Fix error checking of predicted voltage. Also get rid of
maybe-uninitialized warning when using 4.6 toolchain.
Bug 949219
Bug 999222
Change-Id: I47553aba5a93c91bdd93cbf75081d69f92aec4dd
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/108899
Reviewed-by: Simone Willett <swillett@nvidia.com>
this commit exposes following power management parameter through
sysfs:
- clockgate_delay: delay after which module is clock gated after
it goes idle. this read/write attribute & unit is ms.
- powergate_delay: delay after which module is power gated after
it is clock gated. this is read/write attribute & unit is ms.
- refcount: current reference count on the module. this is
read-only attribute.
path is: /sys/devices/host1x/<device-name>/acm/ where
<device-name> = name of device node like gr2d or gr3d etc
Bug 845598
Change-Id: I6011eb90ee85b5fc576320272e657ce31f9e264d
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/108827
Reviewed-by: Francis Hart <fhart@nvidia.com>
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Becasue of a previous workaround, suspend/resume pair is implemented as
suspend/complete pair in the driver's dev_pm_ops field.
If any driver suspend routine (which is called before otg suspend)
failed, then tegra_otg_resume() will be called even tegra_otg_suspend()
is not called. This will cause disable the OTG clock, and OTG will not
generate any more IRQ.
Ideal fix would be use suspend/resume pair to implement the dev_pm_ops,
but this might break previous workaround. This patch check suspend()
routine is called or not in the resume routine; even we use suspend/
resume pair in the future, it will not cause bad behaviour.
BUG 999759
Change-Id: I88f9c28bb76c5ff9e32917904017f291456cb933
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/108444
(cherry picked from commit c751aeea65f126d8e2df7f8a9ba02a631f958dc1)
Reviewed-on: http://git-master/r/108945
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Change-Id: I34748241728bb0bab1861f8abacffdfe2939740f
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/109158
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Host support should be disabled only when there is platform
data specifying proper setting.
Bug 998001
Change-Id: I99ff534074dd7ebbf12b53dcf53d6286925965d2
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/108760
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
promotion_build
Several compilation errors popped up when building the 3.1 kernel for
chrome. Warnings included callback structure changing and not being
updated in the max98095 codec driver and unused labels.
With these change I am able to compile in the max98095 codec support
and wm8903 without build errors.
Bug 986933
Change-Id: Ia8b2511f54b031eadcad8c74efa88be9288f25fb
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Reviewed-on: http://git-master/r/105464
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Bug 997101
Signed-off-by: Om Prakash Singh <omp@nvidia.com>
Change-Id: I5da0bfe342193d93e021eb9a24aacb09bf38e6a0
Reviewed-on: http://git-master/r/108780
Reviewed-by: Om Prakash Singh <omp@nvidia.com>
Tested-by: Om Prakash Singh <omp@nvidia.com>
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Disable all interrupts on current CPU
while doing 2ls to make sure the 3 us
delay being executed precisely
bug 944998
Change-Id: I645709ffdd2481a63223272e1b3f7f1f78466236
Reviewed-on: http://git-master/r/108536
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Remove L3 state from xmm power driver. New usb phy code
allows pm state transition L0->L2 and L2->L0. When the
system goes in LP0/LP1 suspend then the modem power
state is kept at L2 and bus state in suspend controlled by
PMC. At system resume the hsic bus is given back to USB.
Bug 991709
Change-Id: Ib3b74d7da30a5103eddd747726ac7c4423472c76
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/108076
Reviewed-by: Michael Hsu <mhsu@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Two threads race for two resources when baseband_usb_close()
get called from a user process
Bug 988188
Change-Id: Ic962640b6414e576d34b7ff6870b21b644837434
Signed-off-by: pyu <pyu@nvidia.com>
Reviewed-on: http://git-master/r/107088
GVS: Gerrit_Virtual_Submit
Reviewed-by: Vinayak Pane <vpane@nvidia.com>
Bug 999876
Change-Id: I174d6d7495454f4b28f0315513d6f703743f832d
Bug 999876
Bug 999876
Change-Id: I83a139e6c0dd42cf095fa2ac1376732075a15434
mac80211 leaves sinfo->assoc_req_ies uninitialized, causing a random
pointer memory access in nl80211_send_station.
Instead of checking if the pointer is null, use sinfo->filled, like
the rest of the fields.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
- ETIMEDOUT is interpreted as FW is not responding,
so return EINTR instead
- Deauth frame from p2p GO to client doesn't go from firmware
if we do del_virtual_iface immediately. Putting a delay after
sending deauth frame to allowed FW to send out deauth frame.
- IF_DEL operation was timing out due to wrong status check.
Fixed it and added few debug prints.
- Sending Provision Discovery directly to GO instead of doing
an internal scan. Also put the internal scan count to 3 to have
better timings for GO-NEG.
- Increase beacon timeout only for concurrent mode. For STA only
operation, use the default beacon timeout value (4).
- If scan abort is due to timeout, aborting the scan in FW is not
required. Moreover, as this scan_timeout call is coming in timer
interrupt context, all blocking calls such as fw scan abort will
result in kernel panic : don’t call abort in Firmware.
- Add p2p_cancel_listen routine. Fix p2p_listen_complete related
kernel crash seen while turning off WiFi.
- Add retry to wl_cfg80211_mgmt_tx() for P2P
- Change singal pending return value from -512 to -110
- Minor cleaning
- Reduce IOCTL responce timeout to 2 sec (from 20)
- Fix pending status in case of timeout
- Pass error code from dhd_is_associated() call
- Call cfg80211_disconnected() if no timeout detected
- Fix WEXT compilation
- Start SoftAP in G-band only
- Fix IF_DEL timeout due to wrong status check
- Fix P2P to pass certification
- Enable arpoe in concurrent mode by default
- Fail to start sched scan in P2P GO
- Add SoftAP auto-channel support
- P2P fixes
