Provide proper configuration for VGEN3, to make sure it's is always powered
which allows that rail to be automatically switched to 1.8 volts
for proper UHS-I operation. By default it's disabled.
With UHS-I enabled:
[ 104.153898] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 104.166202] mmcblk1: mmc1:59b4 USD00 15.0 GiB
[ 104.173923] mmcblk1: p1
root@colibri-imx6:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads: 226 MB in 3.01 seconds = 75.01 MB/sec
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Allow to disable extended attribute support.
This aids in reliability testing, especially since some xattr
related bugs have surfaced.
Also an embedded system might not need it, so this allows for a
slightly smaller kernel (about 4KiB).
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Richard Weinberger <richard@nod.at>
(cherry picked from commit 7e5471ce6dba5f28a3c7afdfe168655d236f677b)
When write syscall is called, every time security label is searched to
determine that file's privileges should be changed.
If LSM(Linux Security Model) is not used, this is useless.
So introduce CONFIG_UBIFS_SECURITY to disable security labels. it's default
value is "y".
Signed-off-by: Hyunchul Lee <cheol.lee@lge.com>
(cherry picked from commit 8326c1eec2449f0e868f7b19a5fa7bfa0386ab48)
The KSZ9031 defaults its FLP timing to 8ms whereas the IEEE 802.3 specification
specifiies 16ms +/-8ms.
>From the KSZ9031RNX and KSZ9031MNX data sheets revision 2.2, section
"Auto-Negotiation Timing":
The KSZ9031[RNX or MNX] Fast Link Pulse (FLP) burst-to-burst
transmit timing for Auto-Negotiation defaults to 8ms. IEEE 802.3
Standard specifies this timing to be 16ms +/-8ms. Some PHY link
partners need to receive the FLP with 16ms centered timing;
otherwise, there can be intermittent link failures and long
link-up times.
The PHY datasheet recommends configuring the FLP burst registers after
power-up/reset and immediately thereafter restarting auto-negotiation, so
we center the FLP timing at 16ms and then restart auto-negotiation in the
config_init for KSZ9031.
This commit consists of two upstream commits:
6270e1ae804ae781cdd3cc20eadfa4b6fb090ab7
a0da456bbf95d2a9294799bb05c61bfb24736bb7
Some Micrel KSZ8041NL PHY chips exhibit continous RX errors after using the
power down mode bit (0.11). If the PHY is taken out of power down mode in a
certain temperature range, the PHY enters a weird state which leads to
continously reporting RX errors. In that state, the MAC is not able to receive
or send any Ethernet frames and the activity LED is constantly blinking. Since
Linux is using the suspend callback when the interface is taken down, ending up
in that state can easily happen during a normal startup.
Micrel confirmed the issue, caused by abnormal clock recovery when using power
down mode. Even the latest revision (A4, Revision ID 0x1513) seems to suffer
that problem.
Remove the suspend/resume callback to avoid using the power down mode
completely.
On our i.MX6 SOC, the DIGPROG register is used for represent the
SOC ID and silicon revision. The revision has two part: MAJOR and
MINOR. each is represented in 8 bits in the register.
bits [15:8]: reflect the MAJOR part of the revision;
bits [7:0]: reflect the MINOR part of the revision;
In our linux kernel, the soc revision is represented in 8 bits. MAJOR
part and MINOR each occupy 4 bits.
previous method does NOT take care about the MAJOR part in DIGPROG register.
So reformat the revision read from the HW to compatible the revision format
used in kernel.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
(cherry picked from commit cf6fa1477149d4bddd096c71b46fa6c4cf9cf750)
Switch on 22 kOhm pull ups and lower the I2C frequency to around 40kHz
to get a more reliable communication.
(cherry picked from commit ffb2a2a59869415921e816614749ad5e48f9c077)
Several modules have issues with HS400 at 100MHz at room temperature
but they seem to work fine at HS400 at 200MHz. Do not restrict
frequency for now.
This reverts commit 166fb4842e780f63c31622af706335e7dcd48c24.
A9, A12 and A17
In order to prevent aliasing attacks on the branch predictor,
invalidate the BTB on CPUs that are known to be affected when taking
a prefetch abort on a address that is outside of a user task limit.
(cherry picked from commit a07373c8c365746583f25f49fee41b1bc0ff94b2)
[jason: adapted to 4.1]
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
In order to avoid aliasing attacks against the branch predictor,
some implementations require to invalidate the BTB when switching
from one user context to another.
For this, we reuse the existing implementation for Cortex-A8, and
apply it to A9, A12 and A17.
(cherry picked commit from efcd0e857a656bbd1c1da15ff984ad6402332c61)
Commit 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
changed many more clocks than only the SPDIF core clock as stated in
the commit message.
The MLB clock has been added and this causes SPDIF regression as
reported by Xavi Drudis Ferran and also in this forum post:
https://forum.digikey.com/thread/34240
The MX6Q Reference Manual does not mention that MLB is a clock related
to SPDIF, so change it back to a dummy clock to restore SPDIF
functionality.
Thanks to Ambika for providing the fix at:
https://community.nxp.com/thread/387131
Fixes: 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
Cc: <stable@vger.kernel.org> # 4.4.x
Reported-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
(cherry picked from commit f065e9e4addd75c21bb976bb2558648bf4f61de6)
Tested playback and record on pulseaudio with 44.1kHz samples.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Signed-off-by: Andri Schmidt <a.schmidt@scewo.ch>
SDHCI falls back to fixed sampling if there is an error during tuning.
However it also reports an error unless there is periodic re-tuning.
That is not the best option because:
a) there is a reasonable chance that fixed sampling will work, especially
at room temperature.
b) re-tuning will be done again anyway if there are CRC errors.
Change to return no error always when falling back to fixed sampling.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
(cherry picked from commit 0760c355525c08dd598e86edb2a310688ac8af4c)
Other unsigned properties return hexadecimal values, follow this
convention when printing b_vendor_code too. Also add newlines to
the OS Descriptor support related properties, like other sysfs
files use.
Reviewed-by: Krzysztof Opasiak <k.opasiak@samsung.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
(cherry picked from commit e800e8cbdf42c73602b90258f82a2cfe86ec53a7)
Currently qw_sign requires UTF-8 character to set, but returns UTF-16
when read. This isn't obvious when simply using cat since the null
characters are not visible, but hexdump unveils the true string:
# echo MSFT100 > os_desc/qw_sign
# hexdump -C os_desc/qw_sign
00000000 4d 00 53 00 46 00 54 00 31 00 30 00 30 00 |M.S.F.T.1.0.0.|
Make qw_sign symmetric by returning an UTF-8 string too. Also follow
common convention and add a new line at the end.
(cherry picked from commit 76180d716f91f035d9c8639497cf5459b44e1a51)
Now that the PWM work enable them.
While at it move the backlight pwm settings into the carrier board
file were it belongs. Periode and polarity are carrier board / display
dependent.
Update #pwm-cells to 3 in order to support PWM signal polarity
control.
All PWM clock instances have their clock gate. Add these consistently.
Fixes freezing the kernel when one of these instances is used with
IMX6UL_CLK_DUMMY as its clock source.
Add a device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT.
This is done by splitting out common nodes / properties into
common *dtsi files and keep only the differences in a separate
files.
During temperature testing modules print the following error every
now and then:
[ 12.231006] mmc0: Timeout waiting for hardware interrupt. retries left=0 opcode=12
Often the SDHC controller/driver does not recover from the issue
which leads to a Kernel panic (e.g. during boot the kernel can not
mount the root fs).
Lowering the frequency to 100MHz proves to be stable and affects
effective bandwith by less than 5%.
There are macros specifying the bmode pins for i.MX 6UL and ULL.
Don't use the UL macros.
Add 900MHz/1.25V setpoint according the latest datasheet(Rev.1,2/2017),
we add a 25mV voltage margin to cover the IR frop and board tolerance.
(cherry picked from commit 9c31f7bf938adb9a808ea7bf637ccecf53f6e7be)
(cherry picked from commit c27010d99a3d91703ea2d1a3f9630a9dedc3f86f)
According to the latest datasheet(Rev.1,02/2017), when the internal LDO
is enabled, the ARM core can run at 900MHz. We need to check the
speed grading fuse to determine the max ARM core frequency.
(cherry picked from commit cc0edd14c5fc3b5590302572687b08f80563c683)
(cherry picked from commit c0821bb630b5a993a7cb8405f228f8bbd9e0bef7)
imx6ull RDP
Update imx6ull header file with the latest imx6ull RDP.
- add new pin function definitions.
- update pin function changes.
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
(cherry picked from commit 2c32aec9f6b910e03c7d422ad524352663547f52)
imx6ull.dtsi contains the values for 800/900MHz i.MX 6ULL.
Don't override the values here with wrong cpu voltages.
This fixes the i.MX6ULL 512MB boot freeze and it fixes
the SoC temperature sensor.
We use the second ethernet MAC for the on module ethernet.
Use an alias so that U-Boot fixes up the device tree to assign the
MAC address corresponding to the serial number to the second MAC and
uses the (serial# + 0x100000) one for the first MAC.
By default one can only use channels 0 and 1.
The AD channels on the SODIMM are connected as follows:
AD0 channel 0
AD1 channel 1
AD2 channel 8
AD3 channel 9
Move all entries for node cpu0 together.
This brings in the configuration changes needed for backports.
Also remove drivers not used in a Colibri iMX6ULL.
Synchronize the defconfigs with changes done in meta-toradex-nxp.
Normalize the defconfigs by
make ..._defconfig
make savedevconig
cp defconfig arch/arm/configs/..._defconfig
Enable atmel mxt multi-touch controller driver to be built as a
module.
Add atmel mxt multitouch controller driver which is interfaced over I2C bus.
This controller is used by the Logic Technologies, Capacitive Touch Display
7" Parallel (LT161010-2NHC).
Enable atmel mxt multi-touch controller driver to be built as a module.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add new gpio hog group for atmel mxt ts GPIOs.
module.
They currently don't work. Activating them from the sysfs does
freeze the kernel.
For some reason USDHC and USB access crashes the kernel if the
OCOTP clock is not enabled. It seems not to be software related
since there is no direct access from the USDHC/Chipidea USB
driver to the OCOTP IP. It might be that the hardware checks
the fuses to determine if the particular SoC is supposed to
let user access a certain peripheral...
The file uses linux,keycode = <KEY_POWER>;, so include
the header which defines KEY_POWER.
The device tree property fsl,legacy-bch-geometry was only evaluated
when nand-on-flash-bbt was also defined. This looks wrong.
In mainline (as of 4.12) fsl,legacy-bch-geometry doesn't exist,
its functionality seems to be taken over by the fsl,use-minimum-ecc
property and it is used independent of nand-on-flash-bbt.
The move of code gets also rid of the following compiler warning:
drivers/mtd/nand/gpmi-nand/gpmi-nand.c:2274:2: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if (of_property_read_bool(this->dev->of_node,
drivers/mtd/nand/gpmi-nand/gpmi-nand.c:2278:3: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
i.MX6 SL/UL/ULL use a different node in the device tree for with ocotp.
So change to the relevant compatible string for these SoCs.
With the move from the 3.14.52 to the 4.1 kernel the way the weim
node defines chipselects changed.
A phandle to the gpr node is needed.
Only the following 4 configuration can be specified in the ranges property:
CS0(128M), CS1 (0M), CS2(0M), CS3(0M)
CS0(64M), CS1(64M), CS2(0M), CS3(0M)
CS0(64M), CS1(32M), CS2(32M), CS3(0M)
CS0(32M), CS1(32M), CS2(32M), CS3(32M)
POWER_ENABLE_MOCI
Poweroff failed powering off the carrier board side of things
and did not deassert POWER_ENABLE_MOCI on poweroff. Fix this.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Add support for the latest addition to the Colibri iMX7 familiy,
Colibri iMX7 Dual 1GB with eMMC storage.
