Provide a fixed mapping for the PCIe host registers. This reduces the pressure
on the VMALLOC area significantly.
bug 969392
Change-Id: I80ea0dd5e81a005f86a26eb47aea00d78e9e0ad2
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Signed-off-by: Manoj Chourasia <mchourasia@nvidia.com>
Reviewed-on: http://git-master/r/96748
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Its observed that PCIE all clocks enabled on resume.
Follow up resume and suspend only if any port added
bug 943712
Change-Id: I0644aad8a4994726451cda094f2607eb8398aadf
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/95836
LP2 state of Tegra2 is considered into rail statistic.
Change-Id: Iab2e0fe25ecb8feca1f4aa1040ce5020e6dcf584
Signed-off-by: Joshua Cha <joshuac@nvidia.com>
Reviewed-on: http://git-master/r/98118
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
add trace_printk to log useful debug information.
Bug 870685
Change-Id: I29c0b1600f234ebb06d19c8b6c713b16f6e7643c
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/89204
Reviewed-by: Prashant Malani <pmalani@nvidia.com>
There are a couple of issues found in tegra_camera.
1. clock enable/disable is controlled by user space.
-> If client process crashes, there is no way to disable clock.
2. power enable/disable is associated with clock enable.
-> There is no reason to relate power with clock.
-> There is only one regulator for this driver.
-> As same as #1, it may leave power up when client process crashes.
3. driver allows multiple clients to access.
-> This is not the case for this driver.
This changes addresses the problems described above.
Bug 948780
Change-Id: Ie534771327175f56cf0e138f1c07096ddba470a8
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/92386
Reviewed-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
update DVFS table for kai.
bug 945613
Signed-off-by: Ankit Pashiney <apashiney@nvidia.com>
Change-Id: If4d2e814bc01df1d14ae05b8f5c557d387ae19e4
Reviewed-on: http://git-master/r/95463
Reviewed-by: Ankit Pashiney <apashiney@nvidia.com>
Tested-by: Ankit Pashiney <apashiney@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
- Add valid flag to GPIO runtime structure so that scratch
flag can be used for other purposes.
Bug 852480
Change-Id: Ie5e36b733fe67b504e83efcf606be264725c987c
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/94156
check return value of usb_autopm_get_interface().
if return value is not success, usb_autopm_put_interface() should
not be called to make up the reference count.
Bug 936094
Signed-off-by: Shawn Joo <sjoo@nvidia.com>
Reviewed-on: http://git-master/r/85974
(cherry picked from commit aad2bf5c8fef639465c4bb895b73a23c3f0c0403)
Change-Id: Ifd1deb1e0953eae1fd8d41f48989b650d6951fed
Reviewed-on: http://git-master/r/97647
Reviewed-by: Shawn Joo <sjoo@nvidia.com>
Tested-by: Shawn Joo <sjoo@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Add nvavp_force_clock_stay_on ioctl which provides way for user-mode driver
to stay on AVP clock state. This change is to fix LP0 resume fail during
Widevine playback. Since VDE/BSEV clocks are used by OTF driver in secure
world during closing sesssion, the change makes VDE/BSEV clocks running
while entering LP0.
Bug 960130
Bug 961015
Change-Id: I7eaaa9a33537a72b6ae0a016372bc513fef532e2
Reviewed-on: http://git-master/r/96302
Reviewed-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Tested-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Reviewed-by: Karan Jhavar <kjhavar@nvidia.com>
When registering fixed regulator for gpio, setting the open drain
state to false for normal pin i.e. non-open drain pin.
This was side effect of the changes done for porting gpio
regulator to fixed regulator.
bug 970262
Change-Id: I1977e48b3461f8eb2aacadc28e4b53165ac4e1ec
Reviewed-on: http://git-master/r/97946
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
In resuming from LP1, USB HOST is wrongly detected in Tegra2.
In that time, adb connection doesn't work also.
So clear only interrupt enabling bits to fix this problem.
Bug 960254
Bug 970012
Change-Id: I2f8e891ab2abcf8552526ff305d6f3a148076edd
Reviewed-on: http://git-master/r/96769
Reviewed-by: Simone Willett <swillett@nvidia.com>
If there are no callbacks associated with the request,
dma interrupt is not enabled.
Bug 969125
Change-Id: Ifbf2a8d6c474187927ee38af03cb96e53e199b83
Signed-off-by: Chaitanya Bandi <bandik@nvidia.com>
Reviewed-on: http://git-master/r/96724
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
TEGRA_DC_EXT_SET_LUT programmed the proper shadow registers
but did not copy the shadow registers to the active set.
Signed-off-by: Adam Cheney <acheney@nvidia.com>
bug 947281
Change-Id: Id734e128bb708f1a75c0cad22b0c51b083d8df3b
Reviewed-on: http://git-master/r/91368
For SDMMC4 GMI interface, tap delay value of 0xF
is recommended by HW team.
Bug 911075
Change-Id: I2cdf90f34341cb8062dbded52ff1739c0c84cb0d
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-on: http://git-master/r/97668
Addition of callback function to nofity the plug and
un-plug of OTG cable to charger driver.
Change-Id: I6b16d051cafe0799cffe8a05d1510da27e841f8b
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/97514
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
Tested-by: Chandler Zhang <chazhang@nvidia.com>
Disable card clock before disabling internal clock to
ensure that there are no abnormal clock waveforms.
Bug 947058
Change-Id: I98a3f7f63b4380b62bead05f1018d3cddc0ac217
Reviewed-on: http://git-master/r/95396
Disable SDIO card clock when there are no commands/
data transfers on the SD bus.
Bug 958954
Bug 955742
Bug 952344
Change-Id: I7390be0406f7e46c0eb88ede2ae6f904b2181306
Reviewed-on: http://git-master/r/95390
There is a chance that we might read an TD request which
has just arrived after fence read in a interrupt handler.
Added fence read in unmap urb to avoid this issue.
Bug 964879
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/95916
(cherry picked from commit 8d8415820014710052eef088ed2d579d0531cd52)
Change-Id: Ia682654a25c685cf3dd2e76c8b9ea30427a06d89
Reviewed-on: http://git-master/r/97507
Set minimum sclk,pclk and hclk rate same at 12Mhz for power optimization
bug 939415
Change-Id: I579eeca780357b02f65333ffea58301040943506
Signed-off-by: Amit Kamath <akamath@nvidia.com>
Reviewed-on: http://git-master/r/96922
This reverts commit 037bc840859c0d52abedeb576888714698f04bcf.
Bug 967887
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Change-Id: I89fa9aad8e56628ebb8932c694d37ab92daaab22
Reviewed-on: http://git-master/r/96796
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
This reverts commit 55f0f45a45263ba26bd473f50f867d29dd836e46.
Bug 967887
Change-Id: I036e0bd4e391a17dec8fa0fe86da7eb6b98d503a
Reviewed-on: http://git-master/r/96795
This reverts commit 46d9f14943770c24603ef7cdfd8eb2dbcd3c1248.
Bug 967887
Change-Id: Iee732d8137043240902201d7783d2c3fede98fbe
Reviewed-on: http://git-master/r/96794
This reverts commit 5682179d980e1a70bcf37fd97a14e27a2ddde822.
Bug 967887
Change-Id: Ieb44d89a8361d1fa59b3d6375234f06f57c1c717
Reviewed-on: http://git-master/r/96793
This reverts commit 16e0bb8c46656b1d902d422e0065c746af161a1c.
Bug 967887
Change-Id: Ifa115c4030c48cbd0b629cf02899ca8c6f25d314
Reviewed-on: http://git-master/r/96792
This reverts commit 11a2e1bb69affe9e8273bc6d1452cd9282ddd27a.
Bug 967887
Change-Id: Ibace368a190a14d24e1cc963e8e2a7ed6fdbba6a
Reviewed-on: http://git-master/r/96791
This reverts commit a27cd62bb4934abe2af420ba7ca5115fbfb653be.
Bug 967887
Change-Id: I826224a4aea4bac78f9d2d1ce6797e8585fc148b
Reviewed-on: http://git-master/r/96790
This restores commit 607d5ec8bb46f95473533f611da1ffc97907d16e.
The common ARM CPU state suspend/resume code does not work with
and external L2 cache controller (like a PL310) enabled. This
change fixes corruption of the current PMD by the MMU resume code.
cpu_resume_mmu modifies the currently active page tables to add
a flat (VA==PA) section mapping of cpu_resume_turn_mmu_on to
handle MMU off-to-on transition. It turns off the L1 data cache
but it knows nothing of the L2 cache. Since page table walks are
L2 cacheable, other CPUs in the system can pick up the corrupted
PMD which will eventually result in a kernel panic.
The workaround for this is to modify push_ctx_regs to save the
current TTB0 and CONTEXID registers in the CPU register context
and switch to the private tegra_pgd before saving the rest of the
CPU context. The tegra_pgd already has a flat mapping for the
code in question, so it can't be damaged by the actions of
cpu_resume_mmu. Likewise, pop_ctx_regs is modified to restore
the actual TTB0 and CONTEXTID registers when restoring the CPU
registers.
Bug 967887
Change-Id: Iaf98c46359860531874354e8cddabe299ea90d57
Reviewed-on: http://git-master/r/96789
This reverts commit e6d0e0ceec7cd1a7b8085eb31d2e70bc4d15684f.
Bug 967887
Change-Id: I60927a93ebdf6ba4da14311f8ffcc1edf4f56391
Reviewed-on: http://git-master/r/96788
This reverts commit f31ca2d9e0580b58dc51fde31fc8ace190dd253b.
Bug 967887
Change-Id: I3fe975f7a6939cace5e208947bcb82e09008c0ac
Reviewed-on: http://git-master/r/96787
This reverts commit 209209a303742d6312f66896b4351dd97e48e24c.
Bug 967887
Change-Id: I2464db28b5a4970d6e60ef79c89c2107c64cb6d3
Reviewed-on: http://git-master/r/96786
This reverts commit 743c03fbeb5908faf4aef6bee7702a2ad4caac22.
Bug 967887
Change-Id: Ie4477e3b5fa9773c9e60b5cace47b3ff240a4bf1
Reviewed-on: http://git-master/r/96785
bug 949219
Change-Id: I5942ba86bd1cbe1f1bd06a7c9f51a10d83e6cabb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92819
Remove T30 FPGA support as it will conflict with downstreaming mainline
way of using chipid and revision.
Change-Id: Ic1fd1107801de13c265c7dde8571e0537c43f4fd
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/95872
bug 949219
Change-Id: I52969e8dd1a5ed4dc76ac360ec08b0afb18cd4a5
Reviewed-on: http://git-master/r/92833
Bug 949219
Change-Id: I875f8688a272c415ebf345b8f30e4afdf7551b29
Reviewed-on: http://git-master/r/91523
Enabling the 3v3 voltage rail during boot.
bug 822562
Change-Id: I15318b0c30bae716f40985cbee06cd9eaff54ee3
Reviewed-on: http://git-master/r/96685
Adding support for protocol mangling I2C_M_NOSTART.
Change-Id: I6cc0c96b3c374d452ea886a0f983dc5d31c4575c
Reviewed-on: http://git-master/r/92573
vbus int can be generated from pmu and directly from port
when host mode is reqruied, we use vbus int and pmu int
is not required as usb clock is not disabled.
Bug 961166
Change-Id: I96fde7daf052a7c5b8e94414e309b0be6354ec80
Reviewed-on: http://git-master/r/96338
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Use SMB349 regulator instead of irq to controll USB1 VBUS
Bug 961166
Bug 966874
Change-Id: I68884444883277ef169f3eb066ea50d6d49b708d
Signed-off-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-on: http://git-master/r/96441
Addition of reglator interface to detect the usb cable
plug/unplug detection.
Bug 961166
Bug 966874
Change-Id: Ida297bc39df9aca8cffe60c29bc24f2d32819f56
Reviewed-on: http://git-master/r/96440
Disable Hard Reset on long press of power key.
Bug 893517
Change-Id: Ic328a04e917aa1bed6780e6f9a2f1c575f84fb68
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/96687
Currently udc driver is dependent on otg driver.
Added irq work to make gadget driver work with
disabling otg driver.
Bug 962366
Change-Id: Id782d8003da12ace553b8b812fa410567c281b34
Reviewed-on: http://git-master/r/95106
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Tested-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
AVDD_DSI_CSI is shared by modem and dsi. If DSI turns
off this rail then HSIC fails after wakeup from modem.
This patch provides a way to turn on this rail from
modem as well as from DSI. Create two virtual power rails
from avdd_csi_dsi to control it from both the drivers separately.
This is enterprise specific change as per the power rail layout.
Bug 920881
(cherry picked from commit ab52b51c59f776ae770d48a28a2744e2db2e5d2f)
Reviewed-on: http://git-master/r/85656
Change-Id: I2e9c04a8f4e8d6fd20584b4e75657c1cb6d5c8bd
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/89134
Reviewed-by: Puneet Saxena <puneets@nvidia.com>
Added tegra_dma_get_channel_id API to determine the id
of a given channel.
Bug 969125
Change-Id: Ibad67d65c87dc267a4e6942557c02acbd0f6e938
Reviewed-on: http://git-master/r/96714
The VDD2 supply the power to three rails: 1.5V, LDO1 and LDO2.
LDO1 is used for PEX and LDO2 is used for SATA.
By default making the VDD2 off and enabling when
consumer requires.
Change-Id: I283f62277246214966e7635bc31b6eb066f9282b
Reviewed-on: http://git-master/r/96451
fix typo in pre-power wifi code
Bug 956238
Change-Id: Iee794da508d39131e3166bba71b1c46c60d19a3b
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/96821
Reviewed-by: Allen Martin <amartin@nvidia.com>
Change-Id: Ib1b0fc6015a9dd45982a97231972dadba6b5a92e
Reviewed-on: http://git-master/r/96966
Add support for setting & reading back OTG state with sysfs
bug 947300
Change-Id: I178c3eb6e2b227ca11fee8916e38c6677d3e4cb0
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/96660
The bias control must be done after the default register value
been restored.
Bug 964400
Change-Id: Iefbd96506573d5ea0e1b3123bb34c38e34e75068
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Reviewed-on: http://git-master/r/96658
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Bug 939292
Change-Id: Ib0c849418c6c426518948785082fcceb180f3d64
Reviewed-on: http://git-master/r/96250
Tested-by: Liang Cheng (SW) <licheng@nvidia.com>
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Reviewed-by: Mark Peters <mpeters@nvidia.com>
