Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
(cherry picked from commit 50496a1fab6c6a90b77da4b247321a88e632bd46)
(cherry picked from commit 6238cbaec429c98d1a280014839c934107c7c8f6)
(cherry picked from commit f4d663ce6357e533f107ce3789bd8848c94bea81)
(cherry picked from commit 6c5a86f529a9e9ca4c9aca5fa477e9557d4a3d3d)
We add a report function pointer to struct crypto_type. This function
pointer is used from the crypto userspace configuration API to report
crypto algorithms to userspace.
(cherry picked from commit b6aa63c09ba3b150a1030f9c95c7647361e7910e)
The upcomming crypto usrerspace configuration api needs
to remove the spawns on top on an algorithm, so export
crypto_remove_spawns.
(cherry picked from commit 89b596ba22d79dd5616616a9975192e1c2bea0fe)
This patch adds a basic userspace configuration API for the crypto layer.
With this it is possible to instantiate, remove and to show crypto
algorithms from userspace.
(cherry picked from commit a38f7907b926e4c6c7d389ad96cc38cec2e5a9e9)
Incresed PWM base clock to 25.5MHz. This results in maximum 99.6Khz
PWM out frequency which can be further divided by an integer divider.
Integrate Atmel MXT multitouch controller driver which is interfaced
over I2C bus. The driver supports the 7" multitouch variant available
from Logic Technologies.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Update mxt driver to upstream version.
With gcc 7 the following compile time error occurs:
| .../drivers/usb/gadget/tegra_udc.c:2565:17: error: 'out' directive writing 3 bytes into a region of size between 2 and 11 [-Werror=format-overflow=]
| sprintf(name, "ep%dout", i);
| .../drivers/usb/gadget/tegra_udc.c:2565:3: note: 'sprintf' output between 7 and 16 bytes into a destination of size 14
The last end point will never be greater than 32 but the compiler can
not find this out from the code. Work around this by passing a format
specifier to interpreat i as a signed char.
We were only looking in tegra, VESA and CEA tables.
Let's also check standard video mode definitions table
At least the LM95245 temperature sensor is only supposed to be run at a
speed of 100 KHz.
Prepare for snapd integration.
While MXM3 pin 37 aka WAKE1_MICO is pulled up with 4.7 K on the Apalis
Evaluation board and 100 K on the Ixora carrier board a custom carrier
board may leave it floating which may cause an unintended high interrupt
load on the default wake-up key with which may cause a lower CPU
performance.
While SODIMM pin 45 is pulled down with 100 K on the Colibri Evaluation
board it is currently left floating on the Iris carrier board. This can
cause an unintended high interrupt load on the default power-key with
wake-up capabilities which can cause a lower CPU performance.
Print log message before module (local) or SoC (remote) is reaching
critical shutdown temperature nT_CRIT as the LM95245 temperature
sensor's OVERT_N pin is directly connected to PMIC PWRDN.
The number of channels registered when not using the touchscreen
block has been wrong. This did not allow to access all channels
in case where touchscreen is not used. By default Apalis and
Colibri T30 do use the touchscreen block, so the bug has not
affected the products when used with default platform data.
Rather than the TPS65910 driver the TPS6591X one is in use and to avoid
any confusion we drop the former completely.
Register SOC device to expose the SoC UID information via soc_sys
Use the standard sys_soc interface to expose the SoC UID information.
e.g.
~# cat /sys/bus/soc/devices/soc0/machine
NVIDIA Tegra
~# cat /sys/bus/soc/devices/soc0/family
NVIDIA Tegra30
~# cat /sys/bus/soc/devices/soc0/revision
A03
~# cat /sys/bus/soc/devices/soc0/soc_id
98317451306464792
This fixes:
note: expected ‘struct ida *’ but argument is of type ‘struct idr *’
warning: passing argument 1 of ‘ida_pre_get’ from incompatible pointer type
Reported-by: Arnd Bergman <arnd@arndb.de>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
(cherry picked from commit 3a4ffe930a2d2dad07604fe74d21b878decc6461)
Traditionally, any System-on-Chip based platform creates a flat list
of platform_devices directly under /sys/devices/platform.
In order to give these some better structure, this introduces a new
bus type for soc_devices that are registered with the new
soc_device_register() function. All devices that are on the same
chip should then be registered as child devices of the soc device.
The soc bus also exports a few standardised device attributes which
allow user space to query the specific type of soc.
(cherry picked from commit 74d1d82cdaaec727f5072eb1c9f49b7e920e076f)
Hack to prevent boot lock-up if HDMI is not connected.
This has been observed on recent T20 SoC production lots produced some
when after mid 2015.
Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI.
This work is based on Tom St Denis' earlier patch,
http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2
Cc: Tom St Denis <tstdenis@elliptictech.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
(cherry picked from commit 93b5e86a6d13c5dec18c6611933fb38d7d80f0d2)
eMMC's may have a hardware reset line. This patch provides a
host controller operation to implement hardware reset and
a function to reset and reinitialize the card. Also, for MMC,
the reset is always performed before initialization.
The host must set the new host capability MMC_CAP_HW_RESET
to enable hardware reset.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
(cherry picked from commit b2499518b5ad7e28bb3ed348fd3f370eeb1e36c0)
As ext4 is known to cause issues on that ancient NVIDIA L4T kernel just
disable it in favour of ext3 which is known to be working fine.
Fix PCIe clock and reset not conforming to specification by moving PCIe
reset handling including the PLX PEX 8605 errata 5 workaround from the
board platform data into the right places timing wise in the PCIe driver
itself.
Also add a kernel command line argument to allow using the Apalis GPIO7
as a regular GPIO rather than for above mentioned PLX PEX 8605
workaround:
pex_perst=0
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Floating pins towards the camera input level-shifter cause it to
consume at least 100mW of power even in idle. This patch fixes this by
configuring pull-downs on all multiplexed camera input pins.
arch/arm/mach-tegra/board-colibri_t20.c:668:43: error: 'i2c2_ddc'
defined but not used [-Werror=unused-const-variable=]
static const struct tegra_pingroup_config i2c2_ddc = {
sound/soc/tegra/tegra30_dam.c: In function 'tegra30_dam_probe':
sound/soc/tegra/tegra30_dam.c:620:3: error: this 'if' clause does not
guard... [-Werror=misleading-indentation]
if ((i == TEGRA30_DAM_CTRL_RSVD_6) ||
sound/soc/tegra/tegra30_dam.c:624:4: note: ...this statement, but the
latter is misleadingly indented as if it is guarded by the 'if'
dam->reg_cache[i] =
drivers/video/tegra/dc/dsi.c: In function 'tegra_dsi_read_fifo':
drivers/video/tegra/dc/dsi.c:2515:3: error: this 'if' clause does not
if (rd_fifo_cnt << 2 > DSI_READ_FIFO_DEPTH)
drivers/video/tegra/dc/dsi.c:2518:4: note: ...this statement, but the
break;
commit 95272c29378ee7dc15f43fa2758cb28a5913a06d upstream.
-ftracer can duplicate asm blocks causing compilation to fail in
noclone functions. For example, KVM declares a global variable
in an asm like
asm("2: ... \n
.pushsection data \n
.global vmx_return \n
vmx_return: .long 2b");
and -ftracer causes a double declaration.
Cc: Michal Marek <mmarek@suse.cz>
Cc: stable@vger.kernel.org
Cc: kvm@vger.kernel.org
Reported-by: Linda Walsh <lkml@tlinx.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
(cherry picked from commit 5d814ad8d35e5e23e0c27fb0f0b80c1044ecefad)
commit cb984d101b30eb7478d32df56a0023e4603cba7f upstream.
As gcc major version numbers are going to advance rather rapidly in the
future, there's no real value in separate files for each compiler
version.
Deduplicate some of the macros #defined in each file too.
Neaten comments using normal kernel commenting style.
Cc: Segher Boessenkool <segher@kernel.crashing.org>
Cc: Sasha Levin <levinsasha928@gmail.com>
Cc: Alan Modra <amodra@gmail.com>
[ philm: backport to 3.10-stable ]
Signed-off-by: Philip Müller <philm@manjaro.org>
(cherry picked from commit a4a4f1cd733fe5b345db4e8cc19bb8868d562a8a)
Throughout compiler*.h, many version checks are made. These can be
simplified by using the macro that gcc's documentation recommends.
However, my primary reason for adding this is that I need bug-check
macros that are enabled at certain gcc versions and it's cleaner to use
this macro than the tradition method:
#if __GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ => 2)
If you add patch level, it gets this ugly:
#if __GNUC__ > 4 || (__GNUC__ == 4 && (__GNUC_MINOR__ > 2 || \
__GNUC_MINOR__ == 2 __GNUC_PATCHLEVEL__ >= 1))
As opposed to:
#if GCC_VERSION >= 40201
While having separate headers for gcc 3 & 4 eliminates some of this
verbosity, they can still be cleaned up by this.
See also:
http://gcc.gnu.org/onlinedocs/cpp/Common-Predefined-Macros.html
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
Acked-by: Borislav Petkov <bp@alien8.de>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Joe Perches <joe@perches.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
(cherry picked from commit 3f3f8d2f48acfd8ed3b8e6b7377935da57b27b16)
Commit 5963e317b1e9d2a ("ftrace/x86: Do not change stacks in DEBUG when
calling lockdep") prevented lockdep calls from the int3 breakpoint handler
from reseting the stack if a function that was called was in the process
of being converted for tracing and had a breakpoint on it. The idea is,
before calling the lockdep code, do a load_idt() to the special IDT that
kept the breakpoint stack from reseting. This worked well as a quick fix
for this kernel release, until a certain config caused a lockup in the
function tracer start up tests.
Investigating it, I found that the load_idt that was used to prevent
the int3 from changing stacks was itself being traced!
Even though the config had CONFIG_OPTIMIZE_INLINING disabled, and
all 'inline' tags were set to always inline, there were still cases that
it did not inline! This was caused by CONFIG_PARAVIRT_GUEST, where it
would add a pointer to the native_load_idt() which made that function
to be traced.
Commit 45959ee7aa645815a ("ftrace: Do not function trace inlined functions")
only touched the 'inline' tags when CONFIG_OPMITIZE_INLINING was enabled.
PARAVIRT_GUEST shows that this was not enough and we need to also
mark always_inline with notrace as well.
Reported-by: Fengguang Wu <wfg@linux.intel.com>
Tested-by: Fengguang Wu <wfg@linux.intel.com>
(cherry picked from commit 93b3cca1ccd30b1ad290951a3fc7c10c73db7313)
When gcc inlines a function, it does not mark it with the mcount
prologue, which in turn means that inlined functions are not traced
by the function tracer. But if CONFIG_OPTIMIZE_INLINING is set, then
gcc is allowed not to inline a function that is marked inline.
Depending on the options and the compiler, a function may or may
not be traced by the function tracer, depending on whether gcc
decides to inline a function or not. This has caused several
problems in the pass becaues gcc is not always consistent with
what it decides to inline between different gcc versions.
Some places should not be traced (like paravirt native_* functions)
and these are mostly marked as inline. When gcc decides not to
inline the function, and if that function should not be traced, then
the ftrace function tracer will suddenly break when it use to work
fine. This becomes even harder to debug when different versions of
gcc will not inline that function, making the same kernel and config
work for some gcc versions and not work for others.
By making all functions marked inline to not be traced will remove
the ambiguity that gcc adds when it comes to tracing functions marked
inline. All gcc versions will be consistent with what functions are
traced and having volatile working code will be removed.
Note, only the inline macro when CONFIG_OPTIMIZE_INLINING is set needs
to have notrace added, as the attribute __always_inline will force
the function to be inlined and then not traced.
(cherry picked from commit 45959ee7aa645815a5ce303a0ea1e48a21e67c6a)
When connected display EDID presents
aspect ratio that is in valid range,
but it's not in a table of valid ratios
accept it with a warning message.
Connecting unsuported screen to HDMI
resulted in kernel panic.
