devpts_pty_new()
d_alloc_name return NULL in case error, but we expect errno in
devpts_pty_new.
Addresses http://bugzilla.openvz.org/show_bug.cgi?id=1758
Signed-off-by: Andrey Vagin <avagin@openvz.org>
The test program below will hang because io_getevents() uses
add_wait_queue_exclusive(), which means the wake_up() in io_destroy() only
wakes up one of the threads. Fix this by using wake_up_all() in the aio
code paths where we want to make sure no one gets stuck.
// t.c -- compile with gcc -lpthread -laio t.c
#include <libaio.h>
#include <pthread.h>
#include <stdio.h>
#include <unistd.h>
static const int nthr = 2;
void *getev(void *ctx)
struct io_event ev;
io_getevents(ctx, 1, 1, &ev, NULL);
printf("io_getevents returned\n");
return NULL;
int main(int argc, char *argv[])
io_context_t ctx = 0;
pthread_t thread[nthr];
int i;
io_setup(1024, &ctx);
for (i = 0; i < nthr; ++i)
pthread_create(&thread[i], NULL, getev, ctx);
sleep(1);
io_destroy(ctx);
pthread_join(thread[i], NULL);
return 0;
Signed-off-by: Roland Dreier <roland@purestorage.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Cc: <stable@kernel.org>
Remove code enabled only when CONFIG_PREEMPT_RT is turned on because it is
not used in the vanilla kernel.
Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Rodolfo Giometti <giometti@linux.it>
ADFS (FileCore) storage complies with the RISC OS filetype specification
(12 bits of file type information is stored in the file load address,
rather than using a file extension). The existing driver largely ignores
this information and does not present it to the end user.
It is desirable that stored filetypes be made visible to the end user to
facilitate a precise copy of data and metadata from a hard disc (or image
thereof) into a RISC OS emulator (such as RPCEmu) or to a network share
which can be accessed by real Acorn systems.
This patch implements a per-mount filetype suffix option (use -o
ftsuffix=1) to present any filetype as a ,xyz hexadecimal suffix on each
file. This type suffix is compatible with that used by RISC OS systems
that access network servers using NFS client software and by RPCemu's host
filing system.
Signed-off-by: Stuart Swales <stuart.swales.croftnuisk@gmail.com>
ADFS (FileCore) storage complies with the RISC OS timestamp specification
(40-bit centiseconds since 01 Jan 1900 00:00:00). It is desirable that
stored timestamp precision be maintained to facilitate a precise copy of
data and metadata from a hard disc (or image thereof) into a RISC OS
emulator (such as RPCEmu).
This patch implements a full-precision conversion from ADFS to Unix
timestamp as the existing driver, for ease of calculation with old 32-bit
compilers, uses the common trick of shifting the 40-bits representing
centiseconds around into 32-bits representing seconds thereby losing
precision.
Signed-off-by: Stuart Swales<stuart.swales.croftnuisk@gmail.com>
Kernel crashes in fs/adfs module when accessing directories with a large
number of objects on mounted Acorn ADFS E+/F+ format discs (or images) as
the existing code writes off the end of the fixed array of struct
buffer_head pointers.
Additionally, each directory access that didn't crash would leak a buffer
as nr_buffers was not adjusted correctly for E+/F+ discs (was always left
as one less than required).
The patch fixes this by allocating a dynamically-sized set of struct
buffer_head pointers if necessary for the E+/F+ case (many directories
still do in fact fit in 2048 bytes) and sets the correct nr_buffers so
that all buffers are released.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=26072
Tested by tar'ing the contents of my RISC PC's E+ format 20Gb HDD which
contains a number of large directories that previously crashed the kernel.
page-types.c doesn't supply a way to specify the debugfs path and the
original debugfs path is not usual on most machines. This patch supplies
a way to auto mount debugfs if needed.
This patch is heavily inspired by tools/perf/utils/debugfs.c
[akpm@linux-foundation.org: make functions static]
[akpm@linux-foundation.org: fix debugfs_mount() signature]
Signed-off-by: Chen Gong <gong.chen@linux.intel.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
I noticed the 'mcelog' program had no comment and then ended up "fixing"
a few more things:
* reiserfsck -V does not print "reiserfsprogs" (any more?)
* is "udevinfo" still shipped? udevd certainly is
* grub2 doesn't have a 'grub' binary
* add a "# how to get the mcelog version" comment
Signed-off-by: Christian Kujau <lists@nerdbynature.de>
There is a missing case for "Chapter 3: Placing Braces and Spaces". We
often know we should not use braces where a single statement. The first
case is:
if (condition)
action();
Another case is:
if (condition)
do_this();
else
do_that();
However, I can not find a description of the second case.
Signed-off-by: Harry Wei <harryxiyou@gmail.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
When CONFIG_SYSCTL=n, we get the following warning:
fs/coda/sysctl.c:18: warning: `coda_tabl' defined but not used
Fix the warning by making sure coda_table and it's callee function are in
the same context. Also clean up the code by removing extra #ifdef.
[akpm@linux-foundation.org: remove unneeded stub macros]
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
Cc: Jan Harkes <jaharkes@cs.cmu.edu>
Not all 64-bit systems require ISA-style DMA, so allow it to be
configurable. x86 utilizes the generic ISA DMA allocator from
kernel/dma.c, so require it only when CONFIG_ISA_DMA_API is enabled.
Disabling CONFIG_ISA_DMA_API is dependent on x86_64 since those machines
do not have ISA slots and benefit the most from disabling the option (and
on CONFIG_EXPERT as required by H. Peter Anvin).
When disabled, this also avoids declaring claim_dma_lock(),
release_dma_lock(), request_dma(), and free_dma() since those interfaces
will no longer be provided.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
The generic floppy disk driver utilizies the interface provided by
CONFIG_ISA_DMA_API, specifically claim_dma_lock(), release_dma_lock(),
request_dma(), and free_dma(). Thus, there's a strict dependency on the
config option and the driver should only be loaded if the kernel supports
ISA-style DMA.
8237A utilizes the interface provided by CONFIG_ISA_DMA_API, specifically
claim_dma_lock() and release_dma_lock(). Thus, there's a strict
dependency on the config option and the module should only be loaded if
the kernel supports ISA-style DMA.
IORESOURCE_DMA cannot be assigned without utilizing the interface
provided by CONFIG_ISA_DMA_API, specifically request_dma() and
free_dma(). Thus, there's a strict dependency on the config option and
limits IORESOURCE_DMA only to architectures that support ISA-style DMA.
ia64 is not one of those architectures, so pnp_check_dma() no longer
needs to be special-cased for that architecture.
pnp_assign_resources() will now return -EINVAL if IORESOURCE_DMA is
attempted on such a kernel.
This is a platform driver that supports the built-in real-time clock on
Tegra SOCs.
Signed-off-by: Andrew Chew <achew@nvidia.com>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Jon Mayo <jmayo@nvidia.com>
Don't allow everybogy to write to NVRAM.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: Andy Sharp <andy.sharp@onstor.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Add alarm/wakeup support to rtc isl1208 driver
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
There is a general move to replace bus-specific PM ops with dev_pm_ops in
order to facilitate core improvements. Do this conversion for DS1374.
In do_mounts_rd() if memory cannot be allocated, return -ENOMEM.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
With GCC-4.6 we get warnings about things being 'set but not used'.
In load_elf_binary() this can happen with reloc_func_desc if ELF_PLAT_INIT
is defined, but doesn't use the reloc_func_desc argument.
Quiet the warning/error by marking reloc_func_desc as __maybe_unused.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Add a comment to ep_poll(), rename labels a bit clearly, fix a warning of
unused variable from gcc and optimize the non-blocking path a little.
Hinted-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
hannes@cmpxchg.org:
: The non-blocking ep_poll path optimization introduced skipping over the
: return value setup.
: Initialize it properly, my userspace gets upset by epoll_wait() returning
: random things.
: In addition, remove the reinitialization at the fetch_events label, the
: return value is garuanteed to be zero when execution reaches there.
[hannes@cmpxchg.org: fix initialization]
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Shawn Bohrer <shawn.bohrer@gmail.com>
Acked-by: Davide Libenzi <davidel@xmailserver.org>
Move the event readiness check into a proper inline, and use it uniformly
inside ep_poll() code. Events in the ->ovflist are no less ready than the
ones in ->rdllist.
Add brackets around typecasted argument in crc32() macro.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Because the second and third arguments of memset have the same type, it
turns out to be really easy to mix them up.
This bug comes up time after time, so checkpatch should really be checking
for it at patch submission time.
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Andy Whitcroft <apw@shadowen.org>
If you run checkpatch against multiple patches, and one of them has a
whitespace issue which can be helped via a script (rpt_cleaners), you will
see the same NOTE over and over for all subsequent patches. It makes it
seem like those patches also have whitespace problems when in reality,
there's only one or two bad apples.
So reset rpt_cleaners back to 0 after we've issued the note so that it
only shows up near the patch with the actual problems.
Cc: Andy Whitcroft <apw@canonical.com>
Use resource_size().
Signed-off-by: Chris Ball <cjb@laptop.org>
Cc: Madhusudhan Chikkature <madhu.cr@ti.com>
Cc: <linux-mmc@vger.kernel.org>
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: Tony Lindgren <tony@atomide.com>
Analog Devices' SigmaStudio can produce firmware blobs for devices with
these DSPs embedded (like some audio codecs). Allow these device drivers
to easily parse and load them.
1. simple_strto*() do not contain overflow checks and crufty,
libc way to indicate failure.
2. strict_strto*() also do not have overflow checks but the name and
comments pretend they do.
3. Both families have only "long long" and "long" variants,
but users want strtou8()
4. Both "simple" and "strict" prefixes are wrong:
Simple doesn't exactly say what's so simple, strict should not exist
because conversion should be strict by default.
The solution is to use "k" prefix and add convertors for more types.
Enter
kstrtoull()
kstrtoll()
kstrtoul()
kstrtol()
kstrtouint()
kstrtoint()
kstrtou64()
kstrtos64()
kstrtou32()
kstrtos32()
kstrtou16()
kstrtos16()
kstrtou8()
kstrtos8()
Include runtime testsuite (somewhat incomplete) as well.
strict_strto*() become deprecated, stubbed to kstrto*() and
eventually will be removed altogether.
Use kstrto*() in code today!
Note: on some archs _kstrtoul() and _kstrtol() are left in tree, even if
they'll be unused at runtime. This is temporarily solution,
because I don't want to hardcode list of archs where these
functions aren't needed. Current solution with sizeof() and
__alignof__ at least always works.
Signed-off-by: Kenneth Heitke <kheitke@codeaurora.org>
commit 5b2e303f6df ("[media] rc-core: convert winbond-cir") moved the
files, update the pattern.
Acked-by: David Härdeman <david@hardeman.nu>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
And set the status to Orphan.
Cc: Jeroen Vreeken <pe1rxq@amsat.org>
Cc: Hans Verkuil <hverkuil@xs4all.nl>
commit 937f961a653 ("x86: Move sfi to platform") moved the files, update
the pattern.
commit 82e6923e186 ("ARM: lh7a40x: remove unmaintained platform support")
removed support, remove it from MAINTAINERS.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
commit 3b3da9d25ae ("x86: Move scx200 to platform") moved it, convert the
pattern too.
Commit 88606e80da0 ("MAINTAINERS: Update timer related entries") added a
file pattern that didn't actually exist.
commit 66fa12c571d ("ieee1394: remove the old IEEE 1394 driver stack")
removed the code, remove the MAINTAINERS entry.
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Commit 52b661449ae ("[media] rc: Rename remote controller type to rc_type
instead of ir_type") moved it around.
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Acked-by: Harry Wei <harryxiyou@gmail.com>
Commit 6d803ba736a ("ARM: 6483/1: arm & sh: factorised duplicated
clkdev.c") moved it to a separate directory.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
CC'ing lkml is the default and doesn't need separate entries.
Remove these patterns until such files are actually in the tree.
wiki-analog doesn't seem to work, but wiki.analog does.
Cc: Mike Frysinger <vapier.adi@gmail.com>
Typo in path.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
Add quotes around email address with periods and commas. So they don't
explode when pasted into certain email clients.
Cc: "Mark F. Brown" <mark.brown314@gmail.com>
Cc: "Gustavo F. Padovan" <padovan@profusion.mobi>
Cc: "Stephen M. Cameron" <scameron@beardog.cce.hp.com>
Cc: "Lee, Chun-Yi" <jlee@novell.com>
At least one tree:
ARM/EZX SMARTPHONES (A780, A910, A1200, E680, ROKR E2 and ROKR E6)
is available via topgit. Add mention of topgit in the MAINTAINERS
description section.
Extend the usage of the K section in the MAINTAINERS file to support
matching regular expressions to any arbitrary text that may precede the
patch itself. For example, the commit message or mail headers generated
by git-format-patch.
Original-patch-by: L. Alberto Giménez <agimenez@sysvalve.es>
Acked-by: L. Alberto Giménez <agimenez@sysvalve.es>
We've been burned by regressions/bugs which we later realized could have
been triaged quicker if only we'd paid closer attention to dmesg. To make
it easier to audit dmesg, we'd like to make DEFAULT_MESSAGE_LEVEL
Kconfig-settable. That way we can set it to KERN_NOTICE and audit any
messages <= KERN_WARNING.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Joe Perches <joe@perches.com>
Cc: Olof Johansson <olofj@chromium.org>
In an effort to reduce kernel address leaks that might be used to help
target kernel privilege escalation exploits, this patch uses %pK when
displaying addresses in /proc/kallsyms, /proc/modules, and
/sys/module/*/sections/*.
Note that this changes %x to %p, so some legitimately 0 values in
/proc/kallsyms would have changed from 00000000 to "(null)". To avoid
this, "(null)" is not used when using the "K" format. Anything that was
already successfully parsing "(null)" in addition to full hex digits
should have no problem with this change. (Thanks to Joe Perches for the
suggestion.) Due to the %x to %p, "void *" casts are needed since these
addresses are already "unsigned long" everywhere internally, due to their
starting life as ELF section offsets.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Cc: Eugene Teo <eugene@redhat.com>
Cc: Dan Rosenberg <drosenberg@vsecurity.com>
For a platform with many consoles like:
"console=tty1 console=ttyMFD2 console=ttyS0 earlyprintk=mrst"
Each time when the non "selected_console" (tty1 and ttyMFD2 here) get
registered, the existing kernel message will be printed out on registered
consoles again, the "mrst" early console will get some same message for 3
times, and "tty1" will get some for twice.
As suggested by Andrew Morton, every time a new console is registered, it
will be set as the "exclusive" console which will dump the already
existing kernel messages.
Signed-off-by: Feng Tang <feng.tang@intel.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
