Add gpio irq masking in irq_sync_unlock.
Change-Id: I008caf58ae82d9ed888f4720f54675e9106f027d
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/98664
Reviewed-by: Simone Willett <swillett@nvidia.com>
Some boards don't have a vddio regulator for few rails hence not getting
the regulator handle. And we assume that those rails are always powered.
Hence rephrased the error message and lowered the loglevel to KERN_INFO.
Bug 976177
Change-Id: I92b82f75934eaf7137584a625065e3389b6ae1b7
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/100490
Modified board file to increase the speed of I2C connection
for Atmel touch driver from 100KHz to 400KHz
Bug 962710
Bug 950422
Change-Id: Ib0f08af35d84cfc1f33cc3771d2aa422f79d98d0
Signed-off-by: Ali Ekici <aekici@nvidia.com>
Reviewed-on: http://git-master/r/97744
Reviewed-by: Robert Collins <rcollins@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: David Jung <djung@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Fix fps update condition in max77663_regulator_set_fps().
Bug 930883
Change-Id: I2f57603320a91b2727932586fc3c66d9de347d64
signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/92707
Unmasked EN0 rising interrupt to generate fast PMU_INT by
EN0(POWER_KEY).
Bug 930883
Change-Id: I9a3d8c4f564e83deea86fbd3d05f14933a0b0f65
Reviewed-on: http://git-master/r/98665
Remove UART clock enable code, as UART clock gating is not
needed in tibluesleep driver.
Remove un-wanted tasklets, workqueues and wakelocks
Remove extra lines and spaces
Change-Id: I422e09ece2c736c4a98911a5bd84029ad654cb08
Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com>
Reviewed-on: http://git-master/r/96944
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
bug 978829
Reviewed-on: http://git-master/r/99460
(cherry picked from commit b5531673e3da75f2406685ce377f39d76f494162)
Change-Id: I5280dedb460df9852cc39d1c17132319e202c7b2
Reviewed-on: http://git-master/r/100524
To have the proper LP0 exit power sequence, it is require to
wakeup system through tegra gpio rather than PMU-INT.
bug 957972
Reviewed-on: http://git-master/r/100107
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Cherry-picked commit ffe8e102d91c5eafc0b71b044b97fe9e8cef7463
Change-Id: I0518e46b43ec36ba6e076a946da2d395cd31777e
Reviewed-on: http://git-master/r/100521
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Add locked version of round rate API to be used by tegra arch
specific layer.
Signed-off-by: Alex Frid <afrid@nvidia.com>
(cherry picked from commit 457627966b91f2141439812869adc4acf9242471)
Change-Id: Id68d0bb952d1e7d9e650341872d1b06b0b2d3cea
Reviewed-on: http://git-master/r/100474
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Bug 947861
Change-Id: Ib4ce7bfa3624562a766678a2ef20ebdcd3055d89
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/100462
Reviewed-by: Bo Yan <byan@nvidia.com>
Bug 947861
Change-Id: I1ac97b5de5e7e79a418b3c38c70df4976616cdf3
Reviewed-on: http://git-master/r/100457
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Add config option to enable/disable nvmap page pools.
Change-Id: I873e81a675fecd768534d4ce03c2f8fdd3c6a063
Reviewed-on: http://git-master/r/100424
TEGRA_GPIO_PCC7(PEX_L2_CLKREQ) is used as the pull up source to pull up
other pins in schematic. So set it to high default.
bug 949026
Change-Id: I5a4d806ec4b54969514547472cd08018d285ced5
Signed-off-by: Hunk Lin <hulin@nvidia.com>
Reviewed-on: http://git-master/r/99778
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Enable CONFIG_PREINIT_CLOCKS.
bug 967065
Change-Id: Ib6675f9bff6729ffe7dfcd8b753c42b5d32240e4
Signed-off-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/99517
Changed the suspend resume logic as per new
UDC driver. Also, added few debug prints.
Bug 887361
Change-Id: I36ec1f160e8b4db54b5bd2153bdbf1c4fae1cc2a
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/99450
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Enable tegra udc driver.
Bug 887361
Change-Id: Iaac2486d2a05454fa351920d5c65d17b9c2a881b
Reviewed-on: http://git-master/r/99449
Update the clocks structure to use new udc driver
name. Also, update the device structure.
Bug 887361
Change-Id: I0fd846ab177e8651f285bcb9796361d30967b830
Reviewed-on: http://git-master/r/99448
Add High-speed USB device controller driver for tegra chips.
This can work in OTG device mode with tegra OTG driver.
Driver currently supports only UMTIP PHY.
Bug 887361
Change-Id: I63774a44e3bb607c93007b170ba8b811f96e43f8
Reviewed-on: http://git-master/r/97918
Export tegra_powergate_is_powered() for use by modules.
Change-Id: I8cfbb8aeb95dca00cbf6ef0c8c2bd189afeb62b6
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-on: http://git-master/r/97724
Disable internal temperature sensor and enable external temperature
sensor.
This is a modified version of change
74db6e22d316a95630d3059644fbc55e2620cb9b
Bug 954134
Change-Id: Id64bb93a09e1701165ad1f82e08bb92e61425873
Signed-off-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-on: http://git-master/r/96285
Waking up system through the tegra gpio inplace of ricoh onkey
when using the ricoh based pmu.
bug 978922
Change-Id: If9c5baffa42aca5fcc7d6238c5cf122a136e7760
Reviewed-on: http://git-master/r/100351
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
when update_cdma_locked() is invoked, CDMA is not running
implies that the queue is cleared and we can return immediately.
Bug 960487
Change-Id: I599027906dc405f4490590443d4f4d5a3202b5b0
Reviewed-on: http://git-master/r/96650
(cherry picked from commit f297b4812d15540f4b14c87178662a7ca6575ce9)
Reviewed-on: http://git-master/r/99994
Clean up #includes. Replace #includes with forward declarations where
possible, and remove extraneous #includes.
Bug 871237
Change-Id: I6942e0c632b42ad7009589ebdd78def88ae4baa4
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/99046
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Bug 935079
Signed-off-by: Ray Poudrier <rapoudrier@nvidia.com>
Reviewed-on: http://git-master/r/86009
(cherry picked from commit 83eb3734f76e598d570dd9624e7e06f8b3e05afe)
Change-Id: I5911670e7c1e8dd5fc4e89d4be21b9dcbc4c9085
Reviewed-on: http://git-master/r/98535
Reviewed-by: Raymond Poudrier <rapoudrier@nvidia.com>
Tested-by: Raymond Poudrier <rapoudrier@nvidia.com>
The sequence of read fuse id is:
1. write to OTP index register 0x3d00.
2. read out byte from ox3d04.
3. repeat step 1 to the next byte with its index respectively.
also fixed ov5650_read_reg always fail issue.
bug 957657
Change-Id: I649a7765320d0d4be8111a7f523d8487b872b620
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/98330
Reviewed-by: Wei Chen <wechen@nvidia.com>
Reviewed-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Change-Id: Id71da6f6371f337f913d981f6d121c3fb2561a41
Reviewed-on: http://git-master/r/95915
Under some rare circumstances, an uncacheable load multiple
instruction (LDRD, LDM, VLDM, VLD1, VLD2, VLD3, VLD4) can cause
a processor deadlock.
Change-Id: Ibd79aa8182dce37d0be9892f2310735e1123618a
Reviewed-on: http://git-master/r/95914
Bug 950086
Change-Id: I2eb129566bfea83b9a73d29f0c6443bdab087b65
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/95518
Reviewed-by: Andy Park <andyp@nvidia.com>
Change-Id: I0931f4ef7a5464dd32d8c703288a137fc77857ce
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/100090
Add TEGRA_PREINIT_CLOCKS option to put host1x, disp1, and video clocks
into known state, so that L4T Ventana/Harmony works on u-boot.
bug 967065
Change-Id: If7637b13e0daf1823fa0fe694a87870f4601e4df
Reviewed-on: http://git-master/r/95734
We found missed irq could be happened if clear all INT_STS_x register in one time.
Shadow register pushes the irq status after the first byte of INT_STS_x was cleared
The proposed way to clear interrupt is to write only one INT_STS_x register.
It will also clear the other two ones.
Bug 952476
Reviewed-on: http://git-master/r/93453
Signed-off-by: Steve Kuo <stevek@nvidia.com>
(cherry picked from commit 0c92f32e9e03defaeac991518b26134e59ef4db6)
Change-Id: I76179be4847f59a1687926b9b0dde6ebd3f58aa4
Reviewed-on: http://git-master/r/100306
LDO3 has the input from the VIO output and hence VIO should be
register before LDO3 for regulator registration.
bug 976254
Reviewed-on: http://git-master/r/99446
Change-Id: I6771af3e7eb93886e974695ab3550cdf8ebc52c4
Reviewed-on: http://git-master/r/100262
Setting i2c drive strenth to maximum and pulling all pins
to high.
bug 951052
bug 958415
bug 927583
Reviewed-on: http://git-master/r/91805
Change-Id: Ia2bf4ccba6d4c47411e59fb9567dc4e3c2db76ae
Reviewed-on: http://git-master/r/100261
Setting drive strength to maiximum for all i2c pins.
Reviewed-on: http://git-master/r/91952
Change-Id: I8882dd238af34e06c924f2e160d0897111e8103d
Reviewed-on: http://git-master/r/100260
Configuring all i2c controller to have slave addresss to 0xFC
(unused slave address) to avoid responding the slave with general
call address.
Reviewed-on: http://git-master/r/91951
Change-Id: Id1a45f46cfc5ffa3a48b01c0bae71c4ee9ab699b
Reviewed-on: http://git-master/r/100259
This reverts commit 9349cedf17f9b3c10760c8d48f831473f87a3a15.
It is reviewed on http://git-master/r/99635
It will cause HDMI power ON and emc clock bump up to 667Mhz
after resume from LP0.
bug 930136
Change-Id: I130494fdb381b3d322ac0e3fc8be2e44f2c2d7a7
Reviewed-on: http://git-master/r/100202
On Tegra3 make sure cpu rate is within G-mode range before LP to G
mode switch triggered by minimum CPUs notifier.
Bug 964208
Change-Id: Ic4ee6bc7eca5ad0902da4907e4702f296a155280
Reviewed-on: http://git-master/r/99834
LCD_D8 used for BAT_REMOVAL staus from PMU to be
programmed as input/tristate to in line with hardware
schematics. It is connected VIO_IN
Bug 955519
(Cherry picked from I692d8d805c54da3996c33b9837b197a6995689c8)
Change-Id: I68e6566249675cd5fce8aa954983478e4fc29a4c
Reviewed-On: http://git-master/r/#change,91589
Signed-off-by: Karthik Ramakrishnan <karthikr@nvidia.com>
Reviewed-on: http://git-master/r/99742
Recent pinctrl discussions concluded that gpiolib APIs
should in fact do whatever is required to mux a GPIO onto
pins.
This change is based on the work done by Stephen Warren in mainline
kernel.
commit 3e215d0a19c2a0c389bd9117573b6dd8e46f96a8
gpio: tegra: Hide tegra_gpio_enable/disable()
Recent pinctrl discussions concluded that gpiolib APIs should in fact do
whatever is required to mux a GPIO onto pins, by calling pinctrl APIs if
required. This change implements this for the Tegra GPIO driver, and removes
calls to the Tegra-specific APIs from drivers and board files.
Change-Id: I482ea5c177cf2ee6fa06ddac48b556f1508efacb
Reviewed-on: http://git-master/r/98466
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
Bug 933653
Change-Id: If7ce4dc5129782a7e3487028d2dba01c9380ba90
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/98256
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
Added dsi fixed clock entry derived from PLLP_OUT3. This would allow
DC driver to properly ref-count implicit dependency of DSI operations
on PLLP_OUT3 clock.
Bug 933653
Change-Id: I71e6ada13f9d231c5a4924f345cdbf7cf05cd59e
Reviewed-on: http://git-master/r/98103
Set KB_ROW11 pin to default PULL_UP to fix
the excessive interrupts from nct alert.
Bug 973536
Change-Id: Idab3769f3fe1945f5e0f487f7bd23a7c0b58d5d1
Reviewed-on: http://git-master/r/99339
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Hunk Lin <hulin@nvidia.com>
This reverts commit 5dc206986103aaa443fa6b0ef6fef20bcb35d299 because
it causes noisy audio playback on Tegra3 platforms with secure-os.
Bug 939415
Change-Id: Ib19962dd57a2560945d1c0ed49b3eade2c751446
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/98986
Change wlan interface from mlan to wlan.
Bug 954218
Change-Id: I5b2b2840a4830eda908a47cc0fc59d0479a1df34
Signed-off-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-on: http://git-master/r/98997
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
enable marvel driver as module to load at boot time
Bug 954218
Change-Id: I7dc6385dcbad7b7a7960b688c6d74bd6bc35cad9
Reviewed-on: http://git-master/r/98454
The CL disables SDIO card clock when idle for Tegra 3 only.
Bonus: conditional build for some tegra 3 functionalities.
Bug 975541
Change-Id: I097c4771f3565bf9137d7854ada10c1fe8535056
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/99707
Reviewed-by: Allen Martin <amartin@nvidia.com>
Reviewed-by: Peer Chen <pchen@nvidia.com>
Set window enabled flag in pan display. This fixes a blank
window display while switching console from dc_ext device to
framebuffer device, and allows dc_ext and fbdev to co-exist.
Removed previous work around to unblank fb from
tegra_dc_blank function.
Bug: 970263
Bug: 963480
Change-Id: I9853da211f78815246965d240d1717345c5ab391
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/99422
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Allow setting bias level to turn off clock extern1 on KAI when
codec is idle. Added a dummy widgets to make the target_bias_level
to BIAS_OFF as per required by the new ALSA kernel.
Bug 964287
Change-Id: I628744040866a9879eedc41ed4ee25af38ed86fb
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/99667
Tested-by: Hunk Lin <hulin@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Allow setting bias level to turn off clock extern1 when codec
is idle.
Bug 964287
Change-Id: I48056b86a9fdaea70202bee9326debaaddf69c0c
Reviewed-on: http://git-master/r/99665
is idle.
Bug 964287
Reviewed on: http://git-master/r/#change,93950
Change-Id: Icc11e8bfb359b432f0bfd9ba214877259188de2b
Reviewed-on: http://git-master/r/99659
