2006-07-29Linux v2.6.18-rc3v2.6.18-rc3Linus Torvalds
2006-07-29Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3734/1: Fix the unused variable warning in __iounmap() [ARM] 3737/1: Export ARM copy/clear_user_page symbols [ARM] 3736/1: xscale: don't mis-report 80219 as an iop32x [ARM] 3733/2: S3C24XX: Remove old IDE registers in Anubis [ARM] 3732/1: S3C24XX: tidy syntax in osiris and anubis machines [ARM] Fix SMP booting [ARM] 3731/1: Allow IRQ definitions of IQ80331 and IQ80332 to co-exist [ARM] 3730/1: ep93xx: enable usb ohci driver in the defconfig [ARM] Fix cats build
2006-07-29[PATCH] MM: Remove rogue readahead printkAndi Kleen
For some reason it triggers always with NFS root and spams the kernel logs of my nfs root boxes a lot. Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] i386: Fix up backtrace fallback patchAndi Kleen
I didn't test all compilation combinations. Shame on me. And fix a missing option in the boot option following x86-64 (Jan Beulich) Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Fix swiotlb=forceAndi Kleen
It was broken before. But having it is important as possible hardware bug workaround. And previously there was no way to force swiotlb if there is another IOMMU. Side effect is that iommu=force won't force swiotlb anymore even if there isn't another IOMMU. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Revert k8-bus.c northbridge access changeAndi Kleen
As Travis Betak points out it accesses the wrong northbridge subfunction now. Switch back to the old code. Cc: "Travis Betak" <betak@mpdtxmail.amd.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Calgary IOMMU - Multi-Node NULL pointer dereference fixJon Mason
Calgary hits a NULL pointer dereference when booting in a multi-chassis NUMA system. See Redhat bugzilla number 198498, found by Konrad Rzeszutek (konradr@redhat.com). There are many issues that had to be resolved to fix this problem. Firstly when I originally wrote the code to handle NUMA systems, I had a large misunderstanding that was not corrected until now. That was that I thought the "number of nodes online" referred to number of physical systems connected. So that if NUMA was disabled, there would only be 1 node and it would only show that node's PCI bus. In reality if NUMA is disabled, the system displays all of the connected chassis as one node but is only ignorant of the delays in accessing main memory. Therefore, references to num_online_nodes() and MAX_NUMNODES are incorrect and need to be set to the maximum number of nodes that can be accessed (which are 8). I created a variable, MAX_NUM_CHASSIS, and set it to 8 to fix this. Secondly, when walking the PCI in detect_calgary, the code only checked the first "slot" when looking to see if a device is present. This will work for most cases, but unfortunately it isn't always the case. In the NUMA MXE drawers, there are USB devices present on the 3rd slot (with slot 1 being empty). So, to work around this, all slots (up to 8) are scanned to see if there are any devices present. Lastly, the bus is being enumerated on large systems in a different way the we originally thought. This throws the ugly logic we had out the window. To more elegantly handle this, I reorganized the kva array to be sparse (which removed the need to have any bus number to kva slot logic in tce.c) and created a secondary space array to contain the bus number to phb mapping. With these changes Calgary boots on an x460 with 4 nodes with and without NUMA enabled. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Calgary IOMMU - fix off by one errorMuli Ben-Yehuda
Fixed off-by-one error in detect_calgary and calgary_init which will cause arrays to overflow. Also, removed impossible to hit BUG_ON. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: On Intel systems when CPU has C3 don't use TSCAndi Kleen
On Intel systems generally the TSC stops in C3 or deeper, so don't use it there. Follows similar logic on i386. This should fix problems on Meroms. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Update defconfigAndi Kleen
Update defconfig Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[ARM] 3734/1: Fix the unused variable warning in __iounmap()Catalin Marinas
Patch from Catalin Marinas This patch adds #ifdef around some variables in the arch/arm/mm/ioremap.c file. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-29[ARM] 3737/1: Export ARM copy/clear_user_page symbolsGeorge G. Davis
Patch from George G. Davis As reported by various folks on the ARM Linux kernel mailing list, the video-buf.ko driver has undefined references on all ARM machines which use it as observed during `make modules`: Warning: "v4wb_clear_user_page" [drivers/media/video/video-buf.ko] undefined! Similar warnings exist for all ARM machines which use this driver. So this change adds the missing EXPORT_SYMBOLs to allow using this driver as a module. Signed-off-by: George G. Davis <gdavis@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-29[ARM] 3736/1: xscale: don't mis-report 80219 as an iop32xLennert Buytenhek
Patch from Lennert Buytenhek The IOP 80219 xscale CPU is a stripped down version of the IOP32x. But the fact that the 80219 and IOP32x are very similar doesn't mean that they need to share a cpu table entry. It's also somewhat confusing for the end user to see the 80219 reported as an IOP32x, so this patch splits the IOP32x cpu table entry to make a separate entry for the 80219. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-28Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] sata_promise: comment out duplicate PCI ID [PATCH] libata: improve EH action and EHI flag handling [PATCH] libata: fix eh_skip_recovery condition [PATCH] libata: fix autopsy ehc->i.action and ehc->i.dev handling
2006-07-29Merge branch 'master' into upstream-fixesJeff Garzik
2006-07-29Merge branch 'upstream' of ↵Jeff Garzik
git://electric-eye.fr.zoreil.com/home/romieu/linux-2.6 into upstream-fixes
2006-07-29[PATCH] skge: chip clock rate typoStephen Hemminger
Okay, Fix both typo's in one patch .The impact is that the incorrect value was being computed for blinking LED and interrupt moderation values. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-29[PATCH] myri10ge - Always do a dummy RDMA after loading the firmwareBrice Goglin
Always do a dummy RDMA after loading the firmware to work around buggy PCIe chipsets which do not implement resending properly. This is so cheap as to be almost free, and should never have been conditional on the tx boundary != 4096. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-29Merge branch 'upstream-fixes' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream-fixes
2006-07-28[PATCH] pi-futex: robust-futex exitIngo Molnar
Fix robust PI-futexes to be properly unlocked on unexpected exit. For this to work the kernel has to know whether a futex is a PI or a non-PI one, because the semantics are different. Since the space in relevant glibc data structures is extremely scarce, the best solution is to encode the 'PI' information in bit 0 of the robust list pointer. Existing (non-PI) glibc robust futexes have this bit always zero, so the ABI is kept. New glibc with PI-robust-futexes will set this bit. Further fixes from Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] pi-futex: robust-futex exit crash fixIngo Molnar
Fix pi_state->list handling bugs: list handling mishap, locking error. Plus add more debug checks and fix a few style issues i noticed while debugging this. (reported by Ulrich Drepper and Jakub Jelinek.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] i386: Do backtrace fallback tooAndi Kleen
Similar patch to earlier x86-64 patch. When the dwarf2 unwinder fails dump the left over stack with the old unwinder. Also some clarifications in the headers. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] x86_64: Document backtracer selection optionsAndi Kleen
2006-07-28[PATCH] x86_64: Dump leftover backtrace entries when dwarf2 unwinder got stuckAndi Kleen
The dwarf2 unwinder currently often gets stuck because a lot of assembly code doesn't have proper dwarf2 annotiation yet. This currently often happens with __down. Should fix this by adding proper dwarf2 annotation to all inline assembly. However until that's done we need a quick fix for 2.6.18 to avoid incomplete backtraces. So when this happens dump the rest of the stack with the old unwinder instead of silently not dumping it. There was already a optional "both" mode that dumped both, but that was too ugly. I also clarified the headers for the different backtraces a bit. Also add a clear error message for missing dwarf2 annotation that people can work on. And I removed a dead variable left over from Ingo's changes. Cc: mingo@elte.hu Cc: jbeulich@novell.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] x86_64: Enlarge debug stack for nested kprobesbibo mao
In x86_64 platform, INT1 and INT3 trap stack is IST stack called DEBUG_STACK, when INT1/INT3 trap happens, system will switch to DEBUG_STACK by hardware. Current DEBUG_STACK size is 4K, when int1/int3 trap happens, kernel will minus current DEBUG_STACK IST value by 4k. But if int3/int1 trap is nested, it will destroy other vector's IST stack. This patch modifies this, it sets DEBUG_STACK size as 8K and allows two level of nested int1/int3 trap. Kprobe DEBUG_STACK may be nested, because kprobe handler may be probed by other kprobes. Thanks jbeulich for pointing out error in the first patch. [AK: nested kprobes are pretty dubious. Hopefully one nest will be enough. This will cost 8K per CPU (4K more than before)] Signed-off-by: bibo, mao <bibo.mao@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] x86_64: Don't clobber r8-r11 in int 0x80 handlerAndi Kleen
When int 0x80 is called from long mode r8-r11 would leak out of the kernel (or rather they would be filled with some values from the kernel stack). I don't think it's a security issue because the values come from the fixed stack frame which should be near always user registers from a previous interrupt. Still better fix it. Longer term the register save macros need to be cleaned up to avoid such mistakes in the future. Original analysis from Richard Brunner, fix by me. Cc: Richard.Brunner@amd.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] i386/x86-64: Add user_mode checks to profile_pc for oprofileAndi Kleen
Fixes a obscure user space triggerable crash during oprofiling. Oprofile calls profile_pc from NMIs even when user_mode(regs) is not true and the program counter is inside the kernel lock section. This opens a race - when a user program jumps to a kernel lock address and a NMI happens before the illegal page fault exception is raised and the program has a unmapped esp or ebp then the kernel could oops. NMIs have a higher priority than exceptions so that could happen. Add user_mode checks to i386/x86-64 profile_pc to prevent that. Cc: John Levon <levon@movementarian.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] update default configuration [S390] duplicate ccw devices in ccwgroup. [S390] permanent subchannel busy conditions may cause I/O stall
2006-07-28Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SUNLANCE]: fix compilation on sparc-UP [SPARC]: Defer clock_probe to fs_initcall() [SPARC64]: Fix typo in pgprot_noncached(). [SPARC64]: Fix quad-float multiply emulation.
2006-07-28Merge git://oss.sgi.com:8090/nathans/xfs-rc-2.6Linus Torvalds
* git://oss.sgi.com:8090/nathans/xfs-rc-2.6: [XFS] Ensure bulkstat from an invalid inode number gets caught always with [XFS] Fix a barrier related forced shutdown on mounts with quota enabled. [XFS] Fix remount vs no/barrier options by ensuring we clear unwanted [XFS] All xfs_disk_dquot_t values are (as the name says) disk endian.
2006-07-28Merge branch 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] scsi: kill overeager "not-ready" messages [PATCH] it821x: fix ide dma setup bug [PATCH] ide: if the id fields looks screwy, disable DMA [PATCH] ide: option to disable cache flushes for buggy drives
2006-07-28[PATCH] i386: switch_to(): misplaced parenthesesChuck Ebbert
Recent changes in i386 __switch_to() have a misplaced closing parenthesis causing an unlikely() to terminate early. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[SUNLANCE]: fix compilation on sparc-UPAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-28[XFS] Ensure bulkstat from an invalid inode number gets caught always withNathan Scott
EINVAL. SGI-PV: 953819 SGI-Modid: xfs-linux-melb:xfs-kern:26629a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-07-28[XFS] Fix a barrier related forced shutdown on mounts with quota enabled.Nathan Scott
SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:26622a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-07-28[XFS] Fix remount vs no/barrier options by ensuring we clear unwantedNathan Scott
flags from iclog buffers before submitting them for writing. SGI-PV: 954772 SGI-Modid: xfs-linux-melb:xfs-kern:26605a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-07-28[XFS] All xfs_disk_dquot_t values are (as the name says) disk endian.Christoph Hellwig
Before putting them into struct statfs they should be endian-swapped. SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26550a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-07-28[PATCH] scsi: kill overeager "not-ready" messagesJens Axboe
HAL and friends have a tendency to trigger this one all the time. It's not really interesting, so kill it. The vendor kernels all do anyways. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-28[PATCH] it821x: fix ide dma setup bugJens Axboe
Only enable dma for a valid speed setting. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-28[PATCH] ide: if the id fields looks screwy, disable DMAJens Axboe
It's the safer choice. Originally due to a bug in itx821x, but a generally sound thing to do. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-28[PATCH] ide: option to disable cache flushes for buggy drivesJens Axboe
Some drives claim they support cache flushing, but get seriously confused if you try. Add this option to be able to boot with barriers enabled by default. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-27[SPARC]: Defer clock_probe to fs_initcall()Bob Breuer
From: Bob Breuer <breuerr@mc.net> That way all the of_driver bits will be ready. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-27[SPARC64]: Fix typo in pgprot_noncached().David S. Miller
The sun4v code sequence was or'ing in the sun4u pte bits by mistake. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-27[SPARC64]: Fix quad-float multiply emulation.David S. Miller
Something is wrong with the 3-multiply (vs. 4-multiply) optimized version of _FP_MUL_MEAT_2_*(), so just use the slower version which actually computes correct values. Noticed by Rene Rebe Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-27[PATCH] ieee80211: TKIP requires CRC32Chuck Ebbert
ieee80211_crypt_tkip will not work without CRC32. LD .tmp_vmlinux1 net/built-in.o: In function `ieee80211_tkip_encrypt': net/ieee80211/ieee80211_crypt_tkip.c:349: undefined reference to `crc32_le' Reported by Toralf Foerster <toralf.foerster@gmx.de> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-27[PATCH] orinoco: fix setting transmit key onlyDan Williams
When determining whether there's a key to set or not, orinoco should be looking at the key length, not the key data. Otherwise confusion reigns when trying to set TX key only, passing in zero-length key, but non-NULL pointer. Key length takes precedence over non-NULL key data. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-27[PATCH] softmac: do shared key auth in workqueueDaniel Drake
Johann Uhrmann reported a bcm43xx crash and Michael Buesch tracked it down to a problem with the new shared key auth code (recursive calls into the driver) This patch (effectively Michael's patch with a couple of small modifications) solves the problem by sending the authentication challenge response frame from a workqueue entry. I also removed a lone \n from the bcm43xx messages relating to authentication mode - this small change was previously discussed but not patched in. Signed-off-by: Daniel Drake <dsd@gentoo.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-27[PATCH] airo: should select crypto_aesRobert Schulze
The driver airo (for Cisco Wlan-Cards) complains about "failed to load transform for AES", when it is loaded and CRYPTO_AES is not selected in Kconfig. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-27[PATCH] zd1201: workaround interference problemPavel Machek
zd1201 has nasty tendency to emit magicall anti-wifi cloud when it is inserted into slot, but not used. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-27[S390] update default configurationMartin Schwidefsky
