2006-09-16[PATCH] Add mixed source and assembly listings (*.lst) to .gitignoreJosh Triplett
The kernel build system supports making mixed source and assembly listings (*.lst) from C source files. Add these files to .gitignore. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] Add preprocessed files (*.i) to .gitignoreJosh Triplett
The kernel build system supports making preprocessed files (*.i) from C source files. Add these files to .gitignore. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] IPMI: fix handling of OEM flagsCorey Minyard
If one of the OEM flags becomes set in the flags from the hardware, the driver could hang if no OEM handler was set. Fix the code to handle this. This was tested by setting the flags by hand after they were fetched. Signed-off-by: Corey Minyard <minyard@acm.org> Ackde-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] Add a missing space that prevents building modules that require host ↵Ross Biro
programs Signed-off-by: Ross Biro <rossb@google.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] hvc_console suspend fixAndrew Morton
Fix http://bugzilla.kernel.org/show_bug.cgi?id=7152 Cc: Michael Tautschnig <tautschn@model.in.tum.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] knfsd: Make ext3 reject filehandles referring to invalid inode numberNeilBrown
Inodes earlier than the 'first' inode (e.g. journal, resize) should be rejected early - except the root inode. Also inode numbers that are too big should be rejected early. [akpm@osdl.org: cleanup] Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] knfsd: Have ext2 reject file handles with bad inode numbers earlyNeilBrown
This prevents bad inode numbers from triggering errors in ext2_get_inode. [akpm@osdl.org: speedup, cleanup] Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] IPMI: Fix oops on ipmi_msghandler removal for non ipmi systemsArnaud Patard
When the ipmi_si module is loaded on a system without any ipmi device, it fails with nodev. It would be fine if all resources were freed. A call to device_unregister() is missing, resulting to a oops when you remove the ipmi_msghandler. Signed-off-by: Arnaud Patard <apatard@mandriva.com> Acked-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] genirq: fix typo in IRQ resendImre Deak
Fix a bug where the IRQ_PENDING flag is never cleared and the ISR is called endlessly without an actual interrupt. Signed-off-by: Imre Deak <imre.deak@solidboot.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Fix G5 DART (IOMMU) race causing occasional data corruption [POWERPC] Fix MMIO ops to provide expected barrier behaviour [POWERPC] Fix interrupt clearing in kdump shutdown sequence [POWERPC] update prep_defconfig [POWERPC] kdump: Support kernels having 64k page size. [POWERPC] Implement PowerPC futex_atomic_cmpxchg_inatomic(). [POWERPC] Add new, missing argument to of_irq_map_raw() for 86xx. [POWERPC] Update defconfigs
2006-09-13[PATCH] cciss: version update, new hwMike Miller
Add support for new hardware and bumps the version to 3.6.10. It seems there were several changes introduced including soft_irq. I decided to bump the major number to reflect these changes. Since we're still supporting older vendor kernels I need some way differentiate between kernel versions <=2.6.10 and newer kernels >=2.6.16. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: fix userspace build of asm-mips/page.hDavid Woodhouse
MIPS asm/page.h unconditionally includes <asm-generic/memory_model.h>, which doesn't exist in userspace. Move an #endif /* __KERNEL__ */ down a few lines to prevent that. Also, remove the broken definition of PAGE_SIZE which is never going to be correct -- in the absence of PAGE_SIZE, non-broken userspace will fall back to using sysconf() or getpagesize() instead. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: don't expose PFN stuff to userspace in <asm-i386/setup.h>David Woodhouse
The header file <linux/pfn.h> doesn't exist in userspace and probably shouldn't -- but it's used unconditionally in <asm-i386/setup.h>. Protect it with #ifdef __KERNEL__ and move setup.h from $(header-y) to $(unifdef-y) in Kbuild accordingly. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: move kernel-only #includes within <asm-i386/elf.h>David Woodhouse
Some files which don't exist in userspace were being included unconditionally in asm-i386/elf.h. Move the offending #includes down a few lines so that they're protected by #ifdef __KERNEL__ In fact, we probably want to kill off all userspace use of asm/elf.h -- but we aren't there yet, so we should at least make it possible to include it for now. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: move inclusion of <linux/linkage.h> in ↵David Woodhouse
<asm-i386/signal.h> Because <linux/linkage.h> doesn't exist in userspace, it should be only included from within #ifdef __KERNEL__. Move the corresponding #include Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: remove <asm/timex.h> from user exportDavid Woodhouse
There's useful stuff in <linux/timex.h> but <asm/timex.h> has nothing for userspace. Stop exporting it, and include it only from within the existing #ifdef __KERNEL__ part of <linux/timex.h> This fixes a 'make headers_check' failure on i386 because asm-i386/timex.h includes both asm-i386/tsc.h and asm-i386/processor.h, neither of which are exported to userspace. It's not entirely clear _why_ it includes either of these, but it does. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: reduce user-visible noise in <linux/nfs_fs.h>David Woodhouse
We don't need any of this crap included from the user-visible part of nfs_fs.h -- remove it all. In fact, we probably don't need anything but NFS_SUPER_MAGIC to be defined; is there any need for anything else? And magic numbers should probably move to <linux/magic.h> rather than being strewn across various fs-specific include files which exist in userspace for solely that purpose. With this patch, 'make header_check' works again at least on PowerPC. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: clarify error messageAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: improve #include regexpAlexey Dobriyan
The following combinations of pp-tokens are used #include #include # include so, script'd better check for all of them. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] x86: reserve a boot-loader ID number for XenJeremy Fitzhardinge
Claim an ID number for Xen in the LOADER_TYPE field. Also, keep the table in zero-page.txt consistent with boot.txt. [hpa says: 6 was skipped because I couldn't rule out that it hadn't been unofficially used. It seemed easier to skip it for now.] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] rcu_do_batch: make ->qlen decrement irq safeOleg Nesterov
rcu_do_batch() decrements rdp->qlen with irqs enabled. This is not good, it can also be modified by call_rcu() from interrupt. Decrement ->qlen once with irqs disabled, after a main loop. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] SCSI: lockdep annotation in scsi_send_eh_cmndStefan Richter
Fixup for lockdep enabled kernels: Annotate an on-stack completion. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] alim15x3.c: M5229 (rev c8) support for DMA cd-writerMichael De Backer
Configuration bits are not set properly for DMA on some chipset revisions. It has already been corrected for M5229 (rev c7) but not for M5229 (rev c8). This leads to the bug described at http://bugzilla.kernel.org/show_bug.cgi?id=5786 (lost interrupt + ide bus hangs). Signed-off-by: Michael De Backer <micdb@skynet.be> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] We can not allow anonymous contributions to the kernelGreg KH
The DCO does not mean anything if we allow anonymous contributors to the kernel. As this is an open source project, we need to do everything in the open. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] lockdep: double the number of stack-trace entriesIngo Molnar
Miles Lane reported the "BUG: MAX_STACK_TRACE_ENTRIES too low!" message, which means that during normal use his system produced enough lockdep events so that the 128-thousand entries stack-trace array got exhausted. Double the size of the array. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Miles Lane <miles.lane@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] libata: ignore CFA signature while sanity-checking an ATAPI deviceTejun Heo
0x848a in ID word 0 indicates CFA device iff the ID data is obtained from IDENTIFY DEVICE. For ATAPI devices, 0x848a in ID work 0 indicates valid ATAPI device. Fix sanity check in ata_dev_read_id() such that ATAPI devices reporting 0x848a in ID word 0 is not handled as error. The problem is identified by J.A. Magallon with HL-DT-ST DVDRAM GSA-4120B. Signed-off-by: Tejun Helo <htejun@gmail.com> Cc: J.A. Magallon <jamagallon@ono.com> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[POWERPC] Fix G5 DART (IOMMU) race causing occasional data corruptionBenjamin Herrenschmidt
It seems that the occasional data corruption observed with the tg3 driver wasn't due to missing barriers after all, but rather seems to be due to the DART (= IOMMU) in the U4 northbridge reading stale IOMMU table entries from memory due to a race. This fixes it by making the CPU read the entry back from memory before using it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13[POWERPC] Fix MMIO ops to provide expected barrier behaviourPaul Mackerras
This changes the writeX family of functions to have a sync instruction before the MMIO store rather than after, because the generally expected behaviour is that the device receiving the MMIO store can be guaranteed to see the effects of any preceding writes to normal memory. To preserve ordering between writeX and readX, and to preserve ordering between preceding stores and the readX, the readX family of functions have had an sync added before the load. Although writeX followed by spin_unlock is not officially guaranteed to keep the writeX inside the spin-locked region unless an mmiowb() is used, there are currently drivers that depend on the previous behaviour on powerpc, which was that the mmiowb wasn't actually required. Therefore we have a per-cpu flag that is set by writeX, cleared by __raw_spin_lock and mmiowb, and tested by __raw_spin_unlock. If it is set, __raw_spin_unlock does a sync and clears it. This changes both 32-bit and 64-bit readX/writeX. 32-bit already has a sync in __raw_spin_unlock (since lwsync doesn't exist on 32-bit), and thus doesn't need the per-cpu flag. Tested on G5 (PPC970) and POWER5. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13[POWERPC] Fix interrupt clearing in kdump shutdown sequenceMohan Kumar M
Call chip->eoi(irq) to clear any pending interrupt in case of kdump shutdown sequence. chip->end(irq) does not serve this purpose. Signed-off-by: Mohan Kumar M <mohan@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13[POWERPC] update prep_defconfigOlaf Hering
Update PReP defconfig, disable some drivers for hardware that is not used on those systems; enable SL82C105 IDE driver for Powerstack. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13[POWERPC] kdump: Support kernels having 64k page size.Sachin P. Sant
This is required to generate proper core files using kdump on ppc64. Create a backup region of 64K size irrespective of the PAGE SIZE. At present 32K was used as backup size. In the case of 64K page size, second PT_LOAD segments starts at 32K and the first one is not page aligned. __ioremap() (crash_dump.c) fails if pfn = 0 which is the case for the second PT_LOAD segment. This is not an issue for 4K page size because the the first page (32K backup) is copied to second kernel memory and thus referencing with the second kernel pfn. Signed-off-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13[POWERPC] Implement PowerPC futex_atomic_cmpxchg_inatomic().David Woodhouse
The sys_[gs]et_robust_list() syscalls were wired up on PowerPC but didn't work correctly because futex_atomic_cmpxchg_inatomic() wasn't implemented. Implement it, based on __cmpxchg_u32(). Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13[POWERPC] Add new, missing argument to of_irq_map_raw() for 86xx.Jon Loeliger
Ben speaks; we follow. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-12Linux v2.6.18-rc7v2.6.18-rc7Linus Torvalds
One last time..
2006-09-12Merge branch 'audit.b29' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b29' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] sparc64 audit syscall classes hookup [PATCH] syscall class hookup for all normal targets
2006-09-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] Fix CIFS readdir access denied when SE Linux enabled
2006-09-12Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: V4L/DVB (4608c): Fix I2C dependencies for saa7146 modules V4L/DVB (4608b): i2c deps fix on DVB V4L/DVB (4605): Fixes an issue with V4L1 and make headers-install V4L/DVB (4520): Fix an error when loading bttv driver on PV M4900. V4L/DVB (4511): Restore tuner_ymec_tvf66t5_b_dff_pal_ranges[] to fix UHF switch functionality V4L/DVB (4494a): Fix compilation when V4L1 support is not present
2006-09-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: Fix unload oops and memory leak in yealink driver usbserial: Reference leak
2006-09-12Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6: sh64: Add a sane pm_power_off implementation. sh64: Use generic BUG_ON()/WARN_ON(). sh64: Trivial build fixes. sh64: Drop deprecated ISA tuning for legacy toolchains.
2006-09-12Merge git://oss.sgi.com:8090/xfs/xfs-2.6Linus Torvalds
* git://oss.sgi.com:8090/xfs/xfs-2.6: [XFS] Fix a bad pointer dereference in the quota statvfs handling. [XFS] Fix xfs_splice_write() so appended data gets to disk. [XFS] Fix ABBA deadlock between i_mutex and iolock. Avoid calling [XFS] Prevent free space oversubscription and xfssyncd looping.
2006-09-12USB: Fix unload oops and memory leak in yealink driverHenk Vergonet
This patch fixes a memory leak and a kernel oops when trying to unload the driver, due to an unbalanced cleanup. Thanks Ivar Jensen for spotting my mistake. Signed-off-by: Henk Vergonet <henk.vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-12usbserial: Reference leakMatthias Urlichs
A sufficiently-large number of USB serial devices causes a reference leak when /proc/tty/drivers/usbserial is read. Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-12[PATCH] sparc64 audit syscall classes hookupAl Viro
... that should do it for all targets; the only remaining issues are mips (currently treated as non-biarch) and handling of other OS emulations (OSF/SunOS/Solaris/???). The latter would need to be assigned new AUDIT_ARCH_... ABI numbers anyway... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-09-12[PATCH] syscall class hookup for all normal targetsAl Viro
Take default arch/*/kernel/audit.c to lib/, have those with special needs (== biarch) define AUDIT_ARCH in their Kconfig. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-09-12sh64: Add a sane pm_power_off implementation.Paul Mundt
sh64 wasn't providing a sensible pm_power_off(), add one, and just wrap it to machine_power_off, which already does the right thing. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-12sh64: Use generic BUG_ON()/WARN_ON().Paul Mundt
sh64 doesn't need to do anything special for BUG_ON() or WARN_ON(), use the generic versions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-12sh64: Trivial build fixes.Paul Mundt
While we've been sorting out the toolchain fiasco, some of the code has suffered a bit of bitrot. Building with GCC4 also brings up some more build warnings. Trivial fixes for both issues. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-12sh64: Drop deprecated ISA tuning for legacy toolchains.Paul Mundt
The original sh64 toolchains required that we tune the ISA level accordingly to not have head.S/entry.S blow up. With current toolchains, this is no longer the case, and the syntax magically changed as well, causing all current toolchains to die a horrible death. Incidentally, code generation in other parts of the kernel is now significantly complex enough that none of the older toolchains make it very far these days, so there's not even any point in preserving legacy compatability via as-option. This fixes a long-standing issue, as noted here: http://lkml.org/lkml/2005/1/5/223 Though at the time the current toolchains were too broken to make adjusting the tuning worthwhile. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-11Merge branch 'audit.b28' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b28' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] audit: AUDIT_PERM support [PATCH] audit: more syscall classes added [PATCH] syscall classes hookup for ppc and s390 [PATCH] update audit rule change messages [PATCH] sanity check audit_buffer [PATCH] fix ppid bug in 2.6.18 kernel
2006-09-11Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: usbtouchscreen: fix ITM data reading USB: New device ID for ftdi_sio usb serial driver USB: Support for USB20SVGA-WH & USB20SVGA-DG USB: hid-core.c: fix duplicate USB_DEVICE_ID_GTCO_404
