psmouse_show_int_attr() and psmouse_set_int_attr() were accessing
unsigned int fields as unsigned long, which gave garbage on x86_64.
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
Commit 2b48716d1d2f2edb1e7cbc5ecf1cb2cb39373e33 back in January
2006 was a bit overzealous. It removed .owner from all i2c drivers,
including i2c-isa ones, while they still need it.
Dave Jones wrote:
> sfuzz D 724EF62A 2828 28717 28691 (NOTLB)
> cd69fe98 00000082 0000012d 724ef62a 0001971a 00000010 00000007 df6d22b0
> dfd81080 725bbc5e 0001971a 000cc634 00000001 df6d23bc c140e260 00000202
> de1d5ba0 cd69fea0 de1d5ba0 00000000 00000000 de1d5b60 de1d5b8c de1d5ba0
> Call Trace:
> [<c05b1708>] lock_sock+0x75/0xa6
> [<e0b0b604>] dn_getname+0x18/0x5f [decnet]
> [<c05b083b>] sys_getsockname+0x5c/0xb0
> [<c05b0b46>] sys_socketcall+0xef/0x261
> [<c0403f97>] syscall_call+0x7/0xb
> DWARF2 unwinder stuck at syscall_call+0x7/0xb
> I wonder if the plethora of lockdep related changes inadvertantly broke something?
Looks like unbalanced locking.
Fix from http://bugzilla.kernel.org/show_bug.cgi?id=7747
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
This patch refactors SENSOR_DEVICE_ATTR_2 macro, following pattern set by
SENSOR_ATTR. First it creates a new macro SENSOR_ATTR_2() which expands
to an initialization expression, then it uses that in SENSOR_DEVICE_ATTR_2,
which declares and initializes a struct sensor_device_attribute_2.
Signed-off-by: Jim Cromie <jim.cromie@gmail.com>
This patch refactors SENSOR_DEVICE_ATTR macro. First it creates a new
macro SENSOR_ATTR() which expands to an initialization expression, then
it uses that in SENSOR_DEVICE_ATTR, which declares and initializes a
struct sensor_device_attribute.
IOW, SENSOR_ATTR() imitates __ATTR() in include/linux/device.h.
Put in new email address.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Update the pci device id table to match 2.6.20 (except for new 88e807x
that is still experimental).
This is a simple enhancement to dump more device statistics with ethtool.
Ben added this for 2.6.18, it allows sky2 to run on big endian.
The 802 standard allows pause frames to be either unicast or multicast.
Switches seem to send unicast frames, but on a direct link, other boards send
multicast pause. Unless the filter bit is set, these pause frames get
dropped.
Different chipsets have different amount of ram buffer (some have none),
so need to make sure that driver does proper setup for all cases from 0 on
to 48K, in units of 1K.
This is a backport of the code from 2.6.19 or later
This patch fixes ext3 block bitmap leakage,
which leads to the following fsck messages on
_healthy_ filesystem:
Block bitmap differences: -64159 -73707
All kernels up to 2.6.17 have this bug.
Found by
Vasily Averin <vvs@sw.ru> and Andrey Savochkin <saw@sawoct.com>
Test case triggered the issue was created by
Dmitry Monakhov <dmonakhov@sw.ru>
Signed-Off-By: Kirill Korotaev <dev@openvz.org>
TCP may advertize up to 16-bits window in SYN packets (no window
scaling allowed). At the same time, TCP may have rcv_wnd
(32-bits) that does not fit to 16-bits without window scaling
resulting in pseudo garbage into advertized window from the
low-order bits of rcv_wnd. This can happen at least when
mss <= (1<<wscale) (see tcp_select_initial_window). This patch
fixes the handling of SYN advertized windows (compile tested
only).
In worst case (which is unlikely to occur though), the receiver
advertized window could be just couple of bytes. I'm not sure
that such situation would be handled very well at all by the
receiver!? Fortunately, the situation normalizes after the
first non-SYN ACK is received because it has the correct,
scaled window.
Alternatively, tcp_select_initial_window could be changed to
prevent too large rcv_wnd in the first place.
[ tcp_make_synack() has the same bug, and I've added a fix for
that to this patch -DaveM ]
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
add_grhead() allocates memory with GFP_ATOMIC and in at least two places skb
from it passed to skb_put() without checking.
Adrian Bunk:
backported to 2.6.16
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Add support for the Winbond W83687THF chip to the w83627hf hardware
monitoring driver. This new chip is almost similar to the already
supported W83627THF chip, except for VID and a few other minor
changes.
The alarm bits and the beep enable bits are in different positions in
the hardware. Document the problem and leave it to the user-space code
to handle the situation. When this driver is updated to the standardized
sysfs alarm/beep methodology, this won't be a problem.
This is a documentation only change.
Signed-off by: Charles Spirakis <bezaur@gmail.com>
Add support for the w83791d sensor chip. The w83791d hardware is
somewhere between the w83781d and the w83792d and this driver code
is derived from the code that supports those chips.
Signed-off-by: Charles Spirakis <bezaur@gmail.com>
New driver (smsc47m192) which supports voltage and temperature
measurement features of SMSC LPC47M192 and LPC47M997 chips.
Signed-off-by: Hartmut Rick <linux@rick.claranet.de>
This is a new hardware monitoring driver for the National Semiconductor
PC87427 Super-I/O chip. It only supports fan speed monitoring for now,
while the chip can do much more.
Thanks to Amir Habibi at Candelis for setting up a test system, and to
Michael Kress for testing several iterations of this driver.
Add LM82 temperature sensor support (similar to the LM83,
but less featureful).
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
This patch adds the ATI IXP southbridges support to i2c-piix4,
as it turned out those chips are compatible with it.
Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz>
Add Broadcom HT-1000 south bridge's PCI ID to i2c-piix driver. Note
that at least on Supermicro H8SSL it uses non-standard SMBHSTCFG = 3
and standard values like 0 or 9 causes hangup.
Signed-off-by: Martin Devera <devik@cdi.cz>
Arjan van de Ven <arjan@infradead.org> reported an illegal re-usage of
the fileoperations struct if more than one dvb device (e.g. frontend) is
present.
This patch fixes this issue.
It allocates a new fileoperations struct each time a device is
registered and copies the default template fileops.
Signed-off-by: Marcel Siegert <mws@linuxtv.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
This one adds another vendor ID to rtl8150 driver.
Signed-off-by: Petko Manolov <petkan@nucleusys.com>
I just got a "ZyXEL Prestige USB Adapter" that is actually RTL8150
adapter. Here is the relevant /proc/bus/usb/devices output (after
adding the vendor/product IDs to the driver):
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#=119 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=0586 ProdID=401a Rev= 1.00
S: Manufacturer=ZyXEL
S: Product=Prestige USB Adapter
S: SerialNumber=1027
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=120mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=ff Driver=rtl8150
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 8 Ivl=1ms
This patch adds the ZyXEL vendor ID to the rtl8150.c driver. The
device has absolutely no identifying marks on the outside for model
type, just a serial number, and I can't find anything on ZyXEL's
website, so I called the product ID PRODUCT_ID_PRESTIGE to match the
product string.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Add a workaround for dual port PCI-X card that returns status out of
order sometimes because of split transactions.
This driver uses port 0 to handle receives on both ports. So
the netif_poll_disable call in dev_close would end up stopping the
second port on dual port cards.
That code doesn't do what its author apparently thought it would do...
6.5.7(5): The result of E1 >> E2 is E1 right-shifted E2 bit positions.
If E1 has a signed type and a negative value, the resulting value
is implementation defined.
So, cast -1 to unsigned type to make result well-defined.
[ Modified to use ~0U based upon recommendation from Al Viro. -DaveM ]
gcc emits the following warning:
drivers/atm/firestream.c: In function ‘fs_open’:
drivers/atm/firestream.c:870: warning: ‘tmc0’ may be used uninitialized in this function
This indicates a real bug. We should check make_rate() return value for
potential errors.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Thanks to Randy Dunlap.
Fix the key serial number collision avoidance code in key_alloc_serial().
This didn't use to be so much of a problem as the key serial numbers were
allocated from a simple incremental counter, and it would have to go through
two billion keys before it could possibly encounter a collision. However, n
that random numbers are used instead, collisions are much more likely.
This is fixed by finding a hole in the rbtree where the next unused serial
number ought to be and using that by going almost back to the top of the
insertion routine and redoing the insertion with the new serial number rathe
than trying to be clever and attempting to work out the insertion point
pointer directly.
This fixes kernel Bugzilla #7727.
CVE-2006-5753 is for a case where an inode can be marked bad, switching
the ops to bad_inode_ops, which are all connected as:
static int return_EIO(void)
return -EIO;
#define EIO_ERROR ((void *) (return_EIO))
static struct inode_operations bad_inode_ops =
.create = bad_inode_create
...etc...
The problem here is that the void cast causes return types to not be
promoted, and for ops such as listxattr which expect more than 32 bits of
return value, the 32-bit -EIO is interpreted as a large positive 64-bit
number, i.e. 0x00000000fffffffa instead of 0xfffffffa.
This goes particularly badly when the return value is taken as a number of
bytes to copy into, say, a user's buffer for example...
I originally had coded up the fix by creating a return_EIO_<TYPE> macro
for each return type, like this:
static int return_EIO_int(void)
return -EIO;
#define EIO_ERROR_INT ((void *) (return_EIO_int))
.create = EIO_ERROR_INT,
...etc...
but Al felt that it was probably better to create an EIO-returner for each
actual op signature. Since so few ops share a signature, I just went ahead
& created an EIO function for each individual file & inode op that returns
a value.
Adrian Bunk:
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
The PSM values below 0x1001 of L2CAP are reserved for well known
services. Restrict the possibility to bind them to privileged
users.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
The PSM value in the L2CAP socket list must be converted to host
order before printing it.
Due to type confusion, when an nfsacl verison 2 'ACCESS' request
finishes and tries to clean up, it calls fh_put on entiredly the
wrong thing and this can cause an oops.
We are doing ->buf_prepare(buf) before adding buf to q->stream list. This
means that videobuf_qbuf() should not try to re-add a STATE_PREPARED buffer.
Adrian Bunk:
Backported to 2.6.16.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Use the same signal frame alignment calculations as the underlying
architecture. x86_64 appeared to do this, but the "- 8" was really
subtracting 8 * sizeof(struct rt_sigframe) rather than 8 bytes.
UML/i386 might have been OK, but I changed the calculation to match
i386 just to be sure.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Despite being under linux/, linux/irq.h shouldn't be #include'd by arch
independent code.
This reverts commit ac4d63dab8bb425f1ae037abf349090c12f16883.
Does not work in 2.6.16.
Some of the instances of tcp_sack_block are host-endian, some - net-endian.
Define struct tcp_sack_block_wire identical to struct tcp_sack_block
with u32 replaced with __be32; annotate uses of tcp_sack_block replacing
net-endian ones with tcp_sack_block_wire. Change is obviously safe since
for cc(1) __be32 is typedefed to u32.
