commit c25573b5134294c0be82bfaecc6d08136835b271 upstream.
Whenever we free a slot, we know that the resulting xprt->num_reqs will
be less than xprt->max_reqs, so we know that we can release at least one
backlogged rpc_task.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 913050b91eb94f194392dd797b1ff3779f606ac0 upstream.
If oprofilefs_ulong_from_user() is called with count equals
zero, *val remains unchanged. Depending on the implementation it
might be uninitialized.
Change oprofilefs_ulong_from_user()'s interface to return count
on success. Thus, we are able to return early if count equals
zero which avoids using *val uninitialized. Fixing all users of
oprofilefs_ulong_ from_user().
This follows write syscall implementation when count is zero:
"If count is zero ... [and if] no errors are detected, 0 will be
returned without causing any other effect." (man 2 write)
Reported-By: Mike Waychison <mikew@google.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: oprofile-list <oprofile-list@lists.sourceforge.net>
Link: http://lkml.kernel.org/r/20111219153830.GH16765@erda.amd.com
commit ff05b6f7ae762b6eb464183eec994b28ea09f6dd upstream.
An integer overflow will happen on 64bit archs if task's sum of rss,
swapents and nr_ptes exceeds (2^31)/1000 value. This was introduced by
commit
f755a04 oom: use pte pages in OOM score
where the oom score computation was divided into several steps and it's no
longer computed as one expression in unsigned long(rss, swapents, nr_pte
are unsigned long), where the result value assigned to points(int) is in
range(1..1000). So there could be an int overflow while computing
176 points *= 1000;
and points may have negative value. Meaning the oom score for a mem hog task
will be one.
196 if (points <= 0)
197 return 1;
For example:
[ 3366] 0 3366 35390480 24303939 5 0 0 oom01
Out of memory: Kill process 3366 (oom01) score 1 or sacrifice child
Here the oom1 process consumes more than 24303939(rss)*4096~=92GB physical
memory, but it's oom score is one.
In this situation the mem hog task is skipped and oom killer kills another and
most probably innocent task with oom score greater than one.
The points variable should be of type long instead of int to prevent the
int overflow.
Signed-off-by: Frantisek Hrbata <fhrbata@redhat.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: David Rientjes <rientjes@google.com>
commit 3d3c8f93a237b64580c5c5e138edeb1377e98230 upstream.
binary_sysctl() calls sysctl_getname() which allocates from names_cache
slab usin __getname()
The matching function to free the name is __putname(), and not putname()
which should be used only to match getname() allocations.
This is because when auditing is enabled, putname() calls audit_putname
*instead* (not in addition) to __putname(). Then, if a syscall is in
progress, audit_putname does not release the name - instead, it expects
the name to get released when the syscall completes, but that will happen
only if audit_getname() was called previously, i.e. if the name was
allocated with getname() rather than the naked __getname(). So,
__getname() followed by putname() ends up leaking memory.
Signed-off-by: Michel Lespinasse <walken@google.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Eric Paris <eparis@redhat.com>
commit 4af3ce0de0c12e5c17811eaefad36ab8e146c0fd upstream.
Commit cfcde11c3d7a ("IB/mlx4: Use flow counters on IBoE ports") added
code that sets elements of counters[] to -1 if no counter is allocated,
but then goes ahead and passes every entry to mlx4_counter_free() on
shutdown. This is a bad idea, especially if MLX4_DEV_CAP_FLAG_COUNTERS
isn't set so there isn't even an underlying bitmap to free from.
Tested-by: Sean Hefty <sean.hefty@intel.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 9f57bd4d6dc69a4e3bf43044fa00fcd24dd363e3 upstream.
per_cpu_ptr_to_phys() incorrectly rounds up its result for non-kmalloc
case to the page boundary, which is bogus for any non-page-aligned
address.
This affects the only in-tree user of this function - sysfs handler
for per-cpu 'crash_notes' physical address. The trouble is that the
crash_notes per-cpu variable is not page-aligned:
crash_notes = 0xc08e8ed4
PER-CPU OFFSET VALUES:
CPU 0: 3711f000
CPU 1: 37129000
CPU 2: 37133000
CPU 3: 3713d000
So, the per-cpu addresses are:
crash_notes on CPU 0: f7a07ed4 => phys 36b57ed4
crash_notes on CPU 1: f7a11ed4 => phys 36b4ded4
crash_notes on CPU 2: f7a1bed4 => phys 36b43ed4
crash_notes on CPU 3: f7a25ed4 => phys 36b39ed4
However, /sys/devices/system/cpu/cpu*/crash_notes says:
/sys/devices/system/cpu/cpu0/crash_notes: 36b57000
/sys/devices/system/cpu/cpu1/crash_notes: 36b4d000
/sys/devices/system/cpu/cpu2/crash_notes: 36b43000
/sys/devices/system/cpu/cpu3/crash_notes: 36b39000
As you can see, all values are rounded down to a page
boundary. Consequently, this is where kexec sets up the NOTE segments,
and thus where the secondary kernel is looking for them. However, when
the first kernel crashes, it saves the notes to the unaligned
addresses, where they are not found.
Fix it by adding offset_in_page() to the translated page address.
-tj: Combined Eugene's and Petr's commit messages.
Signed-off-by: Eugene Surovegin <ebs@ebshome.net>
Reported-by: Petr Tesarik <ptesarik@suse.cz>
commit 8521478f67e95ada4e87970c7b41e504c724b2cf upstream.
Synaptics touchpads on several Dell laptops, particularly Vostro V13
systems, may not respond properly to PS/2 commands and queries immediately
after resuming from suspend to RAM. This leads to unresponsive touchpad
after suspend/resume cycle.
Adding a 1-second delay after resetting the device allows touchpad to
finish initializing (calibrating?) and start reacting properly.
Reported-by: Daniel Manrique <daniel.manrique@canonical.com>
Tested-by: Daniel Manrique <daniel.manrique@canonical.com>
commit c0d96aed8c6dd925afe9ea35491a0cd458642a86 upstream.
Signed-off-by: Jason Chen <jason.chen@linaro.org>
transition
commit 91ddff8a3b9cc7ac2252aca138220939cf6cc2cf upstream.
In drivers rtl8192ce, rtl8192cu, rtl8192se, and rtl8192de, break
statements would allow ppsc->rfpwr_state to be changed to ERFSLEEP
even though the device is actually in ERFOFF.
Signed-off-by: Philipp Dreimann <philipp@dreimann.net>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
commit 329456d1ffb416c220813725b7363cda9975c9aa upstream.
This fixes a Data bus error on some SoCs. The first fix for this
problem did not solve it on all devices.
commit 6ae8ec27868bfdbb815287bee8146acbefaee867
Author: Rafał Miłecki <zajec5@gmail.com>
Date: Tue Jul 5 17:25:32 2011 +0200
ssb: fix init regression of hostmode PCI core
In ssb_pcicore_fix_sprom_core_index() the sprom on the PCI core is
accessed, but the sprom only exists when the ssb bus is connected over
a PCI bus to the rest of the system and not when the SSB Bus is the
main system bus. SoCs sometimes have a PCI host controller and there
this code will not be executed, but there are some old SoCs with an PCI
controller in client mode around and ssb_pcicore_fix_sprom_core_index()
should not be called on these devices too. The PCI controller on these
devices are unused, but without this fix it results in an Data bus
error when it gets initialized.
Cc: Michael Buesch <m@bues.ch>
Cc: Rafał Miłecki <zajec5@gmail.com>
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
commit 5151412dd4338b273afdb107c3772528e9e67d92 upstream.
struct request_queue is allocated with __GFP_ZERO so its "node" field is
zero before initialization. This causes an oops if node 0 is offline in
the page allocator because its zonelists are not initialized. From Dave
Young's dmesg:
SRAT: Node 1 PXM 2 0-d0000000
SRAT: Node 1 PXM 2 100000000-330000000
SRAT: Node 0 PXM 1 330000000-630000000
Initmem setup node 1 0000000000000000-000000000affb000
Built 1 zonelists in Node order, mobility grouping on.
BUG: unable to handle kernel paging request at 0000000000001c08
IP: [<ffffffff8111c355>] __alloc_pages_nodemask+0xb5/0x870
and __alloc_pages_nodemask+0xb5 translates to a NULL pointer on
zonelist->_zonerefs.
The fix is to initialize q->node at the time of allocation so the correct
node is passed to the slab allocator later.
Since blk_init_allocated_queue_node() is no longer needed, merge it with
blk_init_allocated_queue().
[rientjes@google.com: changelog, initializing q->node]
Reported-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Tested-by: Dave Young <dyoung@redhat.com>
commit 37d5993c5cc9bc83762ae1b5bd287438022e8afe upstream.
Record the clock after the divider as that is what all SYSCLK users see.
Without this the other clock configuration in the device comes out at
half rate.
commit 15062e6a8524f5977f2cbdf6e3eb2f144262f74e upstream.
Emmanuel noticed that when mac80211 stops the queues
for aggregation that can leave a packet pending. This
packet will be given to the driver after the AMPDU
callback, but as a non-aggregated packet which messes
up the sequence number etc.
I also noticed by looking at the code that if packets
are being processed while we clear the WANT_START bit,
they might see it cleared already and queue up on
tid_tx->pending. If the driver then rejects the new
aggregation session we leak the packet.
Fix both of these issues by changing this code to not
stop the queues at all. Instead, let packets queue up
on the tid_tx->pending queue instead of letting them
get to the driver, and add code to recover properly
in case the driver rejects the session.
(The patch looks large because it has to move two
functions to before their new use.)
Reported-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 7e1e7ead88dff75b11b86ee0d5232c4591be1326 upstream.
The error exit path leaks preempt count. Add the missing put_cpu().
Reviewed-by: Yi Zou <yi.zou@intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit f6a290b419a2675c4b77a6b0731cd2a64332365e upstream.
_scsih_smart_predicted_fault is called in an interrupt and therefore
must allocate memory using GFP_ATOMIC.
commit 44f747fff6e9f027a4866c1a6864e26ae7c510c8 upstream.
zfcp_scsi_slave_destroy erroneously always tried to finish its task
even if the corresponding previous zfcp_scsi_slave_alloc returned
early. This can lead to kernel page faults on accessing uninitialized
fields of struct zfcp_scsi_dev in zfcp_erp_lun_shutdown_wait. Take the
port field of the struct to determine if slave_alloc returned early.
This zfcp bug is exposed by 4e6c82b (in turn fixing f7c9c6b to be
compatible with 21208ae) which can call slave_destroy for a
corresponding previous slave_alloc that did not finish.
This patch is based on James Bottomley's fix suggestion in
http://www.spinics.net/lists/linux-scsi/msg55449.html.
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
commit 5eb46851de3904cd1be9192fdacb8d34deadc1fc upstream.
cfq_cic_link() has race condition. When some processes which shared ioc
issue I/O to same block device simultaneously, cfq_cic_link() returns -EEXIST
sometimes. The race condition might stop I/O by following steps:
step 1: Process A: Issue an I/O to /dev/sda
step 2: Process A: Get an ioc (iocA here) in get_io_context() which does not
linked with a cic for the device
step 3: Process A: Get a new cic for the device (cicA here) in
cfq_alloc_io_context()
step 4: Process B: Issue an I/O to /dev/sda
step 5: Process B: Get iocA in get_io_context() since process A and B share the
same ioc
step 6: Process B: Get a new cic for the device (cicB here) in
cfq_alloc_io_context() since iocA has not been linked with a
cic for the device yet
step 7: Process A: Link cicA to iocA in cfq_cic_link()
step 8: Process A: Dispatch I/O to driver and finish it
step 9: Process B: Try to link cicB to iocA in cfq_cic_link()
But it fails with showing "cfq: cic link failed!" kernel
message, since iocA has already linked with cicA at step 7.
step 10: Process B: Wait for finishig I/O in get_request_wait()
The function does not wake up, when there is no I/O to the
device.
When cfq_cic_link() returns -EEXIST, it means ioc has already linked with cic.
So when cfq_cic_link() return -EEXIST, retry cfq_cic_lookup().
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
commit 2984ff38ccf6cbc02a7a996a36c7d6f69f3c6146 upstream.
If we fail allocating the blkpg stats, we free cfqd and cfgq.
But we need to free the IDA cfqd->cic_index as well.
Signed-off-by: majianpeng <majianpeng@gmail.com>
commit 4ed0b577457eb6aeb7cdc7e7316576e63d15abb2 upstream.
This prevents an in-kernel division by zero which happens when we are
asking for i915_chipset_val too quickly, or within a race condition
between the power monitoring thread and userspace accesses via debugfs.
The issue can be reproduced easily via the following command:
while ``; do cat /sys/kernel/debug/dri/0/i915_emon_status; done
This is particularly dangerous because it can be triggered by
a non-privileged user by just reading the debugfs entry.
This issue was also found independently by Konstantin Belousov
<kostikbel@gmail.com>, who proposed a similar patch.
Reported-by: Konstantin Belousov <kostikbel@gmail.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Acked-by: Keith Packard <keithp@keithp.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
commit 3573c4103f7a486838bb6b5b8353788103f91802 upstream.
v2: add a CPT-specific macro, make code cleaner
v3: fix commit message
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41272
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
commit 1c89fe3b51a2f8068f2f9faa9c48584151416583 upstream.
For the Asus 1101HA, reporting position by reading the DMA position
buffer map seems unstable and often wrong. The reporter says that
position_fix=LPIB works much better (although not 100%, but this is
probably due to other issues).
The controller chip is an Intel Poulsbo 8086:811b (rev 07) controller,
and complete alsa-info is available here:
https://launchpadlibrarian.net/86691768/alsa-info.txt.1TNwyE5Ea7
BugLink: http://bugs.launchpad.net/bugs/825709
Tested-by: Stefano Lodi
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit c3b79770e51ab1fd4201f3b54edf30113b9ce74f upstream.
The m41t80 driver can read and set the alarm, but it doesn't
seem to have a functional alarm irq.
This causes failures when the generic core sees alarm functions,
but then cannot use them properly for things like UIE mode.
Disabling the alarm functions allows proper error reporting,
and possible fallback to emulated modes. Once someone fixes
the alarm irq functionality, this can be restored.
CC: Matt Turner <mattst88@gmail.com>
CC: Nico Macrionitis <acrux@cruxppc.org>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Reported-by: Matt Turner <mattst88@gmail.com>
Reported-by: Nico Macrionitis <acrux@cruxppc.org>
Tested-by: Nico Macrionitis <acrux@cruxppc.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 72b36015ba43a3cca5303f5534d2c3e1899eae29 upstream.
Same fix as 731abb9cb2 for ipip and sit tunnel.
Commit 1c5cae815d removed an explicit call to dev_alloc_name in
ipip_tunnel_locate and ipip6_tunnel_locate, because register_netdevice
will now create a valid name, however the tunnel keeps a copy of the
name in the private parms structure. Fix this by copying the name back
after register_netdevice has successfully returned.
This shows up if you do a simple tunnel add, followed by a tunnel show:
$ sudo ip tunnel add mode ipip remote 10.2.20.211
$ ip tunnel
tunl0: ip/ip remote any local any ttl inherit nopmtudisc
tunl%d: ip/ip remote 10.2.20.211 local any ttl inherit
$ sudo ip tunnel add mode sit remote 10.2.20.212
$ ip tunnel
sit0: ipv6/ip remote any local any ttl 64 nopmtudisc 6rd-prefix 2002::/16
sit%d: ioctl 89f8 failed: No such device
sit%d: ipv6/ip remote 10.2.20.212 local any ttl inherit
Signed-off-by: Ted Feng <artisdom@gmail.com>
commit e5fe29c7198a1f6616286dfc8602a69da165cb3f upstream.
Commit 10299e2e4e3ed3b16503d4e04edd48b33083f4e2 (ARM: RX-51:
Enable isp1704 power on/off) added power management for isp1704.
However, the transceiver should be powered on by default,
otherwise USB doesn't work at all for networking during
boot.
All kernels after v3.0 are affected.
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com>
Reviewed-by: Sebastian Reichel <sre@debian.org>
[tony@atomide.com: updated comments]
commit 3b87487ac5008072f138953b07505a7e3493327f upstream.
This reverts commit de28f25e8244c7353abed8de0c7792f5f883588c.
It results in resume problems for various people. See for example
http://thread.gmane.org/gmane.linux.kernel/1233033
http://thread.gmane.org/gmane.linux.kernel/1233389
http://thread.gmane.org/gmane.linux.kernel/1233159
http://thread.gmane.org/gmane.linux.kernel/1227868/focus=1230877
and the fedora and ubuntu bug reports
https://bugzilla.redhat.com/show_bug.cgi?id=767248
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/904569
which got bisected down to the stable version of this commit.
Reported-by: Jonathan Nieder <jrnieder@gmail.com>
Reported-by: Phil Miller <mille121@illinois.edu>
Reported-by: Philip Langdale <philipl@overt.org>
Reported-by: Tim Gardner <tim.gardner@canonical.com>
commit 02a551c9755b799579e0a093bcc99b80b4dc1453 upstream.
Huawei use the product code HUAWEI_PRODUCT_E353 (0x1506) for a
number of different devices, which each can appear with a number
of different descriptor sets. Different types of interfaces
can be identified by looking at the subclass and protocol fields
Subclass 1 protocol 8 is actually the data interface of a CDC
ECM set, with subclass 1 protocol 9 as the control interface.
Neither support serial data communcation, and cannot therefore
be supported by this driver.
At the same time, add a few other sets which appear if the
device is configured in "Windows mode" using this modeswitch
message:
55534243000000000000000000000011060000000100000000000000000000
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Cc: stable <stable@vger.kernel.org>
commit 414b591fd16655871e9f5592a55368b10a3ccc30 upstream.
This patch adds the controlling interfaces for the Huawei E398.
Thanks to Bjørn Mork <bjorn@mork.no> for extracting the interface
numbers from the windows driver.
Signed-off-by: Alex Hermann <alex@wenlex.nl>
commit 6abff5dc4d5a2c90e597137ce8987e7fd439259b upstream.
Add USB IDs for Motorola H24 HSPA USB module.
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
Acked-by: Oliver Neukum <oneukum@suse.de>
commit 935a9fee51c945b8942be2d7b4bae069167b4886 upstream.
Found one system with UEFI/iBFT, kernel does not detect the iBFT during
iscsi_ibft module loading.
Root cause: on x86 (UEFI), we are calling of find_ibft_region() much earlier
- specifically in setup_arch() before ACPI is enabled.
Try to split acpi checking code out and call that later
At that time ACPI iBFT already get permanent mapped with ioremap.
So isa_virt_to_bus() will get wrong phys from right virt address.
We could just skip that phys address printing.
For legacy one, print the found address early.
-v2: update comments and description according to Konrad.
-v3: fix problem about module use case that is found by Konrad.
-v4: use acpi_get_table() instead of acpi_table_parse() to handle module use case that is found by Konrad again..
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
commit cd5cfce856684e13b9b57d46b78bb827e9c4da3c upstream.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=43739
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit c7caf4d4c56aee40b995f5858ccf1c814f3d2da2 upstream.
Add USB ID for Sitecom WLA-2000 v1.001 WLAN.
Reported-and-tested-by: Roland Gruber <post@rolandgruber.de>
commit b48c6af2086ab2ba8a9c9b6ce9ecb34592ce500c upstream.
The test in fuse_file_llseek() "not SEEK_CUR or not SEEK_SET" always evaluates
to true.
This was introduced in 3.1 by commit 06222e49 (fs: handle SEEK_HOLE/SEEK_DATA
properly in all fs's that define their own llseek) and changed the behavior of
SEEK_CUR and SEEK_SET to always retrieve the file attributes. This is a
performance regression.
Fix the test so that it makes sense.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: Josef Bacik <josef@redhat.com>
CC: Al Viro <viro@zeniv.linux.org.uk>
commit 48706d0a91583d08c56e7ef2a7602d99c8d4133f upstream.
Fix two bugs in fuse_retrieve():
- retrieving more than one page would yield repeated instances of the
first page
- if more than FUSE_MAX_PAGES_PER_REQ pages were requested than the
request page array would overflow
fuse_retrieve() was added in 2.6.36 and these bugs had been there since the
beginning.
commit 5a0dc7365c240795bf190766eba7a27600be3b3e upstream.
We need to zero out part of a page which beyond EOF before setting uptodate,
otherwise, mapread or write will see non-zero data beyond EOF.
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 13a79a4741d37fda2fbafb953f0f301dc007928f upstream.
If there is an unwritten but clean buffer in a page and there is a
dirty buffer after the buffer, then mpage_submit_io does not write the
dirty buffer out. As a result, da_writepages loops forever.
This patch fixes the problem by checking dirty flag.
commit ea51d132dbf9b00063169c1159bee253d9649224 upstream.
If the pte mapping in generic_perform_write() is unmapped between
iov_iter_fault_in_readable() and iov_iter_copy_from_user_atomic(), the
"copied" parameter to ->end_write can be zero. ext4 couldn't cope with
it with delayed allocations enabled. This skips the i_disksize
enlargement logic if copied is zero and no new data was appeneded to
the inode.
gdb> bt
#0 0xffffffff811afe80 in ext4_da_should_update_i_disksize (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x1\
08000, len=0x1000, copied=0x0, page=0xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2467
#1 ext4_da_write_end (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x108000, len=0x1000, copied=0x0, page=0\
xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2512
#2 0xffffffff810d97f1 in generic_perform_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value o\
ptimized out>, pos=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2440
#3 generic_file_buffered_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value optimized out>, p\
os=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2482
#4 0xffffffff810db5d1 in __generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, ppos=0\
xffff88001e26be40) at mm/filemap.c:2600
#5 0xffffffff810db853 in generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=<value optimi\
zed out>, pos=<value optimized out>) at mm/filemap.c:2632
#6 0xffffffff811a71aa in ext4_file_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, pos=0x108000) a\
t fs/ext4/file.c:136
#7 0xffffffff811375aa in do_sync_write (filp=0xffff88003f606a80, buf=<value optimized out>, len=<value optimized out>, \
ppos=0xffff88001e26bf48) at fs/read_write.c:406
#8 0xffffffff81137e56 in vfs_write (file=0xffff88003f606a80, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x4\
000, pos=0xffff88001e26bf48) at fs/read_write.c:435
#9 0xffffffff8113816c in sys_write (fd=<value optimized out>, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x\
4000) at fs/read_write.c:487
#10 <signal handler called>
#11 0x00007f120077a390 in __brk_reservation_fn_dmi_alloc__ ()
#12 0x0000000000000000 in ?? ()
gdb> print offset
$22 = 0xffffffffffffffff
gdb> print idx
$23 = 0xffffffff
gdb> print inode->i_blkbits
$24 = 0xc
gdb> up
2512 if (ext4_da_should_update_i_disksize(page, end)) {
gdb> print start
$25 = 0x0
gdb> print end
$26 = 0xffffffffffffffff
gdb> print pos
$27 = 0x108000
gdb> print new_i_size
$28 = 0x108000
gdb> print ((struct ext4_inode_info *)((char *)inode-((int)(&((struct ext4_inode_info *)0)->vfs_inode))))->i_disksize
$29 = 0xd9000
gdb> down
2467 for (i = 0; i < idx; i++)
gdb> print i
$30 = 0xd44acbee
This is 100% reproducible with some autonuma development code tuned in
a very aggressive manner (not normal way even for knumad) which does
"exotic" changes to the ptes. It wouldn't normally trigger but I don't
see why it can't happen normally if the page is added to swap cache in
between the two faults leading to "copied" being zero (which then
hangs in ext4). So it should be fixed. Especially possible with lumpy
reclaim (albeit disabled if compaction is enabled) as that would
ignore the young bits in the ptes.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
commit fc6cb1cda5db7b2d24bf32890826214b857c728e upstream.
/proc/mounts was showing the mount option [no]init_inode_table when
the correct mount option that will be accepted by parse_options() is
[no]init_itable.
commit b5a7e97039a80fae673ccc115ce595d5b88fb4ee upstream.
We need to make sure iocb->private is cleared *before* we put the
io_end structure on i_completed_io_list. Otherwise fsync() could
potentially run on another CPU and free the iocb structure out from
under us.
Reported-by: Kent Overstreet <koverstreet@google.com>
commit d3db728125c4470a2d061ac10fa7395e18237263 upstream.
d312ae878b6a "xen: use maximum reservation to limit amount of usable RAM"
clamped the total amount of RAM to the current maximum reservation. This is
correct for dom0 but is not correct for guest domains. In order to boot a guest
"pre-ballooned" (e.g. with memory=1G but maxmem=2G) in order to allow for
future memory expansion the guest must derive max_pfn from the e820 provided by
the toolstack and not the current maximum reservation (which can reflect only
the current maximum, not the guest lifetime max). The existing algorithm
already behaves this correctly if we do not artificially limit the maximum
number of pages for the guest case.
For a guest booted with maxmem=512, memory=128 this results in:
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] Xen: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] Xen: 00000000000a0000 - 0000000000100000 (reserved)
-[ 0.000000] Xen: 0000000000100000 - 0000000008100000 (usable)
-[ 0.000000] Xen: 0000000008100000 - 0000000020800000 (unusable)
+[ 0.000000] Xen: 0000000000100000 - 0000000020800000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] DMI not present or invalid.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
-[ 0.000000] last_pfn = 0x8100 max_arch_pfn = 0x1000000
+[ 0.000000] last_pfn = 0x20800 max_arch_pfn = 0x1000000
[ 0.000000] initial memory mapped : 0 - 027ff000
[ 0.000000] Base memory trampoline at [c009f000] 9f000 size 4096
-[ 0.000000] init_memory_mapping: 0000000000000000-0000000008100000
-[ 0.000000] 0000000000 - 0008100000 page 4k
-[ 0.000000] kernel direct mapping tables up to 8100000 @ 27bb000-27ff000
+[ 0.000000] init_memory_mapping: 0000000000000000-0000000020800000
+[ 0.000000] 0000000000 - 0020800000 page 4k
+[ 0.000000] kernel direct mapping tables up to 20800000 @ 26f8000-27ff000
[ 0.000000] xen: setting RW the range 27e8000 - 27ff000
[ 0.000000] 0MB HIGHMEM available.
-[ 0.000000] 129MB LOWMEM available.
-[ 0.000000] mapped low ram: 0 - 08100000
-[ 0.000000] low ram: 0 - 08100000
+[ 0.000000] 520MB LOWMEM available.
+[ 0.000000] mapped low ram: 0 - 20800000
+[ 0.000000] low ram: 0 - 20800000
With this change "xl mem-set <domain> 512M" will successfully increase the
guest RAM (by reducing the balloon).
There is no change for dom0.
Reported-and-Tested-by: George Shuklin <george.shuklin@gmail.com>
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit cf2aff6eff251b6fbdaf8c253e65ff7c693de8cd upstream.
Supposedly both NUTMEG and TRAVIS should use the same
panel mode, but switching the panel mode for TRAVIS
gets things working.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=41569
commit 1d33e1fc8dcce667a70387b666a8b6f60153d90f upstream.
Return the encoder id rather than a boolean. This is needed
for differentiate between multiple DP bridge chips.
commit b4f15f808b9a79b6ad9032fa5f6d8b88e1e1bf11 upstream.
The logic was messy and hard to follow.
commit 434a964daa14b9db083ce20404a4a2add54d037a upstream.
Clement Lecigne reports a filesystem which causes a kernel oops in
hfs_find_init() trying to dereference sb->ext_tree which is NULL.
This proves to be because the filesystem has a corrupted MDB extent
record, where the extents file does not fit into the first three extents
in the file record (the first blocks).
In hfs_get_block() when looking up the blocks for the extent file
(HFS_EXT_CNID), it fails the first blocks special case, and falls
through to the extent code (which ultimately calls hfs_find_init())
which is in the process of being initialised.
Hfs avoids this scenario by always having the extents b-tree fitting
into the first blocks (the extents B-tree can't have overflow extents).
The fix is to check at mount time that the B-tree fits into first
blocks, i.e. fail if HFS_I(inode)->alloc_blocks >=
HFS_I(inode)->first_blocks
Note, the existing commit 47f365eb57573 ("hfs: fix oops on mount with
corrupted btree extent records") becomes subsumed into this as a special
case, but only for the extents B-tree (HFS_EXT_CNID), it is perfectly
acceptable for the catalog B-Tree file to grow beyond three extents,
with the remaining extent descriptors in the extents overfow.
This fixes CVE-2011-2203
Reported-by: Clement LECIGNE <clement.lecigne@netasq.com>
Signed-off-by: Phillip Lougher <plougher@redhat.com>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Moritz Mühlenhoff <jmm@inutil.org>
commit 8762202dd0d6e46854f786bdb6fb3780a1625efe upstream.
I hit a J_ASSERT(blocknr != 0) failure in cleanup_journal_tail() when
mounting a fsfuzzed ext3 image. It turns out that the corrupted ext3
image has s_first = 0 in journal superblock, and the 0 is passed to
journal->j_head in journal_reset(), then to blocknr in
cleanup_journal_tail(), in the end the J_ASSERT failed.
So validate s_first after reading journal superblock from disk in
journal_get_superblock() to ensure s_first is valid.
The following script could reproduce it:
fstype=ext3
blocksize=1024
img=$fstype.img
offset=0
found=0
magic="c0 3b 39 98"
dd if=/dev/zero of=$img bs=1M count=8
mkfs -t $fstype -b $blocksize -F $img
filesize=`stat -c %s $img`
while [ $offset -lt $filesize ]
do
if od -j $offset -N 4 -t x1 $img | grep -i "$magic";then
echo "Found journal: $offset"
found=1
break
fi
offset=`echo "$offset+$blocksize" | bc`
done
if [ $found -ne 1 ];then
echo "Magic \"$magic\" not found"
exit 1
fi
dd if=/dev/zero of=$img seek=$(($offset+23)) conv=notrunc bs=1 count=1
mkdir -p ./mnt
mount -o loop $img ./mnt
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 2ded6e6a94c98ea453a156748cb7fabaf39a76b9 upstream.
When HPET is operating in RTC mode, the TN_ENABLE bit on timer1
controls whether the HPET or the RTC delivers interrupts to irq8. When
the system goes into suspend, the RTC driver sends a signal to the
HPET driver so that the HPET releases control of irq8, allowing the
RTC to wake the system from suspend. The switchover is accomplished by
a write to the HPET configuration registers which currently only
occurs while servicing the HPET interrupt.
On some systems, I have seen the system suspend before an HPET
interrupt occurs, preventing the write to the HPET configuration
register and leaving the HPET in control of the irq8. As the HPET is
not active during suspend, it does not generate a wake signal and RTC
alarms do not work.
This patch forces the HPET driver to immediately transfer control of
the irq8 channel to the RTC instead of waiting until the next
interrupt event.
Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com>
Link: http://lkml.kernel.org/r/20111118153306.GB16319@alberich.amd.com
Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
commit e5fd47bfab2df0c2184cc0bf4245d8e1bb7724fb upstream.
The idea behind commit d91ee5863b71 ("cpuidle: replace xen access to x86
pm_idle and default_idle") was to have one call - disable_cpuidle()
which would make pm_idle not be molested by other code. It disallows
cpuidle_idle_call to be set to pm_idle (which is excellent).
But in the select_idle_routine() and idle_setup(), the pm_idle can still
be set to either: amd_e400_idle, mwait_idle or default_idle. This
depends on some CPU flags (MWAIT) and in AMD case on the type of CPU.
In case of mwait_idle we can hit some instances where the hypervisor
(Amazon EC2 specifically) sets the MWAIT and we get:
Brought up 2 CPUs
invalid opcode: 0000 [#1] SMP
Pid: 0, comm: swapper Not tainted 3.1.0-0.rc6.git0.3.fc16.x86_64 #1
RIP: e030:[<ffffffff81015d1d>] [<ffffffff81015d1d>] mwait_idle+0x6f/0xb4
Call Trace:
[<ffffffff8100e2ed>] cpu_idle+0xae/0xe8
[<ffffffff8149ee78>] cpu_bringup_and_idle+0xe/0x10
RIP [<ffffffff81015d1d>] mwait_idle+0x6f/0xb4
RSP <ffff8801d28ddf10>
In the case of amd_e400_idle we don't get so spectacular crashes, but we
do end up making an MSR which is trapped in the hypervisor, and then
follow it up with a yield hypercall. Meaning we end up going to
hypervisor twice instead of just once.
The previous behavior before v3.0 was that pm_idle was set to
default_idle regardless of select_idle_routine/idle_setup.
We want to do that, but only for one specific case: Xen. This patch
does that.
Fixes RH BZ #739499 and Ubuntu #881076
Reported-by: Stefan Bader <stefan.bader@canonical.com>
commit e58f516ff4730c4047c3f104b061f7a03e9a263c upstream.
When we can't configure the dma channel we want to fall
back to PIO. We do this by setting host->do_dma to zero.
This does not work as do_dma is used to see whether dma
can be used for the current transfer. Instead, we have
to set host->dma to NULL.
Signed-off-by: Chris Ball <cjb@laptop.org>
commit 9811ccdfa94b4773c8030569bd8ec75eafa485ac upstream.
arm_dma_zone_size is used by arm_bootmem_free() which is called by
paging_init(). Thus it needs to be set before calling it.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
