2007-02-10Linux 2.6.16.40v2.6.16.40Adrian Bunk
2007-02-03Linux 2.6.16.40-rc1v2.6.16.40-rc1Adrian Bunk
2007-02-03reiserfs: avoid tail packing if an inode was ever mmappedVladimir Saveliev
This patch fixes a confusion reiserfs has for a long time. On release file operation reiserfs used to try to pack file data stored in last incomplete page of some files into metadata blocks. After packing the page got cleared with clear_page_dirty. It did not take into account that the page may be mmaped into other process's address space. Recent replacement for clear_page_dirty cancel_dirty_page found the confusion with sanity check that page has to be not mapped. The patch fixes the confusion by making reiserfs avoid tail packing if an inode was ever mmapped. reiserfs_mmap and reiserfs_file_release are serialized with mutex in reiserfs specific inode. reiserfs_mmap locks the mutex and sets a bit in reiserfs specific inode flags. reiserfs_file_release checks the bit having the mutex locked. If bit is set - tail packing is avoided. This eliminates a possibility that mmapped page gets cancel_page_dirty-ed. Signed-off-by: Vladimir Saveliev <vs@namesys.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03[libata] use kmap_atomic(KM_IRQ0) in SCSI simulatorJeff Garzik
We are inside spin_lock_irqsave(). quoth akpm's debug facility: [ 231.948000] SCSI device sda: 195371568 512-byte hdwr sectors (100030 MB) [ 232.232000] ata1.00: configured for UDMA/33 [ 232.404000] WARNING (1) at arch/i386/mm/highmem.c:47 kmap_atomic() [ 232.404000] [<c01162e6>] kmap_atomic+0xa9/0x1ab [ 232.404000] [<c0242c81>] ata_scsi_rbuf_get+0x1c/0x30 [ 232.404000] [<c0242caf>] ata_scsi_rbuf_fill+0x1a/0x87 [ 232.404000] [<c0243ab2>] ata_scsiop_mode_sense+0x0/0x309 [ 232.404000] [<c01729d5>] end_bio_bh_io_sync+0x0/0x37 [ 232.404000] [<c02311c6>] scsi_done+0x0/0x16 [ 232.404000] [<c02311c6>] scsi_done+0x0/0x16 [ 232.404000] [<c0242dcc>] ata_scsi_simulate+0xb0/0x13f [...] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03ia64: add pci_get_legacy_ide_irq()Bartlomiej Zolnierkiewicz
Add pci_get_legacy_ide_irq() identical to the one used by i386/x86_64. Fixes amd74xx driver build on ia64 (bugzilla bug #6644). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03hwmon: Update Rudolf Marek's e-mail addressRudolf Marek
The Silicon Hill club is not what it used to be. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03k8temp: Documentation updateRudolf Marek
Update the documentation for the k8temp driver. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03k8temp: Add documentationRudolf Marek
Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03Make 'repair' actually work for raid1.Neil Brown
When 'repair' finds a block that is different one the various parts of the mirror. it is meant to write a chosen good version to the others. However it currently writes out the original data to each. The memcpy to make all the data the same is missing. Also correct a test so that 'repair' causes a repair, rather than anything other then 'repair'. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30hwmon: New driver k8tempRudolf Marek
Add support for the temperature sensor(s) found in AMD K8 CPUs. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30[SCSI] arcmsr: fix up sysfs valuesJames Bottomley
The sysfs files in arcmsr are non-standard in that they aren't simple filename value pairs, the values actually contain preceeding text which would have to be parsed. The idea of sysfs files is that the file name is the description and the contents is a simple value. Fix up arcmsr to conform to this standard. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30[SCSI] areca sysfs fixAndrew Morton
Remove sysfs_remove_bin_file() return-value checking from the areca driver. There's nothing a driver can do if sysfs file removal fails, so we'll soon be changing sysfs_remove_bin_file() to internally print a diagnostic and to return void. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30[SCSI] arcmsr: initial driver, version 1.20.00.13Erich Chen
arcmsr is a driver for the Areca Raid controller, a host based RAID subsystem that speaks SCSI at the firmware level. This patch is quite a clean up over the initial submission with contributions from: Randy Dunlap <rdunlap@xenotime.net> Christoph Hellwig <hch@lst.de> Matthew Wilcox <matthew@wil.cx> Adrian Bunk <bunk@stusta.de> Signed-off-by: Erich Chen <erich@areca.com.tw> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30Linux 2.6.16.39v2.6.16.39Adrian Bunk
2007-01-26Linux 2.6.16.39-rc1v2.6.16.39-rc1Adrian Bunk
2007-01-26[Bluetooth] Fix deadlock in the L2CAP layerMarcel Holtmann
The Bluetooth L2CAP layer has 2 locks that are used in softirq context, (one spinlock and one rwlock, where the softirq usage is readlock) but where not all usages of the lock were _bh safe. The patch below corrects this. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-26[Bluetooth] Add locking for bt_proto array manipulationMarcel Holtmann
The bt_proto array needs to be protected by some kind of locking to prevent a race condition between bt_sock_create and bt_sock_register. And in addition all calls to sk_alloc need to be made GFP_ATOMIC now. Signed-off-by: Masatake YAMATO <jet@gyve.org> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-26[Bluetooth] Fix compat ioctl for BNEP, CMTP and HIDPMarcel Holtmann
There exists no attempt do deal with the fact that a structure with a uint32_t followed by a pointer is going to be different for 32-bit and 64-bit userspace. Any 32-bit process trying to use it will be failing with -EFAULT if it's lucky; suffering from having data dumped at a random address if it's not. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-26[Bluetooth] Handle command complete event for exit periodic inquiryMarcel Holtmann
The command complete event of the exit periodic inquiry command must clear the HCI_INQUIRY flag and finish the HCI request. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-26[Bluetooth] Return EINPROGRESS for non-blocking socket callsMarcel Holtmann
In case of non-blocking socket calls we should return EINPROGRESS and not EAGAIN. Signed-off-by: Ulisses Furquim <ulissesf@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-26kbuild: explicitly turn off gcc stack-protectorAdrian Bunk
Ubuntu has enabled -fstack-protector per default in gcc breaking kernel build. Explicit turn it off for now. Backported based on several patches by Sam Ravnborg <sam@ravnborg.org>. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-25[Bluetooth] Fix uninitialized return value for RFCOMM sendmsg()Marcel Holtmann
When calling send() with a zero length parameter on a RFCOMM socket it returns a positive value. In this rare case the variable err is used uninitialized and unfortunately its value is returned. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-25[Bluetooth] More checks if DLC is still attached to the TTYMarcel Holtmann
If the DLC device is no longer attached to the TTY device, then return errors or default values for various callbacks of the TTY layer. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-25BLUETOOTH: Fix unaligned access in hci_send_to_sock.David S. Miller
The "u16 *" derefs of skb->data need to be wrapped inside of a get_unaligned(). Thanks to Gustavo Zacarias for the bug report. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-25[Bluetooth] Check if DLC is still attached to the TTYMarcel Holtmann
If the DLC device is no longer attached to the TTY device, then it makes no sense to go through with changing the termios settings. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-25sparc32: add offset in pci_map_sg()Jan Andersson
Add sg->offset to sg->dvma_address in pci_map_sg() on sparc32. Without the offset, transfers to buffers that do not begin on a page boundary will not work as expected. Signed-off-by: Jan Andersson <jan.andersson@ieee.org> Acked-By: David Miller <davem@davemloft.net>
2007-01-25V4L/DVB: Missing statement in drivers/media/dvb/frontends/cx22700.cEric Sesterhenn
Stumbled over this because of coverity (id #492), seems like we are missing a return statement here and fail to do proper bounds checking. If this assumption is false we should at least change the identation to make it clear Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-24V4L/DVB: Flexcop-usb: fix debug printkAlexey Dobriyan
.. fix debug printk. Why, oh why, one would want to do (u16 & 0xff) << 8 and print it with %02x format? Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-24V4L/DVB: Fix uninitialised variable in dvb_frontend_swzigzagAndrew de Quincey
Spotted by coverity/Adrian Bunk. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-24[Bluetooth] Let BT_HIDP depend on INPUTAdrian Bunk
This patch lets BT_HIDP depend on instead of select INPUT. This fixes the following warning during an s390 build: net/bluetooth/hidp/Kconfig:4:warning: 'select' used by config symbol 'BT_HIDP' refer to undefined symbol 'INPUT' A dependency on INPUT also implies !S390 (and therefore makes the explicit dependency obsolete) since INPUT is not available on s390. The practical difference should be nearly zero, since INPUT is always set to y unless EMBEDDED=y (or S390=y). Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-23i386: fix CPU hotplug with 2GB VMSPLITShaohua Li
In VMSPLIT mode, kernel PGD might have more entries than user space Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-23read_zero_pagealigned() locking fixHugh Dickins
Ramiro Voicu hits the BUG_ON(!pte_none(*pte)) in zeromap_pte_range: kernel bugzilla 7645. Right: read_zero_pagealigned uses down_read of mmap_sem, but another thread's racing read of /dev/zero, or a normal fault, can easily set that pte again, in between zap_page_range and zeromap_page_range getting there. It's been wrong ever since 2.4.3. The simple fix is to use down_write instead, but that would serialize reads of /dev/zero more than at present: perhaps some app would be badly affected. So instead let zeromap_page_range return the error instead of BUG_ON, and read_zero_pagealigned break to the slower clear_user loop in that case - there's no need to optimize for it. Use -EEXIST for when a pte is found: BUG_ON in mmap_zero (the other user of zeromap_page_range), though it really isn't interesting there. And since mmap_zero wants -EAGAIN for out-of-memory, the zeromaps better return that than -ENOMEM. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22atiixp: hang fixAlan Cox
When the old IDE layer calls into methods in the driver during error handling it is essentially random whether ide_lock is already held. This causes a deadlock in the atiixp driver which also uses ide_lock internally for locking. Switch to a private lock instead. [akpm@osl.org: cleanup] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22cdrom: set default timeout to 7 secondsJens Axboe
It's a known fact that Windows times out commands after 7 seconds, so drives generally try and respond if they can before that happens. We default to 5 seconds, which sometimes is a bit too short. Jeremy Higdon reported here: http://lkml.org/lkml/2007/1/1/145 that his drive takes longer than 5 seconds for a "read track information" command, later confirming that it is about 6.7 seconds. So just do the sane thing and change the default command timeout to 7 seconds to avoid other surprises. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22[SCSI] qla1280 bus reset typoJes Sorensen
Fix typo in check of return value of qla1280_bus_reset() which would result in an adapter reset in addition to the bus reset. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22[SCSI] qla1280 command timeoutJes Sorensen
Original patch from Ian Dall in bugzilla. Set command timeout as specified by the SCSI layer rather than hardcode it to 30 seconds. I have received a couple of reports of people hitting this one with various tape configurations and the patch looks obviously correct. From http://bugzilla.kernel.org/show_bug.cgi?id=6275 Ian Dall <ian@beware.dropbear.id.au>: The command sent to the card was using a 30second timeout regardless of the timeout requested in the scsi command passed down from higher levels. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22adfs: fix filename handlingJames Bursa
Fix filenames on adfs discs being terminated at the first character greater than 128 (adfs filenames are Latin 1). I saw this problem when using a loopback adfs image on a 2.6.17-rc5 x86_64 machine, and the patch fixed it there. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22s390: connector supportMartin Schwidefsky
Include connector config in the s390 arch Kconfig to get support for connectors. This also fixes the following Kconfig warning: fs/Kconfig:1728:warning: 'select' used by config symbol 'CIFS_UPCALL' refer to undefined symbol 'CONNECTOR' Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22NETFILTER: arp_tables: missing unregistration on module unloadPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-20NETFILTER: NAT: fix NOTRACK checksum handlingPatrick McHardy
The whole idea with the NOTRACK netfilter target is that you can force the netfilter code to avoid connection tracking, and all costs assosciated with it, by making traffic match a NOTRACK rule. But this is totally broken by the fact that we do a checksum calculation over the packet before we do the NOTRACK bypass check, which is very expensive. People setup NOTRACK rules explicitly to avoid all of these kinds of costs. This patch from Patrick, already in Linus's tree, fixes the bug. Move the check for ip_conntrack_untracked before the call to skb_checksum_help to fix NOTRACK excemptions from NAT. Pre-2.6.19 NAT code breaks TSO by invalidating hardware checksums for every packet, even if explicitly excluded from NAT through NOTRACK. 2.6.19 includes a fix that makes NAT and TSO live in harmony, but the performance degradation caused by this deserves making at least the workaround work properly in -stable. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-20mm: fix bug in set_page_dirty_buffersNick Piggin
This was triggered, but not the fault of, the dirty page accounting patches. Suitable for -stable as well, after it goes upstream. Unable to handle kernel NULL pointer dereference at virtual address 0000004c EIP is at _spin_lock+0x12/0x66 Call Trace: [<401766e7>] __set_page_dirty_buffers+0x15/0xc0 [<401401e7>] set_page_dirty+0x2c/0x51 [<40140db2>] set_page_dirty_balance+0xb/0x3b [<40145d29>] __do_fault+0x1d8/0x279 [<40147059>] __handle_mm_fault+0x125/0x951 [<401133f1>] do_page_fault+0x440/0x59f [<4034d0c1>] error_code+0x39/0x40 [<08048a33>] 0x8048a33 ======================= Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-20Linux 2.6.16.38v2.6.16.38Adrian Bunk
2007-01-18Linux 2.6.16.38-rc2v2.6.16.38-rc2Adrian Bunk
2007-01-18[IPV6] Fix joining all-node multicast group.YOSHIFUJI Hideaki
2007-01-14UML: fix the MODE_TT compilationPaolo 'Blaisorblade' Giarrusso
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09Linux 2.6.16.38-rc1v2.6.16.38-rc1Adrian Bunk
2007-01-09x86_64: re-add a newline to RESTORE_CONTEXTAdrian Bunk
RESTORE_CONTEXT lost a newline: http://www.mail-archive.com/kgdb-bugreport@lists.sourceforge.net/msg00559.html Reported by Steven M. Christey. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09ALSA: snd_rtctimer: handle RTC interrupts with a taskletClemens Ladisch
The calls to rtc_control() from inside the interrupt handler can deadlock the RTC code, so move our interrupt handling code to a tasklet. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Acked-By: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09ALSA: emu10k1: Fix outl() in snd_emu10k1_resume_regs()Arnaud Patard
The emu10k1 driver saves the A_IOCFG and HCFG register on suspend and restores it on resumes. Unfortunately, this doesn't work as the arguments to outl() are reversed. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09ALSA: Fix initiailization of user-space controlsTakashi Iwai
Fix an assertion when accessing a user-defined control due to lack of initialization (appears only when CONFIG_SND_DEBUg is enabled). ALSA sound/core/control.c:660: BUG? (info->access == 0) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
