The clk_round_rate() and clk_set_rate() will return int, so not store thier
return value to unsigned long variable. This bug hides real error on these
API.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
This patch adds support for the Toshiba Equium L30 laptop and renames the mixer
controls to match Laptop usages.
Signed-off-by: Tobin Davis <tdavis@dsl-only.net>
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no
side-effects to allow a definition of BUG_ON that drops the code completely.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@ disable unlikely @ expression E,f; @@
if (<... f(...) ...>) { BUG(); }
- if (unlikely(E)) { BUG(); }
+ BUG_ON(E);
@@ expression E,f; @@
- if (E) { BUG(); }
+ BUG_ON(E);
// </smpl>
Added the internal mic as a capture source item for ALC268 acer model.
Fixed the handling of dmics on ALC268 in the auto-configuration mode.
hda_intel.c
Add the Device IDs of nvidia MCP79 HD audio controller to hda_intel.c
Signed-off-by: Peer Chen <peerchen@gmail.com>
Currently the model laptop-hpsense use the 0x12 as ExtMic,
and use 0x14 as Internal IntMic.
But the hp530 only have one ExtMic, the Pin widget is 0x14.
In this patch, I changed the mixer item for them.
I still reserved the IntMic item, it will be helpful if
other machine may use this model.
ALSA bug#3821.
Signed-off-by: Jiang zhe <zhe.jiang@intel.com>
There is no suitable model for Pi2515.
This model is to support it. ALSA bug#3800.
update ALSA-Configuration.txt
Signed-off-by: Stas Sergeev <stsp@aknet.ru>
Simplify init code.
NEC S970 has no sound in the internal speakers when autodetection is
used.
With targa-dig model, there is sound in the speakers and it gets
correctly muted when pluging headphones.
- make pcsp_start_timer_tasklet static
- remove redundant includes. <asm/i8253.h> is not available on all platforms.
There is no suitable model for M720R (ALSA bug#3781).
This patch is to support HP jack-sensing and mixer.
Removed unnecessary dependency on the little-endianess.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
sparc32:
sound/pci/hda/hda_intel.c: In function 'azx_create':
sound/pci/hda/hda_intel.c:1838: error: 'DMA_64BIT_MASK' undeclared (first use in this function)
sound/pci/hda/hda_intel.c:1838: error: (Each undeclared identifier is reported only once
sound/pci/hda/hda_intel.c:1838: error: for each function it appears in.)
GTA02 device has a speaker between LOUT2 & ROUT2 and in this mode ROUT2
needs to be inverted. This patch adds a mixer control for this.
Signed-off-by: Graeme Gregory <graeme@openmoko.org>
Added PC-speaker sound driver (snd-pcsp).
Add the check of the array range for dac_nids to prevent the over-range
access.
Added definition for byte 4 of SPDIF channel status, according to
second edition of IEC 60958-3 (consumer) spec.
Signed-off-by: Pawel MOLL <pawel.moll@st.com>
Added core_init[] for several 92hd73xxx laptops.
Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com>
Power management can't be enabled on fixed ports, since the presence
will always return false and prevent output.
Move the array declaration to hda_codec.c where it is used and add includes
where the individual presets are declared.
Fixes the following sparse warnings:
sound/pci/hda/patch_realtek.c:13744:25: warning: symbol 'snd_hda_preset_realtek' was not declared. Should it be static?
sound/pci/hda/patch_cmedia.c:729:25: warning: symbol 'snd_hda_preset_cmedia' was not declared. Should it be static?
sound/pci/hda/patch_analog.c:3656:25: warning: symbol 'snd_hda_preset_analog' was not declared. Should it be static?
sound/pci/hda/patch_sigmatel.c:3995:25: warning: symbol 'snd_hda_preset_sigmatel' was not declared. Should it be static?
sound/pci/hda/patch_si3054.c:286:25: warning: symbol 'snd_hda_preset_si3054' was not declared. Should it be static?
sound/pci/hda/patch_atihdmi.c:156:25: warning: symbol 'snd_hda_preset_atihdmi' was not declared. Should it be static?
sound/pci/hda/patch_conexant.c:1721:25: warning: symbol 'snd_hda_preset_conexant' was not declared. Should it be static?
sound/pci/hda/patch_via.c:1962:25: warning: symbol 'snd_hda_preset_via' was not declared. Should it be static?
The HD-audio parameters are at most 32bit int.
Temp variable in the loop shadows the second argument (which is otherwise
unused in this function). Change this to defcfg as it is used to hold
the default config.
sound/pci/hda/patch_sigmatel.c:2759:18: warning: symbol 'cfg' shadows an earlier one
sound/pci/hda/patch_sigmatel.c:2734:26: originally declared here
Just drop the returns.
sound/pci/rme9652/hdspm.c:1031:3: warning: returning void-valued expression
sound/pci/rme9652/hdspm.c:1033:3: warning: returning void-valued expression
In both cases we are passing around the substream number, use
sub_num for this.
sound/pci/riptide/riptide.c:1633:6: warning: symbol 'index' shadows an earlier one
sound/pci/riptide/riptide.c:121:12: originally declared here
sound/pci/riptide/riptide.c:1673:6: warning: symbol 'index' shadows an earlier one
Inner loop redeclares err with u32 rather than int, stupid fix here
is to change the inner err to err2.
sound/pci/pcxhr/pcxhr_core.c:1008:8: warning: symbol 'err' shadows an earlier one
sound/pci/pcxhr/pcxhr_core.c:983:6: originally declared here
Use priv_idx as an identifier.
sound/pci/oxygen/virtuoso.c:277:15: warning: symbol 'index' shadows an earlier one
sound/pci/oxygen/virtuoso.c:56:12: originally declared here
In all four case, adding a private value to the iooff index,
call it priv_idx.
sound/pci/ice1712/ice1712.c:1300:6: warning: symbol 'index' shadows an earlier one
sound/pci/ice1712/ice1712.c:85:12: originally declared here
sound/pci/ice1712/ice1712.c:1312:6: warning: symbol 'index' shadows an earlier one
sound/pci/ice1712/ice1712.c:1338:6: warning: symbol 'index' shadows an earlier one
sound/pci/ice1712/ice1712.c:1350:6: warning: symbol 'index' shadows an earlier one
[tiwai - fixed coding issues as well]
enable in these contexts refers specifically to intr enable, as
per the two functions it is found in. Use intr_enable instead.
sound/pci/emu10k1/emu10k1x.c:330:15: warning: symbol 'enable' shadows an earlier one
sound/pci/emu10k1/emu10k1x.c:53:12: originally declared here
sound/pci/emu10k1/emu10k1x.c:341:15: warning: symbol 'enable' shadows an earlier one
instead of shadowing, use cap_voice as we test for the capture
voice in this statement.
sound/pci/emu10k1/emu10k1x.c:798:25: warning: symbol 'pvoice' shadows an earlier one
sound/pci/emu10k1/emu10k1x.c:787:24: originally declared here
Reading regs from the fpga into an int instead of a u32, trivial
fix.
sound/pci/emu10k1/emuproc.c:422:34: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emuproc.c:422:34: expected unsigned int [usertype] *value
sound/pci/emu10k1/emuproc.c:422:34: got int *<noident>
sound/pci/au88x0/au88x0_pcm.c:508:15: warning: Using plain integer as NULL pointer
Also some small codingstyle fixes.
when the time interval for a period is smaller than kernel HZ, then
snd-aloop and snd-dummy cannot call snd_pcm_period_elapsed as fast enough
annymore. this happens for example with games. but the app still needs to
see, that the buffer actually did go further, which is provided by these
patches.
Signed-off-by: Ahmet İnan <ainan <at> mathematik.uni-freiburg.de>
Change the variable err to _err within the ADD_CTLS macro to avoid
shadowing the local variable.
sound/pci/ca0106/ca0106_mixer.c:710:2: warning: symbol 'err' shadows an earlier one
sound/pci/ca0106/ca0106_mixer.c:663:6: originally declared here
sound/pci/ca0106/ca0106_mixer.c:712:3: warning: symbol 'err' shadows an earlier one
sound/pci/ca0106/ca0106_mixer.c:721:3: warning: symbol 'err' shadows an earlier one
change to intr_enable as per the two functions it is defined in.
sound/pci/ca0106/ca0106_main.c:438:15: warning: symbol 'enable' shadows an earlier one
sound/pci/ca0106/ca0106_main.c:159:12: originally declared here
sound/pci/ca0106/ca0106_main.c:449:15: warning: symbol 'enable' shadows an earlier one
enable is used to test for whether or not spdif should be enabled,
change to spdif_enable.
sound/pci/ali5451/ali5451.c:1812:15: warning: symbol 'enable' shadows an earlier one
sound/pci/ali5451/ali5451.c:63:12: originally declared here
sound/pci/ali5451/ali5451.c:1840:27: warning: symbol 'enable' shadows an earlier one
err is always assigned before it is used, no need to declare another
inside the if statement.
sound/pci/ac97/ac97_pcm.c:577:7: warning: symbol 'err' shadows an earlier one
sound/pci/ac97/ac97_pcm.c:572:6: originally declared here
kernel style does assignment outside of if() block
sound/pci/rme96.c:1562:71: warning: Using plain integer as NULL pointer
kernel style does assignment outside of if() statements.
sound/pci/rme32.c:1353:71: warning: Using plain integer as NULL pointer
change id to elem_id as it is used to initialize each mixer element
sound/pci/maestro3.c:2071:25: warning: symbol 'id' shadows an earlier one
sound/pci/maestro3.c:67:13: originally declared here
index is used in each of these places to count over the dsp's memory,
change to the name dsp_index
sound/pci/maestro3.c:2572:9: warning: symbol 'index' shadows an earlier one
sound/pci/maestro3.c:66:12: originally declared here
sound/pci/maestro3.c:2604:9: warning: symbol 'index' shadows an earlier one
[tiwai - fixed coding style issues as well]
id was only used as a counter in a for loop, move the declaration
to where it is used and change it to i.
sound/pci/fm801.c:1288:6: warning: symbol 'id' shadows an earlier one
sound/pci/fm801.c:51:13: originally declared here
[tiwai - fixed a coding style issue as well]
id is used when initializing the mixer elements, use elem_id here
instead.
sound/pci/es1968.c:1963:25: warning: symbol 'id' shadows an earlier one
sound/pci/es1968.c:129:13: originally declared here
index is incremented only when AC97_EI_SPDIF and then assigned to
the index field. Change the temporary name to is_spdif.
sound/pci/ens1370.c:1638:10: warning: symbol 'index' shadows an earlier one
sound/pci/ens1370.c:84:12: originally declared here
A temporary variable for each mixer element is used in an initialization
loop, use the name elem_id.
sound/pci/cmipci.c:2747:26: warning: symbol 'id' shadows an earlier one
sound/pci/cmipci.c:56:13: originally declared here
Added the docking-stationc mic input to the capture source list
for Thinkpad X61.
Fix the initial num_dacs of 92HD71bxx codecs.
Move some entries to their proper position so that the list is again
sorted by vendor/product ID.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Reduce the number of times to check for a non-empty Tx FIFO from 100 to
2 because there is no MPU-401 implementation that needs more than one or
two reads to determine the actual FIFO status.
