2006-09-23[ALSA] Fix disconnection of proc interfaceTakashi Iwai
- Add the linked list to each proc entry to enable a single-shot disconnection (unregister) - Deprecate snd_info_unregister(), use snd_info_free_entry() - Removed NULL checks of snd_info_free_entry() Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Control API - TLV implementation for additional information like dB scaleJaroslav Kysela
This patch implements a TLV mechanism to transfer an additional information like dB scale to the user space. The types might be extended in future. Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] statfs for cifs unix extensions no longer experimental [CIFS] New POSIX locking code not setting rc properly to zero on successful [CIFS] Support deep tree mounts (e.g. mounts to //server/share/path)
2006-09-22Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] Rework AGPv3 modesetting fallback. [AGPGART] Add suspend callback for i965 [AGPGART] Fix number of aperture sizes in 830 gart structs. [AGPGART] Intel 965 Express support. [AGPGART] agp.h: constify struct agp_bridge_data::version [AGPGART] const'ify VIA AGP PCI table. [AGPGART] CONFIG_PM=n slim: drivers/char/agp/intel-agp.c [AGPGART] CONFIG_PM=n slim: drivers/char/agp/efficeon-agp.c [AGPGART] Const'ify the agpgart driver version. [AGPGART] remove private page protection map
2006-09-22Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] sw_any_bug_dmi_table can be used on resume, so it isn't initdata [CPUFREQ] Fix some more CPU hotplug locking. [CPUFREQ] Workaround for BIOS bug in software coordination of frequency [CPUFREQ] Longhaul - Add voltage scaling to driver [CPUFREQ] Fix sparse warning in ondemand [CPUFREQ] make drivers/cpufreq/cpufreq_ondemand.c:powersave_bias_target() static [CPUFREQ] Longhaul - Add ignore_latency option [CPUFREQ] Longhaul - Disable arbiter [CPUFREQ][2/2] ondemand: updated add powersave_bias tunable [CPUFREQ][1/2] ondemand: updated tune for hardware coordination [CPUFREQ] Fix typo.
2006-09-22[PATCH] fallout from hcd-core patchAl Viro
missing le16_to_cpu() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[PATCH] fix the survivors of fbcon_vbl_handler() renamingAl Viro
In |Author: James Simmons <jsimmons@kozmo.(none)> |Date: Thu Mar 13 22:37:08 2003 -0800 | | [FBCON] Cursor handling clean up. I nuked several static variables. we have -static void fbcon_vbl_handler(int irq, void *dummy, struct pt_regs *fp) +static void fb_vbl_handler(int irq, void *dev_id, struct pt_regs *fp) and 3 years later a couple of instances missed back then still remains there. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[PATCH] sun4: fix sbus_setup_iommu()Al Viro
iommu_init() and iounit_init() are never called for sun4, but that's not enough - these calls should be ifdefed out since the functions in question simply do not exist for CONFIG_SUN4 kernel. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[PATCH] asm/backlight.h is ppc-onlyAl Viro
2006-09-22[PATCH] sanitize frv archcleanAl Viro
2006-09-22[PATCH] aoa is pmac-onlyAl Viro
2006-09-22[PATCH] memcpy_fromio() missing in istallionAl Viro
memcpy() from iomem is a bad thing... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[PATCH] fix ancient breakage in ebus_init()Al Viro
Back when pci_dev had base_address[], loop of form base = &...->base_address[0]; for (.....) { ... *base++ = addr; } was fine, but when that array got spread in ->resource[...].start replacing the initialization with base = &...->resource[0].start; was not a sufficient modification. IOW this code got broken for cases when there had been more than one resource to fill. All way back in 2.3.41-pre3... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[PATCH] fix missing ifdefs in syscall classes hookup for generic targetsAl Viro
several targets have no ....at() family and m32r calls its only chown variant chown32(), with __NR_chown being undefined. creat(2) is also absent in some targets. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[CPUFREQ] sw_any_bug_dmi_table can be used on resume, so it isn't initdataJeremy Fitzhardinge
sw_any_bug_dmi_table can be used on resume, so it isn't initdata. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-22[CPUFREQ] Fix some more CPU hotplug locking.Dave Jones
Lukewarm IQ detected in hotplug locking BUG: warning at kernel/cpu.c:38/lock_cpu_hotplug() [<b0134a42>] lock_cpu_hotplug+0x42/0x65 [<b02f8af1>] cpufreq_update_policy+0x25/0xad [<b0358756>] kprobe_flush_task+0x18/0x40 [<b0355aab>] schedule+0x63f/0x68b [<b01377c2>] __link_module+0x0/0x1f [<b0119e7d>] __cond_resched+0x16/0x34 [<b03560bf>] cond_resched+0x26/0x31 [<b0355b0e>] wait_for_completion+0x17/0xb1 [<f965c547>] cpufreq_stat_cpu_callback+0x13/0x20 [cpufreq_stats] [<f9670074>] cpufreq_stats_init+0x74/0x8b [cpufreq_stats] [<b0137872>] sys_init_module+0x91/0x174 [<b0102c81>] sysenter_past_esp+0x56/0x79 As there are other places that call cpufreq_update_policy without the hotplug lock, it seems better to keep the hotplug locking at the lower level for the time being until this is revamped. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-22Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: (65 commits) IB: Fix typo in kerneldoc for ib_set_client_data() IPoIB: Add some likely/unlikely annotations in hot path IPoIB: Remove unused include of vmalloc.h IPoIB: Rejoin all multicast groups after a port event IPoIB: Create MCGs with all attributes required by RFC IB/sa: fix ib_sa_selector names IB/iser: INFINIBAND_ISER depends on INET IB/mthca: Simplify calls to mthca_cq_clean() RDMA/cma: Document rdma_accept() error handling IB/mthca: Recover from catastrophic errors RDMA/cma: Document rdma_destroy_id() function IB/cm: Do not track remote QPN in timewait state IB/sa: Require SA registration IPoIB: Refactor completion handling IB/iser: Do not use FMR for a single dma entry sg IB/iser: fix some debug prints IB/iser: make FMR "page size" be 4K and not PAGE_SIZE IB/iser: Limit the max size of a scsi command IB/iser: fix a check of SG alignment for RDMA RDMA/cma: Protect against adding device during destruction ...
2006-09-22Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: [netdrvr] mv643xx_eth: fix obvious typo, which caused build breakage [netdrvr] lp486e: fix typo
2006-09-22IB: Fix typo in kerneldoc for ib_set_client_data()Krishna Kumar
Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IPoIB: Add some likely/unlikely annotations in hot pathEli Cohen
Signed-off-by: Eli Cohen <eli@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IPoIB: Remove unused include of vmalloc.hDotan Barak
IPoIB doesn't use anything from <linux/vmalloc.h>, so don't include it. Signed-off-by: Dotan Barak <dotanb@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IPoIB: Rejoin all multicast groups after a port eventEli Cohen
When ipoib_ib_dev_flush() is called because of a port event, the driver needs to rejoin all multicast groups, since the flush will call ipoib_mcast_dev_flush() (via ipoib_ib_dev_down()). Otherwise no (non-broadcast) multicast groups will be rejoined until the networking core calls ->set_multicast_list again, and so multicast reception will be broken for potentially a long time. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IPoIB: Create MCGs with all attributes required by RFCRoland Dreier
RFC 4391 ("Transmission of IP over InfiniBand (IPoIB)") says: If the IB multicast group does not already exist, one must be created first with the IPoIB link MTU. The MGID MUST use the same P_Key, Q_Key, SL, MTU, and HopLimit as those used in the broadcast-GID. The rest of attributes SHOULD follow the values used in the broadcast-GID as well. However, the current IPoIB driver is only setting the attributes required by the InfiniBand spec to create a multicast group, so in particular the MTU and HopLimit are not being set. Add these attributes when creating MCGs, and also set the Rate attribute, since IPoIB pays attention to that attribute as well. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/sa: fix ib_sa_selector namesMichael S. Tsirkin
Relevant SA queries are actually "greater than" / "less than", not "greater than or equal" / "less than or equal" as the names imply. (See IB spec 1.2 Vol 1, 15.2.5.16 PATHRECORD/Table 205 PathRecord) Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/iser: INFINIBAND_ISER depends on INETRoland Dreier
iSER won't build without CONFIG_INET enabled, so make Kconfig reflect that. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/mthca: Simplify calls to mthca_cq_clean()Roland Dreier
If a QP has separate send and receive CQs, then the send CQ will never have receive completions from that QP in it. So when cleaning the send CQ, there's no need to pass in an SRQ pointer, even if the QP is attached to an SRQ. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA/cma: Document rdma_accept() error handlingOr Gerlitz
Document the reject sending and modifying QP to error done in rdma_accept(). Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/mthca: Recover from catastrophic errorsJack Morgenstein
Trigger device remove and then add when a catastrophic error is detected in hardware. This, in turn, will cause a device reset, which we hope will recover from the catastrophic condition. Since this might interefere with debugging the root cause, add a module option to suppress this behaviour. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA/cma: Document rdma_destroy_id() functionOr Gerlitz
Clarify that rdma_destroy_id cancels outstanding asynchronous operations on the Associated id. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/cm: Do not track remote QPN in timewait stateMichael S. Tsirkin
Do not track remote QPN in TimeWait state, since QP is not connected. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/sa: Require SA registrationMichael S. Tsirkin
Require users to register with SA module, to prevent the sa_query module text from going away while an SA query callback is still running. Update all in-tree users for the new interface. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IPoIB: Refactor completion handlingRoland Dreier
Split up ipoib_ib_handle_wc() into ipoib_ib_handle_rx_wc() and ipoib_ib_handle_tx_wc() to make the code easier to read. This will also help implement NAPI in the future. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/iser: Do not use FMR for a single dma entry sgErez Zilber
Fast Memory Registration (fmr) is used to register for rdma an sg whose elements are not linearly sequential after dma mapping. The IB verbs layer provides an "all dma memory MR (memory region)" which can be used for RDMA-ing a dma linearly sequential buffer. Change the code to use the dma mr instead of doing fmr when dma mapping produces a single dma entry sg. Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/iser: fix some debug printsErez Zilber
fix and add some debug prints related to iser handling of memory for rdma. Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/iser: make FMR "page size" be 4K and not PAGE_SIZEErez Zilber
As iser is able to use at most one rdma operation for the execution of a scsi command, and registration of the sg associated with scsi command has its restrictions, the code checks if an sg is "aligned for rdma". Alignment for rdma is measured in "fmr page" units whose possible resolutions are different between HCAs and can be smaller, equal or bigger to the system page size. When the system page size is bigger than 4KB (eg the default with ia64 kernels) there a bigger chance that an sg would be aligned for rdma if the fmr page size is 4KB. Change the code to create FMR whose pages are of size 4KB and to take that into account when processing the sg. Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/iser: Limit the max size of a scsi commandErez Zilber
Currently, the data length of a command coming down from scsi-ml is limited only by the size of its sg list (sg_tablesize). The max data length may be different for different page size values. By setting max_sectors, we limit the data length to max_sectors*512 bytes. Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/iser: fix a check of SG alignment for RDMAErez Zilber
dma mapping may include a "compaction" of the sg associated with scsi command. Hence, the size of the maximal prefix of the SG which is aligned for rdma must be compared against the length of the dma mapped sg (mem->dma_nents) and not against the size of it before it was mapped (mem->size). Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA/cma: Protect against adding device during destructionSean Hefty
Closes a window where address resolution can attach an rdma_cm_id to a device during destruction of the rdma_cm_id. This can result in the rdma_cm_id remaining in the device list after its memory has been freed. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA/amso1100: Add driver for Ammasso 1100 RNICTom Tucker
Add a driver for the Ammasso 1100 gigabit ethernet RNIC. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA: iWARP Core Changes.Tom Tucker
Modifications to the existing rdma header files, core files, drivers, and ulp files to support iWARP, including: - Hook iWARP CM into the build system and use it in rdma_cm. - Convert enum ib_node_type to enum rdma_node_type, which includes the possibility of RDMA_NODE_RNIC, and update everything for this. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA: iWARP Connection Manager.Tom Tucker
Add an iWARP Connection Manager (CM), which abstracts connection management for iWARP devices (RNICs). It is a logical instance of the xx_cm where xx is the transport type (ib or iw). The symbols exported are used by the transport independent rdma_cm module, and are available also for transport dependent ULPs. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB: Whitespace fixesRoland Dreier
Remove some trailing whitespace that has snuck in despite the best efforts of whitespace=error-all. Also fix a few other whitespace bogosities. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/cm: Randomize starting comm IDSean Hefty
Randomize the starting local comm ID to avoid getting a rejected connection due to a stale connection after a system reboot or reloading of the ib_cm. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/mad: Remove unused includesJames Lentini
The ib_mad module does not use a kthread function, but mad_priv.h includes <linux/kthread.h>. mad_rmpp.c does not do any DMA-related stuff, but includes <linux/dma-mapping.h>. Remove the unused includes. Signed-off-by: James Lentini <jlentini@netapp.com> Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/mad: Add support for dual-sided RMPP transfers.Sean Hefty
The implementation assumes that any RMPP request that requires a response uses DS RMPP. Based on the RMPP start-up scenarios defined by the spec, this should be a valid assumption. That is, there is no start-up scenario defined where an RMPP request is followed by a non-RMPP response. By having this assumption we avoid any API changes. In order for a node that supports DS RMPP to communicate with one that does not, RMPP responses assume a new window size of 1 if a DS ACK has not been received. (By DS ACK, I'm referring to the turn-around ACK after the final ACK of the request.) This is a slight spec deviation, but is necessary to allow communication with nodes that do not generate the DS ACK. It also handles the case when a response is sent after the request state has been discarded. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/cm: Use correct reject code for invalid GIDSean Hefty
Set the reject code properly when rejecting a request that contains an invalid GID. A suitable GID is returned by the IB CM in the additional reject information (ARI). This is a spec compliancy issue. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/cm: Enable atomics along with RDMA readsSean Hefty
Enable atomic operations along with RDMA reads if a local RDMA read/atomic depth is provided by the user. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/mthca: Return correct number of bits for static rate in query_qpJack Morgenstein
Incorrect number of bits was taken for static_rate field. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/mthca: Return port number for unconnected QPs in query_qpJack Morgenstein
port_num was not being returned for unconnected QPs. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/mthca: Fix default static rate returned for Tavor in AVJack Morgenstein
When default static rate is returned for Tavor, need to translate it to an ib rate value. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
