commit ccc2d97cb7c798e785c9f198de243e2b59f7073b upstream.
commit 2783ef23 moved the initialisation of saddr and daddr after
pskb_may_pull() to avoid a potential data corruption. Unfortunately
also placing it after the short packet and bad checksum error paths,
where these variables are used for logging. The result is bogus
output like
[92238.389505] UDP: short packet: From 2.0.0.0:65535 23715/178 to 0.0.0.0:65535
Moving the saddr and daddr initialisation above the error paths, while still
keeping it after the pskb_may_pull() to keep the fix from commit 2783ef23.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
This reverts commit d150a2b96558a7349cbf3a72a279c37bc67d50fb.
Thanks to Jiri Benc for finding the problem that this patch is
not correct for the 2.6.32-stable series.
Cc: Jiri Kosina <jkosina@suse.cz>
(cherry picked from commit e65c7f33d75e977350ca350573d93c517ec02776)
Previously it was unconditionally used on all Sibyte family SOCs. The
M3 bug has to be handled in the TLB exception handler which is extremly
performance sensitive, so this modification is expected to deliver around
2-3% performance improvment. This is important as required changes to the
M3 workaround will make it more costly.
commit 77a4229719e511a0d38d9c355317ae1469adeb54 upstream.
There's nastyness in the way we currently handle barriers (and
discards): They're effectively filesystem commands, but they get
processed as BLOCK_PC commands. Unfortunately BLOCK_PC commands are
taken by SCSI to be SG_IO commands and the issuer expects to see and
handle any returned errors, however trivial. This leads to a huge
problem, because the block layer doesn't expect this to happen and any
trivially retryable error on a barrier causes an immediate I/O error
to the filesystem.
The only real way to hack around this is to take the usual class of
offending errors (unit attentions) and make them all retryable in the
case of a REQ_HARDBARRIER. A correct fix would involve a rework of
the entire block and SCSI submit system, and so is out of scope for a
quick fix.
Cc: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit c213e1407be6b04b144794399a91472e0ef92aec upstream.
Some arrays are giving I/O errors with ext3 filesystems when
SYNCHRONIZE_CACHE gets a UNIT_ATTENTION. What is happening is that
these commands have no retries, so the UNIT_ATTENTION causes the
barrier to fail. We should be enable retries here to clear any
transient error and allow the barrier to succeed.
Signed-off-by: Hannes Reinecke <hare@suse.de>
commit 5447ed6c968e7270b656afa273c2b79d15d82edd upstream.
In the scsi_debug driver, the virtual_gb option ignores the
sector_size, implicitly assuming that is 512 bytes. So if
'virtual_gb=1 sector_size=4096' the result is an 8 GB (virtual) disk.
Signed-off-by: Douglas Gilbert <dgilbert@interlog.com>
commit 96b1f96dcab87756c0a1e7ba76bc5dc2add82b88 upstream.
This fixes a regression introduced with this commit:
commit d3305f3407fa3e9452079ec6cc8379067456e4aa
Author: Mike Christie <michaelc@cs.wisc.edu>
Date: Thu Aug 20 15:10:58 2009 -0500
[SCSI] libiscsi: don't increment cmdsn if cmd is not sent
in 2.6.32.
When I moved the hdr->cmdsn after init_task, I added
a bug when header digests are used. The problem is
that the LLD may calculate the header digest in init_task,
so if we then set the cmdsn after the init_task call we
change what the digest will be calculated by the target.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
commit 70b25f890ce9f0520c64075ce9225a5b020a513e upstream.
blk_abort_request() expects queue lock to be held by the caller.
Grab it before calling the function.
Lack of this synchronization led to infinite loop on corrupt
q->timeout_list.
commit ccb8d8d070b8f25f0163da5c9ceacf63a5169540 upstream.
The use of mfp_cfg_t causes build errors without including <mach/mfp.h>.
CC: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Jakob Viketoft <jakob.viketoft@bitsim.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
commit 1c6fe0364fa7bf28248488753ee0afb6b759cd04 upstream.
commit 672917dcc78 ("cpuidle: menu governor: reduce latency on exit")
added an optimization, where the analysis on the past idle period moved
from the end of idle, to the beginning of the new idle.
Unfortunately, this optimization had a bug where it zeroed one key
variable for new use, that is needed for the analysis. The fix is
simple, zero the variable after doing the work from the previous idle.
During the audit of the code that found this issue, another issue was
also found; the ->measured_us data structure member is never set, a
local variable is always used instead.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Corrado Zoccolo <czoccolo@gmail.com>
commit ea5bc73f4f56449b2d450068d492bcd17a675d7a upstream.
Add Dell Studio models (1558, 1557, 1555) to the 'set_sci_en_on_resume'
list to fix hang on resume.
BugLink: http://bugs.launchpad.net/bugs/553498
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
Acked-by: Alex Chiang <achiang@canonical.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 18262714ca0fb65c290b8ea1807b2b02bb52d0e3 upstream.
acpi_device_class can only be 19 characters and a NULL terminator.
The current code has a buffer overflow in acpi_power_meter_add():
strcpy(acpi_device_class(device), ACPI_POWER_METER_CLASS);
Cc: Len Brown <lenb@kernel.org>
Cc: "Darrick J. Wong" <djwong@us.ibm.com>
commit 07bedca29b0973f36a6b6db36936deed367164ed upstream.
Multiple Lenovo ThinkPad models with Intel Core i5/i7 CPUs can
successfully suspend/resume once, and then hang on the second s/r
cycle.
We got confirmation that this was due to a BIOS defect. The BIOS
did not properly set SCI_EN coming out of S3. The BIOS guys
hinted that The Other Leading OS ignores the fact that hardware
owns the bit and sets it manually.
In any case, an existing DMI table exists for machines where this
defect is a known problem. Lenovo promise to fix their BIOS, but
for folks who either won't or can't upgrade their BIOS, allow
Linux to workaround the issue.
https://bugzilla.kernel.org/show_bug.cgi?id=15407
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/532374
Confirmed by numerous testers in the launchpad bug that using
acpi_sleep=sci_force_enable fixes the issue. We add the machines
to acpisleep_dmi_table[] to automatically enable this workaround.
Cc: Colin King <colin.king@canonical.com>
Signed-off-by: Alex Chiang <achiang@canonical.com>
commit 6f550dc08369ee0bc6402963c377e65f0f2e3b71 upstream.
Never call dvb_frontend_detach if we failed to attach a frontend. This fixes
the following oops, which will be triggered by a missing stv090x module:
[ 8.172997] DVB: registering new adapter (TT-Budget S2-1600 PCI)
[ 8.209018] adapter has MAC addr = 00:d0:5c:cc:a7:29
[ 8.328665] Intel ICH 0000:00:1f.5: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 8.328753] Intel ICH 0000:00:1f.5: setting latency timer to 64
[ 8.562047] DVB: Unable to find symbol stv090x_attach()
[ 8.562117] BUG: unable to handle kernel NULL pointer dereference at 000000ac
[ 8.562239] IP: [<e08b04a3>] dvb_frontend_detach+0x4/0x67 [dvb_core]
Ref http://bugs.debian.org/575207
commit 87aa63000c484bfb9909989316f615240dfee018 upstream.
Fix: Raid-6 was not trying to correct a read-error when in
singly-degraded state and was instead dropping one more device, going to
doubly-degraded state. This patch fixes this behaviour.
Tested-by: Janos Haar <janos.haar@netcenter.hu>
Signed-off-by: Gabriele A. Trombetti <g.trombetti.lkrnl1213@logicschema.com>
Reported-by: Janos Haar <janos.haar@netcenter.hu>
Signed-off-by: NeilBrown <neilb@suse.de>
commit e2dbe06c271f3bb2a495627980aad3d1d8ccef2a upstream.
Move initialization of the virtio framework before the initialization of
mtd, so that block2mtd can be used on virtio-based block devices.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15644
Signed-off-by: Stijn Tintel <stijn@linux-ipv6.be>
commit 1176568de7e066c0be9e46c37503b9fd4730edcf upstream.
Some time ago we stopped the clean/active metadata updates
from being written to a 'spare' device in most cases so that
it could spin down and say spun down. Device failure/removal
etc are still recorded on spares.
However commit 51d5668cb2e3fd1827a55 broke this 50% of the time,
depending on whether the event count is even or odd.
The change log entry said:
This means that the alignment between 'odd/even' and
'clean/dirty' might take a little longer to attain,
how ever the code makes no attempt to create that alignment, so it
could take arbitrarily long.
So when we find that clean/dirty is not aligned with odd/even,
force a second metadata-update immediately. There are already cases
where a second metadata-update is needed immediately (e.g. when a
device fails during the metadata update). We just piggy-back on that.
Reported-by: Joe Bryant <tenminjoe@yahoo.com>
commit b338cc8207eae46640a8d534738fda7b5e48511d upstream.
There is a typo here. We should be testing "*dentry" instead of
"dentry". If "*dentry" is an ERR_PTR, it gets dereferenced in either
mkdir() or create() which would cause an OOPs.
Signed-off-by: James Morris <jmorris@namei.org>
commit 86c38a31aa7f2dd6e74a262710bf8ebf7455acc5 upstream.
GCC 4.5 introduces behavior that forces the alignment of structures to
use the largest possible value. The default value is 32 bytes, so if
some structures are defined with a 4-byte alignment and others aren't
declared with an alignment constraint at all - it will align at 32-bytes.
For things like the ftrace events, this results in a non-standard array.
When initializing the ftrace subsystem, we traverse the _ftrace_events
section and call the initialization callback for each event. When the
structures are misaligned, we could be treating another part of the
structure (or the zeroed out space between them) as a function pointer.
This patch forces the alignment for all the ftrace_event_call structures
to 4 bytes.
Without this patch, the kernel fails to boot very early when built with
gcc 4.5.
It's trivial to check the alignment of the members of the array, so it
might be worthwhile to add something to the build system to do that
automatically. Unfortunately, that only covers this case. I've asked one
of the gcc developers about adding a warning when this condition is seen.
Cc: stable@kernel.org
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
LKML-Reference: <4B85770B.6010901@suse.com>
Cc: Andreas Radke <a.radke@arcor.de>
commit c441b8d2cb2194b05550a558d6d95d8944e56a84 upstream.
It has been reported that under certain heavy traffic conditions in MSI-X
mode, the driver can lose an MSI-X vector causing all packets in the
associated rx/tx ring pair to be dropped. The problem is caused by
the chip dropping the write to unmask the MSI-X vector by the kernel
(when migrating the IRQ for example).
This can be prevented by increasing the GRC timeout value for these
register read and write operations.
Thanks to Dell for helping us debug this problem.
Signed-off-by: Michael Chan <mchan@broadcom.com>
commit 0f00a206ccb1dc644b6770ef25f185610fee6962 upstream.
Correct issues where the lower scsi-status would be improperly
cleared, instead, allow the midlayer to process the status after
the proper residual-count checks are performed. Finally,
validate firmware status flags prior to assigning values from the
FCP_RSP frame.
Signed-off-by: Lalit Chandivade <lalit.chandivade@qlogic.com>
Signed-off-by: Michael Hernandez <michael.hernandez@qlogic.com>
Signed-off-by: Ravi Anand <ravi.anand@qlogic.com>
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
commit 5fd4514bb351b5ecb0da3692fff70741e5ed200c upstream.
Set the PCI CLS early in the boot process to prevent
device failures. In pcibios_set_master use the new
pci_cache_line_size instead of a hard-coded value.
Signed-off-by: Carlos O'Donell <carlos@codesourcery.com>
Reviewed-by: Grant Grundler <grundler@google.com>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
commit 9bf729c0af67897ea8498ce17c29b0683f7f2028 upstream
On low memory boxes or those with highmem, kernel can OOM before the
background reclaims inodes via xfssyncd. Add a shrinker to run inode
reclaim so that it inode reclaim is expedited when memory is low.
This is more complex than it needs to be because the VM folk don't
want a context added to the shrinker infrastructure. Hence we need
to add a global list of XFS mount structures so the shrinker can
traverse them.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Acked-by: Alex Elder <aelder@sgi.com>
commit dc8bf1b1a6edfc92465526de19772061302f0929 upstream.
tg3: Fix INTx fallback when MSI fails
MSI setup changes the value of irq_vec in struct tg3 *tp.
This attribute must be taken into account and restored before
we try to do a new request_irq for INTx fallback.
In powerpc, the original code was leading to an EINVAL return within
request_irq, because the driver was trying to use the disabled MSI
virtual irq number instead of tp->pdev->irq.
Signed-off-by: Andre Detsch <adetsch@br.ibm.com>
Acked-by: Michael Chan <mchan@broadcom.com>
Cc: Brandon Philips <bphilips@suse.de>
commit e7efe5932b1d3916c79326a4221693ea90a900e2 upstream.
Further to the lsml thread titled:
"does scsi_io_completion need to dump sense data for ata pass through (ck_cond =
1) ?"
This is a patch to skip logging when the sense data is
associated with a SENSE_KEY of "RECOVERED_ERROR" and the
additional sense code is "ATA PASS-THROUGH INFORMATION
AVAILABLE". This only occurs with the SAT ATA PASS-THROUGH
commands when CK_COND=1 (in the cdb). It indicates that
the sense data contains ATA registers.
Smartmontools uses such commands on ATA disks connected via
SAT. Periodic checks such as those done by smartd cause
nuisance entries into logs that are:
- neither errors nor warnings
- pointless unless the cdb that caused them are also logged
commit cc2893b6af5265baa1d68b17b136cffca9e40cfa upstream.
If the firmware puts a device back into D0 state at resume time, we'll
update its state in resume_noirq and thus skip the platform resume code.
Calling that code twice should be safe and we ought to avoid getting to
that point anyway, so remove the check and also allow the platform pci
code to be called for D0.
Fixes USB not being powered after resume on recent Lenovo machines.
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 908ba2bfd22253f26fa910cd855e4ccffb1467d0 upstream.
78f1cd02457252e1ffbc6caa44a17424a45286b8 ("fix broken register writes")
does not work for Al Viro's r8169 (XID 18000000).
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
commit 78f1cd02457252e1ffbc6caa44a17424a45286b8 upstream.
This is quite similar to b39fe41f481d20c201012e4483e76c203802dda7
though said registers are not even documented as 64-bit registers
- as opposed to the initial TxDescStartAddress ones - but as single
bytes which must be combined into 32 bits at the MMIO read/write
level before being merged into a 64 bit logical entity.
Credits go to Ben Hutchings <ben@decadent.org.uk> for the MAR
registers (aka "multicast is broken for ages on ARM) and to
Timo Teräs <timo.teras@iki.fi> for the MAC registers.
commit 4c020a961a812ffae9846b917304cea504c3a733 upstream.
r8169 needs certain writes to be visible to other CPUs or the NIC before
touching the hardware, but was using smp_wmb() which is only required to
order cacheable memory access. Switch to wmb() which is required to
order both cacheable and non-cacheable memory.
Noticed by Catalin Marinas and Paul Mackerras.
Signed-off-by: David Dillow <dave@thedillows.org>
commit 56151e753468e34aeb322af4b0309ab727c97d2e upstream.
The bypassing of this test is a leftover from 2.4 vintage
kernels, and is no longer appropriate, or even used by KGDB.
Currently KGDB uses probe_kernel_write() for all access to
memory via the KGDB core, so it can simply be deleted.
This fixes CVE-2010-1446.
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: Paul Mackerras <paulus@samba.org>
CC: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Wufei <fei.wu@windriver.com>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Commit 78ce64a384 in v2.6.32.12 introduced a warning due to unused
load_segment_descriptor_to_kvm_desct helper, which has been opencoded by
this commit.
On upstream, the helper was removed as part of a different commit.
Remove the now unused function.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 38ff3e6bb987ec583268da8eb22628293095d43b upstream.
This was just recently reported to me. When built as modules, the
dccp_probe module has a silent dependency on the dccp module. This
stems from the fact that the module_init routine of dccp_probe
registers a jprobe on the dccp_sendmsg symbol. Since the symbol is
only referenced as a text string (the .symbol_name field in the jprobe
struct) rather than the address of the symbol itself, depmod never
picks this dependency up, and so if you load the dccp_probe module
without the dccp module loaded, the register_jprobe call fails with an
-EINVAL, and the whole module load fails.
The fix is pretty easy, we can just wrap the register_jprobe call in a
try_then_request_module call, which forces the dependency to get
satisfied prior to the probe registration.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: maximilian attems <max@stro.at>
commit 088ea189c4c75cdf211146faa4b341a0f7476be6 upstream.
fix off by one error in the queue size check of p54_tx_qos_accounting_alloc()
Coverity CID: 13314
Signed-off-by: Darren Jenkins <darrenrjenkins@gmail.com>
commit f5300e04df78feae8107c1846dd3a9e27c071b2f upstream.
A long time ago, a user reported several crashes due to
data corruptions which are likely the result of a
not-100%-supported, or faulty? PCI bridge.
( http://patchwork.kernel.org/patch/53004/ )
This patch fixes entry #1.
"1. p54p_check_rx_ring - skb_over_panic: Under a ping flood
or just left running for a bit would panic with a skb_over_panic."
As described in the mail: The invalid frame length causes
skb_put to bailout and trigger a crash.
Note:
Simply dropping the frame is problematic, because if its content
contains a tx feedback we would lose some portion of the device
memory space.... And the driver/mac80211 should handle all other
invalid data.
Reported-by: Quintin Pitts <geek4linux@gmail.com>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit d7f0eea9e431e1b8b0742a74db1a9490730b2a25 upstream.
Introduce kernel parameter acpi_sleep=sci_force_enable
some laptop requires SCI_EN being set directly on resume,
or else they hung somewhere in the resume code path.
We already have a blacklist for these laptops but we still need
this option, especially when debugging some suspend/resume problems,
in case there are systems that need this workaround and are not yet
in the blacklist.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
commit 2b0b39517d1af5294128dbc2fd7ed39c8effa540 upstream.
Resizing the filesystem would result in an diAllocExt error in some
instances because changes in bmp->db_agsize would not get noticed if
goto extendBmap was called.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: jfs-discussion@lists.sourceforge.net
commit e134d200d57d43b171dcb0b55c178a1a0c7db14a upstream.
creds_are_invalid() reads both cred->usage and cred->subscribers and then
compares them to make sure the number of processes subscribed to a cred struct
never exceeds the refcount of that cred struct.
The problem is that this can cause a race with both copy_creds() and
exit_creds() as the two counters, whilst they are of atomic_t type, are only
atomic with respect to themselves, and not atomic with respect to each other.
This means that if creds_are_invalid() can read the values on one CPU whilst
they're being modified on another CPU, and so can observe an evolving state in
which the subscribers count now is greater than the usage count a moment
before.
Switching the order in which the counts are read cannot help, so the thing to
do is to remove that particular check.
I had considered rechecking the values to see if they're in flux if the test
fails, but I can't guarantee they won't appear the same, even if they've
changed several times in the meantime.
Note that this can only happen if CONFIG_DEBUG_CREDENTIALS is enabled.
The problem is only likely to occur with multithreaded programs, and can be
tested by the tst-eintr1 program from glibc's "make check". The symptoms look
like:
CRED: Invalid credentials
CRED: At include/linux/cred.h:240
CRED: Specified credentials: ffff88003dda5878 [real][eff]
CRED: ->magic=43736564, put_addr=(null)
CRED: ->usage=766, subscr=766
CRED: ->*uid = { 0,0,0,0 }
CRED: ->*gid = { 0,0,0,0 }
CRED: ->security is ffff88003d72f538
CRED: ->security {359, 359}
kernel BUG at kernel/cred.c:850!
RIP: 0010:[<ffffffff81049889>] [<ffffffff81049889>] __invalid_creds+0x4e/0x52
Call Trace:
[<ffffffff8104a37b>] copy_creds+0x6b/0x23f
Note the ->usage=766 and subscr=766. The values appear the same because
they've been re-read since the check was made.
Reported-by: Roland McGrath <roland@redhat.com>
commit c36a2a6de59e4a141a68b7575de837d3b0bd96b3 upstream.
Current code is definitely crap: Largest pitch allowed spills into
the TILING_Y bit of the fence registers ... :(
I've rewritten the limits check under the assumption that 3rd gen hw
has a 3d pitch limit of 8kb (like 2nd gen). This is supported by an
otherwise totally misleading XXX comment.
This bug mostly resulted in tiling-corrupted pixmaps because the kernel
allowed too wide buffers to be tiled. Bug brought to the light by the
xf86-video-intel 2.11 release because that unconditionally enabled
tiling for pixmaps, relying on the kernel to check things. Tiling for
the framebuffer was not affected because the ddx does some additional
checks there ensure the buffer is within hw-limits.
v2: Instead of computing the value that would be written into the
hw fence registers and then checking the limits simply check whether
the stride is above the 8kb limit. To better document the hw, add
some WARN_ONs in i915_write_fence_reg like I've done for the i830
case (using the right limits).
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=27449
Tested-by: Alexander Lam <lambchop468@gmail.com>
Signed-off-by: Eric Anholt <eric@anholt.net>
commit df37bd156dcb4f5441beaf5bde444adac974e9a0 upstream.
The unpack routine fails to handle the decompress_method() returning
unrecognised decompressor (compress_name == NULL). This results in the
routine looping eventually oopsing on an out of bounds memory access.
Note this bug is usually hidden, only triggering on trailing junk after
one or more correct compressed blocks. The case of the compressed archive
being complete junk is (by accident?) caught by the if (state != Reset)
check because state is initialised to Start, but not updated due to the
decompressor not having been called. Obviously if the junk is trailing a
correctly decompressed buffer, state == Reset from the previous call to
the decompressor.
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit aca92ff6f57c000d1b4523e383c8bd6b8269b8b1 upstream.
ext4_fiemap() rounds the length of the requested range down to
blocksize, which is is not the true number of blocks that cover the
requested region. This problem is especially impressive if the user
requests only the first byte of a file: not a single extent will be
reported.
We fix this by calculating the last block of the region and then
subtract to find the number of blocks in the extents.
Signed-off-by: Leonard Michlmayr <leonard.michlmayr@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 45c4d015a92f72ec47acd0c7557abdc0c8a6499d upstream.
Most drives from Seagate, Hitachi, and possibly other brands,
do not allow LBA28 access to sector number 0x0fffffff (2^28 - 1).
So instead use LBA48 for such accesses.
This bug could bite a lot of systems, especially when the user has
taken care to align partitions to 4KB boundaries. On misaligned systems,
it is less likely to be encountered, since a 4KB read would end at
0x10000000 rather than at 0x0fffffff.
Signed-off-by: Mark Lord <mlord@pobox.com>
commit c53666813813a0ea3d0391e1911eefc05a5e6b4f upstream.
BugLink: https://launchpad.net/bugs/549267
The OR verified that using the olpc-xo-1_5 model quirk allows the
headphones to be audible when inserted into the jack. Capture was
also verified to work correctly.
Reported-by: Richard Gagne
Tested-by: Richard Gagne
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
commit 4442dd4613fe3795b4c8a5f42fc96b7ffb90d01a upstream.
BugLink: https://launchpad.net/bugs/573284
Reported-by: Andy Couldrake <acouldrake@googlemail.com>
Tested-by: Andy Couldrake <acouldrake@googlemail.com>
commit 8f0f5ff6777104084b4b2e1ae079541c2a6ed6d9 upstream.
BugLink: https://launchpad.net/bugs/541802
The OR's hardware distorts at PCM 100% because it does not correspond to
0 dB. Fix this in patch_cxt5045() for all Packard Bell models.
Reported-by: Valombre
CX20549 (Venice)
commit 0b587fc4d35afb1bc0fc3d890084bb14c78372dc upstream.
BugLink: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4792
Cristian reported that these models have really bad sound above 6 dB
and proposed the original patch. I've updated the comment to reflect
this change.
Reported-by: Cristian Klein
commit 715aa675338ce6e1a3b4f77cf87ea611f93058a8 upstream.
Ignore spurious HV interrupts during suspend / resume, this avoids
mistaking them for a mute button press. This is not very pretty but
it seems the only way to fix the master volume control gets muted
after suspend issue I'm seeing. Note that the es1968 driver is doing
exactly the same.
commit 7efbfd1ae98ef9efe06352e2a1ad83e8c14ceeb1 upstream.
Without this quirk sound stops working after suspend resume. With this quirk,
one still needs to manually unmute the master volume control after a suspend /
/ resume cycle. That is fixed in another patch in this set.
Note that this patch was submitted to the alsa bug tracker a long time ago:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4319
commit 3353541fe533350a22a03e2fb7dc085b35912575 upstream.
BugLink: https://launchpad.net/bugs/567494
The OR has verified that the existing model quirk, ALC880_UNIWILL,
is insufficient for audible playback and capture by default. Instead,
the ALC880_F1734 model quirk needs to be used.
This change is necessary for both 2.6.32.11 and 2.6.33.2.
Reported-by: Arnaud Malpeyre <amalpeyre@gmail.com>
Tested-by: Arnaud Malpeyre <amalpeyre@gmail.com>
commit 5c1bccf645d4ab65e4c7502acb42e8b9afdb5bdc upstream.
BugLink: https://launchpad.net/bugs/568600
The OR has verified that the dell-m6 model quirk is necessary for audio
to be audible by default on the Dell Studio XPS 1645.
This change is necessary for 2.6.32.11 and 2.6.33.2 alike.
Reported-by: Andy Ross <andy@plausible.org>
Tested-by: Andy Ross <andy@plausible.org>
