2018-12-27imx_thermal.c: Use old trip point values from BSP 2.7toradex_4.9-1.0.x-imx-rebasedPhilippe Schenker
In kernel upgrade from 4.1 -> 4.9 trip point values have been changed by NXP. These new values caused a lot of modules to critical shut-down during validation and verification. This commit changes the new imx_thermal.c code to use the old, well verified values. Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 308edefe57c5c96fad196b6e65fa159857e969f3)
2018-12-27ARM: dts: imx6: add missing uart transceiver enable pinmuxPhilippe Schenker
This adds the enable-pin to uart2 that controls the transceiver for uart2/4. Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 07a8f35650e711666cf42f4962792d87b3b39b09)
2018-12-27ARM: dts: imx6ull: improve can templatesMax Krummenacher
Add the pinmuxing and a inactive node for flexcan1 on SODIMM 55/63 and move the inactive flexcan modes to imx6ull-colibri-eval-v3.dtsi where they belong. Note that this commit does not enable flexcan functionality, but rather eases the effort needed to do so. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 1865142fd6a9dff221ace05fcbd704b5d86523df)
2018-12-27phy: micrel: do not use power down modeStefan Agner
Some Micrel KSZ8041NL PHY chips exhibit continous RX errors after using the power down mode bit (0.11). If the PHY is taken out of power down mode in a certain temperature range, the PHY enters a weird state which leads to continously reporting RX errors. In that state, the MAC is not able to receive or send any Ethernet frames and the activity LED is constantly blinking. Since Linux is using the suspend callback when the interface is taken down, ending up in that state can easily happen during a normal startup. Micrel confirmed the issue, caused by abnormal clock recovery when using power down mode. Even the latest revision (A4, Revision ID 0x1513) seems to suffer that problem. Remove the suspend/resume callback to avoid using the power down mode completely. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit a76182f34d2963ee5dca3bc026cbddb44b19be7c)
2018-12-27net: phy-micrel: check return code in flp center functionMax Uvarov
Fix obvious typo that first return value is set but not checked. Signed-off-by: Max Uvarov <muvarov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> (cherry picked from commit a0da456bbf95d2a9294799bb05c61bfb24736bb7) Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 5f0a65495d895df2be2ddd681662f877f1a05b7f)
2018-12-27ARM: dts: imx6ull: add sleep mode to fecPhilippe Schenker
Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit fb97f0b4043af52820cb4c2ca40fe855f8746e90)
2018-12-27Input: atmel_mxt_ts - fix reset-gpio for level based irqsSebastian Reichel
The current reset-gpio support triggers an interrupt storm on platforms using the maxtouch with level based interrupt. The Motorola Droid 4, which I used for some of the tests is not affected, since it uses a edge based interrupt. This change avoids the interrupt storm by enabling the device while its interrupt is disabled. Afterwards we wait 100ms. This is important for two reasons: The device is unresponsive for some time (~22ms for mxt224E) and the CHG (interrupt) line is not working properly for 100ms. We don't need to wait for any following interrupts, since the following mxt_initialize() checks for bootloader mode anyways. This fixes a boot issue on GE PPD (watchdog kills device due to interrupt storm) and does not cause regression on Motorola Droid 4. Fixes: f657b00df22e ("Input: atmel_mxt_ts - add support for reset line") Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Reviewed-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (cherry picked from commit ca1cd36cef00260db6b35b32d863e0c580c0488d) (cherry picked from commit 6d7ffbea51c1f314a4435065147b36159169571f)
2018-12-21tty: serial: imx: fix merge inconsistencyMarcel Ziswiler
Missing commit 688f897ddd96 ("Merge remote-tracking branch 'linux-fslc/4.9-1.0.x-imx' into toradex_4.9-1.0.x-imx-next"). Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09ARM: dts: imx6ull-colibri: reduce v_batt current in power offMax Krummenacher
Reduce the current drawn from VCC_BATT when the main power on the 3V3 pins to the module are switched off. This switches off SoC internal pull resistors which are provided on the module for TAMPER7 and TAMPER9 SoC pin and switches on a pull down instead of a pullup for the USBC_DET module pin (TAMPER2). Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09ARM: dts: imx7-colibri: disable HS400Stefan Agner
Force HS200 by masking bit 63 of the SDHCI capability register. The i.MX ESDHC driver uses SDHCI_QUIRK2_CAPS_BIT63_FOR_HS400. With that the stack checks bit 63 to descide whether HS400 is available. Using sdhci-caps-mask allows to mask bit 63. The stack then selects HS200 as operating mode. This prevents rare communication errors with minimal effect on performance: sdhci-esdhc-imx 30b60000.usdhc: warning! HS400 strobe DLL status REF not lock! Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09mmc: sdhci: Use sdhci-caps-mask and sdhci-caps to change the caps read ↵Zach Brown
during __sdhci_read_caps The sdhci capabilities register can be incorrect. The sdhci-caps-mask and sdhci-caps dt properties specify which bits of the register are incorrect and what their values should be. This patch makes the sdhci driver use those properties to correct the caps during __sdhci_read_caps. During __sdhci_read_caps Use the sdhci-caps-mask property to turn off the incorrect bits of the sdhci register after reading them. Use the sdhci-caps to turn on bits after using sdhci-caps-mask to turn off the incorrect ones. Signed-off-by: Zach Brown <zach.brown@ni.com> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit 92e0c44b92e463a47746b520ea9aa9ef154f27e7)
2018-12-09mmc: sdhci: dt: Add device tree properties sdhci-caps and sdhci-caps-maskZach Brown
On some systems the sdhci capabilty register is incorrect for one reason or another. The sdhci-caps-mask property specifies which bits in the register are incorrect and should be turned off before using sdhci-caps to turn on bits. The sdhci-caps property specifies which bits should be turned on. Signed-off-by: Zach Brown <zach.brown@ni.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit 426ad975237e880c5ecdc1b74f0a4c34b93d3e14)
2018-12-09ARM: dts: imx6: remove 1.8V regulatorStefan Agner
There is no fixed 1.8V regulator. VDDD is connected to the PMIC. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09ARM: dts: imx6ull-colibri-aster: Add support for Aster with Colibri iMX6ULLMax Krummenacher
Add support for Aster Carrier Board with Colibri iMX6ULL. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09ARM: dts: imx7-colibri: unify settings for FlexCANMax Krummenacher
The current Colibri iMX7 device tree are prepared for flexcan1 and flexcan2. However their settings are different and the integration is done to a different degree. Unify that. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09imx6ull-colibri.dtsi: change touch i2c parametersMax Krummenacher
Switch on 22 kOhm pull ups and lower the I2C frequency to around 40kHz to get a more reliable communication. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09imx6qdl-apalis.dtsi: card detect pins: use pull up and hysteresisMax Krummenacher
The apalis has a 8 and 4 bit SD/MMC interface. Switch on a 100k pull up on the card detect pins for carrier boards which leave the pin floating. Switch on hysteresis in case the signal has slow rise or fall times. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09arm: dts: correct VDDA in SGTL5000 for imx6 modules.Gerard Salvatella
On imx6 the SGTL5000 audio codec supply voltage is 3.3V and not 2.5V as might have been copied over from other modules. Output is slightly overamplified if the value is not corrected, which may lead to signal clipping. Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09ARM: dts: Coibri iMX6ULL: use wdog HW signal for resetMax Krummenacher
The i.MX6 ULL's watchdog is used to reset the SoC on reboot. The watchdog is configured to use the SoC's internal reset signal which does not generate a reset pulse on nRESET_OUT. Change the watchdog configuration to use a SoC external HW signal. This will additionally change the 'Reset cause' message from U-Boot from WDOG to POR. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09ARM: dts: imx6: mux SD/MMC CD and SPI CS explicitlyStefan Agner
Use a pinmux configuration for SD/MMC card detect and SPI chip select instead of relying on reset/boot settings. There have been no adverse effects observed, but it seems sensible to mux the pads explicitly. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09colibri-imx7: defconfig: enable sound simple card driverMax Krummenacher
The device tree got changed to use the simple card driver, so enable it in the defconfig. While at it remove the IMX_SGTL5000 driver now replaced by the simple card driver. While at it remove the unused ESAI driver. While at it remove the unused CS42XX8_I2C codec driver. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-12-09mmc: fix idx assigning for not aliased sdhci host controllersMax Krummenacher
Forward porting of 35928d6c6a to 6e9e049fa introduced a bug for host controllers which are not aliased in the device tree. Instead of instantiating the driver it fails with: sdhci-esdhc-imx 2194000.usdhc: sdhci_pltfm_init failed -12 sdhci-esdhc-imx: probe of 2194000.usdhc failed with error -12 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09dts: imx: colibri eval/iris: change pins to capacitive touch adapterMax Krummenacher
The Capacitive Touch Adapter is an interface board designed to easily connect the Capacitive Touch Display 7" Parallel to the Colibri Carrier boards which do not have PCAP connector yet available on board. Change the pins for interrupt and reset to those defined in the Capacitive Touch Adapter's datasheet. While at it remove the '#ifdef PCAP' in favour of disabled nodes. That way one can fixup the device tree in U-Boot to disable the pwm nodes and enable the connected touch controller. e.g. for a Colibri iMX6S/DL: Colibri iMX6 # setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt resize && fdt set /soc/aips-bus@02100000/i2c@021a8000/atmel_mxt_ts@4a status okay; fdt set /soc/aips-bus@02000000/pwm@02080000 status disabled; fdt set /soc/aips-bus@02000000/pwm@0208c000 status disabled' Colibri iMX6 # saveenv Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09dts: imx: fix M41T0 RTC compatible stringGerard Salvatella
Toradex Carrier boards use the ST M41T0 RTC (not M41T00). The RTC is almost the same, but the M41T0 needs some special handling in case the oscillator fails. Now that support for this difference is available, using the new compatible string to make use of it. Sync with commit 10e718b1c60c4e490e6972cfa58e97fcf5260685 Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09dts: add can-spi controllerGerard Salvatella
Synced with 558d378d522189ad68fcb00aff05fd134bf20924 Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09dts: update/add atmel mxtGerard Salvatella
Add mxt nodes to dts and gpio-reset functionality. Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09dts: enable hdmi also on asterGerard Salvatella
2018-12-09dts: synchronize snvs node pathGerard Salvatella
Synchronize with commit fcfdb9c32075501e64751cc6a79fd91d15933692 Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09Input: atmel_mxt_ts - add support for reset lineSebastian Reichel
Provide support for controlling reset pin. If this is not driven correctly the device will be held in reset and will not respond. Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (cherry picked from commit f657b00df22e231da217ca0162a75db452475e8f) Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
2018-12-09Input: atmel_mxt_ts - use more managed resourcesSebastian Reichel
Switch mxt_data and interrupt to resource managed allocation methods, which cleans up the driver slightly and prepares for adding reset GPIO support. Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (cherry picked from commit 8cc8446b9b62ef954b630ed30e53bd1553e916a6) Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
2018-12-09drivers/firmware: Expose psci_get_version through psci_ops structureWill Deacon
Entry into recent versions of ARM Trusted Firmware will invalidate the CPU branch predictor state in order to protect against aliasing attacks. This patch exposes the PSCI "VERSION" function via psci_ops, so that it can be invoked outside of the PSCI driver where necessary. Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> (cherry picked commit from a6df699da786079b7e2249df3f3211be7862f0e1) Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
2018-12-09arm: Invalidate BTB on prefetch abort outside of user mapping on Cortex A8, ↵Marc Zyngier
A9, A12 and A17 In order to prevent aliasing attacks on the branch predictor, invalidate the BTB on CPUs that are known to be affected when taking a prefetch abort on a address that is outside of a user task limit. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> (cherry picked from commit a07373c8c365746583f25f49fee41b1bc0ff94b2) Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
2018-12-09arm: Add BTB invalidation on switch_mm for Cortex-A9, A12 and A17Marc Zyngier
In order to avoid aliasing attacks against the branch predictor, some implementations require to invalidate the BTB when switching from one user context to another. For this, we reuse the existing implementation for Cortex-A8, and apply it to A9, A12 and A17. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> (cherry picked commit from efcd0e857a656bbd1c1da15ff984ad6402332c61) [jason: adapted to 4.9] Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
2018-12-09ARM: dts: imx7-colibri: prepare module device tree for FlexCANStefan Agner
Prepare FlexCAN use on SODIMM 55/63. Those SODIMM pins are compatible for CAN bus use with several modules from the Colibri family. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09ARM: dts: imx6qdl: Fix SPDIF regressionFabio Estevam
Commit 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif") changed many more clocks than only the SPDIF core clock as stated in the commit message. The MLB clock has been added and this causes SPDIF regression as reported by Xavi Drudis Ferran and also in this forum post: https://forum.digikey.com/thread/34240 The MX6Q Reference Manual does not mention that MLB is a clock related to SPDIF, so change it back to a dummy clock to restore SPDIF functionality. Thanks to Ambika for providing the fix at: https://community.nxp.com/thread/387131 Fixes: 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif") Cc: <stable@vger.kernel.org> # 4.4.x Reported-by: Xavi Drudis Ferran <xdrudis@tinet.cat> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Xavi Drudis Ferran <xdrudis@tinet.cat> Signed-off-by: Shawn Guo <shawnguo@kernel.org> (cherry picked from commit f065e9e4addd75c21bb976bb2558648bf4f61de6) This fix was correct, but overwritten by commit 833f2cbf7091099baee28136dc68678e974c0ac5. MLB (Media Local Bus) Clock is in fact not related to SPDIF according to the MX6Q Reference Manual. Tested playback and record on pulseaudio with 44.1kHz samples. Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09arm: imx: gpc: do not poweroff M/F mix in suspendMax Krummenacher
The Colibri iMX6ULL 256MB crashes in resume if the M/F mix domain is powered down when suspending. With this workaround this does not happen. Crash looks as follows: root@colibri-imx6ull:~# echo +3 > /sys/class/rtc/rtc1/wakealarm; echo mem > /sys/power/state [ 52.800741] PM: Syncing filesystems ... done. [ 52.856715] Freezing user space processes ... (elapsed 0.001 seconds) done. [ 52.865669] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done. [ 52.875024] Suspending console(s) (use no_console_suspend to debug) [ 52.950638] PM: suspend of devices complete after 68.211 msecs [ 52.952506] PM: late suspend of devices complete after 1.835 msecs [ 52.954292] PM: noirq suspend of devices complete after 1.757 msecs [ 52.954300] Disabling non-boot CPUs ... [ 52.954307] Turn off M/F mix! [ 52.955663] PM: noirq resume of devices complete after 1.222 msecs [ 52.956767] imx-sdma 20ec000.sdma: loaded firmware 3.3 [ 52.957669] PM: early resume of devices complete after 1.411 msecs [ 52.959140] gpmi-nand 1806000.gpmi-nand: use legacy bch geometry [ 53.005653] Suspended for 2.907 seconds [ 53.012207] PM: resume of devices complete after 54.507 msecs [ 53.073751] Restarting tasks ... done. root@colibri-imx6ull:~# [ 55.049753] gpmi-nand 1806000.gpmi-nand: DMA timeout, last DMA :2 [ 55.056377] gpmi-nand 1806000.gpmi-nand: Show GPMI registers : [ 55.062835] gpmi-nand 1806000.gpmi-nand: offset 0x000 : 0x00000000 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09ARM: dts: imx: fix PCI bus dtc warningsRob Herring
dtc recently added PCI bus checks. Fix these warnings. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org> (cherry picked from commit 3e1b857786f0d46a92b3a4d7878767883ed90bdc)
2018-12-09Revert "PCI: Do not allocate more buses than available in parent"Marcel Ziswiler
This reverts commit 9a4bf05126f42c2632729ab0da503021d74ed454. With this commit the PCIe enumaration fails. A follow up commit further addresses the issue. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09ARM: dts: imx6: add required RS-485 propertiesStefan Agner
To operate RS-485 on Toradex Carrier Boards a low active RTS signal is required. Furthermore, a low active RTS signal requires the receiver to be active (this seems to be a hardware limitation of the i.MX UART). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09serial: imx: add RS-485 device tree propertiesStefan Agner
Add device tree properties to influence RTS polarity and whether the receiver is enabled during transmission (rs485-rts-active-low, rs485-rx-during-tx). This aligns with behavior with upstream Linux, where RTS is active high by default (SER_RS485_RTS_AFTER_SEND) and the receiver is disabled by default when using RS485 (SER_RS485_RX_DURING_TX). Note that for Toradex hardware both properties are required, hence using RS-485 on Toradex Carrier Boards requires the following properties being specified in the device tree: linux,rs485-enabled-at-boot-time; rs485-rts-active-low; rs485-rx-during-tx; Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-12-09rpmsg: imx: Disable character echoing by defaultAndri Schmidt
Signed-off-by: Andri Schmidt <a.schmidt@scewo.ch> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2018-12-09pci-imx6.c: address compiler warningMax Krummenacher
pci-imx6.c:303:20: warning: unused variable 'pp' [-Wunused-variable] Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09mmc: sdhci: Always allow tuning to fall back to fixed samplingAdrian Hunter
SDHCI falls back to fixed sampling if there is an error during tuning. However it also reports an error unless there is periodic re-tuning. That is not the best option because: a) there is a reasonable chance that fixed sampling will work, especially at room temperature. b) re-tuning will be done again anyway if there are CRC errors. Change to return no error always when falling back to fixed sampling. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit 0760c355525c08dd598e86edb2a310688ac8af4c)
2018-12-09Revert "MLK-14498-2 ARM: imx7d: clk: select uart clock parent and rate"Stefan Agner
This seems to limit possible baud rates due to lower input clock. Since Toradex modules do not use UART5/6 as console, do not set clock explicitly. This reverts commit 4f447cb8bccb1d40973e46478d7b11aa61961c90. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09Revert "MLK-15120 ARM: imx7d: clk: select uart3 clock parent and set rate"Stefan Agner
This seems to limit possible baud rates due to lower input clock. Since Toradex modules do not use UART3 as console, do not set clock explicitly. This reverts commit 89869792e2f59c81354f9a53280c4eb6e95f4a9a. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09ARM: dts: imx6ull-colibri-eval-v3: remove duplicate nodesStefan Agner
Remove duplicate nodes introduced with the move to L4.9.11 release. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09arm: dts: apalis imx6: fix mipi-csi2 gpio assignmentMax Krummenacher
The new Apalis iMX6 Mezzanine board allows access to the MIPI-CSI2 interface from the evaluation board. The current device tree has different GPIO pin assignments for the camera reset and power pins. Change the pin assignment to use Apalis GPIO1 for reset and Apalis GPIO2 for power down. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09arm: dts: apalis imx6: add timings for new 10 inch lvdsMax Krummenacher
Add timings for LTTD1280800101-L4WH-CT1 panel used in the new Capacitive Touch 10.1" LVDS display. Note that the color mapping is to be set as follows: fsl,data-mapping = "spwg"; fsl,data-width = <24>; Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09arm: dts: apalis imx6: add reset controller for atmel mxt multitouchMax Krummenacher
The Atmel maXTouch multitouch controller driver does not control the reset line connected to the chip. Use a GPIO reset controller node to release the reset line and make the controller work. Note that both the reset controller's and the mxt mutitouch controller's node are set to disabled. Either change this in the dtsi source or fix this from U-Boot if you use an Atmel maXTouch multitouch controller. setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /soc/aips-bus@02100000/i2c@021a0000/atmel_mxt_ts@4a status okay && fdt set /mxt-reset status okay' Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-12-09video: fbdev: mxsfb: allow setting display timings via kernel command lineBhuvanchandra DV
Add support to allow configuring the display timings via kernel command line. e.g.: video=mxsfb:800x480M-16@60,pixclockpol=1,outputen=1 Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 22db6beb45cba5a67cab9e9a55cd60d7471591d9) Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: drivers/video/fbdev/mxsfb.c
