Setting vbus_reg to NULL if regulator get
fails.
Bug 1047065
Change-Id: I574f58d46f226d70034a4f363103fd9763482292
Signed-off-by: Petlozu Pravareshwar <petlozup@nvidia.com>
Reviewed-on: http://git-master/r/131759
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Adding the check for vbus before setting the
run bit.
Bug 1046443
Change-Id: If71748f0fe9c942061ca871034ad4298a58efc23
Signed-off-by: Rohith Seelaboyina <rseelaboyina@nvidia.com>
Reviewed-on: http://git-master/r/131733
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
This reverts commit 616ade39df296b2c60d8ce74c719bc560f78f598.
Bug 1046372
Change-Id: I1e8554f773e6af459f50658b683eafb2b0160f64
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/131458
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Sends kobject_uevent signal back to userspace to signal that
the cpufreq governor has been set to interactive
Bug 1039141
Change-Id: I699e9d5834a1874b36c675764c080112ccba0f9f
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/131224
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
When a throughput hint is available, still keep track of the idle time
percentage and use both in gpu scaling. Also modifying fallback
scaling code to use same idle estimate used when a throughput hint is
available. Dropping different time frames for scaling up and down.
Bug 1034948
Bug 965517
Change-Id: Ib3945642768e36a6c0c50f4195c89e3bb67f8442
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/129410
(cherry picked from commit 1e9974097286a78f34367683a3921c9b5bf77d4d)
Reviewed-on: http://git-master/r/131155
As WAR, limit 3d clock frequency and emc clock frequency
when camera is on and chip is AP37. 3d clock is set to
361MHz and 437MHz is requested for emc clock with this
change. This change allows 3d to request 1.1V in Core
instead of 1.3V in AP37.
Bug 1001262
Bug 1019309
Change-Id: I9f46f93d8da0fcf5afe05839177bf0d6e43a5840
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/130945
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
- Set frame duration to 0 in NULL modeset.
bug 1039104
Reviewed-on: http://git-master/r/127603
(cherry picked from commit 604cda21d79ed168e9863f0122eb0c23fa1a901b)
Change-Id: I0be1b96529e40a374e4507ecd3da990677d4cbd4
Signed-off-by: Raghavendra VK <rvk@nvidia.com>
Reviewed-on: http://git-master/r/130943
Commit a76d7bd96d65 ("ARM: 7467/1: mutex: use generic xchg-based
implementation for ARMv6+") removed the barrier-less, ARM-specific
mutex implementation in favour of the generic xchg-based code.
Since then, a bug was uncovered in the xchg code when running on SMP
platforms, due to interactions between the locking paths and the
MUTEX_SPIN_ON_OWNER code. This was fixed in 0bce9c46bf3b ("mutex: place
lock in contended state after fastpath_lock failure"), however, the
atomic_dec-based mutex algorithm is now marginally more efficient for
ARM (~0.5% improvement in hackbench scores on dual A15).
This patch moves ARMv6+ platforms to the atomic_dec-based mutex code.
Change-Id: I8f64e98ccb61cc1cb9cb68ee15e55d8a792792f5
Cc: Nicolas Pitre <nico@fluxnic.net>
Acked-by: Nicolas Pitre <nico@linaro.org>
Reviewed-on: http://git-master/r/130941
The open-coded mutex implementation for ARMv6+ cores suffers from a
severe lack of barriers, so in the uncontended case we don't actually
protect any accesses performed during the critical section.
Furthermore, the code is largely a duplication of the ARMv6+ atomic_dec
code but optimised to remove a branch instruction, as the mutex fastpath
was previously inlined. Now that this is executed out-of-line, we can
reuse the atomic access code for the locking (in fact, we use the xchg
code as this produces shorter critical sections).
This patch uses the generic xchg based implementation for mutexes on
ARMv6+, which introduces barriers to the lock/unlock operations and also
has the benefit of removing a fair amount of inline assembly code.
Change-Id: I58e3ca4d2740a834d30b54fc35742fa2df7792ad
Cc: <stable@vger.kernel.org> : 0bce9c46: mutex: Place lock in contended...
Reported-by: Shan Kang <kangshan0910@gmail.com>
Reviewed-on: http://git-master/r/130940
When reading alarm of RTC-max77663, it didn't set alrm->enabled correctly,
if irq is masked, means disable alarm, alrm->enabled should be set to 0,
else it should be 1.
Change-Id: Id0b1ffd9a816643712f33624d7d52cbe7b66b3c3
Signed-off-by: Daniel Fu <danifu@nvidia.com>
Reviewed-on: http://git-master/r/129593
Reviewed-by: Simone Willett <swillett@nvidia.com>
phy post_resume is called when usb port+hub is resumed,
check if modem has finished resume by then. Notify modem
about post resume by setting bb_wake to low.
Modify check for CP initiated wakeup to read current
modem state (ap_wake).
Bug 1034420
Change-Id: Ie9a3aa581bd7660183464e3fc2554ceb055b69b2
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/129533
Tegra 3 version: TF_TEGRA3_AB01.16.37161
Improvements in maintenance operations of L2 Cache Controlller.
Change-Id: Iddbd61b21b6d83548d5a8c636e26b07b3b4f1385
Signed-off-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Reviewed-on: http://git-master/r/128948
Reviewed-by: James Zhao <jamesz@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Reviewed-by: Wen Yi <wyi@nvidia.com>
This is an alternate way to have the L2 disabled available with
later TL secureos versions.
In this version, the sleep CPU SMC which is the last one issued
before entering LP2 on CPU0, will also disable the L2 without a
flush of the secureos workspace.
Change-Id: I61c3caade6cb6f922b9d9f9ca0739bc6ae4e78cd
Reviewed-on: http://git-master/r/128951
Bug 990784
Change-Id: I173df3f7244e7d0b40ae5aad98c72885ff42fdab
Signed-off-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-on: http://git-master/r/129103
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
NFC use GPIO4 for download firmware
BT_RST is required to make bluetooth on/off
Bug 1002637
Change-Id: Ic49a3fe606de618dfafdf0bc35b6a6fc1ac12cdd
Reviewed-on: http://git-master/r/128612
bug 947148
Change-Id: Icc9711e44375dee9346cbe2cb8af090286a244a2
Signed-off-by: Kerwin Wan <kerwinw@nvidia.com>
Reviewed-on: http://git-master/r/126834
(cherry picked from commit 90ec2d7e47927723f8c088c178bb560828fac622)
Reviewed-on: http://git-master/r/129571
GVS: Gerrit_Virtual_Submit
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
This patch fixes wait base handling in CDMA timeouts.
Bug 1025617
Change-Id: Ia93e55631c1159da161d5c4f257d3beebf0d3149
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-on: http://git-master/r/129278
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
If usb device already connected, should disable WKCN
in USB2D_PORTSC1, and enable WKDS in USB2D_PORTSC1,
during utmi phy power off. All the wakeup resource
should be cleared after the event happened.
Bug 1020021
Bug 1028429
Change-Id: I807ca76d4392318adf6adb808cb2bf290cd0d60c
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/128547
Set default mode for probe and resume to enable initialization of dc.1
Skipping this initialization results in hard system hang.
bug 1030415
Reviewed-on: http://git-master/r/124001
(cherry picked from commit 50fa5e50b74a0534d7524fb6d7dcaa65b2e6e74c)
Change-Id: Id9ad95e114a27c1667f0286443534a23b7fa64d4
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/128533
Set default videomode happens during probe and resume. _tegra_dc_enable
is also called during hotplug, setting default videomode there causes
hdcp test failure.
Bug 991805
Reviewed-on: http://git-master/r/121052
(cherry picked from commit 7d4e0461a88b8cf638963e69829274824fecc38b)
Change-Id: I98be07e883699ba9fa6e222bb1d8ea68d199dfc6
Reviewed-on: http://git-master/r/128532
The wday is configured only when disabled alarm.
When enable alarm, set it to its default reset value 0x01,
and not enable it, to prevent an error happened when re-read the
alarm value into the virtualized generic layer at boot up in
reading alarm setting of RTC.
Bug 1034871
Change-Id: I8bfa997653edaaa286cf768c1827b5ab986f52cc
Reviewed-on: http://git-master/r/129398
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
Update the power sequence to match the specification
Bug 1031318
Reviewed-on: http://git-master/r/124496
(cherry picked from commit d2b1e1ddb2e65482eb15698b925471daf573a7ba)
Change-Id: I837cafb494571816ee6ef25ea8159fc0de9fb2f5
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/128945
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock before unlink, but may
cause skb traversing races:
- after URB is unlinked and the queue lock is released,
the refered skb and skb->next may be moved to done queue,
even be released
- in skb_queue_walk_safe, the next skb is still obtained
by next pointer of the last skb
- so maybe trigger oops or other problems
This patch extends the usage of entry->state to describe 'start_unlink'
state, so always holding the queue(rx/tx) lock to change the state if
the referd skb is in rx or tx queue because we need to know if the
refered urb has been started unlinking in unlink_urbs.
The other part of this patch is based on Huajun's patch:
always traverse from head of the tx/rx queue to get skb which is
to be unlinked but not been started unlinking.
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: Oliver Neukum <oneukum@suse.de>
Cc: stable@kernel.org
(cherry picked from commit 5b6e9bcdeb65634b4ad604eb4536404bbfc62cfa)
Bug 1040642
Change-Id: I1a8c248016529bebf71d540738ad4726cf3f59b7
Signed-off-by: Steve Lin <stlin@nvidia.com>
Reviewed-on: http://git-master/r/128693
Add support for setting of DMA address through alsa control for AVP
rendering. This is required to directly do DMA from IRAM to I2S.
Bug 1024403
Change-Id: I6b79ae6e9a562160a19d238b817e1a8b407ac208
Reviewed-on: http://git-master/r/127436
(cherry picked from commit f270f46bef98a56f44432e608041adb617c22559)
Signed-off-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Change-Id: I195aae9043f967273283579f44d5367fe73d542f
Reviewed-on: http://git-master/r/129159
Reviewed-by: Scott Peterson <speterson@nvidia.com>
It has now become necessary to use a DAPM mutex instead of the codec
mutex to lock the DAPM operations. This is due to the recent multi
component support and forth coming Dynamic PCM updates.
Currently we lock DAPM operations with the codec mutex of the calling
RTD context. However, DAPM operations can span the whole card context
and all components.
This patch updates the DAPM operations that use the codec mutex to
now use the DAPM mutex PCM subclass for all DAPM ops.
We also add a mutex subclass for DAPM init and PCM operations.
Signed-off-by: Liam Girdwood <lrg@ti.com>
(cherry picked from commit a73fb2df01866b772a48fab93401fe3edbe0b38d)
Updated call sequences
Bug 1039523
Change-Id: If079bbe5032971251d6b5426c752cbcc6ad6bcf5
Reviewed-on: http://git-master/r/128937
enable slave mode for cardhu platform.
BUG 998682
Change-Id: Iad330677154af417e0848059536581bcabdd98bc
Reviewed-on: http://git-master/r/128734
Add wait for vsync support for one-shot panels. The code supports extension
of this feature to other panels.
Bug 1033411.
Change-Id: Ie4d6cb45e5de81083458169ccdfa33230235ed72
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/128927
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
Bug: 1039342
Reviewed-on: http://git-master/r/127868
(cherry picked from commit 92f2d2099e3411dfa1966e8ead58dc5654f3124c)
Change-Id: Ibe7dd39a06170766ec043ccbf18df0078ee9e7cb
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/128508
Reviewed-by: Niranjan Wartikar <nwartikar@nvidia.com>
Add stub runtime_pm calls which go through the flow of enabling and
disabling but don't actually do anything with the device itself as
there's nothing useful we can do. This provides the core PM framework
with information about when the device is idle, enabling chip wide
power savings.
Change-Id: Ie795c16840ccbe07e1a8bfac1a1c5a87281e6849
Reviewed-on: http://git-master/r/128184
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
power savings.
The change is based on change done by Mark Brown for s3c2410 i2c bus
driver.
Author: Mark Brown <broonie@opensource.wolfsonmicro.com>
i2c-s3c2410: Add stub runtime power management
Change-Id: Icb92129c4f79a1642b2b73d14578b05928d745a8
Reviewed-on: http://git-master/r/128151
Rename fast clock to "fast-clk" and div clock to
"div-clk" in driver and clock table to have aligned
with mainline as:
This is based on change:
commit f16e6e77a105ec53496f0d8343895da342917873
Author: Laxman Dewangan <ldewangan@nvidia.com>
i2c: tegra: pass proper name for getting clock
Change-Id: Ie9a1972a18e2e60ac7c84c4509860cf72405ef16
Reviewed-on: http://git-master/r/128150
The Tegra i2c controller actually can not support the reverse of
direction address (toggling r/w bit of address) as controller
take 7 bit address from configuration and HW make it 8 bit address
based on read/write flag.
Hence reverting this protocol mangling support.
Change-Id: I987b2be343d535c078e27b44575717a209d15584
Reviewed-on: http://git-master/r/128149
Sync point values are unsigned, but sysfs creates the text
representation as signed. Correct to use unsigned representation.
Bug 1039058
Change-Id: I96de13952eeeba9510bae179a036459ddee18dcd
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/128075
Reviewed-by: Michal Pecio <mpecio@nvidia.com>
Bug 1029431
Change-Id: I79ba7e363feeaec86912445ce005ea65a3960718
Signed-off-by: Seema Khowala <seemaj@nvidia.com>
Reviewed-on: http://git-master/r/127994
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
http://www.arm.linux.org.uk/developer/machines/list.php?id=4311
Bug 1002637
Change-Id: Id52214c1780294e4e4a6607b954c05e9be950fdd
Reviewed-on: http://git-master/r/127978
Bug 1002637
Change-Id: I33d38ab3a5395f85564ef9a3282db152b4d79113
Reviewed-on: http://git-master/r/127974
When allocation is bigger than L2 size it is more optimal to
flush or writeback whole L2 instead of doing maintenance
for each allocated page.
bug 983964
Change-Id: Ibb3609be71621ff9ab75bea9146bfe7578f9315a
Signed-off-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-on: http://git-master/r/127835
Reviewed-by: Rhyland Klein <rklein@nvidia.com>
The EmcTclkStable is set to 0x00000004 and McEmemArbOutStandingReq
is set to 0xc0000030
Bug 1030392
Bug 1039060
Reviewed-on: http://git-master/r/122302
(cherry picked from commit a3a1d1797e310d61204256af8be995f9396c22e7)
Change-Id: Ic65334a6573582ae99d05a8f6f8290096755827e
Signed-off-by: Wen Yi <wyi@nvidia.com>
Reviewed-on: http://git-master/r/127458
The memory frequencies 266.5mhz and 437mhz have incorrect
EMEM_ARB_CFG set in emc table of Samsung part. That resulted
in emc scaling completely disabled and emc runs at 533mhz all
time. The settings have been corrected to 0x00000008
and 0x0000000D.
Bug 1030392
Bug 1039060
Reviewed-on: http://git-master/r/122163
(cherry picked from commit f691268c138b9ed31b3867b049e64c121ecb188e)
Change-Id: I13f89c19af5391743aeba348f4a3ca4a73307bdf
Reviewed-on: http://git-master/r/127429
Reviewed-by: Raymond Poudrier <rapoudrier@nvidia.com>
Tested-by: Sanjay Singh Rawat <srawat@nvidia.com>
Disable host1x interrupts when clock gating host1x. This fixes a race
where host1x interrupt was raised at the same time when host1x clock
is turned off.
Bug 1031724
Change-Id: I169cd5796608b8888a6b48ed99bb5da754559b2c
Reviewed-on: http://git-master/r/125129
Enable LP1 Core voltage settings to 950mV
The feature is added in the below change.
Refer to http://git-master/r/#change,124135 for more details.
Bug 1035684
Change-Id: I922efff17797f4666fd6ed069a8523c164445842
Signed-off-by: Karthik Ramakrishnan <karthikr@nvidia.com>
(cherry picked from commit 0f5d34db547ca6bfb9c0bae0b0048f58ba71c833)
Reviewed-on: http://git-master/r/124781
Set the register values for each of the board files to
keep the Core voltage to 0.95V in LP1.
This change is only for those platforms where LP1 is supported.
Enterprise and Kai are the main platforms for this change. There
is no support for Cardhu for LP1 and so is left blank and the
feature will be skipped for Cardhu platforms, except for AP37.
AP37 with a PM269 board needs this change and so Cardhu board
file is updated with the values specific to AP37.
This change is part of the feature to set VCore to 0.95V
Refer to http://git-master/r/124135 for more details
Bug 1035684
Change-Id: I6d1d984b0e7968b441cebbc37705c25647a4a85a
(cherry picked from commit b46921e475bd95e729896a6763bc94df1e03ee4a)
Reviewed-on: http://git-master/r/124780
When the device prepares for LP1, the Core voltage is set to the
highest value(1.2V for Enterprise and Kai, and 1.3V for AP37 and
Cardhu). This is to set for some of the driver suspend along the
sequence need a higher emc frequency and thus a higher Core voltage.
Since the sequence of drivers suspend depends on the sequence of
their registration in the table, which in turn is platform-dependent,
there is no right place in the LP1 entry path where the Core voltage
can be set to a lower voltage. Hence, the Core voltage remains high
in LP1 resulting in higher power.
Thus, the only safe location where the Core voltage can be lowered is
once all the drivers are suspended and the DRAM is set in self-refresh,
at the final point just before the system is suspended in the IRAM code.
This location at the assembly code ensures that no other module will be
running and thus that nothing will require a higher core voltage. The Core
is set to the lowest possible value since nothing requires it. It is then
restored to the highest voltage as soon as the LP1 resume code is started
so that all drivers are resumed safely.
At the execution point in IRAM during LP1 suspend path, even the I2C clocks
are gated. They must be reset first and then the I2C transaction is performed.
An I2C transaction involves 4 bytes of data, to send the slave address,
the Core voltage register address and 2 bytes of data which has the value
to set the voltage(the second byte is not required for this transaction).
Once these registers are set, the I2C transaction is performed by setting
the I2C transaction register to 0xA02. After sending the I2C transaction,
we wait for about 250us to check the status of the transaction and if not
updated, wait for more time to check again. If after 2ms and the transaction
fails to register, the transaction is aborted and the device is allowed
to enter at high voltage. Since the failure rate of I2C transaction is very
low at this point in execution where there will be no conflicts in the bus,
it is okay to have Core high for some of the LP1 cycles.
However, it is unacceptable for the I2C transaction to fail on the way
from LP1 resume since the device cannot come up with a lower Core
voltage. In this case, the transaction is retried again and again till
it is successful. There is no way but to keep trying as the device
would fail to resume with Core at 0.95V.
Each platform(or each PMU) has different values for the I2C transaction
ie. slave address, Core voltage register and the value to set the
voltage. For the device in IRAM, it cannot access anything in SDRAM
memory, these values needs to be pushed to IRAM memory before the device
starts execution in IRAM. This is done during initialization of suspend
code when it picks values from the board files and copies it to IRAM
part of code, before the whole memory is copied to IRAM.
This new feature is controlled by a KConfig variable TEGRA_LP1_950 which
should be enabled once the board file of the device is updated with the
right values. The device hangs when it does not have the right values for
the I2C transaction.
With this change in Core, LP1 power is reduced by 12mW in Enterprise,
20mW in AP37 and about 24mW in Kai.
Bug 1035684
Change-Id: I4318c66fd70ab227ef0786d6a13286e020e4541d
(cherry picked from commit ab476f287376fd0ae51a9f298659f5eba19f0296)
Reviewed-on: http://git-master/r/124779
This patch adds:
1. line_stride value is honored in fb_set_par routine
2. Hardware value for line_stride is used in fb_register
Bug 1025739
Change-Id: Ic37c4c90911c2c70e74b8d5609f3b32b521772ff
Signed-off-by: Christopher Freeman <cfreeman@nvidia.com>
Reviewed-on: http://git-master/r/127690
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
This reverts commit 0405128605ed7a858aecb8fb9aaaf80e0e44c4b8
Change-Id: I3a0ee9b0079b884d53c43323e21b472a40c31bb7
Reviewed-on: http://git-master/r/125323
This patch adds:
1. A kernel config option that hints to DC driver
to use the current value of the color depth
register as the default for initializing the FB
driver.
2. Checks to see if DC is enabled before reading
off the color depth register in tegra_dc_probe.
Change-Id: I852cc1328fcf42f33052f46b86d753e691744329
Reviewed-on: http://git-master/r/127297
Make parallel data strobed on rising clock edge
For SKU2 MODS get correct CRC.
Bug 995623
Change-Id: I70f4b87e781821cf4ff8370c17b79f5bea7dc55c
Signed-off-by: Dongfang Shi <dshi@nvidia.com>
Reviewed-on: http://git-master/r/121824
(cherry-pick from 5200d0f10b936e00dbc2a946eed8c2e48b039943)
Reviewed-on: http://git-master/r/122537
Reviewed-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Expanding NOR functionality to work with ADMUX and Burst mode for Micron
Support in E1853.
Bug 989919
Bug 966833
- Adding fields for picking MUX vs NONMUX and picking Async, Paging,
Burst mode for reads
- Added run time decision between them
- 1853 specific settings for Async NOR
- 1852 specific settings for NOR
- 1853 NOR timings changed
Reviewed-on: http://git-master/r/122286
(cherry picked from commit a242e7194c7de559d22fe5b275a8782086f10e50)
Change-Id: I79de1d52d4c7199c83b380c2fa6d8cae6b35f09d
Signed-off-by: Bob Johnston <BJohnston@nvidia.com>
Reviewed-on: http://git-master/r/124946
Tested-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-by: Sumeet Gupta <sumeetg@nvidia.com>
Bug: 1039342
Change-Id: Ic1f0e9fa8c8d9e69b7fb9cd35d2cbbf578c579e5
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
