2006-03-27Linux 2.6.15.7v2.6.15.7Greg Kroah-Hartman
2006-03-27[PATCH] Fix ext2 readdir f_pos re-validation logicAl Viro
This fixes not one, but _two_, silly (but admittedly hard to hit) bugs in the ext2 filesystem "readdir()" function. It also cleans up the code to avoid the unnecessary goto mess. The bugs were related to re-valiating the f_pos value after somebody had either done an "lseek()" on the directory to an invalid offset, or when the offset had become invalid due to a file being unlinked in the directory. The code would not only set the f_version too eagerly, it would also not update f_pos appropriately for when the offset fixup took place. When that happened, we'd occasionally subsequently fail the readdir() even when we shouldn't (no real harm done, but an ugly printk, and obviously you would end up not necessarily seeing all entries). Thanks to Masoud Sharbiani <masouds@google.com> who noticed the problem and had a test-case for it, and also fixed up a thinko in the first version of this patch. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Masoud Sharbiani <masouds@google.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] NET: Ensure device name passed to SO_BINDTODEVICE is NULL terminated.David S. Miller
The user can pass us arbitrary garbage so we should ensure the string they give us is null terminated before we pass it on to dev_get_by_index() et al. Found by Solar Designer. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] TCP: Do not use inet->id of global tcp_socket when sending RST ↵Alexey Kuznetsov
(CVE-2006-1242) The problem is in ip_push_pending_frames(), which uses: if (!df) { __ip_select_ident(iph, &rt->u.dst, 0); } else { iph->id = htons(inet->id++); } instead of ip_select_ident(). Right now I think the code is a nonsense. Most likely, I copied it from old ip_build_xmit(), where it was really special, we had to decide whether to generate unique ID when generating the first (well, the last) fragment. In ip_push_pending_frames() it does not make sense, it should use plain ip_select_ident() instead. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] Kconfig: VIDEO_DECODER must select FW_LOADERMichael Krufky
The cx25840 module requires external firmware in order to function, so it must select FW_LOADER, but saa7115 and saa7129 do not require it. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] cramfs mounts provide corrupted content since 2.6.15Dave Johnson
Fix handling of cramfs images created by util-linux containing empty regular files. Images created by cramfstools 1.x were ok. Fill out inode contents in cramfs_iget5_set() instead of get_cramfs_inode() to prevent issues if cramfs_iget5_test() is called with I_LOCK|I_NEW still set. Signed-off-by: Dave Johnson <djohnson+linux-kernel@sw.starentnetworks.com> Cc: Olaf Hering <olh@suse.de> Cc: Chris Mason <mason@suse.com> Cc: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] compat ifconf: fix limitsRandy Dunlap
A recent change to compat. dev_ifconf() in fs/compat_ioctl.c causes ifconf data to be truncated 1 entry too early when copying it to userspace. The correct amount of data (length) is returned, but the final entry is empty (zero, not filled in). The for-loop 'i' check should use <= to allow the final struct ifreq32 to be copied. I also used the ifconf-corruption program in kernel bugzilla #4746 to make sure that this change does not re-introduce the corruption. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] Netfilter ip_queue: Fix wrong skb->len == nlmsg_len assumptionDavid S. Miller
The size of the skb carrying the netlink message is not equivalent to the length of the actual netlink message due to padding. ip_queue matches the length of the payload against the original packet size to determine if packet mangling is desired, due to the above wrong assumption arbitary packets may not be mangled depening on their original size. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] IB/srp: Don't send task management commands after target removalRoland Dreier
Just fail abort and reset requests that come in after we've already decided to remove a target. This fixes a nasty crash if a storage target goes away. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-05Linux 2.6.15.6v2.6.15.6Chris Wright
2006-03-05[PATCH] mempolicy.c compile fix, make sure BITS_PER_BYTE is definedDave Jones
Gar.. mm/mempolicy.c: In function 'get_nodes': mm/mempolicy.c:527: error: 'BITS_PER_BYTE' undeclared (first use in this function) mm/mempolicy.c:527: error: (Each undeclared identifier is reported only once mm/mempolicy.c:527: error: for each function it appears in.) About to retry a build with the below patch which should do the trick. (How did this *ever* build?) Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-05[PATCH] fs/nfs/direct.c compile fixChris Wright
Compile fix: fs/nfs/direct.c: In function 'nfs_get_user_pages': fs/nfs/direct.c:110: warning: implicit declaration of function 'nfs_free_user_pages' fs/nfs/direct.c: At top level: fs/nfs/direct.c:127: warning: conflicting types for 'nfs_free_user_pages' fs/nfs/direct.c:127: error: static declaration of 'nfs_free_user_pages' follows non-static declaration fs/nfs/direct.c:110: error: previous implicit declaration of 'nfs_free_user_pages' was here This should now be the same as fix that's going upstream. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
2006-03-05[PATCH] die_if_kernel() can return (CVE-2006-0742)Tony Luck
arch/ia64/kernel/unaligned.c erroneously marked die_if_kernel() with a "noreturn" attribute ... which is silly (it returns whenever the argument regs say that the fault happened in user mode, as one might expect given the "if_kernel" part of its name!). Thanks to Alan and Gareth for pointing this out. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-05[PATCH] Don't reset rskq_defer_accept in reqsk_queue_allocArnaldo Carvalho de Melo
In 295f7324ff8d9ea58b4d3ec93b1aaa1d80e048a9 I moved defer_accept from tcp_sock to request_queue and mistakingly reset it at reqsl_queue_alloc, causing calls to setsockopt(TCP_DEFER_ACCEPT ) to be lost after bind, the fix is to remove the zeroing of rskq_defer_accept from reqsl_queue_alloc. Thanks to Alexandra N. Kossovsky <Alexandra.Kossovsky@oktetlabs.ru> for reporting and testing the suggested fix. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01Linux 2.6.15.5v2.6.15.5Chris Wright
2006-03-01[PATCH] IB/mthca: max_inline_data handling tweaksJack Morgenstein
Fix a case where copying max_inline_data from a successful create_qp capabilities output to create_qp input could cause EINVAL error: mthca_set_qp_size must check max_inline_data directly against max_desc_sz; checking qp->sq.max_gs is wrong since max_inline_data depends on the qp type and does not involve max_sg. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] Normal user can panic NFS client with direct I/O (CVE-2006-0555)Trond Myklebust
This is CVE-2006-0555 and SGI bug 946529. A normal user can panic an NFS client and cause a local DoS with 'judicious'(?) use of O_DIRECT. Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] XFS ftruncate() bug could expose stale data (CVE-2006-0554)Mike O'Connor
This is CVE-2006-0554 and SGI bug 942658. With certain types of ftruncate() activity on 2.6 kernels, XFS can end up exposing stale data off disk to a user, putting extents where holes should be. Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] sbp2: fix another deadlock after disconnectionStefan Richter
sbp2: fix another deadlock after disconnection If there were commands enqueued but not completed before an SBP-2 unit was unplugged (or an attempt to reconnect failed), knodemgrd or any process which tried to remove the device would sleep uninterruptibly in blk_execute_rq(). Therefore make sure that all commands are completed when sbp2 retreats. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] sd: fix memory corruption with broken mode page headersStefan Richter
sd: fix memory corruption with broken mode page headers There's a problem in sd where we blindly believe the length of the headers and block descriptors. Some devices return insane values for these and cause our length to end up greater than the actual buffer size, so check to make sure. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Also removed the buffer size magic number (512) and added DPOFUA of zero to the defaults Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org> rediff for 2.6.15.x without DPOFUA bit, taken from commit 489708007785389941a89fa06aedc5ec53303c96 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] Fix a severe bugAlexey Kuznetsov
netlink overrun was broken while improvement of netlink. Destination socket is used in the place where it was meant to be source socket, so that now overrun is never sent to user netlink sockets, when it should be, and it even can be set on kernel socket, which results in complete deadlock of rtnetlink. Suggested fix is to restore status quo passing source socket as additional argument to netlink_attachskb(). A little explanation: overrun is set on a socket, when it failed to receive some message and sender of this messages does not or even have no way to handle this error. This happens in two cases: 1. when kernel sends something. Kernel never retransmits and cannot wait for buffer space. 2. when user sends a broadcast and the message was not delivered to some recipients. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] x86_64: Check for bad elf entry address (CVE-2006-0741)Suresh Siddha
Fixes a local DOS on Intel systems that lead to an endless recursive fault. AMD machines don't seem to be affected. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] skge: fix SMP raceStephen Hemminger
If skge is attached to a bad cable, that goes up/down. It exposes an SMP race with the management of IRQ mask Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] skge: genesis phy initialization fixStephen Hemminger
The SysKonnect Genesis based board would fail on initialization with phy_read errors caused by not waiting for last phy write. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] skge: fix NAPI/irq raceStephen Hemminger
Fix a race in the receive NAPI, irq handling. The interrupt clear and the start need to be separated. Otherwise there is a window between the last frame received and the NAPI done level handling. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] skge: speed settingStephen Hemminger
This is a clone of John Linville's fixed for speed setting on sky2 driver. The skge driver has the same code (and bug). It would not allow manually forcing 100 and 10 mbit. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] gbefb: IP32 gbefb depth change fixKaj-Michael Lang
The gbefb driver does not update the framebuffer layers visual setting when depth is changed with fbset, resulting in strange colors (very dark blue in 16-bit, almost black in 24-bit). Signed-off-by: Kaj-Michael Lang <milang@tal.org> Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] ramfs: update dir mtime and ctimeAndrew Morton
Phil Marek <philipp.marek@bmlv.gv.at> points out that ramfs forgets to update a directory's mtime and ctime when it is modified. Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] dm: free minor after unlink gendiskJun'ichi Nomura
Minor number should be freed after del_gendisk(). Otherwise, there could be a window where 2 registered gendisk has same minor number. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> [chrisw: backport to 2.6.15] Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] dm: missing bdput/thaw_bdev at removalJun'ichi Nomura
Need to unfreeze and release bdev otherwise the bdev inode with inconsistent state is reused later and cause problem. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> [chrisw: backport to 2.6.15] Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] gbefb: Set default of FB_GBE_MEM to 4 MBMartin Michlmayr
Allocating more than 4 MB memory for the GBE (SGI O2) framebuffer completely breakfs gbefb support at the moment. According to comments on #mipslinux, more than 4 MB has never worked correctly in Linux. Therefore, the default should be 4 MB. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] cfi: init wait queue in chip structSimon Vogl
Fix a kernel oops for Intel P30 flashes, where the wait queue head was not initialized for the flchip struct, which in turn caused a crash at the first read operation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] alsa: fix bogus snd_device_free() in opl3-oss.cTakashi Iwai
Remove snd_device_free() for an opl3-oss instance which should have been released. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] Fix snd-usb-audio in 32-bit compat environmentJuergen Kreileder
I'm getting oopses with snd-usb-audio in 32-bit compat environments: control_compat.c:get_ctl_type() doesn't initialize 'info', so 'itemlist[uinfo->value.enumerated.item]' in usbmixer.c:mixer_ctl_selector_info() might access random memory (The 'if ((int)uinfo->value.enumerated.item >= cval->max)' doesn't fix all problems because of the unsigned -> signed conversion.) Signed-off-by: Juergen Kreileder <jk@blackdown.de> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] hwmon it87: Probe i2c 0x2d onlyJean Delvare
Only scan I2C address 0x2d. This is the default address and no IT87xxF chip was ever seen on I2C at a different address. These chips are better accessed through their ISA interface anyway. This fixes bug #5889, although it doesn't address the whole class of problems. We'd need the ability to blacklist arbitrary I2C addresses on systems known to contain I2C devices which behave badly when probed. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] it87: Fix oops on removalJean Delvare
Fix an oops on it87 module removal when no supported hardware was found. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-03-01[PATCH] sys_mbind sanity checkingChris Wright
Make sure maxnodes is safe size before calculating nlongs in get_nodes(). Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> [chrisw: fix units, pointed out by Andi] Cc: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] fix deadlock in ext2Peter Staubach
Fix a deadlock possible in the ext2 file system implementation. This deadlock occurs when a file is removed from an ext2 file system which was mounted with the "sync" mount option. The problem is that ext2_xattr_delete_inode() was invoking the routine, sync_dirty_buffer(), using a buffer head which was previously locked via lock_buffer(). The first thing that sync_dirty_buffer() does is to lock the buffer head that it was passed. It does this via lock_buffer(). Oops. The solution is to unlock the buffer head in ext2_xattr_delete_inode() before invoking sync_dirty_buffer(). This makes the code in ext2_xattr_delete_inode() obey the same locking rules as all other callers of sync_dirty_buffer() in the ext2 file system implementation. Signed-off-by: Peter Staubach <staubach@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] fix zap_thread's ptrace related problemsOleg Nesterov
1. The tracee can go from ptrace_stop() to do_signal_stop() after __ptrace_unlink(p). 2. It is unsafe to __ptrace_unlink(p) while p->parent may wait for tasklist_lock in ptrace_detach(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Hellwig <hch@lst.de> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] Fix deadlock in br_stp_disable_bridgeAdrian Drzewiecki
Looks like somebody forgot to use the _bh spin_lock variant. We ran into a deadlock where br->hello_timer expired while br_stp_disable_br() walked br->port_list. Signed-off-by: Adrian Drzewiecki <z@drze.net> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] Fix s390 build failure.Dave Jones
arch/s390/kernel/compat_signal.c:199: error: conflicting types for 'do_sigaction' include/linux/sched.h:1115: error: previous declaration of 'do_sigaction' was here Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] sys32_signal() forgets to initialize ->sa_maskTony Luck
Pointed out by Oleg Nesterov <oleg@tv-sign.ru>, who in turn got the hint from Linus. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] do_sigaction: cleanup ->sa_mask manipulationOleg Nesterov
Clear unblockable signals beforehand. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] sys_signal: initialize ->sa_maskOleg Nesterov
Pointed out by Linus Torvalds. sys_signal() forgets to initialize ->sa_mask. ( I suspect arch/ia64/ia32/ia32_signal.c:sys32_signal() also needs this fix ) Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] Address autoconfiguration does not work after device down/up cycleKristian Slavov
If you set network interface down and up again, the IPv6 address autoconfiguration does not work. 'ip addr' shows that the link-local address is in tentative state. We don't even react to periodical router advertisements. During NETDEV_DOWN we clear IF_READY, and we don't set it back in NETDEV_UP. While starting to perform DAD on the link-local address, we notice that the device is not in IF_READY, and we abort autoconfiguration process (which would eventually send router solicitations). Acked-by: Juha-Matti Tapio <jmtapio@verkkotelakka.net> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] Revert skb_copy_datagram_iovec() recursion elimination.David S. Miller
Revert the following changeset: bc8dfcb93970ad7139c976356bfc99d7e251deaf Recursive SKB frag lists are really possible and disallowing them breaks things. Noticed by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] reiserfs: disable automatic enabling of reiserfs inode attributesJeff Mahoney
Unfortunately, the reiserfs_attrs_cleared bit in the superblock flag can lie. File systems have been observed with the bit set, yet still contain garbage in the stat data field, causing unpredictable results. This patch backs out the enable-by-default behavior. It eliminates the changes from: d50a5cd860ce721dbeac6a4f3c6e42abcde68cd8, and ef5e5414e7a83eb9b4295bbaba5464410b11e030. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] hugetlbfs mmap ENOMEM failureHugh Dickins
2.6.15's hugepage faulting introduced huge_pages_needed accounting into hugetlbfs: to count how many pages are already in cache, for spot check on how far a new mapping may be allowed to extend the file. But it's muddled: each hugepage found covers HPAGE_SIZE, not PAGE_SIZE. Once pages were already in cache, it would overshoot, wrap its hugepages count backwards, and so fail a harmless repeat mapping with -ENOMEM. Fixes the problem found by Don Dupuis. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-By: Adam Litke <agl@us.ibm.com> Acked-by: William Irwin <wli@us.ibm.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] i386: Move phys_proc_id/early intel workaround to correct functionAndi Kleen
early_cpu_detect only runs on the BP, but this code needs to run on all CPUs. This will fix problems with the powernow-k8 driver on dual core systems and general misdetection of AMD dual core. Looks like a mismerge somewhere. Also add a warning comment. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-01[PATCH] netfilter missing symbol has_bridge_parentHorms
5dce971acf2ae20c80d5e9d1f6bbf17376870911 in Linus' tree, otherwise known as bridge-netfilter-races-on-device-removal.patch in 2.5.15.4 removed has_bridge_parent, however this symbol is still called with NETFILTER_DEBUG is enabled. This patch uses the already seeded realoutdev value to detect if a parent exists, and if so, the value of the parent. Signed-Off-By: Horms <horms@verge.net.au> Acked-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
