2010-04-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: ohci: wait for local CSR lock access to finish firewire: ohci: prevent aliasing of locally handled register addresses firewire: core: fw_iso_resource_manage: return -EBUSY when out of resources firewire: core: fix retries calculation in iso manage_channel() firewire: cdev: fix cut+paste mistake in disclaimer
2010-04-22dri-devel mailing list moved - update MAINTAINERSValdis.Kletnieks@vt.edu
I posted to dri-devel@lists.sourceforge.net, and got a bounce back: The dri-devel list has moved to freedesktop.org (see http://lists.freedesktop.org/mailman/listinfo/dri-devel). If you were subscribed to the list here, the subscription should have been transferred to the new location. Please only post to the new list. Fix MAINTAINERS to correspond. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-22Merge branch 'slabh' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/miscLinus Torvalds
* 'slabh' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc: uml: Fix build breakage after slab.h changes
2010-04-22scsi: fix operator precedence warningRandy Dunlap
Fix operator precedence warning (from sparse), which results in the data value always being 0: drivers/scsi/qla4xxx/ql4_mbx.c:470:66: warning: right shift by bigger than source value Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Ravi Anand <ravi.anand@qlogic.com> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Cc: Karen Higgins <karen.higgins@qlogic.com> Cc: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-22Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] zcore: Fix reipl device detection [S390] vdso: use ntp adjusted clock multiplier [S390] cio: use exception-save stsch [S390] add hook to reenable mss after hibernation [S390] cio: allow enable_facility from outside init functions [S390] dasd: fix endless loop in erp
2010-04-22[S390] zcore: Fix reipl device detectionMichael Holzheu
The reipl device information is passed from the kernel to zfcpdump using a pointer in the lowcore (0xe00) that points to the reipl information Currently if that pointer is not zero, we copy the reipl information. If the pointer is not initialized and points outside the accessible memory, it can happen that the memory copy fails. In that case we currently stop the initialization of zcore which leads to a failing kernel dump. The correct behavior is to disable the reipl after dump and continue with zcore intialization. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-04-22[S390] vdso: use ntp adjusted clock multiplierHendrik Brueckner
Commit "timekeeping: Fix clock_gettime vsyscall time warp" (0696b711e) introduced the new parameter "mult" to update_vsyscall(). This parameter contains the internal NTP adjusted clock multiplier. The s390x vdso did not use this adjusted multiplier. Instead, it used the constant clock multiplier for gettimeofday() and clock_gettime() variants. This may result in observable time warps as explained in commit 0696b711e. Make the NTP adjusted clock multiplier available to the s390x vdso implementation and use it for time calculations. Cc: <stable@kernel.org> Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-04-22[S390] cio: use exception-save stschSebastian Ott
Using stsch on schids with ssid != 0 can lead to an operand exception. Use stsch_err to handle potential exceptions if we fail to reenable mss after hibernation. Cc: <stable@kernel.org> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-04-22[S390] add hook to reenable mss after hibernationSebastian Ott
Reenable multiple subchannel sets after hibernation, prior to the device callbacks. Cc: <stable@kernel.org> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-04-22[S390] cio: allow enable_facility from outside init functionsSebastian Ott
Prepare chsc_enable_facility to be used from outside init functions. Use static memory for the chsc call and protect its access by a spinlock (although there is no concurrent usage). Cc: <stable@kernel.org> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-04-22[S390] dasd: fix endless loop in erpStefan Haberland
If not enough memory is available to build a new erp request it ended up in an endless loop trying to build erp requests. Fixed the loop to proceed the next request instead. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] bnx2i: Bug fixes related to MTU change issue when there are active iscsi sessions [SCSI] ibmvscsi: fix DMA API misuse [SCSI] wd7000: fix reset handler typo spin_unlock_irq() => spin_lock_irq() [SCSI] zfcp: Fix tracing of requests with error status [SCSI] zfcp: Update MAINTAINERS entry [SCSI] iscsi_tcp: fix relogin/shutdown hang [SCSI] qla2xxx: fix lock imbalance [SCSI] lpfc: fix lock imbalances [SCSI] be2iscsi: fix lock imbalance [SCSI] dpt_i2o: several use after free issues
2010-04-22virtio: Fix GFP flags passed from the virtio balloon driverBalbir Singh
The virtio balloon driver can dig into the reservation pools of the OS to satisfy a balloon request. This is not advisable and other balloon drivers (drivers/xen/balloon.c) avoid this as well. The patch also adds changes to avoid printing a warning if allocation fails, since we retry after sometime anyway. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: kvm <kvm@vger.kernel.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-22Merge branch 'for-linus/i2c' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/i2c' of git://git.fluff.org/bjdooks/linux: i2c-stu300: off by one issue i2c-pnx: Add stop conditions for end of transfer i2c-pnx: Limit maximum divider to 1023 i2c-omap: fix OOPS in omap_i2c_unidle() during probe i2c-imx: fix error handling
2010-04-22staging: fix dt3155 buildRandy Dunlap
When the dt3155 driver is built-in (not as a loadable module), these build errors happen: drivers/staging/dt3155/dt3155_drv.c:1047: error: implicit declaration of function 'request_irq' drivers/staging/dt3155/dt3155_drv.c:1048: error: 'IRQF_SHARED' undeclared (first use in this function) drivers/staging/dt3155/dt3155_drv.c:1048: error: 'IRQF_DISABLED' undeclared (first use in this function) drivers/staging/dt3155/dt3155_drv.c:1091: error: implicit declaration of function 'free_irq' so remove the #ifdef MODULE check since it's not needed. Also remove the CONFIG_PCI check since the Kconfig file already requires that. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Scott Smedley <ss@aao.gov.au> Tested-by: Jan III Sobieski <jan3sobi3ski@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: security: testing the wrong variable in create_by_name() CRED: Fix a race in creds_are_invalid() in credentials debugging CRED: Fix double free in prepare_usermodehelper_creds() error handling
2010-04-22security: testing the wrong variable in create_by_name()Dan Carpenter
There is a typo here. We should be testing "*dentry" instead of "dentry". If "*dentry" is an ERR_PTR, it gets dereferenced in either mkdir() or create() which would cause an OOPs. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-22CRED: Fix a race in creds_are_invalid() in credentials debuggingDavid Howells
creds_are_invalid() reads both cred->usage and cred->subscribers and then compares them to make sure the number of processes subscribed to a cred struct never exceeds the refcount of that cred struct. The problem is that this can cause a race with both copy_creds() and exit_creds() as the two counters, whilst they are of atomic_t type, are only atomic with respect to themselves, and not atomic with respect to each other. This means that if creds_are_invalid() can read the values on one CPU whilst they're being modified on another CPU, and so can observe an evolving state in which the subscribers count now is greater than the usage count a moment before. Switching the order in which the counts are read cannot help, so the thing to do is to remove that particular check. I had considered rechecking the values to see if they're in flux if the test fails, but I can't guarantee they won't appear the same, even if they've changed several times in the meantime. Note that this can only happen if CONFIG_DEBUG_CREDENTIALS is enabled. The problem is only likely to occur with multithreaded programs, and can be tested by the tst-eintr1 program from glibc's "make check". The symptoms look like: CRED: Invalid credentials CRED: At include/linux/cred.h:240 CRED: Specified credentials: ffff88003dda5878 [real][eff] CRED: ->magic=43736564, put_addr=(null) CRED: ->usage=766, subscr=766 CRED: ->*uid = { 0,0,0,0 } CRED: ->*gid = { 0,0,0,0 } CRED: ->security is ffff88003d72f538 CRED: ->security {359, 359} ------------[ cut here ]------------ kernel BUG at kernel/cred.c:850! ... RIP: 0010:[<ffffffff81049889>] [<ffffffff81049889>] __invalid_creds+0x4e/0x52 ... Call Trace: [<ffffffff8104a37b>] copy_creds+0x6b/0x23f Note the ->usage=766 and subscr=766. The values appear the same because they've been re-read since the check was made. Reported-by: Roland McGrath <roland@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68knommu: allow 4 coldfire serial ports m68knommu: fix coldfire tcdrain m68knommu: remove a duplicate vector setting line for 68360 Fix m68k-uclinux's rt_sigreturn trampoline m68knommu: correct the CC flags for Coldfire M5272 targets uclinux: error message when FLAT reloc symbol is invalid, v2
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: mc13783-regulator: fix a memory leak in mc13783_regulator_remove regulator: Let drivers know when they use the stub API
2010-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Split large truncated into smaller chunks [LogFS] Set s_bdi [LogFS] Prevent mempool_destroy NULL pointer dereference [LogFS] Move assertion [LogFS] Plug 8 byte information leak [LogFS] Prevent memory corruption on large deletes [LogFS] Remove unused method Fix trivial conflict with added header includes in fs/logfs/super.c
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: jfs: add jfs specific ->setattr call jfs: fix diAllocExt error in resizing filesystem jfs_dmap.[ch]: trivial typo fix: s/heigth/height/g
2010-04-21Merge branch 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: Fix TSS size check for 16-bit tasks KVM: Add missing srcu_read_lock() for kvm_mmu_notifier_release() KVM: Increase NR_IOBUS_DEVS limit to 200 KVM: fix the handling of dirty bitmaps to avoid overflows KVM: MMU: fix kvm_mmu_zap_page() and its calling path KVM: VMX: Save/restore rflags.vm correctly in real mode KVM: allow bit 10 to be cleared in MSR_IA32_MC4_CTL KVM: Don't spam kernel log when injecting exceptions due to bad cr writes KVM: SVM: Fix memory leaks that happen when svm_create_vcpu() fails KVM: take srcu lock before call to complete_pio()
2010-04-21Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md/raid5: allow for more than 2^31 chunks.
2010-04-21AFS: Don't pass error value to page_cache_release() in error handlingDavid Howells
In the error handling in afs_mntpt_do_automount(), we pass an error pointer to page_cache_release() if read_mapping_page() failed. Instead, we should extend the gotos around the error handling we don't need. Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-21KVM: x86: Fix TSS size check for 16-bit tasksJan Kiszka
A 16-bit TSS is only 44 bytes long. So make sure to test for the correct size on task switch. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-21KVM: Add missing srcu_read_lock() for kvm_mmu_notifier_release()Lai Jiangshan
I got this dmesg due to srcu_read_lock() is missing in kvm_mmu_notifier_release(). =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- arch/x86/kvm/x86.h:72 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by qemu-system-x86/3100: #0: (rcu_read_lock){.+.+..}, at: [<ffffffff810d73dc>] __mmu_notifier_release+0x38/0xdf #1: (&(&kvm->mmu_lock)->rlock){+.+...}, at: [<ffffffffa0130a6a>] kvm_mmu_zap_all+0x21/0x5e [kvm] stack backtrace: Pid: 3100, comm: qemu-system-x86 Not tainted 2.6.34-rc3-22949-gbc8a97a-dirty #2 Call Trace: [<ffffffff8106afd9>] lockdep_rcu_dereference+0xaa/0xb3 [<ffffffffa0123a89>] unalias_gfn+0x56/0xab [kvm] [<ffffffffa0119600>] gfn_to_memslot+0x16/0x25 [kvm] [<ffffffffa012ffca>] gfn_to_rmap+0x17/0x6e [kvm] [<ffffffffa01300c1>] rmap_remove+0xa0/0x19d [kvm] [<ffffffffa0130649>] kvm_mmu_zap_page+0x109/0x34d [kvm] [<ffffffffa0130a7e>] kvm_mmu_zap_all+0x35/0x5e [kvm] [<ffffffffa0122870>] kvm_arch_flush_shadow+0x16/0x22 [kvm] [<ffffffffa01189e0>] kvm_mmu_notifier_release+0x15/0x17 [kvm] [<ffffffff810d742c>] __mmu_notifier_release+0x88/0xdf [<ffffffff810d73dc>] ? __mmu_notifier_release+0x38/0xdf [<ffffffff81040848>] ? exit_mm+0xe0/0x115 [<ffffffff810c2cb0>] exit_mmap+0x2c/0x17e [<ffffffff8103c472>] mmput+0x2d/0xd4 [<ffffffff81040870>] exit_mm+0x108/0x115 [...] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-21m68knommu: allow 4 coldfire serial portsPhilippe De Muyter
Fix driver/serial/mcf.c for 4-ports coldfire's (e.g. MCF5484). Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2010-04-21m68knommu: fix coldfire tcdrainPhilippe De Muyter
Fix tcdrain on coldfire uarts. Currently with coldfire uarts tcdrain returns without waiting for txempty, because (tx)fifosize is 0. Fix that and call uart_update_timeout when setting the baud rate, otherwise tcdrain will wait for an half our :) Also constify mcf_uart_ops. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2010-04-21m68knommu: remove a duplicate vector setting line for 68360Greg Ungerer
Remove a duplicate vector setting line for the 68360 interrupt setup. Pointed out by Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2010-04-21Fix m68k-uclinux's rt_sigreturn trampolineMaxim Kuvyrkov
Signed-off-by: Maxim Kuvyrkov <maxim@codesourcery.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2010-04-21m68knommu: correct the CC flags for Coldfire M5272 targetsPhilip Nye
Signed-off-by: Philip Nye <philipn@engarts.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2010-04-21uclinux: error message when FLAT reloc symbol is invalid, v2Jun Sun
This patch fixes a cosmetic error in printk. Text segment and data/bss segment are allocated from two different areas. It is not meaningful to give the diff between them in the error reporting messages. Signed-off-by: Jun Sun <jsun@junsun.net> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2010-04-21CRED: Fix double free in prepare_usermodehelper_creds() error handlingDavid Howells
Patch 570b8fb505896e007fd3bb07573ba6640e51851d: Author: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Date: Tue Mar 30 00:04:00 2010 +0100 Subject: CRED: Fix memory leak in error handling attempts to fix a memory leak in the error handling by making the offending return statement into a jump down to the bottom of the function where a kfree(tgcred) is inserted. This is, however, incorrect, as it does a kfree() after doing put_cred() if security_prepare_creds() fails. That will result in a double free if 'error' is jumped to as put_cred() will also attempt to free the new tgcred record by virtue of it being pointed to by the new cred record. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-20[LogFS] Split large truncated into smaller chunksJoern Engel
Truncate would do an almost limitless amount of work without invoking the garbage collector in between. Split it up into more manageable, though still large, chunks. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-20Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Convert __DQUOT_PARANOIA symbol to standard config option
2010-04-20quota: Convert __DQUOT_PARANOIA symbol to standard config optionJan Kara
Make __DQUOT_PARANOIA define from the old days a standard config option and turn it off by default. This gets rid of a quota warning about writes before quota is turned on for systems with ext4 root filesystem. Currently there's no way to legally solve this because /etc/mtab has to be written before quota is turned on on most systems. Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-20Merge branch 'urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6 * 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: fix error handling in cm4000_cs.c drivers/pcmcia: Add missing local_irq_restore serial_cs: MD55x support (PCMCIA GPRS/EDGE modem) (kernel 2.6.33) pcmcia: avoid late calls to pccard_validate_cis pcmcia: fix ioport size calculation in rsrc_nonstatic pcmcia: re-start on MFC override pcmcia: fix io_probe due to parent (PCI) resources pcmcia: use previously assigned IRQ for all card functions
2010-04-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Fix hardirq tracing in trap return path. sparc64: Use correct pt_regs in decode_access_size() error paths. sparc64: Fix PREEMPT_ACTIVE value. sparc64: Run NMIs on the hardirq stack. sparc64: Allocate sufficient stack space in ftrace stubs. sparc: Fix forgotten kmemleak headers inclusion
2010-04-20Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Fix unsafe frame rewinding with hot regs fetching
2010-04-20Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: delay vblank cleanup until after driver unload
2010-04-20x86: correctly wire up the newuname system callChristoph Hellwig
Before commit e28cbf22933d0c0ccaf3c4c27a1a263b41f73859 ("improve sys_newuname() for compat architectures") 64-bit x86 had a private implementation of sys_uname which was just called sys_uname, which other architectures used for the old uname. Due to some merge issues with the uname refactoring patches we ended up calling the old uname version for both the old and new system call slots, which lead to the domainname filed never be set which caused failures with libnss_nis. Reported-and-tested-by: Andy Isaacson <adi@hexapodia.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-20KVM: Increase NR_IOBUS_DEVS limit to 200Sridhar Samudrala
This patch increases the current hardcoded limit of NR_IOBUS_DEVS from 6 to 200. We are hitting this limit when creating a guest with more than 1 virtio-net device using vhost-net backend. Each virtio-net device requires 2 such devices to service notifications from rx/tx queues. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-20KVM: fix the handling of dirty bitmaps to avoid overflowsTakuya Yoshikawa
Int is not long enough to store the size of a dirty bitmap. This patch fixes this problem with the introduction of a wrapper function to calculate the sizes of dirty bitmaps. Note: in mark_page_dirty(), we have to consider the fact that __set_bit() takes the offset as int, not long. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-04-20KVM: MMU: fix kvm_mmu_zap_page() and its calling pathXiao Guangrong
This patch fix: - calculate zapped page number properly in mmu_zap_unsync_children() - calculate freeed page number properly kvm_mmu_change_mmu_pages() - if zapped children page it shoud restart hlist walking KVM-Stable-Tag. Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-04-20KVM: VMX: Save/restore rflags.vm correctly in real modeAvi Kivity
Currently we set eflags.vm unconditionally when entering real mode emulation through virtual-8086 mode, and clear it unconditionally when we enter protected mode. The means that the following sequence KVM_SET_REGS (rflags.vm=1) KVM_SET_SREGS (cr0.pe=1) Ends up with rflags.vm clear due to KVM_SET_SREGS triggering enter_pmode(). Fix by shadowing rflags.vm (and rflags.iopl) correctly while in real mode: reads and writes to those bits access a shadow register instead of the actual register. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-04-20KVM: allow bit 10 to be cleared in MSR_IA32_MC4_CTLAndre Przywara
There is a quirk for AMD K8 CPUs in many Linux kernels (see arch/x86/kernel/cpu/mcheck/mce.c:__mcheck_cpu_apply_quirks()) that clears bit 10 in that MCE related MSR. KVM can only cope with all zeros or all ones, so it will inject a #GP into the guest, which will let it panic. So lets add a quirk to the quirk and ignore this single cleared bit. This fixes -cpu kvm64 on all machines and -cpu host on K8 machines with some guest Linux kernels. Signed-off-by: Andre Przywara <andre.przywara@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-20KVM: Don't spam kernel log when injecting exceptions due to bad cr writesAvi Kivity
These are guest-triggerable. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-20KVM: SVM: Fix memory leaks that happen when svm_create_vcpu() failsTakuya Yoshikawa
svm_create_vcpu() does not free the pages allocated during the creation when it fails to complete the allocations. This patch fixes it. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-20KVM: take srcu lock before call to complete_pio()Gleb Natapov
complete_pio() may use slot table which is protected by srcu. Signed-off-by: Gleb Natapov <gleb@redhat.com> Cc: stable@kernel.org Signed-off-by: Avi Kivity <avi@redhat.com>
