2007-10-10cxgb3 - remove false positive in xgmac workaroundDivy Le Ray
Qualify toggling of xgmac tx enable with not getting pause frames, we might not make forward progress because the peer is sending lots of pause frames. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - log and clear PEX errorsDivy Le Ray
Clear pciE PEX errors late at module load time. Log details when PEX errors occur. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - Firmware updateDivy Le Ray
Update firmware version. Allow the driver to be up and running with older FW image Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10e100: timer power savingStephen Hemminger
Since E100 timer is 2HZ, use rounding to make timer occur on the correct boundary. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10ixgbe: driver for Intel(R) 82598 PCI-Express 10GbE adapters (v4)Auke Kok
This patch adds support for the Intel 82598 PCI-Express 10GbE chipset. Devices will be available on the market soon. This version of the driver is largely the same as the last release: * Driver uses a single RX and single TX queue, each using 1 MSI-X irq vector. * Driver runs in NAPI mode only * Driver is largely multiqueue-ready (TM) Changes since 20070803: * removed wrappers for hardware functions * incorporated e1000e-style HW api reorganization code * sparse/checkpatch cleanups, namespace cleanups * driver prints out extra debugging information at load time identifying adapter board number, mac, phy types * removed ixgbe_api.c, ixgbe_api.h, ixgbe_osdep.h * driver update to 1.1.18 * removed ixgbe.txt which contained no useful info anymore [ Integrated napi_struct changes from Auke as well... -DaveM ] Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Ayyappan Veeraiyan <ayyappan.veeraiyan@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10PS3: Remove the workaround no longer neededMasakazu Mokuno
Removed the workaround that was needed for PS3 firmware versions prior to the first release. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> CC: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10PS3: changed the way to handle tx skbsMasakazu Mokuno
The PS3 virtual network device requires a vlan tag in the sending packet to select the destination device, ethernet port or wireless. As the vlan tag field is in the middle of the passed data, we should insert it into the packet data. To avoid copying much of the packet data, the driver used two tx descriptors for one tx skb; one descriptor was for sending a small static buffer which contained vlan tag and copied header (two mac addresses), one was for the residual data after the vlan field. This patch changes the way to insert the vlan tag. By changing netdev->hard_header_len, we can make the headroom for moving mac address fields in the skb buffer. Then we can send one tx skb with one tx descriptor. This also gives us a tx throughut gain of approx. 20% according to netperf results. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> CC: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10pasemi_mac: Clean TX ring in pollOlof Johansson
Unfortunately there's no timeout for how long a packet can sit on the TX ring after completion before an interrupt is generated, and we want to have a threshold that's larger than one packet per interrupt. So we have to have a timer that occasionally cleans the TX ring even though there hasn't been an interrupt. Instead of setting up a dedicated timer for this, just clean it in the NAPI poll routine instead. [ Resolved conflicts with napi_struct changes... -DaveM ] Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10pasemi_mac: Enable LLTXOlof Johansson
Enable LLTX on pasemi_mac: we're already doing sufficient locking in the driver to enable it. [ Resolved merge conflicts with napi_struct changes... -DaveM ] Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10pasemi_mac: Fix RX checksum flagsOlof Johansson
RX side flag to use is CHECKSUM_UNNECESSARY, not CHECKSUM_COMPLETE. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10pasemi_mac: Fix TX ring wrap checkingOlof Johansson
The old logic didn't detect full (tx) ring cases properly, causing overruns and general badness. Clean it up a bit and abstract out the ring size checks, always making sure to leave 1 slot open. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10pasemi_mac: Batch up TX buffer freesOlof Johansson
Postpone pci unmap and skb free of the transmitted buffers to outside of the tx ring lock, batching them up 32 at a time. Also increase the count threshold to 128. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10pasemi_mac: RX performance tweaksOlof Johansson
Various RX performance tweaks, do some explicit prefetching of packet data, etc. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10pasemi_mac: Fix memcpy amount for short receivesOlof Johansson
Fix up memcpy for short receives. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10pasemi_mac: Enable L2 caching of packet headersOlof Johansson
Enable settings to target l2 for the first few cachelines of the packet, since we'll access them to get to the various headers. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10pasemi_mac: Stop using the pci config space accessors for register read/writesOlof Johansson
Move away from using the pci config access functions for simple register access. Our device has all of the registers in the config space (hey, from the hardware point of view it looks reasonable :-), so we need to somehow get to it. Newer firmwares have it in the device tree such that we can just get it and ioremap it there (in case it ever moves in future products). For now, provide a hardcoded fallback for older firmwares. [ Resolved napi_struct conflicts... -DaveM ] Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10pasemi_mac: Abstract out register accessOlof Johansson
Abstract out the PCI config read/write accesses into reg read/write ones, still calling the pci accessors on the back end. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10bmac: add simple ethtool support for network managerOlaf Hering
NetworkManager will not start dhcpd on an interface unless it reports link-up state via ethtool. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10sky2: use pci_config access functionsStephen Hemminger
Use the PCI layer config access functions. The driver was using the memory mapped window in device, to workaround issues accessing the advanced error reporting registers. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10sky2: advanced error reportingStephen Hemminger
Use the kernel interfaces for advanced error reporting. This should be cleaner and clear up errors on boot. For those systems with busted BIOS's that don't correctly support mmconfig, advanced error reporting will be disabled. The PCI registers for advanced error reporting start at 0x100 which is too large to be accessed by legacy functions. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10sky2: dont restrict config space accessStephen Hemminger
Take out the code that protects driver from accessing the PCI config space. We are old enough to run with scissors now. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10sky2: document GPHY_CTRL bitsStephen Hemminger
Add documentation of GPHY_CTRL register bits even if driver is not using them (yet). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10sky2: use debugfs renameStephen Hemminger
Use debugfs rename to handle device neame changes. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - Update internal memory managementDivy Le Ray
Set PM1 internal memory to round robin mode It balances access to this internal memory for multiport adapters. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - log adapter serial numberDivy Le Ray
Log HW serial number when cxgb3 module is loaded. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - Fatal error updateDivy Le Ray
Stop the MAC when a fatal error is detected. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - tighten checks on TID valuesDivy Le Ray
Enforce validity checks on connection ids Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - Expose HW memory page infoDivy Le Ray
A HW issue requires limiting the receive window size to 23 pages of internal memory. These pages can be configured to different sizes, thus the RDMA driver needs to know the page size to enforce the upper limit. Also assign explicit enum values. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - use immediate data for offload TxDivy Le Ray
Send small TX_DATA work requests as immediate data even when there are fragments. this avoids doing multiple DMAs for small fragmented packets. The driver already implements this optimization for small contiguous packets. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - SGE doorbell overflow warningDivy Le Ray
Log doorbell Fifo overflow Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - Update rx coalescing lengthDivy Le Ray
Reduce Rx coalescing length to 12288 Large bursts from the adapter to the host create back pressure on the chip. Reducing the burst size avoids the issue. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-103c59x: check return of pci_enable_device()Mark Hindley
Check return of pci_enable_device in vortex_up(). Also modify vortex_up to return error to callers. Handle failure of vortex_up in vortex_open and vortex_resume. Signed-off-by: Mark Hindley <mark@hindley.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10ibmveth: Remove use of bitfieldsBrian King
Removes the use of bitfields from the ibmveth driver. This results in slightly smaller object code. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10ibmveth: Remove dead frag processing codeBrian King
Removes dead frag processing code from ibmveth. Since NETIF_F_SG was not set, this code was never executed. Also, since the ibmveth interface can only handle 6 fragments, core networking code would need to be modified in order to efficiently enable this support. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10ibmveth: Add ethtool driver stats hooksBrian King
Add ethtool hooks to ibmveth to retrieve driver statistics. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10ibmveth: Add ethtool TSO handlersBrian King
Add handlers for get_tso and get_ufo to prevent errors being printed by ethtool. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10ibmveth: Implement ethtool hooks to enable/disable checksum offloadBrian King
This patch adds the appropriate ethtool hooks to allow for enabling/disabling of hypervisor assisted checksum offload for TCP. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10ibmveth: Enable TCP checksum offloadBrian King
This patchset enables TCP checksum offload support for IPV4 on ibmveth. This completely eliminates the generation and checking of the checksum for packets that are completely virtual and never touch a physical network. A simple TCP_STREAM netperf run on a virtual network with maximum mtu set yielded a ~30% increase in throughput. This feature is enabled by default on systems that support it, but can be disabled with a module option. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10dl2k: add Sundance/Tamarack TC902x Gigabit Ethernet Adapter supportKomuro
Actually, D-Link modified the VendorID/ProductID of the TC902x. The TC902x is the original chipset. Signed-off-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10uli526x: Add suspend and resume routines (updated)Rafael J. Wysocki
Add suspend/resume support to the uli526x network driver (tested on x86_64, with 'Ethernet controller: ALi Corporation M5263 Ethernet Controller, rev 40'). This patch is based on the suspend/resume code in the tg3 driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10pcnet32: add suspend and resume capabilityDon Fry
Add suspend and resume capability to the driver. Tested both to ram and to disk on x86_64 platform. Signed-off-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10support for USB autosuspend in the asix driverOliver Neukum
this implements support for USB autosuspend in the asix USB ethernet driver. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[E1000E]: New pci-express e1000 driver (currently for ICH9 devices only)Auke Kok
This driver implements support for the ICH9 on-board LAN ethernet device. The device is similar to ICH8. The driver encompasses code to support 82571/2/3, es2lan and ICH8 devices as well, but those device IDs are disabled and will be "lifted" from the e1000 driver over one at a time once this driver receives some more live time. Changes to the last snapshot posted are exclusively in the internal hardware API organization. Many thanks to Jeff Garzik for jumping in and getting this organized with a keen eye on the future layout. [ Integrated napi_struct patch from Auke as well... -DaveM ] Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] libertas: remove unused adhoc_rates_b definitionJohn W. Linville
2007-10-10[PATCH] libertas: printk warning fixesAndrew Morton
drivers/net/wireless/libertas/if_cs.c: In function 'if_cs_prog_helper': drivers/net/wireless/libertas/if_cs.c:462: warning: format '%d' expects type 'int', but argument 3 has type 'size_t' drivers/net/wireless/libertas/if_cs.c: In function 'if_cs_prog_real': drivers/net/wireless/libertas/if_cs.c:538: warning: format '%d' expects type 'int', but argument 3 has type 'size_t' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] net: Kill some unneeded allocation return value casts in libertasJesper Juhl
kmalloc() and friends return void*, no need to cast it. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] libertas: advertise 11g ad-hoc ratesBrajesh Dave
Advertise support for 802.11g bitrates when starting adhoc networks, not just 802.11b bitrates. Signed-off-by: Brajesh Dave <brajeshd@marvell.com> Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] libertas: region code values specified as 8bitMarek Vašut
This patch strips away possible mess in regioncode (eg. on my card - 88W8305 chipset - I get 0x3031 instead of expected 0x0031 and as a result the driver defaults to USA region which is obviously incorrect). Following patch fixes the issue. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] libertas: properly end commands on hardware failurePierre Ossman
Make sure that errors reported by the hardware layer is properly handled. Otherwise commands tend to get stuck in limbo. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] libertas: send reset command directly instead of calling ↵Dan Williams
libertas_reset_device Ensures that any platform specific code that might live in libertas_reset_device (for example, OLPC tells the EC to do a GPIO-toggled reset of the wireless from libertas_reset_device) isn't called. Could be handled better by interface-specific callbacks and a flag for "other hardware reset". Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: Marcelo Tosatti <marcelo@kvack.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
