For now, just make sure all inclusion of private header files is done
within #ifdef __KERNEL__. There'll be more to clean up later.
It only really needs to define a few constants and include <asm/mman.h>
when it's used by userspace. Move the rest within #ifdef __KERNEL__
It was unconditionally including a whole bunch of headers which aren't
user-visible, and also exposing a lot of private internal stuff of its
own. Also fix some legacy character set to UTF-8 while we're at it.
It doesn't need to include i2c.h, because a forward declaration of
struct i2c_adapter is perfectly sufficient. And it can be inside
#ifdef __KERNEL__ along with the kernel-internal structure definition.
* master.kernel.org:/pub/scm/linux/kernel/git/sfrench/cifs-2.6-stable:
[CIFS] Fix compile error when CONFIG_CIFS_EXPERIMENTAL is undefined
The targets don't do the basic verification themselves anymore so
the ipt action needs to take care of it.
xt_table->lock should be initialized before xt_replace_table() call, which
uses it. This patch removes strict requirement that table should define
lock before registering.
Signed-off-by: Dmitry Mishin <dim@openvz.org>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
The introduction of x_tables broke comefrom debugging, remove it from
ip6_tables as well (ip_tables already got removed).
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
Some (?) non-x86 architectures require 8byte alignment for u_int64_t
even when compiled for 32bit, using u_int32_t in compat_xt_counters
breaks on these architectures, use u_int64_t for everything but x86.
Reported by Andreas Schwab <schwab@suse.de>.
The backend part is obsoleted, but the target itself is still needed.
Signed-off-by: Thomas Voegtle <tv@lio96.de>
If nf_ct_l3proto_find_get() fails to get the refcount of
nf_ct_l3proto_generic, nf_ct_l3proto_put() will drop the refcount
too far.
This gets rid of '.me = THIS_MODULE' of nf_ct_l3proto_generic so that
nf_ct_l3proto_find_get() doesn't try to get refcount of it.
It's OK because its symbol is usable until nf_conntrack.ko is unloaded.
This also kills unnecessary NULL pointer check as well.
__nf_ct_proto_find() allways returns non-NULL pointer.
__NR_sys_sync_file_range part was lost somewhere...
[glibc is already checking __NR_sync_file_range]
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
[PARISC] MAINTAINERS
[PARISC] Make ioremap default to _nocache
[PARISC] Add new entries to the syscall table
[PARISC] Further work for multiple page sizes
[PARISC] Fix up hil_kbd.c mismerge
[PARISC] defconfig updates
[PARISC] Document that we tolerate "Relaxed Ordering"
[PARISC] Misc. janitorial work
[PARISC] EISA regions must be mapped NO_CACHE
[PARISC] OSS ad1889: Match register names with ALSA driver
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-fixes-2.6:
[PATCH] pcmcia/pcmcia_resource.c: fix crash when using Cardbus cards
[PATCH] vrc4171: update config
[PATCH] pcmcia: fix oops in static mapping case
[PATCH] pcmcia: remove unneeded forward declarations
[PATCH] pcmcia: do not set dev_node to NULL too early
[PATCH] pcmcia: fix comment for pcmcia_load_firmware
[PATCH] pcmcia: unload second device first
[PATCH] pcmcia: add new ID to pcnet_cs
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: possible cleanups
drm: fixup r300 scratch on BE machines
[CIFS] Fix typo in previous
[CIFS] Readdir fixes to allow search to start at arbitrary position
[CIFS] Use the kthread_ API instead of opencoding lots of hairy code for kernel
[CIFS] Don't allow a backslash in a path component
[CIFS] [CIFS] Do not take rename sem on most path based calls (during
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-merge:
powerpc: Fix define_machine so machine_is() works from modules
powerpc/ppc: export strncasecmp
[PATCH] powerpc: fix oops in alsa powermac driver
[PATCH] powerpc: update {g5,iseries,pseries}_defconfigs
[PATCH] ppc: Fix powersave code on arch/ppc
[PATCH] powerpc/cell: remove BUILD_BUG_ON and add sys_tee to spu_syscall_table
[PATCH] powermac: Fix i2c on keywest based chips
[PATCH] powerpc: Lower threshold for DART enablement to 1GB
[PATCH] powerpc: IOMMU support for honoring dma_mask
This patch contains the following possible cleanups:
- make the following needlessly global function static:
- drm_bufs.c: drm_addbufs_fb()
- remove the following unused EXPORT_SYMBOL's:
- drm_agpsupport.c: drm_agp_bind_memory
- drm_bufs.c: drm_rmmap_locked
- drm_stub.c: drm_get_dev
Signed-off-by: Dave Airlie <airlied@linux.ie>
This fixes the r300 scratch stuff to work on PPC,
from Ben Herrenschmidt on IRC.
machine_is() was always returning 0 when used in a module, because
we weren't exporting the machine definitions. This was why sound
wasn't working on powermacs when CONFIG_SND_POWERMAC=m. Original
fix from Ben Herrenschmidt, further fixed by me.
I recently found that not all BIOS manufacturers are using the specified
generic PNP id in their TPM ACPI table entry. I have added the vendor
specific IDs that I know about and added a module parameter that a user can
specify another HID to the probe list if their device isn't being found by the
default list.
Signed-off-by: Kylene Hall <kjhall@us.ibm.com>
This patch adds a boolean module parameter that allows the user to turn
interrupt support on and off. The default behavior is to attempt to use
interrupts.
Fixes minor spacing issues.
Use __devexit_p() for the exit/remove function to protect against
discarding it.
WARNING: drivers/char/tpm/tpm_infineon.o - Section mismatch: reference to .exit.text:tpm_inf_pnp_remove from .data between 'tpm_inf_pnp' (at offset 0x20) and 'tpm_inf'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Kylene Jo Hall <kjhall@us.ibm.com>
The acpi table which contains the BIOS log events was updated for 1.2.
There are now client and server modes as defined in the specifications with
slightly different formats. Additionally, the start field was even too
small for the 1.1 version but had been working anyway. This patch updates
the code to deal with any of the three types of headers probperly (1.1, 1.2
client and 1.2 server).
Signed-off-by: Kylie Hall <kjhall@us.ibm.com>
The memory start and length values obtained from the ACPI entry need to be
checked and filled in with the default values from the specification if
they don't exist. This patch fills in the default values and uses them
appropriately.
Apply the latest changes in the TPM interface to the Infineon TPM-driver.
Signed-off-by: Marcel Selhorst <selhorst@crypto.rub.de>
Acked-by: Kylie Hall <kjhall@us.ibm.com>
Use set_bit() and clear_bit() for dev_mask manipulation.
The timeout and duration values used in the tpm driver are not exposed to
userspace. This patch converts the storage units to jiffies with
msecs_to_jiffies. They were always being used in jiffies so this
simplifies things removing the need for calculation all over the place.
The change necessitated a type change in the tpm_chip struct to hold
jiffies.
The driver for the next generation of TPM chips version 1.2 including support
for interrupts. The Trusted Computing Group has written the TPM Interface
Specification (TIS) which defines a common interface for all manufacturer's
1.2 TPM's thus the name tpm_tis.
Signed-off-by: Leendert van Doorn <leendert@watson.ibm.com>
Cc: Greg KH <greg@kroah.com>
Many of the sysfs files were calling the TPM_GetCapability command with array.
Since for 1.2 more sysfs files of this type are coming I am generalizing the
array so there can be one array and the unique parts can be filled in just
before the command is called.
This updated version of the patch breaks the multi-value sysfs file into
separate files pointed out by Greg. It also addresses the code redundancy and
ugliness in the tpm_show_* functions pointed out on another patch by Dave
Hansen.
