2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (250 commits) ALSA: hda: Storage class should be before const qualifier ASoC: tpa6130a2: Remove CPVSS and HPVdd supplies ASoC: tpa6130a2: Define output pins with SND_SOC_DAPM_OUTPUT ASoC: sdp4430 - add sdp4430 pcm ops to DAI. ASoC: TWL6040: Enable earphone path in codec ASoC: SDP4430: Add support for Earphone speaker ASoC: SDP4430: Add sdp4430 machine driver ASoC: tlv320dac33: Avoid powering off while in BIAS_OFF ASoC: tlv320dac33: Use dev_dbg in dac33_hard_power function ALSA: sound/pci/asihpi: Use kzalloc ALSA: hdmi - dont fail on extra nodes ALSA: intelhdmi - add id for the CougarPoint chipset ALSA: intelhdmi - user friendly codec name ALSA: intelhdmi - add dependency on SND_DYNAMIC_MINORS ALSA: asihpi: incorrect range check ALSA: asihpi: testing the wrong variable ALSA: es1688: add pedantic range checks ARM: McBSP: Add support for omap4 in McBSP driver ARM: McBSP: Fix request for irq in OMAP4 OMAP: McBSP: Add 32-bit mode support ...
2010-05-20Merge branch 'for-linus/i2c-2635' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/i2c-2635' of git://git.fluff.org/bjdooks/linux: (21 commits) i2c-highlander: remover superflous variable i2c-ibm-iic: drop NO_IRQ i2c-cpm: drop NO_IRQ i2c-mpc: drop NO_IRQ MAINTAINERS: add i2c tree for embedded platforms i2c-pxa: only define 'blue_murder'-function if DEBUG is #defined i2c-pxa: remove unused macro i2c-nomadik: fix operator precedence warning i2c-nomadik: release region when removed OMAP3: I2C: Clean up Errata 1p153 handling OMAP2/3: I2C: Errata ID i207: Clear wrong RDR interrupt omap: i2c: add a timeout to the busy waiting omap: i2c: make errata 1.153 workaround a separate function i2c-omap: add mpu wake up latency constraint in i2c omap: i2c: Add i2c support on omap4 platform i2c-bfin-twi: return completion in interrupt for smbus quick transfers i2c-bfin-twi: remove redundant retry i2c-bfin-twi: fix lost interrupts at high speeds i2c-bfin-twi: add debug output for error status i2c-bfin-twi: integrate timeout timer with completion interface ...
2010-05-20Merge branch 'v4l_for_2.6.35' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (534 commits) V4L/DVB (13554a): v4l: Use the video_drvdata function in drivers V4L/DVB: vivi and mem2mem_testdev need slab.h to build V4L/DVB: tm6000: bugfix image position V4L/DVB: IR/imon: remove dead IMON_KEY_RELEASE_OFFSET V4L/DVB: tm6000: README - add vbi V4L/DVB: Fix unlock logic at medusa_video_init V4L/DVB: fix dvb frontend lockup V4L/DVB: s2255drv: remove dead code V4L/DVB: s2255drv: return if vdev not found V4L/DVB: ov511: cleanup: remove unneeded null check V4L/DVB: media/mem2mem: dereferencing free memory V4L/DVB: media/IR: Add missing include file to rc-map.c V4L/DVB: dvb/stv6110x: cleanup error handling V4L/DVB: ngene: Add lgdt3303 and mt2131 deps to Kconfig V4L/DVB: ngene: start separating out DVB functions into separate file V4L/DVB: ngene: split out card specific code into a separate file V4L/DVB: ngene: split out i2c code into a separate file V4L/DVB: ngene: add initial support for digital side of Avermedia m780 V4L/DVB: ngene: properly support boards where channel 0 isn't a TS input V4L-DVB: ngene: make sure that tuner headers are included ...
2010-05-20Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (49 commits) libata-sff: separate out BMDMA qc_issue libata-sff: prd is BMDMA specific libata-sff: ata_sff_[dumb_]qc_prep are BMDMA specific libata-sff: separate out BMDMA EH libata-sff: port_task is SFF specific libata-sff: ap->[last_]ctl are SFF specific libata-sff: rename ap->ops->drain_fifo() to sff_drain_fifo() libata-sff: introduce ata_sff_init/exit() and ata_sff_port_init() libata-sff: clean up BMDMA initialization libata-sff: clean up inheritance in several drivers libata-sff: reorder SFF/BMDMA functions sata_inic162x: kill PORT_PRD_ADDR initialization libata: kill ATA_FLAG_DISABLED libata-sff: kill unused prototype and make ata_dev_select() static libata-sff: update bmdma host bus error handling sata_mv: remove unnecessary initialization sata_inic162x: inic162x is not dependent on CONFIG_ATA_SFF pata_sch: use ata_pci_sff_init_one() pata_sil680: Do our own exec_command posting libata: Remove excess delay in the tf_load path ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (29 commits) pcmcia: disable PCMCIA ioctl also for ARM drivers/staging/comedi: dev_node removal (quatech_daqp_cs) drivers/staging/comedi: dev_node removal (ni_mio_cs) drivers/staging/comedi: dev_node removal (ni_labpc_cs) drivers/staging/comedi: dev_node removal (ni_daq_dio24) drivers/staging/comedi: dev_node removal (ni_daq_700) drivers/staging/comedi: dev_node removal (das08_cs) drivers/staging/comedi: dev_node removal (cb_das16_cs) pata_pcmcia: get rid of extra indirection pcmcia: remove suspend-related comment from yenta_socket.c pcmcia: call pcmcia_{read,write}_cis_mem with ops_mutex held pcmcia: remove pcmcia_add_device_lock pcmcia: update gfp/slab.h includes pcmcia: remove unused mem_op.h pcmcia: do not autoadd root PCI bus resources pcmcia: clarify alloc_io_space, move it to resource handlers pcmcia: move all pcmcia_resource_ops providers into one module pcmcia: move high level CIS access code to separate file pcmcia: dev_node removal (core) pcmcia: dev_node removal (remaining drivers) ...
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: PM QOS update fix Freezer / cgroup freezer: Update stale locking comments PM / platform_bus: Allow runtime PM by default i2c: Fix bus-level power management callbacks PM QOS update PM / Hibernate: Fix block_io.c printk warning PM / Hibernate: Group swap ops PM / Hibernate: Move the first_sector out of swsusp_write PM / Hibernate: Separate block_io PM / Hibernate: Snapshot cleanup FS / libfs: Implement simple_write_to_buffer PM / Hibernate: document open(/dev/snapshot) side effects PM / Runtime: Add sysfs debug files PM: Improve device power management document PM: Update device power management document PM: Allow runtime_suspend methods to call pm_schedule_suspend() PM: pm_wakeup - switch to using bool
2010-05-20Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: change cancel_work_sync() to clear work->data workqueue: warn about flush_scheduled_work()
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: ia64: add sparse annotation to __ia64_per_cpu_var() percpu: implement kernel memory based chunk allocation percpu: move vmalloc based chunk management into percpu-vm.c percpu: misc preparations for nommu support percpu: reorganize chunk creation and destruction percpu: factor out pcpu_addr_in_first/reserved_chunk() and update per_cpu_ptr_to_phys()
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/core: Use kmemdup() instead of kmalloc()+memcpy() IB/iser: Fix error flow in iser_create_ib_conn_res() IB/iser: Enhance disconnection logic for multi-pathing IB/iser: Remove buggy back-pointer setting IB/iser: Add asynchronous event handler MAINTAINERS: Add cxgb4 and iw_cxgb4 entries RDMA/cxgb3: Shrink .text with compile-time init of handlers arrays IPoIB: Allow disabling/enabling TSO on the fly through ethtool IB/mlx4: Add support for masked atomic operations IB/core: Add support for masked atomic operations RDMA/cma: Randomize local port allocation RDMA/nes: Make unnecessarily global functions static RDMA/nes: Make nesadapter->phy_lock usage consistent RDMA/cxgb4: Add driver for Chelsio T4 RNIC IB/mthca: Use the dma state API instead of pci equivalents RDMA/amso1100: Use the dma state API instead of pci equivalents RDMA/cxgb3: Don't free skbs on NET_XMIT_* indications from LLD RDMA/cxgb3: Use the dma state API instead of pci equivalents IB: Explicitly rule out llseek to avoid BKL in default_llseek()
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (61 commits) KEYS: Return more accurate error codes LSM: Add __init to fixup function. TOMOYO: Add pathname grouping support. ima: remove ACPI dependency TPM: ACPI/PNP dependency removal security/selinux/ss: Use kstrdup TOMOYO: Use stack memory for pending entry. Revert "ima: remove ACPI dependency" Revert "TPM: ACPI/PNP dependency removal" KEYS: Do preallocation for __key_link() TOMOYO: Use mutex_lock_interruptible. KEYS: Better handling of errors from construct_alloc_key() KEYS: keyring_serialise_link_sem is only needed for keyring->keyring links TOMOYO: Use GFP_NOFS rather than GFP_KERNEL. ima: remove ACPI dependency TPM: ACPI/PNP dependency removal selinux: generalize disabling of execmem for plt-in-heap archs LSM Audit: rename LSM_AUDIT_NO_AUDIT to LSM_AUDIT_DATA_NONE CRED: Holding a spinlock does not imply the holding of RCU read lock SMACK: Don't #include Ext2 headers ...
2010-05-20Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: sound/soc/codecs/ad1938.c
2010-05-20Merge branch 'topic/hda' into for-linusTakashi Iwai
2010-05-20Merge branch 'topic/usb' into for-linusTakashi Iwai
2010-05-20Merge branch 'topic/jack' into for-linusTakashi Iwai
2010-05-20Merge branch 'topic/misc' into for-linusTakashi Iwai
2010-05-20Merge branch 'topic/nomm' into for-linusTakashi Iwai
2010-05-20Merge branch 'topic/core-cleanup' into for-linusTakashi Iwai
2010-05-20ALSA: hda: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-20ASoC: tpa6130a2: Remove CPVSS and HPVdd suppliesJarkko Nikula
These pins are for decoupling capacitors for the internal charge pumps in TPA6130A2 and TPA6140A2 and not for connecting external supply. Thanks to Eduardo Valentin <eduardo.valentin@nokia.com> for pointing out the issue with TPA6130A2 and Ilkka Koskinen <ilkka.koskinen@nokia.com> with TPA6140A2. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Reviewed-by: Ilkka Koskinen <ilkka.koskinen@nokia.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-19Merge branch 'for-2.6.35' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.35' of git://linux-nfs.org/~bfields/linux: (45 commits) Revert "nfsd4: distinguish expired from stale stateids" nfsd: safer initialization order in find_file() nfs4: minor callback code simplification, comment NFSD: don't report compiled-out versions as present nfsd4: implement reclaim_complete nfsd4: nfsd4_destroy_session must set callback client under the state lock nfsd4: keep a reference count on client while in use nfsd4: mark_client_expired nfsd4: introduce nfs4_client.cl_refcount nfsd4: refactor expire_client nfsd4: extend the client_lock to cover cl_lru nfsd4: use list_move in move_to_confirmed nfsd4: fold release_session into expire_client nfsd4: rename sessionid_lock to client_lock nfsd4: fix bare destroy_session null dereference nfsd4: use local variable in nfs4svc_encode_compoundres nfsd: further comment typos sunrpc: centralise most calls to svc_xprt_received nfsd4: fix unlikely race in session replay case nfsd4: fix filehandle comment ...
2010-05-19Merge branch 'nfs-for-2.6.35' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.35' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (78 commits) SUNRPC: Don't spam gssd with upcall requests when the kerberos key expired SUNRPC: Reorder the struct rpc_task fields SUNRPC: Remove the 'tk_magic' debugging field SUNRPC: Move the task->tk_bytes_sent and tk_rtt to struct rpc_rqst NFS: Don't call iput() in nfs_access_cache_shrinker NFS: Clean up nfs_access_zap_cache() NFS: Don't run nfs_access_cache_shrinker() when the mask is GFP_NOFS SUNRPC: Ensure rpcauth_prune_expired() respects the nr_to_scan parameter SUNRPC: Ensure memory shrinker doesn't waste time in rpcauth_prune_expired() SUNRPC: Dont run rpcauth_cache_shrinker() when gfp_mask is GFP_NOFS NFS: Read requests can use GFP_KERNEL. NFS: Clean up nfs_create_request() NFS: Don't use GFP_KERNEL in rpcsec_gss downcalls NFSv4: Don't use GFP_KERNEL allocations in state recovery SUNRPC: Fix xs_setup_bc_tcp() SUNRPC: Replace jiffies-based metrics with ktime-based metrics ktime: introduce ktime_to_ms() SUNRPC: RPC metrics and RTT estimator should use same RTT value NFS: Calldata for nfs4_renew_done() NFS: Squelch compiler warning in nfs_add_server_stats() ...
2010-05-19Merge branch 'bkl/procfs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'bkl/procfs' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: sunrpc: Include missing smp_lock.h procfs: Kill the bkl in ioctl procfs: Push down the bkl from ioctl procfs: Use generic_file_llseek in /proc/vmcore procfs: Use generic_file_llseek in /proc/kmsg procfs: Use generic_file_llseek in /proc/kcore procfs: Kill BKL in llseek on proc base
2010-05-19Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: Add clocksource_register_hz/khz interface posix-cpu-timers: Optimize run_posix_cpu_timers() time: Remove xtime_cache mqueue: Convert message queue timeout to use hrtimers hrtimers: Provide schedule_hrtimeout for CLOCK_REALTIME timers: Introduce the concept of timer slack for legacy timers ntp: Remove tickadj ntp: Make time_adjust static time: Add xtime, wall_to_monotonic to feature-removal-schedule timer: Try to survive timer callback preempt_count leak timer: Split out timer function call timer: Print function name for timer callbacks modifying preemption count time: Clean up warp_clock() cpu-timers: Avoid iterating over all threads in fastpath_timer_check() cpu-timers: Change SIGEV_NONE timer implementation cpu-timers: Return correct previous timer reload value cpu-timers: Cleanup arm_timer() cpu-timers: Simplify RLIMIT_CPU handling
2010-05-19Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: cs5535-clockevt: Free timer in IRQ setup error path
2010-05-19Merge branch 'timers-for-linus-hpet' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-hpet' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, hpet: Add reference to chipset erratum documentation for disable-hpet-msi-quirk x86, hpet: Restrict read back to affected ATI chipsets
2010-05-19Merge branch 'timers-for-linus-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: avr32: Fix typo in read_persistent_clock() sparc: Convert sparc to use read/update_persistent_clock cris: Convert cris to use read/update_persistent_clock m68k: Convert m68k to use read/update_persistent_clock m32r: Convert m32r to use read/update_peristent_clock blackfin: Convert blackfin to use read/update_persistent_clock ia64: Convert ia64 to use read/update_persistent_clock avr32: Convert avr32 to use read/update_persistent_clock h8300: Convert h8300 to use read/update_persistent_clock frv: Convert frv to use read/update_persistent_clock mn10300: Convert mn10300 to use read/update_persistent_clock alpha: Convert alpha to use read/update_persistent_clock xtensa: Fix unnecessary setting of xtime time: Clean up direct xtime usage in xen
2010-05-19Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Clear CPU mask in affinity_hint when none is provided genirq: Add CPU mask affinity hint genirq: Remove IRQF_DISABLED from core code genirq: Run irq handlers with interrupts disabled genirq: Introduce request_any_context_irq() genirq: Expose irq_desc->node in proc/irq Fixed up trivial conflicts in Documentation/feature-removal-schedule.txt
2010-05-20i2c-highlander: remover superflous variableWolfram Sang
When cppcheck found this flaw [./i2c/busses/i2c-highlander.c:284]: (style) Warning - using char variable in bit operation it was noted that the 'read'-variable could be simply removed as read_write can only be 0 or 1 anyhow. So, we remove the flaw and simplify the code. Reported-by: d binderman <dcb314@hotmail.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-ibm-iic: drop NO_IRQWolfram Sang
Drop NO_IRQ as 0 is the preferred way to describe 'no irq' (http://lkml.org/lkml/2005/11/21/221). This change is safe, as the driver is only used on powerpc, where NO_IRQ is 0 anyhow. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Cc: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-cpm: drop NO_IRQWolfram Sang
Drop NO_IRQ as 0 is the preferred way to describe 'no irq' (http://lkml.org/lkml/2005/11/21/221). This change is safe, as the driver is only used on powerpc, where NO_IRQ is 0 anyhow. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jochen Friedrich <jochen@scram.de> Cc: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-mpc: drop NO_IRQWolfram Sang
Drop NO_IRQ as 0 is the preferred way to describe 'no irq' (http://lkml.org/lkml/2005/11/21/221). This change is safe, as the driver is only used on powerpc, where NO_IRQ is 0 anyhow. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: Ben Dooks <ben-linux@fluff.org>
2010-05-20MAINTAINERS: add i2c tree for embedded platformsUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2010-05-20i2c-pxa: only define 'blue_murder'-function if DEBUG is #definedWolfram Sang
This talkative function is also called on timeouts. As timeouts can happen on regular writes to EEPROMs (no error case), this creates false positives. Giving lots of details is interesting only for developers anyhow, so just use the function if DEBUG is #defined. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Eric Miao <eric.y.miao@gmail.com> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Pavel Machek <pavel@ucw.cz>
2010-05-20i2c-pxa: remove unused macroUwe Kleine-König
Commit beea494 ([ARM] Remove EEPROM slave emulation from i2c-pxa driver.) removed all uses of eedbg, so the definition can go, too. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Roel Kluin <roel.kluin@gmail.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2010-05-20i2c-nomadik: fix operator precedence warningRabin Vincent
Fix this warning: i2c-nomadik.c:707: warning: suggest parentheses around operand of '!' or change '&' to '&&' or '!' to '~' Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-nomadik: release region when removedRabin Vincent
So that the module can be loaded again after an unload. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20OMAP3: I2C: Clean up Errata 1p153 handlingmanjugk manjugk
Clean up existing Errata 1p153 handling to use generic errata handling mechanism through dev flag. Signed-off-by: Manjunatha GK <manjugk@ti.com> Cc: Nishanth Menon <nm@ti.com> Cc: Alexander Shishkin <virtuoso@slind.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20OMAP2/3: I2C: Errata ID i207: Clear wrong RDR interruptmanjugk manjugk
Under certain rare conditions, I2C_STAT[13].RDR bit may be set and the corresponding interrupt fire, even there is no data in the receive FIFO, or the I2C data transfer is still ongoing. These spurious RDR events must be ignored by the software. This patch handles and ignores RDR spurious interrupts. The below sequence is required in interrupt handler for handling this errata: 1. If RDR is set to 1, clear RDR 2. Read I2C status register and check for BusBusy bit. If BusBusy bit is set, skip remaining steps. 3. If BusBusy bit is not set, perform read operation on I2C status register. 4. If RDR is set, clear the same. Check RDR again and clear if it sets RDR bit again. 5. Perform I2C Data Read operation N number of times(where N is value read from the register BUFSTAT-RXSTAT bit fields). Note: This errata is not applicable for omap2420 and omap4. It is applicable for: 1. omap2430 2. omap34xx(including omap3630). Signed-off-by: Manjunatha GK <manjugk@ti.com> Cc: Hema Kalliguddi <hemahk@ti.com> Cc: Nishanth Menon <nm@ti.com> Cc: Aaro Koskinen <Aaro.Koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20omap: i2c: add a timeout to the busy waitingAlexander Shishkin
The errata 1.153 workaround is busy waiting on XUDF bit in interrupt context, which may lead to kernel hangs. The problem can be reproduced by running the bus with wrong (too high) speed. Signed-off-by: Alexander Shishkin <virtuoso@slind.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20omap: i2c: make errata 1.153 workaround a separate functionAlexander Shishkin
This is to avoid insanely long lines and levels of indentation. Signed-off-by: Alexander Shishkin <virtuoso@slind.org> Cc: Nishant Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-omap: add mpu wake up latency constraint in i2cKalle Jokiniemi
While waiting for completion of the i2c transfer, the MPU could hit OFF mode and cause several msecs of delay that made i2c transfers fail more often. The extra delays and subsequent re-trys cause i2c clocks to be active more often. This has also an negative effect on power consumption. Created a mechanism for passing and using the constraint setting function in driver code. The used mpu wake up latency constraints are now set individually per bus, and they are calculated based on clock rate and fifo size. Thanks to Jarkko Nikula, Moiz Sonasath, Paul Walmsley, and Nishanth Menon for tuning out the details of this patch. Updates by Kevin as requested by Tony: - Remove omap_set_i2c_constraint_func() in favor of conditionally adding the flag in omap_i2c_add_bus() in order to keep all the OMAP conditional checking in a single location. - Update set_mpu_wkup_lat prototypes to match OMAP PM layer so OMAP PM function can be used directly in pdata. Cc: Moiz Sonasath <m-sonasath@ti.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Kalle Jokiniemi <kalle.jokiniemi@digia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20omap: i2c: Add i2c support on omap4 platformSantosh Shilimkar
This patch is rebased version of earlier post to add I2C driver support to OMAP4 platform. On OMAP4, all I2C register address offsets are changed from OMAP1/2/3 I2C. In order to not have #ifdef's at various places in code, as well as to support multi-OMAP build, an array is created to hold the register addresses with it's offset. This patch was submitted, reviewed and acked on mailing list already. For more details refer below link http://www.mail-archive.com/linux-i2c@vger.kernel.org/msg02281.html This updated verion has a depedancy on "Add support for 16-bit registers" posted on linux-omap. Below is the patch-works link for the same http://patchwork.kernel.org/patch/72295/ Signed-off-by: Syed Rafiuddin <rafiuddin.syed@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Reviewed-by: Paul Walmsley <paul@pwsan.com> Cc: Cory Maccarrone <darkstar6262@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-bfin-twi: return completion in interrupt for smbus quick transfersSonic Zhang
A smbus quick transfer has no data after the address byte. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-bfin-twi: remove redundant retrySonic Zhang
2010-05-20i2c-bfin-twi: fix lost interrupts at high speedsSonic Zhang
i2c event of next read/write byte may trigger before current int state is cleared in the interrupt handler. So, this should be done at the beginning of interrupt handler to avoid losing new i2c events. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-bfin-twi: add debug output for error statusMichael Hennerich
Add some debug() code to decode the error register. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-bfin-twi: integrate timeout timer with completion interfaceSonic Zhang
There isn't much point in managing our own custom timeout timer when the completion interface already includes support for it. This makes the resulting code much simpler and robust. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20i2c-s3c2410: Remove unconditional 1ms delay on each transferMark Brown
The S3C I2C controller indicates completion of I2C transfers before the bus has a stop condition on it. In order to ensure that we do not attempt to start a new transfer before the bus is idle the driver currently inserts a 1ms delay. This is vastly larger than is generally required and has a visible effect on performance under load, such as when bringing up audio CODECs or reading back status information with non-bulk I2C reads. Replace the sleep with a spin on the IIC status register for up to 1ms. This will busy wait but testing on my SMDK6410 system indicates that the overwhelming majority of transactions complete on the first spin, with maximum latencies of less than 10 spins so the absolute overhead of busy waiting should be at worst comprable to msleep(), and the overall system performance is dramatically improved. The main risk is poor interaction with multimaster systems where we may miss the bus going idle before the next transaction. Defend against this by falling back to the original 1ms delay after 20 spins. The overall effect in my testing is an approximately 20% improvement in kernel startup time. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-19Merge branch 'msm-core' of git://codeaurora.org/quic/kernel/dwalker/linux-msmLinus Torvalds
* 'msm-core' of git://codeaurora.org/quic/kernel/dwalker/linux-msm: (72 commits) msm: 7x30 Kconfig and makefile changes msm: clock support for the MSM7x30 CPU. msm: physical offset for MSM7X30 msm: io: add io support for 7x30 msm: Add extern for 7x30 clock list. msm: dma: add 7x30 security domain abstraction msm: update basic board layout for MSM7x30 msm: add devices-msm7x30.c msm: add msm_iomap-7x30.h for MSM7x30 support msm: irqs: add irqs-7x30.h for MSM7x30 support msm: 8x50 Kconfig changes msm: physical offset for QSD8x50 msm: io: add io support for 8x50 msm: add extern for 8x50 clock list. msm: add devices-qsd8x50.c msm: update basic board layout for QSD8x50 msm: add msm_iomap-8x50.h for QSD8x50 support msm: irqs: add irqs-8x50.h for QSD8x50 support msm: timer: allow MSM_DGT_BASE to be overriden msm: add Qualcomm 7x30 interrupt controller driver. ...
