2010-10-17Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-10-17ALSA: fix unused warnings with snd_power_get_stateMike Frysinger
If we compile the ASoC code with PM disabled, we hit stuff like: sound/soc/soc-dapm.c: In function 'snd_soc_dapm_suspend_check': sound/soc/soc-dapm.c:440: warning: unused variable 'codec' So tweak the stub macro to avoid these issues. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-17sound: fixed typosAndrea Gelmini
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-14ALSA: snd-aloop - fix issue in the timer start functionJaroslav Kysela
In some circumstances (the rate shift value was changed), the irq_pos value may be higher than the fraction value in the timer start function. Check for it. Also, to avoid value overflow, decrease maximum period size. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-11Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-10-11ALSA: sound/usb/usx2y: simplify conditionalNicolas Kaiser
Simplify conditional: (a || (!a && b)) => (a || b) Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-11OSS: soundcard: fix return value of sound_open()Dan Carpenter
Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-11Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-10-11OSS: soundcard: locking bug in sound_ioctl()Dan Carpenter
We shouldn't return directly here because we're still holding the &soundcard_mutex. This bug goes all the way back to the start of git. It's strange that no one has complained about it as a runtime bug. CC: stable@kernel.org Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-11ALSA: OSS mixer emulation - fix lockingJaroslav Kysela
Fix mutex release and cleanup some locking code. Cc: <stable@kernel.org> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-11ALSA: snd-aloop: Fix hw_params restrictions and checkingJaroslav Kysela
This patch fixes the hw_params restrictions when first (or playback) stream sets the final hardware parameters. Also, fix the hw_params checking in the trigger callback. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-06Linux 2.6.36-rc7v2.6.36-rc7Linus Torvalds
2010-10-06Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: MIPS: Octeon: Place cnmips_cu2_setup in __init memory. MIPS: Don't place cu2 notifiers in __cpuinitdata MIPS: Calculate VMLINUZ_LOAD_ADDRESS based on the length of vmlinux.bin MIPS: Alchemy: Resolve prom section mismatches MIPS: Fix syscall 64 bit number comments. MIPS: Hookup fanotify_init, fanotify_mark, and prlimit64 syscalls. MIPS: TX49xx: Rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN MIPS: N32: Fix getdents64 syscall for n32 MIPS: Remove pr_<level> uses of KERN_<level> MIPS: PNX8550: Sort out machine halt, restart and powerdown functions. MIPS: GIC: Remove dependencies from Malta files. MIPS: Kconfig: Fix and clarify kconfig help text for VSMP and SMTC. MIPS: DMA: Fix computation of DMA flags from device's coherent_dma_mask. MIPS: Audit: Fix hang in entry.S. MIPS: Document why RELOC_HIDE is there. MIPS: Octeon: Determine if helper needs to be built MIPS: Use generic atomic64 for 32-bit kernels MIPS: RM7000: Symbol should be static MIPS: kspd: Adjust confusing if indentation MIPS: Fix a typo.
2010-10-06Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: writeback: always use sb->s_bdi for writeback purposes
2010-10-06Merge branch 'v2.6.36-rc6-urgent-fixes' of ↵Linus Torvalds
git://xenbits.xen.org/people/sstabellini/linux-pvhvm * 'v2.6.36-rc6-urgent-fixes' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: do not initialize PV timers on HVM if !xen_have_vector_callback xen: do not set xenstored_ready before xenbus_probe on hvm
2010-10-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: Initialize total_len in fuse_retrieve()
2010-10-06ALSA: oxygen - Add a SSID for CMI8787-HG2PCITakashi Iwai
This board has a strange PCI SSID 13f6:ffff. Works as compabile as MODEL_CMEDIA_REF. Reported-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-06ALSA: oxygen: add PEX8111 initializationClemens Ladisch
Configure the PEX8111 bridge on the PCI Express cards so that the audio DMA controller can do proper burst reads and is less likely to lose data. This is usually done automatically, but is required on older cards where the user has not applied the PLX firmware update. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-06ALSA: oxygen: rewrite PCIe bridge initializationClemens Ladisch
Change the PCIe/PCI bridge initialization code to configure only the bridge that is actually connected to the sound chip, instead of any bridge found in the system. The new code also makes it easier to add other bridges. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-06ALSA: oxygen: reduce minimum period countClemens Ladisch
The interrupt counter is independent of the buffer counter, so there are no restrictions on the period size. Having fewer periods also makes PulseAudio happy. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-05powerpc: remove unused variableStephen Rothwell
Since powerpc uses -Werror on arch powerpc, the build was broken like this: cc1: warnings being treated as errors arch/powerpc/kernel/module.c: In function 'module_finalize': arch/powerpc/kernel/module.c:66: error: unused variable 'err' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: rcu_read_lock_bh_held(): disabling irqs also disables bh generic-ipi: Fix deadlock in __smp_call_function_single
2010-10-05Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf trace scripting: Fix extern struct definitions perf ui hist browser: Fix segfault on 'a' for annotate perf tools: Fix build breakage perf, x86: Handle in flight NMIs on P4 platform oprofile, ARM: Release resources on failure oprofile: Add Support for Intel CPU Family 6 / Model 29
2010-10-05wait: using uninitialized member of wait queueEvgeny Kuznetsov
The "flags" member of "struct wait_queue_t" is used in several places in the kernel code without beeing initialized by init_wait(). "flags" is used in bitwise operations. If "flags" not initialized then unexpected behaviour may take place. Incorrect flags might used later in code. Added initialization of "wait_queue_t.flags" with zero value into "init_wait". Signed-off-by: Evgeny Kuznetsov <EXT-Eugeny.Kuznetsov@nokia.com> [ The bit we care about does end up being initialized by both prepare_to_wait() and add_to_wait_queue(), so this doesn't seem to cause actual bugs, but is definitely the right thing to do -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05modules: Fix module_bug_list list corruption raceLinus Torvalds
With all the recent module loading cleanups, we've minimized the code that sits under module_mutex, fixing various deadlocks and making it possible to do most of the module loading in parallel. However, that whole conversion totally missed the rather obscure code that adds a new module to the list for BUG() handling. That code was doubly obscure because (a) the code itself lives in lib/bugs.c (for dubious reasons) and (b) it gets called from the architecture-specific "module_finalize()" rather than from generic code. Calling it from arch-specific code makes no sense what-so-ever to begin with, and is now actively wrong since that code isn't protected by the module loading lock any more. So this commit moves the "module_bug_{finalize,cleanup}()" calls away from the arch-specific code, and into the generic code - and in the process protects it with the module_mutex so that the list operations are now safe. Future fixups: - move the module list handling code into kernel/module.c where it belongs. - get rid of 'module_bug_list' and just use the regular list of modules (called 'modules' - imagine that) that we already create and maintain for other reasons. Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05ALSA: oxygen: fix input monitor dB scaleClemens Ladisch
The input monitor half volume bit results in a factor of 0.5, so the minimum scale value should be -6 dB. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-05ALSA: oxygen: fix chip ID register symbolsClemens Ladisch
Rename the symbol for the XCID pins, fix up a decimal/hex confusion for the CMI8787 package ID, and add the other known package IDs. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-05ALSA: virtuoso: fix Xonar STX anti-pop delayClemens Ladisch
The anti-pop delay for the STX should be 800 ms, not 100 ms like the ST. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-05ALSA: virtuoso: add HDAV1.3 Slim PCI IDClemens Ladisch
Add a PCI ID for the Xonar HDAV1.3 Slim. There is no actual support, but the presence of the ID allows the EEPROM repair code to work for this card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-05ALSA: oxygen: handle CD input configuration with a flagClemens Ladisch
There are more models without a CD input than with one, so handle this explicitly with a device_config flag to avoid having to define a control filter callback to filter it out. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-05ALSA: virtuoso: fix Xonar DS chip nameClemens Ladisch
The controller on the Xonar DS is labeled "AV66", not "AV200". Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-05ALSA: usb-audio: add more Yamaha USB MIDI devicesClemens Ladisch
Add quirks for more devices (according to driver V.3.0.4-2). Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-05xen: do not initialize PV timers on HVM if !xen_have_vector_callbackStefano Stabellini
if !xen_have_vector_callback do not initialize PV timer unconditionally because we still don't know how many cpus are available and if there is more than one we won't be able to receive the timer interrupts on cpu > 0. This patch fixes an hang at boot when Xen does not support vector callbacks and the guest has multiple vcpus. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
2010-10-05xen: do not set xenstored_ready before xenbus_probe on hvmStefano Stabellini
Register_xenstore_notifier should guarantee that the caller gets notified even if xenstore is already up. Therefore we revert "do not notify callers from register_xenstore_notifier" and set xenstored_read at the right time for PV on HVM guests too. In fact in case of PV on HVM guests xenstored is ready only after the platform pci driver has completed the initialization, so do not set xenstored_ready before the call to xenbus_probe(). This patch fixes a shutdown_event watcher registration bug that causes "xm shutdown" not to work properly. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
2010-10-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: regulator: max8649 - fix setting extclk_freq regulator: fix typo in current units regulator: fix device_register() error handling
2010-10-04Merge branch 'merge-powerpc' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'merge-powerpc' of git://git.secretlab.ca/git/linux-2.6: powerpc/5200: tighten up ac97 reset timing powerpc/5200: efika.c: Add of_node_put to avoid memory leak powerpc/512x: fix clk_get() return value
2010-10-04Merge branch 'fix/misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/misc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: i2c/other/ak4xx-adda: Fix a compile warning with CONFIG_PROCFS=n ALSA: prevent heap corruption in snd_ctl_new()
2010-10-04Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: hwmon: f71882fg: use a muxed resource lock for the Super I/O port
2010-10-04Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Fix memory leaks in pcc_cpufreq_do_osc [CPUFREQ] acpi-cpufreq: add missing __percpu markup
2010-10-04Merge branch 'merge-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'merge-spi' of git://git.secretlab.ca/git/linux-2.6: of/spi: Fix OF-style driver binding of spi devices spi: spi-gpio.c tests SPI_MASTER_NO_RX bit twice, but not SPI_MASTER_NO_TX spi/mpc8xxx: fix buffer overrun on large transfers
2010-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: vlan: dont drop packets from unknown vlans in promiscuous mode Phonet: Correct header retrieval after pskb_may_pull um: Proper Fix for f25c80a4: remove duplicate structure field initialization ip_gre: Fix dependencies wrt. ipv6. net-2.6: SYN retransmits: Add new parameter to retransmits_timed_out() iwl3945: queue the right work if the scan needs to be aborted mac80211: fix use-after-free
2010-10-04Merge branch 'drm-intel-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel: drm/i915: Rephrase pwrite bounds checking to avoid any potential overflow drm/i915: Sanity check pread/pwrite drm/i915: Use pipe state to tell when pipe is off drm/i915: vblank status not valid while training display port drivers/gpu/drm/i915/i915_gem.c: Add missing error handling code drm/i915: Fix refleak during eviction. drm/i915: fix GMCH power reporting
2010-10-04ksm: fix bad user data when swappingHugh Dickins
Building under memory pressure, with KSM on 2.6.36-rc5, collapsed with an internal compiler error: typically indicating an error in swapping. Perhaps there's a timing issue which makes it now more likely, perhaps it's just a long time since I tried for so long: this bug goes back to KSM swapping in 2.6.33. Notice how reuse_swap_page() allows an exclusive page to be reused, but only does SetPageDirty if it can delete it from swap cache right then - if it's currently under Writeback, it has to be left in cache and we don't SetPageDirty, but the page can be reused. Fine, the dirty bit will get set in the pte; but notice how zap_pte_range() does not bother to transfer pte_dirty to page_dirty when unmapping a PageAnon. If KSM chooses to share such a page, it will look like a clean copy of swapcache, and not be written out to swap when its memory is needed; then stale data read back from swap when it's needed again. We could fix this in reuse_swap_page() (or even refuse to reuse a page under writeback), but it's more honest to fix my oversight in KSM's write_protect_page(). Several days of testing on three machines confirms that this fixes the issue they showed. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-04ksm: fix page_address_in_vma anon_vma oopsHugh Dickins
2.6.36-rc1 commit 21d0d443cdc1658a8c1484fdcece4803f0f96d0e "rmap: resurrect page_address_in_vma anon_vma check" was right to resurrect that check; but now that it's comparing anon_vma->roots instead of just anon_vmas, there's a danger of oopsing on a NULL anon_vma. In most cases no NULL anon_vma ever gets here; but it turns out that occasionally KSM, when enabled on a forked or forking process, will itself call page_address_in_vma() on a "half-KSM" page left over from an earlier failed attempt to merge - whose page_anon_vma() is NULL. It's my bug that those should be getting here at all: I thought they were already dealt with, this oops proves me wrong, I'll fix it in the next release - such pages are effectively pinned until their process exits, since rmap cannot find their ptes (though swapoff can). For now just work around it by making page_address_in_vma() safe (and add a comment on why that check is wanted anyway). A similar check in __page_check_anon_rmap() is safe because do_page_add_anon_rmap() already excluded KSM pages. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-04MIPS: Octeon: Place cnmips_cu2_setup in __init memory.David Daney
It is an early_initcall, so it should be in __init memory. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1593/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-04MIPS: Don't place cu2 notifiers in __cpuinitdataDavid Daney
The notifiers may be called at any time, so the notifier_block cannot be in init memory. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1592/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-04MIPS: Calculate VMLINUZ_LOAD_ADDRESS based on the length of vmlinux.binShmulik Ladkani
Fix VMLINUZ_LOAD_ADDRESS calculation to be based on the length of vmlinux.bin, the actual uncompressed kernel binary. Previously it was based on the length of KBUILD_IMAGE (the unstripped ELF vmlinux), which is bigger than vmlinux.bin. As a result, vmlinuz was loaded into a memory address higher then actually needed - a problem for small memory platforms. Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> To: linux-mips@linux-mips.org Cc: alex@digriz.org.uk Cc: manuel.lauss@googlemail.com Cc: sam@ravnborg.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1564/ Acked-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-04MIPS: Alchemy: Resolve prom section mismatchesManuel Lauss
The function prom_init_cmdline() references the variable __initdata arcs_cmdline. The function prom_get_ethernet_addr() references the variable __initdata arcs_cmdline. Annotate prom_init_cmdline() as __init, unexport and annotate prom_get_ethernet_addr() since it's no longer called from within driver code. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1547/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-04MIPS: Fix syscall 64 bit number comments.Ralf Baechle
Noticed and original patch by Philby John <pjohn@mvista.com>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-04MIPS: Hookup fanotify_init, fanotify_mark, and prlimit64 syscalls.David Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1553/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
