2021-11-04Merge tag 'v4.4.291' into toradex_vf_4.4-nexttoradex_vf_4.4-nexttoradex_vf_4.4Max Krummenacher
This is the 4.4.291 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-11-02Linux 4.4.291Greg Kroah-Hartman
Link: https://lore.kernel.org/r/20211101082440.664392327@linuxfoundation.org Tested-by: Jon Hunter <jonathanh@nvidia.com> Tested-by: Shuah Khan <skhan@linuxfoundation.org> Tested-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Linux Kernel Functional Testing <lkft@linaro.org> Tested-by: Pavel Machek (CIP) <pavel@denx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02sctp: add vtag check in sctp_sf_violationXin Long
[ Upstream commit aa0f697e45286a6b5f0ceca9418acf54b9099d99 ] sctp_sf_violation() is called when processing HEARTBEAT_ACK chunk in cookie_wait state, and some other places are also using it. The vtag in the chunk's sctphdr should be verified, otherwise, as later in chunk length check, it may send abort with the existent asoc's vtag, which can be exploited by one to cook a malicious chunk to terminate a SCTP asoc. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-11-02sctp: use init_tag from inithdr for ABORT chunkXin Long
[ Upstream commit 4f7019c7eb33967eb87766e0e4602b5576873680 ] Currently Linux SCTP uses the verification tag of the existing SCTP asoc when failing to process and sending the packet with the ABORT chunk. This will result in the peer accepting the ABORT chunk and removing the SCTP asoc. One could exploit this to terminate a SCTP asoc. This patch is to fix it by always using the initiate tag of the received INIT chunk for the ABORT chunk to be sent. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-11-02nios2: Make NIOS2_DTB_SOURCE_BOOL depend on !COMPILE_TESTGuenter Roeck
commit 4a089e95b4d6bb625044d47aed0c442a8f7bd093 upstream. nios2:allmodconfig builds fail with make[1]: *** No rule to make target 'arch/nios2/boot/dts/""', needed by 'arch/nios2/boot/dts/built-in.a'. Stop. make: [Makefile:1868: arch/nios2/boot/dts] Error 2 (ignored) This is seen with compile tests since those enable NIOS2_DTB_SOURCE_BOOL, which in turn enables NIOS2_DTB_SOURCE. This causes the build error because the default value for NIOS2_DTB_SOURCE is an empty string. Disable NIOS2_DTB_SOURCE_BOOL for compile tests to avoid the error. Fixes: 2fc8483fdcde ("nios2: Build infrastructure") Signed-off-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02regmap: Fix possible double-free in regcache_rbtree_exit()Yang Yingliang
commit 55e6d8037805b3400096d621091dfbf713f97e83 upstream. In regcache_rbtree_insert_to_block(), when 'present' realloc failed, the 'blk' which is supposed to assign to 'rbnode->block' will be freed, so 'rbnode->block' points a freed memory, in the error handling path of regcache_rbtree_init(), 'rbnode->block' will be freed again in regcache_rbtree_exit(), KASAN will report double-free as follows: BUG: KASAN: double-free or invalid-free in kfree+0xce/0x390 Call Trace: slab_free_freelist_hook+0x10d/0x240 kfree+0xce/0x390 regcache_rbtree_exit+0x15d/0x1a0 regcache_rbtree_init+0x224/0x2c0 regcache_init+0x88d/0x1310 __regmap_init+0x3151/0x4a80 __devm_regmap_init+0x7d/0x100 madera_spi_probe+0x10f/0x333 [madera_spi] spi_probe+0x183/0x210 really_probe+0x285/0xc30 To fix this, moving up the assignment of rbnode->block to immediately after the reallocation has succeeded so that the data structure stays valid even if the second reallocation fails. Reported-by: Hulk Robot <hulkci@huawei.com> Fixes: 3f4ff561bc88b ("regmap: rbtree: Make cache_present bitmap per node") Signed-off-by: Yang Yingliang <yangyingliang@huawei.com> Link: https://lore.kernel.org/r/20211012023735.1632786-1-yangyingliang@huawei.com Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02net: lan78xx: fix division by zero in send pathJohan Hovold
commit db6c3c064f5d55fa9969f33eafca3cdbefbb3541 upstream. Add the missing endpoint max-packet sanity check to probe() to avoid division by zero in lan78xx_tx_bh() in case a malicious device has broken descriptors (or when doing descriptor fuzz testing). Note that USB core will reject URBs submitted for endpoints with zero wMaxPacketSize but that drivers doing packet-size calculations still need to handle this (cf. commit 2548288b4fb0 ("USB: Fix: Don't skip endpoint descriptors with maxpacket=0")). Fixes: 55d7de9de6c3 ("Microchip's LAN7800 family USB 2/3 to 10/100/1000 Ethernet device driver") Cc: stable@vger.kernel.org # 4.3 Cc: Woojung.Huh@microchip.com <Woojung.Huh@microchip.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02mmc: sdhci: Map more voltage level to SDHCI_POWER_330Shawn Guo
commit 4217d07b9fb328751f877d3bd9550122014860a2 upstream. On Thundercomm TurboX CM2290, the eMMC OCR reports vdd = 23 (3.5 ~ 3.6 V), which is being treated as an invalid value by sdhci_set_power_noreg(). And thus eMMC is totally broken on the platform. [ 1.436599] ------------[ cut here ]------------ [ 1.436606] mmc0: Invalid vdd 0x17 [ 1.436640] WARNING: CPU: 2 PID: 69 at drivers/mmc/host/sdhci.c:2048 sdhci_set_power_noreg+0x168/0x2b4 [ 1.436655] Modules linked in: [ 1.436662] CPU: 2 PID: 69 Comm: kworker/u8:1 Tainted: G W 5.15.0-rc1+ #137 [ 1.436669] Hardware name: Thundercomm TurboX CM2290 (DT) [ 1.436674] Workqueue: events_unbound async_run_entry_fn [ 1.436685] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 1.436692] pc : sdhci_set_power_noreg+0x168/0x2b4 [ 1.436698] lr : sdhci_set_power_noreg+0x168/0x2b4 [ 1.436703] sp : ffff800010803a60 [ 1.436705] x29: ffff800010803a60 x28: ffff6a9102465f00 x27: ffff6a9101720a70 [ 1.436715] x26: ffff6a91014de1c0 x25: ffff6a91014de010 x24: ffff6a91016af280 [ 1.436724] x23: ffffaf7b1b276640 x22: 0000000000000000 x21: ffff6a9101720000 [ 1.436733] x20: ffff6a9101720370 x19: ffff6a9101720580 x18: 0000000000000020 [ 1.436743] x17: 0000000000000000 x16: 0000000000000004 x15: ffffffffffffffff [ 1.436751] x14: 0000000000000000 x13: 00000000fffffffd x12: ffffaf7b1b84b0bc [ 1.436760] x11: ffffaf7b1b720d10 x10: 000000000000000a x9 : ffff800010803a60 [ 1.436769] x8 : 000000000000000a x7 : 000000000000000f x6 : 00000000fffff159 [ 1.436778] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 00000000ffffffff [ 1.436787] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff6a9101718d80 [ 1.436797] Call trace: [ 1.436800] sdhci_set_power_noreg+0x168/0x2b4 [ 1.436805] sdhci_set_ios+0xa0/0x7fc [ 1.436811] mmc_power_up.part.0+0xc4/0x164 [ 1.436818] mmc_start_host+0xa0/0xb0 [ 1.436824] mmc_add_host+0x60/0x90 [ 1.436830] __sdhci_add_host+0x174/0x330 [ 1.436836] sdhci_msm_probe+0x7c0/0x920 [ 1.436842] platform_probe+0x68/0xe0 [ 1.436850] really_probe.part.0+0x9c/0x31c [ 1.436857] __driver_probe_device+0x98/0x144 [ 1.436863] driver_probe_device+0xc8/0x15c [ 1.436869] __device_attach_driver+0xb4/0x120 [ 1.436875] bus_for_each_drv+0x78/0xd0 [ 1.436881] __device_attach_async_helper+0xac/0xd0 [ 1.436888] async_run_entry_fn+0x34/0x110 [ 1.436895] process_one_work+0x1d0/0x354 [ 1.436903] worker_thread+0x13c/0x470 [ 1.436910] kthread+0x150/0x160 [ 1.436915] ret_from_fork+0x10/0x20 [ 1.436923] ---[ end trace fcfac44cb045c3a8 ]--- Fix the issue by mapping MMC_VDD_35_36 (and MMC_VDD_34_35) to SDHCI_POWER_330 as well. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@vger.kernel.org Link: https://lore.kernel.org/r/20211004024935.15326-1-shawn.guo@linaro.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02mmc: dw_mmc: exynos: fix the finding clock sample valueJaehoon Chung
commit 697542bceae51f7620af333b065dd09d213629fb upstream. Even though there are candiates value if can't find best value, it's returned -EIO. It's not proper behavior. If there is not best value, use a first candiate value to work eMMC. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Christian Hewitt <christianshewitt@gmail.com> Cc: stable@vger.kernel.org Fixes: c537a1c5ff63 ("mmc: dw_mmc: exynos: add variable delay tuning sequence") Link: https://lore.kernel.org/r/20211022082106.1557-1-jh80.chung@samsung.com Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02mmc: vub300: fix control-message timeoutsJohan Hovold
commit 8c8171929116cc23f74743d99251eedadf62341a upstream. USB control-message timeouts are specified in milliseconds and should specifically not vary with CONFIG_HZ. Fixes: 88095e7b473a ("mmc: Add new VUB300 USB-to-SD/SDIO/MMC driver") Cc: stable@vger.kernel.org # 3.0 Signed-off-by: Johan Hovold <johan@kernel.org> Link: https://lore.kernel.org/r/20211025115608.5287-1-johan@kernel.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02Revert "net: mdiobus: Fix memory leak in __mdiobus_register"Pavel Skripkin
commit 10eff1f5788b6ffac212c254e2f3666219576889 upstream. This reverts commit ab609f25d19858513919369ff3d9a63c02cd9e2e. This patch is correct in the sense that we _should_ call device_put() in case of device_register() failure, but the problem in this code is more vast. We need to set bus->state to UNMDIOBUS_REGISTERED before calling device_register() to correctly release the device in mdiobus_free(). This patch prevents us from doing it, since in case of device_register() failure put_device() will be called 2 times and it will cause UAF or something else. Also, Reported-by: tag in revered commit was wrong, since syzbot reported different leak in same function. Link: https://lore.kernel.org/netdev/20210928092657.GI2048@kadam/ Acked-by: Yanfei Xu <yanfei.xu@windriver.com> Signed-off-by: Pavel Skripkin <paskripkin@gmail.com> Link: https://lore.kernel.org/r/f12fb1faa4eccf0f355788225335eb4309ff2599.1633024062.git.paskripkin@gmail.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02nfc: port100: fix using -ERRNO as command type maskKrzysztof Kozlowski
commit 2195f2062e4cc93870da8e71c318ef98a1c51cef upstream. During probing, the driver tries to get a list (mask) of supported command types in port100_get_command_type_mask() function. The value is u64 and 0 is treated as invalid mask (no commands supported). The function however returns also -ERRNO as u64 which will be interpret as valid command mask. Return 0 on every error case of port100_get_command_type_mask(), so the probing will stop. Cc: <stable@vger.kernel.org> Fixes: 0347a6ab300a ("NFC: port100: Commands mechanism implementation") Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02ata: sata_mv: Fix the error handling of mv_chip_id()Zheyu Ma
commit a0023bb9dd9bc439d44604eeec62426a990054cd upstream. mv_init_host() propagates the value returned by mv_chip_id() which in turn gets propagated by mv_pci_init_one() and hits local_pci_probe(). During the process of driver probing, the probe function should return < 0 for failure, otherwise, the kernel will treat value > 0 as success. Since this is a bug rather than a recoverable runtime error we should use dev_alert() instead of dev_err(). Signed-off-by: Zheyu Ma <zheyuma97@gmail.com> Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02usbnet: fix error return code in usbnet_probe()Wang Hai
commit 6f7c88691191e6c52ef2543d6f1da8d360b27a24 upstream. Return error code if usb_maxpacket() returns 0 in usbnet_probe() Fixes: 397430b50a36 ("usbnet: sanity check for maxpacket") Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: Wang Hai <wanghai38@huawei.com> Reviewed-by: Johan Hovold <johan@kernel.org> Link: https://lore.kernel.org/r/20211026124015.3025136-1-wanghai38@huawei.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02usbnet: sanity check for maxpacketOliver Neukum
commit 397430b50a363d8b7bdda00522123f82df6adc5e upstream. maxpacket of 0 makes no sense and oopses as we need to divide by it. Give up. V2: fixed typo in log and stylistic issues Signed-off-by: Oliver Neukum <oneukum@suse.com> Reported-by: syzbot+76bb1d34ffa0adc03baa@syzkaller.appspotmail.com Reviewed-by: Johan Hovold <johan@kernel.org> Link: https://lore.kernel.org/r/20211021122944.21816-1-oneukum@suse.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02ARM: 8819/1: Remove '-p' from LDFLAGSNathan Chancellor
commit 091bb549f7722723b284f63ac665e2aedcf9dec9 upstream. This option is not supported by lld: ld.lld: error: unknown argument: -p This has been a no-op in binutils since 2004 (see commit dea514f51da1 in that tree). Given that the lowest officially supported of binutils for the kernel is 2.20, which was released in 2009, nobody needs this flag around so just remove it. Commit 1a381d4a0a9a ("arm64: remove no-op -p linker flag") did the same for arm64. Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Nick Desaulniers <ndesaulniers@google.com> Reviewed-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02ARM: 9139/1: kprobes: fix arch_init_kprobes() prototypeArnd Bergmann
commit 1f323127cab086e4fd618981b1e5edc396eaf0f4 upstream. With extra warnings enabled, gcc complains about this function definition: arch/arm/probes/kprobes/core.c: In function 'arch_init_kprobes': arch/arm/probes/kprobes/core.c:465:12: warning: old-style function definition [-Wold-style-definition] 465 | int __init arch_init_kprobes() Link: https://lore.kernel.org/all/20201027093057.c685a14b386acacb3c449e3d@kernel.org/ Fixes: 24ba613c9d6c ("ARM kprobes: core code") Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King (Oracle) <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02ARM: 9134/1: remove duplicate memcpy() definitionArnd Bergmann
commit eaf6cc7165c9c5aa3c2f9faa03a98598123d0afb upstream. Both the decompressor code and the kasan logic try to override the memcpy() and memmove() definitions, which leading to a clash in a KASAN-enabled kernel with XZ decompression: arch/arm/boot/compressed/decompress.c:50:9: error: 'memmove' macro redefined [-Werror,-Wmacro-redefined] #define memmove memmove ^ arch/arm/include/asm/string.h:59:9: note: previous definition is here #define memmove(dst, src, len) __memmove(dst, src, len) ^ arch/arm/boot/compressed/decompress.c:51:9: error: 'memcpy' macro redefined [-Werror,-Wmacro-redefined] #define memcpy memcpy ^ arch/arm/include/asm/string.h:58:9: note: previous definition is here #define memcpy(dst, src, len) __memcpy(dst, src, len) ^ Here we want the set of functions from the decompressor, so undefine the other macros before the override. Link: https://lore.kernel.org/linux-arm-kernel/CACRpkdZYJogU_SN3H9oeVq=zJkRgRT1gDz3xp59gdqWXxw-B=w@mail.gmail.com/ Link: https://lore.kernel.org/lkml/202105091112.F5rmd4By-lkp@intel.com/ Fixes: d6d51a96c7d6 ("ARM: 9014/2: Replace string mem* functions for KASan") Fixes: a7f464f3db93 ("ARM: 7001/2: Wire up support for the XZ decompressor") Reported-by: kernel test robot <lkp@intel.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King (Oracle) <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02ARM: 9133/1: mm: proc-macros: ensure *_tlb_fns are 4B alignedNick Desaulniers
commit e6a0c958bdf9b2e1b57501fc9433a461f0a6aadd upstream. A kernel built with CONFIG_THUMB2_KERNEL=y and using clang as the assembler could generate non-naturally-aligned v7wbi_tlb_fns which results in a boot failure. The original commit adding the macro missed the .align directive on this data. Link: https://github.com/ClangBuiltLinux/linux/issues/1447 Link: https://lore.kernel.org/all/0699da7b-354f-aecc-a62f-e25693209af4@linaro.org/ Debugged-by: Ard Biesheuvel <ardb@kernel.org> Debugged-by: Nathan Chancellor <nathan@kernel.org> Debugged-by: Richard Henderson <richard.henderson@linaro.org> Fixes: 66a625a88174 ("ARM: mm: proc-macros: Add generic proc/cache/tlb struct definition macros") Suggested-by: Ard Biesheuvel <ardb@kernel.org> Acked-by: Ard Biesheuvel <ardb@kernel.org> Signed-off-by: Nick Desaulniers <ndesaulniers@google.com> Tested-by: Nathan Chancellor <nathan@kernel.org> Signed-off-by: Russell King (Oracle) <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27Linux 4.4.290Greg Kroah-Hartman
Link: https://lore.kernel.org/r/20211025190928.054676643@linuxfoundation.org Tested-by: Pavel Machek (CIP) <pavel@denx.de> Tested-by: Linux Kernel Functional Testing <lkft@linaro.org> Tested-by: Shuah Khan <skhan@linuxfoundation.org> Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27ARM: 9122/1: select HAVE_FUTEX_CMPXCHGNick Desaulniers
commit 9d417cbe36eee7afdd85c2e871685f8dab7c2dba upstream. tglx notes: This function [futex_detect_cmpxchg] is only needed when an architecture has to runtime discover whether the CPU supports it or not. ARM has unconditional support for this, so the obvious thing to do is the below. Fixes linkage failure from Clang randconfigs: kernel/futex.o:(.text.fixup+0x5c): relocation truncated to fit: R_ARM_JUMP24 against `.init.text' and boot failures for CONFIG_THUMB2_KERNEL. Link: https://github.com/ClangBuiltLinux/linux/issues/325 Comments from Nick Desaulniers: See-also: 03b8c7b623c8 ("futex: Allow architectures to skip futex_atomic_cmpxchg_inatomic() test") Reported-by: Arnd Bergmann <arnd@arndb.de> Reported-by: Nathan Chancellor <nathan@kernel.org> Suggested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Nick Desaulniers <ndesaulniers@google.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Nathan Chancellor <nathan@kernel.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Cc: stable@vger.kernel.org # v3.14+ Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King (Oracle) <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27tracing: Have all levels of checks prevent recursionSteven Rostedt (VMware)
commit ed65df63a39a3f6ed04f7258de8b6789e5021c18 upstream. While writing an email explaining the "bit = 0" logic for a discussion on making ftrace_test_recursion_trylock() disable preemption, I discovered a path that makes the "not do the logic if bit is zero" unsafe. The recursion logic is done in hot paths like the function tracer. Thus, any code executed causes noticeable overhead. Thus, tricks are done to try to limit the amount of code executed. This included the recursion testing logic. Having recursion testing is important, as there are many paths that can end up in an infinite recursion cycle when tracing every function in the kernel. Thus protection is needed to prevent that from happening. Because it is OK to recurse due to different running context levels (e.g. an interrupt preempts a trace, and then a trace occurs in the interrupt handler), a set of bits are used to know which context one is in (normal, softirq, irq and NMI). If a recursion occurs in the same level, it is prevented*. Then there are infrastructure levels of recursion as well. When more than one callback is attached to the same function to trace, it calls a loop function to iterate over all the callbacks. Both the callbacks and the loop function have recursion protection. The callbacks use the "ftrace_test_recursion_trylock()" which has a "function" set of context bits to test, and the loop function calls the internal trace_test_and_set_recursion() directly, with an "internal" set of bits. If an architecture does not implement all the features supported by ftrace then the callbacks are never called directly, and the loop function is called instead, which will implement the features of ftrace. Since both the loop function and the callbacks do recursion protection, it was seemed unnecessary to do it in both locations. Thus, a trick was made to have the internal set of recursion bits at a more significant bit location than the function bits. Then, if any of the higher bits were set, the logic of the function bits could be skipped, as any new recursion would first have to go through the loop function. This is true for architectures that do not support all the ftrace features, because all functions being traced must first go through the loop function before going to the callbacks. But this is not true for architectures that support all the ftrace features. That's because the loop function could be called due to two callbacks attached to the same function, but then a recursion function inside the callback could be called that does not share any other callback, and it will be called directly. i.e. traced_function_1: [ more than one callback tracing it ] call loop_func loop_func: trace_recursion set internal bit call callback callback: trace_recursion [ skipped because internal bit is set, return 0 ] call traced_function_2 traced_function_2: [ only traced by above callback ] call callback callback: trace_recursion [ skipped because internal bit is set, return 0 ] call traced_function_2 [ wash, rinse, repeat, BOOM! out of shampoo! ] Thus, the "bit == 0 skip" trick is not safe, unless the loop function is call for all functions. Since we want to encourage architectures to implement all ftrace features, having them slow down due to this extra logic may encourage the maintainers to update to the latest ftrace features. And because this logic is only safe for them, remove it completely. [*] There is on layer of recursion that is allowed, and that is to allow for the transition between interrupt context (normal -> softirq -> irq -> NMI), because a trace may occur before the context update is visible to the trace recursion logic. Link: https://lore.kernel.org/all/609b565a-ed6e-a1da-f025-166691b5d994@linux.alibaba.com/ Link: https://lkml.kernel.org/r/20211018154412.09fcad3c@gandalf.local.home Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <James.Bottomley@hansenpartnership.com> Cc: Helge Deller <deller@gmx.de> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Walmsley <paul.walmsley@sifive.com> Cc: Palmer Dabbelt <palmer@dabbelt.com> Cc: Albert Ou <aou@eecs.berkeley.edu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Borislav Petkov <bp@alien8.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Jiri Kosina <jikos@kernel.org> Cc: Miroslav Benes <mbenes@suse.cz> Cc: Joe Lawrence <joe.lawrence@redhat.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Jisheng Zhang <jszhang@kernel.org> Cc: =?utf-8?b?546L6LSH?= <yun.wang@linux.alibaba.com> Cc: Guo Ren <guoren@kernel.org> Cc: stable@vger.kernel.org Fixes: edc15cafcbfa3 ("tracing: Avoid unnecessary multiple recursion checks") Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27net: mdiobus: Fix memory leak in __mdiobus_registerYanfei Xu
commit ab609f25d19858513919369ff3d9a63c02cd9e2e upstream. Once device_register() failed, we should call put_device() to decrement reference count for cleanup. Or it will cause memory leak. BUG: memory leak unreferenced object 0xffff888114032e00 (size 256): comm "kworker/1:3", pid 2960, jiffies 4294943572 (age 15.920s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 08 2e 03 14 81 88 ff ff ................ 08 2e 03 14 81 88 ff ff 90 76 65 82 ff ff ff ff .........ve..... backtrace: [<ffffffff8265cfab>] kmalloc include/linux/slab.h:591 [inline] [<ffffffff8265cfab>] kzalloc include/linux/slab.h:721 [inline] [<ffffffff8265cfab>] device_private_init drivers/base/core.c:3203 [inline] [<ffffffff8265cfab>] device_add+0x89b/0xdf0 drivers/base/core.c:3253 [<ffffffff828dd643>] __mdiobus_register+0xc3/0x450 drivers/net/phy/mdio_bus.c:537 [<ffffffff828cb835>] __devm_mdiobus_register+0x75/0xf0 drivers/net/phy/mdio_devres.c:87 [<ffffffff82b92a00>] ax88772_init_mdio drivers/net/usb/asix_devices.c:676 [inline] [<ffffffff82b92a00>] ax88772_bind+0x330/0x480 drivers/net/usb/asix_devices.c:786 [<ffffffff82baa33f>] usbnet_probe+0x3ff/0xdf0 drivers/net/usb/usbnet.c:1745 [<ffffffff82c36e17>] usb_probe_interface+0x177/0x370 drivers/usb/core/driver.c:396 [<ffffffff82661d17>] call_driver_probe drivers/base/dd.c:517 [inline] [<ffffffff82661d17>] really_probe.part.0+0xe7/0x380 drivers/base/dd.c:596 [<ffffffff826620bc>] really_probe drivers/base/dd.c:558 [inline] [<ffffffff826620bc>] __driver_probe_device+0x10c/0x1e0 drivers/base/dd.c:751 [<ffffffff826621ba>] driver_probe_device+0x2a/0x120 drivers/base/dd.c:781 [<ffffffff82662a26>] __device_attach_driver+0xf6/0x140 drivers/base/dd.c:898 [<ffffffff8265eca7>] bus_for_each_drv+0xb7/0x100 drivers/base/bus.c:427 [<ffffffff826625a2>] __device_attach+0x122/0x260 drivers/base/dd.c:969 [<ffffffff82660916>] bus_probe_device+0xc6/0xe0 drivers/base/bus.c:487 [<ffffffff8265cd0b>] device_add+0x5fb/0xdf0 drivers/base/core.c:3359 [<ffffffff82c343b9>] usb_set_configuration+0x9d9/0xb90 drivers/usb/core/message.c:2170 [<ffffffff82c4473c>] usb_generic_driver_probe+0x8c/0xc0 drivers/usb/core/generic.c:238 BUG: memory leak unreferenced object 0xffff888116f06900 (size 32): comm "kworker/0:2", pid 2670, jiffies 4294944448 (age 7.160s) hex dump (first 32 bytes): 75 73 62 2d 30 30 31 3a 30 30 33 00 00 00 00 00 usb-001:003..... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff81484516>] kstrdup+0x36/0x70 mm/util.c:60 [<ffffffff814845a3>] kstrdup_const+0x53/0x80 mm/util.c:83 [<ffffffff82296ba2>] kvasprintf_const+0xc2/0x110 lib/kasprintf.c:48 [<ffffffff82358d4b>] kobject_set_name_vargs+0x3b/0xe0 lib/kobject.c:289 [<ffffffff826575f3>] dev_set_name+0x63/0x90 drivers/base/core.c:3147 [<ffffffff828dd63b>] __mdiobus_register+0xbb/0x450 drivers/net/phy/mdio_bus.c:535 [<ffffffff828cb835>] __devm_mdiobus_register+0x75/0xf0 drivers/net/phy/mdio_devres.c:87 [<ffffffff82b92a00>] ax88772_init_mdio drivers/net/usb/asix_devices.c:676 [inline] [<ffffffff82b92a00>] ax88772_bind+0x330/0x480 drivers/net/usb/asix_devices.c:786 [<ffffffff82baa33f>] usbnet_probe+0x3ff/0xdf0 drivers/net/usb/usbnet.c:1745 [<ffffffff82c36e17>] usb_probe_interface+0x177/0x370 drivers/usb/core/driver.c:396 [<ffffffff82661d17>] call_driver_probe drivers/base/dd.c:517 [inline] [<ffffffff82661d17>] really_probe.part.0+0xe7/0x380 drivers/base/dd.c:596 [<ffffffff826620bc>] really_probe drivers/base/dd.c:558 [inline] [<ffffffff826620bc>] __driver_probe_device+0x10c/0x1e0 drivers/base/dd.c:751 [<ffffffff826621ba>] driver_probe_device+0x2a/0x120 drivers/base/dd.c:781 [<ffffffff82662a26>] __device_attach_driver+0xf6/0x140 drivers/base/dd.c:898 [<ffffffff8265eca7>] bus_for_each_drv+0xb7/0x100 drivers/base/bus.c:427 [<ffffffff826625a2>] __device_attach+0x122/0x260 drivers/base/dd.c:969 Reported-by: syzbot+398e7dc692ddbbb4cfec@syzkaller.appspotmail.com Signed-off-by: Yanfei Xu <yanfei.xu@windriver.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27ALSA: hda: avoid write to STATESTS if controller is in resetKai Vehmanen
[ Upstream commit b37a15188eae9d4c49c5bb035e0c8d4058e4d9b3 ] The snd_hdac_bus_reset_link() contains logic to clear STATESTS register before performing controller reset. This code dates back to an old bugfix in commit e8a7f136f5ed ("[ALSA] hda-intel - Improve HD-audio codec probing robustness"). Originally the code was added to azx_reset(). The code was moved around in commit a41d122449be ("ALSA: hda - Embed bus into controller object") and ended up to snd_hdac_bus_reset_link() and called primarily via snd_hdac_bus_init_chip(). The logic to clear STATESTS is correct when snd_hdac_bus_init_chip() is called when controller is not in reset. In this case, STATESTS can be cleared. This can be useful e.g. when forcing a controller reset to retry codec probe. A normal non-power-on reset will not clear the bits. However, this old logic is problematic when controller is already in reset. The HDA specification states that controller must be taken out of reset before writing to registers other than GCTL.CRST (1.0a spec, 3.3.7). The write to STATESTS in snd_hdac_bus_reset_link() will be lost if the controller is already in reset per the HDA specification mentioned. This has been harmless on older hardware. On newer generation of Intel PCIe based HDA controllers, if configured to report issues, this write will emit an unsupported request error. If ACPI Platform Error Interface (APEI) is enabled in kernel, this will end up to kernel log. Fix the code in snd_hdac_bus_reset_link() to only clear the STATESTS if the function is called when controller is not in reset. Otherwise clearing the bits is not possible and should be skipped. Signed-off-by: Kai Vehmanen <kai.vehmanen@linux.intel.com> Link: https://lore.kernel.org/r/20211012142935.3731820-1-kai.vehmanen@linux.intel.com Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-27platform/x86: intel_scu_ipc: Update timeout value in commentPrashant Malani
[ Upstream commit a0c5814b9933f25ecb6de169483c5b88cf632bca ] The comment decribing the IPC timeout hadn't been updated when the actual timeout was changed from 3 to 5 seconds in commit a7d53dbbc70a ("platform/x86: intel_scu_ipc: Increase virtual timeout from 3 to 5 seconds") . Since the value is anyway updated to 10s now, take this opportunity to update the value in the comment too. Signed-off-by: Prashant Malani <pmalani@chromium.org> Cc: Benson Leung <bleung@chromium.org> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Link: https://lore.kernel.org/r/20210928101932.2543937-4-pmalani@chromium.org Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-27isdn: mISDN: Fix sleeping function called from invalid contextZheyu Ma
[ Upstream commit 6510e80a0b81b5d814e3aea6297ba42f5e76f73c ] The driver can call card->isac.release() function from an atomic context. Fix this by calling this function after releasing the lock. The following log reveals it: [ 44.168226 ] BUG: sleeping function called from invalid context at kernel/workqueue.c:3018 [ 44.168941 ] in_atomic(): 1, irqs_disabled(): 1, non_block: 0, pid: 5475, name: modprobe [ 44.169574 ] INFO: lockdep is turned off. [ 44.169899 ] irq event stamp: 0 [ 44.170160 ] hardirqs last enabled at (0): [<0000000000000000>] 0x0 [ 44.170627 ] hardirqs last disabled at (0): [<ffffffff814209ed>] copy_process+0x132d/0x3e00 [ 44.171240 ] softirqs last enabled at (0): [<ffffffff81420a1a>] copy_process+0x135a/0x3e00 [ 44.171852 ] softirqs last disabled at (0): [<0000000000000000>] 0x0 [ 44.172318 ] Preemption disabled at: [ 44.172320 ] [<ffffffffa009b0a9>] nj_release+0x69/0x500 [netjet] [ 44.174441 ] Call Trace: [ 44.174630 ] dump_stack_lvl+0xa8/0xd1 [ 44.174912 ] dump_stack+0x15/0x17 [ 44.175166 ] ___might_sleep+0x3a2/0x510 [ 44.175459 ] ? nj_release+0x69/0x500 [netjet] [ 44.175791 ] __might_sleep+0x82/0xe0 [ 44.176063 ] ? start_flush_work+0x20/0x7b0 [ 44.176375 ] start_flush_work+0x33/0x7b0 [ 44.176672 ] ? trace_irq_enable_rcuidle+0x85/0x170 [ 44.177034 ] ? kasan_quarantine_put+0xaa/0x1f0 [ 44.177372 ] ? kasan_quarantine_put+0xaa/0x1f0 [ 44.177711 ] __flush_work+0x11a/0x1a0 [ 44.177991 ] ? flush_work+0x20/0x20 [ 44.178257 ] ? lock_release+0x13c/0x8f0 [ 44.178550 ] ? __kasan_check_write+0x14/0x20 [ 44.178872 ] ? do_raw_spin_lock+0x148/0x360 [ 44.179187 ] ? read_lock_is_recursive+0x20/0x20 [ 44.179530 ] ? __kasan_check_read+0x11/0x20 [ 44.179846 ] ? do_raw_spin_unlock+0x55/0x900 [ 44.180168 ] ? ____kasan_slab_free+0x116/0x140 [ 44.180505 ] ? _raw_spin_unlock_irqrestore+0x41/0x60 [ 44.180878 ] ? skb_queue_purge+0x1a3/0x1c0 [ 44.181189 ] ? kfree+0x13e/0x290 [ 44.181438 ] flush_work+0x17/0x20 [ 44.181695 ] mISDN_freedchannel+0xe8/0x100 [ 44.182006 ] isac_release+0x210/0x260 [mISDNipac] [ 44.182366 ] nj_release+0xf6/0x500 [netjet] [ 44.182685 ] nj_remove+0x48/0x70 [netjet] [ 44.182989 ] pci_device_remove+0xa9/0x250 Signed-off-by: Zheyu Ma <zheyuma97@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-27ARM: dts: spear3xx: Fix gmac nodeHerve Codina
[ Upstream commit 6636fec29cdf6665bd219564609e8651f6ddc142 ] On SPEAr3xx, ethernet driver is not compatible with the SPEAr600 one. Indeed, SPEAr3xx uses an earlier version of this IP (v3.40) and needs some driver tuning compare to SPEAr600. The v3.40 IP support was added to stmmac driver and this patch fixes this issue and use the correct compatible string for SPEAr3xx Signed-off-by: Herve Codina <herve.codina@bootlin.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-27netfilter: Kconfig: use 'default y' instead of 'm' for bool config optionVegard Nossum
commit 77076934afdcd46516caf18ed88b2f88025c9ddb upstream. This option, NF_CONNTRACK_SECMARK, is a bool, so it can never be 'm'. Fixes: 33b8e77605620 ("[NETFILTER]: Add CONFIG_NETFILTER_ADVANCED option") Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27isdn: cpai: check ctr->cnr to avoid array index out of boundXiaolong Huang
commit 1f3e2e97c003f80c4b087092b225c8787ff91e4d upstream. The cmtp_add_connection() would add a cmtp session to a controller and run a kernel thread to process cmtp. __module_get(THIS_MODULE); session->task = kthread_run(cmtp_session, session, "kcmtpd_ctr_%d", session->num); During this process, the kernel thread would call detach_capi_ctr() to detach a register controller. if the controller was not attached yet, detach_capi_ctr() would trigger an array-index-out-bounds bug. [ 46.866069][ T6479] UBSAN: array-index-out-of-bounds in drivers/isdn/capi/kcapi.c:483:21 [ 46.867196][ T6479] index -1 is out of range for type 'capi_ctr *[32]' [ 46.867982][ T6479] CPU: 1 PID: 6479 Comm: kcmtpd_ctr_0 Not tainted 5.15.0-rc2+ #8 [ 46.869002][ T6479] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.14.0-2 04/01/2014 [ 46.870107][ T6479] Call Trace: [ 46.870473][ T6479] dump_stack_lvl+0x57/0x7d [ 46.870974][ T6479] ubsan_epilogue+0x5/0x40 [ 46.871458][ T6479] __ubsan_handle_out_of_bounds.cold+0x43/0x48 [ 46.872135][ T6479] detach_capi_ctr+0x64/0xc0 [ 46.872639][ T6479] cmtp_session+0x5c8/0x5d0 [ 46.873131][ T6479] ? __init_waitqueue_head+0x60/0x60 [ 46.873712][ T6479] ? cmtp_add_msgpart+0x120/0x120 [ 46.874256][ T6479] kthread+0x147/0x170 [ 46.874709][ T6479] ? set_kthread_struct+0x40/0x40 [ 46.875248][ T6479] ret_from_fork+0x1f/0x30 [ 46.875773][ T6479] Signed-off-by: Xiaolong Huang <butterflyhuangxx@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Link: https://lore.kernel.org/r/20211008065830.305057-1-butterflyhuangxx@gmail.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27nfc: nci: fix the UAF of rf_conn_info objectLin Ma
commit 1b1499a817c90fd1ce9453a2c98d2a01cca0e775 upstream. The nci_core_conn_close_rsp_packet() function will release the conn_info with given conn_id. However, it needs to set the rf_conn_info to NULL to prevent other routines like nci_rf_intf_activated_ntf_packet() to trigger the UAF. Reviewed-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com> Signed-off-by: Lin Ma <linma@zju.edu.cn> Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27ovl: fix missing negative dentry check in ovl_rename()Zheng Liang
commit a295aef603e109a47af355477326bd41151765b6 upstream. The following reproducer mkdir lower upper work merge touch lower/old touch lower/new mount -t overlay overlay -olowerdir=lower,upperdir=upper,workdir=work merge rm merge/new mv merge/old merge/new & unlink upper/new may result in this race: PROCESS A: rename("merge/old", "merge/new"); overwrite=true,ovl_lower_positive(old)=true, ovl_dentry_is_whiteout(new)=true -> flags |= RENAME_EXCHANGE PROCESS B: unlink("upper/new"); PROCESS A: lookup newdentry in new_upperdir call vfs_rename() with negative newdentry and RENAME_EXCHANGE Fix by adding the missing check for negative newdentry. Signed-off-by: Zheng Liang <zhengliang6@huawei.com> Fixes: e9be9d5e76e3 ("overlay filesystem") Cc: <stable@vger.kernel.org> # v3.18 Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Masami Ichikawa(CIP) <masami.ichikawa@cybertrust.co.jp>
2021-10-27ASoC: DAPM: Fix missing kctl change notificationsTakashi Iwai
commit 5af82c81b2c49cfb1cad84d9eb6eab0e3d1c4842 upstream. The put callback of a kcontrol is supposed to return 1 when the value is changed, and this will be notified to user-space. However, some DAPM kcontrols always return 0 (except for errors), hence the user-space misses the update of a control value. This patch corrects the behavior by properly returning 1 when the value gets updated. Reported-and-tested-by: Hans de Goede <hdegoede@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Link: https://lore.kernel.org/r/20211006141712.2439-1-tiwai@suse.de Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27ALSA: usb-audio: Provide quirk for Sennheiser GSP670 HeadsetBrendan Grieve
commit 3c414eb65c294719a91a746260085363413f91c1 upstream. As per discussion at: https://github.com/szszoke/sennheiser-gsp670-pulseaudio-profile/issues/13 The GSP670 has 2 playback and 1 recording device that by default are detected in an incompatible order for alsa. This may have been done to make it compatible for the console by the manufacturer and only affects the latest firmware which uses its own ID. This quirk will resolve this by reordering the channels. Signed-off-by: Brendan Grieve <brendan@grieve.com.au> Cc: <stable@vger.kernel.org> Link: https://lore.kernel.org/r/20211015025335.196592-1-brendan@grieve.com.au Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27elfcore: correct reference to CONFIG_UMLLukas Bulwahn
commit b0e901280d9860a0a35055f220e8e457f300f40a upstream. Commit 6e7b64b9dd6d ("elfcore: fix building with clang") introduces special handling for two architectures, ia64 and User Mode Linux. However, the wrong name, i.e., CONFIG_UM, for the intended Kconfig symbol for User-Mode Linux was used. Although the directory for User Mode Linux is ./arch/um; the Kconfig symbol for this architecture is called CONFIG_UML. Luckily, ./scripts/checkkconfigsymbols.py warns on non-existing configs: UM Referencing files: include/linux/elfcore.h Similar symbols: UML, NUMA Correct the name of the config to the intended one. [akpm@linux-foundation.org: fix um/x86_64, per Catalin] Link: https://lkml.kernel.org/r/20211006181119.2851441-1-catalin.marinas@arm.com Link: https://lkml.kernel.org/r/YV6pejGzLy5ppEpt@arm.com Link: https://lkml.kernel.org/r/20211006082209.417-1-lukas.bulwahn@gmail.com Fixes: 6e7b64b9dd6d ("elfcore: fix building with clang") Signed-off-by: Lukas Bulwahn <lukas.bulwahn@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Nathan Chancellor <nathan@kernel.org> Cc: Nick Desaulniers <ndesaulniers@google.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Barret Rhoden <brho@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27ocfs2: mount fails with buffer overflow in strlenValentin Vidic
commit b15fa9224e6e1239414525d8d556d824701849fc upstream. Starting with kernel 5.11 built with CONFIG_FORTIFY_SOURCE mouting an ocfs2 filesystem with either o2cb or pcmk cluster stack fails with the trace below. Problem seems to be that strings for cluster stack and cluster name are not guaranteed to be null terminated in the disk representation, while strlcpy assumes that the source string is always null terminated. This causes a read outside of the source string triggering the buffer overflow detection. detected buffer overflow in strlen ------------[ cut here ]------------ kernel BUG at lib/string.c:1149! invalid opcode: 0000 [#1] SMP PTI CPU: 1 PID: 910 Comm: mount.ocfs2 Not tainted 5.14.0-1-amd64 #1 Debian 5.14.6-2 RIP: 0010:fortify_panic+0xf/0x11 ... Call Trace: ocfs2_initialize_super.isra.0.cold+0xc/0x18 [ocfs2] ocfs2_fill_super+0x359/0x19b0 [ocfs2] mount_bdev+0x185/0x1b0 legacy_get_tree+0x27/0x40 vfs_get_tree+0x25/0xb0 path_mount+0x454/0xa20 __x64_sys_mount+0x103/0x140 do_syscall_64+0x3b/0xc0 entry_SYSCALL_64_after_hwframe+0x44/0xae Link: https://lkml.kernel.org/r/20210929180654.32460-1-vvidic@valentin-vidic.from.hr Signed-off-by: Valentin Vidic <vvidic@valentin-vidic.from.hr> Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com> Cc: Mark Fasheh <mark@fasheh.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Junxiao Bi <junxiao.bi@oracle.com> Cc: Changwei Ge <gechangwei@live.cn> Cc: Gang He <ghe@suse.com> Cc: Jun Piao <piaojun@huawei.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27can: peak_pci: peak_pci_remove(): fix UAFZheyu Ma
commit 949fe9b35570361bc6ee2652f89a0561b26eec98 upstream. When remove the module peek_pci, referencing 'chan' again after releasing 'dev' will cause UAF. Fix this by releasing 'dev' later. The following log reveals it: [ 35.961814 ] BUG: KASAN: use-after-free in peak_pci_remove+0x16f/0x270 [peak_pci] [ 35.963414 ] Read of size 8 at addr ffff888136998ee8 by task modprobe/5537 [ 35.965513 ] Call Trace: [ 35.965718 ] dump_stack_lvl+0xa8/0xd1 [ 35.966028 ] print_address_description+0x87/0x3b0 [ 35.966420 ] kasan_report+0x172/0x1c0 [ 35.966725 ] ? peak_pci_remove+0x16f/0x270 [peak_pci] [ 35.967137 ] ? trace_irq_enable_rcuidle+0x10/0x170 [ 35.967529 ] ? peak_pci_remove+0x16f/0x270 [peak_pci] [ 35.967945 ] __asan_report_load8_noabort+0x14/0x20 [ 35.968346 ] peak_pci_remove+0x16f/0x270 [peak_pci] [ 35.968752 ] pci_device_remove+0xa9/0x250 Fixes: e6d9c80b7ca1 ("can: peak_pci: add support of some new PEAK-System PCI cards") Link: https://lore.kernel.org/all/1634192913-15639-1-git-send-email-zheyuma97@gmail.com Cc: stable@vger.kernel.org Signed-off-by: Zheyu Ma <zheyuma97@gmail.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27can: peak_usb: pcan_usb_fd_decode_status(): fix back to ERROR_ACTIVE state ↵Stephane Grosjean
notification commit 3d031abc7e7249573148871180c28ecedb5e27df upstream. This corrects the lack of notification of a return to ERROR_ACTIVE state for USB - CANFD devices from PEAK-System. Fixes: 0a25e1f4f185 ("can: peak_usb: add support for PEAK new CANFD USB adapters") Link: https://lore.kernel.org/all/20210929142111.55757-1-s.grosjean@peak-system.com Cc: stable@vger.kernel.org Signed-off-by: Stephane Grosjean <s.grosjean@peak-system.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27can: rcar_can: fix suspend/resumeYoshihiro Shimoda
commit f7c05c3987dcfde9a4e8c2d533db013fabebca0d upstream. If the driver was not opened, rcar_can_suspend() should not call clk_disable() because the clock was not enabled. Fixes: fd1159318e55 ("can: add Renesas R-Car CAN driver") Link: https://lore.kernel.org/all/20210924075556.223685-1-yoshihiro.shimoda.uh@renesas.com Cc: stable@vger.kernel.org Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Tested-by: Ayumi Nakamichi <ayumi.nakamichi.kf@renesas.com> Reviewed-by: Ulrich Hecht <uli+renesas@fpond.eu> Tested-by: Biju Das <biju.das.jz@bp.renesas.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27NIOS2: irqflags: rename a redefined register nameRandy Dunlap
[ Upstream commit 4cce60f15c04d69eff6ffc539ab09137dbe15070 ] Both arch/nios2/ and drivers/mmc/host/tmio_mmc.c define a macro with the name "CTL_STATUS". Change the one in arch/nios2/ to be "CTL_FSTATUS" (flags status) to eliminate the build warning. In file included from ../drivers/mmc/host/tmio_mmc.c:22: drivers/mmc/host/tmio_mmc.h:31: warning: "CTL_STATUS" redefined 31 | #define CTL_STATUS 0x1c arch/nios2/include/asm/registers.h:14: note: this is the location of the previous definition 14 | #define CTL_STATUS 0 Fixes: b31ebd8055ea ("nios2: Nios2 registers") Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Dinh Nguyen <dinguyen@kernel.org> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-27netfilter: ipvs: make global sysctl readonly in non-init netnsAntoine Tenart
[ Upstream commit 174c376278949c44aad89c514a6b5db6cee8db59 ] Because the data pointer of net/ipv4/vs/debug_level is not updated per netns, it must be marked as read-only in non-init netns. Fixes: c6d2d445d8de ("IPVS: netns, final patch enabling network name space.") Signed-off-by: Antoine Tenart <atenart@kernel.org> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-27NFSD: Keep existing listeners on portlist errorBenjamin Coddington
[ Upstream commit c20106944eb679fa3ab7e686fe5f6ba30fbc51e5 ] If nfsd has existing listening sockets without any processes, then an error returned from svc_create_xprt() for an additional transport will remove those existing listeners. We're seeing this in practice when userspace attempts to create rpcrdma transports without having the rpcrdma modules present before creating nfsd kernel processes. Fix this by checking for existing sockets before calling nfsd_destroy(). Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-27r8152: select CRC32 and CRYPTO/CRYPTO_HASH/CRYPTO_SHA256Vegard Nossum
commit 9973a43012b6ad1720dbc4d5faf5302c28635b8c upstream. Fix the following build/link errors by adding a dependency on CRYPTO, CRYPTO_HASH, CRYPTO_SHA256 and CRC32: ld: drivers/net/usb/r8152.o: in function `rtl8152_fw_verify_checksum': r8152.c:(.text+0x2b2a): undefined reference to `crypto_alloc_shash' ld: r8152.c:(.text+0x2bed): undefined reference to `crypto_shash_digest' ld: r8152.c:(.text+0x2c50): undefined reference to `crypto_destroy_tfm' ld: drivers/net/usb/r8152.o: in function `_rtl8152_set_rx_mode': r8152.c:(.text+0xdcb0): undefined reference to `crc32_le' Fixes: 9370f2d05a2a1 ("r8152: support request_firmware for RTL8153") Fixes: ac718b69301c7 ("net/usb: new driver for RTL8152") Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27drm/msm: Fix null pointer dereference on pointer edpColin Ian King
commit 2133c4fc8e1348dcb752f267a143fe2254613b34 upstream. The initialization of pointer dev dereferences pointer edp before edp is null checked, so there is a potential null pointer deference issue. Fix this by only dereferencing edp after edp has been null checked. Addresses-Coverity: ("Dereference before null check") Fixes: ab5b0107ccf3 ("drm/msm: Initial add eDP support in msm drm driver (v5)") Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Dmitry Baryshkov <dmitry.baryshkov@linaro.org> Link: https://lore.kernel.org/r/20210929121857.213922-1-colin.king@canonical.com Signed-off-by: Rob Clark <robdclark@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27pata_legacy: fix a couple uninitialized variable bugsDan Carpenter
commit 013923477cb311293df9079332cf8b806ed0e6f2 upstream. The last byte of "pad" is used without being initialized. Fixes: 55dba3120fbc ("libata: update ->data_xfer hook for ATAPI") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27NFC: digital: fix possible memory leak in digital_in_send_sdd_req()Ziyang Xuan
commit 291c932fc3692e4d211a445ba8aa35663831bac7 upstream. 'skb' is allocated in digital_in_send_sdd_req(), but not free when digital_in_send_cmd() failed, which will cause memory leak. Fix it by freeing 'skb' if digital_in_send_cmd() return failed. Fixes: 2c66daecc409 ("NFC Digital: Add NFC-A technology support") Signed-off-by: Ziyang Xuan <william.xuanziyang@huawei.com> Reviewed-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com> Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27NFC: digital: fix possible memory leak in digital_tg_listen_mdaa()Ziyang Xuan
commit 58e7dcc9ca29c14e44267a4d0ea61e3229124907 upstream. 'params' is allocated in digital_tg_listen_mdaa(), but not free when digital_send_cmd() failed, which will cause memory leak. Fix it by freeing 'params' if digital_send_cmd() return failed. Fixes: 1c7a4c24fbfd ("NFC Digital: Add target NFC-DEP support") Signed-off-by: Ziyang Xuan <william.xuanziyang@huawei.com> Reviewed-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com> Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27nfc: fix error handling of nfc_proto_register()Ziyang Xuan
commit 0911ab31896f0e908540746414a77dd63912748d upstream. When nfc proto id is using, nfc_proto_register() return -EBUSY error code, but forgot to unregister proto. Fix it by adding proto_unregister() in the error handling case. Fixes: c7fe3b52c128 ("NFC: add NFC socket family") Signed-off-by: Ziyang Xuan <william.xuanziyang@huawei.com> Reviewed-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com> Link: https://lore.kernel.org/r/20211013034932.2833737-1-william.xuanziyang@huawei.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27ethernet: s2io: fix setting mac address during resumeArnd Bergmann
commit 40507e7aada8422c38aafa0c8a1a09e4623c712a upstream. After recent cleanups, gcc started warning about a suspicious memcpy() call during the s2io_io_resume() function: In function '__dev_addr_set', inlined from 'eth_hw_addr_set' at include/linux/etherdevice.h:318:2, inlined from 's2io_set_mac_addr' at drivers/net/ethernet/neterion/s2io.c:5205:2, inlined from 's2io_io_resume' at drivers/net/ethernet/neterion/s2io.c:8569:7: arch/x86/include/asm/string_32.h:182:25: error: '__builtin_memcpy' accessing 6 bytes at offsets 0 and 2 overlaps 4 bytes at offset 2 [-Werror=restrict] 182 | #define memcpy(t, f, n) __builtin_memcpy(t, f, n) | ^~~~~~~~~~~~~~~~~~~~~~~~~ include/linux/netdevice.h:4648:9: note: in expansion of macro 'memcpy' 4648 | memcpy(dev->dev_addr, addr, len); | ^~~~~~ What apparently happened is that an old cleanup changed the calling conventions for s2io_set_mac_addr() from taking an ethernet address as a character array to taking a struct sockaddr, but one of the callers was not changed at the same time. Change it to instead call the low-level do_s2io_prog_unicast() function that still takes the old argument type. Fixes: 2fd376884558 ("S2io: Added support set_mac_address driver entry point") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Link: https://lore.kernel.org/r/20211013143613.2049096-1-arnd@kernel.org Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27net: encx24j600: check error in devm_regmap_init_encx24j600Nanyong Sun
commit f03dca0c9e2297c84a018e306f8a9cd534ee4287 upstream. devm_regmap_init may return error which caused by like out of memory, this will results in null pointer dereference later when reading or writing register: general protection fault in encx24j600_spi_probe KASAN: null-ptr-deref in range [0x0000000000000090-0x0000000000000097] CPU: 0 PID: 286 Comm: spi-encx24j600- Not tainted 5.15.0-rc2-00142-g9978db750e31-dirty #11 9c53a778c1306b1b02359f3c2bbedc0222cba652 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.13.0-1ubuntu1.1 04/01/2014 RIP: 0010:regcache_cache_bypass drivers/base/regmap/regcache.c:540 Code: 54 41 89 f4 55 53 48 89 fb 48 83 ec 08 e8 26 94 a8 fe 48 8d bb a0 00 00 00 48 b8 00 00 00 00 00 fc ff df 48 89 fa 48 c1 ea 03 <80> 3c 02 00 0f 85 4a 03 00 00 4c 8d ab b0 00 00 00 48 8b ab a0 00 RSP: 0018:ffffc900010476b8 EFLAGS: 00010207 RAX: dffffc0000000000 RBX: fffffffffffffff4 RCX: 0000000000000000 RDX: 0000000000000012 RSI: ffff888002de0000 RDI: 0000000000000094 RBP: ffff888013c9a000 R08: 0000000000000000 R09: fffffbfff3f9cc6a R10: ffffc900010476e8 R11: fffffbfff3f9cc69 R12: 0000000000000001 R13: 000000000000000a R14: ffff888013c9af54 R15: ffff888013c9ad08 FS: 00007ffa984ab580(0000) GS:ffff88801fe00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 000055a6384136c8 CR3: 000000003bbe6003 CR4: 0000000000770ef0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 PKRU: 55555554 Call Trace: encx24j600_spi_probe drivers/net/ethernet/microchip/encx24j600.c:459 spi_probe drivers/spi/spi.c:397 really_probe drivers/base/dd.c:517 __driver_probe_device drivers/base/dd.c:751 driver_probe_device drivers/base/dd.c:782 __device_attach_driver drivers/base/dd.c:899 bus_for_each_drv drivers/base/bus.c:427 __device_attach drivers/base/dd.c:971 bus_probe_device drivers/base/bus.c:487 device_add drivers/base/core.c:3364 __spi_add_device drivers/spi/spi.c:599 spi_add_device drivers/spi/spi.c:641 spi_new_device drivers/spi/spi.c:717 new_device_store+0x18c/0x1f1 [spi_stub 4e02719357f1ff33f5a43d00630982840568e85e] dev_attr_store drivers/base/core.c:2074 sysfs_kf_write fs/sysfs/file.c:139 kernfs_fop_write_iter fs/kernfs/file.c:300 new_sync_write fs/read_write.c:508 (discriminator 4) vfs_write fs/read_write.c:594 ksys_write fs/read_write.c:648 do_syscall_64 arch/x86/entry/common.c:50 entry_SYSCALL_64_after_hwframe arch/x86/entry/entry_64.S:113 Add error check in devm_regmap_init_encx24j600 to avoid this situation. Fixes: 04fbfce7a222 ("net: Microchip encx24j600 driver") Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: Nanyong Sun <sunnanyong@huawei.com> Link: https://lore.kernel.org/r/20211012125901.3623144-1-sunnanyong@huawei.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27net: korina: select CRC32Vegard Nossum
commit 427f974d9727ca681085ddcd0530c97ab5811ae0 upstream. Fix the following build/link error by adding a dependency on the CRC32 routines: ld: drivers/net/ethernet/korina.o: in function `korina_multicast_list': korina.c:(.text+0x1af): undefined reference to `crc32_le' Fixes: ef11291bcd5f9 ("Add support the Korina (IDT RC32434) Ethernet MAC") Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Acked-by: Florian fainelli <f.fainelli@gmail.com> Link: https://lore.kernel.org/r/20211012152509.21771-1-vegard.nossum@oracle.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
