Clear out all overlays and disable DC on .shutdown
Change-Id: I4bc78fddb0ed8bd621733df191f305ecb279e3f7
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/106549
Reviewed-by: Simone Willett <swillett@nvidia.com>
It is not necessary that all platform do register platform
data for tegra HS uart. platfrom_data pointer should
be checked before accessing it.
Added a check for same.
bug 995731
Change-Id: I2dbbaa4387157b92b29bc7b8eacefad23372427e
Signed-off-by: Manoj Chourasia <mchourasia@nvidia.com>
Reviewed-on: http://git-master/r/106451
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
We need SYSRQ during reboot to remount all the partitions as RO.
Otherwise all the partitions will be corrupted.
This reverts commit 2eea8dc6392dadce503ed9a9f709da3cab8d11ad
Bug 978676
Change-Id: I6d04ac284da174c161fb61f9f590715d4e6ac470
Signed-off-by: Gaurav Sarode <gsarode@nvidia.com>
Reviewed-on: http://git-master/r/106447
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
HSIC device enumeration is broken after usb common
phy changes. Setting correct hsic config in port_power
and repairing wIndex in hub_control.
Bug 991485
Change-Id: Ic2873879070cba8a06fb2cadc40d6c46158f71e9
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/105513
- For slave mode, clk_audio_2x needs to be
programmed to bitclock value. Setting this frequency
is not possible if the parent clock has different
frequency. Hence change the parent of this clock
to i2s_sync clock first before setting the rate.
- Fixed setting uninitialized variables.
Bug 948478
Change-Id: Ieb4656e6e114d3a9b815f44003a476c4b9892059
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/104445
Reviewed-by: Bob Johnston <bjohnston@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Scott Peterson <speterson@nvidia.com>
- Adding flag to treat warning as error.
- Warnings handled are unused functions, wrong C coding style, function argument
mismatch.
Bug 949219
Change-Id: I52cf5298ba552747dd4292af5b20db5ac8993cb0
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/106208
Disabling the ID_WAKEUP in the suspend causing the
otg state to change to host, so disabling it in otg
suspend. Also, renaming the readl calls to otg_readl
call.
Bug 993390
Change-Id: I2789ea31fefe4425eb63b6be3e70d794bddcfd83
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/106177
Move bandwidth calculation logic into its own file.
Change-Id: I57f58a6399805eede8783fea922c6f07dcbd54cb
Reviewed-on: http://git-master/r/106291
The current BCM4329 rfkill driver assumes usage of 2 GPIOs
known as RST and SHUTDOWN and the driver makes a particular
GPIO mandatory. Some of the platforms does not define both
GPIOs, instead a single either RST/SHUTDOWN GPIO is used to
setup the chip.
Hence print a less alarming message if gpio is not found.
Bug 975333
Signed-off-by: Preetham Chandru r <pchandru@nvidia.com>
Change-Id: I229844d9d5dfc94ea00bb086d1091ac41bf97b99
Reviewed-on: http://git-master/r/106158
Tested-by: Preetham Chandru <pchandru@nvidia.com>
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
removed tegra_dc_hdmi_mode_equal.
It was replaced by tegra_dc_hdmi_cvt_mode_equal
Change-Id: I7988d02a1c0b91eed88fdf573d8c993b6ee7be8d
Reviewed-on: http://git-master/r/106074
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
remove and rename unused variable in tega_dc_get_stride
Change-Id: I0d101de22c08609f9727469ad7e4708de8de59ef
Reviewed-on: http://git-master/r/106072
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Enable Atmel Mxt touchscreen for E1506 panel.
Bug 978305.
Change-Id: I57b02e4a9b3180e8114a96d5f9a8e075df166260
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/104895
Reviewed-by: Robert Collins <rcollins@nvidia.com>
Add support for 720p DSI panel on the E1506.
Bug 978305.
Change-Id: If76d2754eebc9e612c2ce006fa73ead7ebb1a109
Reviewed-on: http://git-master/r/104894
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
The function tegra_dc_host_trigger() is no longer used, removing it.
Change-Id: I929450bdf0224779910e8569bc8d1b3edb93f12d
Reviewed-on: http://git-master/r/106075
Added void to function prototypes and initialized some variables.
Change-Id: I69250f5e17560f900fffddec9697e496af6ad4d2
Reviewed-on: http://git-master/r/106073
baseband_xmm_power has delays related to CP sync-up.
Changing these delays from mdelay() to msleep and
usleep_range.
Adding wait_event mechanism to wait for L2->L0
Bug 932574
Change-Id: Ie33a3f1cc0a798e592f00153435b0135713213ea
Signed-off-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-on: http://git-master/r/102689
Reviewed-by: Steve Lin <stlin@nvidia.com>
Bug 992947
Change-Id: I0d1ecc9f8f042956cbe631779260a38573936616
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/105776
Change to correct behavior for changing settings while
phase_in_adjustments is set. Manual K values should not be overridden
in the case where DIDIM was on and aggressiveness was changed.
They should maintain state to avoid flickering.
Bug 992995
Change-Id: Ic35c32a0fd5c6caaeee147dff114649ea25770c5
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/105523
Change-Id: I762929a0d72a0b26aa1451a946993f4a57806fd4
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/104292
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Reviewed-by: Bo Yan <byan@nvidia.com>
Reviewed-by: Hiro Sugawara <hsugawara@nvidia.com>
Add a macro of_match_ptr() that allows the .of_match_table
entry in the driver structures to be assigned without having
an #ifdef xxx NULL for the case that OF is not enabled
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
(cherry picked from commit 3a1e362e3f3cd571b3974b8d44b8e358ec7a098c)
Change-Id: Ib0365629efb6f203f8d87b487f66f99417e71bb3
Reviewed-on: http://git-master/r/105929
Make the gpio-tps65910 as platform driver and register
this from tps65910 core driver as mfd sub device.
(cherry picked from commit 10bbc48d7a045c022a54f637c0c6b72f0e38b519)
Change-Id: Ib9419107acdaaa95052cc0fbe2efffb22c85e68d
Reviewed-on: http://git-master/r/105928
The tps65910_parse_dt() prototype for !CONFIG_OF was not correct, leading to:
drivers/mfd/tps65910.c: In function ‘tps65910_i2c_probe’:
drivers/mfd/tps65910.c:218:3: error: too many arguments to function ‘tps65910_parse_dt’
(cherry picked from commit 7f65f74ccee15f6eb0009921a428e3c5d5d06ae0)
Change-Id: I1592020268c408effc331069b7ae241c6da248bb
Reviewed-on: http://git-master/r/105927
As gpio support for tps65910 is on gpio driver, registering
gpio support as the mfd sub devices instead of calling gpio_init()
from the core probe.
(cherry picked from commit 32df986e985921386b75b4bd1117102bf65fe095)
Change-Id: I631596313528ab192d7d8c2f376965ccc989c313
Reviewed-on: http://git-master/r/105926
Convert memory allocation and regmap initialization to
use devm_* functions.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
(cherry picked from commit 63fe7dee9183118716078a9f2503f5f805d37c12)
Change-Id: I9b21c63031afffd1d9d1a37abf80895824f7fc7b
Reviewed-on: http://git-master/r/105925
During regmap initialization, we do not provide the default value and
hence in place of caching register during regmap_init(), cache it
when actually we need it i.e. after reading of that register.
(cherry picked from commit 3bf6bf9be51a0195c6b1604454fdd28ed1cc1770)
Change-Id: I151f52436162a328b8d683fc06beba0587d6bda3
Reviewed-on: http://git-master/r/105924
Add device tree based initialization support for TI's tps65910 pmic.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
(cherry picked from commit cd4209ced4d3936cfe51b7b8833260457e2d9995)
Change-Id: I6f211ebcee135fd0c52662f296eee9f47f801e7a
Reviewed-on: http://git-master/r/105923
This change removes the read/write callback functions in favor of common
regmap accessors inside the header file. This change also makes use of
regmap_read/write for single register access which maps better onto what this
driver actually needs.
(Cherry-pick from mainline
3f7e82759c692df473675ed06fb90b20f1f225c3)
Change-Id: Ida79b196acf65ed14ff9fd2cc1f7c0048f99ba2b
Reviewed-on: http://git-master/r/105922
Reviewed-by: Rhyland Klein <rklein@nvidia.com>
A warning was being generated by the reference from tps65910_i2c_probe()
to tps65910_sleepinit() since the latter was annotated as __init but the
former was unannotated. Since these functions can only be called during
device init make them both __devinit, and while we're at it also annotate
tps65910_i2c_remove() __devexit for symmetry.
(cherry picked from commit 63745d4068de8ccea3580214c6dbfdca0ec37859)
Change-Id: I9e85e31e770c7ea68524d046b87036d6d0264523
Reviewed-on: http://git-master/r/105921
Adding support for device sleep through the external input control
signal "SLEEP".
Changing the SLEEP signal state can switch the device into SLEEP and
ACTIVE state.
Also adding sleep configuration for different resources so that they
should be keep on during sleep state of device.
(Cherry-picked from mainline
201cf052810d20814a77ca0e0045a2c1a3508a1f)
Change-Id: Iec18bfcc7a1df6442e833dccaa1d39407918f710
Reviewed-on: http://git-master/r/105920
This was the copy-paste issue in reg cache support code where
variable name for regmap config was not really starting from
the device name, it was starting from some other device name.
Fixing this so that variable name contains actual device name.
(cherry picked from commit 39ecb0376508b5cd20a951388d10aed2d719a77f)
Change-Id: Ife11f77952d847ae7918f11cf1e936bf5008feb4
Reviewed-on: http://git-master/r/105918
Replaced kstrtoul with sscanf.
Change-Id: I1c82e92bf43d2ceba6ac3a7c0090394ba3497f13
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/105888
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Remove BUG_ON()s in error cases:
* If IOCTL size is too large, return error instead
* If sync point id is out of range, return error. Prevents panics in
sanity checks nvhost_cdma.
Bug 993642
Change-Id: I3cfa7a23dc557c811e20b726885f82666437de7f
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/105866
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Change the mechanism of enabling the force PWM mode through
regulator set mode. This can be dynamically configured now.
In the REGULATOR_MODE_FAST the force PWM is enabled and in
REGULATOR_MODE_NORMAL the force PWM is disabled.
Cherry-picked from mainline commit 9a00630
Change-Id: I39a77dbe5d0c4c2a5b81dbfe51163a65894bc98c
Reviewed-on: http://git-master/r/105832
Use the pcm-driver specified from platform/board
specified file.
Bug 991926
Change-Id: I9e4c9a3f76bacb22de817273a2281ac9b8959c43
Reviewed-on: http://git-master/r/105415
sdio supports 1.8 volts, setting 1.8 volts for
cardhu, kai, ventana, whistler
Bug 979504
Change-Id: I8f03b01e0792ac0e6abe74ce898934e65762fb85
Signed-off-by: naveen kumar arepalli <naveenk@nvidia.com>
Reviewed-on: http://git-master/r/104712
Fix the issue -
When device connects to 2GHz AP, it does not scan
APs in 5GHz and vice-versa.
Bug 968022
Change-Id: I5dfddf4e73260cb1e03bd3d28c029503507cd898
Signed-off-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-on: http://git-master/r/104482
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Due to noise on serial port , we get unwanted SYSRQ events.
Bug 978676
Change-Id: Ida73f6817c2365b74c7237ae97a9fc006674c34c
Reviewed-on: http://git-master/r/103786
Bug 949219
Change-Id: I91a67d30869e9800c483f112d58b9f76e2dbe361
Reviewed-on: http://git-master/r/103534
Use sg_next to get next sg
Bug 958431
Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Change-Id: I14aa7c9c551d0230b9c5b681a2699dd5355d0a6d
Reviewed-on: http://git-master/r/98449
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
The RICOH RC5T583 drivers are back ported to downstream from
mainline. Enabling this driver.
Change-Id: I1c956e622aebb705d860e5b50df5a1c82c5d57c3
Reviewed-on: http://git-master/r/105886
The PMIC device RC5T583 from RICOH supports 8 gpios.
Adding gpio driver for this device to access the pins
control through gpio library.
[grant.likely: slight cosmetic changes]
e9fe32bcadb8a7a40411d77f168abd45941b049b)
Change-Id: Id11f0dec229a92ce0ddcf606376ff83b6e14ca90
Reviewed-on: http://git-master/r/105885
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Fixing build issue reported by Paul Gortmaker:
It appears this breaks linux-next allmodconfig build, because it
uses an uppercase V in the v2 of its MODULE_LICENSE.
FATAL: modpost: GPL-incompatible module rc5t583-regulator.ko uses
GPL-only symbol 'platform_driver_unregister'
make[2]: *** [__modpost] Error 1
(cherry picked from commit 4eb06453648bb0d1eca3669f26798a19b6f40eb8)
Change-Id: I8c715cf5a8e72555721a954d6db6879aed2eb423
Reviewed-on: http://git-master/r/105884
The nsteps can be calculated by (_max_mv - _min_mv) * 1000 / _step_uV + 1,
thus we can remove _nsteps from RC5T583_REG macro, and then remove
nsteps from struct rc5t583_regulator_info.
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
(cherry picked from commit e3a7384c3e98c48b5f122e449e22cc8a1a6c7e0d)
Change-Id: If6db39255b2f7f8be38b848f2ca2619301b19b38
Reviewed-on: http://git-master/r/105883
The valid selector should be 0 ... nsteps-1.
(cherry picked from commit 9cc7a453b637d8c1f628f9873204ff55d7aa664c)
Change-Id: Ie1a39883036de3b2945d35854e0a16c46d2a9db2
Reviewed-on: http://git-master/r/105882
1. regulator_register returns ERR_PTR on error, thus use IS_ERR to check the
return value.
2. Fix off-by-one for unregistering the registered regulator.
Current code does not unregister regs[0].rdev in clean_exit.
(cherry picked from commit a69df8a14ae7b891ee22f0e4c081f3ff65c0640f)
Change-Id: Ib5e00e655020e313c73e5b838e62dbdea54c28d0
Reviewed-on: http://git-master/r/105881
(cherry picked from commit f8dddc0cfe9f56ed74fd5efde8d0754f5fb73a3f)
Change-Id: I72d44f59c79abbbdac95398a5d4da2bedf19d8f1
Reviewed-on: http://git-master/r/105880
Adding the gpio of RC583 in the list of rc583 mfd devices
to register the gpio driver of RC5T583.
(cherry picked from commit e1277f45d8748ff59608b140780f75390cb5400c)
Change-Id: Iea2ccf7831c331d1ad08f96100d4222cce31224f
Reviewed-on: http://git-master/r/105879
The combination of commit 1b1247dd75aa5cf5fae54a3bec7280046e9c7957
"mfd: Add support for RICOH PMIC RC5T583"
and commit 6ffc3270210efa2bea526953a142ffc908f5bd86
"regulator: Add support for RICOH PMIC RC5T583 regulator"
are causing the i386 allmodconfig builds to fail with this:
ERROR: "rc5t583_update" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_set_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_clear_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_read" [drivers/regulator/rc5t583-regulator.ko] undefined!
and this:
ERROR: "rc5t583_ext_power_req_config" [drivers/regulator/rc5t583-regulator.ko] undefined!
For the 1st four, make the simple ops static inline, instead of
polluting the namespace with trivial exports. For the last one,
add an EXPORT_SYMBOL.
(cherry picked from commit 82ea267f7dc853a5e6a724916a70a10656efdfc2)
Change-Id: I7f03cc5c0005883eb8355170cdc7996a9c392091
Reviewed-on: http://git-master/r/105878
The RC5T583 PMIC from RICOH consists of 4 DCDC and 10
LDOs. This driver supports the control of different
regulator output through regulator interface.
This driver depends on MFD driver of RC5T583 and uses
mfd rc5t583 apis to communicate to device for accessing
different device's registers.
(Cherry-picked from mainline commit
6ffc3270210efa2bea526953a142ffc908f5bd86)
Change-Id: If6bcc9c987fc97ff6f0c61e53de715cd84d0151b
Reviewed-on: http://git-master/r/105877
Add config Enable TEGRA_NVAVP_AUDIO to enable
Audio Channel support
bug 964515
Change-Id: Ibc17e650f5a26b348ea9dda329d009c79ba21a49
Signed-off-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-on: http://git-master/r/104382
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
