Change the mechanism of enabling the force PWM mode through
regulator set mode. This can be dynamically configured now.
In the REGULATOR_MODE_FAST the force PWM is enabled and in
REGULATOR_MODE_NORMAL the force PWM is disabled.
Cherry-picked from mainline commit 9a00630
Change-Id: I39a77dbe5d0c4c2a5b81dbfe51163a65894bc98c
Reviewed-on: http://git-master/r/105832
Use the pcm-driver specified from platform/board
specified file.
Bug 991926
Change-Id: I9e4c9a3f76bacb22de817273a2281ac9b8959c43
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/105415
Reviewed-by: Bob Johnston <bjohnston@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Scott Peterson <speterson@nvidia.com>
sdio supports 1.8 volts, setting 1.8 volts for
cardhu, kai, ventana, whistler
Bug 979504
Change-Id: I8f03b01e0792ac0e6abe74ce898934e65762fb85
Signed-off-by: naveen kumar arepalli <naveenk@nvidia.com>
Reviewed-on: http://git-master/r/104712
Reviewed-by: Simone Willett <swillett@nvidia.com>
Fix the issue -
When device connects to 2GHz AP, it does not scan
APs in 5GHz and vice-versa.
Bug 968022
Change-Id: I5dfddf4e73260cb1e03bd3d28c029503507cd898
Signed-off-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-on: http://git-master/r/104482
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Due to noise on serial port , we get unwanted SYSRQ events.
Bug 978676
Signed-off-by: Gaurav Sarode <gsarode@nvidia.com>
Change-Id: Ida73f6817c2365b74c7237ae97a9fc006674c34c
Reviewed-on: http://git-master/r/103786
Bug 949219
Change-Id: I91a67d30869e9800c483f112d58b9f76e2dbe361
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/103534
Use sg_next to get next sg
Bug 958431
Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Change-Id: I14aa7c9c551d0230b9c5b681a2699dd5355d0a6d
Reviewed-on: http://git-master/r/98449
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
The RICOH RC5T583 drivers are back ported to downstream from
mainline. Enabling this driver.
Change-Id: I1c956e622aebb705d860e5b50df5a1c82c5d57c3
Reviewed-on: http://git-master/r/105886
The PMIC device RC5T583 from RICOH supports 8 gpios.
Adding gpio driver for this device to access the pins
control through gpio library.
[grant.likely: slight cosmetic changes]
(Cherry-picked from mainline
e9fe32bcadb8a7a40411d77f168abd45941b049b)
Change-Id: Id11f0dec229a92ce0ddcf606376ff83b6e14ca90
Reviewed-on: http://git-master/r/105885
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Fixing build issue reported by Paul Gortmaker:
It appears this breaks linux-next allmodconfig build, because it
uses an uppercase V in the v2 of its MODULE_LICENSE.
FATAL: modpost: GPL-incompatible module rc5t583-regulator.ko uses
GPL-only symbol 'platform_driver_unregister'
make[2]: *** [__modpost] Error 1
(cherry picked from commit 4eb06453648bb0d1eca3669f26798a19b6f40eb8)
Change-Id: I8c715cf5a8e72555721a954d6db6879aed2eb423
Reviewed-on: http://git-master/r/105884
The nsteps can be calculated by (_max_mv - _min_mv) * 1000 / _step_uV + 1,
thus we can remove _nsteps from RC5T583_REG macro, and then remove
nsteps from struct rc5t583_regulator_info.
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
(cherry picked from commit e3a7384c3e98c48b5f122e449e22cc8a1a6c7e0d)
Change-Id: If6db39255b2f7f8be38b848f2ca2619301b19b38
Reviewed-on: http://git-master/r/105883
The valid selector should be 0 ... nsteps-1.
(cherry picked from commit 9cc7a453b637d8c1f628f9873204ff55d7aa664c)
Change-Id: Ie1a39883036de3b2945d35854e0a16c46d2a9db2
Reviewed-on: http://git-master/r/105882
1. regulator_register returns ERR_PTR on error, thus use IS_ERR to check the
return value.
2. Fix off-by-one for unregistering the registered regulator.
Current code does not unregister regs[0].rdev in clean_exit.
(cherry picked from commit a69df8a14ae7b891ee22f0e4c081f3ff65c0640f)
Change-Id: Ib5e00e655020e313c73e5b838e62dbdea54c28d0
Reviewed-on: http://git-master/r/105881
(cherry picked from commit f8dddc0cfe9f56ed74fd5efde8d0754f5fb73a3f)
Change-Id: I72d44f59c79abbbdac95398a5d4da2bedf19d8f1
Reviewed-on: http://git-master/r/105880
Adding the gpio of RC583 in the list of rc583 mfd devices
to register the gpio driver of RC5T583.
(cherry picked from commit e1277f45d8748ff59608b140780f75390cb5400c)
Change-Id: Iea2ccf7831c331d1ad08f96100d4222cce31224f
Reviewed-on: http://git-master/r/105879
The combination of commit 1b1247dd75aa5cf5fae54a3bec7280046e9c7957
"mfd: Add support for RICOH PMIC RC5T583"
and commit 6ffc3270210efa2bea526953a142ffc908f5bd86
"regulator: Add support for RICOH PMIC RC5T583 regulator"
are causing the i386 allmodconfig builds to fail with this:
ERROR: "rc5t583_update" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_set_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_clear_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_read" [drivers/regulator/rc5t583-regulator.ko] undefined!
and this:
ERROR: "rc5t583_ext_power_req_config" [drivers/regulator/rc5t583-regulator.ko] undefined!
For the 1st four, make the simple ops static inline, instead of
polluting the namespace with trivial exports. For the last one,
add an EXPORT_SYMBOL.
(cherry picked from commit 82ea267f7dc853a5e6a724916a70a10656efdfc2)
Change-Id: I7f03cc5c0005883eb8355170cdc7996a9c392091
Reviewed-on: http://git-master/r/105878
The RC5T583 PMIC from RICOH consists of 4 DCDC and 10
LDOs. This driver supports the control of different
regulator output through regulator interface.
This driver depends on MFD driver of RC5T583 and uses
mfd rc5t583 apis to communicate to device for accessing
different device's registers.
(Cherry-picked from mainline commit
6ffc3270210efa2bea526953a142ffc908f5bd86)
Change-Id: If6bcc9c987fc97ff6f0c61e53de715cd84d0151b
Reviewed-on: http://git-master/r/105877
Add config Enable TEGRA_NVAVP_AUDIO to enable
Audio Channel support
bug 964515
Change-Id: Ibc17e650f5a26b348ea9dda329d009c79ba21a49
Signed-off-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-on: http://git-master/r/104382
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Duplicate functions for wakeup support removed.
bug 980993
Change-Id: I1e385a1adec6f2d64ce2c88a59e94d647a16569d
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/105901
To save power turning off/on clocks (controller, emc, sclk)
appropriately depending upon the features supported on
particular controller.
Bug 991262
Bug 993380
Change-Id: I15fd5641c73f6a170a33515b5e9fe0a62c8430cc
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/105887
Register access (read/write) to modules MPE, ISP and VI lack sanity
check for the register number. Add checks to ensure only aperture is
accessed. Also make sure that the check accounts for wrapping of
values of offset and count.
Also fixes the register offset for reads which are done in multiple
blocks.
Bug 992938
Change-Id: I35f30cbd1dda31956286e48c5995b24fd262d1ae
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/105585
Added code to select i2s vs tdm mode.
Added tdm-pcm-audio device defination.
Changed the pcm driver to use tdm-pcm-audio device.
Added fields to pass the pcm driver name to ASoC.
Added P1852_TDM config to KConfig and Linux defconfig
Bug 948478
Change-Id: I82fa03ab947cc615089e0a3107fb53901a1c00cd
Signed-off-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-on: http://git-master/r/105383
Added support for audio channel.
Push buffers can be submitted on audio channel.
bug 964514
Change-Id: Ib13b6ed41678e9dcc170fddc64ab4646f960838b
Reviewed-on: http://git-master/r/97534
Reviewed-by: Gajanan Bhat <gbhat@nvidia.com>
Fix multiple stylistic issue like:
- The print message should be not break into multiple line.
- line gap after variable declaration and statement.
- checkpatch error.
- some typo.
Some enhancement on error message printing to print error value
also along with proper text.
Avoid voltage_base conversion to microvolts every time.
Put init functions in init section.
Using efficient function inplace of calling multiple function
to reduce the code size.
(cherry picked from commit 2935fb18aa1e75e6afaab3303cdd1a4ac62be63e)
Change-Id: I988938f8f8cc6fb5355e32bd6ac25d95db94913c
Reviewed-on: http://git-master/r/105831
Settling time is require when there is voltage output change.
Implement set_voltage_time_sel() callback which returns delay time
for voltage change to settle down to new value.
(cherry picked from commit a60cfce051dd5e22329df1018d278bf3e52d82bc)
Change-Id: I522df8a72595622fd99cc46043c34610434d932f
Reviewed-on: http://git-master/r/105830
Enable cache of device register using regmap cache RBTREE.
(cherry picked from commit 16ea003bd1c95ea55a0b88187ce7cbeaca760fcf)
Change-Id: If747dd18a488d500f8295f903c8da92c241c293e
Reviewed-on: http://git-master/r/105829
(cherry picked from commit 9a4bdd87a29bf297d9046410b011d726d51c3999)
Change-Id: Ic7cca64e14b2b2e812140c8d368279b615da074f
Reviewed-on: http://git-master/r/105828
According to the datasheet[1], tps62360 is register compatible with tps62362.
tps62361B is register compatible with tps62363.
Thus this patch adds support for tps62362 and tps62363.
[1] http://www.ti.com/litv/pdf/slvsau9b
Change-Id: I62cdede0755d7decedeb7b1ef08e216a0dad3a12
(Cherry-picked from mainline commit d1cf4f6)
Change-Id: Ib9c4a63f06182c0ed2c1f27d9bf63342aa8474bc
Reviewed-on: http://git-master/r/105827
The client field of struct tps62360_chip is not used after converting to regmap.
The name field of struct tps62360_chip is not used in this driver.
(cherry picked from mainline commit c60f1718f508a40964c149f1139b4eaaae825fd3)
Change-Id: If7b0606b60bd887bc20ecbdaf5cafa6ccba8ff77
Reviewed-on: http://git-master/r/105826
The variable 'selector' is a 'unsigned int', so it can never be less than zero.
(cherry picked from commit 46783a046e13588f0459271ad6db9785fa8dcb8b)
Change-Id: I920b1628016b7d1c0b626497f24210c5c1f549ab
Reviewed-on: http://git-master/r/105825
Fixing the UTMIP auto suspend issues.
Bug 992463
Bug 989400
Change-Id: Ia0d536cd66081b263f7f2bde5debcc600dcef22a
Reviewed-on: http://git-master/r/105692
changed pad strengths to the values provided
by syseng.
Bug 978870
Change-Id: I23afc8235065ce8ab950dc92dc40e7df5f835989
Signed-off-by: Mohit Kataria <mkataria@nvidia.com>
Reviewed-on: http://git-master/r/105578
Bug 986402
Change-Id: Icf06b136c602639fc84ea822db8cf54078ace5fd
Signed-off-by: Tom Cherry <tcherry@nvidia.com>
Reviewed-on: http://git-master/r/104270
Bug 986402
Change-Id: Id12540e31f8d7d9a04d764ed012310a685eafb8d
Reviewed-on: http://git-master/r/104269
Removed unused wake header file from Tegra board files
bug 980993
Change-Id: I61d919a2dc5b98caaca612b990fd1a7d06e76ae2
Reviewed-on: http://git-master/r/103622
Changed pingroups with proper bit fields
provided in TRM.
Bug 978870
Change-Id: Ie02ff14448103c70e27149ac95cd487d33ab52c0
Reviewed-on: http://git-master/r/103353
Change-Id: Ia6dccfbd0464bc088dfcb05cc16e7f2ad35a9783
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/104291
Add config option to enable/disable cache maintenance by set/ways.
Change-Id: Ie795e19650b2c05cd4789dbc1e8f04f9edc70bf1
Reviewed-on: http://git-master/r/104290
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Reviewed-by: Bo Yan <byan@nvidia.com>
Removing tegra_gpio_enable and disable calls
from board files as they are supported thorugh
set direction calls in the driver
Bug 984439
Change-Id: I4ec51c8eb68c373b7cec6903bf52539cd520b227
Reviewed-on: http://git-master/r/102813
PCIE dock detection is done using GPIO for cardhu
e1291 board. Currently supporting only hotplug
disconnect when all pcie devices will be stopped
and will not work on hotplug connect later.
Bug 912743
Bug 955043
Bug 946385
Change-Id: Ibb2869c12e193be5e6e7e057e149e7699598a061
Signed-off-by: Jay Agarwal <jagarwal@nvidia.com>
Reviewed-on: http://git-master/r/87315
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Disable the interrupts when the baudrate or any uart
configuration. This will avoid the interrupt to be call
when configuration is getting change.
bug 984164
bug 969087
Change-Id: Id008964773237726a0ec4a04c428d3975bf3ebd9
Reviewed-on: http://git-master/r/104476
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-by: David Yu (Engrg-SW) <davyu@nvidia.com>
Tested-by: David Yu (Engrg-SW) <davyu@nvidia.com>
Ensure i2s_client_bits and i2s_audio_bits do not get used
uninitialized.
Bug 949219
Change-Id: Ibdd7f2598278639388d2c2afb5843f2471375ea2
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/105426
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Remove nvhost dsi driver. Real dsi driver is in tegradc.
Bug 982965
Change-Id: I86044ba586d796ae8d049471a154dcf37bd0e6ed
Reviewed-on: http://git-master/r/104975
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Gpio direction setting and freeing functions will do the needful now.
Bug 984440
Change-Id: I598cfbda4ac1d8fe7a61fe070abc92c5179807e9
Reviewed-on: http://git-master/r/104493
On Tegra3 switch and stay on G-CPU if minimum 1 is requested via
PM QoS interface. Allow return to LP-CPU only if request is at
default 0 level.
Change-Id: Ie1a732fe6c6a1dcd2f7e78be01e32dcc5a7993a6
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/102120
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Satya Popuri <spopuri@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Change default PM QoS request value for minimum online cpus
parameter from 1 to 0. This is consistent with all other
PM_QOS_MAX type parameters, and allow to differentiate request
for 1 CPU and "no request".
Change-Id: I548449d0b7a443b77f7f065e1e1f10dffc5587ed
Reviewed-on: http://git-master/r/102119
Convert the jiffies to msecs when assigning a channel the default
timeout.
Change-Id: If9b6fb7c695e9621a0c50d99d4d1362b6dd214b6
Reviewed-on: http://git-master/r/105022
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Bug 964287
1) Add support for resetting the codec while entering in lp0
state to save codec power in lpo for KAI.
2) Fix for cache sync.
3) Add index sync functionality.
Change-Id: I04039eb55944bfe7f06e6a1405ac3c810c5688a1
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/104480
Tested-by: Daniel Solomon <daniels@nvidia.com>
Adding the implementation of null ulpi
baseband ops.
Bug 991485
Change-Id: Ic5ed9b2143650a07528189c80c5b6b8b8a9657c7
Reviewed-on: http://git-master/r/105398
A space is missing between the words 'an' and 'independent'
in the print statement:
dev_info(&info->i2c_client->dev,
"%s no regulator found for %s. "
"This board may not have an"
"independent %s regulator.\n",
__func__, info->vreg[j].vreg_name,
info->vreg[j].vreg_name);
Bug 991768
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Idde809c162b3b32c1db57436273af1810f03000a
Reviewed-on: http://git-master/r/105157
Tested-by: Preetham Chandru <pchandru@nvidia.com>
