The new Apalis iMX6 Mezzanine board allows access to the MIPI-CSI2
interface from the evaluation board. The current device tree has
different GPIO pin assignments for the camera reset and power pins.
Change the pin assignment to use Apalis GPIO1 for reset and Apalis
GPIO2 for power down.
Add timings for LTTD1280800101-L4WH-CT1 panel used in the new
Capacitive Touch 10.1" LVDS display.
Note that the color mapping is to be set as follows:
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
The Atmel maXTouch multitouch controller driver does not control the
reset line connected to the chip. Use a GPIO reset controller node to
release the reset line and make the controller work.
Note that both the reset controller's and the mxt mutitouch controller's
node are set to disabled. Either change this in the dtsi source or fix
this from U-Boot if you use an Atmel maXTouch multitouch controller.
setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /soc/aips-bus@02100000/i2c@021a0000/atmel_mxt_ts@4a status okay && fdt set /mxt-reset status okay'
Add support to allow configuring the display timings via
kernel command line.
e.g.:
video=mxsfb:800x480M-16@60,pixclockpol=1,outputen=1
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
(cherry picked from commit 22db6beb45cba5a67cab9e9a55cd60d7471591d9)
drivers/video/fbdev/mxsfb.c
Configure Ethernet clock source for each FEC instance individually.
This allows to use different clock source setting for the two FEC
controllers.
Exit early in case General-Purpose Registers are missing. This makes
sure that clock is always freed properly (clk_put).
Add alias for Ethernet controllers. This allows code to determine
id of controllers using of_alias_get_id.
Commit 95c163471135 ("usb: chipidea: use of extcon framework to
work for non OTG case") requires both pins to be specified (ID and
VBUS pin) to work correctly.
Fix the remaining dts.
toradex_4.9-1.0.x-imx-next
This is the 4.9.87 stable release
drivers/dma/fsl-edma.c
commit d7d824966530acfe32b94d1ed672e6fe1638cd68 upstream.
When changing a file's acl mask, btrfs_set_acl() will first set the
group bits of i_mode to the value of the mask, and only then set the
actual extended attribute representing the new acl.
If the second part fails (due to lack of space, for example) and the
file had no acl attribute to begin with, the system will from now on
assume that the mask permission bits are actual group permission bits,
potentially granting access to the wrong users.
Prevent this by restoring the original mode bits if __btrfs_set_acl
fails.
Signed-off-by: Ernesto A. Fernández <ernesto.mnd.fernandez@gmail.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
[ upstream commit d269176e766c71c998cb75b4ea8cbc321cc0019d ]
While working on 16338a9b3ac3 ("bpf, arm64: fix out of bounds access in
tail call") I noticed that ppc64 JIT is partially affected as well. While
the bound checking is correctly performed as unsigned comparison, the
register with the index value however, is never truncated into 32 bit
space, so e.g. a index value of 0x100000000ULL with a map of 1 element
would pass with PPC_CMPLW() whereas we later on continue with the full
64 bit register value. Therefore, as we do in interpreter and other JITs
truncate the value to 32 bit initially in order to fix access.
Fixes: ce0761419fae ("powerpc/bpf: Implement support for tail calls")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Reviewed-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Tested-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ upstream commit 32fff239de37ef226d5b66329dd133f64d63b22d ]
syszbot managed to trigger RCU detected stalls in
bpf_array_free_percpu()
It takes time to allocate a huge percpu map, but even more time to free
it.
Since we run in process context, use cond_resched() to yield cpu if
needed.
Fixes: a10423b87a7e ("bpf: introduce BPF_MAP_TYPE_PERCPU_ARRAY map")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ upstream commit 16338a9b3ac30740d49f5dfed81bac0ffa53b9c7 ]
I recently noticed a crash on arm64 when feeding a bogus index
into BPF tail call helper. The crash would not occur when the
interpreter is used, but only in case of JIT. Output looks as
follows:
[ 347.007486] Unable to handle kernel paging request at virtual address fffb850e96492510
[ 347.043065] [fffb850e96492510] address between user and kernel address ranges
[ 347.050205] Internal error: Oops: 96000004 [#1] SMP
[ 347.190829] x13: 0000000000000000 x12: 0000000000000000
[ 347.196128] x11: fffc047ebe782800 x10: ffff808fd7d0fd10
[ 347.201427] x9 : 0000000000000000 x8 : 0000000000000000
[ 347.206726] x7 : 0000000000000000 x6 : 001c991738000000
[ 347.212025] x5 : 0000000000000018 x4 : 000000000000ba5a
[ 347.217325] x3 : 00000000000329c4 x2 : ffff808fd7cf0500
[ 347.222625] x1 : ffff808fd7d0fc00 x0 : ffff808fd7cf0500
[ 347.227926] Process test_verifier (pid: 4548, stack limit = 0x000000007467fa61)
[ 347.235221] Call trace:
[ 347.237656] 0xffff000002f3a4fc
[ 347.240784] bpf_test_run+0x78/0xf8
[ 347.244260] bpf_prog_test_run_skb+0x148/0x230
[ 347.248694] SyS_bpf+0x77c/0x1110
[ 347.251999] el0_svc_naked+0x30/0x34
[ 347.255564] Code: 9100075a d280220a 8b0a002a d37df04b (f86b694b)
In this case the index used in BPF r3 is the same as in r1
at the time of the call, meaning we fed a pointer as index;
here, it had the value 0xffff808fd7cf0500 which sits in x2.
While I found tail calls to be working in general (also for
hitting the error cases), I noticed the following in the code
emission:
# bpftool p d j i 988
38: ldr w10, [x1,x10]
3c: cmp w2, w10
40: b.ge 0x000000000000007c <-- signed cmp
44: mov x10, #0x20 // #32
48: cmp x26, x10
4c: b.gt 0x000000000000007c
50: add x26, x26, #0x1
54: mov x10, #0x110 // #272
58: add x10, x1, x10
5c: lsl x11, x2, #3
60: ldr x11, [x10,x11] <-- faulting insn (f86b694b)
64: cbz x11, 0x000000000000007c
Meaning, the tests passed because commit ddb55992b04d ("arm64:
bpf: implement bpf_tail_call() helper") was using signed compares
instead of unsigned which as a result had the test wrongly passing.
Change this but also the tail call count test both into unsigned
and cap the index as u32. Latter we did as well in 90caccdd8cc0
("bpf: fix bpf_tail_call() x64 JIT") and is needed in addition here,
too. Tested on HiSilicon Hi1616.
Result after patch:
# bpftool p d j i 268
3c: add w2, w2, #0x0
40: cmp w2, w10
44: b.cs 0x0000000000000080
48: mov x10, #0x20 // #32
4c: cmp x26, x10
50: b.hi 0x0000000000000080
54: add x26, x26, #0x1
58: mov x10, #0x110 // #272
5c: add x10, x1, x10
60: lsl x11, x2, #3
64: ldr x11, [x10,x11]
68: cbz x11, 0x0000000000000080
Fixes: ddb55992b04d ("arm64: bpf: implement bpf_tail_call() helper")
[ upstream commit a493a87f38cfa48caaa95c9347be2d914c6fdf29 ]
Implement a retpoline [0] for the BPF tail call JIT'ing that converts
the indirect jump via jmp %rax that is used to make the long jump into
another JITed BPF image. Since this is subject to speculative execution,
we need to control the transient instruction sequence here as well
when CONFIG_RETPOLINE is set, and direct it into a pause + lfence loop.
The latter aligns also with what gcc / clang emits (e.g. [1]).
JIT dump after patch:
# bpftool p d x i 1
0: (18) r2 = map[id:1]
2: (b7) r3 = 0
3: (85) call bpf_tail_call#12
4: (b7) r0 = 2
5: (95) exit
With CONFIG_RETPOLINE:
# bpftool p d j i 1
33: cmp %edx,0x24(%rsi)
36: jbe 0x0000000000000072 |*
38: mov 0x24(%rbp),%eax
3e: cmp $0x20,%eax
41: ja 0x0000000000000072 |
43: add $0x1,%eax
46: mov %eax,0x24(%rbp)
4c: mov 0x90(%rsi,%rdx,8),%rax
54: test %rax,%rax
57: je 0x0000000000000072 |
59: mov 0x28(%rax),%rax
5d: add $0x25,%rax
61: callq 0x000000000000006d |+
66: pause |
68: lfence |
6b: jmp 0x0000000000000066 |
6d: mov %rax,(%rsp) |
71: retq |
72: mov $0x2,%eax
* relative fall-through jumps in error case
+ retpoline for indirect jump
Without CONFIG_RETPOLINE:
# bpftool p d j i 1
36: jbe 0x0000000000000063 |*
3e: cmp $0x20,%eax
41: ja 0x0000000000000063 |
43: add $0x1,%eax
54: test %rax,%rax
57: je 0x0000000000000063 |
5d: add $0x25,%rax
61: jmpq *%rax |-
63: mov $0x2,%eax
- plain indirect jump as before
[0] https://support.google.com/faqs/answer/7625886
[1] https://github.com/gcc-mirror/gcc/commit/a31e654fa107be968b802786d747e962c2fcdb2b
[ upstream commit 9c2d63b843a5c8a8d0559cc067b5398aa5ec3ffc ]
syzkaller recently triggered OOM during percpu map allocation;
while there is work in progress by Dennis Zhou to add __GFP_NORETRY
semantics for percpu allocator under pressure, there seems also a
missing bpf_map_precharge_memlock() check in array map allocation.
Given today the actual bpf_map_charge_memlock() happens after the
find_and_alloc_map() in syscall path, the bpf_map_precharge_memlock()
is there to bail out early before we go and do the map setup work
when we find that we hit the limits anyway. Therefore add this for
array map as well.
Fixes: 6c9059817432 ("bpf: pre-allocate hash map elements")
Reported-by: syzbot+adb03f3f0bb57ce3acda@syzkaller.appspotmail.com
Cc: Dennis Zhou <dennisszhou@gmail.com>
[ upstream commit a316338cb71a3260201490e615f2f6d5c0d8fb2c ]
trie_alloc() always needs to have BPF_F_NO_PREALLOC passed in via
attr->map_flags, since it does not support preallocation yet. We
check the flag, but we never copy the flag into trie->map.map_flags,
which is later on exposed into fdinfo and used by loaders such as
iproute2. Latter uses this in bpf_map_selfcheck_pinned() to test
whether a pinned map has the same spec as the one from the BPF obj
file and if not, bails out, which is currently the case for lpm
since it exposes always 0 as flags.
Also copy over flags in array_map_alloc() and stack_map_alloc().
They always have to be 0 right now, but we should make sure to not
miss to copy them over at a later point in time when we add actual
flags for them to use.
Fixes: b95a5c4db09b ("bpf: add a longest prefix match trie map implementation")
Reported-by: Jarno Rajahalme <jarno@covalent.io>
Acked-by: Alexei Starovoitov <ast@kernel.org>
commit 3968523f855050b8195134da951b87c20bd66130 upstream.
mpls_label_ok() validates that the 'platform_label' array index from a
userspace netlink message payload is valid. Under speculation the
mpls_label_ok() result may not resolve in the CPU pipeline until after
the index is used to access an array element. Sanitize the index to zero
to prevent userspace-controlled arbitrary out-of-bounds speculation, a
precursor for a speculative execution side channel vulnerability.
Cc: Eric W. Biederman <ebiederm@xmission.com>
[bwh: Backported to 4.4:
- mpls_label_ok() doesn't take an extack parameter
- Drop change in mpls_getroute()]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit b7b386f42f079b25b942c756820e36c6bd09b2ca upstream.
mpls_route_add and mpls_route_del have the same checks on the label.
Move to a helper. Avoid duplicate extack messages in the next patch.
Signed-off-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 07f2c7ab6f8d0a7e7c5764c4e6cc9c52951b9d9c ]
When SCTP makes INIT or INIT_ACK packet the total chunk length
can exceed SCTP_MAX_CHUNK_LEN which leads to kernel panic when
transmitting these packets, e.g. the crash on sending INIT_ACK:
[ 597.804948] skbuff: skb_over_panic: text:00000000ffae06e4 len:120168
put:120156 head:000000007aa47635 data:00000000d991c2de
tail:0x1d640 end:0xfec0 dev:<NULL>
[ 597.976970] ------------[ cut here ]------------
[ 598.033408] kernel BUG at net/core/skbuff.c:104!
[ 600.314841] Call Trace:
[ 600.345829] <IRQ>
[ 600.371639] ? sctp_packet_transmit+0x2095/0x26d0 [sctp]
[ 600.436934] skb_put+0x16c/0x200
[ 600.477295] sctp_packet_transmit+0x2095/0x26d0 [sctp]
[ 600.540630] ? sctp_packet_config+0x890/0x890 [sctp]
[ 600.601781] ? __sctp_packet_append_chunk+0x3b4/0xd00 [sctp]
[ 600.671356] ? sctp_cmp_addr_exact+0x3f/0x90 [sctp]
[ 600.731482] sctp_outq_flush+0x663/0x30d0 [sctp]
[ 600.788565] ? sctp_make_init+0xbf0/0xbf0 [sctp]
[ 600.845555] ? sctp_check_transmitted+0x18f0/0x18f0 [sctp]
[ 600.912945] ? sctp_outq_tail+0x631/0x9d0 [sctp]
[ 600.969936] sctp_cmd_interpreter.isra.22+0x3be1/0x5cb0 [sctp]
[ 601.041593] ? sctp_sf_do_5_1B_init+0x85f/0xc30 [sctp]
[ 601.104837] ? sctp_generate_t1_cookie_event+0x20/0x20 [sctp]
[ 601.175436] ? sctp_eat_data+0x1710/0x1710 [sctp]
[ 601.233575] sctp_do_sm+0x182/0x560 [sctp]
[ 601.284328] ? sctp_has_association+0x70/0x70 [sctp]
[ 601.345586] ? sctp_rcv+0xef4/0x32f0 [sctp]
[ 601.397478] ? sctp6_rcv+0xa/0x20 [sctp]
Here the chunk size for INIT_ACK packet becomes too big, mostly
because of the state cookie (INIT packet has large size with
many address parameters), plus additional server parameters.
Later this chunk causes the panic in skb_put_data():
skb_packet_transmit()
sctp_packet_pack()
skb_put_data(nskb, chunk->skb->data, chunk->skb->len);
'nskb' (head skb) was previously allocated with packet->size
from u16 'chunk->chunk_hdr->length'.
As suggested by Marcelo we should check the chunk's length in
_sctp_make_chunk() before trying to allocate skb for it and
discard a chunk if its size bigger than SCTP_MAX_CHUNK_LEN.
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leinter@gmail.com>
[ Upstream commit d22ffb5a712f9211ffd104c38fc17cbfb1b5e2b0 ]
If multiple IPA commands are build & sent out concurrently,
fill_ipacmd_header() may assign a seqno value to a command that's
different from what send_control_data() later assigns to this command's
reply.
This is due to other commands passing through send_control_data(),
and incrementing card->seqno.ipa along the way.
So one IPA command has no reply that's waiting for its seqno, while some
other IPA command has multiple reply objects waiting for it.
Only one of those waiting replies wins, and the other(s) times out and
triggers a recovery via send_ipa_cmd().
Fix this by making sure that the same seqno value is assigned to
a command and its reply object.
Do so immediately before submitting the command & while holding the
irq_pending "lock", to produce nicely ascending seqnos.
As a side effect, *all* IPA commands now use a reply object that's
waiting for its actual seqno. Previously, early IPA commands that were
submitted while the card was still DOWN used the "catch-all" IDX seqno.
Signed-off-by: Julian Wiedmann <jwi@linux.vnet.ibm.com>
[ Upstream commit c5c48c58b259bb8f0482398370ee539d7a12df3e ]
Current code ("qeth_l3_ip_from_hash()") matches a queried address object
against objects in the IP table by IP address, Mask/Prefix Length and
MAC address ("qeth_l3_ipaddrs_is_equal()"). But what callers actually
require is either
a) "is this IP address registered" (ie. match by IP address only),
before adding a new address.
b) or "is this address object registered" (ie. match all relevant
attributes), before deleting an address.
Right now
1. the ADD path is too strict in its lookup, and eg. doesn't detect
conflicts between an existing NORMAL address and a new VIPA address
(because the NORMAL address will have mask != 0, while VIPA has
a mask == 0),
2. the DELETE path is not strict enough, and eg. allows del_rxip() to
delete a VIPA address as long as the IP address matches.
Fix all this by adding helpers (_addr_match_ip() and _addr_match_all())
that do the appropriate checking.
Note that the ADD path for NORMAL addresses is special, as qeth keeps
track of how many times such an address is in use (and there is no
immediate way of returning errors to the caller). So when a requested
NORMAL address _fully_ matches an existing one, it's not considered a
conflict and we merely increment the refcount.
Fixes: 5f78e29ceebf ("qeth: optimize IP handling in rx_mode callback")
[ Upstream commit 14d066c3531a87f727968cacd85bd95c75f59843 ]
Registering an IPv4 address with the HW takes quite a while, so we
temporarily drop the ip_htable lock. Any concurrent add/remove of the
same IP adjusts the IP's use count, and (on remove) is then blocked by
addr->in_progress.
After the register call has completed, we check the use count for
concurrently attempted add/remove calls - and possibly straight-away
deregister the IP again. This happens via l3_delete_ip(), which
1) looks up the queried IP in the htable (getting a reference to the
*same* queried object),
2) deregisters the IP from the HW, and
3) frees the IP object.
The caller in l3_add_ip() then does a second free on the same object.
For this case, skip all the extra checks and lookups in l3_delete_ip()
and just deregister & free the IP object ourselves.
[ Upstream commit 98d823ab1fbdcb13abc25b420f9bb71bade42056 ]
If the HW is not reachable, then none of the IPs in qeth's internal
table has been registered with the HW yet. So when deleting such an IP,
there's no need to stage it for deregistration - just drop it from
the table.
This fixes the "add-delete-add" scenario on an offline card, where the
the second "add" merely increments the IP's use count. But as the IP is
still set to DISP_ADDR_DELETE from the previous "delete" step,
l3_recover_ip() won't register it with the HW when the card goes online.
[ Upstream commit 12472af89632beb1ed8dea29d4efe208ca05b06a ]
qeth_get_elements_for_range() doesn't know how to handle a 0-length
range (ie. start == end), and returns 1 when it should return 0.
Such ranges occur on TSO skbs, where the L2/L3/L4 headers (and thus all
of the skb's linear data) are skipped when mapping the skb into regular
buffer elements.
This overestimation may cause several performance-related issues:
1. sub-optimal IO buffer selection, where the next buffer gets selected
even though the skb would actually still fit into the current buffer.
2. forced linearization, if the element count for a non-linear skb
exceeds QETH_MAX_BUFFER_ELEMENTS.
Rather than modifying qeth_get_elements_for_range() and adding overhead
to every caller, fix up those callers that are in risk of passing a
0-length range.
Fixes: 2863c61334aa ("qeth: refactor calculation of SBALE count")
[ Upstream commit 1c5b2216fbb973a9410e0b06389740b5c1289171 ]
send_control_data() applies some special handling to SETIP v4 IPA
commands. But current code parses *all* command types for the SETIP
command code. Limit the command code check to IPA commands.
Fixes: 5b54e16f1a54 ("qeth: do not spin for SETIP ip assist command")
[ Upstream commit 89271c65edd599207dd982007900506283c90ae3 ]
For a memory range/skb where the last byte falls onto a page boundary
(ie. 'end' is of the form xxx...xxx001), the PFN_UP() part of the
calculation currently doesn't round up to the next PFN due to an
off-by-one error.
Thus qeth believes that the skb occupies one page less than it
actually does, and may select a IO buffer that doesn't have enough spare
buffer elements to fit all of the skb's data.
HW detects this as a malformed buffer descriptor, and raises an
exception which then triggers device recovery.
Signed-off-by: Ursula Braun <ubraun@linux.vnet.ibm.com>
[ Upstream commit 957d761cf91cdbb175ad7d8f5472336a4d54dbf2 ]
When going through the bind address list in sctp_v6_get_dst() and
the previously found address is better ('matchlen > bmatchlen'),
the code continues to the next iteration without releasing currently
held destination.
Fix it by releasing 'bdst' before continue to the next iteration, and
instead of introducing one more '!IS_ERR(bdst)' check for dst_release(),
move the already existed one right after ip6_dst_lookup_flow(), i.e. we
shouldn't proceed further if we get an error for the route lookup.
Fixes: dbc2b5e9a09e ("sctp: fix src address selection if using secondary addresses for ipv6")
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit 350c9f484bde93ef229682eedd98cd5f74350f7f ]
BBR uses tcp_tso_autosize() in an attempt to probe what would be the
burst sizes and to adjust cwnd in bbr_target_cwnd() with following
gold formula :
/* Allow enough full-sized skbs in flight to utilize end systems. */
cwnd += 3 * bbr->tso_segs_goal;
But GSO can be lacking or be constrained to very small
units (ip link set dev ... gso_max_segs 2)
What we really want is to have enough packets in flight so that both
GSO and GRO are efficient.
So in the case GSO is off or downgraded, we still want to have the same
number of packets in flight as if GSO/TSO was fully operational, so
that GRO can hopefully be working efficiently.
To fix this issue, we make tcp_tso_autosize() unaware of
sk->sk_gso_max_segs
Only tcp_tso_segs() has to enforce the gso_max_segs limit.
Tested:
ethtool -K eth0 tso off gso off
tc qd replace dev eth0 root pfifo_fast
Before patch:
for f in {1..5}; do ./super_netperf 1 -H lpaa24 -- -K bbr; done
691 (ss -temoi shows cwnd is stuck around 6 )
667
651
631
517
After patch :
# for f in {1..5}; do ./super_netperf 1 -H lpaa24 -- -K bbr; done
1733 (ss -temoi shows cwnd is around 386 )
1778
1746
1781
1718
Fixes: 0f8782ea1497 ("tcp_bbr: add BBR congestion control")
Reported-by: Oleksandr Natalenko <oleksandr@natalenko.name>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit 93c62c45ed5fad1b87e3a45835b251cd68de9c46 ]
All the kernel_sendmsg() calls in rxrpc_send_data_packet() need to send
both parts of the iov[] buffer, but one of them does not. Fix it so that
it does.
Without this, short IPv6 rxrpc DATA packets may be seen that have the rxrpc
header included, but no payload.
Fixes: 5a924b8951f8 ("rxrpc: Don't store the rxrpc header in the Tx queue sk_buffs")
Reported-by: Marc Dionne <marc.dionne@auristor.com>
[ Upstream commit 808cf9e38cd7923036a99f459ccc8cf2955e47af ]
Avoid SKB coalescing if eor bit is set in one of the relevant
SKBs.
Fixes: c134ecb87817 ("tcp: Make use of MSG_EOR in tcp_sendmsg")
Signed-off-by: Ilya Lesokhin <ilyal@mellanox.com>
[ Upstream commit 08f5138512180a479ce6b9d23b825c9f4cd3be77 ]
This condition wasn't adjusted when PHY_IGNORE_INTERRUPT (-2) was added
long ago. In case of PHY_IGNORE_INTERRUPT the MAC interrupt indicates
also PHY state changes and we should do what the symbol says.
Fixes: 84a527a41f38 ("net: phylib: fix interrupts re-enablement in phy_start")
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 0a8a1bf17e3af34f1f8d2368916a6327f8b3bfd5 ]
Until now, we assumed that in case of error when adding FDB entries, the
write operation will fail, but this is not the case. Instead, we need to
check that the number of entries reported in the response is equal to
the number of entries specified in the request.
Fixes: 56ade8fe3fe1 ("mlxsw: spectrum: Add initial support for Spectrum ASIC")
Reported-by: Ido Schimmel <idosch@mellanox.com>
Signed-off-by: Shalom Toledo <shalomt@mellanox.com>
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 4a31a6b19f9ddf498c81f5c9b089742b7472a6f8 ]
Fix dst reference count leak in sctp_v4_get_dst() introduced in commit
410f03831 ("sctp: add routing output fallback"):
When walking the address_list, successive ip_route_output_key() calls
may return the same rt->dst with the reference incremented on each call.
The code would not decrement the dst refcount when the dst pointer was
identical from the previous iteration, causing the dst refcnt leak.
Testcase:
ip netns add TEST
ip netns exec TEST ip link set lo up
ip link add dummy0 type dummy
ip link add dummy1 type dummy
ip link add dummy2 type dummy
ip link set dev dummy0 netns TEST
ip link set dev dummy1 netns TEST
ip link set dev dummy2 netns TEST
ip netns exec TEST ip addr add 192.168.1.1/24 dev dummy0
ip netns exec TEST ip link set dummy0 up
ip netns exec TEST ip addr add 192.168.1.2/24 dev dummy1
ip netns exec TEST ip link set dummy1 up
ip netns exec TEST ip addr add 192.168.1.3/24 dev dummy2
ip netns exec TEST ip link set dummy2 up
ip netns exec TEST sctp_test -H 192.168.1.2 -P 20002 -h 192.168.1.1 -p 20000 -s -B 192.168.1.3
ip netns del TEST
In 4.4 and 4.9 kernels this results to:
[ 354.179591] unregister_netdevice: waiting for lo to become free. Usage count = 1
[ 364.419674] unregister_netdevice: waiting for lo to become free. Usage count = 1
[ 374.663664] unregister_netdevice: waiting for lo to become free. Usage count = 1
[ 384.903717] unregister_netdevice: waiting for lo to become free. Usage count = 1
[ 395.143724] unregister_netdevice: waiting for lo to become free. Usage count = 1
[ 405.383645] unregister_netdevice: waiting for lo to become free. Usage count = 1
Fixes: 410f03831 ("sctp: add routing output fallback")
Fixes: 0ca50d12f ("sctp: fix src address selection if using secondary addresses")
Signed-off-by: Tommi Rantala <tommi.t.rantala@nokia.com>
[ Upstream commit 15f35d49c93f4fa9875235e7bf3e3783d2dd7a1b ]
Since UDP-Lite is always using checksum, the following path is
triggered when calculating pseudo header for it:
udp4_csum_init() or udp6_csum_init()
skb_checksum_init_zero_check()
__skb_checksum_validate_complete()
The problem can appear if skb->len is less than CHECKSUM_BREAK. In
this particular case __skb_checksum_validate_complete() also invokes
__skb_checksum_complete(skb). If UDP-Lite is using partial checksum
that covers only part of a packet, the function will return bad
checksum and the packet will be dropped.
It can be fixed if we skip skb_checksum_init_zero_check() and only
set the required pseudo header checksum for UDP-Lite with partial
checksum before udp4_csum_init()/udp6_csum_init() functions return.
Fixes: ed70fcfcee95 ("net: Call skb_checksum_init in IPv4")
Fixes: e4f45b7f40bd ("net: Call skb_checksum_init in IPv6")
[ Upstream commit 77f840e3e5f09c6d7d727e85e6e08276dd813d11 ]
PPP units don't hold any reference on the channels connected to it.
It is the channel's responsibility to ensure that it disconnects from
its unit before being destroyed.
In practice, this is ensured by ppp_unregister_channel() disconnecting
the channel from the unit before dropping a reference on the channel.
However, it is possible for an unregistered channel to connect to a PPP
unit: register a channel with ppp_register_net_channel(), attach a
/dev/ppp file to it with ioctl(PPPIOCATTCHAN), unregister the channel
with ppp_unregister_channel() and finally connect the /dev/ppp file to
a PPP unit with ioctl(PPPIOCCONNECT).
Once in this situation, the channel is only held by the /dev/ppp file,
which can be released at anytime and free the channel without letting
the parent PPP unit know. Then the ppp structure ends up with dangling
pointers in its ->channels list.
Prevent this scenario by forbidding unregistered channels from
connecting to PPP units. This maintains the code logic by keeping
ppp_unregister_channel() responsible from disconnecting the channel if
necessary and avoids modification on the reference counting mechanism.
This issue seems to predate git history (successfully reproduced on
Linux 2.6.26 and earlier PPP commits are unrelated).
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit cb9f7a9a5c96a773bbc9c70660dc600cfff82f82 ]
Nowadays, nlmsg_multicast() returns only 0 or -ESRCH but this was not the
case when commit 134e63756d5f was pushed.
However, there was no reason to stop the loop if a netns does not have
listeners.
Returns -ESRCH only if there was no listeners in all netns.
To avoid having the same problem in the future, I didn't take the
assumption that nlmsg_multicast() returns only 0 or -ESRCH.
Fixes: 134e63756d5f ("genetlink: make netns aware")
CC: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit c7272c2f1229125f74f22dcdd59de9bbd804f1c8 ]
According to RFC 1191 sections 3 and 4, ICMP frag-needed messages
indicating an MTU below 68 should be rejected:
A host MUST never reduce its estimate of the Path MTU below 68
octets.
and (talking about ICMP frag-needed's Next-Hop MTU field):
This field will never contain a value less than 68, since every
router "must be able to forward a datagram of 68 octets without
fragmentation".
Furthermore, by letting net.ipv4.route.min_pmtu be set to negative
values, we can end up with a very large PMTU when (-1) is cast into u32.
Let's also make ip_rt_min_pmtu a u32, since it's only ever compared to
unsigned ints.
Reported-by: Jianlin Shi <jishi@redhat.com>
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Reviewed-by: Stefano Brivio <sbrivio@redhat.com>
[ Upstream commit ac5b70198adc25c73fba28de4f78adcee8f6be0b ]
netif_set_real_num_tx_queues() can be called when netdev is up.
That usually happens when user requests change of number of
channels/rings with ethtool -L. The procedure for changing
the number of queues involves resetting the qdiscs and setting
dev->num_tx_queues to the new value. When the new value is
lower than the old one, extra care has to be taken to ensure
ordering of accesses to the number of queues vs qdisc reset.
Currently the queues are reset before new dev->num_tx_queues
is assigned, leaving a window of time where packets can be
enqueued onto the queues going down, leading to a likely
crash in the drivers, since most drivers don't check if TX
skbs are assigned to an active queue.
Fixes: e6484930d7c7 ("net: allocate tx queues in register_netdevice")
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
[ Upstream commit ca79bec237f5809a7c3c59bd41cd0880aa889966 ]
gcc-8 has a new warning that detects overlapping input and output arguments
in memcpy(). It triggers for sit_init_net() calling ipip6_tunnel_clone_6rd(),
which is actually correct:
net/ipv6/sit.c: In function 'sit_init_net':
net/ipv6/sit.c:192:3: error: 'memcpy' source argument is the same as destination [-Werror=restrict]
The problem here is that the logic detecting the memcpy() arguments finds them
to be the same, but the conditional that tests for the input and output of
ipip6_tunnel_clone_6rd() to be identical is not a compile-time constant.
We know that netdev_priv(t->dev) is the same as t for a tunnel device,
and comparing "dev" directly here lets the compiler figure out as well
that 'dev == sitn->fb_tunnel_dev' when called from sit_init_net(), so
it no longer warns.
This code is old, so Cc stable to make sure that we don't get the warning
for older kernels built with new gcc.
Cc: Martin Sebor <msebor@gmail.com>
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=83456
[ Upstream commit b6c3bad1ba83af1062a7ff6986d9edc4f3d7fc8e ]
Sometimes when physical lines have a just good noise to make the protocol
handshaking fail, but the carrier detect still good. Then after remove of
the noise, nobody will trigger this protocol to be start again to cause
the link to never come back. The fix is when the carrier is still on, not
terminate the protocol handshaking.
Signed-off-by: Denis Du <dudenis2000@yahoo.ca>
[ Upstream commit a8c6db1dfd1b1d18359241372bb204054f2c3174 ]
In fib_nh_match(), if output interface or gateway are passed in
the FIB configuration, we don't have to check next hops of
multipath routes to conclude whether we have a match or not.
However, we might still have routes with different realms
matching the same output interface and gateway configuration,
and this needs to cause the match to fail. Otherwise the first
route inserted in the FIB will match, regardless of the realms:
# ip route add 1.1.1.1 dev eth0 table 1234 realms 1/2
# ip route append 1.1.1.1 dev eth0 table 1234 realms 3/4
# ip route list table 1234
1.1.1.1 dev eth0 scope link realms 1/2
1.1.1.1 dev eth0 scope link realms 3/4
# ip route del 1.1.1.1 dev ens3 table 1234 realms 3/4
1.1.1.1 dev ens3 scope link realms 3/4
whereas route with realms 3/4 should have been deleted instead.
Explicitly check for fc_flow passed in the FIB configuration
(this comes from RTA_FLOW extracted by rtm_to_fib_config()) and
fail matching if it differs from nh_tclassid.
The handling of RTA_FLOW for multipath routes later in
fib_nh_match() is still needed, as we can have multiple RTA_FLOW
attributes that need to be matched against the tclassid of each
next hop.
v2: Check that fc_flow is set before discarding the match, so
that the user can still select the first matching rule by
not specifying any realm, as suggested by David Ahern.
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
Acked-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 1b12580af1d0677c3c3a19e35bfe5d59b03f737f ]
Now br_sysfs_if file flush doesn't have attr show. To read it will
cause kernel panic after users chmod u+r this file.
Xiong found this issue when running the commands:
ip link add br0 type bridge
ip link add type veth
ip link set veth0 master br0
chmod u+r /sys/devices/virtual/net/veth0/brport/flush
timeout 3 cat /sys/devices/virtual/net/veth0/brport/flush
kernel crashed with NULL a pointer dereference call trace.
This patch is to fix it by return -EINVAL when brport_attr->show
is null, just the same as the check for brport_attr->store in
brport_store().
Fixes: 9cf637473c85 ("bridge: add sysfs hook to flush forwarding table")
Reported-by: Xiong Zhou <xzhou@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
The backport of upstream commit 45d55e7bac40 ("x86/apic/vector: Fix off by
one in error path") missed to fixup the legacy interrupt data which is not
longer available upstream.
Handle legacy irq data correctly by clearing the legacy storage to prevent
use after free.
Fixes: 7fd133539289 ("x86/apic/vector: Fix off by one in error path") - 4.4.y
Fixes: c557481a9491 ("x86/apic/vector: Fix off by one in error path") - 4.9.y
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit b87b6194be631c94785fe93398651e804ed43e28 upstream.
Before, if cb->start() failed, the module reference would never be put,
because cb->cb_running is intentionally false at this point. Users are
generally annoyed by this because they can no longer unload modules that
leak references. Also, it may be possible to tediously wrap a reference
counter back to zero, especially since module.c still uses atomic_inc
instead of refcount_inc.
This patch expands the error path to simply call module_put if
cb->start() fails.
Fixes: 41c87425a1ac ("netlink: do not set cb_running if dump's start() errs")
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
commit 39772f0a7be3b3dc26c74ea13fe7847fd1522c8b upstream.
The locking protocols in md assume that a device will
never be removed from an array during resync/recovery/reshape.
When that isn't happening, rcu or reconfig_mutex is needed
to protect an rdev pointer while taking a refcount. When
it is happening, that protection isn't needed.
Unfortunately there are cases were remove_and_add_spares() is
called when recovery might be happening: is state_store(),
slot_store() and hot_remove_disk().
In each case, this is just an optimization, to try to expedite
removal from the personality so the device can be removed from
the array. If resync etc is happening, we just have to wait
for md_check_recover to find a suitable time to call
remove_and_add_spares().
This optimization and not essential so it doesn't
matter if it fails.
So change remove_and_add_spares() to abort early if
resync/recovery/reshape is happening, unless it is called
from md_check_recovery() as part of a newly started recovery.
The parameter "this" is only NULL when called from
md_check_recovery() so when it is NULL, there is no need to abort.
As this can result in a NULL dereference, the fix is suitable
for -stable.
cc: yuyufen <yuyufen@huawei.com>
Cc: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Fixes: 8430e7e0af9a ("md: disconnect device from personality before trying to remove it.")
Cc: stable@ver.kernel.org (v4.8+)
Signed-off-by: NeilBrown <neilb@suse.com>
Signed-off-by: Shaohua Li <sh.li@alibaba-inc.com>
commit 18bf3c3ea8ece8f03b6fc58508f2dfd23c7711c7 upstream.
Flush indirect branches when switching into a process that marked itself
non dumpable. This protects high value processes like gpg better,
without having too high performance overhead.
If done naïvely, we could switch to a kernel idle thread and then back
to the original process, such as:
process A -> idle -> process A
In such scenario, we do not have to do IBPB here even though the process
is non-dumpable, as we are switching back to the same process after a
hiatus.
To avoid the redundant IBPB, which is expensive, we track the last mm
user context ID. The cost is to have an extra u64 mm context id to track
the last mm we were using before switching to the init_mm used by idle.
Avoiding the extra IBPB is probably worth the extra memory for this
common scenario.
For those cases where tlb_defer_switch_to_init_mm() returns true (non
PCID), lazy tlb will defer switch to init_mm, so we will not be changing
the mm for the process A -> idle -> process A switch. So IBPB will be
skipped for this case.
Thanks to the reviewers and Andy Lutomirski for the suggestion of
using ctx_id which got rid of the problem of mm pointer recycling.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Cc: ak@linux.intel.com
Cc: karahmed@amazon.de
Cc: arjan@linux.intel.com
Cc: torvalds@linux-foundation.org
Cc: linux@dominikbrodowski.net
Cc: peterz@infradead.org
Cc: bp@alien8.de
Cc: luto@kernel.org
Cc: pbonzini@redhat.com
Link: https://lkml.kernel.org/r/1517263487-3708-1-git-send-email-dwmw@amazon.co.uk
