commit 2d1618170eb493d18f66f2ac03775409a6fb97c6 upstream.
priv->work must not be synced while priv->mutex is locked, because
the mutex is taken in the work handler.
Move cancel_work_sync down to after the device shutdown code.
This is safe, because the work handler checks fw_state and bails out
early in case of a race.
Signed-off-by: Michael Buesch <m@bues.ch>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
commit 32d3a3922d617a5a685a5e2d24b20d0e88f192a9 upstream.
The tx_lock is not initialized properly. Add spin_lock_init().
commit d65670a78cdbfae94f20a9e05ec705871d7cdf2b upstream.
For some frequencies, the clocks_calc_mult_shift() function will
unfortunately select mult values very close to 0xffffffff. This
has the potential to overflow when NTP adjusts the clock, adding
to the mult value.
This patch adds a clocksource.maxadj value, which provides
an approximation of an 11% adjustment(NTP limits adjustments to
500ppm and the tick adjustment is limited to 10%), which could
be made to the clocksource.mult value. This is then used to both
check that the current mult value won't overflow/underflow, as
well as warning us if the timekeeping_adjust() code pushes over
that 11% boundary.
v2: Fix max_adjustment calculation, and improve WARN_ONCE
messages.
v3: Don't warn before maxadj has actually been set
CC: Yong Zhang <yong.zhang0@gmail.com>
CC: David Daney <ddaney.cavm@gmail.com>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Chen Jie <chenj@lemote.com>
CC: zhangfx <zhangfx@lemote.com>
Reported-by: Chen Jie <chenj@lemote.com>
Reported-by: zhangfx <zhangfx@lemote.com>
Tested-by: Yong Zhang <yong.zhang0@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 27c9cd7e601632b3794e1c3344d37b86917ffb43 upstream.
__remove_hrtimer() attempts to reprogram the clockevent device when
the timer being removed is the next to expire. However,
__remove_hrtimer() reprograms the clockevent *before* removing the
timer from the timerqueue and thus when hrtimer_force_reprogram()
finds the next timer to expire it finds the timer we're trying to
remove.
This is especially noticeable when the system switches to NOHz mode
and the system tick is removed. The timer tick is removed from the
system but the clockevent is programmed to wakeup in another HZ
anyway.
Silence the extra wakeup by removing the timer from the timerqueue
before calling hrtimer_force_reprogram() so that we actually program
the clockevent for the next timer to expire.
This was broken by 998adc3 "hrtimers: Convert hrtimers to use
timerlist infrastructure".
Signed-off-by: Jeff Ohlstein <johlstei@codeaurora.org>
Link: http://lkml.kernel.org/r/1321660030-8520-1-git-send-email-johlstei@codeaurora.org
commit d004e024058a0eaca097513ce62cbcf978913e0a upstream.
ktime_get and ktime_get_ts were calling timekeeping_get_ns()
but later they were not calling arch_gettimeoffset() so architectures
using this mechanism returned 0 ns when calling these functions.
This happened for example when running Busybox's ping which calls
syscall(__NR_clock_gettime, CLOCK_MONOTONIC, ts) which eventually
calls ktime_get. As a result the returned ping travel time was zero.
Signed-off-by: Hector Palacios <hector.palacios@digi.com>
commit 884a45d964dd395eda945842afff5e16bcaedf56 upstream.
2d3cbf8b (cgroup_freezer: update_freezer_state() does incorrect state
transitions) removed is_task_frozen_enough and replaced it with a simple
frozen call. This, however, breaks freezing for a group with stopped tasks
because those cannot be frozen and so the group remains in CGROUP_FREEZING
state (update_if_frozen doesn't count stopped tasks) and never reaches
CGROUP_FROZEN.
Let's add is_task_frozen_enough back and use it at the original locations
(update_if_frozen and try_to_freeze_cgroup). Semantically we consider
stopped tasks as frozen enough so we should consider both cases when
testing frozen tasks.
Testcase:
mkdir /dev/freezer
mount -t cgroup -o freezer none /dev/freezer
mkdir /dev/freezer/foo
sleep 1h &
pid=$!
kill -STOP $pid
echo $pid > /dev/freezer/foo/tasks
echo FROZEN > /dev/freezer/foo/freezer.state
while true
do
cat /dev/freezer/foo/freezer.state
[ "`cat /dev/freezer/foo/freezer.state`" = "FROZEN" ] && break
sleep 1
done
echo OK
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Tomasz Buchert <tomasz.buchert@inria.fr>
Cc: Paul Menage <paul@paulmenage.org>
Signed-off-by: Tejun Heo <htejun@gmail.com>
commit ba305e31e88ea5c2f598ff9fbc5424711a429e30 upstream.
SMPS regulator voltage control differs from the one of the LDO ones.
Current TWL code was using LDO regulator ops for controlling the SMPS
regulators, which fails. This was fixed fixed by adding separate
regulator type which uses correct logic and calculations for the
voltage levels.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
aat2870_get_regulator
commit d4d6373c1109b11c8118340be97ae31b8f94d66a upstream.
In current implementation, the pointer ri is not NULL if no id is matched.
Fix it by checking i == ARRAY_SIZE(aat2870_regulators) if no id is matched.
commit 52553ddffad76ccf192d4dd9ce88d5818f57f62a upstream.
Commit fa27271bc8d2("genirq: Fixup poll handling") introduced a
regression that broke irqfixup/irqpoll for some hardware configurations.
Amidst reorganizing 'try_one_irq', that patch removed a test that
checked for 'action->handler' returning IRQ_HANDLED, before acting on
the interrupt. Restoring this test back returns the functionality lost
since 2.6.39. In the current set of tests, after 'action' is set, it
must precede '!action->next' to take effect.
With this and my previous patch to irq/spurious.c, c75d720fca8a, all
IRQ regressions that I have encountered are fixed.
Signed-off-by: Edward Donovan <edward.donovan@numble.net>
Reported-and-tested-by: Rogério Brito <rbrito@ime.usp.br>
commit e55b32c110b025ce07b40227f620e99700bf8741 upstream.
rtl_lps_leave can be called from interrupt context, so we have to
disable interrupts when taking lps_lock.
Below is full lockdep info about deadlock:
[ 93.815269] =================================
[ 93.815390] [ INFO: inconsistent lock state ]
[ 93.815472] 2.6.41.1-3.offch.fc15.x86_64.debug #1
[ 93.815556] ---------------------------------
[ 93.815635] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
[ 93.815743] swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
[ 93.815832] (&(&rtlpriv->locks.lps_lock)->rlock){+.?...}, at: [<ffffffffa025dad6>] rtl_lps_leave+0x26/0x103 [rtlwifi]
[ 93.815947] {SOFTIRQ-ON-W} state was registered at:
[ 93.815947] [<ffffffff8108e10d>] __lock_acquire+0x369/0xd0c
[ 93.815947] [<ffffffff8108efb3>] lock_acquire+0xf3/0x13e
[ 93.815947] [<ffffffff814e981d>] _raw_spin_lock+0x45/0x79
[ 93.815947] [<ffffffffa025de34>] rtl_swlps_rf_awake+0x5a/0x76 [rtlwifi]
[ 93.815947] [<ffffffffa025aec0>] rtl_op_config+0x12a/0x32a [rtlwifi]
[ 93.815947] [<ffffffffa01d614b>] ieee80211_hw_config+0x124/0x129 [mac80211]
[ 93.815947] [<ffffffffa01e0af3>] ieee80211_dynamic_ps_disable_work+0x32/0x47 [mac80211]
[ 93.815947] [<ffffffff81075aa5>] process_one_work+0x205/0x3e7
[ 93.815947] [<ffffffff81076753>] worker_thread+0xda/0x15d
[ 93.815947] [<ffffffff8107a119>] kthread+0xa8/0xb0
[ 93.815947] [<ffffffff814f3184>] kernel_thread_helper+0x4/0x10
[ 93.815947] irq event stamp: 547822
[ 93.815947] hardirqs last enabled at (547822): [<ffffffff814ea1a7>] _raw_spin_unlock_irqrestore+0x45/0x61
[ 93.815947] hardirqs last disabled at (547821): [<ffffffff814e9987>] _raw_spin_lock_irqsave+0x22/0x8e
[ 93.815947] softirqs last enabled at (547790): [<ffffffff810623ed>] _local_bh_enable+0x13/0x15
[ 93.815947] softirqs last disabled at (547791): [<ffffffff814f327c>] call_softirq+0x1c/0x30
[ 93.815947]
[ 93.815947] other info that might help us debug this:
[ 93.815947] Possible unsafe locking scenario:
[ 93.815947]
[ 93.815947] CPU0
[ 93.815947] ----
[ 93.815947] lock(&(&rtlpriv->locks.lps_lock)->rlock);
[ 93.815947] <Interrupt>
[ 93.815947]
[ 93.815947] *** DEADLOCK ***
[ 93.815947]
[ 93.815947] no locks held by swapper/0.
[ 93.815947]
[ 93.815947] stack backtrace:
[ 93.815947] Pid: 0, comm: swapper Not tainted 2.6.41.1-3.offch.fc15.x86_64.debug #1
[ 93.815947] Call Trace:
[ 93.815947] <IRQ> [<ffffffff814dfd00>] print_usage_bug+0x1e7/0x1f8
[ 93.815947] [<ffffffff8101a849>] ? save_stack_trace+0x2c/0x49
[ 93.815947] [<ffffffff8108d55c>] ? print_irq_inversion_bug.part.18+0x1a0/0x1a0
[ 93.815947] [<ffffffff8108dc8a>] mark_lock+0x106/0x220
[ 93.815947] [<ffffffff8108e099>] __lock_acquire+0x2f5/0xd0c
[ 93.815947] [<ffffffff810152af>] ? native_sched_clock+0x34/0x36
[ 93.830125] [<ffffffff810152ba>] ? sched_clock+0x9/0xd
[ 93.830125] [<ffffffff81080181>] ? sched_clock_local+0x12/0x75
[ 93.830125] [<ffffffffa025dad6>] ? rtl_lps_leave+0x26/0x103 [rtlwifi]
[ 93.830125] [<ffffffff8108efb3>] lock_acquire+0xf3/0x13e
[ 93.830125] [<ffffffff814e981d>] _raw_spin_lock+0x45/0x79
[ 93.830125] [<ffffffff81422467>] ? skb_dequeue+0x62/0x6d
[ 93.830125] [<ffffffffa025dad6>] rtl_lps_leave+0x26/0x103 [rtlwifi]
[ 93.830125] [<ffffffffa025f677>] _rtl_pci_ips_leave_tasklet+0xe/0x10 [rtlwifi]
[ 93.830125] [<ffffffff8106281f>] tasklet_action+0x8d/0xee
[ 93.830125] [<ffffffff810629ce>] __do_softirq+0x112/0x25a
[ 93.830125] [<ffffffff814f327c>] call_softirq+0x1c/0x30
[ 93.830125] [<ffffffff81010bf6>] do_softirq+0x4b/0xa1
[ 93.830125] [<ffffffff81062d7d>] irq_exit+0x5d/0xcf
[ 93.830125] [<ffffffff814f3b7e>] do_IRQ+0x8e/0xa5
[ 93.830125] [<ffffffff814ea533>] common_interrupt+0x73/0x73
[ 93.830125] <EOI> [<ffffffff8108b825>] ? trace_hardirqs_off+0xd/0xf
[ 93.830125] [<ffffffff812bb6d5>] ? intel_idle+0xe5/0x10c
[ 93.830125] [<ffffffff812bb6d1>] ? intel_idle+0xe1/0x10c
[ 93.830125] [<ffffffff813f8d5e>] cpuidle_idle_call+0x11c/0x1fe
[ 93.830125] [<ffffffff8100e2ef>] cpu_idle+0xab/0x101
[ 93.830125] [<ffffffff814c6373>] rest_init+0xd7/0xde
[ 93.830125] [<ffffffff814c629c>] ? csum_partial_copy_generic+0x16c/0x16c
[ 93.830125] [<ffffffff81d4bbb0>] start_kernel+0x3dd/0x3ea
[ 93.830125] [<ffffffff81d4b2c4>] x86_64_start_reservations+0xaf/0xb3
[ 93.830125] [<ffffffff81d4b140>] ? early_idt_handlers+0x140/0x140
[ 93.830125] [<ffffffff81d4b3ca>] x86_64_start_kernel+0x102/0x111
Resolves:
https://bugzilla.redhat.com/show_bug.cgi?id=755154
Reported-by: vjain02@students.poly.edu
Reported-and-tested-by: Oliver Paukstadt <pstadt@sourcentral.org>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 4c81f045c0bd2cbb78cc6446a4cd98038fe11a2e upstream.
ext4_end_io_dio() queues io_end->work and then clears iocb->private;
however, io_end->work calls aio_complete() which frees the iocb
object. If that slab object gets reallocated, then ext4_end_io_dio()
can end up clearing someone else's iocb->private, this use-after-free
can cause a leak of a struct ext4_io_end_t structure.
Detected and tested with slab poisoning.
[ Note: Can also reproduce using 12 fio's against 12 file systems with the
following configuration file:
[global]
direct=1
ioengine=libaio
iodepth=1
bs=4k
ba=4k
size=128m
[create]
filename=${TESTDIR}
rw=write
-- tytso ]
Google-Bug-Id: 5354697
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reported-by: Kent Overstreet <koverstreet@google.com>
Tested-by: Kent Overstreet <koverstreet@google.com>
commit 24ca9a847791fd53d9b217330b15f3c285827a18 upstream.
By returning '0' instead of 'EAGAIN' when the tests in xs_nospace() fail
to find evidence of socket congestion, we are making the RPC engine believe
that the message was incorrectly sent and so it disconnects the socket
instead of just retrying.
The bug appears to have been introduced by commit
5e3771ce2d6a69e10fcc870cdf226d121d868491 (SUNRPC: Ensure that xs_nospace
return values are propagated).
Reported-by: Andrew Cooper <andrew.cooper3@citrix.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Andrew Cooper <andrew.cooper3@citrix.com>
commit ed3e80c4c991a52f9fce3421536a78e331ae0949 upstream.
commit 2391a0e06789a3f1718dee30b282562f7ed28c87 upstream.
This patch makes it possible to set DAI mode to its currently applied
value even if codec is active. This is necessary to allow
aplay -t raw -r 44100 -f S16_LE -c 2 < /dev/urandom &
alsactl store -f backup.state
alsactl restore -f backup.state
to work without returning errors. This patch is based on a patch sent
by Klaus Kurzmann <mok@fluxnetz.de>.
Signed-off-by: Timo Juhani Lindfors <timo.lindfors@iki.fi>
commit 0f768a7235d3dfb6f4833030a95a06419df089cb upstream.
Commit 6992f533 ("sysfs: Use one lockdep class per sysfs attribute")
requires 'struct attribute' objects to be initialized with sysfs_attr_init().
commit 54dc6cabe684375b3cf549c7b0545613d694aba8 upstream.
The coefficient RAM must be saved in a shadow so it can
be restored when the codec is powered on using
regulator_bulk_enable().
Signed-off-by: Johannes Stezenbach <js@sig21.net>
commit 6759dc323826c2c806c998cd93945c5476688dd2 upstream.
When the imux entries are rebuilt in alc_rebuild_imux_for_auto_mic(),
the initialization of index field is missing. It may work without it
casually when the original imux was created by the auto-parser, but
it's definitely broken in the case of static configs where no imux was
parsed beforehand. Because of this, the auto-mic switching doesn't
work properly on some model options.
This patch adds the missing initialization of index field.
Reported-by: Dmitry Nezhevenko <dion@inhex.net>
commit a29878553a9a7b4c06f93c7e383527cf014d4ceb upstream.
commit 6175ddf06b6172046a329e3abfd9c901a43efd2e optimized the mem*io
functions that have been used to send commands to the device. these
optimizations somehow corrupted the communication with the lx6464es,
that resulted the device to be unusable with kernels after 2.6.33.
this patch emulates the memcpy_*_io functions via a loop to avoid these
problems.
Signed-off-by: Tim Blechmann <tim@klingt.org>
LKML-Reference: <4ECB5257.4040600@ladisch.de>
commit 187d333edc0a8e1bb507900ce89853ffe3bd2c84 upstream.
VT1708 has no support for unsolicited events per jack-plug, the driver
implements the workq for polling the jack-detection. The mixer element
"Jack Detect" was supposed to control this behavior on/off, but this
doesn't work properly as is now. The workq is always started and the
HP automute is always enabled.
This patch fixes the jack-detect control behavior by triggering / stopping
the work appropriately at the state change. Also the work checks the
internal state to continue scheduling or not.
commit 11ed0ba1754841316d4095478944300acf19acc3 upstream.
This patch implements a workaround for PL310 erratum 769419. On
revisions of the PL310 prior to r3p2, the Store Buffer does not
automatically drain. This can cause normal, non-cacheable writes to be
retained when the memory system is idle, leading to suboptimal I/O
performance for drivers using coherent DMA.
This patch adds an optional wmb() call to the cpu_idle loop. On systems
with an outer cache, this causes an explicit flush of the store buffer.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
commit 46232a3622c6e33605906ee6690dfef372925f53 upstream.
Current code registers voltage layer details for TWL PMIC even when a TWL
has not been registered. Fix this to only register the TWL with voltage
layer when the TWL PMIC is initialized by board-level code.
Signed-off-by: Kevin Hilman <khilman@ti.com>
commit a8a6565c7615cab3608d75af95b5c8a3522cd7c4 upstream.
This patch selects ARM_AMBA if OMAP3_EMU is defined because
OC_ETM depends on ARM_AMBA, so fix the link failure[1].
[1],
arch/arm/kernel/built-in.o: In function `etm_remove':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:609: undefined
reference to `amba_release_regions'
arch/arm/kernel/built-in.o: In function `etb_remove':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:409: undefined
arch/arm/kernel/built-in.o: In function `etm_init':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:640: undefined
reference to `amba_driver_register'
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:646: undefined
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:648: undefined
reference to `amba_driver_unregister'
arch/arm/kernel/built-in.o: In function `etm_probe':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:545: undefined
reference to `amba_request_regions'
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:595: undefined
arch/arm/kernel/built-in.o: In function `etb_probe':
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:347: undefined
/home/tom/git/omap/linux-2.6-omap/arch/arm/kernel/etm.c:392: undefined
arch/arm/mach-omap2/built-in.o: In function `emu_init':
/home/tom/git/omap/linux-2.6-omap/arch/arm/mach-omap2/emu.c:62:
undefined reference to `amba_device_register'
/home/tom/git/omap/linux-2.6-omap/arch/arm/mach-omap2/emu.c:63:
make: *** [.tmp_vmlinux1] Error 1
making modules
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit cc1b0765da6078b906772b79ff211b88cc0ae958 upstream.
The address spaces, irqs and dma reqs count APIs return the
number of corresponding entries in a hwmod including a additional
null value or a -1 terminator in the structure introduced recently.
More information here:
- 212738a4: omap_hwmod: use a terminator record with omap_hwmod_mpu_irqs
arrays
- 78183f3f: omap_hwmod: use a null structure record to terminate
omap_hwmod_addr_space arrays
- bc614958: omap_hwmod: use a terminator record with omap_hwmod_dma_info
arrays
The issue with irqs and dma info was originally reported by Benoit Cousson.
The devices which have multiple hwmods and use device_build_ss are
broken with this, as their resources are populated with a extra null
value, subsequently the probe fails. So fix the API not to include
the array terminator in the count.
Reported-by: Benoit Cousson <b-cousson@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimar@ti.com>
Signed-off-by: sricharan <r.sricharan@ti.com>
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
commit 5a4f1844c2ba21f804d7729306d9b16eaeb724a8 upstream.
Fix a bug which has been on this driver since
it was added by the original commit 984aa6db
which would never clear IRQSTATUS bits.
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit c2735391fbc68feae10d6d14e60956c8106e725f upstream.
reg | (1 << clk->enable_shift) always evaluates to true. Switch it
to & which makes much more sense. Same fix as 13be9f00 (ARM i.MX28: fix
bit operation) at a different location.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Shawn Guo <shawn.guo@freescale.com>
commit c0a39151a4055332897cba615623d3de2f3896df upstream.
Since CONFIG_USB_GADGET_PXA27X and other macros are renamed to
CONFIG_USB_PXA27X. Update them in arch/arm/mach-pxa and arch/arm/configs
to keep consistent.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
commit a32839696a8eef813a1aff604fbad9a32dff6c95 upstream.
While the OLPC display appears to be able to handle either positive
or negative sync, the Display Controller only recognises positive sync.
This brings viafb (for XO-1.5) in line with lxfb (for XO-1) and
fixes a recent regression where the XO-1.5 DCON could no longer be
frozen. Thanks to Florian Tobias Schandinat for helping identify
the fix.
Test case: from a vt,
echo 1 > /sys/devices/platform/dcon/freeze
should cause the current screen contents to freeze, rather than garbage being
displayed.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
commit 6c47e5c23aa2a7c54ad7ac13af4bd56cd9e703bf upstream.
Fixes i2c test failures when i2c_algo_bit.bit_test=1.
The hw doesn't actually require a mask, so just set it
to the default mask bits for r1xx-r4xx radeon ddc.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: Jean Delvare <khali@linux-fr.org>
commit 4cac2eb158c6da0c761689345c6cc5df788a6292 upstream.
Previously we claimed device ID 0x7450, regardless of the vendor, which is
clearly wrong. Now we'll claim that device ID only for AMD.
I suspect this was just a typo in the original code, but it's possible this
change will break shpchp on non-7450 AMD bridges. If so, we'll have to fix
them as we find them.
Reference: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=638863
Reported-by: Ralf Jung <ralfjung-e@gmx.de>
Cc: Joerg Roedel <joerg.roedel@amd.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 04b38670cf46c096705f24e92a8747d1ab89e53c upstream.
When the brightness property is inquired while the backlight is disabled,
the driver returns a wrong value (zero) because it probes the value after
the backlight was turned off. This caused a black screen even after the
backlight is enabled again. It should return the internal backlight_level
instead, so that it won't be influenced by the backlight-enable state.
BugLink: https://bugs.freedesktop.org/show_bug.cgi?id=41926
BugLink: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/872652
Tested-by: Kamal Mostafa <kamal@canonical.com>
Cc: Alex Davis <alex14641@yahoo.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
commit 9ca1d10d748e56964de95e3ed80211b192f56cf4 upstream.
Unlike the previous one, I don't have known testcases it fixes. I'd
rather not go through the same debug cycle on whatever testcases those
might be.
Signed-off-by: Eric Anholt <eric@anholt.net>
commit 406478dc911e16677fbd9c84d1d50cdffbc031ab upstream.
Fixes rendering failures in Unigine Tropics and Sanctuary and the mesa
"fire" demo.
commit 775d17b6ca4357048f36c22151335addfe15db4b upstream.
So don't forget to restore them on resume and dump them into
the error state.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
commit d724502a9d7a46f4a56a1663b1f50d2dc9d1ef40 upstream.
I missed this part the first time through.
commit a5cd335165e31db9dbab636fd29895d41da55dd2 upstream.
There is a potential integer overflow in drm_mode_dirtyfb_ioctl()
if userspace passes in a large num_clips. The call to kmalloc would
allocate a small buffer, and the call to fb->funcs->dirty may result
in a memory corruption.
Reported-by: Haogang Chen <haogangchen@gmail.com>
Signed-off-by: Xi Wang <xi.wang@gmail.com>
commit 274252862f386b7868f35bf5ceaa5391a8ccfdf3 upstream.
This was broken by commit 7759995c75ae0cbd4c861582908449f6b6208e7a (yes,
myself). The basic problem here is since the digest state is only saved
after the last chunk, the state array is only valid when handling the
first chunk of the next buffer. Broken since linux-3.0.
Signed-off-by: Phil Sutter <phil.sutter@viprinet.com>
commit 0f751e641a71157aa584c2a2e22fda52b52b8a56 upstream.
From mhalcrow's original commit message:
Characters with ASCII values greater than the size of
filename_rev_map[] are valid filename characters.
ecryptfs_decode_from_filename() will access kernel memory beyond
that array, and ecryptfs_parse_tag_70_packet() will then decrypt
those characters. The attacker, using the FNEK of the crafted file,
can then re-encrypt the characters to reveal the kernel memory past
the end of the filename_rev_map[] array. I expect low security
impact since this array is statically allocated in the text area,
and the amount of memory past the array that is accessible is
limited by the largest possible ASCII filename character.
This patch solves the issue reported by mhalcrow but with an
implementation suggested by Linus to simply extend the length of
filename_rev_map[] to 256. Characters greater than 0x7A are mapped to
0x00, which is how invalid characters less than 0x7A were previously
being handled.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Reported-by: Michael Halcrow <mhalcrow@google.com>
commit cc6bcf7d2ec2234e7b41770185e4dc826390185e upstream.
The wrong bits were put on the wire, fix that.
This fixes kernel bug #42562.
Signed-off-by: Sheng-Hui J. Chu <jeffchu@broadcom.com>
commit 32001d6fe9ac6b0423e674a3093aa56740849f3b upstream.
Dirty pages weren't being written back when an mmap'ed eCryptfs file was
closed before the mapping was unmapped. Since f_ops->flush() is not
called by the munmap() path, the lower file was simply being released.
This patch flushes the eCryptfs file in the vm_ops->close() path.
https://launchpad.net/bugs/870326
commit b59db43ad4434519feb338eacb01d77eb50825c5 upstream.
The file creation path prematurely called d_instantiate() and
unlock_new_inode() before the eCryptfs inode info was fully
allocated and initialized and before the eCryptfs metadata was written
to the lower file.
This could result in race conditions in subsequent file and inode
operations leading to unexpected error conditions or a null pointer
dereference while attempting to use the unallocated memory.
https://launchpad.net/bugs/813146
This reverts commit f0cc710a6dec5b808a6f13f1f8853c094fce5f12.
Cc: Matthieu Castet <matthieu.castet@parrot.com>
Cc: Thomas Poussevin <thomas.poussevin@parrot.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
commit 09f363c7363eb10cfb4b82094bd7064e5608258b upstream.
The callback must not return -1 when nr_to_scan is zero. Fix the bug in
fs/super.c and add this requirement to the callback specification.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 93840ac40bb0d0f177ef8af74e64671be67e8c37 upstream.
Function tt_response_fill_table() actually uses a tt_local_entry pointer to
iterate either over the local or the global table entries (it depends on the
what hash table is passed as argument). To iterate over such entries the
hlist_for_each_entry_rcu() macro has to access their "hash_entry" field which
MUST be at the same position in both the tt_global/local_entry structures.
Reported-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Signed-off-by: Antonio Quartulli <ordex@autistici.org>
Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
commit 6e8014947d6469df1566e9e253805557c5c0e4e0 upstream.
After removing the batman-adv module, the hash may be already gone
when tt_global_del_orig() tries to clean the hash. This patch adds
a sanity check to avoid this.
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Tested-by: Alexey Fisher <bug-track@fisher-privat.net>
commit 531027fcddbcf81c9937dd04f08a7e8f11fd47d2 upstream.
struct tt_global_entry holds a reference to an orig_node which must be
decremented before deallocating the structure.
commit 9d8523931f7f5eb8900077f0da0fbe6b8ad0010b upstream.
In the TT_RESPONSE packet, the number of carried entries is not correctly set.
This leads to a wrong interpretation of the packet payload on the receiver side
causing random entries to be added to the global translation table. Therefore
the latter gets always corrupted, triggering a table recovery all the time.
commit 31901264511cf20c5ed33b8649a3ca9ce28df60b upstream.
Currently the counter of tt_local_entry structures (tt_local_num) is incremented
each time the tt_local_reset_flags() is invoked causing the node to send wrong
TT_REPONSE packets containing a copy of non-initialised memory thus corrupting
other nodes global translation table and making higher level communication
impossible.
Reported-by: Junkeun Song <jun361@gmail.com>
Acked-by: Junkeun Song <jun361@gmail.com>
commit c4f9c4c2b3f1831e932e04db992cf6fe92c2a95a upstream.
It's needed for 3 pipe support as well as just regular functionality
(e.g. DisplayPort).
Tested-by: Adam Jackson <ajax@redhat.com>
Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-off-by: Robert Hooker <robert.hooker@canonical.com>
