2006-11-15Linux 2.6.16.32v2.6.16.32Adrian Bunk
2006-11-11Linux 2.6.16.32-rc1v2.6.16.32-rc1Adrian Bunk
2006-11-11Fix longstanding load balancing bug in the schedulerChristoph Lameter
The scheduler will stop load balancing if the most busy processor contains processes pinned via processor affinity. The scheduler currently only does one search for busiest cpu. If it cannot pull any tasks away from the busiest cpu because they were pinned then the scheduler goes into a corner and sulks leaving the idle processors idle. F.e. If you have processor 0 busy running four tasks pinned via taskset, there are none on processor 1 and one just started two processes on processor 2 then the scheduler will not move one of the two processes away from processor 2. This patch fixes that issue by forcing the scheduler to come out of its corner and retrying the load balancing by considering other processors for load balancing. This patch was originally developed by John Hawkes and discussed at http://marc.theaimsgroup.com/?l=linux-kernel&m=113901368523205&w=2. I have removed extraneous material and gone back to equipping struct rq with the cpu the queue is associated with since this makes the patch much easier and it is likely that others in the future will have the same difficulty of figuring out which processor owns which runqueue. The overhead added through these patches is a single word on the stack if the kernel is configured to support 32 cpus or less (32 bit). For 32 bit environments the maximum number of cpus that can be configued is 255 which would result in the use of 32 bytes additional on the stack. On IA64 up to 1k cpus can be configured which will result in the use of 128 additional bytes on the stack. The maximum additional cache footprint is one cacheline. Typically memory use will be much less than a cacheline and the additional cpumask will be placed on the stack in a cacheline that already contains other local variable. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-11sata_sil24: add a new PCI ID for SiI 3124Tejun Heo
Add a new PCI ID for SiI 3124. Reported by Silicon Image. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-11ia64/sparc: fix local DoS with corrupted ELFs (CVE-2006-4538)Kirill Korotaev
This patch prevents cross-region mappings on IA64 and SPARC which could lead to system crash. Adrian Bunk: Adapted to 2.6.16. Signed-Off-By: Kirill Korotaev <dev@openvz.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-11nvidia fbdev: fix powerpc xmon scribblesPaul Mackerras
xmon writes garbage on the screen because the nvidia console driver has changed the line pitch from what the firmware set it to. Fix it by making the nvidia driver inform the btext engine (which xmon uses if the screen is its output device) about changes to display resolution. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-11[POWERPC] Fix return value from memcpyPaul Mackerras
As pointed out by Herbert Xu <herbert@gondor.apana.org.au>, our memcpy implementation didn't return the destination pointer as its return value, and there is code in the kernel that expects that. This fixes it. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-11[NET]: Update frag_list in pskb_trimHerbert Xu
When pskb_trim has to defer to ___pksb_trim to trim the frag_list part of the packet, the frag_list is not updated to reflect the trimming. This will usually work fine until you hit something that uses the packet length or tail from the frag_list. Examples include esp_output and ip_fragment. Another problem caused by this is that you can end up with a linear packet with a frag_list attached. It is possible to get away with this if we audit everything to make sure that they always consult skb->len before going down onto frag_list. In fact we can do the samething for the paged part as well to avoid copying the data area of the skb. For now though, let's do the conservative fix and update frag_list. Many thanks to Marco Berizzi for helping me to track down this bug. This 4-year old bug took 3 months to track down. Marco was very patient indeed :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-11scx200_acb: Fix the block transactionsJean Delvare
The scx200_acb i2c bus driver pretends to support SMBus block transactions, but in fact it implements the more simple I2C block transactions. Additionally, it lacks sanity checks on the length of the block transactions, which could lead to a buffer overrun. This fixes an oops reported by Alexander Atanasov: http://marc.theaimsgroup.com/?l=linux-kernel&m=114970382125094 Thanks to Ben Gardner for fixing my bugs :) Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-11Fix the scx200_acb state machine:Thomas Andrews
* Nack was sent one byte too late on reads >= 2 bytes. * Stop bit was set one byte too late on reads. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-09drivers/video/nvidia/nvidia.c: Add ID for Quadro NVS280Pavel Roskin
Quadro NVS280 is a dual-head PCIe card with PCI ID 10de:00fd and subsystem I 10de:0215. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-09[DISKLABEL] SUN: Fix signed int usage for sector countJeff Mahoney
The current sun disklabel code uses a signed int for the sector count. When partitions larger than 1 TB are used, the cast to a sector_t causes the partition sizes to be invalid: # cat /proc/paritions | grep sdan 66 112 2146435072 sdan 66 115 9223372036853660736 sdan3 66 120 9223372036853660736 sdan8 This patch switches the sector count to an unsigned int to fix this. Eric Sandeen also submitted the same patch. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-09[NET]: __alloc_pages() failures reported due to fragmentationLarry Woodman
We have seen a couple of __alloc_pages() failures due to fragmentation, there is plenty of free memory but no large order pages available. I think the problem is in sock_alloc_send_pskb(), the gfp_mask includes __GFP_REPEAT but its never used/passed to the page allocator. Shouldnt the gfp_mask be passed to alloc_skb() ? Signed-off-by: Larry Woodman <lwoodman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-09[NET]: Set truesize in pskb_copyHerbert Xu
Since pskb_copy tacks on the non-linear bits from the original skb, it needs to count them in the truesize field of the new skb. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-09[TCP]: Don't use highmem in tcp hash size calculation.John Heffner
This patch removes consideration of high memory when determining TCP hash table sizes. Taking into account high memory results in tcp_mem values that are too large. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-09[AGPGART] remove unused variableAdrian Bunk
This patch removes an unused variable. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Jones <davej@redhat.com>
2006-11-09[AGPGART] Suspend/Resume support for nVidia nForce AGP.Dave Jones
Based on a patch from the Ubuntu kernel. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-09drivers/telephony/ixj: fix an array overrunAdrian Bunk
The Coverity checker noted that in drivers/telephony/ixj.c:ixj_build_filter_cadence(), filter_en[4] or filter_en[5] could be written to. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-08nvidiafb: Add support for Geforce 6100 and related chipsetsAntonino Daplas
Add support for Geforce 6100 and related chipsets (PCI device id 0x024x) Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-08drivers/md/md.c: update START_ARRAY printkAdrian Bunk
START_ARRAY will not be removed in 2.6.16, therefore replace the date reference with a kernel version reference. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-08remove Documentation/feature-removal-schedule.txtAdrian Bunk
The information in Documentation/feature-removal-schedule.txt doesn't apply to the 2.6.16 branch (and most dates were already in the past. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-08[IPV4]: Limit rt cache size properly.Kirill Korotaev
During OpenVZ stress testing we found that UDP traffic with random src can generate too much excessive rt hash growing leading finally to OOM and kernel panics. It was found that for 4GB i686 system (having 1048576 total pages and 225280 normal zone pages) kernel allocates the following route hash: syslog: IP route cache hash table entries: 262144 (order: 8, 1048576 bytes) => ip_rt_max_size = 4194304 entries, i.e. max rt size is 4194304 * 256b = 1Gb of RAM > normal_zone Attached the patch which removes HASH_HIGHMEM flag from alloc_large_system_hash() call. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-08Don't allow chmod() on the /proc/<pid>/ filesMarcel Holtmann
This just turns off chmod() on the /proc/<pid>/ files, since there is no good reason to allow it, and had we disallowed it originally, the nasty /proc race exploit wouldn't have been possible. The other patches already fixed the problem chmod() could cause, so this is really just some final mop-up.. This particular version is based off a patch by Eugene and Marcel which had much better naming than my original equivalent one. Signed-off-by: Eugene Teo <eteo@redhat.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-08fbdev: correct buffer size limit in fbmem_read_proc()Geert Uytterhoeven
Address http://bugzilla.kernel.org/show_bug.cgi?id=7189 It should check `clen', not `len'. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-08[NET]: Add missing UFO initialisationsHerbert Xu
This bug was unknowingly fixed the GSO patches (or rather, its effect was unknown at the time). Thanks to Marco Berizzi's persistence which is documented in the thread "ipsec tunnel asymmetrical mtu", we now know that it can have highly non-obvious symptoms. What happens is that uninitialised uso_size fields can cause packets to be incorrectly identified as UFO, which means that it does not get fragmented even if it's over the MTU. The fix is simple enough. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-07 from mm/memory.c:Dmitriy Monakhov
1434 static inline void cow_user_page(struct page *dst, struct page *src, unsigned long va) 1435 { 1436 /* 1437 * If the source page was a PFN mapping, we don't have 1438 * a "struct page" for it. We do a best-effort copy by 1439 * just copying from the original user address. If that 1440 * fails, we just zero-fill it. Live with it. 1441 */ 1442 if (unlikely(!src)) { 1443 void *kaddr = kmap_atomic(dst, KM_USER0); 1444 void __user *uaddr = (void __user *)(va & PAGE_MASK); 1445 1446 /* 1447 * This really shouldn't fail, because the page is there 1448 * in the page tables. But it might just be unreadable, 1449 * in which case we just give up and fill the result with 1450 * zeroes. 1451 */ 1452 if (__copy_from_user_inatomic(kaddr, uaddr, PAGE_SIZE)) 1453 memset(kaddr, 0, PAGE_SIZE); 1454 kunmap_atomic(kaddr, KM_USER0); #### D-cache have to be flushed here. #### It seems it is just forgotten. 1455 return; 1456 1457 } 1458 copy_user_highpage(dst, src, va); #### Ok here. flush_dcache_page() called from this func if arch need it 1459 } Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-07[MAINTAINERS]: Add proper entry for TC classifierStephen Hemminger
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-07[PKT_SCHED]: act_api: Fix module leak while flushing actionsThomas Graf
Module reference needs to be given back if message header construction fails. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-07PKT_SCHED: Return ENOENT if action module is unavailableThomas Graf
Return ENOENT if action module is unavailable Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-07PKT_SCHED: Fix illegal memory dereferences when dumping actionsThomas Graf
The TCA_ACT_KIND attribute is used without checking its availability when dumping actions therefore leading to a value of 0x4 being dereferenced. The use of strcmp() in tc_lookup_action_n() isn't safe when fed with string from an attribute without enforcing proper NUL termination. Both bugs can be triggered with malformed netlink message and don't require any privileges. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-07PKT_SCHED: Fix error handling while dumping actionsThomas Graf
"return -err" and blindly inheriting the error code in the netlink failure exception handler causes errors codes to be returned as positive value therefore making them being ignored by the caller. May lead to sending out incomplete netlink messages. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-07[PATCH] md: Make sure bi_max_vecs is set properly in bio_splitNeil Brown
Else a subsequent bio_clone might make a mess. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-07[CPUFREQ] Fix powernow-k8 SMP kernel on UP hardware bug.Randy Dunlap
Fix powernow-k8 doesn't load bug. Reference: https://launchpad.net/distros/ubuntu/+source/linux-source-2.6.15/+bug/35145 Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-11-07[CPUFREQ] Make powernow-k7 work on SMP kernels.Dave Jones
Even though powernow-k7 doesn't work in SMP environments, it can work on an SMP configured kernel if there's only one CPU present, however recalibrate_cpu_khz was returning -EINVAL on such kernels, so we failed to init the cpufreq driver. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-07Linux 2.6.16.31v2.6.16.31Adrian Bunk
2006-11-05Linux 2.6.16.31-rc1v2.6.16.31-rc1Adrian Bunk
2006-11-05[NETFILTER]: Fix ip6_tables extension header bypass bug (CVE-2006-4572)Patrick McHardy
As reported by Mark Dowd <Mark_Dowd@McAfee.com>, ip6_tables is susceptible to a fragmentation attack causing false negatives on extension header matches. When extension headers occur in the non-first fragment after the fragment header (possibly with an incorrect nexthdr value in the fragment header) a rule looking for this extension header will never match. Drop fragments that are at offset 0 and don't contain the final protocol header regardless of the ruleset, since this should not happen normally. Since all extension headers are before the protocol header this makes sure an extension header is either not present or in the first fragment, where we can properly parse it. With help from Yasuyuki KOZAKAI <yasuyuki.kozakai@toshiba.co.jp>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05[NETFILTER]: Fix ip6_tables protocol bypass bug (CVE-2006-4572)Patrick McHardy
As reported by Mark Dowd <Mark_Dowd@McAfee.com>, ip6_tables is susceptible to a fragmentation attack causing false negatives on protocol matches. When the protocol header doesn't follow the fragment header immediately, the fragment header contains the protocol number of the next extension header. When the extension header and the protocol header are sent in a second fragment a rule like "ip6tables .. -p udp -j DROP" will never match. Drop fragments that are at offset 0 and don't contain the final protocol header regardless of the ruleset, since this should not happen normally. With help from Yasuyuki KOZAKAI <yasuyuki.kozakai@toshiba.co.jp>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05knfsd: Fix race that can disable NFS server.Neil Brown
This is a long standing bug that seems to have only recently become apparent, presumably due to increasing use of NFS over TCP - many distros seem to be making it the default. The SK_CONN bit gets set when a listening socket may be ready for an accept, just as SK_DATA is set when data may be available. It is entirely possible for svc_tcp_accept to be called with neither of these set. It doesn't happen often but there is a small race in svc_sock_enqueue as SK_CONN and SK_DATA are tested outside the spin_lock. They could be cleared immediately after the test and before the lock is gained. This normally shouldn't be a problem. The sockets are non-blocking so trying to read() or accept() when ther is nothing to do is not a problem. However: svc_tcp_recvfrom makes the decision "Should I accept() or should I read()" based on whether SK_CONN is set or not. This usually works but is not safe. The decision should be based on whether it is a TCP_LISTEN socket or a TCP_CONNECTED socket. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05posix-cpu-timers: prevent signal delivery starvationThomas Gleixner
The integer divisions in the timer accounting code can round the result down to 0. Adding 0 is without effect and the signal delivery stops. Clamp the division result to minimum 1 to avoid this. Problem was reported by Seongbae Park <spark@google.com>, who provided also an inital patch. Roland sayeth: I have had some more time to think about the problem, and to reproduce it using Toyo's test case. For the record, if my understanding of the problem is correct, this happens only in one very particular case. First, the expiry time has to be so soon that in cputime_t units (usually 1s/HZ ticks) it's < nthreads so the division yields zero. Second, it only affects each thread that is so new that its CPU time accumulation is zero so now+0 is still zero and ->it_*_expires winds up staying zero. For the VIRT and PROF clocks when cputime_t is tick granularity (or the SCHED clock on configurations where sched_clock's value only advances on clock ticks), this is not hard to arrange with new threads starting up and blocking before they accumulate a whole tick of CPU time. That's what happens in Toyo's test case. Note that in general it is fine for that division to round down to zero, and set each thread's expiry time to its "now" time. The problem only arises with thread's whose "now" value is still zero, so that now+0 winds up 0 and is interpreted as "not set" instead of ">= now". So it would be a sufficient and more precise fix to just use max(ticks, 1) inside the loop when setting each it_*_expires value. But, it does no harm to round the division up to one and always advance every thread's expiry time. If the thread didn't already fire timers for the expiry time of "now", there is no expectation that it will do so before the next tick anyway. So I followed Thomas's patch in lifting the max out of the loops. This patch also covers the reload cases, which are harder to write a test for (and I didn't try). I've tested it with Toyo's case and it fixes that. [toyoa@mvista.com: fix: min_t -> max_t] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05[IPV6]: fix lockup via /proc/net/ip6_flowlabel (CVE-2006-5619)James Morris
There's a bug in the seqfile handling for /proc/net/ip6_flowlabel, where, after finding a flowlabel, the code will loop forever not finding any further flowlabels, first traversing the rest of the hash bucket then just looping. This patch fixes the problem by breaking after the hash bucket has been traversed. Note that this bug can cause lockups and oopses, and is trivially invoked by an unpriveleged user. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05ACPI: enable SMP C-states on x86_64Shaohua Li
http://bugzilla.kernel.org/show_bug.cgi?id=5653 Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05fix RARP ic_servaddr breakageAl Viro
memcpy 4 bytes to address of auto unsigned long variable followed by comparison with u32 is a bloody bad idea. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05[S390] fix user readable uninitialised kernel memory, take 2.Martin Schwidefsky
The previous patch to correct the copy_from_user padding is quite broken. The execute instruction needs to be done via the register %r4, not via %r2 and 31 bit doesn't know the instructions lgr and ahji. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05[S390] fix user readable uninitialised kernel memory (CVE-2006-5174)Martin Schwidefsky
A user space program can read uninitialised kernel memory by appending to a file from a bad address and then reading the result back. The cause is the copy_from_user function that does not clear the remaining bytes of the kernel buffer after it got a fault on the user space address. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-02Linux 2.6.16.30v2.6.16.30Adrian Bunk
2006-10-17Linux 2.6.16.30-rc1v2.6.16.30-rc1Adrian Bunk
2006-10-17[IA64] correct file descriptor reference counting in perfmon (CVE-2006-3741)Stephane Eranian
Fix a bug in sys_perfmonctl() whereby it was not correctly decrementing the file descriptor reference count. Signed-off-by: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14[PPPOE]: Advertise PPPoE MTUMichal Ostrowski
PPPoE must advertise the underlying device's MTU via the ppp channel descriptor structure, as multilink functionality depends on it. Signed-off-by: Michal Ostrowski <mostrows@earthlink.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14PKT_SCHED: cls_basic: Use unsigned int when generating handleKim Nordlund
Prevents filters from being added if the first generated handle already exists. Signed-off-by: Kim Nordlund <kim.nordlund@nokia.com> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Adrian Bunk <bunk@stusta.de>
