2007-10-12Linux 2.6.16.55v2.6.16.55Adrian Bunk
2007-10-12Revert "TCP: Fix TCP handling of SACK in bidirectional flows"Adrian Bunk
This reverts commit 3198d0f16dec0c87071cf26f3f11af9c8f0a009b.
2007-10-07Linux 2.6.16.55-rc1v2.6.16.55-rc1Adrian Bunk
2007-10-07Convert snd-page-alloc proc file to use seq_file (CVE-2007-4571)Takashi Iwai
Commit ccec6e2c4a74adf76ed4e2478091a311b1806212 in mainline. Use seq_file for the proc file read/write of snd-page-alloc module. This automatically fixes bugs in the old proc code. Adrian Bunk: Backported to 2.6.16. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-07snd_mem_proc_read(): convert to list_for_each_entry*Adrian Bunk
Stolen from a patch by Johannes Berg <johannes@sipsolutions.net>. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-07sysfs: store sysfs inode nrs in s_ino to avoid readdir oopses (CVE-2007-3104)Eric Sandeen
Backport of ftp://ftp.kernel.org/pub/linux/kernel/people/akpm/patches/2.6/2.6.22-rc1/2.6.22-rc1-mm1/broken-out/gregkh-driver-sysfs-allocate-inode-number-using-ida.patch For regular files in sysfs, sysfs_readdir wants to traverse sysfs_dirent->s_dentry->d_inode->i_ino to get to the inode number. But, the dentry can be reclaimed under memory pressure, and there is no synchronization with readdir. This patch follows Tejun's scheme of allocating and storing an inode number in the new s_ino member of a sysfs_dirent, when dirents are created, and retrieving it from there for readdir, so that the pointer chain doesn't have to be traversed. Tejun's upstream patch uses a new-ish "ida" allocator which brings along some extra complexity; this -stable patch has a brain-dead incrementing counter which does not guarantee uniqueness, but because sysfs doesn't hash inodes as iunique expects, uniqueness wasn't guaranteed today anyway. Adrian Bunk: Backported to 2.6.16. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-07random: fix bound check ordering (CVE-2007-3105)Matt Mackall
If root raised the default wakeup threshold over the size of the output pool, the pool transfer function could overflow the stack with RNG bytes, causing a DoS or potential privilege escalation. (Bug reported by the PaX Team <pageexec@freemail.hu>) Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-07random: fix seeding with zero entropy (CVE-2007-2453 2 of 2)Matt Mackall
Add data from zero-entropy random_writes directly to output pools to avoid accounting difficulties on machines without entropy sources. Tested on lguest with all entropy sources disabled. Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-07random: fix error in entropy extraction (CVE-2007-2453 1 of 2)Matt Mackall
Fix cast error in entropy extraction. Add comments explaining the magic 16. Remove extra confusing loop variable. Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-07Reset current->pdeath_signal on SUID binary execution (CVE-2007-3848)Marcel Holtmann
This fixes a vulnerability in the "parent process death signal" implementation discoverd by Wojciech Purczynski of COSEINC PTE Ltd. and iSEC Security Research. http://marc.info/?l=bugtraq&m=118711306802632&w=2 Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-06fix buffer overflow in the moxa driver (CVE-2005-0504)Dann Frazier
Signed-off-by: Dann Frazier <dannf@hp.com> Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-06[POWERPC] Flush registers to proper task contextKumar Gala
When we flush register state for FP, Altivec, or SPE in flush_*_to_thread we need to respect the task_struct that the caller has passed to us. Most cases we are called with current, however sometimes (ptrace) we may be passed a different task_struct. This showed up when using gdbserver debugging a simple program that used floating point. When gdb tried to show the FP regs they all showed up as 0, because the child's FP registers were never properly flushed to memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-06x86_64: Zero extend all registers after ptrace in 32bit entry path ↵Andi Kleen
(CVE-2007-4573) Strictly it's only needed for eax. It actually does a little more than strictly needed -- the other registers are already zero extended. Also remove the now unnecessary and non functional compat task check in ptrace. Found by Wojciech Purczynski Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-06unexport ip_conntrack_{,un}register_notifierAdrian Bunk
Static functions mustn't be exported. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-06sound/core/pcm_lib.c: don't export static functionsAdrian Bunk
2007-10-06unexport csr1212_release_keyvalAdrian Bunk
A static function mustn't be exported. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-06unexport cpufreq_parse_governorAdrian Bunk
2007-10-06unexport neigh_update_hhsAdrian Bunk
2007-10-06[SPARC]: fix sparc64 gcc 4.2 compile failureMikael Pettersson
Compiling 2.6.21-rc5 with gcc-4.2.0 20070317 (prerelease) for sparc64 fails as follows: gcc -Wp,-MD,arch/sparc64/kernel/.time.o.d -nostdinc -isystem /home/mikpe/pkgs/linux-sparc64/gcc-4.2.0/lib/gcc/sparc64-unknown-linux-gnu/4.2.0/include -D__KERNEL__ -Iinclude -include include/linux/autoconf.h -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -m64 -pipe -mno-fpu -mcpu=ultrasparc -mcmodel=medlow -ffixed-g4 -ffixed-g5 -fcall-used-g7 -Wno-sign-compare -Wa,--undeclared-regs -fomit-frame-pointer -fno-stack-protector -Wdeclaration-after-statement -Wno-pointer-sign -Werror -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(time)" -D"KBUILD_MODNAME=KBUILD_STR(time)" -c -o arch/sparc64/kernel/time.o arch/sparc64/kernel/time.c cc1: warnings being treated as errors arch/sparc64/kernel/time.c: In function 'kick_start_clock': arch/sparc64/kernel/time.c:559: warning: overflow in implicit constant conversion make[1]: *** [arch/sparc64/kernel/time.o] Error 1 make: *** [arch/sparc64/kernel] Error 2 gcc gets unhappy when the MSTK_SET macro's u8 __val variable is updated with &= ~0xff (MSTK_YEAR_MASK). Making the constant unsigned fixes the problem. [ I fixed up the sparc32 side as well -DaveM ] Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-06unexport ktime_get_realAdrian Bunk
2007-10-06[IPSEC] AH4: Update IPv4 options handling to conform to RFC 4302.Nick Bowler
In testing our ESP/AH offload hardware, I discovered an issue with how AH handles mutable fields in IPv4. RFC 4302 (AH) states the following on the subject: For IPv4, the entire option is viewed as a unit; so even though the type and length fields within most options are immutable in transit, if an option is classified as mutable, the entire option is zeroed for ICV computation purposes. The current implementation does not zero the type and length fields, resulting in authentication failures when communicating with hosts that do (i.e. FreeBSD). I have tested record route and timestamp options (ping -R and ping -T) on a small network involving Windows XP, FreeBSD 6.2, and Linux hosts, with one router. In the presence of these options, the FreeBSD and Linux hosts (with the patch or with the hardware) can communicate. The Windows XP host simply fails to accept these packets with or without the patch. I have also been trying to test source routing options (using traceroute -g), but haven't had much luck getting this option to work *without* AH, let alone with. Signed-off-by: Nick Bowler <nbowler@ellipticsemi.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-09-25Linux 2.6.16.54v2.6.16.54Adrian Bunk
2007-09-24Linux 2.6.16.54-rc1v2.6.16.54-rc1Adrian Bunk
2007-09-24TCP: Fix TCP handling of SACK in bidirectional flowsIlpo Järvinen
It's possible that new SACK blocks that should trigger new LOST markings arrive with new data (which previously made is_dupack false). In addition, I think this fixes a case where we get a cumulative ACK with enough SACK blocks to trigger the fast recovery (is_dupack would be false there too). I'm not completely pleased with this solution because readability of the code is somewhat questionable as 'is_dupack' in SACK case is no longer about dupacks only but would mean something like 'lost_marker_work_todo' too... But because of Eifel stuff done in CA_Recovery, the FLAG_DATA_SACKED check cannot be placed to the if statement which seems attractive solution. Nevertheless, I didn't like adding another variable just for that either... :-) Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-09-24[PPP]: Fix output buffer size in ppp_decompress_frame().Konstantin Sharlaimov
This patch addresses the issue with "osize too small" errors in mppe encryption. The patch fixes the issue with wrong output buffer size being passed to ppp decompression routine. -------------------- As pointed out by Suresh Mahalingam, the issue addressed by ppp-fix-osize-too-small-errors-when-decoding patch is not fully resolved yet. The size of allocated output buffer is correct, however it size passed to ppp->rcomp->decompress in ppp_generic.c if wrong. The patch fixes that. -------------------- Signed-off-by: Konstantin Sharlaimov <konstantin.sharlaimov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-09-24[PPP]: Fix osize too small errors when decoding mppe.Konstantin Sharlaimov
The mppe_decompress() function required a buffer that is 1 byte too small when receiving a message of mru size. This fixes buffer allocation to prevent this from occurring. Signed-off-by: Konstantin Sharlaimov <konstantin.sharlaimov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-30[MATH-EMU]: Fix underflow exception reporting.David S. Miller
The underflow exception cases were wrong. This is one weird area of ieee1754 handling in that the underflow behavior changes based upon whether underflow is enabled in the trap enable mask of the FPU control register. As a specific case the Sparc V9 manual gives us the following description: -------------------- If UFM = 0: Underflow occurs if a nonzero result is tiny and a loss of accuracy occurs. Tininess may be detected before or after rounding. Loss of accuracy may be either a denormalization loss or an inexact result. If UFM = 1: Underflow occurs if a nonzero result is tiny. Tininess may be detected before or after rounding. -------------------- What this amounts to in the packing case is if we go subnormal, we set underflow if any of the following are true: 1) rounding sets inexact 2) we ended up rounding back up to normal (this is the case where we set the exponent to 1 and set the fraction to zero), this should set inexact too 3) underflow is set in FPU control register trap-enable mask The initially discovered example was "DBL_MIN / 16.0" which incorrectly generated an underflow. It should not, unless underflow is set in the trap-enable mask of the FPU csr. Another example, "0x0.0000000000001p-1022 / 16.0", should signal both inexact and underflow. The cpu implementations and ieee1754 literature is very clear about this. This is case #2 above. However, if underflow is set in the trap enable mask, only underflow should be set and reported as a trap. That is handled properly by the prioritization logic in arch/sparc{,64}/math-emu/math.c:record_exception(). Based upon a report and test case from Jakub Jelinek. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-30[SPARC32]: Fix rounding errors in ndelay/udelay implementation.Mark Fortescue
__ndelay and __udelay have not been delayung >= specified time. The problem with __ndelay has been tacked down to the rounding of the multiplier constant. By changing this, delays > app 18us are correctly calculated. The problem with __udelay has also been tracked down to rounding issues. Changing the multiplier constant (to match that used in sparc64) corrects for large delays and adding in a rounding constant corrects for trunctaion errors in the claculations. Many short delays will return without looping. This is not an error as there is the fixed delay of doing all the maths to calculate the loop count. Signed-off-by: Mark Fortescue <mark@mtfhpc.demon.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-30[SPARC32]: Fix bug in sparc optimized memset.Alexander Shmelev
Sparc optimized memset (arch/sparc/lib/memset.S) does not fill last byte of the memory area, if area size is less than 8 bytes and start address is not word (4-bytes) aligned. Here is code chunk where bug located: /* %o0 - memory address, %o1 - size, %g3 - value */ 8: add %o0, 1, %o0 subcc %o1, 1, %o1 bne,a 8b stb %g3, [%o0 - 1] This code should write byte every loop iteration, but last time delay instruction stb is not executed because branch instruction sets "annul" bit. Patch replaces bne,a by bne instruction. Error can be reproduced by simple kernel module: -------------------- #include <linux/module.h> #include <linux/config.h> #include <linux/kernel.h> #include <linux/errno.h> #include <string.h> static void do_memset(void **p, int size) { memset(p, 0x00, size); } static int __init memset_test_init(void) { char fooc[8]; int *fooi; memset(fooc, 0xba, sizeof(fooc)); do_memset((void**)(fooc + 3), 1); fooi = (int*) fooc; printk("%08X %08X\n", fooi[0], fooi[1]); return -1; } static void __exit memset_test_cleanup(void) { return; } module_init(memset_test_init); module_exit(memset_test_cleanup); MODULE_LICENSE("GPL"); EXPORT_NO_SYMBOLS; -------------------- Signed-off-by: Alexander Shmelev <ashmelev@task.sun.mcst.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-23md: avoid possible BUG_ON in md bitmap handlingNeil Brown
md/bitmap tracks how many active write requests are pending on blocks associated with each bit in the bitmap, so that it knows when it can clear the bit (when count hits zero). The counter has 14 bits of space, so if there are ever more than 16383, we cannot cope. Currently the code just calles BUG_ON as "all" drivers have request queue limits much smaller than this. However is seems that some don't. Apparently some multipath configurations can allow more than 16383 concurrent write requests. So, in this unlikely situation, instead of calling BUG_ON we now wait for the count to drop down a bit. This requires a new wait_queue_head, some waiting code, and a wakeup call. Tested by limiting the counter to 20 instead of 16383 (writes go a lot slower in that case...). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-23md: fix a few problems with the interface (sysfs and ioctl) to mdNeil Brown
While developing more functionality in mdadm I found some bugs in md... - When we remove a device from an inactive array (write 'remove' to the 'state' sysfs file - see 'state_store') would should not update the superblock information - as we may not have read and processed it all properly yet. - initialise all raid_disk entries to '-1' else the 'slot sysfs file will claim '0' for all devices in an array before the array is started. - all '\n' not to be present at the end of words written to sysfs files - when we use SET_ARRAY_INFO to set the md metadata version, set the flag to say that there is persistant metadata. - allow GET_BITMAP_FILE to be called on an array that hasn't been started yet. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-23md: assorted md and raid1 one-linersNeil Brown
Fix few bugs that meant that: - superblocks weren't alway written at exactly the right time (this could show up if the array was not written to - writting to the array causes lots of superblock updates and so hides these errors). - restarting device recovery after a clean shutdown (version-1 metadata only) didn't work as intended (or at all). 1/ Ensure superblock is updated when a new device is added. 2/ Remove an inappropriate test on MD_RECOVERY_SYNC in md_do_sync. The body of this if takes one of two branches depending on whether MD_RECOVERY_SYNC is set, so testing it in the clause of the if is wrong. 3/ Flag superblock for updating after a resync/recovery finishes. 4/ If we find the neeed to restart a recovery in the middle (version-1 metadata only) make sure a full recovery (not just as guided by bitmaps) does get done. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-23md: allow SET_BITMAP_FILE to work on 64bit kernel with 32bit userspaceNeil Brown
.. so that you can use bitmaps with 32bit userspace on a 64 bit kernel. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-23md: fix some small races in bitmap plugging in raid5Neil Brown
The comment gives more details, but I didn't quite have the sequencing write, so there was room for races to leave bits unset in the on-disk bitmap for short periods of time. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-23md: fix a plug/unplug race in raid5Neil Brown
When a device is unplugged, requests are moved from one or two (depending on whether a bitmap is in use) queues to the main request queue. So whenever requests are put on either of those queues, we should make sure the raid5 array is 'plugged'. However we don't. We currently plug the raid5 queue just before putting requests on queues, so there is room for a race. If something unplugs the queue at just the wrong time, requests will be left on the queue and nothing will want to unplug them. Normally something else will plug and unplug the queue fairly soon, but there is a risk that nothing will. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-23md: fix resync speed calculation for restarted resyncsNeil Brown
We introduced 'io_sectors' recently so we could count the sectors that causes io during resync separate from sectors which didn't cause IO - there can be a difference if a bitmap is being used to accelerate resync. However when a speed is reported, we find the number of sectors processed recently by subtracting an oldish io_sectors count from a current 'curr_resync' count. This is wrong because curr_resync counts all sectors, not just io sectors. So, add a field to mddev to store the curren io_sectors separately from curr_resync, and use that in the calculations. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-23md: Allow re-add to work on array without bitmapsNeil Brown
When an array has a bitmap, a device can be removed and re-added and only blocks changes since the removal (as recorded in the bitmap) will be resynced. It should be possible to do a similar thing to arrays without bitmaps. i.e. if a device is removed and re-added and *no* changes have been made in the interim, then the add should not require a resync. This patch allows that option. This means that when assembling an array one device at a time (e.g. during device discovery) the array can be enabled read-only as soon as enough devices are available, but extra devices can still be added without causing a resync. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-12md/bitmap: tidy up i_writecount handling in md/bitmapNeil Brown
md/bitmap modifies i_writecount of a bitmap file to make sure that no-one else writes to it. The reverting of the change is sometimes done twice, and there is one error path where it is omitted. This patch tidies that up. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-12md/bitmap: remove dead code from md/bitmapNeil Brown
bitmap_active is never called, and the BITMAP_ACTIVE flag is never users or tested, so discard them both. Also remove some out-of-date 'todo' comments. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-12md/bitmap: remove unnecessary page reference manipulations from md/bitmap codeNeil Brown
md/bitmap gets a collection of pages representing the bitmap when it initialises the bitmap, and puts all the references when discarding the bitmap. It also occasionally takes extra references without any good reason, and sometimes drops them ... though it doesn't always drop them, which can result in a memory leak. This patch removes the unnecessary 'get_page' calls, and the corresponding 'put_page' calls. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-12md/bitmap: use set_bit etc for bitmap page attributesNeil Brown
In particular, this means that we use 4 bits per page instead of a whole unsigned long. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-12md/bitmap: cleaner separation of page attribute handlers in md/bitmapNeil Brown
md/bitmap has some attributes per-page. Handling of these attributes in largely abstracted in set_page_attr and clear_page_attr. However get_page_attr exposes the format used to store them. So prior to changing that format, introduce test_page_attr instead of get_page_attr, and make appropriate usage changes. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-12md/bitmap: fix online removal of file-backed bitmapsNeil Brown
When "mdadm --grow /dev/mdX --bitmap=none" is used to remove a filebacked bitmap, the bitmap was disconnected from the array, but the file wasn't closed (until the array was stopped). The file also wasn't closed if adding the bitmap file failed. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-12md: Don't clear bits in bitmap when writing to one device fails during recoveryNeil Brown
Currently a device failure during recovery leaves bits set in the bitmap. This normally isn't a problem as the offending device will be rejected because of errors. However if device re-adding is being used with non-persistent bitmaps, this can be a problem. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-12md: Add '4' to the list of levels for which bitmaps are supportedNeil Brown
I really should make this a function of the personality.... Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-12[MCA] fix bus matchingJames Bottomley
There's a bug in the MCA bus matching algorithm in that it promotes from signed short to int before comparing with the actual id and does sign extension on anything > 0x7fff (which means that pos ids > 0x7fff never get correctly matched). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-25Linux 2.6.16.53v2.6.16.53Adrian Bunk
2007-07-22Linux 2.6.16.53-rc1v2.6.16.53-rc1Adrian Bunk
2007-07-22[IPV6]: MSG_ERRQUEUE messages do not pass to connected raw socketsDmitry Butskoy
Taken from http://bugzilla.kernel.org/show_bug.cgi?id=8747 Problem Description: It is related to the possibility to obtain MSG_ERRQUEUE messages from the udp and raw sockets, both connected and unconnected. There is a little typo in net/ipv6/icmp.c code, which prevents such messages to be delivered to the errqueue of the correspond raw socket, when the socket is CONNECTED. The typo is due to swap of local/remote addresses. Consider __raw_v6_lookup() function from net/ipv6/raw.c. When a raw socket is looked up usual way, it is something like: sk = __raw_v6_lookup(sk, nexthdr, daddr, saddr, IP6CB(skb)->iif); where "daddr" is a destination address of the incoming packet (IOW our local address), "saddr" is a source address of the incoming packet (the remote end). But when the raw socket is looked up for some icmp error report, in net/ipv6/icmp.c:icmpv6_notify() , daddr/saddr are obtained from the echoed fragment of the "bad" packet, i.e. "daddr" is the original destination address of that packet, "saddr" is our local address. Hence, for icmpv6_notify() must use "saddr, daddr" in its arguments, not "daddr, saddr" ... Steps to reproduce: Create some raw socket, connect it to an address, and cause some error situation: f.e. set ttl=1 where the remote address is more than 1 hop to reach. Set IPV6_RECVERR . Then send something and wait for the error (f.e. poll() with POLLERR|POLLIN). You should receive "time exceeded" icmp message (because of "ttl=1"), but the socket do not receive it. If you do not connect your raw socket, you will receive MSG_ERRQUEUE successfully. (The reason is that for unconnected socket there are no actual checks for local/remote addresses). Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-07-22[NET]: Fix gen_estimator timer removal racePatrick McHardy
As noticed by Jarek Poplawski <jarkao2@o2.pl>, the timer removal in gen_kill_estimator races with the timer function rearming the timer. Check whether the timer list is empty before rearming the timer in the timer function to fix this. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
