irq.c is missing the inclusion of asm/io.h, which causes
readb() and writeb() the be undefined.
Signed-off-by: Sven Hartge <hartge@ds9.argh.org>
Signed-off-by: Chris Wright <chrisw@osdl.org>
You could open the /proc/sys/net/ipv4/conf/<if>/<whatever> file, then
wait for interface to go away, try to grab as much memory as possible in
hope to hit the (kfreed) ctl_table. Then fill it with pointers to your
function. Then do read from file you've opened and if you are lucky,
you'll get it called as ->proc_handler() in kernel mode.
So this is at least an Oops and possibly more. It does depend on an
interface going away though, so less of a security risk than it would
otherwise be.
This fixes the RCU race on bridge delete interface. Basically,
the network device has to be detached from the bridge in the first
step (pre-RCU), rather than later. At that point, no more bridge traffic
will come in, and the other code will not think that network device
is part of a bridge.
This should also fix the XEN test problems. If there is another
2.6.13-stable, add it as well.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Plug request_key_auth memleak. This can be triggered by unprivileged
users, so is local DoS.
Signed-Off-By: David Howells <dhowells@redhat.com>
Please consider for next 2.6.13, it is a minor security issue allowing
users to turn on drm debugging when they shouldn't...
This fell through the cracks. Until Josh pointed me at
http://bugs.gentoo.org/show_bug.cgi?id=107893
Avoid 'names_cache' memory leak with CONFIG_AUDITSYSCALL
The nameidata "last.name" is always allocated with "__getname()", and
should always be free'd with "__putname()".
Using "putname()" without the underscores will leak memory, because the
allocation will have been hidden from the AUDITSYSCALL code.
Arguably the real bug is that the AUDITSYSCALL code is really broken,
but in the meantime this fixes the problem people see.
Reported by Robert Derr, patch by Rick Lindsley.
Acked-by: Al Viro <viro@ftp.linux.org.uk>
We need to use stricter memory barriers around the block
load and store instructions we use to save and restore the
FPU register file.
Please consider this change for 2.6.13-stable Since BIC is
the default congestion control algorithm, this fix is quite
important.
Missing parenthesis in causes BIC to be slow in increasing congestion
window.
Spotted by Injong Rhee.
The orinoco driver can send uninitialized data exposing random pieces of
the system memory. This happens because data is not padded with zeroes
when its length needs to be increased.
Reported by Meder Kydyraliev <meder@o0o.nu>
Signed-off-by: Pavel Roskin <proski@gnu.org>
Fixes for reference counting problems, deadlocks, and delays when SBP-2 devices
are unplugged or unbound from sbp2, or when unloading of sbp2/ ohci1394/ pcilynx
is attempted.
Most often reported symptoms were hotplugs remaining undetected once a FireWire
disk was unplugged since the knodemgrd kernel thread went to uninterruptible
sleep, and "modprobe -r sbp2" being unable to complete because still being in
use.
Patch is equivalent to commit abd559b1052e28d8b9c28aabde241f18fa89090b in
2.6.14-rc3 plus a fix which is necessary together with 2.6.13's scsi core API
(linux1394.org commit r1308 by Ben Collins).
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: Ben Collins <bcollins@debian.org>
Handle better the case where the sender sends full sized
frames initially, then moves to a mode where it trickles
out small amounts of data at a time.
This known problem is even mentioned in the comments
above tcp_grow_window() in tcp_input.c, specifically:
* The scheme does not work when sender sends good segments opening
* window and then starts to feed us spagetti. But it should work
* in common situations. Otherwise, we have to rely on queue collapsing.
When the sender gives full sized frames, the "struct sk_buff" overhead
from each packet is small. So we'll advertize a larger window.
If the sender moves to a mode where small segments are sent, this
ratio becomes tilted to the other extreme and we start overrunning
the socket buffer space.
tcp_clamp_window() tries to address this, but it's clamping of
tp->window_clamp is a wee bit too aggressive for this particular case.
Fix confirmed by Ion Badulescu.
Signed-off-by: "David S. Miller" <davem@davemloft.net>
Patch from Joel Sing to fix the default congestion control algorithm for incoming connections. If a new congestion control handler is added (via module),
it should become the default for new connections. Instead, the incoming
connections use reno. The cause is incorrect
initialisation causes the tcp_init_congestion_control() function to return
after the initial if test fails.
Acked-by: "David S. Miller" <davem@davemloft.net>
Here is the patch (fuzz removed) for 2.6.13.2 that fixes
OOPs when using bonding with skge.
Skge driver was bringing link up/down when changing mac
address. This doesn't work in the bonding environment, and is
more effort than needed.
Fixes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=5271
Sigend-off-by: Chris Wright <chrisw@osdl.org>
We were leaking pmd pages when 3_LEVEL_PGTABLES was enabled. This fixes that,
has been well tested and is included in mainline tree. Please include in -stable
as well.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
ip_vs_ftp when loaded can create NAT connections with unknown
client port for passive FTP. For such expectations we lookup with
cport=0 on incoming packet but it matches the format of the persistence
templates causing packets to other persistent virtual servers to be
forwarded to real server without creating connection. Later the
reply packets are treated as foreign and not SNAT-ed.
If the IPVS box serves both FTP and other services (eg. HTTP)
for the time we wait for first packet for the FTP data connections with
unknown client port (there can be many), other HTTP connections
that have nothing common to the FTP conn break, i.e. HTTP client
sends SYN to the virtual IP but the SYN+ACK is not NAT-ed properly
in IPVS box and the client box returns RST to real server IP. I.e.
the result can be 10% broken HTTP traffic if 10% of the time
there are passive FTP connections in connecting state. It hurts
only IPVS connections.
This patch changes the connection lookup for packets from
clients:
* introduce IP_VS_CONN_F_TEMPLATE connection flag to mark the
connection as template
* create new connection lookup function just for templates - ip_vs_ct_in_get
* make sure ip_vs_conn_in_get hits only connections with
IP_VS_CONN_F_NO_CPORT flag set when s_port is 0. By this way
we avoid returning template when looking for cport=0 (ftp)
Signed-off-by: Julian Anastasov <ja@ssi.bg>
per-socket multicast filters were not being applied to all sockets
in the case of an exact-match bound address, due to an over-exuberant
"return" in the look-up code. Fix below. IPv4 does not have this problem.
Thanks to Hoerdt Mickael for reporting the bug.
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
It turns out that the BUG_ON() in fs/exec.c: de_thread() is unreliable
and can trigger due to the test itself being racy.
de_thread() does
while (atomic_read(&sig->count) > count) {
BUG_ON(!thread_group_empty(current));
but release_task does
write_lock_irq(&tasklist_lock)
__exit_signal
(this is where atomic_dec(&sig->count) is run)
__exit_sighand
__unhash_process
takes write lock on tasklist_lock
remove itself out of PIDTYPE_TGID list
write_unlock_irq(&tasklist_lock)
so there's a clear (although small) window between the
atomic_dec(&sig->count) and the actual PIDTYPE_TGID unhashing of the
thread.
And actually there is no need for all threads to have exited at this
point, so we simply kill the BUG_ON.
Big thanks to Marc Lehmann who provided the test-case.
Fixes Bug 5170 (http://bugme.osdl.org/show_bug.cgi?id=5170)
Signed-off-by: Alexander Nyberg <alexn@telia.com>
Cc: Roland McGrath <roland@redhat.com>
Cc: Andrew Morton <akpm@osdl.org>
Acked-by: Andi Kleen <ak@suse.de>
In some cases, especially on modern laptops with a lot of PCI and
cardbus bridges, we're unable to assign correct secondary/subordinate
bus numbers to all cardbus bridges due to BIOS limitations unless
we are using "pci=assign-busses" boot option.
So some cardbus controllers may not have attached subordinate pci_bus
structure, and yenta driver must cope with it - just ignore such cardbus
bridges.
For example, see https://bugzilla.novell.com/show_bug.cgi?id=113778
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
ftdi_sio: I messed up the baud_base for custom baud rate support in
2.6.13. The attached one-liner patch fixes it.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
It's a dword thing, and the value we write is a dword. Doing a byte
write to it is nonsensical, and writes only the low byte, which only
contains the enable bit. So we enable a nonsensical address (usually
zero), which causes the controller no end of problems.
Trivial fix, but nasty to find.
There was a pretty bad bug in there that the code would
always check the full VMA, not the range the user requested.
When the VMA to be checked was merged with the previous VMA this
could lead to spurious failures.
Signed-off-by: Andi Kleen <ak@suse.de>
JFS: jfs_delete_inode should always call clear_inode.
> From Chuck Ebbert:
I'm submitting this patch for -stable:
- it reportedly fixes an oops
- it's already in 2.6.13-git
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
In 2.6.13-rcX the MASQUERADE target was changed not to exclude local
packets for better source address consistency. This breaks DHCP clients
using UDP sockets when the DHCP requests are caught by a MASQUERADE rule
because the MASQUERADE target drops packets when no address is configured
on the outgoing interface. This patch makes it ignore packets with a
source address of 0.
Thanks to Rusty for this suggestion.
This ports the Sun GEM ROM mapping/enable fixes it sunhme (which used
the same PCI ROM mapping code).
Without this, I get NULL MAC addresses for all 4 ports (it's a SUN QFE).
With it, I get the correct addresses (the ones printed on the label on
the card).
This same patch was reported to fix the MAC address detection on sunhme
(next patch). Most people seem to be running this on Sparcs or PPC
machines, where we get the MAC address from their respective firmware
rather than from the (previously broken) ROM mapping routines.
This is one heck of a confused driver. It uses a byte write to a dword
register to enable a ROM resource that it doesn't even seem to be using.
"Lost and wandering in the desert of confusion"
R�diger found a bug in nv_open that explains some of the reports
with duplex mismatches:
nv_open calls nv_update_link_speed for initializing the hardware link speed
registers. If current link setting matches the values in np->linkspeed and
np->duplex, then the function does nothing.
Usually, doing nothing is the right thing, but not in nv_open: During
nv_open, the registers must be initialized because the nic was reset.
The attached patch fixes that by setting np->linkspeed to an invalid value
before calling nv_update_link_speed from nv_open.
Signed-Off-By: Manfred Spraul <manfred@colorfullife.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
This patch adds lost sockfd_put() in 32bit compat rounting_ioctl() on
64bit platforms, bug found by Vasiliy Averin <vvs@sw.ru>.
I believe this is a security issues, since user can fget() file as many
times as he wants to. So file refcounter can be overlapped and first
fput() will free resources though there will be still structures
pointing to the file, mnt, dentry etc.
Also fput() sets f_dentry and f_vfsmnt to NULL,
so other file users will OOPS.
The oops can be done under files_lock and others, so this can be an
exploitable DoS on SMP. Didn't checked it on practice actually.
Signed-Off-By: Kirill Korotaev <dev@sw.ru>
Signed-Off-By: Maxim Giryaev <gem@sw.ru>
This patch adds lost fput in 32bit tiocgdev ioctl on x86-64
many times as he wants to. So file refcounter can be overlapped and
first fput() will free resources though there will be still structures
pointing to the file, mnt, dentry etc. Also fput() sets f_dentry and
f_vfsmnt to NULL, so other file users will OOPS.
The oops can be done under files_lock and others, so this is really
(chrisw: Update to use fget_light/fput_light)
Fix unchecked __get_user that could be tricked into generating a
memory read on an arbitrary address. The result of the read is not
returned directly but you may be able to divine some information about
it, or use the read to cause a crash on some architectures by reading
hardware state. CAN-2005-2492.
Fix from Al Viro, ack from Dave Miller.
When we copy 32bit ->msg_control contents to kernel, we walk the same
userland data twice without sanity checks on the second pass.
Second version of this patch: the original broke with 64-bit arches
running 32-bit-compat-mode executables doing sendmsg() syscalls with
unaligned CMSG data areas
Another thing is that we use kmalloc() to allocate and sock_kfree_s()
to free afterwards; less serious, but also needs fixing.
Patch by Al Viro, David Miller, David Woodhouse
(sparc64 clean compile fix from David Miller)
[IPV4]: Reassembly trim not clearing CHECKSUM_HW
This was found by inspection while looking for checksum problems
with the skge driver that sets CHECKSUM_HW. It did not fix the
problem, but it looks like it is needed.
If IP reassembly is trimming an overlapping fragment, it
should reset (or adjust) the hardware checksum flag on the skb.
Based upon a report from Jason Wever.
[CRYPTO] Fix boundary check in standard multi-block cipher processors
Fixes Bug 5194 (IPSec related Oops in 2.6.13).
The boundary check in the standard multi-block cipher processors are
broken when nbytes is not a multiple of bsize. In those cases it will
always process an extra block.
This patch corrects the check so that it processes at most nbytes of data.
[NET]: 2.6.13 breaks libpcap (and tcpdump)
Patrick McHardy says:
Never mind, I got it, we never fall through to the second switch
statement anymore. I think we could simply break when load_pointer
returns NULL. The switch statement will fall through to the default
case and return 0 for all cases but 0 > k >= SKF_AD_OFF.
Here's a patch to do just that.
I left BPF_MSH alone because it's really a hack to calculate the IP
header length, which makes no sense when applied to the special data.
I had some time to think about PCI assign issues in 2.6.13-rc series.
The major problem here is that we call pci_assign_unassigned_resources()
way too early - at subsys_initcall level. Therefore we give no chances
to ACPI and PnP routines (called at fs_initcall level) to reserve their
respective resources properly, as the comments in drivers/pnp/system.c
and drivers/acpi/motherboard.c suggest:
* Reserve motherboard resources after PCI claim BARs,
* but before PCI assign resources for uninitialized PCI devices
So I moved the pci_assign_unassigned_resources() call to
pcibios_assign_resources() (fs_initcall), which should hopefully fix a
lot of problems and make PCIBIOS_MIN_IO tweaks unnecessary.
Other changes:
- remove resource assignment code from pcibios_assign_resources(), since
it duplicates pci_assign_unassigned_resources() functionality and
actually does nothing in 2.6.13;
- modify ROM assignment code as per Ben's suggestion: try to use firmware
settings by default (if PCI_ASSIGN_ROMS is not set);
- set CARDBUS_IO_SIZE back to 4K as it's a wonderful stress test for
various setups.
Confirmed by Tero Roponen <teanropo@cc.jyu.fi> (who had problems with
the 4kB CardBus IO size previously).
This fixes a problem with pci_map_rom() which doesn't properly
update the ROM BAR value with the address thas allocated for it by the
PCI code. This problem, among other, breaks boot on Mac laptops.
It'ss a new version based on Linus latest one with better error
checking.
This was noticed by Doug Bazamic and the fix found by Mark Salyzyn at
Adaptec.
There was an error in the BUG_ON() statement that validated the
calculated fib size which can cause the driver to panic.
Signed-off-by: Mark Haverkamp <markh@osdl.org>
Acked-by: James Bottomley <James.Bottomley@SteelEye.com>
I wish I had seen this before 2.6.13 was released... I guess this only
goes to show that there haven't been any testers using saa7134-hybrid
dvb/v4l boards that depend on the tda1004x module, during the 2.6.13-rc
series :-(
Please apply this to 2.6.14, and also to 2.6.13.1 -stable. Without this
patch, users will have to EXPLICITLY select tda1004x in Kconfig. This
SHOULD be done automatically when saa7134-dvb is selected. This patch
corrects this problem.
saa7134-dvb must select tda1004x
Signed-off-by: Michael Krufky <mkrufky@m1k.net>
Bugfix (usage of uninitialized pointer in zfcp_port_dequeue) and compile
fixes for the zfcp device driver.
Acked-by: James Bottomley <James.Bottomley@steeleye.com>
struct zfcp_port::scsi_id was removed by commit
3859f6a248cbdfbe7b41663f3a2b51f48e30b281
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
[ Same race and same patch also by Steven Rostedt <rostedt@goodmis.org> ]
I have a laptop (G3 powerbook) which will pretty reliably hit a race
between con_open and con_close late in the boot process and oops in
vt_ioctl due to tty->driver_data being NULL.
What happens is this: process A opens /dev/tty6; it comes into
con_open() (drivers/char/vt.c) and assign a non-NULL value to
tty->driver_data. Then process A closes that and concurrently process
B opens /dev/tty6. Process A gets through con_close() and clears
tty->driver_data, since tty->count == 1. However, before process A
can decrement tty->count, we switch to process B (e.g. at the
down(&tty_sem) call at drivers/char/tty_io.c line 1626).
So process B gets to run and comes into con_open with tty->count == 2,
as tty->count is incremented (in init_dev) before con_open is called.
Because tty->count != 1, we don't set tty->driver_data. Then when the
process tries to do anything with that fd, it oopses.
The simple and effective fix for this is to test tty->driver_data
rather than tty->count in con_open. The testing and setting of
tty->driver_data is serialized with respect to the clearing of
tty->driver_data in con_close by the console_sem. We can't get a
situation where con_open sees tty->driver_data != NULL and then
con_close on a different fd clears tty->driver_data, because
tty->count is incremented before con_open is called. Thus this patch
eliminates the race, and in fact with this patch my laptop doesn't
oops.
[ Same patch
in http://marc.theaimsgroup.com/?l=linux-kernel&m=112450820432121&w=2 ]
This patch fixes a severe problem with 2.6.13-rc7.
Due to recent SCSI changes it is not possible to add any LUNs to the zfcp
device driver anymore. With registration of remote ports this is fixed.
Signed-off-by: Andreas Herrmann <aherrman@de.ibm.com>
Acked-by: James Bottomley <jejb@steeleye.com>
