2006-06-30Linux 2.6.16.23v2.6.16.23Greg Kroah-Hartman
2006-06-30[PATCH] revert PARPORT_SERIAL should depend on SERIAL_8250_PCI patchChris Wright
Should have not been applied to 2.6.16 Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-30[PATCH] NETFILTER: SCTP conntrack: fix crash triggered by packet without ↵Patrick McHardy
chunks [CVE-2006-2934] When a packet without any chunks is received, the newconntrack variable in sctp_packet contains an out of bounds value that is used to look up an pointer from the array of timeouts, which is then dereferenced, resulting in a crash. Make sure at least a single chunk is present. Problem noticed by George A. Theall <theall@tenablesecurity.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22Linux 2.6.16.22v2.6.16.22Chris Wright
2006-06-22[PATCH] NTFS: Critical bug fix (affects MIPS and possibly others)Anton Altaparmakov
It fixes a crash in NTFS on architectures where flush_dcache_page() is a real function. I never noticed this as all my testing is done on i386 where flush_dcache_page() is NULL. http://bugzilla.kernel.org/show_bug.cgi?id=6700 Many thanks to Pauline Ng for the detailed bug report and analysis! Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-22[PATCH] powernow-k8 crash workaroundAndrew Morton
Work around the oops reported in http://bugzilla.kernel.org/show_bug.cgi?id=6478. Thanks to Ralf Hildebrandt <ralf.hildebrandt@charite.de> for testing and reporting. Acked-by: Dave Jones <davej@codemonkey.org.uk> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] I2O: Bugfixes to get I2O working againMarkus Lidel
- Fixed locking of struct i2o_exec_wait in Executive-OSM - Removed LCT Notify in i2o_exec_probe() which caused freeing memory and accessing freed memory during first enumeration of I2O devices - Added missing locking in i2o_exec_lct_notify() - removed put_device() of I2O controller in i2o_iop_remove() which caused the controller structure get freed to early - Fixed size of mempool in i2o_iop_alloc() - Fixed access to freed memory in i2o_msg_get() See http://bugzilla.kernel.org/show_bug.cgi?id=6561 Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] scsi_lib.c: properly count the number of pages in scsi_req_map_sg()James Bottomley
The calculation of nr_pages in scsi_req_map_sg() doesn't account for the fact that the first page could have an offset that pushes the end of the buffer onto a new page. Signed-off-by: Bryan Holty <lgeek@frontiernet.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] JFS: Fix multiple errors in metapage_releasepageDave Kleikamp
It looks like metapage_releasepage was making in invalid assumption that the releasepage method would not be called on a dirty page. Instead of issuing a warning and releasing the metapage, it should return 0, indicating that the private data for the page cannot be released. I also realized that metapage_releasepage had the return code all wrong. If it is successful in releasing the private data, it should return 1, otherwise it needs to return 0. Lastly, there is no need to call wait_on_page_writeback, since try_to_release_page will not call us with a page in writback state. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] fs/namei.c: Call to file_permission() under a spinlock in ↵Trond Myklebust
do_lookup_path() We're presently running lock_kernel() under fs_lock via nfs's ->permission handler. That's a ranking bug and sometimes a sleep-in-spinlock bug. This problem was introduced in the openat() patchset. We should not need to hold the current->fs->lock for a codepath that doesn't use current->fs. [vsu@altlinux.ru: fix error path] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] tmpfs: time granularity fix for [acm]time going backwardsRobin H. Johnson
I noticed a strange behavior in a tmpfs file system the other day, while building packages - occasionally, and seemingly at random, make decided to rebuild a target. However, only on tmpfs. A file would be created, and if checked, it had a sub-second timestamp. However, after an utimes related call where sub-seconds should be set, they were zeroed instead. In the case that a file was created, and utimes(...,NULL) was used on it in the same second, the timestamp on the file moved backwards. After some digging, I found that this was being caused by tmpfs not having a time granularity set, thus inheriting the default 1 second granularity. Hugh adds: yes, we missed tmpfs when the s_time_gran mods went into 2.6.11. Unfortunately, the granularity of CURRENT_TIME, often used in filesystems, does not match the default granularity set by alloc_super. A few more such discrepancies have been found, but this is the most important to fix now. Signed-off-by: Robin H. Johnson <robbat2@gentoo.org> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] Missed error checking for intent's filp in open_namei().Oleg Drokin
It seems there is error check missing in open_namei for errors returned through intent.open.file (from lookup_instantiate_filp). If there is plain open performed, then such a check done inside __path_lookup_intent_open called from path_lookup_open(), but when the open is performed with O_CREAT flag set, then __path_lookup_intent_open is only called with LOOKUP_PARENT set where no file opening can occur yet. Later on lookup_hash is called where exact opening might take place and intent.open.file may be filled. If it is filled with error value of some sort, then we get kernel attempting to dereference this error value as address (and corresponding oops) in nameidata_to_filp() called from filp_open(). While this is relatively simple to workaround in ->lookup() method by just checking lookup_instantiate_filp() return value and returning error as needed, this is not so easy in ->d_revalidate(), where we can only return "yes, dentry is valid" or "no, dentry is invalid, perform full lookup again", and just returning 0 on error would cause extra lookup (with potential extra costly RPCs). So in short, I believe that there should be no difference in error handling for opening a file and creating a file in open_namei() and propose this simple patch as a solution. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] SPARC64: Fix missing fold at end of checksums.David Miller
Both csum_partial() and the csum_partial_copy*() family of routines forget to do a final fold on the computed checksum value on sparc64. So do the standard Sparc "add + set condition codes, add carry" sequence, then make sure the high 32-bits of the return value are clear. Based upon some excellent detective work and debugging done by Richard Braun and Samuel Thibault. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] SPARC64: Respect gfp_t argument to dma_alloc_coherent().David Miller
Using asm-generic/dma-mapping.h does not work because pushing the call down to pci_alloc_coherent() causes the gfp_t argument of dma_alloc_coherent() to be ignored. Fix this by implementing things directly, and adding a gfp_t argument we can use in the internal call down to the PCI DMA implementation of pci_alloc_coherent(). This fixes massive memory corruption when using the sound driver layer, which passes things like __GFP_COMP down into these routines and (correctly) expects that to work. This is a disk eater when sound is used, so it's pretty critical. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] SPARC64: Fix D-cache corruption in mremapDavid Miller
If we move a mapping from one virtual address to another, and this changes the virtual color of the mapping to those pages, we can see corrupt data due to D-cache aliasing. Check for and deal with this by overriding the move_pte() macro. Set things up so that other platforms can cleanly override the move_pte() macro too. This long standing bug corrupts user memory, and in particular has been notorious for corrupting Debian package database files on sparc64 boxes. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] USB: Whiteheat: fix firmware spurious errorsStuart MacDonald
Attached patch fixes spurious errors during firmware load. Signed-off-by: Stuart MacDonald <stuartm@connecttech.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-20Linux 2.6.16.21v2.6.16.21Chris Wright
2006-06-20[PATCH] xt_sctp: fix endless loop caused by 0 chunk length (CVE-2006-3085)Patrick McHardy
Fix endless loop in the SCTP match similar to those already fixed in the SCTP conntrack helper (was CVE-2006-1527). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-20[PATCH] run_posix_cpu_timers: remove a bogus BUG_ON() (CVE-2006-2445)Oleg Nesterov
do_exit() clears ->it_##clock##_expires, but nothing prevents another cpu to attach the timer to exiting process after that. arm_timer() tries to protect against this race, but the check is racy. After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and before do_exit() calls 'schedule() local timer interrupt can find tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu does sys_wait4) interrupted task has ->signal == NULL. At this moment exiting task has no pending cpu timers, they were cleanuped in __exit_signal()->posix_cpu_timers_exit{,_group}(), so we can just return from irq. John Stultz recently confirmed this bug, see http://marc.theaimsgroup.com/?l=linux-kernel&m=115015841413687 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-20[PATCH] check_process_timers: fix possible lockupOleg Nesterov
If the local timer interrupt happens just after do_exit() sets PF_EXITING (and before it clears ->it_xxx_expires) run_posix_cpu_timers() will call check_process_timers() with tasklist_lock + ->siglock held and check_process_timers: t = tsk; do { .... do { t = next_thread(t); } while (unlikely(t->flags & PF_EXITING)); } while (t != tsk); the outer loop will never stop. Actually, the window is bigger. Another process can attach the timer after ->it_xxx_expires was cleared (see the next commit) and the 'if (PF_EXITING)' check in arm_timer() is racy (see the one after that). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-20[PATCH] powerpc: Fix machine check problem on 32-bit kernels (CVE-2006-2448)Paul Mackerras
This fixes a bug found by Dave Jones that means that it is possible for userspace to provoke a machine check on 32-bit kernels. This also fixes a couple of other places where I found similar problems by inspection. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-05Linux 2.6.16.20v2.6.16.20Chris Wright
2006-06-05[PATCH] sbp2: fix check of return value of hpsb_allocate_and_register_addrspaceStefan Richter
I added a failure check in patch "sbp2: variable status FIFO address (fix login timeout)" --- alas for a wrong error value. This is a bug since Linux 2.6.16. Leads to NULL pointer dereference if the call failed, and bogus failure handling if call succeeded. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-05[PATCH] sbp2: backport read_capacity workaround for iPodStefan Richter
There is a firmware bug in several Apple iPods which prevents access to these iPods under certain conditions. The disk size reported by the iPod is one sector too big. Once access to the end of the disk is attempted, the iPod becomes inaccessible. This problem has been known for USB iPods for some time and has recently been discovered to exist with FireWire/USB combo iPods too. This patch is derived from the fix in Linux 2.6.17, commit e9a1c52c7b19d10342226c12f170d7ab644427e2, to be applicable to 2.6.16.x without prerequisite patches. It hard-wires a workaround for three known affected model numbers (those of 4th generation iPod, iPod Photo, iPod mini). Note: This patch lacks Linux 2.6.17's ability to enable and disable the workaround via a module parameter. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-05[PATCH] x86_64: Don't do syscall exit tracing twiceAndi Kleen
This fixes a regression from the earlier DOS fix for non canonical IRET addresses. It broke UML. int_ret_from_syscall already does syscall exit tracing, so no need to do it again in the caller. This caused problems for UML and some other special programs doing syscall interception. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-05[PATCH] x86_64: x86_64 add crashdump trigger pointsVivek Goyal
o Start booting into the capture kernel after an Oops if system is in a unrecoverable state. System will boot into the capture kernel, if one is pre-loaded by the user, and capture the kernel core dump. o One of the following conditions should be true to trigger the booting of capture kernel. - panic_on_oops is set. - pid of current thread is 0 - pid of current thread is 1 - Oops happened inside interrupt context. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-05[PATCH] ipw2200: Filter unsupported channels out in ad-hoc modeZhu Yi
Currently iwlist ethX freq[uency]/channel lists all the channels the card supported for the current region, which includes some channels can only be used in infrastructure mode. This patch filters these channels out if the card is currently in ad-hoc mode. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-05[PATCH] the latest consensus libata resume fixMark Lord
Okay, just to sum things up. This forces libata to wait for up to 2 seconds for BUSY|DRQ to clear on resume before continuing. [jgarzik adds...] During testing we never saw DRQ asserted, but nonetheless (a) this works and (b) testing for DRQ won't hurt. Signed-off-by: Mark Lord <liml@rtr.ca> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-05[PATCH] ohci1394, sbp2: fix "scsi_add_device failed" with PL-3507 based devicesStefan Richter
Re-enable posted writes for status FIFO. Besides bringing back a very minor bandwidth tweak from Linux 2.6.15.x and older, this also fixes an interoperability regression since 2.6.16: http://bugzilla.kernel.org/show_bug.cgi?id=6356 (sbp2: scsi_add_device failed. IEEE1394 HD is not working anymore.) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Vanei Heidemann <linux@javanei.com.br> Tested-by: Martin Putzlocher <mputzi@gmx.de> (chip type unconfirmed) Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-05[PATCH] Input: psmouse - fix new device detection logicDmitry Torokhov
Input: psmouse - fix new device detection logic Reported to fix http://bugs.gentoo.org/130846 Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Daniel Drake <dsd@gentoo.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-05[PATCH] PowerMac: force only suspend-to-disk to be validJohannes Berg
For a very long time, echoing 'standby' or 'mem' into /sys/power/state has killed the machine on powerpc. This patch fixes that. This patch adds the .valid callback to pm_ops on PowerMac so that only the suspend to disk state can be entered. Note that just returning 0 would suffice since the upper layers don't pass PM_SUSPEND_DISK down, but we handle it there regardless just in case that changes. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-05[PATCH] Cpuset: might sleep checking zones allowed fixPaul Jackson
Fix an infrequently encountered 'sleeping function called from invalid context' in the cpuset hooks in __alloc_pages. Could sleep while interrupts disabled. The routine cpuset_zone_allowed() is called by code in mm/page_alloc.c __alloc_pages() to determine if a zone is allowed in the current tasks cpuset. This routine can sleep, for certain GFP_KERNEL allocations, if the zone is on a memory node not allowed in the current cpuset, but might be allowed in a parent cpuset. But we can't sleep in __alloc_pages() if in interrupt, nor if called for a GFP_ATOMIC request (__GFP_WAIT not set in gfp_flags). The rule was intended to be: Don't call cpuset_zone_allowed() if you can't sleep, unless you pass in the __GFP_HARDWALL flag set in gfp_flag, which disables the code that might scan up ancestor cpusets and sleep. This rule was being violated due to a bogus change made (by myself, pj) to __alloc_pages() as part of the November 2005 effort to cleanup its logic. The bogus change can be seen at: http://linux.derkeiler.com/Mailing-Lists/Kernel/2005-11/4691.html [PATCH 01/05] mm fix __alloc_pages cpuset ALLOC_* flags This was first noticed on a tight memory system, in code that was disabling interrupts and doing allocation requests with __GFP_WAIT not set, which resulted in __might_sleep() writing complaints to the log "Debug: sleeping function called ...", when the code in cpuset_zone_allowed() tried to take the callback_sem cpuset semaphore. Special thanks to Dave Chinner, for figuring this out, and a tip of the hat to Nick Piggin who warned me of this back in Nov 2005, before I was ready to listen. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-05[PATCH] Altix: correct ioc3 port orderPat Gefre
Currently loading the ioc3 as a module will cause the ports to be numbered in reverse order. This mod maintains the proper order of cards for port numbering. Signed-off-by: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-05[PATCH] Altix: correct ioc4 port orderBrent Casavant
Currently loading the ioc4 as a module will cause the ports to be numbered in reverse order. This mod maintains the proper order of cards for port numbering. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Cc: Pat Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-30Linux 2.6.16.19v2.6.16.19Chris Wright
2006-05-30[PATCH] NETFILTER: Fix small information leak in SO_ORIGINAL_DST (CVE-2006-1343)Marcel Holtmann
It appears that sockaddr_in.sin_zero is not zeroed during getsockopt(...SO_ORIGINAL_DST...) operation. This can lead to an information leak (CVE-2006-1343). Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-22Linux 2.6.16.18v2.6.16.18Chris Wright
2006-05-22[PATCH] NETFILTER: SNMP NAT: fix memory corruption (CVE-2006-2444)Patrick McHardy
CVE-2006-2444 - Potential remote DoS in SNMP NAT helper. Fix memory corruption caused by snmp_trap_decode: - When snmp_trap_decode fails before the id and address are allocated, the pointers contain random memory, but are freed by the caller (snmp_parse_mangle). - When snmp_trap_decode fails after allocating just the ID, it tries to free both address and ID, but the address pointer still contains random memory. The caller frees both ID and random memory again. - When snmp_trap_decode fails after allocating both, it frees both, and the callers frees both again. The corruption can be triggered remotely when the ip_nat_snmp_basic module is loaded and traffic on port 161 or 162 is NATed. Found by multiple testcases of the trap-app and trap-enc groups of the PROTOS c06-snmpv1 testsuite. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20Linux 2.6.16.17v2.6.16.17Chris Wright
2006-05-20[PATCH] SCTP: Validate the parameter length in HB-ACK chunk (CVE-2006-1857)Vladislav Yasevich
If SCTP receives a badly formatted HB-ACK chunk, it is possible that we may access invalid memory and potentially have a buffer overflow. We should really make sure that the chunk format is what we expect, before attempting to touch the data. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] SCTP: Respect the real chunk length when walking parameters ↵Vladislav Yasevich
(CVE-2006-1858) When performing bound checks during the parameter processing, we want to use the real chunk and paramter lengths for bounds instead of the rounded ones. This prevents us from potentially walking of the end if the chunk length was miscalculated. We still use rounded lengths when advancing the pointer. This was found during a conformance test that changed the chunk length without modifying parameters. (Vlad noted elsewhere: the most you'd overflow is 3 bytes, so problem is parameter dependent). Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] ptrace_attach: fix possible deadlock schenario with irqsLinus Torvalds
Eric Biederman points out that we can't take the task_lock while holding tasklist_lock for writing, because another CPU that holds the task lock might take an interrupt that then tries to take tasklist_lock for writing. Which would be a nasty deadlock, with one CPU spinning forever in an interrupt handler (although admittedly you need to really work at triggering it ;) Since the ptrace_attach() code is special and very unusual, just make it be extra careful, and use trylock+repeat to avoid the possible deadlock. Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-20[PATCH] Fix ptrace_attach()/ptrace_traceme()/de_thread() raceLinus Torvalds
This holds the task lock (and, for ptrace_attach, the tasklist_lock) over the actual attach event, which closes a race between attacking to a thread that is either doing a PTRACE_TRACEME or getting de-threaded. Thanks to Oleg Nesterov for reminding me about this, and Chris Wright for noticing a lost return value in my first version. Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-20[PATCH] page migration: Fix fallback behavior for dirty pagesChristoph Lameter
Currently we check PageDirty() in order to make the decision to swap out the page. However, the dirty information may be only be contained in the ptes pointing to the page. We need to first unmap the ptes before checking for PageDirty(). If unmap is successful then the page count of the page will also be decreased so that pageout() works properly. This is a fix necessary for 2.6.17. Without this fix we may migrate dirty pages for filesystems without migration functions. Filesystems may keep pointers to dirty pages. Migration of dirty pages can result in the filesystem keeping pointers to freed pages. Unmapping is currently not be separated out from removing all the references to a page and moving the mapping. Therefore try_to_unmap will be called again in migrate_page() if the writeout is successful. However, it wont do anything since the ptes are already removed. The coming updates to the page migration code will restructure the code so that this is no longer necessary. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] add migratepage address space op to shmemLee Schermerhorn
Basic problem: pages of a shared memory segment can only be migrated once. In 2.6.16 through 2.6.17-rc1, shared memory mappings do not have a migratepage address space op. Therefore, migrate_pages() falls back to default processing. In this path, it will try to pageout() dirty pages. Once a shared memory page has been migrated it becomes dirty, so migrate_pages() will try to page it out. However, because the page count is 3 [cache + current + pte], pageout() will return PAGE_KEEP because is_page_cache_freeable() returns false. This will abort all subsequent migrations. This patch adds a migratepage address space op to shared memory segments to avoid taking the default path. We use the "migrate_page()" function because it knows how to migrate dirty pages. This allows shared memory segment pages to migrate, subject to other conditions such as # pte's referencing the page [page_mapcount(page)], when requested. I think this is safe. If we're migrating a shared memory page, then we found the page via a page table, so it must be in memory. Can be verified with memtoy and the shmem-mbind-test script, both available at: http://free.linux.hp.com/~lts/Tools/ Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] Remove cond_resched in gather_stats()Christoph Lameter
gather_stats() is called with a spinlock held from check_pte_range. We cannot reschedule with a lock held. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] VIA quirk fixup, additional PCI IDsChris Wedgwood
An earlier commit (75cf7456dd87335f574dcd53c4ae616a2ad71a11) changed an overly-zealous PCI quirk to only poke those VIA devices that need it. However, some PCI devices were not included in what I hope is now the full list. Consequently we're failing to run the quirk on all machines which need it, causing IRQ routing failures. This should I hope correct this. Thanks to Masoud Sharbiani <masouds@masoud.ir> for pointing this out and testing the fix. Signed-off-by: Chris Wedgwood <cw@f00f.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] PCI quirk: VIA IRQ fixup should only run for VIA southbridgesChris Wedgwood
Alan Cox pointed out that the VIA 'IRQ fixup' was erroneously running on my system which has no VIA southbridge (but I do have a VIA IEEE 1394 device). This should address that. I also changed "Via IRQ" to "VIA IRQ" (initially I read Via as a capitalized via (by way/means of). Signed-off-by: Chris Wedgwood <cw@f00f.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] Fix udev device creationHarald Welte
This patch corrects the order of the calls to register_chrdev() and pcmcia_register_driver(). Now udev correctly creates userspace device files /dev/cmmN and /dev/cmxN respectively. Based on an earlier patch by Jan Niehusmann <jan@gondor.com>. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] limit request_fn recursionJens Axboe
Don't recurse back into the driver even if the unplug threshold is met, when the driver asks for a requeue. This is both silly from a logical point of view (requeues typically happen due to driver/hardware shortage), and also dangerous since we could hit an endless request_fn -> requeue -> unplug -> request_fn loop and crash on stack overrun. Also limit blk_run_queue() to one level of recursion, similar to how blk_start_queue() works. This patch fixed a real problem with SLES10 and lpfc, and it could hit any SCSI lld that returns non-zero from it's ->queuecommand() handler. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
