commit 46db2f86a3b2a94e0b33e0b4548fb7b7b6bdff66 upstream.
The SLB can change sizes across a live migration, which was not
being handled, resulting in possible machine crashes during
migration if migrating to a machine which has a smaller max SLB
size than the source machine. Fix this by first reducing the
SLB size to the minimum possible value, which is 32, prior to
migration. Then during the device tree update which occurs after
migration, we make the call to ensure the SLB gets updated. Also
add the slb_size to the lparcfg output so that the migration
tools can check to make sure the kernel has this capability
before allowing migration in scenarios where the SLB size will change.
BenH: Fixed #include <asm/mmu-hash64.h> -> <asm/mmu.h> to avoid
breaking ppc32 build
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
commit 6b5096e4d4496e185cd1ada5d1b8e1d941c805ed upstream.
One more form factor for Compaq Evo D510, which needs the same quirk
as the other form factors. Apparently there's no hardware monitoring
chip on that one, but SPD EEPROMs, so it's still worth unhiding the
SMBus.
Tested-by: Nuzhna Pomoshch <nuzhna_pomoshch@yahoo.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 6f1186be4feb3364d3a52cbea81e43e4d5296196 upstream.
This patch adds the most recent additions to the list of 82576 device IDs
to the list of devices needing the SR-IOV quirk.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
commit ac8672ea922bde59acf50eaa1eaa1640a6395fd2 upstream.
ata_tf_read_block() has off-by-one error when converting CHS address
to LBA. The bug isn't very visible because ata_tf_read_block() is
used only when generating sense data for a failed RW command and CHS
addressing isn't used too often these days.
This problem was spotted by Atsushi Nemoto.
Reported-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
commit 1444885a045fe3b1905a14ea1b52540bf556578b upstream.
Otherwise its possible to starve the host by programming lapic timer
with a very high frequency.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit ee3d29e8bee8d7c321279a9bd9bd25d4cfbf79b7 upstream.
The jump target should not be sign extened; use an unsigned decode flag.
commit 3b80fffe2b31fb716d3ebe729c54464ee7856723 upstream.
First check if the list is empty before attempting to look at list
entries.
Signed-off-by: Izik Eidus <ieidus@redhat.com>
commit c9eaf20f268c7051bfde2ba212c5ea76a6cbc7a1 upstream.
Absolute jumps use zero extended immediate operands.
commit 5fff7d270bd6a4759b6d663741b729cdee370257 upstream.
Don't call adjust_vmx_controls() two times for the same control.
It restores options that were dropped earlier. This loses us the cr8
exit control, which causes a massive performance regression Windows x64.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit 07708c4af1346ab1521b26a202f438366b7bcffd upstream.
So far unprivileged guest callers running in ring 3 can issue, e.g., MMU
hypercalls. Normally, such callers cannot provide any hand-crafted MMU
command structure as it has to be passed by its physical address, but
they can still crash the guest kernel by passing random addresses.
To close the hole, this patch considers hypercalls valid only if issued
from guest ring 0. This may still be relaxed on a per-hypercall base in
the future once required.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
commit a20316d2aa41a8f4fd171648bad8f044f6060826 upstream.
The use of __pa() to calculate the address of a C-visible symbol
is wrong, and can lead to unpredictable results. See arch/x86/include/asm/page.h
for details.
It should be replaced with __pa_symbol(), that does the correct math here,
by taking relocations into account. This ensures the correct wallclock data
structure physical address is passed to the hypervisor.
Signed-off-by: Glauber Costa <glommer@redhat.com>
commit 0a79b009525b160081d75cef5dbf45817956acf2 upstream.
Debug registers may only be accessed from cpl 0. Unfortunately, vmx will
code to emulate the instruction even though it was issued from guest
userspace, possibly leading to an unexpected trap later.
commit 65a82211636f156a276cac3f8665605ae18f371f upstream.
This bug was introduced by b4a2f5e723e4f7df467.
commit 6ba661787594868512a71c129062ebd57d0c01e7 upstream.
Commit b8bcfe997e4 made paravirt pte updates synchronous in interrupt
context.
Unfortunately the KVM pv mmu code caches the lazy/nonlazy mode
internally, so a pte update from interrupt context during a lazy mmu
operation can be batched while it should be performed synchronously.
https://bugzilla.redhat.com/show_bug.cgi?id=518022
Drop the internal mode variable and use paravirt_get_lazy_mode(), which
returns the correct state.
highmem
commit 7929eb9cf643ae416e5081b2a6fa558d37b9854c upstream.
Let's suppose a highmem page is kmap'd with kmap(). A pkmap entry is
used, the page mapped to it, and the virtual cache is dirtied. Then
kunmap() is used which does virtually nothing except for decrementing a
usage count.
Then, let's suppose the _same_ page gets mapped using kmap_atomic().
It is therefore mapped onto a fixmap entry instead, which has a
different virtual address unaware of the dirty cache data for that page
sitting in the pkmap mapping.
Fortunately it is easy to know if a pkmap mapping still exists for that
page and use it directly with kmap_atomic(), thanks to kmap_high_get().
And actual testing with a printk in the added code path shows that this
condition is actually met *extremely* frequently. Seems that we've been
quite lucky that things have worked so well with highmem so far.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
commit fa526d0d641b5365676a1fb821ce359e217c9b85 upstream.
Fix address passed to cpa_flush_range() when changing page
attributes from WB to UC. The address (*addr) is
modified by __change_page_attr_set_clr(). The result is that
the pages being flushed start at the _end_ of the changed range
instead of the beginning.
This should be considered for 2.6.30-stable and 2.6.31-stable.
Signed-off-by: Jack Steiner <steiner@sgi.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 6dab62ee5a3bf4f71b8320c09db2e6022a19f40e upstream.
http://bugzilla.kernel.org/show_bug.cgi?id=12542 reports that with the
quirk not applied on resume, msi stops working after resuming and mcp78s
ahci fails due to IRQ mis-delivery. Apply it on resume too.
Cc: Peer Chen <pchen@nvidia.com>
Cc: Tj <linux@tjworld.net>
Reported-by: Nicolas Derive <kalon33@ubuntu.com>
Cc: Greg KH <greg@kroah.com>
commit 1ea0d14e480c245683927eecc03a70faf06e80c8 upstream.
The Intel Optimization Reference Guide says:
In Intel Atom microarchitecture, the address generation unit
assumes that the segment base will be 0 by default. Non-zero
segment base will cause load and store operations to experience
a delay.
- If the segment base isn't aligned to a cache line
boundary, the max throughput of memory operations is
reduced to one [e]very 9 cycles.
Assembly/Compiler Coding Rule 15. (H impact, ML generality)
For Intel Atom processors, use segments with base set to 0
whenever possible; avoid non-zero segment base address that is
not aligned to cache line boundary at all cost.
We can't avoid having a non-zero base for the stack-protector
segment, but we can make it cache-aligned.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
LKML-Reference: <4AA01893.6000507@goop.org>
commit 005155b1f626d2b2d7932e4afdf4fead168c6888 upstream.
For the x86_model to be greater than 6 or less than 12 is
logically always true.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
commit 506d4bc8d5dab20d84624aa07cdc6dcd77915d52 upstream.
The current noise computation does:
\Sum abs(n_i - avg(n)) * N^-1.5
Which is (afaik) not a regular noise function, and needs the
complete sample set available to post-process.
Change this to use a regular stddev computation which can be
done by keeping a two sums:
stddev = sqrt( 1/N (\Sum n_i^2) - avg(n)^2 )
For which we only need to keep \Sum n_i and \Sum n_i^2.
Cc: <stable@kernel.org>
LKML-Reference: <new-submission>
commit fa0681d2129732027355d6b7083dd8932b9b799d upstream.
The current implementation allocates a single host page for EQ context
memory, which was OK when we only allocated a few EQs. However, since
we now allocate an EQ for each CPU core, this patch removes the
hard-coded limit (which we exceed with 4 KB pages and 128 byte EQ
context entries with 32 CPUs) and uses the same ICM table code as all
other context tables, which ends up simplifying the code quite a bit
while fixing the problem.
This problem was actually hit in practice on a dual-socket Nehalem box
with 16 real hardware threads and sufficiently odd ACPI tables that it
shows on boot
SMP: Allowing 32 CPUs, 16 hotplug CPUs
so num_possible_cpus() ends up 32, and mlx4 ends up creating 33 MSI-X
interrupts and 33 EQs. This mlx4 bug means that mlx4 can't even
initialize at all on this quite mainstream system.
Reported-by: Eli Cohen <eli@mellanox.co.il>
Tested-by: Christoph Lameter <cl@linux-foundation.org>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
commit f1bc07af9a9edc5c1d4bdd971f7099316ed2e405 upstream.
When the volume is changed continuously (e.g., when the user drags a
volume slider with the mouse), the driver does lots of I2C writes.
Apparently, the sound chip can get confused when we poll the I2C status
register too much, and fails to complete a read from it. On the PCI-E
models, the PCI-E/PCI bridge gets upset by this and generates a machine
check exception.
To avoid this, this patch replaces the polling with an unconditional
wait that is guaranteed to be long enough.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Tested-by: Johann Messner <johann.messner at jku.at>
commit 87831cb660954356d68cebdb1406f3be09e784e9 upstream.
It's the 8th enum of a zero indexed array. This is why I don't let
new drivers use these arrays of enums...
commit 6148b130eb84edc76e4fa88da1877b27be6c2f06 upstream.
Fix minimum period size for cs46xx cards. This fixes a problem in the
case where neither a period size nor a buffer size is passed to ALSA;
this is the case in Audacious, OpenAL, and others.
Signed-off-by: Sophie Hamilton <kernel@theblob.org>
commit 121264827656f5f06328b17983c796af17dc5949 upstream.
As early pci resume has already restored config for host
bridge and graphics device, don't need to restore it again,
This removes an original order hack for graphics device restore.
This fixed the resume hang issue found by Alan Stern on 845G,
caused by extra config restore on graphics device.
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Signed-off-by: Dave Airlie <airlied@linux.ie>
commit b8a9ae779f2c7049071034661e09cb7e1e82250c upstream.
Stacked devices do not. For now, just error out with -EINVAL. Later
we could make the limit apply on stacked devices too, for throttling
reasons.
This fixes
5a54cd13353bb3b88887604e2c980aa01e314309
and should go into 2.6.31 stable as well.
commit bc00351edd5c1b84d48c3fdca740fedfce4ae6ce upstream.
A workaround for flash memory I/O errors when the PS3 internal
hard disk has not been formatted for OtherOS use.
This error condition mainly effects 'Live CD' users who have not
formatted the PS3's internal hard disk for OtherOS.
Fixes errors similar to these when using the ps3-flash-util
or ps3-boot-game-os programs:
ps3flash read failed 0x2050000
os_area_header_read: read error: os_area_header: Input/output error
main:627: os_area_read_hp error.
ERROR: can't change boot flag
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
commit a6dbf93a2ad853585409e715eb96dca9177e3c39 upstream.
Currently there is a bug where if you use oprofile on a pSeries
machine, then use perf_counters, then use oprofile again, oprofile
will not work correctly; it will lose the PMU configuration the next
time the hypervisor does a partition context switch, and thereafter
won't count anything.
Maynard Johnson identified the sequence causing the problem:
- oprofile setup calls ppc_enable_pmcs(), which calls
pseries_lpar_enable_pmcs, which tells the hypervisor that we want
to use the PMU, and sets the "PMU in use" flag in the lppaca.
This flag tells the hypervisor whether it needs to save and restore
the PMU config.
- The perf_counter code sets and clears the "PMU in use" flag directly
as it context-switches the PMU between tasks, and leaves it clear
when it finishes.
- oprofile setup, called for a new oprofile run, calls ppc_enable_pmcs,
which does nothing because it has already been called. In particular
it doesn't set the "PMU in use" flag.
This fixes the problem by arranging for ppc_enable_pmcs to always set
the "PMU in use" flag. It makes the perf_counter code call
ppc_enable_pmcs also rather than calling the lower-level function
directly, and removes the setting of the "PMU in use" flag from
pseries_lpar_enable_pmcs, since that is now done in its caller.
This also removes the declaration of pasemi_enable_pmcs because it
isn't defined anywhere.
Reported-by: Maynard Johnson <mpjohn@us.ibm.com>
commit e51ee31e8af22948dcc3b115978469b09c96c3fd upstream.
Michael Ellerman reported stack-frame size warnings being produced
for power_check_constraints(), which uses an 8*8 array of u64 and
two 8*8 arrays of unsigned long, which are currently allocated on the
stack, along with some other smaller variables. These arrays come
to 1.5kB on 64-bit or 1kB on 32-bit, which is a bit too much for the
stack.
This fixes the problem by putting these arrays in the existing
per-cpu cpu_hw_counters struct. This is OK because two of the call
sites have interrupts disabled already; for the third call site we
use get_cpu_var, which disables preemption, so we know we won't
get a context switch while we're in power_check_constraints().
Note that power_check_constraints() can be called during context
switch but is not called from interrupts.
Reported-by: Michael Ellerman <michael@ellerman.id.au>
commit fa289beca9de9119c7760bd984f3640da21bc94c upstream.
Currently, if a group is created where the group leader is
initially disabled but a non-leader member is initially
enabled, and then the leader is subsequently enabled some time
later, the time_enabled for the non-leader member will reflect
the whole time since it was created, not just the time since
the leader was enabled.
This is incorrect, because all of the members are effectively
disabled while the leader is disabled, since none of the
members can go on the PMU if the leader can't.
Thus we have to update the ->tstamp_enabled for all the enabled
group members when a group leader is enabled, so that the
time_enabled computation only counts the time since the leader
was enabled.
Similarly, when disabling a group leader we have to update the
time_enabled and time_running for all of the group members.
Also, in update_counter_times, we have to treat a counter whose
group leader is disabled as being disabled.
Reported-by: Stephane Eranian <eranian@googlemail.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <19091.29664.342227.445006@drongo.ozlabs.ibm.com>
commit b3e62e35058fc744ac794611f4e79bcd1c5a4b83 upstream.
If we pass a big size data over perf_counter_open() syscall,
the kernel will copy this data to a small buffer, it will
cause kernel crash.
This bug makes the kernel unsafe and non-root local user can
trigger it.
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Paul Mackerras <paulus@samba.org>
LKML-Reference: <4AAF37D4.5010706@cn.fujitsu.com>
commit 2195d2818c37bdf263865f1e9effccdd9fc5f9d4 upstream.
My 353d5c30c666580347515da609dd74a2b8e9b828 "mm: fix hugetlb bug due to
user_shm_unlock call" broke the CONFIG_SYSVIPC !CONFIG_MMU build of both
2.6.31 and 2.6.30.6: "undefined reference to `user_shm_unlock'".
gcc didn't understand my comment! so couldn't figure out to optimize
away user_shm_unlock() from the error path in the hugetlb-less case, as
it does elsewhere. Help it to do so, in a language it understands.
Reported-by: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
commit e0faf54ee82bf9c07f0307b4391caad4020bd659 upstream.
The amd_iommu_pd_table is indexed by protection domain
number and not by device id. So this check is broken and
must be removed.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 0d03d59d9b31cd1e33b7e46a80b6fef66244b1f2 upstream.
Commit b8313b6da7e2e7c7f47d93d8561969a3ff9ba0ea ("dm log: remove incorrect
field from userspace table output") added a call to strstr() with a
single-character "needle" string parameter.
Unfortunately some versions of gcc replace such calls to strstr() by calls
to strchr() behind our back. This causes linking errors if strchr() is
defined as an inline function in <asm/string.h> (e.g. on m68k):
| WARNING: "strchr" [drivers/md/dm-log-userspace.ko] undefined!
Avoid this by explicitly calling strchr() instead.
commit ec57935837a78f9661125b08a5d08b697568e040 upstream.
When probing the device in tpm_tis_init the call request_locality
uses timeout_a, which wasn't being initalized until after
request_locality. This results in request_locality falsely timing
out if the chip is still starting. Move the initialization to before
request_locality.
This probably only matters for embedded cases (ie mine), a BIOS likely
gets the TPM into a state where this code path isn't necessary.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit 9f0ab4a3f0fdb1ff404d150618ace2fa069bb2e1 upstream.
In fs/binfmt_elf.c, load_elf_interp() calls padzero() for .bss even if
the PT_LOAD has no PROT_WRITE and no .bss. This generates EFAULT.
Here is a small test case. (Yes, there are other, useful PT_INTERP
which have only .text and no .data/.bss.)
----- ptinterp.S
_start: .globl _start
nop
int3
$ gcc -m32 -nostartfiles -nostdlib -o ptinterp ptinterp.S
$ gcc -m32 -Wl,--dynamic-linker=ptinterp -o hello hello.c
$ ./hello
Segmentation fault # during execve() itself
After applying the patch:
$ ./hello
Trace trap # user-mode execution after execve() finishes
If the ELF headers are actually self-inconsistent, then dying is fine.
But having no PROT_WRITE segment is perfectly normal and correct if
there is no segment with p_memsz > p_filesz (i.e. bss). John Reiser
suggested checking for PROT_WRITE in the bss logic. I think it makes
most sense to simply apply the bss logic only when there is bss.
This patch looks less trivial than it is due to some reindentation.
It just moves the "if (last_bss > elf_bss) {" test up to include the
partial-page bss logic as well as the more-pages bss logic.
Reported-by: John Reiser <jreiser@bitwagon.com>
Signed-off-by: Roland McGrath <roland@redhat.com>
commit 3355443ad7601991affa5992b0d53870335af765 upstream.
"Ath5k: unify resets"
introduced a regression into 2.6.28 where the PCU registers are never
initialized, due to ath5k_reset() always passing true for change_channel.
We subsequently program a lot of these registers but several may start
in an unknown state.
Reported-by: Forrest Zhang <forrest@hifulltech.com>
Signed-off-by: Bob Copeland <me@bobcopeland.com>
commit fcc6cb0c13555e78c2d47257b6d1b5e59b0c419a upstream.
The find_ie() function uses a size_t for the len parameter, and
directly uses len as a loop variable. If any received packets
are malformed, it is possible for the decrease of len to overflow,
and since the result is unsigned, the loop will not terminate.
Change it to a signed int so the loop conditional works for
negative values.
This fixes the following soft lockup:
[38573.102007] BUG: soft lockup - CPU#0 stuck for 61s! [phy0:2230]
[38573.102007] Modules linked in: aes_i586 aes_generic fuse af_packet ipt_REJECT xt_tcpudp nf_conntrack_ipv4 nf_defrag_ipv4 xt_state iptable_filter ip_tables x_tables acpi_cpufreq binfmt_misc dm_mirror dm_region_hash dm_log dm_multipath dm_mod kvm_intel kvm uinput i915 arc4 ecb drm snd_hda_codec_idt ath5k snd_hda_intel hid_apple mac80211 usbhid appletouch snd_hda_codec snd_pcm ath cfg80211 snd_timer i2c_algo_bit ohci1394 video snd processor ieee1394 rfkill ehci_hcd sg sky2 backlight snd_page_alloc uhci_hcd joydev output ac thermal button battery sr_mod applesmc cdrom input_polldev evdev unix [last unloaded: scsi_wait_scan]
[38573.102007] irq event stamp: 2547724535
[38573.102007] hardirqs last enabled at (2547724534): [<c1002ffc>] restore_all_notrace+0x0/0x18
[38573.102007] hardirqs last disabled at (2547724535): [<c10038f4>] apic_timer_interrupt+0x28/0x34
[38573.102007] softirqs last enabled at (92950144): [<c103ab48>] __do_softirq+0x108/0x210
[38573.102007] softirqs last disabled at (92950274): [<c1348e74>] _spin_lock_bh+0x14/0x80
[38573.102007]
[38573.102007] Pid: 2230, comm: phy0 Tainted: G W (2.6.31-rc7-wl #8) MacBook1,1
[38573.102007] EIP: 0060:[<f8ea2d50>] EFLAGS: 00010292 CPU: 0
[38573.102007] EIP is at cmp_ies+0x30/0x180 [cfg80211]
[38573.102007] EAX: 00000082 EBX: 00000000 ECX: ffffffc1 EDX: d8efd014
[38573.102007] ESI: ffffff7c EDI: 0000004d EBP: eee2dc50 ESP: eee2dc3c
[38573.102007] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
[38573.102007] CR0: 8005003b CR2: d8efd014 CR3: 01694000 CR4: 000026d0
[38573.102007] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[38573.102007] DR6: ffff0ff0 DR7: 00000400
[38573.102007] Call Trace:
[38573.102007] [<f8ea2f8d>] cmp_bss+0xed/0x100 [cfg80211]
[38573.102007] [<f8ea33e4>] cfg80211_bss_update+0x84/0x410 [cfg80211]
[38573.102007] [<f8ea3884>] cfg80211_inform_bss_frame+0x114/0x180 [cfg80211]
[38573.102007] [<f97255ff>] ieee80211_bss_info_update+0x4f/0x180 [mac80211]
[38573.102007] [<f972b118>] ieee80211_rx_bss_info+0x88/0xf0 [mac80211]
[38573.102007] [<f9739297>] ? ieee802_11_parse_elems+0x27/0x30 [mac80211]
[38573.102007] [<f972b224>] ieee80211_rx_mgmt_probe_resp+0xa4/0x1c0 [mac80211]
[38573.102007] [<f972bc59>] ieee80211_sta_rx_queued_mgmt+0x919/0xc50 [mac80211]
[38573.102007] [<c1009707>] ? sched_clock+0x27/0xa0
[38573.102007] [<c105ffd0>] ? mark_held_locks+0x60/0x80
[38573.102007] [<c1348be5>] ? _spin_unlock_irqrestore+0x55/0x70
[38573.102007] [<c134baa5>] ? sub_preempt_count+0x85/0xc0
[38573.102007] [<c1348bce>] ? _spin_unlock_irqrestore+0x3e/0x70
[38573.102007] [<c12c1c0f>] ? skb_dequeue+0x4f/0x70
[38573.102007] [<f972c021>] ieee80211_sta_work+0x91/0xb80 [mac80211]
[38573.102007] [<c10479af>] worker_thread+0x18f/0x320
[38573.102007] [<c104794e>] ? worker_thread+0x12e/0x320
[38573.102007] [<f972bf90>] ? ieee80211_sta_work+0x0/0xb80 [mac80211]
[38573.102007] [<c104cbb0>] ? autoremove_wake_function+0x0/0x50
[38573.102007] [<c1047820>] ? worker_thread+0x0/0x320
[38573.102007] [<c104c854>] kthread+0x84/0x90
[38573.102007] [<c104c7d0>] ? kthread+0x0/0x90
[38573.102007] [<c1003ab7>] kernel_thread_helper+0x7/0x10
commit afffd3dabe5209882c8cc59a373a4d33b5db304a upstream.
This patch fixes a memory leak in the libsrp function srp_ring_free().
It is not documented whether or not this function should free the ring
pointer itself. But the source code of the callers of this function
(srp_target_alloc() and srp_target_free()) makes it clear that
srp_ring_free() should deallocate the ring pointer itself. Furthermore,
the patch below makes srp_ring_free() deallocate all memory allocated by
srp_ring_alloc().
This patch affects the ibmvstgt driver, which is the only in-tree driver
that calls the srp_ring_free() function (indirectly).
Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com>
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit ea038f63ac52439e7816295fa6064fe95e6c1f51 upstream.
Chris Webb reported:
p0# uname -a
Linux f7ea8425-d45b-490f-a738-d181d0df6963.host.elastichosts.com 2.6.30.4-elastic-lon-p #2 SMP PREEMPT Thu Aug 20 14:30:50 BST 2009 x86_64 Intel(R) Xeon(R) CPU E5420 @ 2.50GHz GenuineIntel GNU/Linux
p0# zgrep SCAN_ASYNC /proc/config.gz
# CONFIG_SCSI_SCAN_ASYNC is not set
p0# cat /var/log/kern/2009-08-20
15:27:10.485 kernel: scsi9 : iSCSI Initiator over TCP/IP
15:27:11.493 kernel: scsi 9:0:0:0: RAID IET Controller 0001 PQ: 0 ANSI: 5
15:27:11.493 kernel: scsi 9:0:0:0: Attached scsi generic sg6 type 12
15:27:11.495 kernel: scsi 9:0:0:1: Direct-Access IET VIRTUAL-DISK 0001 PQ: 0 ANSI: 5
15:27:11.495 kernel: sd 9:0:0:1: Attached scsi generic sg7 type 0
15:27:11.495 kernel: sd 9:0:0:1: [sdg] 4194304 512-byte hardware sectors: (2.14 GB/2.00 GiB)
15:27:11.495 kernel: sd 9:0:0:1: [sdg] Write Protect is off
15:27:11.495 kernel: sd 9:0:0:1: [sdg] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
15:27:13.012 kernel: sdg:<6>scsi 9:0:0:1: [sdg] Unhandled error code
15:27:13.012 kernel: scsi 9:0:0:1: [sdg] Result: hostbyte=0x07 driverbyte=0x00
15:27:13.012 kernel: end_request: I/O error, dev sdg, sector 0
15:27:13.012 kernel: Buffer I/O error on device sdg, logical block 0
15:27:13.012 kernel: ldm_validate_partition_table(): Disk read failed.
15:27:13.012 kernel: unable to read partition table
15:27:13.014 kernel: BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
15:27:13.014 kernel: IP: [<ffffffff803f0d77>] disk_part_iter_next+0x74/0xfd
15:27:13.014 kernel: PGD 82ad0b067 PUD 82cd7e067 PMD 0
15:27:13.014 kernel: Oops: 0000 [#1] PREEMPT SMP
15:27:13.014 kernel: last sysfs file: /sys/devices/platform/host9/session4/iscsi_session/session4/ifacename
15:27:13.014 kernel: CPU 5
15:27:13.014 kernel: Modules linked in:
15:27:13.014 kernel: Pid: 13999, comm: async/0 Not tainted 2.6.30.4-elastic-lon-p #2 X7DBN
15:27:13.014 kernel: RIP: 0010:[<ffffffff803f0d77>] [<ffffffff803f0d77>] disk_part_iter_next+0x74/0xfd
15:27:13.014 kernel: RSP: 0018:ffff88066afa3dd0 EFLAGS: 00010246
15:27:13.014 kernel: RAX: ffff88082b58a000 RBX: ffff88066afa3e00 RCX: 0000000000000000
15:27:13.014 kernel: RDX: 0000000000000000 RSI: ffff88082b58a000 RDI: 0000000000000000
15:27:13.014 kernel: RBP: ffff88066afa3df0 R08: ffff88066afa2000 R09: ffff8806a204f000
15:27:13.014 kernel: R10: 000000fb12c7d274 R11: ffff8806c2bf0628 R12: ffff88066afa3e00
15:27:13.014 kernel: R13: ffff88082c829a00 R14: 0000000000000000 R15: ffff8806bc50c920
15:27:13.014 kernel: FS: 0000000000000000(0000) GS:ffff88002818a000(0000) knlGS:0000000000000000
15:27:13.014 kernel: CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
15:27:13.014 kernel: CR2: 0000000000000010 CR3: 000000082ade3000 CR4: 00000000000426e0
15:27:13.014 kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
15:27:13.014 kernel: DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
15:27:13.014 kernel: Process async/0 (pid: 13999, threadinfo ffff88066afa2000, task ffff8806c2bf05e0)
15:27:13.014 kernel: Stack:
15:27:13.014 kernel: 0000000000000000 ffff88066afa3e00 ffff88066afa3e00 ffff88082c829a00
15:27:13.014 kernel: ffff88066afa3e40 ffffffff80306feb ffff88082b58a000 0000000000000000
15:27:13.014 kernel: 0000000000000001 ffff8806bc50c920 ffff88066afa3e40 ffff88082b58a000
15:27:13.014 kernel: Call Trace:
15:27:13.014 kernel: [<ffffffff80306feb>] register_disk+0x122/0x13a
15:27:13.014 kernel: [<ffffffff803f0b0f>] add_disk+0xaa/0x106
15:27:13.014 kernel: [<ffffffff80493609>] sd_probe_async+0x198/0x25b
15:27:13.014 kernel: [<ffffffff80270482>] async_thread+0x10c/0x20d
15:27:13.014 kernel: [<ffffffff802545ff>] ? default_wake_function+0x0/0xf
15:27:13.014 kernel: [<ffffffff80270376>] ? async_thread+0x0/0x20d
15:27:13.014 kernel: [<ffffffff8026ad89>] kthread+0x55/0x80
15:27:13.014 kernel: [<ffffffff8022be6a>] child_rip+0xa/0x20
15:27:13.014 kernel: [<ffffffff8026ad34>] ? kthread+0x0/0x80
15:27:13.014 kernel: [<ffffffff8022be60>] ? child_rip+0x0/0x20
15:27:13.014 kernel: Code: c8 ff 80 e1 0c b9 00 00 00 00 0f 44 c1 41 83 cd ff 48 8d 7a 20 48 be ff ff ff ff 08 00 00 00 48 b9 00 00 00 00 08 00 00 00 eb 50 <8b> 42 10 41 bd 01 00 00 00 eb db 4c 63 c2 4e 8d 04 c7 4d 8b 20
15:27:13.015 kernel: RIP [<ffffffff803f0d77>] disk_part_iter_next+0x74/0xfd
15:27:13.015 kernel: RSP <ffff88066afa3dd0>
15:27:13.015 kernel: CR2: 0000000000000010
15:27:13.015 kernel: ---[ end trace 6104b56ef5590e25 ]---
The problem is caused because the async scanning split in sd.c doesn't hold
any reference to the device when it kicks off the async piece. What's
happening is that an iSCSI disconnect is destorying the device again *before*
the async sd scanning thread even starts. Fix this by taking a reference
before starting the thread and dropping it again when the thread completes.
Reported-by: Chris Webb <chris@arachsys.com>
commit ed79f1280d1bc54f168abcffc8c3e0bf8ffb1873 upstream.
This patch modifies the slave_configure callback so the messages that get sent
to system log for RAID1E volumes contain the string "RAID10" instead of
"RAID1E". These messages contain information regarding what kind of scsi device
is being added. Certain OEMS can enable displaying the RAID10 string instead of
RAID1E via manufacturing page 10. The driver will read this config page at
driver load time, then determine from the GenericFlags0 bits whether display
the RAID10 or RAID1E string, also even drive count is taken into consideration.
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com>
Reviewed-by: Eric Moore <Eric.moore@lsi.com>
commit 34a03bef2202d0c9983a8da0a8abaee37d285847 upstream.
Changing SDEV Running state from interrupt context. Previously It was
handle in work queue thread. With this change It will not wait for work
queue thread to execute scsih_ublock_io_device to put SDEV into Running
state. This will reduce delay for Device becoming RUNNING.
Modified this patch considering James comment "Not to change SDEV state
using scsi_device_set_state API, instead use scsi_internal_device_unblock
scsi_internal_device_block API"
commit 155dd4c763694222c125e65438d823f58ea653bc upstream.
This patch renames the flag for indicating host reset from
ioc_reset_in_progress to shost_recovery. It also removes the spin locks
surrounding the setting of this flag, which are unnecessary. Sanity checks on
the shost_recovery flag were added thru out the code so as to prevent sending
firmware commands during host reset. Also, the setting of the shost state to
SHOST_RECOVERY was removed to prevent deadlocks, this is actually better
handled by the shost_recovery flag.
commit cd4e12e8ad246ec5bc23ab04d0da0e6985025620 upstream.
Following host reset its possible that the controller firmware could
assign new handles for devices, as well as adding or deleting devices. There is
code in the driver that will rescan the topology folowing host reset; updating
device handles, and remove devices that are no longer responding. This patch
will improve the responsivness by moving this rescaning from the delayed hotplug
worker thread to immediately following the host reset.
commit e71044ee2efa4792e21d243b03d49006db66aec9 upstream.
When the allocation fails in sg_build_indirect(), an oops happens in
the error path. It's caused by an obvious typo.
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Reported-by: Bob Tracy <rct@gherkin.frus.com>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
Andy Whitcroft reported an oops in aoe triggered by use of an
incorrectly initialised request_queue object:
[ 2645.959090] kobject '<NULL>' (ffff880059ca22c0): tried to add
an uninitialized object, something is seriously wrong.
[ 2645.959104] Pid: 6, comm: events/0 Not tainted 2.6.31-5-generic #24-Ubuntu
[ 2645.959107] Call Trace:
[ 2645.959139] [<ffffffff8126ca2f>] kobject_add+0x5f/0x70
[ 2645.959151] [<ffffffff8125b4ab>] blk_register_queue+0x8b/0xf0
[ 2645.959155] [<ffffffff8126043f>] add_disk+0x8f/0x160
[ 2645.959161] [<ffffffffa01673c4>] aoeblk_gdalloc+0x164/0x1c0 [aoe]
The request queue of an aoe device is not used but can be allocated in
code that does not sleep.
Bruno bisected this regression down to
cd43e26f071524647e660706b784ebcbefbd2e44
block: Expose stacked device queues in sysfs
"This seems to generate /sys/block/$device/queue and its contents for
everyone who is using queues, not just for those queues that have a
non-NULL queue->request_fn."
Addresses http://bugs.launchpad.net/bugs/410198
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13942
Note that embedding a queue inside another object has always been
an illegal construct, since the queues are reference counted and
must persist until the last reference is dropped. So aoe was
always buggy in this respect (Jens).
Signed-off-by: Ed Cashin <ecashin@coraid.com>
Cc: Andy Whitcroft <apw@canonical.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Bruno Premont <bonbons@linux-vserver.org>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Reinette Chatre reports a frozen system (with blinking keyboard LEDs)
when switching from graphics mode to the text console, or when
suspending (which does the same thing). With netconsole, the oops
turned out to be
BUG: unable to handle kernel NULL pointer dereference at 0000000000000084
IP: [<ffffffffa03ecaab>] i915_driver_irq_handler+0x26b/0xd20 [i915]
and it's due to the i915_gem.c code doing drm_irq_uninstall() after
having done i915_gem_idle(). And the i915_gem_idle() path will do
i915_gem_idle() ->
i915_gem_cleanup_ringbuffer() ->
i915_gem_cleanup_hws() ->
dev_priv->hw_status_page = NULL;
but if an i915 interrupt comes in after this stage, it may want to
access that hw_status_page, and gets the above NULL pointer dereference.
And since the NULL pointer dereference happens from within an interrupt,
and with the screen still in graphics mode, the common end result is
simply a silently hung machine.
Fix it by simply uninstalling the irq handler before idling rather than
after. Fixes
http://bugzilla.kernel.org/show_bug.cgi?id=13819
Reported-and-tested-by: Reinette Chatre <reinette.chatre@intel.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
eDP is exclusive connector too, and add missing crtc_mask
setting for TV.
This fixes
http://bugzilla.kernel.org/show_bug.cgi?id=14139
Reported-and-tested-by: Carlos R. Mafra <crmafra2@gmail.com>
