bug 949219
Change-Id: I4409eaff4042967133cc948452ca8e52d15b2d18
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92279
GVS: Gerrit_Virtual_Submit
bug 949219
Change-Id: I408fb008a70c7ea546384e68ac50c1f0604fc39a
Reviewed-on: http://git-master/r/92276
If there is no dma information exit from trigger, this is required
for the dummy voice call playback and capture streams
Change-Id: I5276e7ebb72c17268a9785204fea9f395b2e5d3a
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/101235
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Use non-inverting type alsa control for headphones as same have
been used for spk and recv
Change-Id: I39d2613071063782dff8151b07ef46ca8e16db5c
Reviewed-on: http://git-master/r/101234
disable the flags for turning off the mini dsp support
Change-Id: Ieb0b18fc3cc1143cbd0a315c85688d2f1ae4efe1
Reviewed-on: http://git-master/r/101233
Tested-by: Nikesh Oswal <noswal@nvidia.com>
changed the max avp clock from 378MHz to 334MHz as per new POR changes
Bug 883565
Change-Id: I4e9dda0288f3f85c8b1705971bb8f389127cff28
Reviewed-on: http://git-master/r/97279
Signed-off-by: Mohit Kataria <mkataria@nvidia.com>
Reviewed-on: http://git-master/r/100870
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Do not use nb_channels to find out the number of client devices.
Instead, allocate devno regions when they are needed and find a
device by module id by iterating over nvhost bus.
Bug 871237
Change-Id: I53fd0d8e5874422ef9877430c0a170db2660118a
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/99067
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
bug 949219
Change-Id: Ied38dc0ff7ade8b15561747cde6d552f2597e9e6
Reviewed-on: http://git-master/r/92307
bug 949219
Change-Id: Ia7d23d3aab631e6a78c53518bc1f608d46e8f341
Reviewed-on: http://git-master/r/92260
Call dc_hdmi_mode_filter to validate a videomode. X prepares its
own modedb of supported HDMI modes, but all of them may not be
supported from the HDMI driver. This call makes sure a X-mode is
listed only if supported in DC driver.
Bug: 959676
Change-Id: I8aff65f4e08fcc4471af096150e3972b5913a95a
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/99650
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Modified board file to increase the speed of I2C connection
for Atmel touch driver from 100KHz to 400KHz
Bug 962710
Change-Id: Ic692a4b610c5b952c1bdcfbb26e19714b1952a5f
Signed-off-by: David Jung <djung@nvidia.com>
Reviewed-on: http://git-master/r/98585
Reviewed-by: Ali Ekici <aekici@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Set default videomode during the dc probe. This patch enables
HDMI during the probe only and fixes following issues:
1. Until Xinit there was no display on HDMI.
2. Framebuffer console on HDMI needs it to be enabled well before
Xinit.
To avoide un-necessary powering on HDMI,Check HPD and enable HDMI
only if it's present.
Bug: 930136
Bug: 977705
Change-Id: Ifb71328e5df0ccbb5751669db71fd24719fe3738
Reviewed-on: http://git-master/r/100656
Add gpio irq masking in irq_sync_unlock.
Change-Id: I008caf58ae82d9ed888f4720f54675e9106f027d
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/98664
Reviewed-by: Simone Willett <swillett@nvidia.com>
Some boards don't have a vddio regulator for few rails hence not getting
the regulator handle. And we assume that those rails are always powered.
Hence rephrased the error message and lowered the loglevel to KERN_INFO.
Bug 976177
Change-Id: I92b82f75934eaf7137584a625065e3389b6ae1b7
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/100490
Bug 962710
Bug 950422
Change-Id: Ib0f08af35d84cfc1f33cc3771d2aa422f79d98d0
Signed-off-by: Ali Ekici <aekici@nvidia.com>
Reviewed-on: http://git-master/r/97744
Reviewed-by: Robert Collins <rcollins@nvidia.com>
Reviewed-by: David Jung <djung@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Fix fps update condition in max77663_regulator_set_fps().
Bug 930883
Change-Id: I2f57603320a91b2727932586fc3c66d9de347d64
signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/92707
Unmasked EN0 rising interrupt to generate fast PMU_INT by
EN0(POWER_KEY).
Bug 930883
Change-Id: I9a3d8c4f564e83deea86fbd3d05f14933a0b0f65
Reviewed-on: http://git-master/r/98665
Remove UART clock enable code, as UART clock gating is not
needed in tibluesleep driver.
Remove un-wanted tasklets, workqueues and wakelocks
Remove extra lines and spaces
Change-Id: I422e09ece2c736c4a98911a5bd84029ad654cb08
Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com>
Reviewed-on: http://git-master/r/96944
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
bug 978829
Reviewed-on: http://git-master/r/99460
(cherry picked from commit b5531673e3da75f2406685ce377f39d76f494162)
Change-Id: I5280dedb460df9852cc39d1c17132319e202c7b2
Reviewed-on: http://git-master/r/100524
To have the proper LP0 exit power sequence, it is require to
wakeup system through tegra gpio rather than PMU-INT.
bug 957972
Reviewed-on: http://git-master/r/100107
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Cherry-picked commit ffe8e102d91c5eafc0b71b044b97fe9e8cef7463
Change-Id: I0518e46b43ec36ba6e076a946da2d395cd31777e
Reviewed-on: http://git-master/r/100521
Add locked version of round rate API to be used by tegra arch
specific layer.
Signed-off-by: Alex Frid <afrid@nvidia.com>
(cherry picked from commit 457627966b91f2141439812869adc4acf9242471)
Change-Id: Id68d0bb952d1e7d9e650341872d1b06b0b2d3cea
Reviewed-on: http://git-master/r/100474
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Bug 947861
Change-Id: Ib4ce7bfa3624562a766678a2ef20ebdcd3055d89
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/100462
Reviewed-by: Bo Yan <byan@nvidia.com>
Bug 947861
Change-Id: I1ac97b5de5e7e79a418b3c38c70df4976616cdf3
Reviewed-on: http://git-master/r/100457
Add config option to enable/disable nvmap page pools.
Change-Id: I873e81a675fecd768534d4ce03c2f8fdd3c6a063
Reviewed-on: http://git-master/r/100424
TEGRA_GPIO_PCC7(PEX_L2_CLKREQ) is used as the pull up source to pull up
other pins in schematic. So set it to high default.
bug 949026
Change-Id: I5a4d806ec4b54969514547472cd08018d285ced5
Signed-off-by: Hunk Lin <hulin@nvidia.com>
Reviewed-on: http://git-master/r/99778
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Enable CONFIG_PREINIT_CLOCKS.
bug 967065
Change-Id: Ib6675f9bff6729ffe7dfcd8b753c42b5d32240e4
Signed-off-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/99517
Changed the suspend resume logic as per new
UDC driver. Also, added few debug prints.
Bug 887361
Change-Id: I36ec1f160e8b4db54b5bd2153bdbf1c4fae1cc2a
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/99450
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Enable tegra udc driver.
Bug 887361
Change-Id: Iaac2486d2a05454fa351920d5c65d17b9c2a881b
Reviewed-on: http://git-master/r/99449
Update the clocks structure to use new udc driver
name. Also, update the device structure.
Bug 887361
Change-Id: I0fd846ab177e8651f285bcb9796361d30967b830
Reviewed-on: http://git-master/r/99448
Add High-speed USB device controller driver for tegra chips.
This can work in OTG device mode with tegra OTG driver.
Driver currently supports only UMTIP PHY.
Bug 887361
Change-Id: I63774a44e3bb607c93007b170ba8b811f96e43f8
Reviewed-on: http://git-master/r/97918
Export tegra_powergate_is_powered() for use by modules.
Change-Id: I8cfbb8aeb95dca00cbf6ef0c8c2bd189afeb62b6
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-on: http://git-master/r/97724
Disable internal temperature sensor and enable external temperature
sensor.
This is a modified version of change
74db6e22d316a95630d3059644fbc55e2620cb9b
Bug 954134
Change-Id: Id64bb93a09e1701165ad1f82e08bb92e61425873
Signed-off-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-on: http://git-master/r/96285
Waking up system through the tegra gpio inplace of ricoh onkey
when using the ricoh based pmu.
bug 978922
Change-Id: If9c5baffa42aca5fcc7d6238c5cf122a136e7760
Reviewed-on: http://git-master/r/100351
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
when update_cdma_locked() is invoked, CDMA is not running
implies that the queue is cleared and we can return immediately.
Bug 960487
Change-Id: I599027906dc405f4490590443d4f4d5a3202b5b0
Reviewed-on: http://git-master/r/96650
(cherry picked from commit f297b4812d15540f4b14c87178662a7ca6575ce9)
Reviewed-on: http://git-master/r/99994
Clean up #includes. Replace #includes with forward declarations where
possible, and remove extraneous #includes.
Bug 871237
Change-Id: I6942e0c632b42ad7009589ebdd78def88ae4baa4
Reviewed-on: http://git-master/r/99046
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Bug 935079
Signed-off-by: Ray Poudrier <rapoudrier@nvidia.com>
Reviewed-on: http://git-master/r/86009
(cherry picked from commit 83eb3734f76e598d570dd9624e7e06f8b3e05afe)
Change-Id: I5911670e7c1e8dd5fc4e89d4be21b9dcbc4c9085
Reviewed-on: http://git-master/r/98535
Reviewed-by: Raymond Poudrier <rapoudrier@nvidia.com>
Tested-by: Raymond Poudrier <rapoudrier@nvidia.com>
The sequence of read fuse id is:
1. write to OTP index register 0x3d00.
2. read out byte from ox3d04.
3. repeat step 1 to the next byte with its index respectively.
also fixed ov5650_read_reg always fail issue.
bug 957657
Change-Id: I649a7765320d0d4be8111a7f523d8487b872b620
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/98330
Reviewed-by: Wei Chen <wechen@nvidia.com>
Reviewed-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Change-Id: Id71da6f6371f337f913d981f6d121c3fb2561a41
Reviewed-on: http://git-master/r/95915
Under some rare circumstances, an uncacheable load multiple
instruction (LDRD, LDM, VLDM, VLD1, VLD2, VLD3, VLD4) can cause
a processor deadlock.
Change-Id: Ibd79aa8182dce37d0be9892f2310735e1123618a
Reviewed-on: http://git-master/r/95914
Bug 950086
Change-Id: I2eb129566bfea83b9a73d29f0c6443bdab087b65
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/95518
Reviewed-by: Andy Park <andyp@nvidia.com>
Change-Id: I0931f4ef7a5464dd32d8c703288a137fc77857ce
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/100090
Add TEGRA_PREINIT_CLOCKS option to put host1x, disp1, and video clocks
into known state, so that L4T Ventana/Harmony works on u-boot.
bug 967065
Change-Id: If7637b13e0daf1823fa0fe694a87870f4601e4df
Reviewed-on: http://git-master/r/95734
We found missed irq could be happened if clear all INT_STS_x register in one time.
Shadow register pushes the irq status after the first byte of INT_STS_x was cleared
The proposed way to clear interrupt is to write only one INT_STS_x register.
It will also clear the other two ones.
Bug 952476
Reviewed-on: http://git-master/r/93453
Signed-off-by: Steve Kuo <stevek@nvidia.com>
(cherry picked from commit 0c92f32e9e03defaeac991518b26134e59ef4db6)
Change-Id: I76179be4847f59a1687926b9b0dde6ebd3f58aa4
Reviewed-on: http://git-master/r/100306
LDO3 has the input from the VIO output and hence VIO should be
register before LDO3 for regulator registration.
bug 976254
Reviewed-on: http://git-master/r/99446
Change-Id: I6771af3e7eb93886e974695ab3550cdf8ebc52c4
Reviewed-on: http://git-master/r/100262
Setting i2c drive strenth to maximum and pulling all pins
to high.
bug 951052
bug 958415
bug 927583
Reviewed-on: http://git-master/r/91805
Change-Id: Ia2bf4ccba6d4c47411e59fb9567dc4e3c2db76ae
Reviewed-on: http://git-master/r/100261
Setting drive strength to maiximum for all i2c pins.
Reviewed-on: http://git-master/r/91952
Change-Id: I8882dd238af34e06c924f2e160d0897111e8103d
Reviewed-on: http://git-master/r/100260
Configuring all i2c controller to have slave addresss to 0xFC
(unused slave address) to avoid responding the slave with general
call address.
Reviewed-on: http://git-master/r/91951
Change-Id: Id1a45f46cfc5ffa3a48b01c0bae71c4ee9ab699b
Reviewed-on: http://git-master/r/100259
This reverts commit 9349cedf17f9b3c10760c8d48f831473f87a3a15.
It is reviewed on http://git-master/r/99635
It will cause HDMI power ON and emc clock bump up to 667Mhz
after resume from LP0.
bug 930136
Change-Id: I130494fdb381b3d322ac0e3fc8be2e44f2c2d7a7
Reviewed-on: http://git-master/r/100202
On Tegra3 make sure cpu rate is within G-mode range before LP to G
mode switch triggered by minimum CPUs notifier.
Bug 964208
Change-Id: Ic4ee6bc7eca5ad0902da4907e4702f296a155280
Reviewed-on: http://git-master/r/99834
LCD_D8 used for BAT_REMOVAL staus from PMU to be
programmed as input/tristate to in line with hardware
schematics. It is connected VIO_IN
Bug 955519
(Cherry picked from I692d8d805c54da3996c33b9837b197a6995689c8)
Change-Id: I68e6566249675cd5fce8aa954983478e4fc29a4c
Reviewed-On: http://git-master/r/#change,91589
Signed-off-by: Karthik Ramakrishnan <karthikr@nvidia.com>
Reviewed-on: http://git-master/r/99742
