please see the source code's header for more information.
Signed-off-by: Oliver Bock <o.bock@fh-wolfenbuettel.de>
Fix up the documentation. Apparently, I left unedited copy-paste results
in examples. Also, Alan helped me to improve the most confusing parts.
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
Implement the "error" event in usbmon.
This update contains one bug fix: some lines can come out truncated,
because of the safety cutoff. This happened because I forgot to update
the size when status packets began to be printed.
The rest is:
- Comments updates
- Allow snooping with pkmap on x86_64, which is cache-coherent
- Enlarge event buffers (certainly we can have a couple of pages)
- Add event counter
First touch upon usbmon for 2.6.18.
Al Borchers suggested to do this in his review of my previous patch.
I guess that I skipped this initially because of my visceral dislike
of sizeof(data). But in this case it seems well localized.
Adds vendor & product IDs to drivers/usb/serial/airprime.c for Kyocera
Wireless KPC650/Passport EV-DO/1xRTT PC Cards.
Signed-off-by: Timothy Sipples <Timothy.Sipples@us.ibm.com>
This patch (as707) improves the FSBR operation in uhci-hcd by turning it
off more quickly when it isn't needed. FSBR puts a noticeable load on a
computer's PCI bus, so it should be disabled as soon as possible when it
isn't in use. The patch leaves it running for only 10 ms after the last
URB stops using it, on the theory that this should be long enough for a
driver to submit another URB if it wants keep FSBR going.
This patch (as706) removes the private hc_inaccessible flag from
uhci-hcd. It's not needed because it conveys exactly the same
information as the generic HCD_FLAG_HW_ACCESSIBLE bit.
In its place goes a new flag recording whether the controller is dead.
The new code allows a complete device reset to resurrect a dead
controller (although usbcore doesn't yet implement such a facility).
This patch (as705) contains a small set of updates for uhci-hcd written
mostly by Dave Brownell:
* Root hub suspend messages come out labeled as root hub messages;
PCI messages should only come out when the pci device suspends.
* Rename the reset() method to better match its init() role
* Behave more like the other HCDs by returning -ESHUTDOWN for root-hub
suspend/resume errors.
* When an URB fails, associate the message with the usb device not
the host controller (it still hides endpoint and direction)
This patch (as704) adds an unusual_devs entry for the Nikon DSC D70s,
which uses a different Product ID from the D70. It also moves the entry
for the DSC E2000 up in the list, to preserve the numerical ordering.
This adds the Apple MacBook product IDs for the Fn translation
to the usbhid.
Signed-off-by: Rene Rebe <rene@exactcode.de>
