commit e9e08a07385e08f1a7f85c5d1e345c21c9564963 upstream.
With CONFIG_LKDTM=y and make OBJCOPY=llvm-objcopy, llvm-objcopy errors:
llvm-objcopy: error: --set-section-flags=.text conflicts with
--rename-section=.text=.rodata
Rather than support setting flags then renaming sections vs renaming
then setting flags, it's simpler to just change both at the same time
via --rename-section. Adding the load flag is required for GNU objcopy
to mark .rodata Type as PROGBITS after the rename.
This can be verified with:
$ readelf -S drivers/misc/lkdtm/rodata_objcopy.o
Section Headers:
[Nr] Name Type Address Offset
Size EntSize Flags Link Info Align
[ 1] .rodata PROGBITS 0000000000000000 00000040
0000000000000004 0000000000000000 A 0 0 4
Which shows that .text is now renamed .rodata, the alloc flag A is set,
the type is PROGBITS, and the section is not flagged as writeable W.
Cc: stable@vger.kernel.org
Link: https://sourceware.org/bugzilla/show_bug.cgi?id=24554
Link: https://github.com/ClangBuiltLinux/linux/issues/448
Reported-by: Nathan Chancellor <natechancellor@gmail.com>
Suggested-by: Alan Modra <amodra@gmail.com>
Suggested-by: Jordan Rupprect <rupprecht@google.com>
Suggested-by: Kees Cook <keescook@chromium.org>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
commit 4c12954965fdf33d8ae3883c1931fc29ca023cfb upstream.
The PixArt OEM mice are known for disconnecting every minute in
runlevel 1 or 3 if they are not always polled. So add quirk
ALWAYS_POLL for this Alienware branded Primax mouse as well.
Daniel Schepler (@dschepler) reported and tested the quirk.
Reference: https://github.com/sriemer/fix-linux-mouse/issues/15
Signed-off-by: Sebastian Parschauer <s.parschauer@gmx.de>
CC: stable@vger.kernel.org
commit 7379e6baeddf580d01feca650ec1ad508b6ea8ee upstream.
The interrupt handler `pci230_interrupt()` causes a null pointer
dereference for a PCI260 card. There is no analog output subdevice for
a PCI260. The `dev->write_subdev` subdevice pointer and therefore the
`s_ao` subdevice pointer variable will be `NULL` for a PCI260. The
following call near the end of the interrupt handler results in the null
pointer dereference for a PCI260:
comedi_handle_events(dev, s_ao);
Fix it by only calling the above function if `s_ao` is valid.
Note that the other uses of `s_ao` in the calls
`pci230_handle_ao_nofifo(dev, s_ao);` and `pci230_handle_ao_fifo(dev,
s_ao);` will never be reached for a PCI260, so they are safe.
Fixes: 39064f23284c ("staging: comedi: amplc_pci230: use comedi_handle_events()")
Cc: <stable@vger.kernel.org> # v3.19+
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit b8336be66dec06bef518030a0df9847122053ec5 upstream.
The interrupt handler `dt282x_interrupt()` causes a null pointer
dereference for those supported boards that have no analog output
support. For these boards, `dev->write_subdev` will be `NULL` and
therefore the `s_ao` subdevice pointer variable will be `NULL`. In that
case, the following call near the end of the interrupt handler results
in a null pointer dereference:
(There are other uses of `s_ao` by the interrupt handler that may or may
not be reached depending on values of hardware registers. Trust that
they are reliable for now.)
Note:
commit 4f6f009b204f ("staging: comedi: dt282x: use comedi_handle_events()")
propagates an earlier error from
commit f21c74fa4cfe ("staging: comedi: dt282x: use cfc_handle_events()").
Fixes: 4f6f009b204f ("staging: comedi: dt282x: use comedi_handle_events()")
commit 2681795b5e7a5bf336537661010072f4c22cea31 upstream.
Writing 4CC commands with tps6598x_write_4cc() already has
a pointer arg, don't reference it when using as arg to
tps6598x_block_write(). Correcting this enforces the constness
of the pointer to propagate to tps6598x_block_write(), so add
the const qualifier there to avoid the warning.
Fixes: 0a4c005bd171 ("usb: typec: driver for TI TPS6598x USB Power Delivery controllers")
Signed-off-by: Nikolaus Voss <nikolaus.voss@loewensteinmedical.de>
Acked-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Cc: stable <stable@vger.kernel.org>
commit 05da75fc651138e51ff74ace97174349910463f5 upstream.
Portinfo bit field is 3 bits wide, not 2 bits. This led to
a wrong driver configuration for some tps6598x configurations.
commit b2357839c56ab7d06bcd4e866ebc2d0e2b7997f3 upstream.
The old commit 6e4b74e4690d ("usb: renesas: fix scheduling in atomic
context bug") fixed an atomic issue by using workqueue for the shdmac
dmaengine driver. However, this has a potential race condition issue
between the work pending and usbhsg_ep_free_request() in gadget mode.
When usbhsg_ep_free_request() is called while pending the queue,
since the work_struct will be freed and then the work handler is
called, kernel panic happens on process_one_work().
To fix the issue, if we could call cancel_work_sync() at somewhere
before the free request, it could be easy. However,
the usbhsg_ep_free_request() is called on atomic (e.g. f_ncm driver
calls free request via gether_disconnect()).
For now, almost all users are having "USB-DMAC" and the DMAengine
driver can be used on atomic. So, this patch adds a workaround for
a race condition to call the DMAengine APIs without the workqueue.
This means we still have TODO on shdmac environment (SH7724), but
since it doesn't have SMP, the race condition might not happen.
Fixes: ab330cf3888d ("usb: renesas_usbhs: add support for USB-DMAC")
Cc: <stable@vger.kernel.org> # v4.1+
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit dfc4fdebc5d62ac4e2fe5428e59b273675515fb2 upstream.
Use a 10000us AHB idle timeout in dwc2_core_reset() and make it
consistent with the other "wait for AHB master IDLE state" ocurrences.
This fixes a problem for me where dwc2 would not want to initialize when
updating to 4.19 on a MIPS Lantiq VRX200 SoC. dwc2 worked fine with
4.14.
Testing on my board shows that it takes 180us until AHB master IDLE
state is signalled. The very old vendor driver for this SoC (ifxhcd)
used a 1 second timeout.
Use the same timeout that is used everywhere when polling for
GRSTCTL_AHBIDLE instead of using a timeout that "works for one board"
(180us in my case) to have consistent behavior across the dwc2 driver.
Cc: linux-stable <stable@vger.kernel.org> # 4.19+
Acked-by: Minas Harutyunyan <hminas@synopsys.com>
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
commit d29fcf7078bc8be2b6366cbd4418265b53c94fac upstream.
On spin lock release in rx_submit, gether_disconnect get a chance to
run, it makes port_usb NULL, rx_submit access NULL port USB, hence null
pointer crash.
Fixed by releasing the lock in rx_submit after port_usb is used.
Fixes: 2b3d942c4878 ("usb ethernet gadget: split out network core")
Signed-off-by: Kiruthika Varadarajan <Kiruthika.Varadarajan@harman.com>
commit 6e41e2257f1094acc37618bf6c856115374c6922 upstream.
The syzbot fuzzer found a bug in the p54 USB wireless driver. The
issue involves a race between disconnect and the firmware-loader
callback routine, and it has several aspects.
One big problem is that when the firmware can't be loaded, the
callback routine tries to unbind the driver from the USB _device_ (by
calling device_release_driver) instead of from the USB _interface_ to
which it is actually bound (by calling usb_driver_release_interface).
The race involves access to the private data structure. The driver's
disconnect handler waits for a completion that is signalled by the
firmware-loader callback routine. As soon as the completion is
signalled, you have to assume that the private data structure may have
been deallocated by the disconnect handler -- even if the firmware was
loaded without errors. However, the callback routine does access the
private data several times after that point.
Another problem is that, in order to ensure that the USB device
structure hasn't been freed when the callback routine runs, the driver
takes a reference to it. This isn't good enough any more, because now
that the callback routine calls usb_driver_release_interface, it has
to ensure that the interface structure hasn't been freed.
Finally, the driver takes an unnecessary reference to the USB device
structure in the probe function and drops the reference in the
disconnect handler. This extra reference doesn't accomplish anything,
because the USB core already guarantees that a device structure won't
be deallocated while a driver is still bound to any of its interfaces.
To fix these problems, this patch makes the following changes:
Call usb_driver_release_interface() rather than
device_release_driver().
Don't signal the completion until after the important
information has been copied out of the private data structure,
and don't refer to the private data at all thereafter.
Lock udev (the interface's parent) before unbinding the driver
instead of locking udev->parent.
During the firmware loading process, take a reference to the
USB interface instead of the USB device.
Don't take an unnecessary reference to the device during probe
(and then don't drop it during disconnect).
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: syzbot+200d4bb11b23d929335f@syzkaller.appspotmail.com
CC: <stable@vger.kernel.org>
Acked-by: Christian Lamparter <chunkeey@gmail.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 3f2640ed7be838c3f05c0d2b0f7c7508e7431e48 upstream.
This reverts commit 2e9fe539108320820016f78ca7704a7342788380.
Reading LSR unconditionally but processing the error flags only if
UART_IIR_RDI bit was set before in IIR may lead to a loss of transmission
error information on UARTs where the transmission error flags are cleared
by a read of LSR. Information are lost in case an error is detected right
before the read of LSR while processing e.g. an UART_IIR_THRI interrupt.
Signed-off-by: Oliver Barta <o.barta89@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Fixes: 2e9fe5391083 ("serial: 8250: Don't service RX FIFO if interrupts are disabled")
commit aed2a26283528fb69c38e414f649411aa48fb391 upstream.
Added USB IDs for GosunCn ME3630 cellular module in RNDIS mode.
T: Bus=03 Lev=01 Prnt=01 Port=01 Cnt=03 Dev#= 18 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=19d2 ProdID=0601 Rev=03.18
S: Manufacturer=Android
S: Product=Android
S: SerialNumber=b950269c
C: #Ifs= 5 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#=0x0 Alt= 0 #EPs= 1 Cls=e0(wlcon) Sub=01 Prot=03 Driver=rndis_host
I: If#=0x1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=rndis_host
I: If#=0x2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#=0x3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#=0x4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
Signed-off-by: Jörgen Storvist <jorgen.storvist@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit f8377eff548170e8ea8022c067a1fbdf9e1c46a8 upstream.
This adds the vid:pid of the isodebug v1 isolated JTAG/SWD+UART. Only the
second channel is available for use as a serial port.
Signed-off-by: Andreas Fritiofson <andreas.fritiofson@unjo.com>
commit 63d7ef36103d26f20325a921ecc96a3288560146 upstream.
Per the 802.11 specification, vendor IEs are (at minimum) only required
to contain an OUI. A type field is also included in ieee80211.h (struct
ieee80211_vendor_ie) but doesn't appear in the specification. The
remaining fields (subtype, version) are a convention used in WMM
headers.
Thus, we should not reject vendor-specific IEs that have only the
minimum length (3 bytes) -- we should skip over them (since we only want
to match longer IEs, that match either WMM or WPA formats). We can
reject elements that don't have the minimum-required 3 byte OUI.
While we're at it, move the non-standard subtype and version fields into
the WMM structs, to avoid this confusion in the future about generic
"vendor header" attributes.
Fixes: 685c9b7750bf ("mwifiex: Abort at too short BSS descriptor element")
Cc: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: Takashi Iwai <tiwai@suse.de>
commit 685c9b7750bfacd6fc1db50d86579980593b7869 upstream.
Currently mwifiex_update_bss_desc_with_ie() implicitly assumes that
the source descriptor entries contain the enough size for each type
and performs copying without checking the source size. This may lead
to read over boundary.
Fix this by putting the source size check in appropriate places.
commit d974ffcfb7447db5f29a4b662a3eaf99a4e1109e upstream.
The vsyscall=native feature is gone -- remove the docs.
Fixes: 076ca272a14c ("x86/vsyscall/64: Drop "native" vsyscalls")
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: Jann Horn <jannh@google.com>
Cc: Kernel Hardening <kernel-hardening@lists.openwall.com>
Link: https://lkml.kernel.org/r/d77c7105eb4c57c1a95a95b6a5b8ba194a18e764.1561610354.git.luto@kernel.org
commit 6e88559470f581741bcd0f2794f9054814ac9740 upstream.
Add documentation for Spectre vulnerability and the mitigation mechanisms:
- Explain the problem and risks
- Document the mitigation mechanisms
- Document the command line controls
- Document the sysfs files
Co-developed-by: Andi Kleen <ak@linux.intel.com>
Co-developed-by: Tim Chen <tim.c.chen@linux.intel.com>
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Reviewed-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
commit 993773d11d45c90cb1c6481c2638c3d9f092ea5b upstream.
The index to access the threads tls array is controlled by userspace
via syscall: sys_ptrace(), hence leading to a potential exploitation
of the Spectre variant 1 vulnerability.
The index can be controlled from:
ptrace -> arch_ptrace -> do_get_thread_area.
Fix this by sanitizing the user supplied index before using it to access
the p->thread.tls_array.
Signed-off-by: Dianzhang Chen <dianzhangchen0@gmail.com>
Cc: bp@alien8.de
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/1561524630-3642-1-git-send-email-dianzhangchen0@gmail.com
commit 31a2fbb390fee4231281b939e1979e810f945415 upstream.
The index to access the threads ptrace_bps is controlled by userspace via
syscall: sys_ptrace(), hence leading to a potential exploitation of the
ptrace -> arch_ptrace -> ptrace_get_debugreg.
Fix this by sanitizing the user supplied index before using it access
thread->ptrace_bps.
Cc: bp@alien8.de
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/1561476617-3759-1-git-send-email-dianzhangchen0@gmail.com
commit 599ee18f0740d7661b8711249096db94c09bc508 upstream.
In commit 292c34c10249 ("perf pmu: Fix core PMU alias list for X86
platform"), we fixed the issue of CPU events being aliased to uncore
events.
Fix this same issue for ARM64, since the said commit left the (broken)
behaviour untouched for ARM64.
Signed-off-by: John Garry <john.garry@huawei.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Hendrik Brueckner <brueckner@linux.ibm.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Kan Liang <kan.liang@linux.intel.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Shaokun Zhang <zhangshaokun@hisilicon.com>
Cc: Thomas Richter <tmricht@linux.ibm.com>
Cc: linuxarm@huawei.com
Fixes: 292c34c10249 ("perf pmu: Fix core PMU alias list for X86 platform")
Link: http://lkml.kernel.org/r/1560521283-73314-2-git-send-email-john.garry@huawei.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit dbc3117d4ca9e17819ac73501e914b8422686750 upstream.
In reboot tests on several devices we were seeing a "use after free"
when slub_debug or KASAN was enabled. The kernel complained about:
Unable to handle kernel paging request at virtual address 6b6b6c2b
...which is a classic sign of use after free under slub_debug. The
stack crawl in kgdb looked like:
0 test_bit (addr=<optimized out>, nr=<optimized out>)
1 bfq_bfqq_busy (bfqq=<optimized out>)
2 bfq_select_queue (bfqd=<optimized out>)
3 __bfq_dispatch_request (hctx=<optimized out>)
4 bfq_dispatch_request (hctx=<optimized out>)
5 0xc056ef00 in blk_mq_do_dispatch_sched (hctx=0xed249440)
6 0xc056f728 in blk_mq_sched_dispatch_requests (hctx=0xed249440)
7 0xc0568d24 in __blk_mq_run_hw_queue (hctx=0xed249440)
8 0xc0568d94 in blk_mq_run_work_fn (work=<optimized out>)
9 0xc024c5c4 in process_one_work (worker=0xec6d4640, work=0xed249480)
10 0xc024cff4 in worker_thread (__worker=0xec6d4640)
Digging in kgdb, it could be found that, though bfqq looked fine,
bfqq->bic had been freed.
Through further digging, I postulated that perhaps it is illegal to
access a "bic" (AKA an "icq") after bfq_exit_icq() had been called
because the "bic" can be freed at some point in time after this call
is made. I confirmed that there certainly were cases where the exact
crashing code path would access the "bic" after bfq_exit_icq() had
been called. Sspecifically I set the "bfqq->bic" to (void *)0x7 and
saw that the bic was 0x7 at the time of the crash.
To understand a bit more about why this crash was fairly uncommon (I
saw it only once in a few hundred reboots), you can see that much of
the time bfq_exit_icq_fbqq() fully frees the bfqq and thus it can't
access the ->bic anymore. The only case it doesn't is if
bfq_put_queue() sees a reference still held.
However, even in the case when bfqq isn't freed, the crash is still
rare. Why? I tracked what happened to the "bic" after the exit
routine. It doesn't get freed right away. Rather,
put_io_context_active() eventually called put_io_context() which
queued up freeing on a workqueue. The freeing then actually happened
later than that through call_rcu(). Despite all these delays, some
extra debugging showed that all the hoops could be jumped through in
time and the memory could be freed causing the original crash. Phew!
To make a long story short, assuming it truly is illegal to access an
icq after the "exit_icq" callback is finished, this patch is needed.
Reviewed-by: Paolo Valente <paolo.valente@unimore.it>
Signed-off-by: Douglas Anderson <dianders@chromium.org>
commit d07a9a4f66e944fcc900812cbc2f6817bde6a43d upstream.
Dell headset mode platform with ALC236.
It doesn't recording after system resume from S3.
S3 mode was deep. s2idle was not has this issue.
S3 deep will cut of codec power. So, the register will back to default
after resume back.
This patch will solve this issue.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit ca95c7bf3d29716916baccdc77c3c2284b703069 upstream.
Extension Unit (XU) is used to have a compatible layout with
Processing Unit (PU) on UAC1, and the usb-audio driver code assumed it
for parsing the descriptors. Meanwhile, on UAC2, XU became slightly
incompatible with PU; namely, XU has a one-byte bmControls bitmap
while PU has two bytes bmControls bitmap. This incompatibility
results in the read of a wrong address for the last iExtension field,
which ended up with an incorrect string for the mixer element name, as
recently reported for Focusrite Scarlett 18i20 device.
This patch corrects this misalignment by introducing a couple of new
macros and calling them depending on the descriptor type.
Fixes: 23caaf19b11e ("ALSA: usb-mixer: Add support for Audio Class v2.0")
Reported-by: Stefan Sauer <ensonic@hora-obscura.de>
commit b09a2ab2baeb36bf7ef7780405ad172281741c7c upstream.
There was a typo at the lower frequency limit for a DVB-C
card, causing the driver to fail while tuning channels at the
VHF range.
https://bugzilla.kernel.org/show_bug.cgi?id=202083
Fixes: f1b1eabff0eb ("media: dvb: represent min/max/step/tolerance freqs in Hz")
Reported-by: Ari Kohtamäki <ari.kohtamaki@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Signed-off-by: Sean Young <sean@mess.org>
commit fa33cdbf3eceb0206a4f844fe91aeebcf6ff2b7a upstream.
In some cases, using the 'truncate' command to extend a UDF file results
in a mismatch between the length of the file's extents (specifically, due
to incorrect length of the final NOT_ALLOCATED extent) and the information
(file) length. The discrepancy can prevent other operating systems
(i.e., Windows 10) from opening the file.
Two particular errors have been observed when extending a file:
1. The final extent is larger than it should be, having been rounded up
to a multiple of the block size.
B. The final extent is not shorter than it should be, due to not having
been updated when the file's information length was increased.
[JK: simplified udf_do_extend_final_block(), fixed up some types]
Fixes: 2c948b3f86e5 ("udf: Avoid IO in udf_clear_inode")
Signed-off-by: Steven J. Magnani <steve@digidescorp.com>
Link: https://lore.kernel.org/r/1561948775-5878-1-git-send-email-steve@digidescorp.com
commit 5858bdad4d0d0fc18bf29f34c3ac836e0b59441f upstream.
The directory may have been removed when entering
fscrypt_ioctl_set_policy(). If so, the empty_dir() check will return
error for ext4 file system.
ext4_rmdir() sets i_size = 0, then ext4_empty_dir() reports an error
because 'inode->i_size < EXT4_DIR_REC_LEN(1) + EXT4_DIR_REC_LEN(2)'. If
the fs is mounted with errors=panic, it will trigger a panic issue.
Add the check IS_DEADDIR() to fix this problem.
Fixes: 9bd8212f981e ("ext4 crypto: add encryption policy and password salt support")
Signed-off-by: Hongjie Fang <hongjiefang@asrmicro.com>
[ Upstream commit b96226148491505318228ac52624956bd98f9e0c ]
rpc_clnt_add_xprt take a reference to struct rpc_xprt_switch, but forget
to release it before return, may lead to a memory leak.
Signed-off-by: Lin Yi <teroincn@163.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit 909105199a682cb09c500acd443d34b182846c9c ]
We can end up in nfs4_opendata_alloc during task exit, in which case
current->fs has already been cleaned up. This leads to a crash in
current_umask().
Fix this by only setting creation opendata if we are actually doing an open
with O_CREAT. We can drop the check for NULL nfs4_open_createattrs, since
O_CREAT will never be set for the recovery path.
Suggested-by: Trond Myklebust <trondmy@hammerspace.com>
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
[ Upstream commit 48620e341659f6e4b978ec229f6944dabe6df709 ]
The comment is correct, but the code ends up moving the bits four
places too far, into the VTUOp field.
Fixes: 11ea809f1a74 (net: dsa: mv88e6xxx: support 256 databases)
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
[ Upstream commit c6d9c35d16f1bafd3fec64b865e569e48cbcb514 ]
Run below script as root, dquot_add_space will return -EDQUOT since
__dquot_transfer call dquot_add_space with flags=0, and dquot_add_space
think it's a preallocation. Fix it by set flags as DQUOT_SPACE_WARN.
mkfs.ext4 -O quota,project /dev/vdb
mount -o prjquota /dev/vdb /mnt
setquota -P 23 1 1 0 0 /dev/vdb
dd if=/dev/zero of=/mnt/test-file bs=4K count=1
chattr -p 23 test-file
Fixes: 7b9ca4c61bc2 ("quota: Reduce contention on dq_data_lock")
Signed-off-by: yangerkun <yangerkun@huawei.com>
[ Upstream commit 1ac3549ed58cdfdaf43bbf31ac260e2381cc0dae ]
The kernel panic was observed during iSCSI discovery via offload with below
call trace,
[ 2115.646901] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 2115.646909] IP: [<ffffffffacf7f0cc>] strncmp+0xc/0x60
[ 2115.646927] PGD 0
[ 2115.646932] Oops: 0000 [#1] SMP
[ 2115.647107] CPU: 24 PID: 264 Comm: kworker/24:1 Kdump: loaded Tainted: G
OE ------------ 3.10.0-957.el7.x86_64 #1
[ 2115.647133] Workqueue: slowpath-13:00. qed_slowpath_task [qed]
[ 2115.647135] task: ffff8d66af80b0c0 ti: ffff8d66afb80000 task.ti: ffff8d66afb80000
[ 2115.647136] RIP: 0010:[<ffffffffacf7f0cc>] [<ffffffffacf7f0cc>] strncmp+0xc/0x60
[ 2115.647141] RSP: 0018:ffff8d66afb83c68 EFLAGS: 00010206
[ 2115.647143] RAX: 0000000000000001 RBX: 0000000000000007 RCX: 000000000000000a
[ 2115.647144] RDX: 0000000000000100 RSI: 0000000000000000 RDI: ffff8d632b3ba040
[ 2115.647145] RBP: ffff8d66afb83c68 R08: 0000000000000000 R09: 000000000000ffff
[ 2115.647147] R10: 0000000000000007 R11: 0000000000000800 R12: ffff8d66a30007a0
[ 2115.647148] R13: ffff8d66747a3c10 R14: ffff8d632b3ba000 R15: ffff8d66747a32f8
[ 2115.647149] FS: 0000000000000000(0000) GS:ffff8d66aff00000(0000) knlGS:0000000000000000
[ 2115.647151] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 2115.647152] CR2: 0000000000000000 CR3: 0000000509610000 CR4: 00000000007607e0
[ 2115.647153] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 2115.647154] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 2115.647155] PKRU: 00000000
[ 2115.647157] Call Trace:
[ 2115.647165] [<ffffffffc0634cc5>] qedi_get_protocol_tlv_data+0x2c5/0x510 [qedi]
[ 2115.647184] [<ffffffffc05968f5>] ? qed_mfw_process_tlv_req+0x245/0xbe0 [qed]
[ 2115.647195] [<ffffffffc05496cb>] qed_mfw_fill_tlv_data+0x4b/0xb0 [qed]
[ 2115.647206] [<ffffffffc0596911>] qed_mfw_process_tlv_req+0x261/0xbe0 [qed]
[ 2115.647215] [<ffffffffacce0e8e>] ? dequeue_task_fair+0x41e/0x660
[ 2115.647221] [<ffffffffacc2a59e>] ? __switch_to+0xce/0x580
[ 2115.647230] [<ffffffffc0546013>] qed_slowpath_task+0xa3/0x160 [qed]
[ 2115.647278] RIP [<ffffffffacf7f0cc>] strncmp+0xc/0x60
Fix kernel panic by validating the session targetname before providing TLV
data and confirming the presence of boot targets.
Signed-off-by: Nilesh Javali <njavali@marvell.com>
Reviewed-by: Lee Duncan <lduncan@suse.com>
Reviewed-by: Chris Leech <cleech@redhat.com>
[ Upstream commit 9476274093a0e79b905f4cd6cf6d149f65e02c17 ]
Left shifting the signed int value 1 by 31 bits has undefined behaviour
and the shift amount oq_no can be as much as 63. Fix this by using
BIT_ULL(oq_no) instead.
Addresses-Coverity: ("Bad shift operation")
Fixes: f21fb3ed364b ("Add support of Cavium Liquidio ethernet adapters")
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit 6f6a8622057c92408930c31698394fae1557b188 ]
A similar fix to Patch "ip_tunnel: allow not to count pkts on tstats by
setting skb's dev to NULL" is also needed by ip6_tunnel.
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 74b67efa8d7b4f90137f0ab9a80dd319da050350 ]
The copy_from_user() function returns the number of bytes remaining
to be copied but we want to return a negative error code. Otherwise
the callers treat it as a successful copy.
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20190618131843.GA29463@mwanda
[ Upstream commit cf18cecca911c0db96b868072665347efe6df46f ]
Some transceivers may comply with SFF-8472 even though they do not
implement the Digital Diagnostic Monitoring (DDM) interface described in
the spec. The existence of such area is specified by the 6th bit of byte
92, set to 1 if implemented.
Currently, without checking this bit, bnx2x fails trying to read sfp
module's EEPROM with the follow message:
ethtool -m enP5p1s0f1
Cannot get Module EEPROM data: Input/output error
Because it fails to read the additional 256 bytes in which it is assumed
to exist the DDM data.
This issue was noticed using a Mellanox Passive DAC PN 01FT738. The EEPROM
data was confirmed by Mellanox as correct and similar to other Passive
DACs from other manufacturers.
Signed-off-by: Mauro S. M. Rodrigues <maurosr@linux.vnet.ibm.com>
Acked-by: Sudarsana Reddy Kalluru <skalluru@marvell.com>
[ Upstream commit 9642fa73d073527b0cbc337cc17a47d545d82cd2 ]
Stopping external metadata arrays during resync/recovery causes
retries, loop of interrupting and starting reconstruction, until it
hit at good moment to stop completely. While these retries
curr_mark_cnt can be small- especially on HDD drives, so subtraction
result can be smaller than 0. However it is casted to uint without
checking. As a result of it the status bar in /proc/mdstat while stopping
is strange (it jumps between 0% and 99%).
The real problem occurs here after commit 72deb455b5ec ("block: remove
CONFIG_LBDAF"). Sector_div() macro has been changed, now the
divisor is casted to uint32. For db = -8 the divisior(db/32-1) becomes 0.
Check if db value can be really counted and replace these macro by
div64_u64() inline.
Signed-off-by: Mariusz Tkaczyk <mariusz.tkaczyk@intel.com>
Signed-off-by: Song Liu <songliubraving@fb.com>
[ Upstream commit b0e370b95a3b231d0fb5d1958cce85ef57196fe6 ]
We don't have a reproducible error case, yet our BSP team suggested that
the mmc_switch_status() command in mmc_select_hs400() should come after
the callback into the driver completing HS400 setup. It makes sense to
me because we want the status of a fully setup HS400, so it will
increase the reliability of the mmc_switch_status() command.
Reported-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Fixes: ba6c7ac3a2f4 ("mmc: core: more fine-grained hooks for HS400 tuning")
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit 36815b416fa48766ac5a98e4b2dc3ebc5887222e ]
Permit mux_id values up to 254 to be used in qmimux_register_device()
for compatibility with ip(8) and the rmnet driver.
Fixes: c6adf77953bc ("net: usb: qmi_wwan: add qmap mux protocol support")
Cc: Daniele Palmas <dnlplm@gmail.com>
Signed-off-by: Reinhard Speyerer <rspmn@arcor.de>
[ Upstream commit a8fdde1cb830e560208af42b6c10750137f53eb3 ]
Switch qmimux_unregister_device() and qmi_wwan_disconnect() to
use unregister_netdevice_queue() and unregister_netdevice_many()
instead of unregister_netdevice(). This avoids RCU stalls which
have been observed on device disconnect in certain setups otherwise.
[ Upstream commit 61356088ace1866a847a727d4d40da7bf00b67fc ]
The QMAP code in the qmi_wwan driver is based on the CodeAurora GobiNet
driver which does not process QMAP padding in the RX path correctly.
Add support for QMAP padding to qmimux_rx_fixup() according to the
description of the rmnet driver.
[ Upstream commit fe8d9571dc50232b569242fac7ea6332a654f186 ]
Since commit 177366bf7ceb the %rbp stopped pointing to %rbp of the
previous stack frame. That broke frame pointer based stack unwinding.
This commit is a partial revert of it.
Note that the location of tail_call_cnt is fixed, since the verifier
enforces MAX_BPF_STACK stack size for programs with tail calls.
Fixes: 177366bf7ceb ("bpf: change x86 JITed program stack layout")
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 86723c8640633bee4b4588d3c7784ee7a0032f65 ]
.ndo_xdp_xmit() assumes it is called under RCU. For example virtio_net
uses RCU to detect it has setup the resources for tx. The assumption
accidentally broke when introducing bulk queue in devmap.
Fixes: 5d053f9da431 ("bpf: devmap prepare xdp frames for bulking")
Reported-by: David Ahern <dsahern@gmail.com>
Signed-off-by: Toshiaki Makita <toshiaki.makita1@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit edabf4d9dd905acd60048ea1579943801e3a4876 ]
dev_map_free() forgot to free bulk queue when freeing its entries.
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit d4dd153d551634683fccf8881f606fa9f3dfa1ef ]
dev_map_free() waits for flush_needed bitmap to be empty in order to
ensure all flush operations have completed before freeing its entries.
However the corresponding clear_bit() was called before using the
entries, so the entries could be used after free.
All access to the entries needs to be done before clearing the bit.
It seems commit a5e2da6e9787 ("bpf: netdev is never null in
__dev_map_flush") accidentally changed the clear_bit() and memory access
order.
Note that the problem happens only in __dev_map_flush(), not in
dev_map_flush_old(). dev_map_flush_old() is called only after nulling
out the corresponding netdev_map entry, so dev_map_free() never frees
the entry thus no such race happens there.
Fixes: a5e2da6e9787 ("bpf: netdev is never null in __dev_map_flush")
[ Upstream commit f8891461a277ec0afc493fd30cd975a38048a038 ]
It is not a good idea to try to perform any work (e.g. send an auth
frame) during reconfigure flow.
Prevent this from happening, and at the end of the reconfigure flow
requeue all the works.
Signed-off-by: Naftali Goldstein <naftali.goldstein@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
[ Upstream commit 563572340173865a9a356e6bb02579e6998a876d ]
In multiple SSID cases, it takes time to prepare every AP interface
to be ready in initializing phase. If a sta already knows everything it
needs to join one of the APs and sends authentication to the AP which
is not fully prepared at this point of time, AP's channel context
could be NULL. As a result, warning message occurs.
Even worse, if the AP is under attack via tools such as MDK3 and massive
authentication requests are received in a very short time, console will
be hung due to kernel warning messages.
WARN_ON_ONCE() could be a better way for indicating warning messages
without duplicate messages to flood the console.
Johannes: We still need to address the underlying problem, but we
don't really have a good handle on it yet. Suppress the
worst side-effects for now.
Signed-off-by: Zhi Chen <zhichen@codeaurora.org>
Signed-off-by: Yibo Zhao <yiboz@codeaurora.org>
[johannes: add note, change subject]
[ Upstream commit 68f2515bb31a664ba3e2bc1eb78dd9f529b10067 ]
The lcdc device is missing the dma_coherent_mask definition causing the
following warning on da850-evm:
da8xx_lcdc da8xx_lcdc.0: found Sharp_LK043T1DG01 panel
WARNING: CPU: 0 PID: 1 at kernel/dma/mapping.c:247 dma_alloc_attrs+0xc8/0x110
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 5.2.0-rc3-00077-g16d72dd4891f #18
Hardware name: DaVinci DA850/OMAP-L138/AM18x EVM
[<c000fce8>] (unwind_backtrace) from [<c000d900>] (show_stack+0x10/0x14)
[<c000d900>] (show_stack) from [<c001a4f8>] (__warn+0xec/0x114)
[<c001a4f8>] (__warn) from [<c001a634>] (warn_slowpath_null+0x3c/0x48)
[<c001a634>] (warn_slowpath_null) from [<c0065860>] (dma_alloc_attrs+0xc8/0x110)
[<c0065860>] (dma_alloc_attrs) from [<c02820f8>] (fb_probe+0x228/0x5a8)
[<c02820f8>] (fb_probe) from [<c02d3e9c>] (platform_drv_probe+0x48/0x9c)
[<c02d3e9c>] (platform_drv_probe) from [<c02d221c>] (really_probe+0x1d8/0x2d4)
[<c02d221c>] (really_probe) from [<c02d2474>] (driver_probe_device+0x5c/0x168)
[<c02d2474>] (driver_probe_device) from [<c02d2728>] (device_driver_attach+0x58/0x60)
[<c02d2728>] (device_driver_attach) from [<c02d27b0>] (__driver_attach+0x80/0xbc)
[<c02d27b0>] (__driver_attach) from [<c02d047c>] (bus_for_each_dev+0x64/0xb4)
[<c02d047c>] (bus_for_each_dev) from [<c02d1590>] (bus_add_driver+0xe4/0x1d8)
[<c02d1590>] (bus_add_driver) from [<c02d301c>] (driver_register+0x78/0x10c)
[<c02d301c>] (driver_register) from [<c000a5c0>] (do_one_initcall+0x48/0x1bc)
[<c000a5c0>] (do_one_initcall) from [<c05cae6c>] (kernel_init_freeable+0x10c/0x1d8)
[<c05cae6c>] (kernel_init_freeable) from [<c048a000>] (kernel_init+0x8/0xf4)
[<c048a000>] (kernel_init) from [<c00090e0>] (ret_from_fork+0x14/0x34)
Exception stack(0xc6837fb0 to 0xc6837ff8)
7fa0: 00000000 00000000 00000000 00000000
7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
---[ end trace 8a8073511be81dd2 ]---
Add a 32-bit mask to the platform device's definition.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
[ Upstream commit 0c0c9b5753cd04601b17de09da1ed2885a3b42fe ]
The BB expander at 0x21 i2c bus 1 fails to probe on da850-evm because
the board doesn't set has_full_constraints to true in the regulator
API.
Call regulator_has_full_constraints() at the end of board registration
just like we do in da850-lcdk and da830-evm.
[ Upstream commit 4b14cc313f076c37b646cee06a85f0db59cf216c ]
When PVID is removed from a bridge port, the Linux bridge drops both
untagged and prio-tagged packets. Align mlxsw with this behavior.
Fixes: 148f472da5db ("mlxsw: reg: Add the Switch Port Acceptable Frame Types register")
Acked-by: Jiri Pirko <jiri@mellanox.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
[ Upstream commit 4729ec8c1e1145234aeeebad5d96d77f4ccbb00a ]
kvm_device->destroy() seems to be supposed to free its kvm_device
struct, but vgic_its_destroy() is not currently doing this,
resulting in a memory leak, resulting in kmemleak reports such as
the following:
unreferenced object 0xffff800aeddfe280 (size 128):
comm "qemu-system-aar", pid 13799, jiffies 4299827317 (age 1569.844s)
backtrace:
[<00000000a08b80e2>] kmem_cache_alloc+0x178/0x208
[<00000000dcad2bd3>] kvm_vm_ioctl+0x350/0xbc0
Fix it.
Cc: Andre Przywara <andre.przywara@arm.com>
Fixes: 1085fdc68c60 ("KVM: arm64: vgic-its: Introduce new KVM ITS device")
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
