2010-01-22Linux 2.6.32.5v2.6.32.5Greg Kroah-Hartman
2010-01-22vfs: Fix vmtruncate() regressionOGAWA Hirofumi
commit cedabed49b39b4319bccc059a63344b6232b619c upstream. If __block_prepare_write() was failed in block_write_begin(), the allocated blocks can be outside of ->i_size. But new truncate_pagecache() in vmtuncate() does nothing if new < old. It means the above usage is not working anymore. So, this patch fixes it by removing "new < old" check. It would need more cleanup/change. But, now -rc and truncate working is in progress, so, this tried to fix it minimum change. Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22sched: Fix task priority bugPeter Zijlstra
commit 57785df5ac53c70da9fb53696130f3c551bfe1f9 upstream. 83f9ac removed a call to effective_prio() in wake_up_new_task(), which leads to tasks running at MAX_PRIO. This is caused by the idle thread being set to MAX_PRIO before forking off init. O(1) used that to make sure idle was always preempted, CFS uses check_preempt_curr_idle() for that so we can savely remove this bit of legacy code. Reported-by: Mike Galbraith <efault@gmx.de> Tested-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1259754383.4003.610.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22serial/8250_pnp: add a new Fujitsu Wacom Tablet PC devicePing
commit 3018aa4b1a46946dfd0ee73a533038f24e390539 upstream. This is a new two finger touch Fujitsu Wacom Tablet PC. Signed-off-by: Ping Cheng <pingc@wacom.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22i2c/pca: Don't use *_interruptibleWolfram Sang
commit 22f8b2695eda496026623020811cae34590ee3d7 upstream. Unexpected signals can disturb the bus-handling and lock it up. Don't use interruptible in 'wait_event_*' and 'wake_*' as in commits dc1972d02747d2170fb1d78d114801f5ecb27506 (for cpm), 1ab082d7cbd0f34e39a5396cc6340c00bc5d66ef (for mpc), b7af349b175af45f9d87b3bf3f0a221e1831ed39 (for omap). Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22i2c: Do not use device name after device_unregisterThadeu Lima de Souza Cascardo
commit c556752109794a5ff199b80a1673336b4df8433a upstream. dev_dbg outputs dev_name, which is released with device_unregister. This bug resulted in output like this: i2c Xy2�0: adapter [SMBus I801 adapter at 1880] unregistered The right output would be: i2c i2c-0: adapter [SMBus I801 adapter at 1880] unregistered Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22sparc64: Fix Niagara2 perf event handling.David S. Miller
[ Upstream commit e04ed38d4e0cd32141f723560efcc8252b0241e2 ] For chips like Niagara2 that have true overflow indications in the %pcr (which we don't actually need and don't use) the interrupt signal persists until the overflow bits are cleared by an explicit %pcr write. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22sparc64: Fix NMI programming when perf events are active.David S. Miller
[ Upstream commit 8183e2b38480672a1f61d416812ac078ce94b67b ] If perf events are active, we should not reset the %pcr to PCR_PIC_PRIV. That perf events code does the management. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22sched: Fix cpu_clock() in NMIs, on !CONFIG_HAVE_UNSTABLE_SCHED_CLOCKDavid Miller
commit b9f8fcd55bbdb037e5332dbdb7b494f0b70861ac upstream. Relax stable-sched-clock architectures to not save/disable/restore hardirqs in cpu_clock(). The background is that I was trying to resolve a sparc64 perf issue when I discovered this problem. On sparc64 I implement pseudo NMIs by simply running the kernel at IRQ level 14 when local_irq_disable() is called, this allows performance counter events to still come in at IRQ level 15. This doesn't work if any code in an NMI handler does local_irq_save() or local_irq_disable() since the "disable" will kick us back to cpu IRQ level 14 thus letting NMIs back in and we recurse. The only path which that does that in the perf event IRQ handling path is the code supporting frequency based events. It uses cpu_clock(). cpu_clock() simply invokes sched_clock() with IRQs disabled. And that's a fundamental bug all on it's own, particularly for the HAVE_UNSTABLE_SCHED_CLOCK case. NMIs can thus get into the sched_clock() code interrupting the local IRQ disable code sections of it. Furthermore, for the not-HAVE_UNSTABLE_SCHED_CLOCK case, the IRQ disabling done by cpu_clock() is just pure overhead and completely unnecessary. So the core problem is that sched_clock() is not NMI safe, but we are invoking it from NMI contexts in the perf events code (via cpu_clock()). A less important issue is the overhead of IRQ disabling when it isn't necessary in cpu_clock(). CONFIG_HAVE_UNSTABLE_SCHED_CLOCK architectures are not affected by this patch. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <20091213.182502.215092085.davem@davemloft.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22asus-laptop: add Lenovo SL hotkey supportIke Panhc
commit 14f8af311e7d3e4198cbaade84a34f86505dcb37 upstream. Lenovo SL series laptop has a very similar DSDT with Asus laptops. We can easily have the extra ACPI function support with little modification in asus-laptop.c Here is the hotkey enablement for Lenovo SL series laptop. This patch will enable the following hotkey: - Volumn Up - Volumn Down - Mute - Screen Lock (Fn+F2) - Battery Status (Fn+F3) - WLAN switch (Fn+F5) - Video output switch (Fn+F7) - Touchpad switch (Fn+F8) - Screen Magnifier (Fn+Space) The following function of Lenovo SL laptop is still need to be enabled: - Hotkey: KEY_SUSPEND (Fn+F4), KEY_SLEEP (Fn+F12), Dock Eject (Fn+F9) - Rfkill for bluetooth and wlan - LenovoCare LED - Hwmon for fan speed - Fingerprint scanner - Active Protection System Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22Input: pmouse - move Sentelic probe down the listTai-hwa Liang
commit 4a18b3ab6ed537b055e3fcfca64ab870b4f9acf0 upstream. Sentelic probes confuse IBM trackpoints so they stop responding to TP_READ_ID command. See: http://bugzilla.kernel.org/show_bug.cgi?id=14970 Let's move FSP detection lower so it is probed after trackpoint and others, just before we strat probing for Intellimouse Explorer. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22megaraid_sas: remove sysfs poll_mode_io world writeable permissionsBryn M. Reeves
commit bb7d3f24c71e528989501617651b669fbed798cb upstream. /sys/bus/pci/drivers/megaraid_sas/poll_mode_io defaults to being world-writable, which seems bad (letting any user affect kernel driver behavior). This turns off group and user write permissions, so that on typical production systems only root can write to it. Signed-off-by: Bryn M. Reeves <bmr@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22PCI/cardbus: Add a fixup hook and fix powerpcBenjamin Herrenschmidt
commit 2d1c861871d767153538a77c498752b36d4bb4b8 upstream The cardbus code creates PCI devices without ever going through the necessary fixup bits and pieces that normal PCI devices go through. There's in fact a commented out call to pcibios_fixup_bus() in there, it's commented because ... it doesn't work. I could make pcibios_fixup_bus() do the right thing on powerpc easily but I felt it cleaner instead to provide a specific hook pci_fixup_cardbus for which a weak empty implementation is provided by the PCI core. This fixes cardbus on powerbooks and probably all other PowerPC platforms which was broken completely for ever on some platforms and since 2.6.31 on others such as PowerBooks when we made the DMA ops mandatory (since those are setup by the fixups). Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22HID: add device IDs for new model of Apple Wireless KeyboardChristian Schuerer-Waldheim
commit 23aeb61e7e1f02fb0f3b8f9e798e75537ca1731d upstream. Added device IDs for the new model of the Apple Wireless Keyboard (November 2009). Signed-off-by: Christian Schuerer-Waldheim <csw@xray.at> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22reiserfs: truncate blocks not used by a writeJan Kara
commit ec8e2f7466ca370f5e09000ca40a71759afc9ac8 upstream. It can happen that write does not use all the blocks allocated in write_begin either because of some filesystem error (like ENOSPC) or because page with data to write has been removed from memory. We truncate these blocks so that we don't have dangling blocks beyond i_size. Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22V4L/DVB (13868): gspca - sn9c20x: Fix test of unsigned.Roel Kluin
commit c60503c1db76bd46577cc7ff4fafa033b675e0e5 upstream. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22ALSA: hda - Fix missing capture mixer for ALC861/660 codecsTakashi Iwai
commit c7a8eb103248a110cdbe0530d8c5ce987f099eee upstream. The capture-related mixer elements are missing with ALC861/ALC660 codecs when quirks are present, due to missing call of set_capture_mixer(). Reference: Novell bnc#567340 http://bugzilla.novell.com/show_bug.cgi?id=567340 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22mfd: Correct WM835x ISINK ramp time definesMark Brown
commit 9dffe2a32b0deef52605d50527c0d240b15cabf7 upstream. The constants used to specify ISINK ramp times for WM835x had the wrong shifts so that the on times applied to the off ramp and vice versa. The masks for the bitfields are correct. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22mfd: WM835x GPIO direction register is not lockedMark Brown
commit 8e6ba2dfa2d6c4691a83a63e211990a8bd7b788b upstream. No need to set the security key when writing to it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22x86: SGI UV: Fix mapping of MMIO registersMike Travis
commit fcfbb2b5facd65efa7284cc315225bfe3d1856c2 upstream. This fixes the problem of the initialization code not correctly mapping the entire MMIO space on a UV system. A side effect is the map_high() interface needed to be changed to accommodate different address and size shifts. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4B479202.7080705@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22edac: i5000_edac critical fix panic out of boundsTamas Vincze
commit 118f3e1afd5534c15f9701f33514186cfc841a27 upstream. EDAC MC0: INTERNAL ERROR: channel-b out of range (4 >= 4) Kernel panic - not syncing: EDAC MC0: Uncorrected Error (XEN) Domain 0 crashed: 'noreboot' set - not rebooting. This happens because FERR_NF_FBD bit 28 is not updated on i5000. Due to that, both bits 28 and 29 may be equal to one, returning channel = 3. As this value is invalid, EDAC core generates the panic. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14568 Signed-off-by: Tamas Vincze <tom@vincze.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22x86, apic: use physical mode for IBM summit platformsSuresh Siddha
commit dfea91d5a7c795fd6f4e1a97489a98e4e767463e upstream. Chris McDermott from IBM confirmed that hurricane chipset in IBM summit platforms doesn't support logical flat mode. Irrespective of the other things like apic_id's, total number of logical cpu's, Linux kernel should default to physical mode for this system. The 32-bit kernel does so using the OEM checks for the IBM summit platform. Add a similar OEM platform check for the 64bit kernel too. Otherwise the linux kernel boot can hang on this platform under certain bios/platform settings. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Tested-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Chris McDermott <lcm@linux.vnet.ibm.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22page allocator: update NR_FREE_PAGES only when necessaryKOSAKI Motohiro
commit 6ccf80eb15ccaca4d3f1ab5162b9ded5eecd9971 upstream. commit f2260e6b (page allocator: update NR_FREE_PAGES only as necessary) made one minor regression. if __rmqueue() was failed, NR_FREE_PAGES stat go wrong. this patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reported-by: Huang Shijie <shijie8@gmail.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22futexes: Remove rw parameter from get_futex_key()KOSAKI Motohiro
commit 7485d0d3758e8e6491a5c9468114e74dc050785d upstream. Currently, futexes have two problem: A) The current futex code doesn't handle private file mappings properly. get_futex_key() uses PageAnon() to distinguish file and anon, which can cause the following bad scenario: 1) thread-A call futex(private-mapping, FUTEX_WAIT), it sleeps on file mapping object. 2) thread-B writes a variable and it makes it cow. 3) thread-B calls futex(private-mapping, FUTEX_WAKE), it wakes up blocked thread on the anonymous page. (but it's nothing) B) Current futex code doesn't handle zero page properly. Read mode get_user_pages() can return zero page, but current futex code doesn't handle it at all. Then, zero page makes infinite loop internally. The solution is to use write mode get_user_page() always for page lookup. It prevents the lookup of both file page of private mappings and zero page. Performance concerns: Probaly very little, because glibc always initialize variables for futex before to call futex(). It means glibc users never see the overhead of this patch. Compatibility concerns: This patch has few compatibility issues. After this patch, FUTEX_WAIT require writable access to futex variables (read-only mappings makes EFAULT). But practically it's not a problem, glibc always initalizes variables for futexes explicitly - nobody uses read-only mappings. Reported-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Darren Hart <dvhltc@us.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Ulrich Drepper <drepper@gmail.com> LKML-Reference: <20100105162633.45A2.A69D9226@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22x86, mce: Thermal monitoring depends on APIC being enabledCyrill Gorcunov
commit 485a2e1973fd9f98c2c6776e66ac4721882b69e0 upstream. Add check if APIC is not disabled since thermal monitoring depends on it. As only apic gets disabled we should not try to install "thermal monitor" vector, print out that thermal monitoring is enabled and etc... Note that "Intel Correct Machine Check Interrupts" already has such a check. Also I decided to not add cpu_has_apic check into mcheck_intel_therm_init since even if it'll call apic_read on disabled apic -- it's safe here and allow us to save a few code bytes. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> LKML-Reference: <4B25FDC2.3020401@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22block: Fix incorrect reporting of partition alignmentMartin K. Petersen
commit 81744ee44ab2845c16ffd7d6f762f7b4a49a4750 upstream queue_sector_alignment_offset returned the wrong value which caused partitions to report an incorrect alignment_offset. Since offset calculation is needed several places it has been split into a separate helper function. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Tested-by: Mike Snitzer <snitzer@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22drm/i915: remove loop in Ironlake interrupt handlerZou Nan hai
commit c7c85101afd0cb8ce497456d12ee1cad4aad152f upstream. On Ironlake, there is an interrupt master control bit. With the bit disabled before clearing IIR, we do not need to handle extra interrupt in a loop. This patch removes the loop in Ironlake interrupt handler. It fixed irq lost issue on some Ironlake platforms. Signed-off-by: Zou Nan hai <Nanhai.zou@intel.com> Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22memcg: ensure list is empty at rmdirDaisuke Nishimura
commit fce66477578d081f19aef5ea218664ff7758c33a upstream. Current mem_cgroup_force_empty() only ensures mem->res.usage == 0 on success. But this doesn't guarantee memcg's LRU is really empty, because there are some cases in which !PageCgrupUsed pages exist on memcg's LRU. For example: - Pages can be uncharged by its owner process while they are on LRU. - race between mem_cgroup_add_lru_list() and __mem_cgroup_uncharge_common(). So there can be a case in which the usage is zero but some of the LRUs are not empty. OTOH, mem_cgroup_del_lru_list(), which can be called asynchronously with rmdir, accesses the mem_cgroup, so this access can cause a problem if it races with rmdir because the mem_cgroup might have been freed by rmdir. Actually, I saw a bug which seems to be caused by this race. [1530745.949906] BUG: unable to handle kernel NULL pointer dereference at 0000000000000230 [1530745.950651] IP: [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80 [1530745.950651] PGD 3863de067 PUD 3862c7067 PMD 0 [1530745.950651] Oops: 0002 [#1] SMP [1530745.950651] last sysfs file: /sys/devices/system/cpu/cpu7/cache/index1/shared_cpu_map [1530745.950651] CPU 3 [1530745.950651] Modules linked in: configs ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp nfsd nfs_acl auth_rpcgss exportfs autofs4 hidp rfcomm l2cap crc16 bluetooth lockd sunrpc ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp bnx2i cnic uio ipv6 cxgb3i cxgb3 mdio libiscsi_tcp libiscsi scsi_transport_iscsi dm_mirror dm_multipath scsi_dh video output sbs sbshc battery ac lp kvm_intel kvm sg ide_cd_mod cdrom serio_raw tpm_tis tpm tpm_bios acpi_memhotplug button parport_pc parport rtc_cmos rtc_core rtc_lib e1000 i2c_i801 i2c_core pcspkr dm_region_hash dm_log dm_mod ata_piix libata shpchp megaraid_mbox sd_mod scsi_mod megaraid_mm ext3 jbd uhci_hcd ohci_hcd ehci_hcd [last unloaded: freq_table] [1530745.950651] Pid: 19653, comm: shmem_test_02 Tainted: G M 2.6.32-mm1-00701-g2b04386 #3 Express5800/140Rd-4 [N8100-1065] [1530745.950651] RIP: 0010:[<ffffffff810fbc11>] [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80 [1530745.950651] RSP: 0018:ffff8803863ddcb8 EFLAGS: 00010002 [1530745.950651] RAX: 00000000000001e0 RBX: ffff8803abc02238 RCX: 00000000000001e0 [1530745.950651] RDX: 0000000000000000 RSI: ffff88038611a000 RDI: ffff8803abc02238 [1530745.950651] RBP: ffff8803863ddcc8 R08: 0000000000000002 R09: ffff8803a04c8643 [1530745.950651] R10: 0000000000000000 R11: ffffffff810c7333 R12: 0000000000000000 [1530745.950651] R13: ffff880000017f00 R14: 0000000000000092 R15: ffff8800179d0310 [1530745.950651] FS: 0000000000000000(0000) GS:ffff880017800000(0000) knlGS:0000000000000000 [1530745.950651] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [1530745.950651] CR2: 0000000000000230 CR3: 0000000379d87000 CR4: 00000000000006e0 [1530745.950651] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [1530745.950651] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [1530745.950651] Process shmem_test_02 (pid: 19653, threadinfo ffff8803863dc000, task ffff88038612a8a0) [1530745.950651] Stack: [1530745.950651] ffffea00040c2fe8 0000000000000000 ffff8803863ddd98 ffffffff810c739a [1530745.950651] <0> 00000000863ddd18 000000000000000c 0000000000000000 0000000000000000 [1530745.950651] <0> 0000000000000002 0000000000000000 ffff8803863ddd68 0000000000000046 [1530745.950651] Call Trace: [1530745.950651] [<ffffffff810c739a>] release_pages+0x142/0x1e7 [1530745.950651] [<ffffffff810c778f>] ? pagevec_move_tail+0x6e/0x112 [1530745.950651] [<ffffffff810c781e>] pagevec_move_tail+0xfd/0x112 [1530745.950651] [<ffffffff810c78a9>] lru_add_drain+0x76/0x94 [1530745.950651] [<ffffffff810dba0c>] exit_mmap+0x6e/0x145 [1530745.950651] [<ffffffff8103f52d>] mmput+0x5e/0xcf [1530745.950651] [<ffffffff81043ea8>] exit_mm+0x11c/0x129 [1530745.950651] [<ffffffff8108fb29>] ? audit_free+0x196/0x1c9 [1530745.950651] [<ffffffff81045353>] do_exit+0x1f5/0x6b7 [1530745.950651] [<ffffffff8106133f>] ? up_read+0x2b/0x2f [1530745.950651] [<ffffffff8137d187>] ? lockdep_sys_exit_thunk+0x35/0x67 [1530745.950651] [<ffffffff81045898>] do_group_exit+0x83/0xb0 [1530745.950651] [<ffffffff810458dc>] sys_exit_group+0x17/0x1b [1530745.950651] [<ffffffff81002c1b>] system_call_fastpath+0x16/0x1b [1530745.950651] Code: 54 53 0f 1f 44 00 00 83 3d cc 29 7c 00 00 41 89 f4 75 63 eb 4e 48 83 7b 08 00 75 04 0f 0b eb fe 48 89 df e8 18 f3 ff ff 44 89 e2 <48> ff 4c d0 50 48 8b 05 2b 2d 7c 00 48 39 43 08 74 39 48 8b 4b [1530745.950651] RIP [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80 [1530745.950651] RSP <ffff8803863ddcb8> [1530745.950651] CR2: 0000000000000230 [1530745.950651] ---[ end trace c3419c1bb8acc34f ]--- [1530745.950651] Fixing recursive fault but reboot is needed! The problem here is pages on LRU may contain pointer to stale memcg. To make res->usage to be 0, all pages on memcg must be uncharged or moved to another(parent) memcg. Moved page_cgroup have already removed from original LRU, but uncharged page_cgroup contains pointer to memcg withou PCG_USED bit. (This asynchronous LRU work is for improving performance.) If PCG_USED bit is not set, page_cgroup will never be added to memcg's LRU. So, about pages not on LRU, they never access stale pointer. Then, what we have to take care of is page_cgroup _on_ LRU list. This patch fixes this problem by making mem_cgroup_force_empty() visit all LRUs before exiting its loop and guarantee there are no pages on its LRU. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22revert "drivers/video/s3c-fb.c: fix clock setting for Samsung SoC Framebuffer"Mark Brown
commit eb29a5cc0b601c458bae9df2f6c3696d75c2d383 upstream. Fix divide by zero and broken output. Commit 600ce1a0fa ("fix clock setting for Samsung SoC Framebuffer") introduced a mandatory refresh parameter to the platform data for the S3C framebuffer but did not introduce any validation code, causing existing platforms (none of which have refresh set) to divide by zero whenever the framebuffer is configured, generating warnings and unusable output. Ben Dooks noted several problems with the patch: - The platform data supplies the pixclk directly and should already have taken care of the refresh rate. - The addition of a window ID parameter doesn't help since only the root framebuffer can control the pixclk. - pixclk is specified in picoseconds (rather than Hz) as the patch assumed. and suggests reverting the commit so do that. Without fixing this no mainline user of the driver will produce output. [akpm@linux-foundation.org: don't revert the correct bit] Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: InKi Dae <inki.dae@samsung.com> Cc: Kyungmin Park <kmpark@infradead.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22inotify: only warn once for inotify problemsEric Paris
commit 976ae32be45a736acd49215a7e4771ff91f161c3 upstream. inotify will WARN() if it finds that the idr and the fsnotify internals somehow got out of sync. It was only supposed to do this once but due to this stupid bug it would warn every single time a problem was detected. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22inotify: do not reuse watch descriptorsEric Paris
commit 9e572cc9877ee6c43af60778f6b8d5ba0692d935 upstream. Since commit 7e790dd5fc937bc8d2400c30a05e32a9e9eef276 ("inotify: fix error paths in inotify_update_watch") inotify changed the manor in which it gave watch descriptors back to userspace. Previous to this commit inotify acted like the following: inotify_add_watch(X, Y, Z) = 1 inotify_rm_watch(X, 1); inotify_add_watch(X, Y, Z) = 2 but after this patch inotify would return watch descriptors like so: inotify_add_watch(X, Y, Z) = 1 inotify_rm_watch(X, 1); inotify_add_watch(X, Y, Z) = 1 which I saw as equivalent to opening an fd where open(file) = 1; close(1); open(file) = 1; seemed perfectly reasonable. The issue is that quite a bit of userspace apparently relies on the behavior in which watch descriptors will not be quickly reused. KDE relies on it, I know some selinux packages rely on it, and I have heard complaints from other random sources such as debian bug 558981. Although the man page implies what we do is ok, we broke userspace so this patch almost reverts us to the old behavior. It is still slightly racey and I have patches that would fix that, but they are rather large and this will fix it for all real world cases. The race is as follows: - task1 creates a watch and blocks in idr_new_watch() before it updates the hint. - task2 creates a watch and updates the hint. - task1 updates the hint with it's older wd - task removes the watch created by task2 - task adds a new watch and will reuse the wd originally given to task2 it requires moving some locking around the hint (last_wd) but this should solve it for the real world and be -stable safe. As a side effect this patch papers over a bug in the lib/idr code which is causing a large number WARN's to pop on people's system and many reports in kerneloops.org. I'm working on the root cause of that idr bug seperately but this should make inotify immune to that issue. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18Linux 2.6.32.4v2.6.32.4Greg Kroah-Hartman
2010-01-18agp/intel-agp: Clear entire GTT on startupDavid Woodhouse
commit fc61901373987ad61851ed001fe971f3ee8d96a3 upstream. Some BIOSes fail to initialise the GTT, which will cause DMA faults when the IOMMU is enabled. We need to clear the whole thing to point at the scratch page, not just the part that Linux is going to use. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> [anholt: Note that this may also help with stability in the presence of driver bugs, by not drawing to memory we don't own] Signed-off-by: Eric Anholt <eric@anholt.net> Cc: Zhenyu Wang <zhenyuw@linux.intel.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18ipv6: skb_dst() can be NULL in ipv6_hop_jumbo().David S. Miller
commit 2570a4f5428bcdb1077622342181755741e7fa60 upstream. This fixes CERT-FI FICORA #341748 Discovered by Olli Jarva and Tuomo Untinen from the CROSS project at Codenomicon Ltd. Just like in CVE-2007-4567, we can't rely upon skb_dst() being non-NULL at this point. We fixed that in commit e76b2b2567b83448c2ee85a896433b96150c92e6 ("[IPV6]: Do no rely on skb->dst before it is assigned.") However commit 483a47d2fe794328d29950fe00ce26dd405d9437 ("ipv6: added net argument to IP6_INC_STATS_BH") put a new version of the same bug into this function. Complicating analysis further, this bug can only trigger when network namespaces are enabled in the build. When namespaces are turned off, the dev_net() does not evaluate it's argument, so the dereference would not occur. So, for a long time, namespaces couldn't be turned on unless SYSFS was disabled. Therefore, this code has largely been disabled except by people turning it on explicitly for namespace development. With help from Eugene Teo <eugene@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=yRusty Russell
commit d4703aefdbc8f9f347f6dcefcddd791294314eb7 upstream. powerpc applies relocations to the kcrctab. They're absolute symbols, but it's not completely unreasonable: other archs may too, but the relocation is often 0. http://lists.ozlabs.org/pipermail/linuxppc-dev/2009-November/077972.html Inspired-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18fix more leaks in audit_tree.c tag_chunk()Al Viro
commit b4c30aad39805902cf5b855aa8a8b22d728ad057 upstream. Several leaks in audit_tree didn't get caught by commit 318b6d3d7ddbcad3d6867e630711b8a705d873d7, including the leak on normal exit in case of multiple rules refering to the same chunk. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18fix braindamage in audit_tree.c untag_chunk()Al Viro
commit 6f5d51148921c242680a7a1d9913384a30ab3cbe upstream. ... aka "Al had badly fscked up when writing that thing and nobody noticed until Eric had fixed leaks that used to mask the breakage". The function essentially creates a copy of old array sans one element and replaces the references to elements of original (they are on cyclic lists) with those to corresponding elements of new one. After that the old one is fair game for freeing. First of all, there's a dumb braino: when we get to list_replace_init we use indices for wrong arrays - position in new one with the old array and vice versa. Another bug is more subtle - termination condition is wrong if the element to be excluded happens to be the last one. We shouldn't go until we fill the new array, we should go until we'd finished the old one. Otherwise the element we are trying to kill will remain on the cyclic lists... That crap used to be masked by several leaks, so it was not quite trivial to hit. Eric had fixed some of those leaks a while ago and the shit had hit the fan... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18mac80211: fix skb buffering issue (and fixes to that)Johannes Berg
This is a backport of the mainline patches cf0277e714a0db302a8f80e1b85fd61c32cf00b3 045cfb71a3901005bf6dcedae98cecb3360a0bfc b49bb574e44226b332c28439999d196ddec2f643 Here is the description of the first of those patches (the other two just fixed bugs added by that patch): Since I removed the master netdev, we've been keeping internal queues only, and even before that we never told the networking stack above the virtual interfaces about congestion. This means that packets are queued in mac80211 and the upper layers never know, possibly leading to memory exhaustion and other problems. This patch makes all interfaces multiqueue and uses ndo_select_queue to put the packets into queues per AC. Additionally, when the driver stops a queue, we now stop all corresponding queues for the virtual interfaces as well. The injection case will use VO by default for non-data frames, and BE for data frames, but downgrade any data frames according to ACM. It needs to be fleshed out in the future to allow chosing the queue/AC in radiotap. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18kernel/sysctl.c: fix stable merge error in NOMMU mmap_min_addrMike Frysinger
Stable commit 0399123f3dcce1a515d021107ec0fb4413ca3efa didn't match the original upstream commit. The CONFIG_MMU check was added much too early in the list disabling a lot of proc entries in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18libertas: Remove carrier signaling from the scan codeSamuel Ortiz
commit 659c8e5243caf14564155ad8421404f044dd8031 upstream. There is no reason to signal a carrier off when doing a 802.11 scan. Cc: Holger Schurig <holgerschurig@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18drm/i915: remove render reclock supportJesse Barnes
commit cda9d05c499093c67b4a376a15009923acc2127a upstream. This code generally fails to adjust the render clock, and when it does, it conflicts with some other register settings and can cause problems. So remove this code altogether. I'm reworking it now to do the right thing, but the only bit it will share is the VBT check for whether reclocking is supported, so I'm leaving that bit. Reverts most of 652c393a3368af84359da37c45afc35a91144960 ("add dynamic clock frequency control"), though for many the regressions showed up in the later 181a5336d6cc836f05507410d66988c483ad0154 ("Fix render reclock availability detection"). Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18mac80211: add missing sanity checks for action framesFelix Fietkau
commit d79074488083ec0d7ecd15352192dc1631f25643 upstream. Various missing sanity checks caused rejected action frames to be interpreted as channel switch announcements, which can cause a client mode interface to switch away from its operating channel, thereby losing connectivity. This patch ensures that only spectrum management action frames are processed by the CSA handling function and prevents rejected action frames from getting processed by the MLME code. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18iwl: off by one bugDan Carpenter
commit 8a9ac160e844c7ce8074f6aa531feefb4acdee7c upstream. tid is used as an array offset. agg = &priv->stations[sta_id].tid[tid].agg; iwl4965_tx_status_reply_tx(priv, agg, tx_resp, txq_id, index); It should be limitted to MAX_TID_COUNT - 1; struct iwl_tid_data tid[MAX_TID_COUNT]; regards, dan carpenter Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18cfg80211: fix syntax error on user regulatory hintsLuis R. Rodriguez
commit e12822e1d3fface0d9e1095c5177e10141bd6bd6 upstream. This fixes a syntax error when setting up the user regulatory hint. This change yields the same exact binary object though so it ends up just being a syntax typo fix, fortunately. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18ath5k: Fix eeprom checksum check for custom sized eepromsLuis R. Rodriguez
commit 359207c687cc8f4f9845c8dadd0d6dabad44e584 upstream. Commit 8bf3d79bc401ca417ccf9fc076d3295d1a71dbf5 enabled EEPROM checksum checks to avoid bogus bug reports but failed to address updating the code to consider devices with custom EEPROM sizes. Devices with custom sized EEPROMs have the upper limit size stuffed in the EEPROM. Use this as the upper limit instead of the static default size. In case of a checksum error also provide back the max size and whether or not this was the default size or a custom one. If the EEPROM is busted we add a failsafe check to ensure we don't loop forever or try to read bogus areas of hardware. This closes bug 14874 http://bugzilla.kernel.org/show_bug.cgi?id=14874 Cc: David Quan <david.quan@atheros.com> Cc: Stephen Beahm <stephenbeahm@comcast.net> Reported-by: Joshua Covington <joshuacov@googlemail.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18iwlwifi: fix iwl_queue_used bug when read_ptr == write_ptrZhu Yi
commit c8106d7625a58ee4387cb2efe3e82320ad44b467 upstream. When txq read_ptr equals to write_ptr, iwl_queue_used should always return false. Because there is no used TFD in this case. This is a complementary fix to the fix already included in commit "iwl3945: fix panic in iwl3945 driver". Both fixes are needed to address the panic below. This problem was discussed on linux-wireless in http://thread.gmane.org/gmane.linux.kernel.wireless.general/43568 <1>[ 7290.414172] IP: [<ffffffffa0dd53a1>] iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <4>[ 7290.414205] PGD 0 <1>[ 7290.414214] Thread overran stack, or stack corrupted <0>[ 7290.414229] Oops: 0002 [#1] PREEMPT SMP <0>[ 7290.414246] last sysfs file: /sys/devices/platform/coretemp.1/temp1_input <4>[ 7290.414265] CPU 0 <4>[ 7290.414274] Modules linked in: af_packet nfsd usb_storage usb_libusual cpufreq_powersave exportfs cpufreq_conservative iwl3945 nfs cpufreq_userspace snd_hda_codec_realtek acpi_cpufreq uvcvideo lockd iwlcore snd_hda_intel joydev coretemp nfs_acl videodev snd_hda_codec mac80211 v4l1_compat snd_hwdep sbp2 v4l2_compat_ioctl32 uhci_hcd psmouse auth_rpcgss ohci1394 cfg80211 ehci_hcd video ieee1394 snd_pcm serio_raw battery ac nvidia(P) usbcore output sunrpc evdev lirc_ene0100 snd_page_alloc rfkill tg3 libphy fuse lzo lzo_decompress lzo_compress <6>[ 7290.414486] Pid: 0, comm: swapper Tainted: P 2.6.32-rc8-wl #213 Aspire 5720 <6>[ 7290.414507] RIP: 0010:[<ffffffffa0dd53a1>] [<ffffffffa0dd53a1>] iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <6>[ 7290.414541] RSP: 0018:ffff880002203d60 EFLAGS: 00010246 <6>[ 7290.414557] RAX: 000000000000004f RBX: ffff880064c11600 RCX: 0000000000000013 <6>[ 7290.414576] RDX: ffffffffa0ddcf20 RSI: ffff8800512b7008 RDI: 0000000000000038 <6>[ 7290.414596] RBP: ffff880002203dd0 R08: 0000000000000000 R09: 0000000000000100 <6>[ 7290.414616] R10: 0000000000000001 R11: 0000000000000000 R12: 00000000000000a0 <6>[ 7290.414635] R13: 0000000000000002 R14: 0000000000000013 R15: 0000000000020201 <6>[ 7290.414655] FS: 0000000000000000(0000) GS:ffff880002200000(0000) knlGS:0000000000000000 <6>[ 7290.414677] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b <6>[ 7290.414693] CR2: 0000000000000041 CR3: 0000000001001000 CR4: 00000000000006f0 <6>[ 7290.414712] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 <6>[ 7290.414732] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 <4>[ 7290.414752] Process swapper (pid: 0, threadinfo ffffffff81524000, task ffffffff81528b60) <0>[ 7290.414772] Stack: <4>[ 7290.414780] ffff880002203da0 0000000000000046 0000000000000000 0000000000000046 <4>[ 7290.414804] <0> 0000000000000282 0000000000000282 0000000000000282 ffff880064c12010 <4>[ 7290.414830] <0> ffff880002203db0 ffff880064c11600 ffff880064c12e50 ffff8800512b7000 <0>[ 7290.414858] Call Trace: <0>[ 7290.414867] <IRQ> <4>[ 7290.414884] [<ffffffffa0dc8c47>] iwl3945_irq_tasklet+0x657/0x1740 [iwl3945] <4>[ 7290.414910] [<ffffffff8138fc60>] ? _spin_unlock+0x30/0x60 <4>[ 7290.414931] [<ffffffff81049a21>] tasklet_action+0x101/0x110 <4>[ 7290.414950] [<ffffffff8104a3d0>] __do_softirq+0xc0/0x160 <4>[ 7290.414968] [<ffffffff8100d01c>] call_softirq+0x1c/0x30 <4>[ 7290.414986] [<ffffffff8100eff5>] do_softirq+0x75/0xb0 <4>[ 7290.415003] [<ffffffff81049ee5>] irq_exit+0x95/0xa0 <4>[ 7290.415020] [<ffffffff8100e547>] do_IRQ+0x77/0xf0 <4>[ 7290.415038] [<ffffffff8100c7d3>] ret_from_intr+0x0/0xf <0>[ 7290.415052] <EOI> <4>[ 7290.415067] [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415087] [<ffffffff81234f04>] ? acpi_idle_enter_bm+0x27a/0x2a5 <4>[ 7290.415107] [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415130] [<ffffffff812c11f3>] ? cpuidle_idle_call+0x93/0xf0 <4>[ 7290.415149] [<ffffffff8100b0d7>] ? cpu_idle+0xa7/0x110 <4>[ 7290.415168] [<ffffffff8137b3d5>] ? rest_init+0x75/0x80 <4>[ 7290.415187] [<ffffffff8158cd0a>] ? start_kernel+0x3a7/0x3b3 <4>[ 7290.415206] [<ffffffff8158c315>] ? x86_64_start_reservations+0x125/0x129 <4>[ 7290.415227] [<ffffffff8158c3fd>] ? x86_64_start_kernel+0xe4/0xeb <0>[ 7290.415243] Code: 00 41 39 ce 0f 8d e8 01 00 00 48 8b 47 40 48 63 d2 48 69 d2 98 00 00 00 4c 8b 04 02 48 c7 c2 20 cf dd a0 49 8d 78 38 49 8d 40 4f <c6> 47 09 00 c6 47 0c 00 c6 47 0f 00 c6 47 12 00 c6 47 15 00 49 <1>[ 7290.415382] RIP [<ffffffffa0dd53a1>] iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <4>[ 7290.415410] RSP <ffff880002203d60> <0>[ 7290.415421] CR2: 0000000000000041 <4>[ 7290.415436] ---[ end trace ec46807277caa515 ]--- <0>[ 7290.415450] Kernel panic - not syncing: Fatal exception in interrupt <4>[ 7290.415468] Pid: 0, comm: swapper Tainted: P D 2.6.32-rc8-wl #213 <4>[ 7290.415486] Call Trace: <4>[ 7290.415495] <IRQ> [<ffffffff8138c040>] panic+0x7d/0x13a <4>[ 7290.415519] [<ffffffff8101071a>] oops_end+0xda/0xe0 <4>[ 7290.415538] [<ffffffff8102e1ea>] no_context+0xea/0x250 <4>[ 7290.415557] [<ffffffff81038991>] ? select_task_rq_fair+0x511/0x780 <4>[ 7290.415578] [<ffffffff8102e475>] __bad_area_nosemaphore+0x125/0x1e0 <4>[ 7290.415597] [<ffffffff81038d0c>] ? __enqueue_entity+0x7c/0x80 <4>[ 7290.415616] [<ffffffff81039201>] ? enqueue_task_fair+0x111/0x150 <4>[ 7290.415636] [<ffffffff8102e53e>] bad_area_nosemaphore+0xe/0x10 <4>[ 7290.415656] [<ffffffff8102e8fa>] do_page_fault+0x26a/0x320 <4>[ 7290.415674] [<ffffffff813905df>] page_fault+0x1f/0x30 <4>[ 7290.415697] [<ffffffffa0dd53a1>] ? iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <4>[ 7290.415723] [<ffffffffa0dc8c47>] iwl3945_irq_tasklet+0x657/0x1740 [iwl3945] <4>[ 7290.415746] [<ffffffff8138fc60>] ? _spin_unlock+0x30/0x60 <4>[ 7290.415764] [<ffffffff81049a21>] tasklet_action+0x101/0x110 <4>[ 7290.415783] [<ffffffff8104a3d0>] __do_softirq+0xc0/0x160 <4>[ 7290.415801] [<ffffffff8100d01c>] call_softirq+0x1c/0x30 <4>[ 7290.415818] [<ffffffff8100eff5>] do_softirq+0x75/0xb0 <4>[ 7290.415835] [<ffffffff81049ee5>] irq_exit+0x95/0xa0 <4>[ 7290.415852] [<ffffffff8100e547>] do_IRQ+0x77/0xf0 <4>[ 7290.415869] [<ffffffff8100c7d3>] ret_from_intr+0x0/0xf <4>[ 7290.415883] <EOI> [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415911] [<ffffffff81234f04>] ? acpi_idle_enter_bm+0x27a/0x2a5 <4>[ 7290.415931] [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415952] [<ffffffff812c11f3>] ? cpuidle_idle_call+0x93/0xf0 <4>[ 7290.415971] [<ffffffff8100b0d7>] ? cpu_idle+0xa7/0x110 <4>[ 7290.415989] [<ffffffff8137b3d5>] ? rest_init+0x75/0x80 <4>[ 7290.416007] [<ffffffff8158cd0a>] ? start_kernel+0x3a7/0x3b3 <4>[ 7290.416026] [<ffffffff8158c315>] ? x86_64_start_reservations+0x125/0x129 <4>[ 7290.416047] [<ffffffff8158c3fd>] ? x86_64_start_kernel+0xe4/0xeb Reported-by: Maxim Levitsky <maximlevitsky@gmail.com> Tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18xen: fix hang on suspend.Ian Campbell
commit c5cae661d6cf808b6984762f763261adf35f3eb7 upstream. In 65f63384 "xen: improve error handling in do_suspend" I said: - xs_suspend()/xs_resume() and dpm_suspend_noirq()/dpm_resume_noirq() were not nested in the obvious way. and changed the ordering of the calls as so: BEFORE AFTER xs_suspend dpm_suspend_noirq dpm_suspend_noirq xs_suspend *SUSPEND* *SUSPEND* dpm_resume_noirq dpm_resume_noirq xs_resume xs_resume Clearly this is not an improvement and I was talking rubbish. In particular the new ordering is susceptible to a hang if a xenstore write is in progress at the point at which the suspend kicks in. When the suspend process calls xs_suspend it tries to take the request_mutex but if a write is in progress it could be looping in xenbus_xs.c:read_reply() waiting for something to arrive on &xs_state.reply_list while holding the request_mutex (taken in the caller of read_reply). However if we have done dpm_suspend_noirq before xs_suspend then we won't get any more xenstore interrupts and process_msg() will never be woken up to add anything to the reply_list. Fix this by calling xs_suspend before dpm_suspend_noirq. If dpm_suspend_noirq fails then make sure we go through the xs_suspend_cancel() code path. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18quota: Fix dquot_transfer for filesystems different from ext4Jan Kara
commit 05b5d898235401c489c68e1f3bc5706a29ad5713 upstream. Commit fd8fbfc1 modified the way we find amount of reserved space belonging to an inode. The amount of reserved space is checked from dquot_transfer and thus inode_reserved_space gets called even for filesystems that don't provide get_reserved_space callback which results in a BUG. Fix the problem by checking get_reserved_space callback and return 0 if the filesystem does not provide it. CC: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18hwmon: (adt7462) Fix pin 28 monitoringRoger Blofeld
commit bb595c923bc51dff9cdd112de18deb57ac7945d2 upstream. The ADT7462_PIN28_VOLT value is a 4-bit field, so the corresponding shift must be 4. Signed-off-by: Roger Blofeld <blofeldus@yahoo.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18hwmon: (coretemp) Fix TjMax for Atom N450/D410/D510 CPUsYong Wang
commit 1fe63ab47a617ee95f562eaa7ddbbc59981ff8c6 upstream. The max junction temperature of Atom N450/D410/D510 CPUs is 100 degrees Celsius. Since these CPUs are always coupled with Intel NM10 chipset in one package, the best way to verify whether an Atom CPU is N450/D410/D510 is to check the host bridge device. Signed-off-by: Yong Wang <yong.y.wang@intel.com> Acked-by: Huaxu Wan <huaxu.wan@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
